Date/Time: Sun, 24 Nov 2024 05:49:17 +0000
Frequent Disconnection and Re-connection of real time Data flow from FXCM FIX connection
View Count: 1760
[2013-09-30 15:31:53]
JordiE - Posts: 38
Dear Support Team:
I've realized of very frecuent Disconnection and Re-connection of real time Data flow from FXCM FIX connections.
It happens independently of the traded pair and with different SierraChart engines on the same PC. I've also tried with a different PC and the failure ramains the same.
I thought it was due a WiFi interruption problems between the PC and the Router but, I now wired both by an ethernet cable and the problem remains.
I could not see any interruption in the internet data flow in any other programa / navigator, so I must asume the problem is only related to SierraCharts and/or the FXCM FIX connection itself.
If you wish, I can send one or more Message-Logs from SierraChart engines.
I would kindly ask for your help in this matter
Thanks so much in advance
Jordi
[2013-09-30 16:08:00]
We need to see one of the Message Logs. Please provide it by following these steps:
https://www.sierrachart.com/index.php?l=PostingInformation.php#log
[2013-09-30 16:27:29]
JordiE - Posts: 38
Software version: 1012 | 2013-09-19 17:57:27
Current Service Package: 3 | 2013-09-19 17:57:27
Usage end date: 2013-10-09 | 2013-09-19 17:57:27
Sierra Chart Historical Data Service is included. | 2013-09-19 17:57:27
Active service: FXCM FIX Trading | 2013-09-19 17:57:27
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2013-09-19 17:57:27
2013-09-19 17:57:27 Local computer clock time | 2013-09-19 17:57:27
2013-09-19 15:57:27 GMT time | 2013-09-19 17:57:27
2013-09-19 17:57:27 Time zone adjusted time | 2013-09-19 17:57:27
Time difference to server time: 5 seconds. | 2013-09-19 17:57:27
Program path: C:\SierraChart_3\ | 2013-09-19 17:57:27
Data Files path: C:\SierraChart_3\Data\ | 2013-09-19 17:57:27
OS Version Number: 6.1 | 2013-09-19 17:57:27
HD Request # 1 - Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: scsrv | 2013-09-19 17:57:33
HD Request # 1 - Starting date and time: 2013-09-19 15:07:06.0 | 2013-09-19 17:57:33
HD Request # 1 - Using server: ds5.sierracharts.com port 10049 | 2013-09-19 17:57:33
The network socket is connected. | 2013-09-19 17:57:33
HD Request # 1 - Requesting up to 400 days of Intraday data. | 2013-09-19 17:57:33
HD Request # 1 - Decompressing data. | 2013-09-19 17:57:34
Socket closed. No error. | 2013-09-19 17:57:34
Remote instance connected: C:\SierraChart_2\SierraChart.exe | 2013-09-19 17:57:34
HD Request # 1 - Historical data for GBPUSD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-09-19 17:57:35
HD Request # 1 - Received 0 records and wrote 0 records for GBPUSD | 2013-09-19 17:57:35
HD Request # 1 - Intraday download COMPLETE for GBPUSD | 2013-09-19 17:57:35
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-19 17:57:35
The network socket is connected. | 2013-09-19 17:57:35
FXCM FIX: Sending the Logon message. | 2013-09-19 17:57:36
Remote instance connected: C:\SierraChart_6\SierraChart.exe | 2013-09-19 17:57:36
Connection with FXCM FIX server established. Sending logon user request... | 2013-09-19 17:57:36
Remote instance connected: C:\SierraChart_4\SierraChart.exe | 2013-09-19 17:57:36
FXCM FIX - User status: Logged In | 2013-09-19 17:57:36
FXCM FIX: Requesting trading session status. | 2013-09-19 17:57:36
FXCM FIX: Connected. | 2013-09-19 17:57:36
Starting updates for: GBPUSD | 2013-09-19 17:57:36
Starting updates for: EURUSD | 2013-09-19 17:57:36
HD Request # 3 - Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: scsrv | 2013-09-19 17:57:36
HD Request # 3 - Starting date and time: 2013-09-19 15:07:06.0 | 2013-09-19 17:57:36
HD Request # 3 - Using server: ds3.sierracharts.com port 10049 | 2013-09-19 17:57:36
The network socket is connected. | 2013-09-19 17:57:37
HD Request # 3 - Requesting up to 400 days of Intraday data. | 2013-09-19 17:57:37
Trading session mode: Production. | 2013-09-19 17:57:37
Trading session status: Open. | 2013-09-19 17:57:37
Remote instance connected: C:\SierraChart_5\SierraChart.exe | 2013-09-19 17:57:37
HD Request # 3 - Decompressing data. | 2013-09-19 17:57:38
HD Request # 3 - Receiving Intraday data for GBPUSD starting at 2013-09-19 15:07:06 | 2013-09-19 17:57:38
HD Request # 3 - Timestamp of first Intraday data file record written: 2013-09-19 15:07:06 | 2013-09-19 17:57:38
Socket closed. No error. | 2013-09-19 17:57:43
HD Request # 3 - Received 7160 records from 2013-09-19 15:07:06 to 2013-09-19 17:57:32 (2.8 hours) and wrote 7160 records for GBPUSD | 2013-09-19 17:57:43
HD Request # 3 - Intraday download COMPLETE for GBPUSD | 2013-09-19 17:57:43
Real-time intraday chart data file updates started for GBPUSD | 2013-09-19 17:57:43
Trading session mode: Production. | 2013-09-20 22:55:07
Trading session status: Closed. | 2013-09-20 22:55:07
FXCM FIX: Received a Logout message. Text = stopped by server, engine bus going down. | 2013-09-21 01:21:19
FXCM FIX: Sending a Logout message. Text = Received Logout message. | 2013-09-21 01:21:19
FXCM FIX: Logged out and disconnected. | 2013-09-21 01:21:19
Connection to the external service has been lost. | 2013-09-21 01:21:19
Disconnected from FXCM FIX. | 2013-09-21 01:21:22
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:21:22
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:21:27
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:21:28
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:21:28
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:21:28
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:21:28
Disconnected from FXCM FIX. | 2013-09-21 01:21:28
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:21:28
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:21:33
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:21:35
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:21:35
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:21:35
