Date/Time: Sun, 19 Jan 2025 12:34:45 +0000
Still only 10/10 levels on DOM
View Count: 2195
[2018-04-05 20:07:14]
User132748 - Posts: 159
I use CQG fix datafeed via AMP Futures account. I have full DOM on WTI crude (thanks for that) but still just 10/10 levels on all other contracts. Im know CQG provides full DOM for all of them, but Sierra still shows only 10/10. What is the reason for that and when/if will it change? Thanks
[2018-04-05 22:11:53]
Open the market depth window with this command:
File Menu: Open Market Depth Window (File)
How many levels do you see there for one of the particular symbols you only supposedly have 10 levels for.
Date Time Of Last Edit: 2018-04-05 22:12:00
[2018-04-06 11:23:45]
I have 10/10 levels for NQ here as example (screenshot). Same for all other instruments. Only Crude has ca. 500/500 levels
imagedepth.JPG / V - Attached On 2018-04-06 11:21:16 UTC - Size: 59.14 KB - 480 views
[2018-04-06 18:08:47]
That market depth window indicates that CQG is only providing 10 levels for that particular symbol. This is not within our control.
Date Time Of Last Edit: 2018-04-06 18:08:54
[2018-04-06 18:38:37]
I checked exactly same datafeed (CQG FIX TRADING) on other platforms (inluding CQG web based client) and I have full DOM for all instruments so you're suggesting CQG is somehow detecting that when used in SierraChart it should provide only 10 levels??
In fact I was worried your answer would be to use Sierra Data Feed instead CQG, but hopefully there is some other solution to this situation as Im sure CQG datafeed provides right data.
[2018-04-06 18:59:26]
Clearly CQG is not providing more than 10 levels . This is definitely not within our control.
Reconnect the data feed:
After about 20 seconds provide a copy of the Message Log following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Use the Send for Analysis method and let us know when you have done that.
We will ask CQG about this.
Date Time Of Last Edit: 2018-04-06 18:59:55
[2018-04-09 18:52:52]
I sent the Message Log with Send For Analysis button and also attached here as private file.
Date Time Of Last Edit: 2018-04-09 18:57:24
[2018-04-09 19:07:19]
We have contacted CQG about this.
[2018-04-09 21:25:34]
This is the response from CQG:
Just confirmed that CQG only support 10 levels of DOM.
Regards,
API Support Technician
[2018-04-10 05:08:48]
OK so why do I see full DOM for WTI Crude? 500 levels up and 500 down. Is it their oversight or just one instrument with full DOM as some advertising/special offer...?
[2018-04-10 05:16:40]
Obviously we cannot answer that question.
This thread is resolved.
