Date/Time: Sun, 19 Jan 2025 09:22:28 +0000
IB connection issues following SC upgrade
View Count: 1774
[2018-03-23 07:06:28] |
User474090 - Posts: 5 |
I am having connection problems with IB. Have had no problems in the past. This is what has happened in chronological sequence: 1. I updated to latest SC yesterday. 2. When I tried to connect to IB with updated SC I could not make a connection. Seemed to be suggesting I needed to update IB. 3. This morning I updated IB from build 956 (which had been connecting perfectly with preupdate SC) to IB 970.1a which as of today was the latest IB build. 4. Tried to connect latest SC with latest IB and again could not make a connection. 5. Spent much time today talking to IB help and checking all settings at their end. Outcome: not there issue. Everything is fine . IB suggested I contact SC support. 6. I have checked SC support documentation and all seems to be in order as far as I can see. 7. As I am not making any progress and need to sort this matter asap I have copied in my log below. 8. I have also sent the “ send for analysis” log report 9. Help please. 10. Log below Reading Internal Order ID file. | 2018-03-23 14:58:06 Reading Trade Orders file. | 2018-03-23 14:58:06 Reading Trade Positions file. | 2018-03-23 14:58:06 Listening on UDP port 22903. | 2018-03-23 14:58:06 Software version: 1721 64-bit | 2018-03-23 14:58:06 Usage end date: 2018-08-28 | 2018-03-23 14:58:06 Enabled for: Advanced Features. | 2018-03-23 14:58:06 Enabled for: Advanced Features 2. | 2018-03-23 14:58:06 Enabled for: Sierra Chart Historical Data Service. | 2018-03-23 14:58:06 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-03-23 14:58:06 Current selected Data/Trading service: Interactive Brokers | 2018-03-23 14:58:06 Chart Update Interval: 500 | 2018-03-23 14:58:06 Time Zone: +11:00:00 (AEST+10AEDT+01,M10.1.0/02:00,M4.1.0/03:00) | 2018-03-23 14:58:06 2018-03-23 13:58:06 Local computer time | 2018-03-23 14:58:06 2018-03-23 03:58:06 Local computer time in UTC | 2018-03-23 14:58:06 2018-03-23 14:58:06 Local computer time in SC Time Zone | 2018-03-23 14:58:06 2018-03-23 03:58:05 Server time in UTC | 2018-03-23 14:58:06 Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-03-23 14:58:06 Program path: C:\SierraChartAust\ | 2018-03-23 14:58:06 Data Files path: C:\SierraChartAust\Data\ | 2018-03-23 14:58:06 OS Version Number: 10.0 | 2018-03-23 14:58:06 Locale Setting: C | 2018-03-23 14:58:06 Checking for new symbol settings for service code interactive_brokers.trading | 2018-03-23 14:58:06 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-03-23 14:58:06 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-03-23 14:58:06 Received 5 login tokens. | 2018-03-23 14:58:07 Symbol settings are up-to-date for interactive_brokers.trading | 2018-03-23 14:58:08 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 14:58:10 Socket (5) | Creating socket. | 2018-03-23 14:58:10 Socket (5) | Connecting to IP: 127.0.0.1. | 2018-03-23 14:58:10 Interactive Brokers | Sending API sign: API | 2018-03-23 14:58:10 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 14:58:10 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-03-23 14:58:12 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-03-23 14:58:12 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-03-23 14:58:12 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 14:58:12 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-03-23 14:58:12 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-03-23 14:58:13 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-03-23 14:58:13 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-03-23 14:58:13 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 14:58:13 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-03-23 14:58:13 Interactive Brokers | TWS server version: 136 | 2018-03-23 14:58:15 Interactive Brokers | TWS time: 20180323 13:58:14 AEST | 2018-03-23 14:58:15 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 14:58:15 Socket (5) | Socket gracefully closed by remote side. | 2018-03-23 14:58:15 Socket (5) | Received socket Close event. | 2018-03-23 14:58:15 Socket (5) | Initiating close of socket by core. | 2018-03-23 14:58:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 14:58:15 Socket (5) | Performed shutdown. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2018-03-23 14:58:15 * Socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 14:58:15 Socket (5) | Closed. | 2018-03-23 14:58:15 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 14:58:15 Interactive Brokers | Disconnected. | 2018-03-23 14:58:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 14:58:15 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 14:58:18 Socket (6) | Creating socket. | 2018-03-23 14:58:18 Socket (6) | Connecting to IP: 127.0.0.1. | 2018-03-23 14:58:18 Interactive Brokers | Sending API sign: API | 2018-03-23 14:58:18 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 14:58:18 Service connection timed out. Will disconnect and retry. | 2018-03-23 14:59:18 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 14:59:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 14:59:18 Socket (6) | Initiating close of socket by core. | 2018-03-23 14:59:18 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 14:59:18 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 14:59:18 * Socket (6) | Shutdown started. Waiting for graceful close. | 2018-03-23 14:59:18 Interactive Brokers | Disconnected. | 2018-03-23 14:59:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 14:59:18 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 14:59:21 Socket (8) | Creating socket. | 2018-03-23 14:59:21 Socket (8) | Connecting to IP: 127.0.0.1. | 2018-03-23 14:59:21 Interactive Brokers | Sending API sign: API | 2018-03-23 14:59:21 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 14:59:21 Interactive Brokers | TWS server version: 136 | 2018-03-23 14:59:30 Interactive Brokers | TWS time: 20180323 13:59:30 AEST | 2018-03-23 14:59:30 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 14:59:30 Socket (8) | Socket gracefully closed by remote side. | 2018-03-23 14:59:31 Socket (8) | Received socket Close event. | 2018-03-23 14:59:31 Socket (8) | Initiating close of socket by core. | 2018-03-23 14:59:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 14:59:31 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 14:59:31 Socket (8) | Performed shutdown. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2018-03-23 14:59:31 * Socket (8) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 14:59:31 Socket (8) | Closed. | 2018-03-23 14:59:31 Interactive Brokers | Disconnected. | 2018-03-23 14:59:31 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 14:59:31 Socket (6) | Socket gracefully closed by remote side. | 2018-03-23 14:59:33 Socket (6) | Closed. | 2018-03-23 14:59:33 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 14:59:34 Socket (9) | Creating socket. | 2018-03-23 14:59:34 Socket (9) | Connecting to IP: 127.0.0.1. | 2018-03-23 14:59:34 Interactive Brokers | Sending API sign: API | 2018-03-23 14:59:34 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 14:59:34 |
[2018-03-23 08:20:39] |
We are going to make a small change to see if it helps. We think it should. Give us about 10 minutes. We are going to then put out version 1723 and update this thread. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-23 08:39:47] |
We want you to update to the "Prerelease" 1723 following the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-23 08:57:14] |
One thing that it appears like from the Message Log is that you do not have a trusted IP address set up in TWS. Definitely do that as explained at step 9 here: Interactive Brokers Trading Service: Setup Instructions Do not manually accept the connection. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-23 12:06:57] |
User479108 - Posts: 19 |
SC v.1720 working perfectly with regard to connecting and to remain connected to InteractiveBrokers AFTER loading a chartbook. .. all versions past 1720 (including 1723) are disconnecting and then trying to reconnect then failing and then retrying etc etc AFTER a chartbook is loaded. Without a chartbook loaded SC by itself does connect and remain connected. The following is Message Log from v.1720 if that helps .. ( Message Log removed) Date Time Of Last Edit: 2018-03-23 16:12:55
[2018-03-23 16:12:09] |
The Message Log is of no use to us from an older version. We need to see the Message Log from 1722 and higher.
[2018-03-23 20:18:10] |
golding - Posts: 18 |
I'm having similar issues with both the latest ( 970.1a mar 20) & the current beta IB TWS. Both will connect to 1720, but drop data feed connectivity for 1721, 1722, 1723; tried 1722 with and without chartbooks, same loss of connectivity |
[2018-03-23 20:29:26] |
Actually, we want to be abundantly clear here. This problem is an Interactive Brokers TWS issue. It only shows the substandard and poor quality of their software. Once again we are wasting our time with trader workstation problems and using hacks to solve this. This is completely ridiculous. Anyway we are going to come up with a hack solution to solve this. Totally ridiculous we have to do this. And it is pointless for us to contact those idiots at Interactive Brokers because they are not going to pay proper attention to what we say and solve the problem. And if the hack which we will release later today does actually solve this, and you would have to confirm this, then this really does confirm the problem is indeed on their side. And for the record we have done so far is a hack. It is just that we have not considered all of the different possibilities that the hack needs to be applied. That is the problem. And it just occurred to us, in the last couple of hours, why the hack we used previously, was not solving the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-23 20:31:48
[2018-03-23 20:41:55] |
anything SC can do to help us out of this impasse wud be most appreciated .. currently the SC v.1720 does 'work' so I hope that SC version doesnt 'go-away' anytime soon .. I will send along a message log for 1723 possible as early as this afternoon (1700 ET USA)
[2018-03-23 20:52:17] |
Here is SC v.1723 with 'No Chartbooks loaded' .. SC data connection is showing green indicating 'to me' that it is connected to IB TWS Reading Internal Order ID file. | 2018-03-23 16:48:12 Reading Trade Orders file. | 2018-03-23 16:48:13 Reading Trade Positions file. | 2018-03-23 16:48:13 Listening on UDP port 22903. | 2018-03-23 16:48:13 Software version: 1723 64-bit | 2018-03-23 16:48:13 Usage end date: 2018-04-14 | 2018-03-23 16:48:13 Enabled for: Advanced Features. | 2018-03-23 16:48:13 Enabled for: Advanced Features 2. | 2018-03-23 16:48:13 Enabled for: Sierra Chart Historical Data Service. | 2018-03-23 16:48:13 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-03-23 16:48:13 Current selected Data/Trading service: Interactive Brokers | 2018-03-23 16:48:13 Chart Update Interval: 500 | 2018-03-23 16:48:13 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-03-23 16:48:13 2018-03-23 16:48:13 Local computer time | 2018-03-23 16:48:13 2018-03-23 20:48:13 Local computer time in UTC | 2018-03-23 16:48:13 2018-03-23 16:48:13 Local computer time in SC Time Zone | 2018-03-23 16:48:13 2018-03-23 20:48:11 Server time in UTC | 2018-03-23 16:48:13 Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-03-23 16:48:13 Program path: E:\SC\LWM\SC1 (IB)\ | 2018-03-23 16:48:13 Data Files path: E:\SC\LWM\SC1 (IB)\Data\ | 2018-03-23 16:48:13 OS Version Number: 10.0 | 2018-03-23 16:48:13 Locale Setting: C | 2018-03-23 16:48:13 Created the DTC Protocol server. | 2018-03-23 16:48:13 DTC Protocol Server listening on port 11099. | 2018-03-23 16:48:13 Created the DTC Protocol historical data server. | 2018-03-23 16:48:13 HD Server Manager | Listening on port 11098 | 2018-03-23 16:48:13 Checking for new symbol settings for service code interactive_brokers.trading | 2018-03-23 16:48:13 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-03-23 16:48:13 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-03-23 16:48:13 Requesting symbol settings for service code interactive_brokers.trading. Overwrite = on. | 2018-03-23 16:48:13 Received 5 login tokens. | 2018-03-23 16:48:13 Symbol settings received. | 2018-03-23 16:48:14 Processed 1393 symbol settings. | 2018-03-23 16:48:14 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:17 Starting TWS auto-login thread. | 2018-03-23 16:48:17 Socket (5) | Creating socket. | 2018-03-23 16:48:17 Socket (5) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:17 TWS auto-login thread ending. | 2018-03-23 16:48:17 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:18 * Socket (5) | Initiating close of socket by core. | 2018-03-23 16:48:18 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:18 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:18 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:18 Socket (5) | Closed. | 2018-03-23 16:48:18 Interactive Brokers | Disconnected. | 2018-03-23 16:48:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:18 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-03-23 16:48:18 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-03-23 16:48:18 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-03-23 16:48:18 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:48:18 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-03-23 16:48:18 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-03-23 16:48:19 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-03-23 16:48:19 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-03-23 16:48:19 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:48:19 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-03-23 16:48:19 Starting TWS auto-login thread. | 2018-03-23 16:48:21 TWS auto-login thread ending. | 2018-03-23 16:48:21 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:21 Socket (6) | Creating socket. | 2018-03-23 16:48:21 Socket (6) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:21 Socket (6) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:22 * Socket (6) | Initiating close of socket by core. | 2018-03-23 16:48:22 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:22 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:22 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:22 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:22 Socket (6) | Closed. | 2018-03-23 16:48:22 Interactive Brokers | Disconnected. | 2018-03-23 16:48:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:22 Starting TWS auto-login thread. | 2018-03-23 16:48:25 TWS auto-login thread ending. | 2018-03-23 16:48:25 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:25 Socket (7) | Creating socket. | 2018-03-23 16:48:25 Socket (7) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:25 Socket (7) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:26 * Socket (7) | Initiating close of socket by core. | 2018-03-23 16:48:26 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:26 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:26 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:26 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:26 Socket (7) | Closed. | 2018-03-23 16:48:26 Interactive Brokers | Disconnected. | 2018-03-23 16:48:26 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:26 Starting TWS auto-login thread. | 2018-03-23 16:48:29 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:29 Socket (8) | Creating socket. | 2018-03-23 16:48:29 Socket (8) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:29 Socket (8) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:30 * Socket (8) | Initiating close of socket by core. | 2018-03-23 16:48:30 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:30 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:30 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:30 Socket (8) | Closed. | 2018-03-23 16:48:30 Interactive Brokers | Disconnected. | 2018-03-23 16:48:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:30 TWS auto-login thread ending. | 2018-03-23 16:48:31 Starting TWS auto-login thread. | 2018-03-23 16:48:33 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:33 Socket (9) | Creating socket. | 2018-03-23 16:48:33 Socket (9) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:33 TWS auto-login thread ending. | 2018-03-23 16:48:34 Socket (9) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:34 * Socket (9) | Initiating close of socket by core. | 2018-03-23 16:48:34 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:34 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:34 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:34 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:34 Socket (9) | Closed. | 2018-03-23 16:48:34 Interactive Brokers | Disconnected. | 2018-03-23 16:48:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:34 Starting TWS auto-login thread. | 2018-03-23 16:48:37 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:37 Socket (10) | Creating socket. | 2018-03-23 16:48:37 Socket (10) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:37 TWS auto-login thread ending. | 2018-03-23 16:48:38 Socket (10) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:38 * Socket (10) | Initiating close of socket by core. | 2018-03-23 16:48:38 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:38 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:38 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:38 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:38 Socket (10) | Closed. | 2018-03-23 16:48:38 Interactive Brokers | Disconnected. | 2018-03-23 16:48:38 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:38 Starting TWS auto-login thread. | 2018-03-23 16:48:41 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:41 Socket (11) | Creating socket. | 2018-03-23 16:48:41 Socket (11) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:41 TWS auto-login thread ending. | 2018-03-23 16:48:42 Socket (11) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:42 * Socket (11) | Initiating close of socket by core. | 2018-03-23 16:48:42 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:42 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:42 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:42 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:42 Socket (11) | Closed. | 2018-03-23 16:48:42 Interactive Brokers | Disconnected. | 2018-03-23 16:48:42 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:42 Starting TWS auto-login thread. | 2018-03-23 16:48:45 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:45 Socket (12) | Creating socket. | 2018-03-23 16:48:45 Socket (12) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:45 TWS auto-login thread ending. | 2018-03-23 16:48:46 Socket (12) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:46 * Socket (12) | Initiating close of socket by core. | 2018-03-23 16:48:46 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:46 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:46 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:46 Socket (12) | Closed. | 2018-03-23 16:48:46 Interactive Brokers | Disconnected. | 2018-03-23 16:48:46 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:46 Starting TWS auto-login thread. | 2018-03-23 16:48:49 TWS auto-login thread ending. | 2018-03-23 16:48:49 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:49 Socket (13) | Creating socket. | 2018-03-23 16:48:49 Socket (13) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:49 Socket (13) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:50 * Socket (13) | Initiating close of socket by core. | 2018-03-23 16:48:50 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:50 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:50 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:50 Socket (13) | Closed. | 2018-03-23 16:48:50 Interactive Brokers | Disconnected. | 2018-03-23 16:48:50 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:50 Starting TWS auto-login thread. | 2018-03-23 16:48:53 TWS auto-login thread ending. | 2018-03-23 16:48:53 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:53 Socket (14) | Creating socket. | 2018-03-23 16:48:53 Socket (14) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:53 Interactive Brokers | Sending API sign: API | 2018-03-23 16:48:53 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 16:48:53 Interactive Brokers | TWS server version: 136 | 2018-03-23 16:48:53 Interactive Brokers | TWS time: 20180323 16:48:53 EST | 2018-03-23 16:48:53 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 16:48:53 IB Account information received. | 2018-03-23 16:48:53 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:48:53 Interactive Brokers | Connected to Live account. | 2018-03-23 16:48:53 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:48:53 Interactive Brokers | Connected to data and trading server. | 2018-03-23 16:48:53 Next valid order ID: 29 | 2018-03-23 16:48:53 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates) for account: U104* | 2018-03-23 16:48:58 Next valid order ID: 29 | 2018-03-23 16:49:02 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:49:02 IB Account information received. | 2018-03-23 16:49:02 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:49:02 Interactive Brokers | Connected to Live account. | 2018-03-23 16:49:02 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:49:02 Interactive Brokers | Received Trade Positions download end message for account U104* | 2018-03-23 16:49:02 Message from IB: Market data farm connection is OK:secdefil. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:02 Interactive Brokers | Sending request for contract details for contract ID 269745169 | 2018-03-23 16:49:03 Interactive Brokers | Sending request for contract details for contract ID 269745182 | 2018-03-23 16:49:03 Interactive Brokers | Sending request for contract details for contract ID 290048106 | 2018-03-23 16:49:03 Interactive Brokers | Sending request for contract details for contract ID 291020195 | 2018-03-23 16:49:03 Interactive Brokers | Sending request for contract details for contract ID 290048111 | 2018-03-23 16:49:03 Interactive Brokers | Received Trade Positions download end message for account U104* | 2018-03-23 16:49:03 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:03 Interactive Brokers | Received contract details for symbol ES-201806-GLOBEX | 2018-03-23 16:49:04 Interactive Brokers | Received contract details for symbol NQ-201806-GLOBEX | 2018-03-23 16:49:04 Interactive Brokers | Received contract details for symbol ZB-201806-ECBOT | 2018-03-23 16:49:04 Interactive Brokers | Received contract details for symbol ZF-201806-ECBOT | 2018-03-23 16:49:04 Interactive Brokers | Received contract details for symbol ZN-201806-ECBOT | 2018-03-23 16:49:04 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2018-03-23 16:49:04 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:49:07 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:07 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:07 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:07 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:07 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:49:07 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:07 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:49:07 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:49:08 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:08 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:09 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:09 Interactive Brokers | All contract details received for symbols used for trading. Re-requesting trading data. | 2018-03-23 16:49:14 Interactive Brokers | Stopping automatic Trade Position updates for account: U104* | 2018-03-23 16:49:14 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates) for account: U104* | 2018-03-23 16:49:14 Message from IB: API client has been unsubscribed from account data. IB Error Code: 2100. Request ID: -1. | 2018-03-23 16:49:14 Interactive Brokers | Received Trade Positions download end message for account U104* | 2018-03-23 16:49:14 |
