Date/Time: Sun, 19 Jan 2025 12:20:44 +0000
[User Discussion] - Vertical Grid Lines
View Count: 999
[2018-04-09 13:00:14]
mkata - Posts: 103
I believe the Vertical Grid Lines need to be shifted one bar to the right.
Example
With the Vertical Grid Lines set to 10-bars and using 1-minute data and the bar numbering study to count every bar
you can clearly see the following:
The first segment of the day has 9 bars labeled 1 thru 9.
The second and subsequent segments have 10 bars labeled 0 thru 9.
By shifting the Grid Lines one bar to the right, every segment will have 10 bars labeled 1 thru 10.
[2018-04-12 13:59:06]
mkata - Posts: 103
Is this being looked at or ignored?
[2018-04-12 16:29:28]
There is no issue. We are declining this further.