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:21:35
Disconnected from FXCM FIX. | 2013-09-21 01:21:35
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:21:35
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:21:40
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:21:42
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:21:42
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:21:42
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:21:42
Disconnected from FXCM FIX. | 2013-09-21 01:21:42
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:21:42
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:21:47
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:21:48
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:21:48
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:21:48
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:21:48
Disconnected from FXCM FIX. | 2013-09-21 01:21:48
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:21:48
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:21:53
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:21:55
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:21:55
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:21:55
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:21:55
Disconnected from FXCM FIX. | 2013-09-21 01:21:55
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:21:55
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:22:00
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:22:01
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:22:01
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:22:01
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:22:01
Disconnected from FXCM FIX. | 2013-09-21 01:22:01
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:22:01
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:22:06
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:22:08
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:22:08
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:22:08
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:22:08
Disconnected from FXCM FIX. | 2013-09-21 01:22:08
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:22:08
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:22:13
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:22:15
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:22:15
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:22:15
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:22:15
Disconnected from FXCM FIX. | 2013-09-21 01:22:15
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:22:15
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:22:20
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:22:21
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:22:21
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:22:21
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:22:21
Disconnected from FXCM FIX. | 2013-09-21 01:22:21
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:22:21
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:22:26
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:22:28
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:22:28
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:22:28
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:22:28
Disconnected from FXCM FIX. | 2013-09-21 01:22:28
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:22:28
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:22:33
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:22:34
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:22:34
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:22:34
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:22:34
Disconnected from FXCM FIX. | 2013-09-21 01:22:34
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:22:34
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:22:39
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:22:41
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:22:41
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:22:41
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:22:41
Disconnected from FXCM FIX. | 2013-09-21 01:22:41
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:22:41
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:22:46
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:22:48
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:22:48
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:22:48
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:22:48
Disconnected from FXCM FIX. | 2013-09-21 01:22:48
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:22:48
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:22:53
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:22:54
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:22:54
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:22:54
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:22:54
Disconnected from FXCM FIX. | 2013-09-21 01:22:54
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:22:54
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:22:59
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:23:01
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:23:01
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:23:01
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:23:01
Disconnected from FXCM FIX. | 2013-09-21 01:23:01
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:23:01
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:23:06
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:23:07
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:23:07
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:23:07
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:23:07
Disconnected from FXCM FIX. | 2013-09-21 01:23:07
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:23:07
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:23:12