[2018-03-23 20:56:39] |
this is SC v.1723 w a chartbook loaded and is showing the repetitive connect-disconnect-retry behavior Reading Internal Order ID file. | 2018-03-23 16:48:12 Reading Trade Orders file. | 2018-03-23 16:48:13 Reading Trade Positions file. | 2018-03-23 16:48:13 Listening on UDP port 22903. | 2018-03-23 16:48:13 Software version: 1723 64-bit | 2018-03-23 16:48:13 Usage end date: 2018-04-14 | 2018-03-23 16:48:13 Enabled for: Advanced Features. | 2018-03-23 16:48:13 Enabled for: Advanced Features 2. | 2018-03-23 16:48:13 Enabled for: Sierra Chart Historical Data Service. | 2018-03-23 16:48:13 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-03-23 16:48:13 Current selected Data/Trading service: Interactive Brokers | 2018-03-23 16:48:13 Chart Update Interval: 500 | 2018-03-23 16:48:13 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-03-23 16:48:13 2018-03-23 16:48:13 Local computer time | 2018-03-23 16:48:13 2018-03-23 20:48:13 Local computer time in UTC | 2018-03-23 16:48:13 2018-03-23 16:48:13 Local computer time in SC Time Zone | 2018-03-23 16:48:13 2018-03-23 20:48:11 Server time in UTC | 2018-03-23 16:48:13 Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-03-23 16:48:13 Program path: E:\SC\LWM\SC1 (IB)\ | 2018-03-23 16:48:13 Data Files path: E:\SC\LWM\SC1 (IB)\Data\ | 2018-03-23 16:48:13 OS Version Number: 10.0 | 2018-03-23 16:48:13 Locale Setting: C | 2018-03-23 16:48:13 Created the DTC Protocol server. | 2018-03-23 16:48:13 DTC Protocol Server listening on port 11099. | 2018-03-23 16:48:13 Created the DTC Protocol historical data server. | 2018-03-23 16:48:13 HD Server Manager | Listening on port 11098 | 2018-03-23 16:48:13 Checking for new symbol settings for service code interactive_brokers.trading | 2018-03-23 16:48:13 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-03-23 16:48:13 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-03-23 16:48:13 Requesting symbol settings for service code interactive_brokers.trading. Overwrite = on. | 2018-03-23 16:48:13 Received 5 login tokens. | 2018-03-23 16:48:13 Symbol settings received. | 2018-03-23 16:48:14 Processed 1393 symbol settings. | 2018-03-23 16:48:14 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:17 Starting TWS auto-login thread. | 2018-03-23 16:48:17 Socket (5) | Creating socket. | 2018-03-23 16:48:17 Socket (5) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:17 TWS auto-login thread ending. | 2018-03-23 16:48:17 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:18 * Socket (5) | Initiating close of socket by core. | 2018-03-23 16:48:18 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:18 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:18 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:18 Socket (5) | Closed. | 2018-03-23 16:48:18 Interactive Brokers | Disconnected. | 2018-03-23 16:48:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:18 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-03-23 16:48:18 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-03-23 16:48:18 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-03-23 16:48:18 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:48:18 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-03-23 16:48:18 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-03-23 16:48:19 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-03-23 16:48:19 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-03-23 16:48:19 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:48:19 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-03-23 16:48:19 Starting TWS auto-login thread. | 2018-03-23 16:48:21 TWS auto-login thread ending. | 2018-03-23 16:48:21 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:21 Socket (6) | Creating socket. | 2018-03-23 16:48:21 Socket (6) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:21 Socket (6) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:22 * Socket (6) | Initiating close of socket by core. | 2018-03-23 16:48:22 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:22 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:22 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:22 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:22 Socket (6) | Closed. | 2018-03-23 16:48:22 Interactive Brokers | Disconnected. | 2018-03-23 16:48:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:22 Starting TWS auto-login thread. | 2018-03-23 16:48:25 TWS auto-login thread ending. | 2018-03-23 16:48:25 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:25 Socket (7) | Creating socket. | 2018-03-23 16:48:25 Socket (7) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:25 Socket (7) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:26 * Socket (7) | Initiating close of socket by core. | 2018-03-23 16:48:26 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:26 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:26 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:26 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:26 Socket (7) | Closed. | 2018-03-23 16:48:26 Interactive Brokers | Disconnected. | 2018-03-23 16:48:26 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:26 Starting TWS auto-login thread. | 2018-03-23 16:48:29 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:29 Socket (8) | Creating socket. | 2018-03-23 16:48:29 Socket (8) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:29 Socket (8) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:30 * Socket (8) | Initiating close of socket by core. | 2018-03-23 16:48:30 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:30 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:30 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:30 Socket (8) | Closed. | 2018-03-23 16:48:30 Interactive Brokers | Disconnected. | 2018-03-23 16:48:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:30 TWS auto-login thread ending. | 2018-03-23 16:48:31 Starting TWS auto-login thread. | 2018-03-23 16:48:33 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:33 Socket (9) | Creating socket. | 2018-03-23 16:48:33 Socket (9) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:33 TWS auto-login thread ending. | 2018-03-23 16:48:34 Socket (9) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:34 * Socket (9) | Initiating close of socket by core. | 2018-03-23 16:48:34 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:34 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:34 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:34 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:34 Socket (9) | Closed. | 2018-03-23 16:48:34 Interactive Brokers | Disconnected. | 2018-03-23 16:48:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:34 Starting TWS auto-login thread. | 2018-03-23 16:48:37 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:37 Socket (10) | Creating socket. | 2018-03-23 16:48:37 Socket (10) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:37 TWS auto-login thread ending. | 2018-03-23 16:48:38 Socket (10) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:38 * Socket (10) | Initiating close of socket by core. | 2018-03-23 16:48:38 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:38 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:38 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:38 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:38 Socket (10) | Closed. | 2018-03-23 16:48:38 Interactive Brokers | Disconnected. | 2018-03-23 16:48:38 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:38 Starting TWS auto-login thread. | 2018-03-23 16:48:41 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:41 Socket (11) | Creating socket. | 2018-03-23 16:48:41 Socket (11) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:41 TWS auto-login thread ending. | 2018-03-23 16:48:42 Socket (11) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:42 * Socket (11) | Initiating close of socket by core. | 2018-03-23 16:48:42 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:42 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:42 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:42 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:42 Socket (11) | Closed. | 2018-03-23 16:48:42 Interactive Brokers | Disconnected. | 2018-03-23 16:48:42 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:42 Starting TWS auto-login thread. | 2018-03-23 16:48:45 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:45 Socket (12) | Creating socket. | 2018-03-23 16:48:45 Socket (12) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:45 TWS auto-login thread ending. | 2018-03-23 16:48:46 Socket (12) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:46 * Socket (12) | Initiating close of socket by core. | 2018-03-23 16:48:46 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:46 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:46 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:46 Socket (12) | Closed. | 2018-03-23 16:48:46 Interactive Brokers | Disconnected. | 2018-03-23 16:48:46 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:46 Starting TWS auto-login thread. | 2018-03-23 16:48:49 TWS auto-login thread ending. | 2018-03-23 16:48:49 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:49 Socket (13) | Creating socket. | 2018-03-23 16:48:49 Socket (13) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:49 Socket (13) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-03-23 16:48:50 * Socket (13) | Initiating close of socket by core. | 2018-03-23 16:48:50 Interactive Brokers | Failed to connect to the data and trade server. | 2018-03-23 16:48:50 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2018-03-23 16:48:50 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-23 16:48:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:50 Socket (13) | Closed. | 2018-03-23 16:48:50 Interactive Brokers | Disconnected. | 2018-03-23 16:48:50 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:48:50 Starting TWS auto-login thread. | 2018-03-23 16:48:53 TWS auto-login thread ending. | 2018-03-23 16:48:53 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:48:53 Socket (14) | Creating socket. | 2018-03-23 16:48:53 Socket (14) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:48:53 Interactive Brokers | Sending API sign: API | 2018-03-23 16:48:53 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 16:48:53 Interactive Brokers | TWS server version: 136 | 2018-03-23 16:48:53 Interactive Brokers | TWS time: 20180323 16:48:53 EST | 2018-03-23 16:48:53 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 16:48:53 IB Account information received. | 2018-03-23 16:48:53 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:48:53 Interactive Brokers | Connected to Live account. | 2018-03-23 16:48:53 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:48:53 Interactive Brokers | Connected to data and trading server. | 2018-03-23 16:48:53 Next valid order ID: 29 | 2018-03-23 16:48:53 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates) for account: U104* | 2018-03-23 16:48:58 Next valid order ID: 29 | 2018-03-23 16:49:02 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:49:02 IB Account information received. | 2018-03-23 16:49:02 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:49:02 Interactive Brokers | Connected to Live account. | 2018-03-23 16:49:02 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:49:02 Interactive Brokers | Received Trade Positions download end message for account U104* | 2018-03-23 16:49:02 Message from IB: Market data farm connection is OK:secdefil. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:02 Interactive Brokers | Sending request for contract details for contract ID 269745169 | 2018-03-23 16:49:03 Interactive Brokers | Sending request for contract details for contract ID 269745182 | 2018-03-23 16:49:03 Interactive Brokers | Sending request for contract details for contract ID 290048106 | 2018-03-23 16:49:03 Interactive Brokers | Sending request for contract details for contract ID 291020195 | 2018-03-23 16:49:03 Interactive Brokers | Sending request for contract details for contract ID 290048111 | 2018-03-23 16:49:03 Interactive Brokers | Received Trade Positions download end message for account U104* | 2018-03-23 16:49:03 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:03 Interactive Brokers | Received contract details for symbol ES-201806-GLOBEX | 2018-03-23 16:49:04 Interactive Brokers | Received contract details for symbol NQ-201806-GLOBEX | 2018-03-23 16:49:04 Interactive Brokers | Received contract details for symbol ZB-201806-ECBOT | 2018-03-23 16:49:04 Interactive Brokers | Received contract details for symbol ZF-201806-ECBOT | 2018-03-23 16:49:04 Interactive Brokers | Received contract details for symbol ZN-201806-ECBOT | 2018-03-23 16:49:04 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2018-03-23 16:49:04 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:49:07 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:07 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:07 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:07 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:07 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:49:07 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:07 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:49:07 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:49:08 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:08 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:09 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:49:09 Interactive Brokers | All contract details received for symbols used for trading. Re-requesting trading data. | 2018-03-23 16:49:14 Interactive Brokers | Stopping automatic Trade Position updates for account: U104* | 2018-03-23 16:49:14 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates) for account: U104* | 2018-03-23 16:49:14 Message from IB: API client has been unsubscribed from account data. IB Error Code: 2100. Request ID: -1. | 2018-03-23 16:49:14 Interactive Brokers | Received Trade Positions download end message for account U104* | 2018-03-23 16:49:14 ES-201806-GLOBEX [C] 1 Min #1 | Reloading chart. | 2018-03-23 16:53:00 ES-201806-GLOBEX [C] 10 Min #4 | Reloading chart. | 2018-03-23 16:53:00 ES-201806-GLOBEX [C] 10 Min #5 | Reloading chart. | 2018-03-23 16:53:00 NQ-201806-GLOBEX [C] 10 Min #6 | Reloading chart. | 2018-03-23 16:53:00 ES-201806-GLOBEX [C] 10 Min #7 | Reloading chart. | 2018-03-23 16:53:00 ZN-201806-ECBOT [C] 10 Min #8 | Reloading chart. | 2018-03-23 16:53:00 ZB-201806-ECBOT [C] 10 Min #9 | Reloading chart. | 2018-03-23 16:53:00 Interactive Brokers | Starting real-time market data updates for: ES-201806-GLOBEX. ID: 1 | 2018-03-23 16:53:00 Interactive Brokers | Subscribing to real-time True Data for symbol: ES SecurityType: FUT Exchange: GLOBEX Currency: | 2018-03-23 16:53:00 Interactive Brokers | Subscribing to Symbol: ES, SecurityType: FUT, Expiration: 201806, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-03-23 16:53:00 Interactive Brokers | Requesting security definition data for: ES-201806-GLOBEX. ID: 1 | 2018-03-23 16:53:00 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ES-201806-GLOBEX | 2018-03-23 16:53:00 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:00 Socket (14) | Socket gracefully closed by remote side. | 2018-03-23 16:53:00 Socket (14) | Received socket Close event. | 2018-03-23 16:53:00 Next valid order ID: 29 | 2018-03-23 16:53:00 Socket (14) | Initiating close of socket by core. | 2018-03-23 16:53:00 Connection to the external service has been lost. | 2018-03-23 16:53:00 Socket (14) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:53:00 Socket (14) | Closed. | 2018-03-23 16:53:00 HD Request # 2 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:00 HD Request # 2 | Download start date-time: 2018-03-23 16:04:45.000 | 2018-03-23 16:53:00 HD Request # 2 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:00 Interactive Brokers | Disconnected. | 2018-03-23 16:53:00 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:53:00 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-201806-GLOBEX | 2018-03-23 16:53:00 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:00 Socket (19) | Creating socket. | 2018-03-23 16:53:00 Socket (19) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:00 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZN-201806-ECBOT | 2018-03-23 16:53:00 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:00 HD Request # 2 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:01 HD Request # 2 | Sending historical data logon request message. | 2018-03-23 16:53:01 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZB-201806-ECBOT | 2018-03-23 16:53:01 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:01 HD Request # 2 | Requesting Intraday data. Start date-time: 2018-03-23 16:04:45. Record interval: 0. Symbol: ESM18 | 2018-03-23 16:53:01 HD Request # 2 | Decompressing data. | 2018-03-23 16:53:01 HD Request # 2 | Receiving Intraday data for ES-201806-GLOBEX starting at 2018-03-23 16:04:45 | 2018-03-23 16:53:01 HD Request # 2 | Timestamp of first Intraday data file record written: 2018-03-23 16:04:45 | 2018-03-23 16:53:01 HD Request # 2 | Historical data for ES-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:01 Socket (19) | Initiating close of socket by core. | 2018-03-23 16:53:01 Socket (19) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:01 Historical data download thread signaled to stop. | 2018-03-23 16:53:01 HD Request # 2 | Received 18639 records from 2018-03-23 16:04:45 to 2018-03-23 16:43:00 (38.3 minutes) and wrote 18638 records for ES-201806-GLOBEX | 2018-03-23 16:53:01 HD Request # 2 | Completion time: 0s | 2018-03-23 16:53:01 HD Request # 2 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 1 | 2018-03-23 16:53:01 Removed historical data download ID 1 | 2018-03-23 16:53:01 Interactive Brokers | Using primary service for historical data for ES-201806-GLOBEX | 2018-03-23 16:53:01 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:01 Socket (19) | Socket gracefully closed by remote side. | 2018-03-23 16:53:01 Socket (19) | Closed. | 2018-03-23 16:53:01 HD Request # 3 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:01 HD Request # 3 | Download start date-time: 2018-03-23 16:04:45.000 | 2018-03-23 16:53:01 HD Request # 3 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:01 Socket (20) | Creating socket. | 2018-03-23 16:53:01 Socket (20) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:01 HD Request # 3 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:01 HD Request # 3 | Sending historical data logon request message. | 2018-03-23 16:53:01 HD Request # 3 | Requesting Intraday data. Start date-time: 2018-03-23 16:04:45. Record interval: 0. Symbol: NQM18 | 2018-03-23 16:53:01 HD Request # 3 | Decompressing data. | 2018-03-23 16:53:01 HD Request # 3 | Receiving Intraday data for NQ-201806-GLOBEX starting at 2018-03-23 16:04:45 | 2018-03-23 16:53:01 HD Request # 3 | Timestamp of first Intraday data file record written: 2018-03-23 16:04:47 | 2018-03-23 16:53:01 Socket (20) | Initiating close of socket by core. | 2018-03-23 16:53:01 HD Request # 3 | Historical data for NQ-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:01 Socket (20) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:01 Historical data download thread signaled to stop. | 2018-03-23 16:53:01 HD Request # 3 | Received 6807 records from 2018-03-23 16:04:45 to 2018-03-23 16:43:01 (38.3 minutes) and wrote 6806 records for NQ-201806-GLOBEX | 2018-03-23 16:53:01 HD Request # 3 | Completion time: 1s | 2018-03-23 16:53:01 HD Request # 3 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 2 | 2018-03-23 16:53:02 Removed historical data download ID 2 | 2018-03-23 16:53:02 Interactive Brokers | Using primary service for historical data for NQ-201806-GLOBEX | 2018-03-23 16:53:02 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:02 HD Request # 4 | Downloading Intraday chart data for ZN-201806-ECBOT to the file ZN-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:02 HD Request # 4 | Download start date-time: 2018-03-23 16:04:45.000 | 2018-03-23 16:53:02 HD Request # 4 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:02 Socket (21) | Creating socket. | 2018-03-23 16:53:02 Socket (21) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:02 Socket (20) | Socket gracefully closed by remote side. | 2018-03-23 16:53:02 Socket (20) | Closed. | 2018-03-23 16:53:02 HD Request # 4 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:02 HD Request # 4 | Sending historical data logon request message. | 2018-03-23 16:53:02 HD Request # 4 | Requesting Intraday data. Start date-time: 2018-03-23 16:04:45. Record interval: 0. Symbol: ZNM18 | 2018-03-23 16:53:02 HD Request # 4 | Decompressing data. | 2018-03-23 16:53:02 HD Request # 4 | Receiving Intraday data for ZN-201806-ECBOT starting at 2018-03-23 16:04:45 | 2018-03-23 16:53:02 HD Request # 4 | Timestamp of first Intraday data file record written: 2018-03-23 16:04:50 | 2018-03-23 16:53:02 Socket (21) | Initiating close of socket by core. | 2018-03-23 16:53:02 HD Request # 4 | Historical data for ZN-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:02 Socket (21) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:02 Historical data download thread signaled to stop. | 2018-03-23 16:53:02 HD Request # 4 | Received 3164 records from 2018-03-23 16:04:45 to 2018-03-23 16:42:53 (38.1 minutes) and wrote 3163 records for ZN-201806-ECBOT | 2018-03-23 16:53:02 HD Request # 4 | Completion time: 0s | 2018-03-23 16:53:02 HD Request # 4 | Intraday data download complete for ZN-201806-ECBOT. Unique request ID: 3 | 2018-03-23 16:53:02 Removed historical data download ID 3 | 2018-03-23 16:53:02 Interactive Brokers | Using primary service for historical data for ZN-201806-ECBOT | 2018-03-23 16:53:02 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:02 HD Request # 5 | Downloading Intraday chart data for ZB-201806-ECBOT to the file ZB-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:02 HD Request # 5 | Download start date-time: 2018-03-23 16:04:45.000 | 2018-03-23 16:53:02 HD Request # 5 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:02 Socket (22) | Creating socket. | 2018-03-23 16:53:02 Socket (22) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:02 Socket (21) | Socket gracefully closed by remote side. | 2018-03-23 16:53:02 Socket (21) | Closed. | 2018-03-23 16:53:02 HD Request # 5 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:02 HD Request # 5 | Sending historical data logon request message. | 2018-03-23 16:53:02 HD Request # 5 | Requesting Intraday data. Start date-time: 2018-03-23 16:04:45. Record interval: 0. Symbol: ZBM18 | 2018-03-23 16:53:02 HD Request # 5 | Decompressing data. | 2018-03-23 16:53:02 HD Request # 5 | Receiving Intraday data for ZB-201806-ECBOT starting at 2018-03-23 16:04:53 | 2018-03-23 16:53:02 HD Request # 5 | Timestamp of first Intraday data file record written: 2018-03-23 16:04:53 | 2018-03-23 16:53:02 Socket (22) | Initiating close of socket by core. | 2018-03-23 16:53:02 HD Request # 5 | Historical data for ZB-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:02 Socket (22) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:02 Historical data download thread signaled to stop. | 2018-03-23 16:53:02 HD Request # 5 | Received 1396 records from 2018-03-23 16:04:53 to 2018-03-23 16:42:50 (38.0 minutes) and wrote 1396 records for ZB-201806-ECBOT | 2018-03-23 16:53:02 HD Request # 5 | Completion time: 0s | 2018-03-23 16:53:02 HD Request # 5 | Intraday data download complete for ZB-201806-ECBOT. Unique request ID: 4 | 2018-03-23 16:53:02 Removed historical data download ID 4 | 2018-03-23 16:53:02 Interactive