Date/Time: Sun, 19 May 2024 04:36:38 +0000
Limiting position size
View Count: 1573
[2018-03-07 19:31:39] |
User202045 - Posts: 11 |
Is there a way to enforce a maximium position size within SC? I.e., if I'm already at the largest position I want to carry, is there a setting where SC will reject orders that add to that position, either orders entered in error or orders that were resting at the time the original order was filled but that I failed to cancel manually for some reason?
[2018-03-07 20:40:08] |
No, this is not supported but we foresee this sometime probably this year.
[2019-11-05 15:38:56] |
b0w3n - Posts: 1 |
Is this still not possible? Can't find in profit/loss management anything related to position size. Thanks! |
[2019-11-06 02:36:46] |
Refer to this setting: Global Symbol Settings: Use Global Trade Position Limit (Global Settings >> Symbol Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