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:23:14
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:23:14
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:23:14
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:23:14
Disconnected from FXCM FIX. | 2013-09-21 01:23:14
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:23:14
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:23:19
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:23:20
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:23:20
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:23:20
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:23:20
Disconnected from FXCM FIX. | 2013-09-21 01:23:20
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:23:20
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:23:25
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:23:27
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:23:27
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:23:27
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:23:27
Disconnected from FXCM FIX. | 2013-09-21 01:23:27
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:23:27
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:23:32
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:23:34
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:23:34
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:23:34
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:23:34
Disconnected from FXCM FIX. | 2013-09-21 01:23:34
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:23:34
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:23:39
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:23:40
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:23:40
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:23:40
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:23:40
Disconnected from FXCM FIX. | 2013-09-21 01:23:40
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:23:40
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:23:45
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:23:47
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:23:47
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:23:47
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:23:47
Disconnected from FXCM FIX. | 2013-09-21 01:23:47
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:23:47
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:23:52
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:23:53
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:23:53
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:23:53
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:23:53
Disconnected from FXCM FIX. | 2013-09-21 01:23:53
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:23:53
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:23:58
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:24:00
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:24:00
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:24:00
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:24:00
Disconnected from FXCM FIX. | 2013-09-21 01:24:00
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:24:00
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:24:05
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:24:06
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:24:06
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:24:06
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:24:06
Disconnected from FXCM FIX. | 2013-09-21 01:24:06
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:24:06
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:24:11
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:24:13
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:24:13
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:24:13
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:24:13
Disconnected from FXCM FIX. | 2013-09-21 01:24:13
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:24:13
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:24:18
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:24:19
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:24:19
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:24:19
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:24:19
Disconnected from FXCM FIX. | 2013-09-21 01:24:20
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:24:20
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:24:25
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:24:26
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:24:26
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:24:26
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:24:26
Disconnected from FXCM FIX. | 2013-09-21 01:24:26
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:24:26
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:24:31
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:24:33
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:24:33
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:24:33
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:24:33
Disconnected from FXCM FIX. | 2013-09-21 01:24:33
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:24:33
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:27:33
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:27:34
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:27:34
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:27:34
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:27:34
Disconnected from FXCM FIX. | 2013-09-21 01:27:34
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:27:34
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:30:34
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:30:36
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:30:36
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:30:36
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:30:36