Brokers | Using primary service for historical data for ZB-201806-ECBOT | 2018-03-23 16:53:02 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:02 Socket (22) | Socket gracefully closed by remote side. | 2018-03-23 16:53:02 Socket (22) | Closed. | 2018-03-23 16:53:02 ZN-201806-ECBOT [C] 10 Min #8 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-02-13 13:40:00. Next Bar Date Time: 2018-02-13 13:30:00. Filename: ZN-201806-ECBOT.scid | 2018-03-23 16:53:03 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:53:03 Starting TWS auto-login thread. | 2018-03-23 16:53:03 Socket (23) | Creating socket. | 2018-03-23 16:53:03 Socket (23) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:53:03 TWS auto-login thread ending. | 2018-03-23 16:53:03 ES-201806-GLOBEX [C] 10 Min #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-01-12 14:00:00. Next Bar Date Time: 2018-01-12 13:20:00. Filename: ES-201806-GLOBEX.scid | 2018-03-23 16:53:05 ES-201806-GLOBEX [C] 10 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-01-12 14:00:00. Next Bar Date Time: 2018-01-12 13:20:00. Filename: ES-201806-GLOBEX.scid | 2018-03-23 16:53:05 ES-201806-GLOBEX [C] 1 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-01-12 14:02:00. Next Bar Date Time: 2018-01-12 13:21:00. Filename: ES-201806-GLOBEX.scid | 2018-03-23 16:53:05 ES-201806-GLOBEX [C] 10 Min #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-01-23 16:30:00. Next Bar Date Time: 2018-01-23 16:10:00. Filename: ES-201806-GLOBEX.scid | 2018-03-23 16:53:05 ES-201806-GLOBEX [C] 10 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-01-23 16:30:00. Next Bar Date Time: 2018-01-23 16:10:00. Filename: ES-201806-GLOBEX.scid | 2018-03-23 16:53:05 ES-201806-GLOBEX [C] 1 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-01-23 16:37:00. Next Bar Date Time: 2018-01-23 16:11:00. Filename: ES-201806-GLOBEX.scid | 2018-03-23 16:53:05 Interactive Brokers | Sending API sign: API | 2018-03-23 16:53:06 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 16:53:06 Interactive Brokers | TWS server version: 136 | 2018-03-23 16:53:06 Interactive Brokers | TWS time: 20180323 16:53:05 EST | 2018-03-23 16:53:06 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 16:53:06 IB Account information received. | 2018-03-23 16:53:06 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:53:06 Interactive Brokers | Connected to Live account. | 2018-03-23 16:53:06 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:53:06 Interactive Brokers | Connected to data and trading server. | 2018-03-23 16:53:06 Next valid order ID: 29 | 2018-03-23 16:53:06 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:06 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:06 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:06 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:06 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:06 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:06 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:06 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:06 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:06 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:06 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:06 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:06 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:06 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:06 HD Request # 6 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-03-23 16:53:06 HD Request # 6 | Download start date-time: 2018-03-23 16:43:00.000 | 2018-03-23 16:53:06 HD Request # 6 | Requesting a total of 0 days and 5406 seconds. | 2018-03-23 16:53:06 HD Request # 6 | IB Backfill - Seconds requested: 5406. Seconds Remaining: 0. | 2018-03-23 16:53:06 HD Request # 6 | Requesting 5406 Seconds of data at 30 secs with ending date-time at 2018-03-23 18:03:06 for ES-201806-GLOBEX. PriceType: TRADES | 2018-03-23 16:53:06 Interactive Brokers | Starting real-time market data updates for: ZN-201806-ECBOT. ID: 2 | 2018-03-23 16:53:06 Interactive Brokers | Subscribing to real-time True Data for symbol: ZN SecurityType: FUT Exchange: ECBOT Currency: | 2018-03-23 16:53:06 Interactive Brokers | Subscribing to Symbol: ZN, SecurityType: FUT, Expiration: 201806, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-03-23 16:53:06 Interactive Brokers | Requesting security definition data for: ZN-201806-ECBOT. ID: 2 | 2018-03-23 16:53:06 Socket (23) | Received socket Close event. | 2018-03-23 16:53:06 Socket (23) | Socket gracefully closed by remote side. | 2018-03-23 16:53:06 Next valid order ID: 29 | 2018-03-23 16:53:06 Socket (23) | Initiating close of socket by core. | 2018-03-23 16:53:06 Connection to the external service has been lost. | 2018-03-23 16:53:06 Socket (23) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:53:06 Socket (23) | Closed. | 2018-03-23 16:53:06 Canceling historical data download request for NQ-201806-GLOBEX Intraday data. | 2018-03-23 16:53:07 Removed historical data download ID 6 | 2018-03-23 16:53:07 Canceling historical data download request for ZN-201806-ECBOT Intraday data. | 2018-03-23 16:53:07 Removed historical data download ID 7 | 2018-03-23 16:53:07 Canceling historical data download request for ZB-201806-ECBOT Intraday data. | 2018-03-23 16:53:07 Removed historical data download ID 8 | 2018-03-23 16:53:07 HD Request # 6 | Download canceled. | 2018-03-23 16:53:07 HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-03-23 16:53:07 HD Request # 6 | Completion time: 0s | 2018-03-23 16:53:07 HD Request # 6 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 5 | 2018-03-23 16:53:07 Removed historical data download ID 5 | 2018-03-23 16:53:07 Interactive Brokers | Disconnected. | 2018-03-23 16:53:07 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:53:07 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZB-201806-ECBOT | 2018-03-23 16:53:07 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:07 HD Request # 7 | Downloading Intraday chart data for ZB-201806-ECBOT to the file ZB-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:07 HD Request # 7 | Download start date-time: 2018-03-23 16:42:50.000 | 2018-03-23 16:53:07 HD Request # 7 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:07 Socket (24) | Creating socket. | 2018-03-23 16:53:07 Socket (24) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:07 HD Request # 7 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:07 HD Request # 7 | Sending historical data logon request message. | 2018-03-23 16:53:07 HD Request # 7 | Requesting Intraday data. Start date-time: 2018-03-23 16:42:50. Record interval: 0. Symbol: ZBM18 | 2018-03-23 16:53:07 HD Request # 7 | Decompressing data. | 2018-03-23 16:53:07 HD Request # 7 | Receiving Intraday data for ZB-201806-ECBOT starting at 2018-03-23 16:42:50 | 2018-03-23 16:53:07 Socket (24) | Initiating close of socket by core. | 2018-03-23 16:53:07 Socket (24) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:07 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-201806-GLOBEX | 2018-03-23 16:53:07 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:07 HD Request # 7 | Historical data for ZB-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:07 Historical data download thread signaled to stop. | 2018-03-23 16:53:07 HD Request # 7 | Received 7 records from 2018-03-23 16:42:50 to 2018-03-23 16:42:50 (0.0 seconds) and wrote 0 records for ZB-201806-ECBOT | 2018-03-23 16:53:07 HD Request # 7 | Completion time: 0s | 2018-03-23 16:53:07 HD Request # 7 | Intraday data download complete for ZB-201806-ECBOT. Unique request ID: 9 | 2018-03-23 16:53:07 Removed historical data download ID 9 | 2018-03-23 16:53:07 Interactive Brokers | Using primary service for historical data for ZB-201806-ECBOT | 2018-03-23 16:53:07 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:07 HD Request # 8 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:07 HD Request # 8 | Download start date-time: 2018-03-23 16:43:01.000 | 2018-03-23 16:53:07 HD Request # 8 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:07 Socket (25) | Creating socket. | 2018-03-23 16:53:07 Socket (25) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:07 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZN-201806-ECBOT | 2018-03-23 16:53:07 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:07 Socket (24) | Socket gracefully closed by remote side. | 2018-03-23 16:53:07 Socket (24) | Closed. | 2018-03-23 16:53:07 HD Request # 8 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:07 HD Request # 8 | Sending historical data logon request message. | 2018-03-23 16:53:07 HD Request # 8 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:01. Record interval: 0. Symbol: NQM18 | 2018-03-23 16:53:07 HD Request # 8 | Decompressing data. | 2018-03-23 16:53:07 HD Request # 8 | Receiving Intraday data for NQ-201806-GLOBEX starting at 2018-03-23 16:43:01 | 2018-03-23 16:53:07 HD Request # 8 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:02 | 2018-03-23 16:53:07 Socket (25) | Initiating close of socket by core. | 2018-03-23 16:53:07 HD Request # 8 | Historical data for NQ-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:07 Socket (25) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:07 Historical data download thread signaled to stop. | 2018-03-23 16:53:07 HD Request # 8 | Received 18 records from 2018-03-23 16:43:01 to 2018-03-23 16:43:05 (4.0 seconds) and wrote 14 records for NQ-201806-GLOBEX | 2018-03-23 16:53:07 HD Request # 8 | Completion time: 1s | 2018-03-23 16:53:07 HD Request # 8 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 10 | 2018-03-23 16:53:07 Removed historical data download ID 10 | 2018-03-23 16:53:07 Interactive Brokers | Using primary service for historical data for NQ-201806-GLOBEX | 2018-03-23 16:53:07 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:07 Socket (25) | Socket gracefully closed by remote side. | 2018-03-23 16:53:07 Socket (25) | Closed. | 2018-03-23 16:53:07 HD Request # 9 | Downloading Intraday chart data for ZN-201806-ECBOT to the file ZN-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:07 HD Request # 9 | Download start date-time: 2018-03-23 16:42:53.000 | 2018-03-23 16:53:07 HD Request # 9 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:07 Socket (26) | Creating socket. | 2018-03-23 16:53:07 Socket (26) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:07 HD Request # 9 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:07 HD Request # 9 | Sending historical data logon request message. | 2018-03-23 16:53:07 HD Request # 9 | Requesting Intraday data. Start date-time: 2018-03-23 16:42:53. Record interval: 0. Symbol: ZNM18 | 2018-03-23 16:53:07 Starting TWS auto-login thread. | 2018-03-23 16:53:07 TWS auto-login thread ending. | 2018-03-23 16:53:07 HD Request # 9 | Decompressing data. | 2018-03-23 16:53:07 HD Request # 9 | Receiving Intraday data for ZN-201806-ECBOT starting at 2018-03-23 16:42:53 | 2018-03-23 16:53:07 HD Request # 9 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:07 | 2018-03-23 16:53:07 Socket (26) | Initiating close of socket by core. | 2018-03-23 16:53:07 Socket (26) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:07 HD Request # 9 | Historical data for ZN-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:07 Historical data download thread signaled to stop. | 2018-03-23 16:53:07 HD Request # 9 | Received 2 records from 2018-03-23 16:42:53 to 2018-03-23 16:43:07 (14.0 seconds) and wrote 1 record for ZN-201806-ECBOT | 2018-03-23 16:53:07 HD Request # 9 | Completion time: 0s | 2018-03-23 16:53:07 HD Request # 9 | Intraday data download complete for ZN-201806-ECBOT. Unique request ID: 12 | 2018-03-23 16:53:07 Removed historical data download ID 12 | 2018-03-23 16:53:07 Interactive Brokers | Using primary service for historical data for ZN-201806-ECBOT | 2018-03-23 16:53:07 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:07 Socket (26) | Socket gracefully closed by remote side. | 2018-03-23 16:53:07 Socket (26) | Closed. | 2018-03-23 16:53:07 ES-201806-GLOBEX [C] 10 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-01-12 14:00:00. Next Bar Date Time: 2018-01-12 13:20:00. Filename: ES-201806-GLOBEX.scid | 2018-03-23 16:53:08 ES-201806-GLOBEX [C] 10 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-01-23 16:30:00. Next Bar Date Time: 2018-01-23 16:10:00. Filename: ES-201806-GLOBEX.scid | 2018-03-23 16:53:08 ES-201806-GLOBEX [C] 10 Min #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-02-13 13:40:00. Next Bar Date Time: 2018-02-13 13:30:00. Filename: ES-201806-GLOBEX.scid | 2018-03-23 16:53:09 ES-201806-GLOBEX [C] 1 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-02-13 13:49:00. Next Bar Date Time: 2018-02-13 13:34:00. Filename: ES-201806-GLOBEX.scid | 2018-03-23 16:53:09 ES-201806-GLOBEX [C] 10 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-02-13 13:40:00. Next Bar Date Time: 2018-02-13 13:30:00. Filename: ES-201806-GLOBEX.scid | 2018-03-23 16:53:09 ES-201806-GLOBEX [C] 10 Min #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-03-05 15:20:00. Next Bar Date Time: 2018-03-05 14:50:00. Filename: ES-201806-GLOBEX.scid | 2018-03-23 16:53:09 NQ-201806-GLOBEX [C] 10 Min #6 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-02-13 13:40:00. Next Bar Date Time: 2018-02-13 13:30:00. Filename: NQ-201806-GLOBEX.scid | 2018-03-23 16:53:09 ES-201806-GLOBEX [C] 1 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-03-05 15:26:00. Next Bar Date Time: 2018-03-05 14:52:00. Filename: ES-201806-GLOBEX.scid | 2018-03-23 16:53:09 ES-201806-GLOBEX [C] 10 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-03-05 15:20:00. Next Bar Date Time: 2018-03-05 14:50:00. Filename: ES-201806-GLOBEX.scid | 2018-03-23 16:53:09 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:53:10 Socket (27) | Creating socket. | 2018-03-23 16:53:10 Socket (27) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:53:10 Interactive Brokers | Sending API sign: API | 2018-03-23 16:53:10 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 16:53:10 Interactive Brokers | TWS server version: 136 | 2018-03-23 16:53:10 Interactive Brokers | TWS time: 20180323 16:53:08 EST | 2018-03-23 16:53:10 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 16:53:10 IB Account information received. | 2018-03-23 16:53:10 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:53:10 Interactive Brokers | Connected to Live account. | 2018-03-23 16:53:10 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:53:10 Interactive Brokers | Connected to data and trading server. | 2018-03-23 16:53:10 Next valid order ID: 29 | 2018-03-23 16:53:10 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:10 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:10 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:10 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:10 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:10 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:10 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:10 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:10 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:10 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:10 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:10 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:10 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:10 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:10 HD Request # 10 | Downloading Intraday chart data for ZB-201806-ECBOT to the file ZB-201806-ECBOT.scid. Service: interactive_brokers.trading | 2018-03-23 16:53:10 HD Request # 10 | Download start date-time: 2018-03-23 16:42:50.000 | 2018-03-23 16:53:10 HD Request # 10 | Requesting a total of 0 days and 5419 seconds. | 2018-03-23 16:53:10 HD Request # 10 | IB Backfill - Seconds requested: 5419. Seconds Remaining: 0. | 2018-03-23 16:53:10 HD Request # 10 | Requesting 5419 Seconds of data at 30 secs with ending date-time at 2018-03-23 18:03:09 for ZB-201806-ECBOT. PriceType: TRADES | 2018-03-23 16:53:10 Interactive Brokers | Starting real-time market data updates for: ZB-201806-ECBOT. ID: 1 | 2018-03-23 16:53:10 Interactive Brokers | Subscribing to real-time True Data for symbol: ZB SecurityType: FUT Exchange: ECBOT Currency: | 2018-03-23 16:53:10 Interactive Brokers | Subscribing to Symbol: ZB, SecurityType: FUT, Expiration: 201806, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-03-23 16:53:10 Interactive Brokers | Requesting security definition data for: ZB-201806-ECBOT. ID: 1 | 2018-03-23 16:53:10 Socket (27) | Socket gracefully closed by remote side. | 2018-03-23 16:53:10 Socket (27) | Received socket Close event. | 2018-03-23 16:53:10 Next valid order ID: 29 | 2018-03-23 16:53:10 Socket (27) | Initiating close of socket by core. | 2018-03-23 16:53:10 Connection to the external service has been lost. | 2018-03-23 16:53:10 Socket (27) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:53:10 Socket (27) | Closed. | 2018-03-23 16:53:10 Canceling historical data download request for NQ-201806-GLOBEX Intraday data. | 2018-03-23 16:53:10 Removed historical data download ID 13 | 2018-03-23 16:53:10 Canceling historical data download request for ZN-201806-ECBOT Intraday data. | 2018-03-23 16:53:10 Removed historical data download ID 14 | 2018-03-23 16:53:10 HD Request # 10 | Download canceled. | 2018-03-23 16:53:10 HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZB-201806-ECBOT | 2018-03-23 16:53:10 HD Request # 10 | Completion time: 0s | 2018-03-23 16:53:10 HD Request # 10 | Intraday data download complete for ZB-201806-ECBOT. Unique request ID: 11 | 2018-03-23 16:53:10 Removed historical data download ID 11 | 2018-03-23 16:53:10 Interactive Brokers | Disconnected. | 2018-03-23 16:53:10 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:53:10 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ES-201806-GLOBEX | 2018-03-23 16:53:10 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:10 HD Request # 11 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:10 HD Request # 11 | Download start date-time: 2018-03-23 16:43:00.000 | 2018-03-23 16:53:10 HD Request # 11 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:10 Socket (28) | Creating socket. | 2018-03-23 16:53:10 Socket (28) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:10 HD Request # 11 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:10 HD Request # 11 | Sending historical data logon request message. | 2018-03-23 16:53:10 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-201806-GLOBEX | 2018-03-23 16:53:10 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:10 HD Request # 11 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:00. Record interval: 0. Symbol: ESM18 | 2018-03-23 16:53:10 HD Request # 11 | Decompressing data. | 2018-03-23 16:53:10 HD Request # 11 | Receiving Intraday data for ES-201806-GLOBEX starting at 2018-03-23 16:43:00 | 2018-03-23 16:53:10 HD Request # 11 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:01 | 2018-03-23 16:53:10 Socket (28) | Initiating close of socket by core. | 2018-03-23 16:53:10 Socket (28) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:10 HD Request # 11 | Historical data for ES-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:10 Historical data download thread signaled to stop. | 2018-03-23 16:53:10 HD Request # 11 | Received 64 records from 2018-03-23 16:43:00 to 2018-03-23 16:43:10 (10.0 seconds) and wrote 63 records for ES-201806-GLOBEX | 2018-03-23 16:53:10 HD Request # 11 | Completion time: 0s | 2018-03-23 16:53:10 HD Request # 11 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 15 | 2018-03-23 16:53:10 Removed historical data download ID 15 | 2018-03-23 16:53:10 Interactive Brokers | Using primary service for historical data for ES-201806-GLOBEX | 2018-03-23 16:53:10 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:10 HD Request # 12 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:10 HD Request # 12 | Download start date-time: 2018-03-23 16:43:05.000 | 2018-03-23 16:53:10 HD Request # 12 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:10 Socket (29) | Creating socket. | 2018-03-23 16:53:10 Socket (29) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:10 Socket (28) | Socket gracefully closed by remote side. | 2018-03-23 16:53:10 Socket (28) | Closed. | 2018-03-23 16:53:10 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZN-201806-ECBOT | 2018-03-23 16:53:10 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:10 HD Request # 12 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:10 HD Request # 12 | Sending historical data logon request message. | 2018-03-23 16:53:10 HD Request # 12 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:05. Record interval: 0. Symbol: NQM18 | 2018-03-23 16:53:10 HD Request # 12 | Decompressing data. | 2018-03-23 16:53:10 HD Request # 12 | Receiving Intraday data for NQ-201806-GLOBEX starting at 2018-03-23 16:43:05 | 2018-03-23 16:53:10 HD Request # 12 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:09 | 2018-03-23 16:53:10 Socket (29) | Initiating close of socket by core. | 2018-03-23 16:53:10 HD Request # 12 | Historical data for NQ-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:10 Socket (29) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:10 Historical data download thread signaled to stop. | 2018-03-23 16:53:10 HD Request # 12 | Received 12 records from 2018-03-23 16:43:05 to 2018-03-23 16:43:09 (4.0 seconds) and wrote 2 records for NQ-201806-GLOBEX | 2018-03-23 16:53:10 HD Request # 12 | Completion time: 0s | 2018-03-23 16:53:10 HD Request # 12 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 16 | 2018-03-23 16:53:10 Removed historical data download ID 16 | 2018-03-23 16:53:10 Interactive Brokers | Using primary service for historical data for NQ-201806-GLOBEX | 2018-03-23 16:53:10 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:10 HD Request # 13 | Downloading Intraday chart data for ZN-201806-ECBOT to the file ZN-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:10 HD Request # 13 | Download start date-time: 2018-03-23 16:43:07.000 | 2018-03-23 16:53:10 HD Request # 13 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:10 Socket (30) | Creating socket. | 2018-03-23 16:53:10 Socket (30) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:10 Socket (29) | Socket gracefully closed by remote side. | 2018-03-23 16:53:10 Socket (29) | Closed. | 2018-03-23 16:53:10 HD Request # 13 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:10 HD Request # 13 | Sending historical data logon request message. | 2018-03-23 16:53:10 HD Request # 13 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:07. Record interval: 0. Symbol: ZNM18 | 2018-03-23 16:53:10 HD Request # 13 | Decompressing data. | 2018-03-23 16:53:10 HD Request # 13 | Receiving Intraday data for ZN-201806-ECBOT starting at 2018-03-23 16:43:07 | 2018-03-23 16:53:10 Socket (30) | Initiating close of socket by core. | 2018-03-23 16:53:10 Socket (30) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:10 Socket (30) | Socket gracefully closed by remote side. | 2018-03-23 16:53:10 Socket (30) | Closed. | 2018-03-23 16:53:10 ES-201806-GLOBEX [C] 10 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-02-13 13:40:00. Next Bar Date Time: 2018-02-13 13:30:00. Filename: ES-201806-GLOBEX.scid | 2018-03-23 16:53:12 ES-201806-GLOBEX [C] 10 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-03-05 15:20:00. Next Bar Date Time: 2018-03-05 14:50:00. Filename: ES-201806-GLOBEX.scid | 2018-03-23 16:53:12 HD Request # 13 | Historical data for ZN-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:14 Historical data download thread signaled to stop. | 2018-03-23 16:53:14 HD Request # 13 | Received 1 record from 2018-03-23 16:43:07 to 2018-03-23 16:43:07 (0.0 seconds) and wrote 0 records for ZN-201806-ECBOT | 2018-03-23 16:53:14 HD Request # 13 | Completion time: 3s | 2018-03-23 16:53:14 HD Request # 13 | Intraday data download complete for ZN-201806-ECBOT. Unique request ID: 18 | 2018-03-23 16:53:14 