Date/Time: Sun, 24 Nov 2024 05:49:11 +0000
[User Discussion] - Problem when copy chart drawings from chart #
View Count: 1661
[2013-09-29 21:53:41] |
GPST10 - Posts: 139 |
CHART - CHART SETTINGS - ADVANCED SETTINGS 2 - COPY CHART DRAWINGS FROM CHART # XX There is a problem needs to be fixed when using this above mentioned option - it copies also stationary text and puts on top of the stationary text in target chart - no good, can SC fix it? thanks |
[2013-09-30 09:36:21] |
Why should stationary text not be copied? Some users may want to have them copied over. What you consider a problem, is considered a feature to someone else. If we change this, inevitably, then someone will complain about this. We cannot make this change. In order to accomplish what you want, requires us to support what type of drawings should be copied over. That is a significant development task and then create new kinds of potential support issues for us. It is not something we want to do. The simple solution on your side is not to put stationary text drawings on a chart you are copying drawings from. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-30 12:29:59] |
Better would be to create option what not to copy and there is only one thing. Later I can send you some examples. Most of my working charts has copied drawings, every chart on all my screens has big bold label stationary in the middle, when I use this option my labels become unreadable overlaying titles over each other. Thanks |