Disconnected from FXCM FIX. | 2013-09-21 01:30:36
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:30:36
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:33:36
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:33:37
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:33:37
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:33:37
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:33:37
Disconnected from FXCM FIX. | 2013-09-21 01:33:37
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:33:37
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:36:38
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:36:39
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:36:39
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:36:39
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:36:39
Disconnected from FXCM FIX. | 2013-09-21 01:36:39
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:36:39
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:39:39
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:39:41
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:39:41
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:39:41
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:39:41
Disconnected from FXCM FIX. | 2013-09-21 01:39:41
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:39:41
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:42:41
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:42:42
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:42:42
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:42:42
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:42:42
Disconnected from FXCM FIX. | 2013-09-21 01:42:42
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:42:42
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:45:42
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:45:44
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:45:44
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:45:44
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:45:44
Disconnected from FXCM FIX. | 2013-09-21 01:45:44
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:45:44
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:48:44
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:48:45
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:48:45
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:48:45
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:48:45
Disconnected from FXCM FIX. | 2013-09-21 01:48:45
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:48:45
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:51:45
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:51:47
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:51:47
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:51:47
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:51:47
Disconnected from FXCM FIX. | 2013-09-21 01:51:47
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:51:47
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:54:47
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:54:49
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:54:49
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:54:49
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:54:49
Disconnected from FXCM FIX. | 2013-09-21 01:54:49
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:54:49
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 01:57:49
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 01:57:50
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 01:57:50
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 01:57:50
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 01:57:50
Disconnected from FXCM FIX. | 2013-09-21 01:57:50
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 01:57:50
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:00:50
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 02:00:52
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 02:00:52
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 02:00:52
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 02:00:52
Disconnected from FXCM FIX. | 2013-09-21 02:00:52
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 02:00:52
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:03:52
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 02:03:54
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 02:03:54
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 02:03:54
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 02:03:54
Disconnected from FXCM FIX. | 2013-09-21 02:03:54
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 02:03:54
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:06:54
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 02:06:55
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 02:06:55
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 02:06:55
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 02:06:55
Disconnected from FXCM FIX. | 2013-09-21 02:06:55
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 02:06:55
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:09:55
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 02:09:57
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 02:09:57
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 02:09:57
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 02:09:57
Disconnected from FXCM FIX. | 2013-09-21 02:09:57
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 02:09:57
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:12:57
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 02:12:58
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 02:12:58
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 02:12:58
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 02:12:58
Disconnected from FXCM FIX. | 2013-09-21 02:12:58
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 02:12:58