Removed historical data download ID 18 | 2018-03-23 16:53:14 Interactive Brokers | Using primary service for historical data for ZN-201806-ECBOT | 2018-03-23 16:53:14 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:14 Chart #6 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:14 Chart #8 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:14 Starting TWS auto-login thread. | 2018-03-23 16:53:14 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:53:14 TWS auto-login thread ending. | 2018-03-23 16:53:14 Socket (32) | Creating socket. | 2018-03-23 16:53:14 Socket (32) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:53:14 Interactive Brokers | Sending API sign: API | 2018-03-23 16:53:14 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 16:53:14 Interactive Brokers | TWS server version: 136 | 2018-03-23 16:53:14 Interactive Brokers | TWS time: 20180323 16:53:13 EST | 2018-03-23 16:53:14 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 16:53:14 IB Account information received. | 2018-03-23 16:53:14 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:53:14 Interactive Brokers | Connected to Live account. | 2018-03-23 16:53:14 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:53:14 Interactive Brokers | Connected to data and trading server. | 2018-03-23 16:53:14 Next valid order ID: 29 | 2018-03-23 16:53:14 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:14 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:14 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:14 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:14 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:14 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:14 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:14 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:14 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:14 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:14 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:14 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:14 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:14 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:14 HD Request # 14 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-03-23 16:53:14 HD Request # 14 | Download start date-time: 2018-03-23 16:43:10.000 | 2018-03-23 16:53:14 HD Request # 14 | Requesting a total of 0 days and 5404 seconds. | 2018-03-23 16:53:14 HD Request # 14 | IB Backfill - Seconds requested: 5404. Seconds Remaining: 0. | 2018-03-23 16:53:14 HD Request # 14 | Requesting 5404 Seconds of data at 30 secs with ending date-time at 2018-03-23 18:03:14 for ES-201806-GLOBEX. PriceType: TRADES | 2018-03-23 16:53:14 Interactive Brokers | Starting real-time market data updates for: ES-201806-GLOBEX. ID: 1 | 2018-03-23 16:53:14 Interactive Brokers | Subscribing to real-time True Data for symbol: ES SecurityType: FUT Exchange: GLOBEX Currency: | 2018-03-23 16:53:14 Interactive Brokers | Subscribing to Symbol: ES, SecurityType: FUT, Expiration: 201806, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-03-23 16:53:14 Interactive Brokers | Requesting security definition data for: ES-201806-GLOBEX. ID: 1 | 2018-03-23 16:53:14 Socket (32) | Socket gracefully closed by remote side. | 2018-03-23 16:53:14 Socket (32) | Received socket Close event. | 2018-03-23 16:53:14 Next valid order ID: 29 | 2018-03-23 16:53:14 Socket (32) | Initiating close of socket by core. | 2018-03-23 16:53:14 Connection to the external service has been lost. | 2018-03-23 16:53:14 Socket (32) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:53:14 Socket (32) | Closed. | 2018-03-23 16:53:14 Canceling historical data download request for NQ-201806-GLOBEX Intraday data. | 2018-03-23 16:53:14 Removed historical data download ID 19 | 2018-03-23 16:53:14 Canceling historical data download request for ZN-201806-ECBOT Intraday data. | 2018-03-23 16:53:14 Removed historical data download ID 20 | 2018-03-23 16:53:14 HD Request # 14 | Download canceled. | 2018-03-23 16:53:14 HD Request # 14 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-03-23 16:53:14 HD Request # 14 | Completion time: 0s | 2018-03-23 16:53:14 HD Request # 14 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 17 | 2018-03-23 16:53:14 Removed historical data download ID 17 | 2018-03-23 16:53:14 Interactive Brokers | Disconnected. | 2018-03-23 16:53:14 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:53:14 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:14 Chart #5 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:14 Chart #5 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:14 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-201806-GLOBEX | 2018-03-23 16:53:14 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:14 HD Request # 15 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:14 HD Request # 15 | Download start date-time: 2018-03-23 16:43:09.000 | 2018-03-23 16:53:14 HD Request # 15 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:14 Socket (33) | Creating socket. | 2018-03-23 16:53:14 Socket (33) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:14 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:14 HD Request # 15 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:14 HD Request # 15 | Sending historical data logon request message. | 2018-03-23 16:53:14 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZN-201806-ECBOT | 2018-03-23 16:53:14 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:14 HD Request # 15 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:09. Record interval: 0. Symbol: NQM18 | 2018-03-23 16:53:15 HD Request # 15 | Decompressing data. | 2018-03-23 16:53:15 HD Request # 15 | Receiving Intraday data for NQ-201806-GLOBEX starting at 2018-03-23 16:43:09 | 2018-03-23 16:53:15 HD Request # 15 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:12 | 2018-03-23 16:53:15 Socket (33) | Initiating close of socket by core. | 2018-03-23 16:53:15 Socket (33) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:15 HD Request # 15 | Historical data for NQ-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:15 Historical data download thread signaled to stop. | 2018-03-23 16:53:15 HD Request # 15 | Received 8 records from 2018-03-23 16:43:09 to 2018-03-23 16:43:13 (4.0 seconds) and wrote 6 records for NQ-201806-GLOBEX | 2018-03-23 16:53:15 HD Request # 15 | Completion time: 0s | 2018-03-23 16:53:15 HD Request # 15 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 21 | 2018-03-23 16:53:15 Removed historical data download ID 21 | 2018-03-23 16:53:15 Interactive Brokers | Using primary service for historical data for NQ-201806-GLOBEX | 2018-03-23 16:53:15 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:15 HD Request # 16 | Downloading Intraday chart data for ZN-201806-ECBOT to the file ZN-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:15 HD Request # 16 | Download start date-time: 2018-03-23 16:43:07.000 | 2018-03-23 16:53:15 HD Request # 16 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:15 Socket (34) | Creating socket. | 2018-03-23 16:53:15 Socket (34) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:15 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZB-201806-ECBOT | 2018-03-23 16:53:15 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:15 Socket (33) | Socket gracefully closed by remote side. | 2018-03-23 16:53:15 Socket (33) | Closed. | 2018-03-23 16:53:15 HD Request # 16 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:15 HD Request # 16 | Sending historical data logon request message. | 2018-03-23 16:53:15 HD Request # 16 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:07. Record interval: 0. Symbol: ZNM18 | 2018-03-23 16:53:15 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:15 HD Request # 16 | Decompressing data. | 2018-03-23 16:53:15 HD Request # 16 | Receiving Intraday data for ZN-201806-ECBOT starting at 2018-03-23 16:43:07 | 2018-03-23 16:53:15 Socket (34) | Initiating close of socket by core. | 2018-03-23 16:53:15 Socket (34) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:15 HD Request # 16 | Historical data for ZN-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:15 Historical data download thread signaled to stop. | 2018-03-23 16:53:15 HD Request # 16 | Received 1 record from 2018-03-23 16:43:07 to 2018-03-23 16:43:07 (0.0 seconds) and wrote 0 records for ZN-201806-ECBOT | 2018-03-23 16:53:15 HD Request # 16 | Completion time: 0s | 2018-03-23 16:53:15 HD Request # 16 | Intraday data download complete for ZN-201806-ECBOT. Unique request ID: 22 | 2018-03-23 16:53:15 Removed historical data download ID 22 | 2018-03-23 16:53:15 Interactive Brokers | Using primary service for historical data for ZN-201806-ECBOT | 2018-03-23 16:53:15 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:15 HD Request # 17 | Downloading Intraday chart data for ZB-201806-ECBOT to the file ZB-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:15 HD Request # 17 | Download start date-time: 2018-03-23 16:42:50.000 | 2018-03-23 16:53:15 HD Request # 17 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:15 Socket (35) | Creating socket. | 2018-03-23 16:53:15 Socket (35) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:15 Chart #6 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:15 Socket (34) | Socket gracefully closed by remote side. | 2018-03-23 16:53:15 Socket (34) | Closed. | 2018-03-23 16:53:15 HD Request # 17 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:15 HD Request # 17 | Sending historical data logon request message. | 2018-03-23 16:53:15 Chart #8 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:15 HD Request # 17 | Requesting Intraday data. Start date-time: 2018-03-23 16:42:50. Record interval: 0. Symbol: ZBM18 | 2018-03-23 16:53:15 HD Request # 17 | Decompressing data. | 2018-03-23 16:53:15 HD Request # 17 | Receiving Intraday data for ZB-201806-ECBOT starting at 2018-03-23 16:42:50 | 2018-03-23 16:53:15 Socket (35) | Initiating close of socket by core. | 2018-03-23 16:53:15 Socket (35) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:15 HD Request # 17 | Historical data for ZB-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:15 Historical data download thread signaled to stop. | 2018-03-23 16:53:15 HD Request # 17 | Received 7 records from 2018-03-23 16:42:50 to 2018-03-23 16:42:50 (0.0 seconds) and wrote 0 records for ZB-201806-ECBOT | 2018-03-23 16:53:15 HD Request # 17 | Completion time: 1s | 2018-03-23 16:53:15 HD Request # 17 | Intraday data download complete for ZB-201806-ECBOT. Unique request ID: 24 | 2018-03-23 16:53:15 Removed historical data download ID 24 | 2018-03-23 16:53:15 Interactive Brokers | Using primary service for historical data for ZB-201806-ECBOT | 2018-03-23 16:53:15 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:15 Chart #9 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:15 Socket (35) | Socket gracefully closed by remote side. | 2018-03-23 16:53:15 Socket (35) | Closed. | 2018-03-23 16:53:15 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:15 Starting TWS auto-login thread. | 2018-03-23 16:53:15 TWS auto-login thread ending. | 2018-03-23 16:53:15 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:15 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:53:17 Socket (36) | Creating socket. | 2018-03-23 16:53:17 Socket (36) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:53:17 Interactive Brokers | Sending API sign: API | 2018-03-23 16:53:17 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 16:53:17 Interactive Brokers | TWS server version: 136 | 2018-03-23 16:53:17 Interactive Brokers | TWS time: 20180323 16:53:16 EST | 2018-03-23 16:53:17 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 16:53:17 IB Account information received. | 2018-03-23 16:53:17 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:53:17 Interactive Brokers | Connected to Live account. | 2018-03-23 16:53:17 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:53:17 Interactive Brokers | Connected to data and trading server. | 2018-03-23 16:53:17 Next valid order ID: 29 | 2018-03-23 16:53:17 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:17 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:17 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:17 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:17 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:17 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:17 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:17 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:17 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:17 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:17 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:17 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:17 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:17 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:17 HD Request # 18 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-03-23 16:53:17 HD Request # 18 | Download start date-time: 2018-03-23 16:43:13.000 | 2018-03-23 16:53:17 HD Request # 18 | Requesting a total of 0 days and 5404 seconds. | 2018-03-23 16:53:17 HD Request # 18 | IB Backfill - Seconds requested: 5404. Seconds Remaining: 0. | 2018-03-23 16:53:17 HD Request # 18 | Requesting 5404 Seconds of data at 30 secs with ending date-time at 2018-03-23 18:03:17 for NQ-201806-GLOBEX. PriceType: TRADES | 2018-03-23 16:53:17 Interactive Brokers | Starting real-time market data updates for: ES-201806-GLOBEX. ID: 2 | 2018-03-23 16:53:17 Interactive Brokers | Subscribing to real-time True Data for symbol: ES SecurityType: FUT Exchange: GLOBEX Currency: | 2018-03-23 16:53:17 Interactive Brokers | Subscribing to Symbol: ES, SecurityType: FUT, Expiration: 201806, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-03-23 16:53:17 Interactive Brokers | Requesting security definition data for: ES-201806-GLOBEX. ID: 2 | 2018-03-23 16:53:17 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ES-201806-GLOBEX | 2018-03-23 16:53:17 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:17 Socket (36) | Socket gracefully closed by remote side. | 2018-03-23 16:53:17 Socket (36) | Received socket Close event. | 2018-03-23 16:53:17 Delaying start of download for ES-201806-GLOBEX | 2018-03-23 16:53:17 Socket (36) | Initiating close of socket by core. | 2018-03-23 16:53:17 Connection to the external service has been lost. | 2018-03-23 16:53:17 Socket (36) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:53:17 Socket (36) | Closed. | 2018-03-23 16:53:17 Canceling historical data download request for ZN-201806-ECBOT Intraday data. | 2018-03-23 16:53:17 Removed historical data download ID 25 | 2018-03-23 16:53:17 Canceling historical data download request for ZB-201806-ECBOT Intraday data. | 2018-03-23 16:53:17 Removed historical data download ID 26 | 2018-03-23 16:53:17 HD Request # 18 | Download canceled. | 2018-03-23 16:53:17 HD Request # 18 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201806-GLOBEX | 2018-03-23 16:53:17 HD Request # 18 | Completion time: 0s | 2018-03-23 16:53:17 HD Request # 18 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 23 | 2018-03-23 16:53:17 Removed historical data download ID 23 | 2018-03-23 16:53:17 Interactive Brokers | Disconnected. | 2018-03-23 16:53:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:53:17 Chart #6 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:17 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZN-201806-ECBOT | 2018-03-23 16:53:17 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:17 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZB-201806-ECBOT | 2018-03-23 16:53:18 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:18 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:18 HD Request # 19 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:18 HD Request # 19 | Download start date-time: 2018-03-23 16:43:10.000 | 2018-03-23 16:53:18 HD Request # 19 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:18 Socket (37) | Creating socket. | 2018-03-23 16:53:18 Socket (37) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:18 HD Request # 19 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:18 HD Request # 19 | Sending historical data logon request message. | 2018-03-23 16:53:18 HD Request # 19 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:10. Record interval: 0. Symbol: ESM18 | 2018-03-23 16:53:18 HD Request # 19 | Decompressing data. | 2018-03-23 16:53:18 HD Request # 19 | Receiving Intraday data for ES-201806-GLOBEX starting at 2018-03-23 16:43:10 | 2018-03-23 16:53:18 HD Request # 19 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:11 | 2018-03-23 16:53:18 Socket (37) | Initiating close of socket by core. | 2018-03-23 16:53:18 HD Request # 19 | Historical data for ES-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:18 Socket (37) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:18 Historical data download thread signaled to stop. | 2018-03-23 16:53:18 HD Request # 19 | Received 6 records from 2018-03-23 16:43:10 to 2018-03-23 16:43:18 (8.0 seconds) and wrote 5 records for ES-201806-GLOBEX | 2018-03-23 16:53:18 HD Request # 19 | Completion time: 0s | 2018-03-23 16:53:18 HD Request # 19 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 27 | 2018-03-23 16:53:18 Removed historical data download ID 27 | 2018-03-23 16:53:18 Interactive Brokers | Using primary service for historical data for ES-201806-GLOBEX | 2018-03-23 16:53:18 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:18 HD Request # 20 | Downloading Intraday chart data for ZN-201806-ECBOT to the file ZN-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:18 HD Request # 20 | Download start date-time: 2018-03-23 16:43:07.000 | 2018-03-23 16:53:18 HD Request # 20 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:18 Socket (38) | Creating socket. | 2018-03-23 16:53:18 Socket (38) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:18 Socket (37) | Socket gracefully closed by remote side. | 2018-03-23 16:53:19 Socket (37) | Closed. | 2018-03-23 16:53:19 HD Request # 20 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:19 HD Request # 20 | Sending historical data logon request message. | 2018-03-23 16:53:19 HD Request # 20 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:07. Record interval: 0. Symbol: ZNM18 | 2018-03-23 16:53:19 HD Request # 20 | Decompressing data. | 2018-03-23 16:53:19 HD Request # 20 | Receiving Intraday data for ZN-201806-ECBOT starting at 2018-03-23 16:43:07 | 2018-03-23 16:53:19 Socket (38) | Initiating close of socket by core. | 2018-03-23 16:53:19 Socket (38) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:19 HD Request # 20 | Historical data for ZN-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:19 Historical data download thread signaled to stop. | 2018-03-23 16:53:19 HD Request # 20 | Received 1 record from 2018-03-23 16:43:07 to 2018-03-23 16:43:07 (0.0 seconds) and wrote 0 records for ZN-201806-ECBOT | 2018-03-23 16:53:19 HD Request # 20 | Completion time: 0s | 2018-03-23 16:53:19 HD Request # 20 | Intraday data download complete for ZN-201806-ECBOT. Unique request ID: 28 | 2018-03-23 16:53:19 Removed historical data download ID 28 | 2018-03-23 16:53:19 Interactive Brokers | Using primary service for historical data for ZN-201806-ECBOT | 2018-03-23 16:53:19 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:19 HD Request # 21 | Downloading Intraday chart data for ZB-201806-ECBOT to the file ZB-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:19 HD Request # 21 | Download start date-time: 2018-03-23 16:42:50.000 | 2018-03-23 16:53:19 HD Request # 21 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:19 Socket (39) | Creating socket. | 2018-03-23 16:53:19 Socket (39) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:19 Socket (38) | Socket gracefully closed by remote side. | 2018-03-23 16:53:19 Socket (38) | Closed. | 2018-03-23 16:53:19 Chart #5 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:19 Chart #5 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:19 HD Request # 21 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:19 HD Request # 21 | Sending historical data logon request message. | 2018-03-23 16:53:19 HD Request # 21 | Requesting Intraday data. Start date-time: 2018-03-23 16:42:50. Record interval: 0. Symbol: ZBM18 | 2018-03-23 16:53:19 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:19 HD Request # 21 | Decompressing data. | 2018-03-23 16:53:19 HD Request # 21 | Receiving Intraday data for ZB-201806-ECBOT starting at 2018-03-23 16:42:50 | 2018-03-23 16:53:19 Socket (39) | Initiating close of socket by core. | 2018-03-23 16:53:19 Socket (39) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:19 Socket (39) | Socket gracefully closed by remote side. | 2018-03-23 16:53:19 Socket (39) | Closed. | 2018-03-23 16:53:19 HD Request # 21 | Historical data for ZB-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:19 Historical data download thread signaled to stop. | 2018-03-23 16:53:19 HD Request # 21 | Received 7 records from 2018-03-23 16:42:50 to 2018-03-23 16:42:50 (0.0 seconds) and wrote 0 records for ZB-201806-ECBOT | 2018-03-23 16:53:19 HD Request # 21 | Completion time: 0s | 2018-03-23 16:53:19 HD Request # 21 | Intraday data download complete for ZB-201806-ECBOT. Unique request ID: 29 | 2018-03-23 16:53:19 Removed historical data download ID 29 | 2018-03-23 16:53:19 Interactive Brokers | Using primary service for historical data for ZB-201806-ECBOT | 2018-03-23 16:53:19 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:19 Chart #8 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:19 Chart #9 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:19 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:19 Starting TWS auto-login thread. | 2018-03-23 16:53:19 TWS auto-login thread ending. | 2018-03-23 16:53:19 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:19 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:53:20 Socket (40) | Creating socket. | 2018-03-23 16:53:20 Socket (40) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:53:20 Interactive Brokers | Sending API sign: API | 2018-03-23 16:53:23 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 16:53:23 Interactive Brokers | TWS server version: 136 | 2018-03-23 16:53:23 Interactive Brokers | TWS time: 20180323 16:53:22 EST | 2018-03-23 16:53:23 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 16:53:23 IB Account information received. | 2018-03-23 16:53:23 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:53:23 Interactive Brokers | Connected to Live account. | 2018-03-23 16:53:23 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:53:23 Interactive Brokers | Connected to data and trading server. | 2018-03-23 16:53:23 Next valid order ID: 29 | 2018-03-23 16:53:23 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:23 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:23 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:23 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:23 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:23 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:23 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:23 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:23 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:23 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:23 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:23 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:23 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:23 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:23 HD Request # 22 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-03-23 16:53:23 HD Request # 22 | Download start date-time: 2018-03-23 16:43:18.000 | 2018-03-23 16:53:23 HD Request # 22 | Requesting a total of 0 days and 5405 seconds. | 2018-03-23 16:53:23 HD Request # 22 | IB Backfill - Seconds requested: 5405. Seconds Remaining: 0. | 2018-03-23 16:53:23 HD Request # 22 | Requesting 5405 Seconds