Date/Time: Sun, 19 Jan 2025 15:27:37 +0000
Current Version 1727
View Count: 1100
[2018-04-16 16:05:25] |
User73463 - Posts: 21 |
Current Version 1727 Tool Configs, Fibonacci Fan Config Option "Extend" does not exist as a check box. It is not showing up as an option. Thanks.
[2018-04-16 19:19:39] |
John - SC Support - Posts: 37327 |
Sorry, after reviewing what was done, we found that the tool is working correctly in this recent version. There was a bug previously where the Fibonacci Fan was incorrectly showing the Extend option. It did allow for the fan to start out not being extended, but it would not cycle correctly from that point forward. Therefore it was changed to not display until there was a proper extension point available. In this current version, in order to allow extensions to take place, you must first Cut the drawing. After which, you can cycle the Extend option on/off. The previous post has been removed to avoid confusion. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-17 02:46:37] |
The change in the Fibonacci Fan is very frustrating. I use the Fan all the time for my trading. I always use the extension and makes my job easier. That means more extra work and time. Why? Thanks.
[2018-04-17 14:15:28] |
We are actually fixing this right now. It just requires some changes at a lower level. Sorry for the trouble.
[2018-04-17 16:39:57] |
The Fibonacci and Gann fan have been updated to allow for Extend from the beginning of the drawing and will show up as an option in the configuration. This will show up in the next release - 1733. Check the main site for when this gets released and then update to that version for these changes. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