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:15:58
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 02:16:00
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 02:16:00
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 02:16:00
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 02:16:00
Disconnected from FXCM FIX. | 2013-09-21 02:16:00
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 02:16:00
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:19:00
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 02:19:01
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 02:19:01
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 02:19:01
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 02:19:01
Disconnected from FXCM FIX. | 2013-09-21 02:19:01
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 02:19:01
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:22:02
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 02:22:03
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 02:22:03
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 02:22:03
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 02:22:03
Disconnected from FXCM FIX. | 2013-09-21 02:22:03
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 02:22:03
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:25:03
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 02:25:05
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 02:25:05
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 02:25:05
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 02:25:05
Disconnected from FXCM FIX. | 2013-09-21 02:25:05
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 02:25:05
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:28:05
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 02:28:06
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 02:28:06
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 02:28:06
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 02:28:06
Disconnected from FXCM FIX. | 2013-09-21 02:28:06
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 02:28:06
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:31:06
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 02:31:08
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 02:31:08
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 02:31:08
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 02:31:08
Disconnected from FXCM FIX. | 2013-09-21 02:31:08
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 02:31:08
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:34:08
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 02:34:09
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 02:34:09
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 02:34:09
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 02:34:09
Disconnected from FXCM FIX. | 2013-09-21 02:34:10
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 02:34:10
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:37:10
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-21 02:37:11
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-21 02:37:11
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 02:37:11
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 02:37:11
Disconnected from FXCM FIX. | 2013-09-21 02:37:11
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 02:37:11
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:40:11
The network socket is connected. | 2013-09-21 02:40:11
FXCM FIX: Sending the Logon message. | 2013-09-21 02:40:12
Connection with FXCM FIX server established. Sending logon user request... | 2013-09-21 02:40:12
FXCM FIX: Received a Logout message. Text = give up waiting, sessionkeeper didn't start. | 2013-09-21 02:40:42
FXCM FIX: Sending a Logout message. Text = Received Logout message. | 2013-09-21 02:40:42
FXCM FIX: Logged out and disconnected. | 2013-09-21 02:40:42
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 02:40:42
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 02:40:42
Disconnected from FXCM FIX. | 2013-09-21 02:40:42
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 02:40:42
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:43:42
The network socket is connected. | 2013-09-21 02:43:43
FXCM FIX: Sending the Logon message. | 2013-09-21 02:43:43
Connection with FXCM FIX server established. Sending logon user request... | 2013-09-21 02:43:43
FXCM FIX: Received a Logout message. Text = give up waiting, sessionkeeper didn't start. | 2013-09-21 02:44:14
FXCM FIX: Sending a Logout message. Text = Received Logout message. | 2013-09-21 02:44:14
FXCM FIX: Logged out and disconnected. | 2013-09-21 02:44:14
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 02:44:14
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 02:44:14
Disconnected from FXCM FIX. | 2013-09-21 02:44:14
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 02:44:14
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:47:14
The network socket is connected. | 2013-09-21 02:47:14
FXCM FIX: Sending the Logon message. | 2013-09-21 02:47:14
Connection with FXCM FIX server established. Sending logon user request... | 2013-09-21 02:47:15
FXCM FIX: Received a Logout message. Text = give up waiting, sessionkeeper didn't start. | 2013-09-21 02:47:45
FXCM FIX: Sending a Logout message. Text = Received Logout message. | 2013-09-21 02:47:45
FXCM FIX: Logged out and disconnected. | 2013-09-21 02:47:45
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-21 02:47:45
To prevent further connection attempts, select File >> Disconnect. | 2013-09-21 02:47:45
Disconnected from FXCM FIX. | 2013-09-21 02:47:45
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2013-09-21 02:47:45
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-21 02:50:45
The network socket is connected. | 2013-09-21 02:50:46
FXCM FIX: Sending the Logon message. | 2013-09-21 02:50:46
Connection with FXCM FIX server established. Sending logon user request... | 2013-09-21 02:50:46