of data at 30 secs with ending date-time at 2018-03-23 18:03:23 for ES-201806-GLOBEX. PriceType: TRADES | 2018-03-23 16:53:23 Interactive Brokers | Starting real-time market data updates for: NQ-201806-GLOBEX. ID: 2 | 2018-03-23 16:53:23 Interactive Brokers | Subscribing to real-time True Data for symbol: NQ SecurityType: FUT Exchange: GLOBEX Currency: | 2018-03-23 16:53:23 Interactive Brokers | Subscribing to Symbol: NQ, SecurityType: FUT, Expiration: 201806, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-03-23 16:53:23 Interactive Brokers | Requesting security definition data for: NQ-201806-GLOBEX. ID: 2 | 2018-03-23 16:53:23 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-201806-GLOBEX | 2018-03-23 16:53:23 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:23 Socket (40) | Received socket Close event. | 2018-03-23 16:53:23 Socket (40) | Socket gracefully closed by remote side. | 2018-03-23 16:53:23 Delaying start of download for NQ-201806-GLOBEX | 2018-03-23 16:53:23 Next valid order ID: 29 | 2018-03-23 16:53:23 Socket (40) | Initiating close of socket by core. | 2018-03-23 16:53:23 Connection to the external service has been lost. | 2018-03-23 16:53:23 Socket (40) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:53:23 Socket (40) | Closed. | 2018-03-23 16:53:23 Canceling historical data download request for ZN-201806-ECBOT Intraday data. | 2018-03-23 16:53:23 Removed historical data download ID 31 | 2018-03-23 16:53:23 Canceling historical data download request for ZB-201806-ECBOT Intraday data. | 2018-03-23 16:53:23 Removed historical data download ID 32 | 2018-03-23 16:53:23 HD Request # 22 | Download canceled. | 2018-03-23 16:53:23 HD Request # 22 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-03-23 16:53:23 HD Request # 22 | Completion time: 0s | 2018-03-23 16:53:23 HD Request # 22 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 30 | 2018-03-23 16:53:23 Removed historical data download ID 30 | 2018-03-23 16:53:23 Interactive Brokers | Disconnected. | 2018-03-23 16:53:23 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:53:23 Starting TWS auto-login thread. | 2018-03-23 16:53:23 TWS auto-login thread ending. | 2018-03-23 16:53:23 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZN-201806-ECBOT | 2018-03-23 16:53:23 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:23 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZB-201806-ECBOT | 2018-03-23 16:53:24 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:24 Chart #5 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:24 Chart #5 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:24 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:24 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:24 HD Request # 23 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:24 HD Request # 23 | Download start date-time: 2018-03-23 16:43:13.000 | 2018-03-23 16:53:24 HD Request # 23 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:24 Socket (41) | Creating socket. | 2018-03-23 16:53:24 Socket (41) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:24 HD Request # 23 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:24 HD Request # 23 | Sending historical data logon request message. | 2018-03-23 16:53:24 HD Request # 23 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:13. Record interval: 0. Symbol: NQM18 | 2018-03-23 16:53:25 HD Request # 23 | Decompressing data. | 2018-03-23 16:53:25 HD Request # 23 | Receiving Intraday data for NQ-201806-GLOBEX starting at 2018-03-23 16:43:13 | 2018-03-23 16:53:25 HD Request # 23 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:21 | 2018-03-23 16:53:25 Socket (41) | Initiating close of socket by core. | 2018-03-23 16:53:25 HD Request # 23 | Historical data for NQ-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:25 Socket (41) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:25 Historical data download thread signaled to stop. | 2018-03-23 16:53:25 HD Request # 23 | Received 4 records from 2018-03-23 16:43:13 to 2018-03-23 16:43:22 (9.0 seconds) and wrote 3 records for NQ-201806-GLOBEX | 2018-03-23 16:53:25 HD Request # 23 | Completion time: 0s | 2018-03-23 16:53:25 HD Request # 23 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 33 | 2018-03-23 16:53:25 Removed historical data download ID 33 | 2018-03-23 16:53:25 Interactive Brokers | Using primary service for historical data for NQ-201806-GLOBEX | 2018-03-23 16:53:25 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:25 HD Request # 24 | Downloading Intraday chart data for ZN-201806-ECBOT to the file ZN-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:25 HD Request # 24 | Download start date-time: 2018-03-23 16:43:07.000 | 2018-03-23 16:53:25 HD Request # 24 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:25 Socket (42) | Creating socket. | 2018-03-23 16:53:25 Socket (42) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:25 Socket (41) | Socket gracefully closed by remote side. | 2018-03-23 16:53:25 Socket (41) | Closed. | 2018-03-23 16:53:25 HD Request # 24 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:25 HD Request # 24 | Sending historical data logon request message. | 2018-03-23 16:53:25 Chart #6 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:25 HD Request # 24 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:07. Record interval: 0. Symbol: ZNM18 | 2018-03-23 16:53:25 HD Request # 24 | Decompressing data. | 2018-03-23 16:53:25 HD Request # 24 | Receiving Intraday data for ZN-201806-ECBOT starting at 2018-03-23 16:43:07 | 2018-03-23 16:53:25 HD Request # 24 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:20 | 2018-03-23 16:53:25 Socket (42) | Initiating close of socket by core. | 2018-03-23 16:53:25 Socket (42) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:25 HD Request # 24 | Historical data for ZN-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:25 Historical data download thread signaled to stop. | 2018-03-23 16:53:25 HD Request # 24 | Received 3 records from 2018-03-23 16:43:07 to 2018-03-23 16:43:22 (15.0 seconds) and wrote 2 records for ZN-201806-ECBOT | 2018-03-23 16:53:25 HD Request # 24 | Completion time: 1s | 2018-03-23 16:53:25 HD Request # 24 | Intraday data download complete for ZN-201806-ECBOT. Unique request ID: 34 | 2018-03-23 16:53:25 Removed historical data download ID 34 | 2018-03-23 16:53:25 Interactive Brokers | Using primary service for historical data for ZN-201806-ECBOT | 2018-03-23 16:53:25 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:25 HD Request # 25 | Downloading Intraday chart data for ZB-201806-ECBOT to the file ZB-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:25 HD Request # 25 | Download start date-time: 2018-03-23 16:42:50.000 | 2018-03-23 16:53:25 HD Request # 25 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:25 Socket (43) | Creating socket. | 2018-03-23 16:53:25 Socket (43) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:25 Socket (42) | Socket gracefully closed by remote side. | 2018-03-23 16:53:25 Socket (42) | Closed. | 2018-03-23 16:53:25 HD Request # 25 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:25 HD Request # 25 | Sending historical data logon request message. | 2018-03-23 16:53:25 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:25 HD Request # 25 | Requesting Intraday data. Start date-time: 2018-03-23 16:42:50. Record interval: 0. Symbol: ZBM18 | 2018-03-23 16:53:25 HD Request # 25 | Decompressing data. | 2018-03-23 16:53:25 HD Request # 25 | Receiving Intraday data for ZB-201806-ECBOT starting at 2018-03-23 16:42:50 | 2018-03-23 16:53:25 Socket (43) | Initiating close of socket by core. | 2018-03-23 16:53:25 Socket (43) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:25 HD Request # 25 | Historical data for ZB-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:25 Historical data download thread signaled to stop. | 2018-03-23 16:53:25 HD Request # 25 | Received 7 records from 2018-03-23 16:42:50 to 2018-03-23 16:42:50 (0.0 seconds) and wrote 0 records for ZB-201806-ECBOT | 2018-03-23 16:53:25 HD Request # 25 | Completion time: 0s | 2018-03-23 16:53:25 HD Request # 25 | Intraday data download complete for ZB-201806-ECBOT. Unique request ID: 35 | 2018-03-23 16:53:25 Removed historical data download ID 35 | 2018-03-23 16:53:25 Interactive Brokers | Using primary service for historical data for ZB-201806-ECBOT | 2018-03-23 16:53:25 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:25 Socket (43) | Socket gracefully closed by remote side. | 2018-03-23 16:53:25 Socket (43) | Closed. | 2018-03-23 16:53:25 Chart #8 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:25 Chart #9 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:26 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:26 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:53:26 Socket (44) | Creating socket. | 2018-03-23 16:53:26 Socket (44) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:53:26 Interactive Brokers | Sending API sign: API | 2018-03-23 16:53:26 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 16:53:26 Interactive Brokers | TWS server version: 136 | 2018-03-23 16:53:26 Interactive Brokers | TWS time: 20180323 16:53:25 EST | 2018-03-23 16:53:26 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 16:53:26 IB Account information received. | 2018-03-23 16:53:26 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:53:26 Interactive Brokers | Connected to Live account. | 2018-03-23 16:53:26 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:53:26 Interactive Brokers | Connected to data and trading server. | 2018-03-23 16:53:26 Next valid order ID: 29 | 2018-03-23 16:53:26 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:26 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:26 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:26 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:26 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:26 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:26 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:26 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:26 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:26 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:26 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:26 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:26 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:26 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:26 HD Request # 26 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-03-23 16:53:26 HD Request # 26 | Download start date-time: 2018-03-23 16:43:22.000 | 2018-03-23 16:53:26 HD Request # 26 | Requesting a total of 0 days and 5404 seconds. | 2018-03-23 16:53:26 HD Request # 26 | IB Backfill - Seconds requested: 5404. Seconds Remaining: 0. | 2018-03-23 16:53:26 HD Request # 26 | Requesting 5404 Seconds of data at 30 secs with ending date-time at 2018-03-23 18:03:26 for NQ-201806-GLOBEX. PriceType: TRADES | 2018-03-23 16:53:26 Interactive Brokers | Starting real-time market data updates for: ES-201806-GLOBEX. ID: 2 | 2018-03-23 16:53:26 Interactive Brokers | Subscribing to real-time True Data for symbol: ES SecurityType: FUT Exchange: GLOBEX Currency: | 2018-03-23 16:53:26 Interactive Brokers | Subscribing to Symbol: ES, SecurityType: FUT, Expiration: 201806, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-03-23 16:53:26 Interactive Brokers | Requesting security definition data for: ES-201806-GLOBEX. ID: 2 | 2018-03-23 16:53:26 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ES-201806-GLOBEX | 2018-03-23 16:53:26 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:26 Socket (44) | Socket gracefully closed by remote side. | 2018-03-23 16:53:26 Socket (44) | Received socket Close event. | 2018-03-23 16:53:26 Delaying start of download for ES-201806-GLOBEX | 2018-03-23 16:53:26 Next valid order ID: 29 | 2018-03-23 16:53:26 Socket (44) | Initiating close of socket by core. | 2018-03-23 16:53:26 Connection to the external service has been lost. | 2018-03-23 16:53:26 Socket (44) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:53:26 Socket (44) | Closed. | 2018-03-23 16:53:26 Canceling historical data download request for ZN-201806-ECBOT Intraday data. | 2018-03-23 16:53:26 Removed historical data download ID 37 | 2018-03-23 16:53:26 Canceling historical data download request for ZB-201806-ECBOT Intraday data. | 2018-03-23 16:53:26 Removed historical data download ID 38 | 2018-03-23 16:53:26 HD Request # 26 | Download canceled. | 2018-03-23 16:53:26 HD Request # 26 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201806-GLOBEX | 2018-03-23 16:53:26 HD Request # 26 | Completion time: 0s | 2018-03-23 16:53:26 HD Request # 26 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 36 | 2018-03-23 16:53:26 Removed historical data download ID 36 | 2018-03-23 16:53:26 Interactive Brokers | Disconnected. | 2018-03-23 16:53:26 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:53:26 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZN-201806-ECBOT | 2018-03-23 16:53:26 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:26 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZB-201806-ECBOT | 2018-03-23 16:53:27 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:27 Chart #6 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:27 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:27 Starting TWS auto-login thread. | 2018-03-23 16:53:27 TWS auto-login thread ending. | 2018-03-23 16:53:27 HD Request # 27 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:27 HD Request # 27 | Download start date-time: 2018-03-23 16:43:18.000 | 2018-03-23 16:53:27 HD Request # 27 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:27 Socket (45) | Creating socket. | 2018-03-23 16:53:27 Socket (45) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:27 HD Request # 27 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:28 HD Request # 27 | Sending historical data logon request message. | 2018-03-23 16:53:28 HD Request # 27 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:18. Record interval: 0. Symbol: ESM18 | 2018-03-23 16:53:28 HD Request # 27 | Decompressing data. | 2018-03-23 16:53:28 HD Request # 27 | Receiving Intraday data for ES-201806-GLOBEX starting at 2018-03-23 16:43:18 | 2018-03-23 16:53:28 HD Request # 27 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:20 | 2018-03-23 16:53:28 Socket (45) | Initiating close of socket by core. | 2018-03-23 16:53:28 HD Request # 27 | Historical data for ES-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:28 Socket (45) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:28 Historical data download thread signaled to stop. | 2018-03-23 16:53:28 HD Request # 27 | Received 6 records from 2018-03-23 16:43:18 to 2018-03-23 16:43:26 (8.0 seconds) and wrote 5 records for ES-201806-GLOBEX | 2018-03-23 16:53:28 HD Request # 27 | Completion time: 0s | 2018-03-23 16:53:28 HD Request # 27 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 39 | 2018-03-23 16:53:28 Removed historical data download ID 39 | 2018-03-23 16:53:28 Interactive Brokers | Using primary service for historical data for ES-201806-GLOBEX | 2018-03-23 16:53:28 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:28 HD Request # 28 | Downloading Intraday chart data for ZN-201806-ECBOT to the file ZN-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:28 HD Request # 28 | Download start date-time: 2018-03-23 16:43:22.000 | 2018-03-23 16:53:28 HD Request # 28 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:28 Socket (46) | Creating socket. | 2018-03-23 16:53:28 Socket (46) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:28 Socket (45) | Socket gracefully closed by remote side. | 2018-03-23 16:53:28 Socket (45) | Closed. | 2018-03-23 16:53:28 HD Request # 28 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:28 HD Request # 28 | Sending historical data logon request message. | 2018-03-23 16:53:28 Chart #5 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:28 Chart #5 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:28 HD Request # 28 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:22. Record interval: 0. Symbol: ZNM18 | 2018-03-23 16:53:28 HD Request # 28 | Decompressing data. | 2018-03-23 16:53:28 HD Request # 28 | Receiving Intraday data for ZN-201806-ECBOT starting at 2018-03-23 16:43:22 | 2018-03-23 16:53:28 Socket (46) | Initiating close of socket by core. | 2018-03-23 16:53:28 HD Request # 28 | Historical data for ZN-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:28 Socket (46) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:28 Historical data download thread signaled to stop. | 2018-03-23 16:53:28 HD Request # 28 | Received 1 record from 2018-03-23 16:43:22 to 2018-03-23 16:43:22 (0.0 seconds) and wrote 0 records for ZN-201806-ECBOT | 2018-03-23 16:53:28 HD Request # 28 | Completion time: 0s | 2018-03-23 16:53:28 HD Request # 28 | Intraday data download complete for ZN-201806-ECBOT. Unique request ID: 40 | 2018-03-23 16:53:28 Removed historical data download ID 40 | 2018-03-23 16:53:28 Interactive Brokers | Using primary service for historical data for ZN-201806-ECBOT | 2018-03-23 16:53:28 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:28 HD Request # 29 | Downloading Intraday chart data for ZB-201806-ECBOT to the file ZB-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:28 HD Request # 29 | Download start date-time: 2018-03-23 16:42:50.000 | 2018-03-23 16:53:28 HD Request # 29 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:28 Socket (47) | Creating socket. | 2018-03-23 16:53:28 Socket (47) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:28 Socket (46) | Socket gracefully closed by remote side. | 2018-03-23 16:53:28 Socket (46) | Closed. | 2018-03-23 16:53:28 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:28 HD Request # 29 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:28 HD Request # 29 | Sending historical data logon request message. | 2018-03-23 16:53:28 Chart #8 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:28 HD Request # 29 | Requesting Intraday data. Start date-time: 2018-03-23 16:42:50. Record interval: 0. Symbol: ZBM18 | 2018-03-23 16:53:28 HD Request # 29 | Decompressing data. | 2018-03-23 16:53:28 HD Request # 29 | Receiving Intraday data for ZB-201806-ECBOT starting at 2018-03-23 16:42:50 | 2018-03-23 16:53:28 Socket (47) | Initiating close of socket by core. | 2018-03-23 16:53:28 HD Request # 29 | Historical data for ZB-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:28 Socket (47) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:28 Historical data download thread signaled to stop. | 2018-03-23 16:53:28 HD Request # 29 | Received 7 records from 2018-03-23 16:42:50 to 2018-03-23 16:42:50 (0.0 seconds) and wrote 0 records for ZB-201806-ECBOT | 2018-03-23 16:53:28 HD Request # 29 | Completion time: 1s | 2018-03-23 16:53:28 HD Request # 29 | Intraday data download complete for ZB-201806-ECBOT. Unique request ID: 41 | 2018-03-23 16:53:28 Removed historical data download ID 41 | 2018-03-23 16:53:28 Interactive Brokers | Using primary service for historical data for ZB-201806-ECBOT | 2018-03-23 16:53:28 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:28 Chart #9 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:28 Socket (47) | Socket gracefully closed by remote side. | 2018-03-23 16:53:28 Socket (47) | Closed. | 2018-03-23 16:53:28 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:28 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:28 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:53:29 Socket (48) | Creating socket. | 2018-03-23 16:53:29 Socket (48) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:53:29 Interactive Brokers | Sending API sign: API | 2018-03-23 16:53:29 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 16:53:29 Interactive Brokers | TWS server version: 136 | 2018-03-23 16:53:29 Interactive Brokers | TWS time: 20180323 16:53:28 EST | 2018-03-23 16:53:29 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 16:53:29 IB Account information received. | 2018-03-23 16:53:29 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:53:29 Interactive Brokers | Connected to Live account. | 2018-03-23 16:53:29 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:53:29 Interactive Brokers | Connected to data and trading server. | 2018-03-23 16:53:29 Next valid order ID: 29 | 2018-03-23 16:53:29 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:29 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:29 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:29 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:29 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:29 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:29 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:29 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:29 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:29 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:29 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:29 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:29 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:29 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:29 HD Request # 30 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-03-23 16:53:29 HD Request # 30 | Download start date-time: 2018-03-23 16:43:26.000 | 2018-03-23 16:53:29 HD Request # 30 | Requesting a total of 0 days and 5403 seconds. | 2018-03-23 16:53:29 HD Request # 30 | IB Backfill - Seconds requested: 5403. Seconds Remaining: 0. | 2018-03-23 16:53:29 HD Request # 30 | Requesting 5403 Seconds of data at 30 secs with ending date-time at 2018-03-23 18:03:29 for ES-201806-GLOBEX. PriceType: TRADES | 2018-03-23 16:53:29 Interactive Brokers | Starting real-time market data updates for: ZN-201806-ECBOT. ID: 2 | 2018-03-23 16:53:30 Interactive Brokers | Subscribing to real-time True Data for symbol: ZN SecurityType: FUT Exchange: ECBOT Currency: | 2018-03-23 16:53:30 Interactive Brokers | Subscribing to Symbol: ZN, SecurityType: FUT, Expiration: 201806, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-03-23 16:53:30 Interactive Brokers | Requesting security definition data for: ZN-201806-ECBOT. ID: 2 | 2018-03-23 16:53:30 Socket (48) | Socket gracefully closed by remote side. | 2018-03-23 16:53:30 Socket (48) | Received socket Close event. | 2018-03-23 16:53:30 Next valid order ID: 29 | 2018-03-23 16:53:30 Socket (48) | Initiating close of socket by core. | 2018-03-23 16:53:30 Connection to the external service has been lost. | 2018-03-23 16:53:30 Socket (48) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:53:30 Socket (48) | Closed. | 2018-03-23 16:53:30 Canceling historical data download request for ZN-201806-ECBOT Intraday data. | 2018-03-23 16:53:30 Removed historical data download ID 43 | 2018-03-23 16:53:30 Canceling historical data download request for ZB-201806-ECBOT Intraday data. | 2018-03-23 16:53:30 Removed historical data download ID 44 | 2018-03-23 16:53:30 HD Request # 30 | Download canceled. | 2018-03-23 16:53:30 HD Request # 30 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-03-23 16:53:30 HD Request # 30 | Completion time: 0s | 2018-03-23 16:53:30 HD Request # 30 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 42 | 2018-03-23 16:53:30 Removed historical data download ID 42 | 2018-03-23 16:53:30 Interactive Brokers | Disconnected. | 2018-03-23 16:53:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:53:30 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZB-201806-ECBOT | 2018-03-23 16:53:30 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:30 HD Request # 31 | Downloading Intraday chart data for ZB-201806-ECBOT to the file ZB-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:30 HD Request # 31 | Download start date-time: 2018-03-23 16:42:50.000 | 2018-03-23 16:53:30 HD Request # 31 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:30 Socket (49) | Creating socket. | 2018-03-23 16:53:30 Socket (49) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:30 HD Request # 31 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:30 HD Request # 31 | Sending historical data logon request message. | 2018-03-23 16:53:30 Chart #5 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:30 Chart #5 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:30 HD Request # 31 | Requesting Intraday data. Start date-time: 2018-03-23 16:42:50. Record interval: 0. Symbol: ZBM18 | 2018-03-23 16:53:30 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-201806-GLOBEX | 2018-03-23 16:53:30 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:30 HD Request # 31 | Decompressing data. | 2018-03-23 16:53:30 HD Request # 31 | Receiving Intraday data for ZB-201806-ECBOT starting at 2018-03-23 16:42:50 | 2018-03-23 16:53:30 Socket (49) | Initiating close of socket by core. | 2018-03-23 16:53:30 HD Request # 31 | Historical data for ZB-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:30 Socket (49) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:30 Historical data download thread signaled to stop. | 2018-03-23 16:53:30 HD Request # 31 | Received 7 records from 2018-03-23 16:42:50 to 2018-03-23 16:42:50 (0.0 seconds) and wrote 0 records for ZB-201806-ECBOT | 2018-03-23 16:53:30 HD Request # 31 | Completion time: 0s | 2018-03-23 16:53:30 HD Request # 31 | Intraday data download complete for ZB-201806-ECBOT. Unique request ID: 45 | 2018-03-23 16:53:30 Removed historical data download ID 45 | 2018-03-23 16:53:30 Interactive Brokers | Using primary service for historical data for ZB-201806-ECBOT | 2018-03-23 16:53:30 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:30 HD Request # 32 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:30 HD Request # 32 | Download start date-time: 2018-03-23 16:43:22.000 | 2018-03-23 16:53:30 HD Request # 32 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:30 Socket (50) | Creating socket. | 2018-03-23 16:53:30 Socket (50) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:30 Socket (49) | Socket gracefully closed by remote side. | 2018-03-23 16:53:30 Socket (49) | Closed. | 2018-03-23 16:53:30 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:30 HD Request # 32 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:30 HD Request # 32 | Sending historical data logon request message. | 2018-03-23 16:53:30 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZN-201806-ECBOT | 2018-03-23 16:53:30 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:30 HD Request # 32 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:22. Record interval: 0. Symbol: NQM18 | 2018-03-23 16:53:30 HD Request # 32 | Decompressing data. | 2018-03-23 16:53:30 HD Request # 32 | Receiving Intraday data for NQ-201806-GLOBEX starting at 2018-03-23 16:43:22 | 2018-03-23 16:53:30 HD Request # 32 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:25 | 2018-03-23 16:53:30 Socket (50) | Initiating close of socket by core. | 2018-03-23 16:53:30 Socket (50) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:30 HD Request # 32 | Historical data for NQ-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:30 Historical data download thread signaled to stop. | 2018-03-23 16:53:30 HD Request # 32 | Received 10 records from 2018-03-23 16:43:22 to 2018-03-23 16:43:28 (6.0 seconds) and wrote 8 records for NQ-201806-GLOBEX | 2018-03-23 16:53:30 HD Request # 32 | Completion time: 1s | 2018-03-23 16:53:30 HD Request # 32 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 46 | 2018-03-23 16:53:30 Removed historical data download ID 46 | 2018-03-23 16:53:30 Interactive Brokers | Using primary service for historical data for NQ-201806-GLOBEX | 2018-03-23 16:53:30 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:30 HD Request # 33 | Downloading Intraday chart data for ZN-201806-ECBOT to the file ZN-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:30 HD Request # 33 | Download start date-time: 2018-03-23 16:43:22.000 | 2018-03-23 16:53:30 HD Request # 33 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:30 Socket (51) | Creating socket. | 2018-03-23 16:53:30 Socket (51) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:30 Chart #9 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:30 Socket (50) | Socket gracefully closed by remote side. | 2018-03-23 16:53:30 Socket (50) | Closed. | 2018-03-23 16:53:30 HD Request # 33 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:30 HD Request # 33 | Sending historical data logon request message. | 2018-03-23 16:53:30 HD Request # 33 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:22. Record interval: 0. Symbol: ZNM18 | 2018-03-23 16:53:30 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:30 HD Request # 33 | Decompressing data. | 2018-03-23 16:53:30 HD Request # 33 | Receiving Intraday data for ZN-201806-ECBOT starting at 2018-03-23 16:43:22 | 2018-03-23 16:53:30 Socket (51) | Initiating close of socket by core. | 2018-03-23 16:53:30 Socket (51) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:30 HD Request # 33 | Historical data for ZN-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:30 Historical data download thread signaled to stop. | 2018-03-23 16:53:30 HD Request # 33 | Received 1 record from 2018-03-23 16:43:22 to 2018-03-23 16:43:22 (0.0 seconds) and wrote 0 records for ZN-201806-ECBOT | 2018-03-23 16:53:30 HD Request # 33 | Completion time: 0s | 2018-03-23 16:53:30 HD Request # 33 | Intraday data download complete for ZN-201806-ECBOT. Unique request ID: 48 | 2018-03-23 16:53:30 Removed historical data download ID 48 | 2018-03-23 16:53:30 Interactive Brokers | Using primary service for historical data for ZN-201806-ECBOT | 2018-03-23 16:53:30 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:30 Chart #6 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:30 Socket (51) | Socket gracefully closed by remote side. | 2018-03-23 16:53:30 Socket (51) | Closed. | 2018-03-23 16:53:30 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:30 Chart #8 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:30 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:31 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:31 Starting TWS auto-login thread. | 2018-03-23 16:53:31 TWS auto-login thread ending. | 2018-03-23 16:53:31 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:53:33 Socket (52) | Creating socket. | 2018-03-23 16:53:33 Socket (52) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:53:33 Interactive Brokers | Sending API sign: API | 2018-03-23 16:53:33 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 16:53:33 Interactive Brokers | TWS server version: 136 | 2018-03-23 16:53:33 Interactive Brokers | TWS time: 20180323 16:53:31 EST | 2018-03-23 16:53:33 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 16:53:33 IB Account information received. | 2018-03-23 16:53:33 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:53:33 Interactive Brokers | Connected to Live account. | 2018-03-23 16:53:33 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:53:33 Interactive Brokers | Connected to data and trading server. | 2018-03-23 16:53:33 Next valid order ID: 29 | 2018-03-23 16:53:33 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:33 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:33 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:33 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:33 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:33 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:33 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:33 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:33 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:33 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:33 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:33 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:33 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:33 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:33 HD Request # 34 | Downloading Intraday chart data for ZB-201806-ECBOT to the file ZB-201806-ECBOT.scid. Service: interactive_brokers.trading | 2018-03-23 16:53:33 HD Request # 34 | Download start date-time: 2018-03-23 16:42:50.000 | 2018-03-23 16:53:33 HD Request # 34 | Requesting a total of 0 days and 5442 seconds. | 2018-03-23 16:53:33 HD Request # 34 | IB Backfill - Seconds requested: 5442. Seconds Remaining: 0. | 2018-03-23 16:53:33 HD Request # 34 | Requesting 5442 Seconds of data at 30 secs with ending date-time at 2018-03-23 18:03:32 for ZB-201806-ECBOT. PriceType: TRADES | 2018-03-23 16:53:33 Interactive Brokers | Starting real-time market data updates for: ZB-201806-ECBOT. ID: 1 | 2018-03-23 16:53:33 Interactive Brokers | Subscribing to real-time True Data for symbol: ZB SecurityType: FUT Exchange: ECBOT Currency: | 2018-03-23 16:53:33 Interactive Brokers | Subscribing to Symbol: ZB, SecurityType: FUT, Expiration: 201806, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-03-23 16:53:33 Interactive Brokers | Requesting security definition data for: ZB-201806-ECBOT. ID: 1 | 2018-03-23 16:53:33 Socket (52) | Received socket Close event. | 2018-03-23 16:53:33 Socket (52) | Socket gracefully closed by remote side. | 2018-03-23 16:53:33 Next valid order ID: 29 | 2018-03-23 16:53:33 Socket (52) | Initiating close of socket by core. | 2018-03-23 16:53:33 Connection to the external service has been lost. | 2018-03-23 16:53:33 Socket (52) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:53:33 Socket (52) | Closed. | 2018-03-23 16:53:33 Canceling historical data download request for NQ-201806-GLOBEX Intraday data. | 2018-03-23 16:53:33 Removed historical data download ID 49 | 2018-03-23 16:53:33 Canceling historical data download request for ZN-201806-ECBOT Intraday data. | 2018-03-23 16:53:33 Removed historical data download ID 50 | 2018-03-23 16:53:33 HD Request # 34 | Download canceled. | 2018-03-23 16:53:33 HD Request # 34 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZB-201806-ECBOT | 2018-03-23 16:53:33 HD Request # 34 | Completion time: 0s | 2018-03-23 16:53:33 HD Request # 34 | Intraday data download complete for ZB-201806-ECBOT. Unique request ID: 47 | 2018-03-23 16:53:33 Removed historical data download ID 47 | 2018-03-23 16:53:33 Interactive Brokers | Disconnected. | 2018-03-23 16:53:33 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:53:33 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ES-201806-GLOBEX | 2018-03-23 16:53:33 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:33 HD Request # 35 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:33 HD Request # 35 | Download start date-time: 2018-03-23 16:43:26.000 | 2018-03-23 16:53:33 HD Request # 35 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:33 Socket (53) | Creating socket. | 2018-03-23 16:53:33 Socket (53) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:33 HD Request # 35 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:33 HD Request # 35 | Sending historical data logon request message. | 2018-03-23 16:53:33 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-201806-GLOBEX | 2018-03-23 16:53:33 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:33 HD Request # 35 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:26. Record interval: 0. Symbol: ESM18 | 2018-03-23 16:53:33 HD Request # 35 | Decompressing data. | 2018-03-23 16:53:33 HD Request # 35 | Receiving Intraday data for ES-201806-GLOBEX starting at 2018-03-23 16:43:26 | 2018-03-23 16:53:33 HD Request # 35 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:31 | 2018-03-23 16:53:33 Socket (53) | Initiating close of socket by core. | 2018-03-23 16:53:33 HD Request # 35 | Historical data for ES-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:33 Socket (53) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:33 Historical data download thread signaled to stop. | 2018-03-23 16:53:33 HD Request # 35 | Received 5 records from 2018-03-23 16:43:26 to 2018-03-23 16:43:32 (6.0 seconds) and wrote 4 records for ES-201806-GLOBEX | 2018-03-23 16:53:33 HD Request # 35 | Completion time: 0s | 2018-03-23 16:53:33 HD Request # 35 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 51 | 2018-03-23 16:53:33 Removed historical data download ID 51 | 2018-03-23 16:53:33 Interactive Brokers | Using primary service for historical data for ES-201806-GLOBEX | 2018-03-23 16:53:33 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:33 HD Request # 36 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:33 HD Request # 36 | Download start date-time: 2018-03-23 16:43:28.000 | 2018-03-23 16:53:33 HD Request # 36 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:33 Socket (54) | Creating socket. | 2018-03-23 16:53:33 Socket (54) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:33 Socket (53) | Socket gracefully closed by remote side. | 2018-03-23 16:53:33 Socket (53) | Closed. | 2018-03-23 16:53:33 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZN-201806-ECBOT | 2018-03-23 16:53:33 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:33 HD Request # 36 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:33 HD Request # 36 | Sending historical data logon request message. | 2018-03-23 16:53:33 Chart #9 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:33 HD Request # 36 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:28. Record interval: 0. Symbol: NQM18 | 2018-03-23 16:53:33 HD Request # 36 | Decompressing data. | 2018-03-23 16:53:33 HD Request # 36 | Receiving Intraday data for NQ-201806-GLOBEX starting at 2018-03-23 16:43:28 | 2018-03-23 16:53:33 HD Request # 36 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:32 | 2018-03-23 16:53:33 Socket (54) | Initiating close of socket by core. | 2018-03-23 16:53:33 Socket (54) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:33 HD Request # 36 | Historical data for NQ-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:33 Historical data download thread signaled to stop. | 2018-03-23 16:53:33 HD Request # 36 | Received 4 records from 2018-03-23 16:43:28 to 2018-03-23 16:43:32 (4.0 seconds) and wrote 2 records for NQ-201806-GLOBEX | 2018-03-23 16:53:33 HD Request # 36 | Completion time: 1s | 2018-03-23 16:53:33 HD Request # 36 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 52 | 2018-03-23 16:53:33 Removed historical data download ID 52 | 2018-03-23 16:53:33 Interactive Brokers | Using primary service for historical data for NQ-201806-GLOBEX | 2018-03-23 16:53:33 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:33 HD Request # 37 | Downloading Intraday chart data for ZN-201806-ECBOT to the file ZN-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:33 HD Request # 37 | Download start date-time: 2018-03-23 16:43:22.000 | 2018-03-23 16:53:33 HD Request # 37 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:33 Socket (55) | Creating socket. | 2018-03-23 16:53:33 Socket (55) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:33 Chart #5 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:33 Chart #5 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:33 Socket (54) | Socket gracefully closed by remote side. | 2018-03-23 16:53:33 Socket (54) | Closed. | 2018-03-23 16:53:33 Chart #6 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:33 HD Request # 37 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:33 HD Request # 37 | Sending historical data logon request message. | 2018-03-23 16:53:33 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:33 HD Request # 37 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:22. Record interval: 0. Symbol: ZNM18 | 2018-03-23 16:53:33 HD Request # 37 | Decompressing data. | 2018-03-23 16:53:33 HD Request # 37 | Receiving Intraday data for ZN-201806-ECBOT starting at 2018-03-23 16:43:22 | 2018-03-23 16:53:33 Socket (55) | Initiating close of socket by core. | 2018-03-23 16:53:33 HD Request # 37 | Historical data for ZN-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:33 Socket (55) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:33 Historical data download thread signaled to stop. | 2018-03-23 16:53:33 HD Request # 37 | Received 1 record from 2018-03-23 16:43:22 to 2018-03-23 16:43:22 (0.0 seconds) and wrote 0 records for ZN-201806-ECBOT | 2018-03-23 16:53:33 HD Request # 37 | Completion time: 0s | 2018-03-23 16:53:33 HD Request # 37 | Intraday data download complete for ZN-201806-ECBOT. Unique request ID: 54 | 2018-03-23 16:53:33 Removed historical data download ID 54 | 2018-03-23 16:53:33 Interactive Brokers | Using primary service for historical data for ZN-201806-ECBOT | 2018-03-23 16:53:33 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:33 Socket (55) | Socket gracefully closed by remote side. | 2018-03-23 16:53:34 Socket (55) | Closed. | 2018-03-23 16:53:34 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:34 Chart #8 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:34 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:34 Starting TWS auto-login thread. | 2018-03-23 16:53:35 TWS auto-login thread ending. | 2018-03-23 16:53:35 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:53:36 Socket (56) | Creating socket. | 2018-03-23 16:53:36 Socket (56) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:53:36 Interactive Brokers | Sending API sign: API | 2018-03-23 16:53:36 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 16:53:36 Interactive Brokers | TWS server version: 136 | 2018-03-23 16:53:36 Interactive Brokers | TWS time: 20180323 16:53:34 EST | 2018-03-23 16:53:36 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 16:53:36 IB Account information received. | 2018-03-23 16:53:36 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:53:36 Interactive Brokers | Connected to Live account. | 2018-03-23 16:53:36 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:53:36 Interactive Brokers | Connected to data and trading server. | 2018-03-23 16:53:36 Next valid order ID: 29 | 2018-03-23 16:53:36 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:36 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:36 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:36 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:36 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:36 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:36 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:36 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:36 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:36 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:36 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:36 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:36 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:36 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:36 HD Request # 38 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-03-23 16:53:36 HD Request # 38 | Download start date-time: 2018-03-23 16:43:32.000 | 2018-03-23 16:53:36 HD Request # 38 | Requesting a total of 0 days and 5403 seconds. | 2018-03-23 16:53:36 HD Request # 38 | IB Backfill - Seconds requested: 5403. Seconds Remaining: 0. | 2018-03-23 16:53:36 HD Request # 38 | Requesting 5403 Seconds of data at 30 secs with ending date-time at 2018-03-23 18:03:35 for ES-201806-GLOBEX. PriceType: TRADES | 2018-03-23 16:53:36 Interactive Brokers | Starting real-time market data updates for: ES-201806-GLOBEX. ID: 1 | 2018-03-23 16:53:36 Interactive Brokers | Subscribing to real-time True Data for symbol: ES SecurityType: FUT Exchange: GLOBEX Currency: | 2018-03-23 16:53:36 Interactive Brokers | Subscribing to Symbol: ES, SecurityType: FUT, Expiration: 201806, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-03-23 16:53:36 Interactive Brokers | Requesting security definition data for: ES-201806-GLOBEX. ID: 1 | 2018-03-23 16:53:36 Socket (56) | Received socket Close event. | 2018-03-23 16:53:36 Socket (56) | Socket gracefully closed by remote side. | 2018-03-23 16:53:36 Next valid order ID: 29 | 2018-03-23 16:53:36 Socket (56) | Initiating close of socket by core. | 2018-03-23 16:53:36 Connection to the external service has been lost. | 2018-03-23 16:53:36 Socket (56) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:53:36 Socket (56) | Closed. | 2018-03-23 16:53:36 Canceling historical data download request for NQ-201806-GLOBEX Intraday data. | 2018-03-23 16:53:36 Removed historical data download ID 55 | 2018-03-23 16:53:36 Canceling historical data download request for ZN-201806-ECBOT Intraday data. | 2018-03-23 16:53:36 Removed historical data download ID 56 | 2018-03-23 16:53:36 HD Request # 38 | Download canceled. | 2018-03-23 16:53:36 HD Request # 38 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-03-23 16:53:36 HD Request # 38 | Completion time: 0s | 2018-03-23 16:53:36 HD Request # 38 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 53 | 2018-03-23 16:53:36 Removed historical data download ID 53 | 2018-03-23 16:53:36 Interactive Brokers | Disconnected. | 2018-03-23 16:53:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:53:36 Chart #5 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:36 Chart #5 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:36 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-201806-GLOBEX | 2018-03-23 16:53:36 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:36 HD Request # 39 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:36 HD Request # 39 | Download start date-time: 2018-03-23 16:43:32.000 | 2018-03-23 16:53:36 HD Request # 39 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:36 Socket (57) | Creating socket. | 2018-03-23 16:53:36 Socket (57) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:36 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:36 HD Request # 39 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:36 HD Request # 39 | Sending historical data logon request message. | 2018-03-23 16:53:36 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZN-201806-ECBOT | 2018-03-23 16:53:36 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:36 HD Request # 39 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:32. Record interval: 0. Symbol: NQM18 | 2018-03-23 16:53:36 HD Request # 39 | Decompressing data. | 2018-03-23 16:53:36 HD Request # 39 | Receiving Intraday data for NQ-201806-GLOBEX starting at 2018-03-23 16:43:32 | 2018-03-23 16:53:36 HD Request # 39 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:36 | 2018-03-23 16:53:36 Socket (57) | Initiating close of socket by core. | 2018-03-23 16:53:36 Socket (57) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:36 HD Request # 39 | Historical data for NQ-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:36 Historical data download thread signaled to stop. | 2018-03-23 16:53:36 HD Request # 39 | Received 4 records from 2018-03-23 16:43:32 to 2018-03-23 16:43:36 (4.0 seconds) and wrote 2 records for NQ-201806-GLOBEX | 2018-03-23 16:53:36 HD Request # 39 | Completion time: 1s | 2018-03-23 16:53:36 HD Request # 39 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 57 | 2018-03-23 16:53:36 Removed historical data download ID 57 | 2018-03-23 16:53:36 Interactive Brokers | Using primary service for historical data for NQ-201806-GLOBEX | 2018-03-23 16:53:36 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:36 HD Request # 40 | Downloading Intraday chart data for ZN-201806-ECBOT to the file ZN-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:36 HD Request # 40 | Download start date-time: 2018-03-23 16:43:22.000 | 2018-03-23 16:53:36 HD Request # 40 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:36 Socket (58) | Creating socket. | 2018-03-23 16:53:36 Socket (58) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:36 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZB-201806-ECBOT | 2018-03-23 16:53:36 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:36 Socket (57) | Socket gracefully closed by remote side. | 2018-03-23 16:53:36 Socket (57) | Closed. | 2018-03-23 16:53:36 HD Request # 40 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:36 HD Request # 40 | Sending historical