FXCM FIX - User status: Logged In | 2013-09-21 02:50:46
FXCM FIX: Requesting trading session status. | 2013-09-21 02:50:46
FXCM FIX: Connected. | 2013-09-21 02:50:46
Trading session mode: Production. | 2013-09-21 02:50:49
Trading session status: Closed. | 2013-09-21 02:50:49
Starting updates for: GBPUSD | 2013-09-21 02:50:49
Starting updates for: EURUSD | 2013-09-21 02:50:49
HD Request # 5 - Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: scsrv | 2013-09-21 02:50:49
HD Request # 5 - Starting date and time: 2013-09-20 22:58:29.0 | 2013-09-21 02:50:49
Remote instance connected: C:\SierraChart_4\SierraChart.exe | 2013-09-21 02:50:49
Remote instance connected: C:\SierraChart_6\SierraChart.exe | 2013-09-21 02:50:49
HD Request # 5 - Using server: ds4.sierracharts.com port 10049 | 2013-09-21 02:50:49
The network socket is connected. | 2013-09-21 02:50:50
HD Request # 5 - Requesting up to 400 days of Intraday data. | 2013-09-21 02:50:50
Remote instance connected: C:\SierraChart_5\SierraChart.exe | 2013-09-21 02:50:50
Remote instance connected: C:\SierraChart_2\SierraChart.exe | 2013-09-21 02:50:50
HD Request # 5 - Decompressing data. | 2013-09-21 02:50:51
Socket closed. No error. | 2013-09-21 02:50:51
HD Request # 5 - Received 0 records and wrote 0 records for GBPUSD | 2013-09-21 02:50:51
HD Request # 5 - Intraday download COMPLETE for GBPUSD | 2013-09-21 02:50:51
Real-time intraday chart data file updates started for GBPUSD | 2013-09-21 02:50:51
FXCM FIX: Received a Logout message. | 2013-09-22 06:00:08
FXCM FIX: Sending a Logout message. Text = Received Logout message. | 2013-09-22 06:00:08
FXCM FIX: Logged out and disconnected. | 2013-09-22 06:00:08
Connection to the external service has been lost. | 2013-09-22 06:00:08
Disconnected from FXCM FIX. | 2013-09-22 06:00:11
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-22 06:00:11
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-22 06:00:16
The network socket is connected. | 2013-09-22 06:00:16
FXCM FIX: Sending the Logon message. | 2013-09-22 06:00:17
Connection with FXCM FIX server established. Sending logon user request... | 2013-09-22 06:00:17
FXCM FIX - User status: Logged In | 2013-09-22 06:00:17
FXCM FIX: Requesting trading session status. | 2013-09-22 06:00:17
FXCM FIX: Connected. | 2013-09-22 06:00:17
Trading session mode: Production. | 2013-09-22 06:00:20
Trading session status: Closed. | 2013-09-22 06:00:20
Starting updates for: GBPUSD | 2013-09-22 06:00:20
Starting updates for: EURUSD | 2013-09-22 06:00:20
HD Request # 7 - Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: scsrv | 2013-09-22 06:00:20
HD Request # 7 - Starting date and time: 2013-09-20 22:58:29.0 | 2013-09-22 06:00:20
Remote instance connected: C:\SierraChart_4\SierraChart.exe | 2013-09-22 06:00:20
HD Request # 7 - Using server: ds5.sierracharts.com port 10049 | 2013-09-22 06:00:20
Remote instance connected: C:\SierraChart_6\SierraChart.exe | 2013-09-22 06:00:20
Remote instance connected: C:\SierraChart_2\SierraChart.exe | 2013-09-22 06:00:20
Remote instance connected: C:\SierraChart_5\SierraChart.exe | 2013-09-22 06:00:20
The network socket is connected. | 2013-09-22 06:00:20
HD Request # 7 - Requesting up to 400 days of Intraday data. | 2013-09-22 06:00:20
HD Request # 7 - Decompressing data. | 2013-09-22 06:00:21
Socket closed. No error. | 2013-09-22 06:00:21
HD Request # 7 - Received 0 records and wrote 0 records for GBPUSD | 2013-09-22 06:00:21
HD Request # 7 - Intraday download COMPLETE for GBPUSD | 2013-09-22 06:00:21
Real-time intraday chart data file updates started for GBPUSD | 2013-09-22 06:00:21
Trading session mode: Production. | 2013-09-22 23:00:21
Trading session status: Open. | 2013-09-22 23:00:21
Socket closed. Windows error code 10053: Se ha anulado una conexión establecida por el software en su equipo host.. | 2013-09-23 08:41:41
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-23 08:41:41
Connection to the external service has been lost. | 2013-09-23 08:41:41
Disconnected from FXCM FIX. | 2013-09-23 08:41:43
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-23 08:41:43
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-23 08:41:48
The network socket is connected. | 2013-09-23 08:41:57
FXCM FIX: Sending the Logon message. | 2013-09-23 08:41:57
FXCM FIX: Received a Reject <3> message. RefSeqNum = 1. RefMsgType = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed.. | 2013-09-23 08:41:57
Socket closed. No error. | 2013-09-23 08:41:57
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-23 08:41:57
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-23 08:41:57
To prevent further connection attempts, select File >> Disconnect. | 2013-09-23 08:41:57
Disconnected from FXCM FIX. | 2013-09-23 08:41:57
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-23 08:41:57
Remote instance connected: C:\SierraChart_5\SierraChart.exe | 2013-09-23 08:42:00
Remote instance connected: C:\SierraChart_4\SierraChart.exe | 2013-09-23 08:42:02
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-23 08:42:02
The network socket is connected. | 2013-09-23 08:42:03
FXCM FIX: Sending the Logon message. | 2013-09-23 08:42:03
Connection with FXCM FIX server established. Sending logon user request... | 2013-09-23 08:42:03
FXCM FIX - User status: Logged In | 2013-09-23 08:42:04
FXCM FIX: Requesting trading session status. | 2013-09-23 08:42:04
FXCM FIX: Connected. | 2013-09-23 08:42:04
Trading session mode: Production. | 2013-09-23 08:42:06
Trading session status: Open. | 2013-09-23 08:42:06
Starting updates for: GBPUSD | 2013-09-23 08:42:06
Starting updates for: EURUSD | 2013-09-23 08:42:06
HD Request # 9 - Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: scsrv | 2013-09-23 08:42:06
HD Request # 9 - Starting date and time: 2013-09-23 08:41:09.0 | 2013-09-23 08:42:06
HD Request # 9 - Using server: ds3.sierracharts.com port 10049 | 2013-09-23 08:42:06