data logon request message. | 2018-03-23 16:53:36 HD Request # 40 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:22. Record interval: 0. Symbol: ZNM18 | 2018-03-23 16:53:36 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:36 HD Request # 40 | Decompressing data. | 2018-03-23 16:53:36 HD Request # 40 | Receiving Intraday data for ZN-201806-ECBOT starting at 2018-03-23 16:43:22 | 2018-03-23 16:53:36 Socket (58) | Initiating close of socket by core. | 2018-03-23 16:53:36 Socket (58) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:36 Socket (58) | Socket gracefully closed by remote side. | 2018-03-23 16:53:36 Socket (58) | Closed. | 2018-03-23 16:53:36 HD Request # 40 | Historical data for ZN-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:36 Historical data download thread signaled to stop. | 2018-03-23 16:53:36 HD Request # 40 | Received 1 record from 2018-03-23 16:43:22 to 2018-03-23 16:43:22 (0.0 seconds) and wrote 0 records for ZN-201806-ECBOT | 2018-03-23 16:53:36 HD Request # 40 | Completion time: 0s | 2018-03-23 16:53:36 HD Request # 40 | Intraday data download complete for ZN-201806-ECBOT. Unique request ID: 58 | 2018-03-23 16:53:36 Removed historical data download ID 58 | 2018-03-23 16:53:36 Interactive Brokers | Using primary service for historical data for ZN-201806-ECBOT | 2018-03-23 16:53:36 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:36 HD Request # 41 | Downloading Intraday chart data for ZB-201806-ECBOT to the file ZB-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:36 HD Request # 41 | Download start date-time: 2018-03-23 16:42:50.000 | 2018-03-23 16:53:36 HD Request # 41 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:36 Socket (59) | Creating socket. | 2018-03-23 16:53:36 Socket (59) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:36 Chart #6 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:36 HD Request # 41 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:36 HD Request # 41 | Sending historical data logon request message. | 2018-03-23 16:53:36 Chart #8 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:36 HD Request # 41 | Requesting Intraday data. Start date-time: 2018-03-23 16:42:50. Record interval: 0. Symbol: ZBM18 | 2018-03-23 16:53:37 HD Request # 41 | Decompressing data. | 2018-03-23 16:53:37 HD Request # 41 | Receiving Intraday data for ZB-201806-ECBOT starting at 2018-03-23 16:42:50 | 2018-03-23 16:53:37 Socket (59) | Initiating close of socket by core. | 2018-03-23 16:53:37 Socket (59) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:37 HD Request # 41 | Historical data for ZB-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:37 Historical data download thread signaled to stop. | 2018-03-23 16:53:37 HD Request # 41 | Received 7 records from 2018-03-23 16:42:50 to 2018-03-23 16:42:50 (0.0 seconds) and wrote 0 records for ZB-201806-ECBOT | 2018-03-23 16:53:37 HD Request # 41 | Completion time: 0s | 2018-03-23 16:53:37 HD Request # 41 | Intraday data download complete for ZB-201806-ECBOT. Unique request ID: 60 | 2018-03-23 16:53:37 Removed historical data download ID 60 | 2018-03-23 16:53:37 Interactive Brokers | Using primary service for historical data for ZB-201806-ECBOT | 2018-03-23 16:53:37 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:37 Chart #9 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:37 Socket (59) | Socket gracefully closed by remote side. | 2018-03-23 16:53:37 Socket (59) | Closed. | 2018-03-23 16:53:37 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:37 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:37 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:53:39 Socket (60) | Creating socket. | 2018-03-23 16:53:39 Socket (60) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:53:39 Interactive Brokers | Sending API sign: API | 2018-03-23 16:53:39 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 16:53:39 Interactive Brokers | TWS server version: 136 | 2018-03-23 16:53:39 Interactive Brokers | TWS time: 20180323 16:53:38 EST | 2018-03-23 16:53:39 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 16:53:39 IB Account information received. | 2018-03-23 16:53:39 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:53:39 Interactive Brokers | Connected to Live account. | 2018-03-23 16:53:39 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:53:39 Interactive Brokers | Connected to data and trading server. | 2018-03-23 16:53:39 Next valid order ID: 29 | 2018-03-23 16:53:39 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:39 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:39 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:39 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:39 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:39 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:39 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:39 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:39 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:39 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:39 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:39 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:39 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:39 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:39 HD Request # 42 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-03-23 16:53:39 HD Request # 42 | Download start date-time: 2018-03-23 16:43:36.000 | 2018-03-23 16:53:39 HD Request # 42 | Requesting a total of 0 days and 5402 seconds. | 2018-03-23 16:53:39 HD Request # 42 | IB Backfill - Seconds requested: 5402. Seconds Remaining: 0. | 2018-03-23 16:53:39 HD Request # 42 | Requesting 5402 Seconds of data at 30 secs with ending date-time at 2018-03-23 18:03:38 for NQ-201806-GLOBEX. PriceType: TRADES | 2018-03-23 16:53:39 Interactive Brokers | Starting real-time market data updates for: ES-201806-GLOBEX. ID: 2 | 2018-03-23 16:53:39 Interactive Brokers | Subscribing to real-time True Data for symbol: ES SecurityType: FUT Exchange: GLOBEX Currency: | 2018-03-23 16:53:39 Interactive Brokers | Subscribing to Symbol: ES, SecurityType: FUT, Expiration: 201806, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-03-23 16:53:39 Interactive Brokers | Requesting security definition data for: ES-201806-GLOBEX. ID: 2 | 2018-03-23 16:53:39 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ES-201806-GLOBEX | 2018-03-23 16:53:39 Socket (60) | Received socket Close event. | 2018-03-23 16:53:39 Socket (60) | Socket gracefully closed by remote side. | 2018-03-23 16:53:39 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:39 Next valid order ID: 29 | 2018-03-23 16:53:39 Socket (60) | Initiating close of socket by core. | 2018-03-23 16:53:39 Connection to the external service has been lost. | 2018-03-23 16:53:39 Socket (60) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:53:39 Socket (60) | Closed. | 2018-03-23 16:53:39 HD Request # 43 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:39 HD Request # 43 | Download start date-time: 2018-03-23 16:43:32.000 | 2018-03-23 16:53:39 HD Request # 43 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:39 Socket (61) | Creating socket. | 2018-03-23 16:53:39 Socket (61) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:39 Canceling historical data download request for ZN-201806-ECBOT Intraday data. | 2018-03-23 16:53:39 Removed historical data download ID 61 | 2018-03-23 16:53:39 Canceling historical data download request for ZB-201806-ECBOT Intraday data. | 2018-03-23 16:53:39 Removed historical data download ID 62 | 2018-03-23 16:53:39 HD Request # 42 | Download canceled. | 2018-03-23 16:53:39 HD Request # 42 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201806-GLOBEX | 2018-03-23 16:53:39 HD Request # 42 | Completion time: 0s | 2018-03-23 16:53:39 HD Request # 42 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 59 | 2018-03-23 16:53:39 Removed historical data download ID 59 | 2018-03-23 16:53:39 Interactive Brokers | Disconnected. | 2018-03-23 16:53:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:53:39 HD Request # 43 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:39 HD Request # 43 | Sending historical data logon request message. | 2018-03-23 16:53:39 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZN-201806-ECBOT | 2018-03-23 16:53:39 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:39 HD Request # 43 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:32. Record interval: 0. Symbol: ESM18 | 2018-03-23 16:53:39 HD Request # 43 | Decompressing data. | 2018-03-23 16:53:39 HD Request # 43 | Receiving Intraday data for ES-201806-GLOBEX starting at 2018-03-23 16:43:32 | 2018-03-23 16:53:39 HD Request # 43 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:34 | 2018-03-23 16:53:39 Socket (61) | Initiating close of socket by core. | 2018-03-23 16:53:39 HD Request # 43 | Historical data for ES-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:39 Socket (61) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:39 Historical data download thread signaled to stop. | 2018-03-23 16:53:39 HD Request # 43 | Received 65 records from 2018-03-23 16:43:32 to 2018-03-23 16:43:37 (5.0 seconds) and wrote 62 records for ES-201806-GLOBEX | 2018-03-23 16:53:39 HD Request # 43 | Completion time: 1s | 2018-03-23 16:53:39 HD Request # 43 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 63 | 2018-03-23 16:53:39 Removed historical data download ID 63 | 2018-03-23 16:53:39 Interactive Brokers | Using primary service for historical data for ES-201806-GLOBEX | 2018-03-23 16:53:39 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:39 HD Request # 44 | Downloading Intraday chart data for ZN-201806-ECBOT to the file ZN-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:39 HD Request # 44 | Download start date-time: 2018-03-23 16:43:22.000 | 2018-03-23 16:53:39 HD Request # 44 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:39 Socket (62) | Creating socket. | 2018-03-23 16:53:39 Socket (62) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:39 Socket (61) | Socket gracefully closed by remote side. | 2018-03-23 16:53:39 Socket (61) | Closed. | 2018-03-23 16:53:39 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZB-201806-ECBOT | 2018-03-23 16:53:39 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:39 HD Request # 44 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:39 HD Request # 44 | Sending historical data logon request message. | 2018-03-23 16:53:39 HD Request # 44 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:22. Record interval: 0. Symbol: ZNM18 | 2018-03-23 16:53:39 Chart #5 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:39 Chart #5 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:39 Chart #6 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:39 HD Request # 44 | Decompressing data. | 2018-03-23 16:53:39 HD Request # 44 | Receiving Intraday data for ZN-201806-ECBOT starting at 2018-03-23 16:43:22 | 2018-03-23 16:53:39 HD Request # 44 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:37 | 2018-03-23 16:53:39 Socket (62) | Initiating close of socket by core. | 2018-03-23 16:53:39 Socket (62) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:39 HD Request # 44 | Historical data for ZN-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:39 Historical data download thread signaled to stop. | 2018-03-23 16:53:39 HD Request # 44 | Received 2 records from 2018-03-23 16:43:22 to 2018-03-23 16:43:37 (15.0 seconds) and wrote 1 record for ZN-201806-ECBOT | 2018-03-23 16:53:39 HD Request # 44 | Completion time: 0s | 2018-03-23 16:53:39 HD Request # 44 | Intraday data download complete for ZN-201806-ECBOT. Unique request ID: 64 | 2018-03-23 16:53:39 Removed historical data download ID 64 | 2018-03-23 16:53:39 Interactive Brokers | Using primary service for historical data for ZN-201806-ECBOT | 2018-03-23 16:53:39 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:39 HD Request # 45 | Downloading Intraday chart data for ZB-201806-ECBOT to the file ZB-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:39 HD Request # 45 | Download start date-time: 2018-03-23 16:42:50.000 | 2018-03-23 16:53:39 HD Request # 45 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:39 Socket (63) | Creating socket. | 2018-03-23 16:53:39 Socket (63) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:39 Socket (62) | Socket gracefully closed by remote side. | 2018-03-23 16:53:39 Socket (62) | Closed. | 2018-03-23 16:53:39 Starting TWS auto-login thread. | 2018-03-23 16:53:39 TWS auto-login thread ending. | 2018-03-23 16:53:39 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:39 HD Request # 45 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:39 HD Request # 45 | Sending historical data logon request message. | 2018-03-23 16:53:39 HD Request # 45 | Requesting Intraday data. Start date-time: 2018-03-23 16:42:50. Record interval: 0. Symbol: ZBM18 | 2018-03-23 16:53:39 Chart #8 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:40 HD Request # 45 | Decompressing data. | 2018-03-23 16:53:40 HD Request # 45 | Receiving Intraday data for ZB-201806-ECBOT starting at 2018-03-23 16:42:50 | 2018-03-23 16:53:40 Socket (63) | Initiating close of socket by core. | 2018-03-23 16:53:40 HD Request # 45 | Historical data for ZB-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:40 Socket (63) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:40 Historical data download thread signaled to stop. | 2018-03-23 16:53:40 HD Request # 45 | Received 7 records from 2018-03-23 16:42:50 to 2018-03-23 16:42:50 (0.0 seconds) and wrote 0 records for ZB-201806-ECBOT | 2018-03-23 16:53:40 HD Request # 45 | Completion time: 0s | 2018-03-23 16:53:40 HD Request # 45 | Intraday data download complete for ZB-201806-ECBOT. Unique request ID: 66 | 2018-03-23 16:53:40 Removed historical data download ID 66 | 2018-03-23 16:53:40 Interactive Brokers | Using primary service for historical data for ZB-201806-ECBOT | 2018-03-23 16:53:40 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:40 Chart #9 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:40 Socket (63) | Socket gracefully closed by remote side. | 2018-03-23 16:53:40 Socket (63) | Closed. | 2018-03-23 16:53:40 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:40 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:40 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:53:42 Socket (64) | Creating socket. | 2018-03-23 16:53:42 Socket (64) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:53:42 Interactive Brokers | Sending API sign: API | 2018-03-23 16:53:42 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 16:53:42 Interactive Brokers | TWS server version: 136 | 2018-03-23 16:53:42 Interactive Brokers | TWS time: 20180323 16:53:41 EST | 2018-03-23 16:53:42 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 16:53:42 IB Account information received. | 2018-03-23 16:53:42 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:53:42 Interactive Brokers | Connected to Live account. | 2018-03-23 16:53:42 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:53:42 Interactive Brokers | Connected to data and trading server. | 2018-03-23 16:53:42 Next valid order ID: 29 | 2018-03-23 16:53:42 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:42 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:42 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:42 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:42 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:42 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:42 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:42 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:42 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:42 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:42 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:42 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:42 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:42 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:42 HD Request # 46 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-03-23 16:53:42 HD Request # 46 | Download start date-time: 2018-03-23 16:43:37.000 | 2018-03-23 16:53:42 HD Request # 46 | Requesting a total of 0 days and 5405 seconds. | 2018-03-23 16:53:42 HD Request # 46 | IB Backfill - Seconds requested: 5405. Seconds Remaining: 0. | 2018-03-23 16:53:42 HD Request # 46 | Requesting 5405 Seconds of data at 30 secs with ending date-time at 2018-03-23 18:03:42 for ES-201806-GLOBEX. PriceType: TRADES | 2018-03-23 16:53:42 Interactive Brokers | Starting real-time market data updates for: ZN-201806-ECBOT. ID: 2 | 2018-03-23 16:53:42 Interactive Brokers | Subscribing to real-time True Data for symbol: ZN SecurityType: FUT Exchange: ECBOT Currency: | 2018-03-23 16:53:42 Interactive Brokers | Subscribing to Symbol: ZN, SecurityType: FUT, Expiration: 201806, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-03-23 16:53:42 Interactive Brokers | Requesting security definition data for: ZN-201806-ECBOT. ID: 2 | 2018-03-23 16:53:42 Socket (64) | Received socket Close event. | 2018-03-23 16:53:42 Socket (64) | Socket gracefully closed by remote side. | 2018-03-23 16:53:42 Next valid order ID: 29 | 2018-03-23 16:53:42 Socket (64) | Initiating close of socket by core. | 2018-03-23 16:53:42 Connection to the external service has been lost. | 2018-03-23 16:53:42 Socket (64) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:53:42 Socket (64) | Closed. | 2018-03-23 16:53:42 Canceling historical data download request for ZN-201806-ECBOT Intraday data. | 2018-03-23 16:53:42 Removed historical data download ID 67 | 2018-03-23 16:53:42 Canceling historical data download request for ZB-201806-ECBOT Intraday data. | 2018-03-23 16:53:42 Removed historical data download ID 68 | 2018-03-23 16:53:42 HD Request # 46 | Download canceled. | 2018-03-23 16:53:42 HD Request # 46 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-03-23 16:53:42 HD Request # 46 | Completion time: 0s | 2018-03-23 16:53:42 HD Request # 46 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 65 | 2018-03-23 16:53:42 Removed historical data download ID 65 | 2018-03-23 16:53:42 Interactive Brokers | Disconnected. | 2018-03-23 16:53:42 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:53:42 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZB-201806-ECBOT | 2018-03-23 16:53:42 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:42 HD Request # 47 | Downloading Intraday chart data for ZB-201806-ECBOT to the file ZB-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:42 HD Request # 47 | Download start date-time: 2018-03-23 16:42:50.000 | 2018-03-23 16:53:42 HD Request # 47 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:42 Socket (65) | Creating socket. | 2018-03-23 16:53:42 Socket (65) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:42 HD Request # 47 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:42 HD Request # 47 | Sending historical data logon request message. | 2018-03-23 16:53:42 Chart #5 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:42 Chart #5 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:42 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-201806-GLOBEX | 2018-03-23 16:53:42 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:42 HD Request # 47 | Requesting Intraday data. Start date-time: 2018-03-23 16:42:50. Record interval: 0. Symbol: ZBM18 | 2018-03-23 16:53:42 HD Request # 47 | Decompressing data. | 2018-03-23 16:53:42 HD Request # 47 | Receiving Intraday data for ZB-201806-ECBOT starting at 2018-03-23 16:42:50 | 2018-03-23 16:53:42 Socket (65) | Initiating close of socket by core. | 2018-03-23 16:53:42 Socket (65) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:42 HD Request # 47 | Historical data for ZB-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:42 Historical data download thread signaled to stop. | 2018-03-23 16:53:42 HD Request # 47 | Received 7 records from 2018-03-23 16:42:50 to 2018-03-23 16:42:50 (0.0 seconds) and wrote 0 records for ZB-201806-ECBOT | 2018-03-23 16:53:42 HD Request # 47 | Completion time: 0s | 2018-03-23 16:53:42 HD Request # 47 | Intraday data download complete for ZB-201806-ECBOT. Unique request ID: 69 | 2018-03-23 16:53:42 Removed historical data download ID 69 | 2018-03-23 16:53:42 Interactive Brokers | Using primary service for historical data for ZB-201806-ECBOT | 2018-03-23 16:53:42 Intraday data recording state for symbol ZB-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:42 HD Request # 48 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:42 HD Request # 48 | Download start date-time: 2018-03-23 16:43:36.000 | 2018-03-23 16:53:42 HD Request # 48 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:42 Socket (66) | Creating socket. | 2018-03-23 16:53:42 Socket (66) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:42 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:42 Socket (65) | Socket gracefully closed by remote side. | 2018-03-23 16:53:42 Socket (65) | Closed. | 2018-03-23 16:53:42 HD Request # 48 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:43 HD Request # 48 | Sending historical data logon request message. | 2018-03-23 16:53:43 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZN-201806-ECBOT | 2018-03-23 16:53:43 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:43 HD Request # 48 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:36. Record interval: 0. Symbol: NQM18 | 2018-03-23 16:53:43 Chart #9 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:43 HD Request # 48 | Decompressing data. | 2018-03-23 16:53:43 HD Request # 48 | Receiving Intraday data for NQ-201806-GLOBEX starting at 2018-03-23 16:43:36 | 2018-03-23 16:53:43 HD Request # 48 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:37 | 2018-03-23 16:53:43 Socket (66) | Initiating close of socket by core. | 2018-03-23 16:53:43 HD Request # 48 | Historical data for NQ-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:43 Socket (66) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:43 Historical data download thread signaled to stop. | 2018-03-23 16:53:43 HD Request # 48 | Received 4 records from 2018-03-23 16:43:36 to 2018-03-23 16:43:39 (3.0 seconds) and wrote 2 records for NQ-201806-GLOBEX | 2018-03-23 16:53:43 HD Request # 48 | Completion time: 0s | 2018-03-23 16:53:43 HD Request # 48 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 70 | 2018-03-23 16:53:43 Removed historical data download ID 70 | 2018-03-23 16:53:43 Interactive Brokers | Using primary service for historical data for NQ-201806-GLOBEX | 2018-03-23 16:53:43 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:43 HD Request # 49 | Downloading Intraday chart data for ZN-201806-ECBOT to the file ZN-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:43 HD Request # 49 | Download start date-time: 2018-03-23 16:43:37.000 | 2018-03-23 16:53:43 HD Request # 49 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:43 Socket (67) | Creating socket. | 2018-03-23 16:53:43 Socket (67) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:43 Socket (66) | Socket gracefully closed by remote side. | 2018-03-23 16:53:43 Socket (66) | Closed. | 2018-03-23 16:53:43 HD Request # 49 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:43 HD Request # 49 | Sending historical data logon request message. | 2018-03-23 16:53:43 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:43 HD Request # 49 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:37. Record interval: 0. Symbol: ZNM18 | 2018-03-23 16:53:43 Chart #6 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:43 HD Request # 49 | Decompressing data. | 2018-03-23 16:53:43 HD Request # 49 | Receiving Intraday data for ZN-201806-ECBOT starting at 2018-03-23 16:43:37 | 2018-03-23 16:53:43 Socket (67) | Initiating close of socket by core. | 2018-03-23 16:53:43 Socket (67) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:43 HD Request # 49 | Historical data for ZN-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:43 Historical data download thread signaled to stop. | 2018-03-23 16:53:43 HD Request # 49 | Received 1 record from 2018-03-23 16:43:37 to 2018-03-23 16:43:37 (0.0 seconds) and wrote 0 records for ZN-201806-ECBOT | 2018-03-23 16:53:43 HD Request # 49 | Completion time: 0s | 2018-03-23 16:53:43 HD Request # 49 | Intraday data download complete for ZN-201806-ECBOT. Unique request ID: 72 | 2018-03-23 16:53:43 Removed historical data download ID 72 | 2018-03-23 16:53:43 Interactive Brokers | Using primary service for historical data for ZN-201806-ECBOT | 2018-03-23 16:53:43 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:43 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:43 Socket (67) | Socket gracefully closed by remote side. | 2018-03-23 16:53:43 Socket (67) | Closed. | 2018-03-23 16:53:43 Chart #8 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:43 ES-201806-GLOBEX [C] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:43 Starting TWS auto-login thread. | 2018-03-23 16:53:43 TWS auto-login thread ending. | 2018-03-23 16:53:43 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:43 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:53:45 Socket (68) | Creating socket. | 2018-03-23 16:53:45 Socket (68) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:53:45 Interactive Brokers | Sending API sign: API | 2018-03-23 16:53:45 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 16:53:45 Interactive Brokers | TWS server version: 136 | 2018-03-23 16:53:46 Interactive Brokers | TWS time: 20180323 16:53:45 EST | 2018-03-23 16:53:46 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 16:53:46 IB Account information received. | 2018-03-23 16:53:46 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:53:46 Interactive Brokers | Connected to Live account. | 2018-03-23 16:53:46 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:53:46 Interactive Brokers | Connected to data and trading server. | 2018-03-23 16:53:46 Next valid order ID: 29 | 2018-03-23 16:53:46 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:46 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:46 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:46 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:46 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:46 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:46 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:46 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:46 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:46 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:46 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:46 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:46 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:46 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:46 HD Request # 50 | Downloading Intraday chart data for ZB-201806-ECBOT to the file ZB-201806-ECBOT.scid. Service: interactive_brokers.trading | 2018-03-23 16:53:46 HD Request # 50 | Download start date-time: 2018-03-23 16:42:50.000 | 2018-03-23 16:53:46 HD Request # 50 | Requesting a total of 0 days and 5456 seconds. | 2018-03-23 16:53:46 HD Request # 50 | IB Backfill - Seconds requested: 5456. Seconds Remaining: 0. | 2018-03-23 16:53:46 HD Request # 50 | Requesting 5456 Seconds of data at 30 secs with ending date-time at 2018-03-23 18:03:46 for ZB-201806-ECBOT. PriceType: TRADES | 2018-03-23 16:53:46 Interactive Brokers | Starting real-time market data updates for: ZB-201806-ECBOT. ID: 1 | 2018-03-23 16:53:46 Interactive Brokers | Subscribing to real-time True Data for symbol: ZB SecurityType: FUT Exchange: ECBOT Currency: | 2018-03-23 16:53:46 Interactive Brokers | Subscribing to Symbol: ZB, SecurityType: FUT, Expiration: 201806, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-03-23 16:53:46 Interactive Brokers | Requesting security definition data for: ZB-201806-ECBOT. ID: 1 | 2018-03-23 16:53:46 Socket (68) | Received socket Close event. | 2018-03-23 16:53:46 Socket (68) | Socket gracefully closed by remote side. | 2018-03-23 16:53:46 Next valid order ID: 29 | 2018-03-23 16:53:46 Socket (68) | Initiating close of socket by core. | 2018-03-23 16:53:46 Connection to the external service has been lost. | 2018-03-23 16:53:46 Socket (68) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-03-23 16:53:46 Socket (68) | Closed. | 2018-03-23 16:53:46 Canceling historical data download request for NQ-201806-GLOBEX Intraday data. | 2018-03-23 16:53:46 Removed historical data download ID 73 | 2018-03-23 16:53:46 Canceling historical data download request for ZN-201806-ECBOT Intraday data. | 2018-03-23 16:53:46 Removed historical data download ID 74 | 2018-03-23 16:53:46 HD Request # 50 | Download canceled. | 2018-03-23 16:53:46 HD Request # 50 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZB-201806-ECBOT | 2018-03-23 16:53:46 HD Request # 50 | Completion time: 0s | 2018-03-23 16:53:46 HD Request # 50 | Intraday data download complete for ZB-201806-ECBOT. Unique request ID: 71 | 2018-03-23 16:53:46 Removed historical data download ID 71 | 2018-03-23 16:53:46 Interactive Brokers | Disconnected. | 2018-03-23 16:53:46 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-03-23 16:53:46 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ES-201806-GLOBEX | 2018-03-23 16:53:46 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:46 HD Request # 51 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:46 HD Request # 51 | Download start date-time: 2018-03-23 16:43:37.000 | 2018-03-23 16:53:46 HD Request # 51 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:46 Socket (69) | Creating socket. | 2018-03-23 16:53:46 Socket (69) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:46 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-201806-GLOBEX | 2018-03-23 16:53:46 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:46 HD Request # 51 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:46 HD Request # 51 | Sending historical data logon request message. | 2018-03-23 16:53:46 HD Request # 51 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:37. Record interval: 0. Symbol: ESM18 | 2018-03-23 16:53:46 HD Request # 51 | Decompressing data. | 2018-03-23 16:53:46 HD Request # 51 | Receiving Intraday data for ES-201806-GLOBEX starting at 2018-03-23 16:43:37 | 2018-03-23 16:53:46 HD Request # 51 | Timestamp of first Intraday data file record written: 2018-03-23 16:43:41 | 2018-03-23 16:53:46 Socket (69) | Initiating close of socket by core. | 2018-03-23 16:53:46 Socket (69) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:46 HD Request # 51 | Historical data for ES-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:46 Historical data download thread signaled to stop. | 2018-03-23 16:53:46 HD Request # 51 | Received 57 records from 2018-03-23 16:43:37 to 2018-03-23 16:43:46 (9.0 seconds) and wrote 13 records for ES-201806-GLOBEX | 2018-03-23 16:53:46 HD Request # 51 | Completion time: 0s | 2018-03-23 16:53:46 HD Request # 51 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 75 | 2018-03-23 16:53:46 Removed historical data download ID 75 | 2018-03-23 16:53:46 Interactive Brokers | Using primary service for historical data for ES-201806-GLOBEX | 2018-03-23 16:53:46 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:46 HD Request # 52 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: cme | 2018-03-23 16:53:46 HD Request # 52 | Download start date-time: 2018-03-23 16:43:39.000 | 2018-03-23 16:53:46 HD Request # 52 | Using server: ds7.sierracharts.com port 10149 | 2018-03-23 16:53:46 Socket (70) | Creating socket. | 2018-03-23 16:53:46 Socket (70) | Connecting to IP: 8.18.161.133. | 2018-03-23 16:53:46 Socket (69) | Socket gracefully closed by remote side. | 2018-03-23 16:53:46 Socket (69) | Closed. | 2018-03-23 16:53:46 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZN-201806-ECBOT | 2018-03-23 16:53:47 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:47 HD Request # 52 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:47 HD Request # 52 | Sending historical data logon request message. | 2018-03-23 16:53:47 Chart #9 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:47 HD Request # 52 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:39. Record interval: 0. Symbol: NQM18 | 2018-03-23 16:53:47 HD Request # 52 | Decompressing data. | 2018-03-23 16:53:47 HD Request # 52 | Receiving Intraday data for NQ-201806-GLOBEX starting at 2018-03-23 16:43:39 | 2018-03-23 16:53:47 Socket (70) | Initiating close of socket by core. | 2018-03-23 16:53:47 HD Request # 52 | Historical data for NQ-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:47 Socket (70) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:47 Historical data download thread signaled to stop. | 2018-03-23 16:53:47 HD Request # 52 | Received 1 record from 2018-03-23 16:43:39 to 2018-03-23 16:43:39 (0.0 seconds) and wrote 0 records for NQ-201806-GLOBEX | 2018-03-23 16:53:47 HD Request # 52 | Completion time: 0s | 2018-03-23 16:53:47 HD Request # 52 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 76 | 2018-03-23 16:53:47 Removed historical data download ID 76 | 2018-03-23 16:53:47 Interactive Brokers | Using primary service for historical data for NQ-201806-GLOBEX | 2018-03-23 16:53:47 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-03-23 16:53:47 HD Request # 53 | Downloading Intraday chart data for ZN-201806-ECBOT to the file ZN-201806-ECBOT.scid. Service: cbot | 2018-03-23 16:53:47 HD Request # 53 | Download start date-time: 2018-03-23 16:43:37.000 | 2018-03-23 16:53:47 HD Request # 53 | Using server: ds1.sierracharts.com port 10150 | 2018-03-23 16:53:47 Socket (71) | Creating socket. | 2018-03-23 16:53:47 Socket (71) | Connecting to IP: 8.18.161.135. | 2018-03-23 16:53:47 Socket (70) | Socket gracefully closed by remote side. | 2018-03-23 16:53:47 Socket (70) | Closed. | 2018-03-23 16:53:47 Chart #5 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:47 Chart #5 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:47 HD Request # 53 | Setting DTC encoding to Binary VLS | 2018-03-23 16:53:47 HD Request # 53 | Sending historical data logon request message. | 2018-03-23 16:53:47 Chart #6 has tagged chart #4 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:47 HD Request # 53 | Requesting Intraday data. Start date-time: 2018-03-23 16:43:37. Record interval: 0. Symbol: ZNM18 | 2018-03-23 16:53:47 HD Request # 53 | Decompressing data. | 2018-03-23 16:53:47 HD Request # 53 | Receiving Intraday data for ZN-201806-ECBOT starting at 2018-03-23 16:43:37 | 2018-03-23 16:53:47 Socket (71) | Initiating close of socket by core. | 2018-03-23 16:53:47 Socket (71) | Shutdown started. Waiting for graceful close. | 2018-03-23 16:53:47 HD Request # 53 | Historical data for ZN-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-03-23 16:53:47 Historical data download thread signaled to stop. | 2018-03-23 16:53:47 HD Request # 53 | Received 1 record from 2018-03-23 16:43:37 to 2018-03-23 16:43:37 (0.0 seconds) and wrote 0 records for ZN-201806-ECBOT | 2018-03-23 16:53:47 HD Request # 53 | Completion time: 0s | 2018-03-23 16:53:47 HD Request # 53 | Intraday data download complete for ZN-201806-ECBOT. Unique request ID: 78 | 2018-03-23 16:53:47 Removed historical data download ID 78 | 2018-03-23 16:53:47 Interactive Brokers | Using primary service for historical data for ZN-201806-ECBOT | 2018-03-23 16:53:47 Intraday data recording state for symbol ZN-201806-ECBOT is set to download 'Pending'. | 2018-03-23 16:53:47 ES-201806-GLOBEX [C] 10 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:47 Socket (71) | Socket gracefully closed by remote side. | 2018-03-23 16:53:47 Socket (71) | Closed. | 2018-03-23 16:53:47 Chart #8 has tagged chart #7 for full recalculation. Chartbook: TRADE.12.52 ES_F 0400-2300 VarM (IB25).Cht | 2018-03-23 16:53:47 Starting TWS auto-login thread. | 2018-03-23 16:53:47 TWS auto-login thread ending. | 2018-03-23 16:53:47 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-03-23 16:53:49 Socket (72) | Creating socket. | 2018-03-23 16:53:49 Socket (72) | Connecting to IP: 127.0.0.1. | 2018-03-23 16:53:49 Interactive Brokers | Sending API sign: API | 2018-03-23 16:53:49 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-03-23 16:53:49 Interactive Brokers | TWS server version: 136 | 2018-03-23 16:53:49 Interactive Brokers | TWS time: 20180323 16:53:48 EST | 2018-03-23 16:53:49 Interactive Brokers | Connected. Waiting for account information. | 2018-03-23 16:53:49 IB Account information received. | 2018-03-23 16:53:49 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:53:49 Interactive Brokers | Connected to Live account. | 2018-03-23 16:53:49 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:53:49 Interactive Brokers | Connected to data and trading server. | 2018-03-23 16:53:49 Next valid order ID: 29 | 2018-03-23 16:53:49 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:49 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:49 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:49 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:49 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:49 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:49 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:49 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:49 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2018-03-23 16:53:49 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:49 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:49 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:49 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:49 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-03-23 16:53:49 HD Request # 54 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-03-23 16:53:49 HD Request # 54 | Download start date-time: 2018-03-23 16:43:46.000 | 2018-03-23 16:53:49 HD Request # 54 | Requesting a total of 0 days and 5403 seconds. | 2018-03-23 16:53:49 HD Request # 54 | IB Backfill - Seconds requested: 5403. Seconds Remaining: 0. | 2018-03-23 16:53:49 HD Request # 54 | Requesting 5403 Seconds of data at 30 secs with ending date-time at 2018-03-23 18:03:49 for ES-201806-GLOBEX. PriceType: TRADES | 2018-03-23 16:53:49 HD Request # 54 | Processing historical data message from TWS | 2018-03-23 16:53:49 HD Request # 54 | Receiving Intraday data for ES-201806-GLOBEX starting at 2018-03-23 16:34:00 | 2018-03-23 16:53:49 HD Request # 54 | Timestamp of first Intraday data file record written: 2018-03-23 16:44:00 | 2018-03-23 16:53:49 HD Request # 54 | Received 169 records and wrote 20 records from 2018-03-23 15:14:30 to 2018-03-23 16:53:30. | 2018-03-23 16:53:49 HD Request # 54 | Received 169 records from 2018-03-23 16:34:00 to 2018-03-23 16:53:30 (19.5 minutes) and wrote 20 records for ES-201806-GLOBEX | 2018-03-23 16:53:49 HD Request # 54 | Completion time: 0s | 2018-03-23 16:53:49 HD Request # 54 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 77 | 2018-03-23 16:53:49 Removed historical data download ID 77 | 2018-03-23 16:53:49 Real-time Intraday chart data file updates started for ES-201806-GLOBEX | 2018-03-23 16:53:49 Intraday chart data file opened for ES-201806-GLOBEX | 2018-03-23 16:53:49 HD Request # 55 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-03-23 16:53:49 HD Request # 55 | Download start date-time: 2018-03-23 16:43:39.000 | 2018-03-23 16:53:49 HD Request # 55 | Requesting a total of 0 days and 5410 seconds. | 2018-03-23 16:53:49 HD Request # 55 | IB Backfill - Seconds requested: 5410. Seconds Remaining: 0. | 2018-03-23 16:53:49 HD Request # 55 | Requesting 5410 Seconds of data at 30 secs with ending date-time at 2018-03-23 18:03:49 for NQ-201806-GLOBEX. PriceType: TRADES | 2018-03-23 16:53:49 HD Request # 55 | Processing historical data message from TWS | 2018-03-23 16:53:50 HD Request # 55 | Receiving Intraday data for NQ-201806-GLOBEX starting at 2018-03-23 16:34:00 | 2018-03-23 16:53:50 HD Request # 55 | Timestamp of first Intraday data file record written: 2018-03-23 16:44:00 | 2018-03-23 16:53:50 HD Request # 55 | Received 169 records and wrote 20 records from 2018-03-23 15:14:30 to 2018-03-23 16:53:30. | 2018-03-23 16:53:50 HD Request # 55 | Received 169 records from 2018-03-23 16:34:00 to 2018-03-23 16:53:30 (19.5 minutes) and wrote 20 records for NQ-201806-GLOBEX | 2018-03-23 16:53:50 HD Request # 55 | Completion time: 0s | 2018-03-23 16:53:50 HD Request # 55 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 79 | 2018-03-23 16:53:50 Removed historical data download ID 79 | 2018-03-23 16:53:50 Real-time Intraday chart data file updates started for NQ-201806-GLOBEX | 2018-03-23 16:53:50 Intraday chart data file opened for NQ-201806-GLOBEX | 2018-03-23 16:53:50 HD Request # 56 | Downloading Intraday chart data for ZN-201806-ECBOT to the file ZN-201806-ECBOT.scid. Service: interactive_brokers.trading | 2018-03-23 16:53:50 HD Request # 56 | Download start date-time: 2018-03-23 16:43:37.000 | 2018-03-23 16:53:50 HD Request # 56 | Requesting a total of 0 days and 5412 seconds. | 2018-03-23 16:53:50 HD Request # 56 | IB Backfill - Seconds requested: 5412. Seconds Remaining: 0. | 2018-03-23 16:53:50 HD Request # 56 | Requesting 5412 Seconds of data at 30 secs with ending date-time at 2018-03-23 18:03:49 for ZN-201806-ECBOT. PriceType: TRADES | 2018-03-23 16:53:50 HD Request # 56 | Processing historical data message from TWS | 2018-03-23 16:53:50 HD Request # 56 | Receiving Intraday data for ZN-201806-ECBOT starting at 2018-03-23 16:34:00 | 2018-03-23 16:53:50 HD Request # 56 | Timestamp of first Intraday data file record written: 2018-03-23 16:44:00 | 2018-03-23 16:53:50 HD Request # 56 | Received 169 records and wrote 20 records from 2018-03-23 15:29:30 to 2018-03-23 16:53:30. | 2018-03-23 16:53:50 HD Request # 56 | Received 169 records from 2018-03-23 16:34:00 to 2018-03-23 16:53:30 (19.5 minutes) and wrote 20 records for ZN-201806-ECBOT | 2018-03-23 16:53:50 HD Request # 56 | Completion time: 0s | 2018-03-23 16:53:50 HD Request # 56 | Intraday data download complete for ZN-201806-ECBOT. Unique request ID: 80 | 2018-03-23 16:53:50 Removed historical data download ID 80 | 2018-03-23 16:53:50 Real-time Intraday chart data file updates started for ZN-201806-ECBOT | 2018-03-23 16:53:50 Intraday chart data file opened for ZN-201806-ECBOT | 2018-03-23 16:53:50 Next valid order ID: 29 | 2018-03-23 16:53:51 IB Account information received. | 2018-03-23 16:53:51 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-03-23 16:53:51 Interactive Brokers | Connected to Live account. | 2018-03-23 16:53:51 Interactive Brokers | Year-Month last connected to Live account: 2018-03 | 2018-03-23 16:53:51 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates) for account: U104* | 2018-03-23 16:53:54 Interactive Brokers | Sending request for contract details for contract ID 269745169 | 2018-03-23 16:53:54 Interactive Brokers | Sending request for contract details for contract ID 269745182 | 2018-03-23 16:53:54 Interactive Brokers | Sending request for contract details for contract ID 290048106 | 2018-03-23 16:53:54 Interactive Brokers | Sending request for contract details for contract ID 291020195 | 2018-03-23 16:53:54 Interactive Brokers | Sending request for contract details for contract ID 290048111 | 2018-03-23 16:53:54 Interactive Brokers | Received Trade Positions download end message for account U104* | 2018-03-23 16:53:54 Interactive Brokers | Received contract details for symbol ES-201806-GLOBEX | 2018-03-23 16:53:54 Interactive Brokers | Received contract details for symbol NQ-201806-GLOBEX | 2018-03-23 16:53:54 Interactive Brokers | Received contract details for symbol ZB-201806-ECBOT | 2018-03-23 16:53:54 Interactive Brokers | Received contract details for symbol ZF-201806-ECBOT | 2018-03-23 16:53:54 Interactive Brokers | Received contract details for symbol ZN-201806-ECBOT | 2018-03-23 16:53:54 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2018-03-23 16:53:54 Interactive Brokers | All contract details received for symbols used for trading. Re-requesting trading data. | 2018-03-23 16:54:04 Interactive Brokers | Stopping automatic Trade Position updates for account: U104* | 2018-03-23 16:54:04 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates) for account: U104* | 2018-03-23 16:54:04 Message from IB: API client has been unsubscribed from account data. IB Error Code: 2100. Request ID: -1. | 2018-03-23 16:54:04 Interactive Brokers | Received Trade Positions download end message for account U104* | 2018-03-23 16:54:04 |
[2018-03-23 21:05:37] |
OK we have enough information here for the time being. We will apply the hack. If in the next release there still is a problem, we will need Interactive Brokers to tell us what the issue is. We will have a new release out later today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-23 21:05:55
[2018-03-24 11:16:33] |
We have released version 1724. Please test and let us know if you still see the problem. While we have seen a problem where there is a random disconnection sometimes when immediately connecting to trader workstation, we are not observing what the most recent Message Log is showing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-24 11:16:53
[2018-03-24 11:21:28] |
User479108 - Posts: 19 |
received msg and setting up test now with 1724
[2018-03-24 11:27:09] |
1724 did not appear to work .. Sent Log For Analysis to support
[2018-03-24 12:05:47] |
OK we have determined what the problem is. There is a new required field which was missing from the true real-time data request which is the cause of this. This is now fixed. We are going to put out a new revision of 1724 in about 10 minutes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-24 12:37:56] |
tested v.1724 and it works .. !!
[2018-03-25 00:05:45] |
User474090 - Posts: 5 |
Have downloaded v. 1724 and still cannot connect to IB. Connects to SC ok but I use IB as I mainly trade ASX instruments. Have forwarded log of recent attempts to connect. Vince |
[2018-03-25 05:55:02] |
In response to post #18, based upon what we see in your Message Log we think at this time it is best you contact Interactive Brokers in regards to the fact that TWS is closing the connection while Sierra Chart is performing the handshake to TWS and provide them the log files as explained here: Interactive Brokers Trading Service: Procedure for Providing TWS Log Files We have noticed ourselves that behavior but it simply has been resolved with a small delay before we begin to send TWS messages after the connection and after the initial handshake. We added a 250 ms delay. We can increase that, but the problem we are seeing at your side is so persistent, we do not think that is going to help and we think there is something else going wrong in your case. And in any case, no delay should be necessary at all. There is clearly some kind of bug on the TWS side. For now just use version 1720 or earlier: Software Download: Software Rollback Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-25 09:25:23
[2018-03-25 07:18:51] |
Gone back to 1720. It works fine with IB. Think I will stick with this version for a while. Thanks for your help and very timely repones. Much appreciated. Vince |
[2018-03-25 19:10:02] |
golding - Posts: 18 |
1725 works for me.
[2018-03-31 02:19:48] |
The outstanding issue where in some cases there is a problem with Sierra Chart connecting to Trader Workstation has been resolved in 1727. It also would be resolved by adding a trusted IP address for your local system, in TWS as our documentation explains and as we explained earlier in this thread. The problem has to do with the fact that there are now two TWS prompts to accept the connection and until both prompts are accepted, no commands can be sent to TWS, otherwise it will disconnect. So we just made sure there were no commands until such time that Sierra Chart receives the first message from TWS after the handshake which is the list of accounts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-31 02:47:32