The network socket is connected. | 2013-09-23 08:42:06
HD Request # 9 - Requesting up to 400 days of Intraday data. | 2013-09-23 08:42:06
HD Request # 9 - Decompressing data. | 2013-09-23 08:42:07
HD Request # 9 - Receiving Intraday data for GBPUSD starting at 2013-09-23 08:41:09 | 2013-09-23 08:42:07
HD Request # 9 - Timestamp of first Intraday data file record written: 2013-09-23 08:41:09 | 2013-09-23 08:42:07
Socket closed. No error. | 2013-09-23 08:42:07
HD Request # 9 - Received 16 records from 2013-09-23 08:41:09 to 2013-09-23 08:41:51 (42.0 seconds) and wrote 16 records for GBPUSD | 2013-09-23 08:42:07
HD Request # 9 - Intraday download COMPLETE for GBPUSD | 2013-09-23 08:42:07
Real-time intraday chart data file updates started for GBPUSD | 2013-09-23 08:42:07
Remote instance connected: C:\SierraChart_2\SierraChart.exe | 2013-09-23 08:42:09
Remote instance connected: C:\SierraChart_6\SierraChart.exe | 2013-09-23 08:42:10
Trading session mode: Production. | 2013-09-27 22:55:18
Trading session status: Closed. | 2013-09-27 22:55:18
FXCM FIX: Received a Logout message. Text = stopped by server, engine bus going down. | 2013-09-28 06:44:24
FXCM FIX: Sending a Logout message. Text = Received Logout message. | 2013-09-28 06:44:24
FXCM FIX: Logged out and disconnected. | 2013-09-28 06:44:24
Connection to the external service has been lost. | 2013-09-28 06:44:24
Disconnected from FXCM FIX. | 2013-09-28 06:44:27
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-28 06:44:27
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-28 06:44:32
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-28 06:44:34
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-28 06:44:34
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-28 06:44:34
To prevent further connection attempts, select File >> Disconnect. | 2013-09-28 06:44:34
Disconnected from FXCM FIX. | 2013-09-28 06:44:34
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-28 06:44:34
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-28 06:44:39
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-28 06:44:40
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-28 06:44:40
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-28 06:44:40
To prevent further connection attempts, select File >> Disconnect. | 2013-09-28 06:44:40
Disconnected from FXCM FIX. | 2013-09-28 06:44:40
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-28 06:44:40
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-28 06:44:45
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-28 06:44:47
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-28 06:44:47
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-28 06:44:47
To prevent further connection attempts, select File >> Disconnect. | 2013-09-28 06:44:47
Disconnected from FXCM FIX. | 2013-09-28 06:44:47
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-28 06:44:47
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-28 06:44:52
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-28 06:44:54
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-28 06:44:54
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-28 06:44:54
To prevent further connection attempts, select File >> Disconnect. | 2013-09-28 06:44:54
Disconnected from FXCM FIX. | 2013-09-28 06:44:54
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-28 06:44:54
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-28 06:44:59
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-28 06:45:00
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-28 06:45:00
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-28 06:45:00
To prevent further connection attempts, select File >> Disconnect. | 2013-09-28 06:45:00
Disconnected from FXCM FIX. | 2013-09-28 06:45:00
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-28 06:45:00
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-28 06:45:05
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-28 06:45:07
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-28 06:45:07
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-28 06:45:07
To prevent further connection attempts, select File >> Disconnect. | 2013-09-28 06:45:07
Disconnected from FXCM FIX. | 2013-09-28 06:45:07
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-28 06:45:07
Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8029 | 2013-09-28 06:45:12
Error connecting socket. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2013-09-28 06:45:13
FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-09-28 06:45:13
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-28 06:45:13
To prevent further connection attempts, select File >> Disconnect. | 2013-09-28 06:45:13
Disconnected from FXCM FIX. | 2013-09-28 06:45:13
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-28 06:45:13
[2013-09-30 16:34:19]
Have you tried disabling any firewall software on your system. The Windows firewall should be OK but you can temporarily disable it.
Date Time Of Last Edit: 2013-09-30 16:36:59
[2013-09-30 17:02:56]
JordiE - Posts: 38
Hi, thanks for your quick reply.
No, I didn't.
The Windows Firewall is Active and no other firewall exist.
I now first would like to try disabling the WiFi adapter, which was also running together with the Ethernet connection.
If until tomorrow there are no positive results, I will try disabling the Windows Firewall.
I'll keep you updated with the results.
Thanks for your help !
Best regards
Jordi
[2013-09-30 20:26:55]
We were able to connect to the same FXCM server without problems. So it is definitely a connectivity problem on your side. Or with your Internet Service Provider.
[2013-09-30 20:47:52]
JordiE - Posts: 38
Thanks Support Team,
When disconnecting the WiFi adapter I found the Ethernet adapter out of order. I re-installed it and now seems to be ok, since a couple of hours.
If any abnormality comes again I will come back to you with a report.
Thanks again for your help
Have a nice evening !
Jordi
