Date/Time: Wed, 09 Sep 2026 13:24:47 +0000
No connection with Live Datafeed
View Count: 1152
[2018-02-26 11:13:28]
User133093 - Posts: 11
Since this morning I can't get connected to the live datafeed anymore. This is the second tim within a few weeks...
First I received Windows errorcode 10061 and now also 10053.
Don't understand how this can happen just over the weekend. Latest version of SC has been installed, nothing has changed with me since Friday. Don't understand the "solutions" from the self help pages, so please give clear instructions what to do.
Reading Internal Order ID file. | 2018-02-26 11:45:00
Reading Trade Orders file. | 2018-02-26 11:45:00
Reading Trade Positions file. | 2018-02-26 11:45:00
Listening on UDP port 22903. | 2018-02-26 11:45:01
Software version: 1705 | 2018-02-26 11:45:01
Usage end date: 2018-03-29 | 2018-02-26 11:45:01
Enabled for: Advanced Features. | 2018-02-26 11:45:01
Enabled for: Sierra Chart Historical Data Service. | 2018-02-26 11:45:01
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-02-26 11:45:01
Current selected Data/Trading service: Rithmic Trading | 2018-02-26 11:45:01
Chart Update Interval: 500 | 2018-02-26 11:45:01
Data/Trade Service Settings automatically set. | 2018-02-26 11:45:01
Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2018-02-26 11:45:01
2018-02-26 11:45:00 Local computer time | 2018-02-26 11:45:01
2018-02-26 10:45:00 Local computer time in UTC | 2018-02-26 11:45:01
2018-02-26 11:45:00 Local computer time in SC Time Zone | 2018-02-26 11:45:01
2018-02-26 10:45:00 Server time in UTC | 2018-02-26 11:45:01
Local computer UTC time and Server UTC time difference: 1 seconds. | 2018-02-26 11:45:01
Program path: C:\SierraChart\ | 2018-02-26 11:45:01
Data Files path: C:\SierraChart\Data\ | 2018-02-26 11:45:01
OS Version Number: 10.0 | 2018-02-26 11:45:01
Locale Setting: C | 2018-02-26 11:45:01
Rithmic Trading | Port for executable: 51725 | 2018-02-26 11:50:00
Listening socket (1780). Port 51725 | Closed. | 2018-02-26 11:50:00
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 11:50:00
Rithmic Trading | Bridge process is not running! | 2018-02-26 11:50:02
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51725 | 2018-02-26 11:50:02
DTC Client socket (56) | Creating socket. | 2018-02-26 11:50:02
DTC Client socket (56) | Connecting to IP: 127.0.0.1. | 2018-02-26 11:50:02
DTC Client socket (56) | Connect event error. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2018-02-26 11:50:03 *
DTC Client socket (56) | Initiating close of socket by core. | 2018-02-26 11:50:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 11:50:03
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:03
DTC Client socket (56) | Closed. | 2018-02-26 11:50:03
Rithmic Trading | Disconnected. | 2018-02-26 11:50:03
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:03
Rithmic Trading | Port for executable: 51730 | 2018-02-26 11:50:05
Listening socket (1656). Port 51730 | Closed. | 2018-02-26 11:50:05
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 11:50:05
Rithmic Trading | Bridge process is not running! | 2018-02-26 11:50:07
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51730 | 2018-02-26 11:50:07
DTC Client socket (57) | Creating socket. | 2018-02-26 11:50:07
DTC Client socket (57) | Connecting to IP: 127.0.0.1. | 2018-02-26 11:50:07
DTC Client socket (57) | Connect event error. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2018-02-26 11:50:08 *
DTC Client socket (57) | Initiating close of socket by core. | 2018-02-26 11:50:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 11:50:08
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:08
DTC Client socket (57) | Closed. | 2018-02-26 11:50:08
Rithmic Trading | Disconnected. | 2018-02-26 11:50:08
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:08
Rithmic Trading | Port for executable: 51732 | 2018-02-26 11:50:10
Listening socket (1656). Port 51732 | Closed. | 2018-02-26 11:50:10
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 11:50:10
Rithmic Trading | Bridge process is not running! | 2018-02-26 11:50:12
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51732 | 2018-02-26 11:50:12
DTC Client socket (58) | Creating socket. | 2018-02-26 11:50:12
DTC Client socket (58) | Connecting to IP: 127.0.0.1. | 2018-02-26 11:50:12
DTC Client socket (58) | Connect event error. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2018-02-26 11:50:13 *
DTC Client socket (58) | Initiating close of socket by core. | 2018-02-26 11:50:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 11:50:13
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:13
DTC Client socket (58) | Closed. | 2018-02-26 11:50:13
Rithmic Trading | Disconnected. | 2018-02-26 11:50:13
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:13
Rithmic Trading | Port for executable: 51734 | 2018-02-26 11:50:15
Listening socket (1656). Port 51734 | Closed. | 2018-02-26 11:50:15
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 11:50:15
Rithmic Trading | Bridge process is not running! | 2018-02-26 11:50:17
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51734 | 2018-02-26 11:50:17
DTC Client socket (59) | Creating socket. | 2018-02-26 11:50:17
DTC Client socket (59) | Connecting to IP: 127.0.0.1. | 2018-02-26 11:50:17
DTC Client socket (54) | Close event error. Windows error code 10053: De software op uw hostcomputer heeft een verbinding verbroken. | 2018-02-26 11:50:18 *
DTC Client socket (54) | Socket gracefully closed by remote side. | 2018-02-26 11:50:18
DTC Client socket (54) | Closed. | 2018-02-26 11:50:18
DTC Client socket (59) | Connect event error. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2018-02-26 11:50:18 *
DTC Client socket (59) | Initiating close of socket by core. | 2018-02-26 11:50:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 11:50:18
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:18
DTC Client socket (59) | Closed. | 2018-02-26 11:50:18
Rithmic Trading | Disconnected. | 2018-02-26 11:50:18
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:18
Rithmic Trading | Port for executable: 51736 | 2018-02-26 11:50:20
Listening socket (1792). Port 51736 | Closed. | 2018-02-26 11:50:20
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 11:50:20
Rithmic Trading | Bridge process is running. | 2018-02-26 11:50:22
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51736 | 2018-02-26 11:50:22
DTC Client socket (60) | Creating socket. | 2018-02-26 11:50:22
DTC Client socket (60) | Connecting to IP: 127.0.0.1. | 2018-02-26 11:50:22
Rithmic Trading | Connected to server. | 2018-02-26 11:50:22
Rithmic Trading | Starting socket receive thread. | 2018-02-26 11:50:22
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-02-26 11:50:22
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-02-26 11:50:22
Rithmic Trading | Sending logon request message. | 2018-02-26 11:50:22
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-02-26 11:50:22
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-02-26 11:50:22
Rithmic Trading | Message from server: Connecting to Rithmic 01 Europe server. | 2018-02-26 11:50:22
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2018-02-26 11:50:24
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2018-02-26 11:50:25
Rithmic Trading | Received logon response. | 2018-02-26 11:50:25
Rithmic Trading | Server Name: DTC Bridge. | 2018-02-26 11:50:25
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-02-26 11:50:25
Rithmic Trading | Logon error received from server | 2018-02-26 11:50:25
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 11:50:25
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:25
DTC Client socket (60) | Initiating close of socket by core. | 2018-02-26 11:50:25
Rithmic Trading | Disconnected. | 2018-02-26 11:50:25
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:25
DTC Client socket (60) | Shutdown started. Waiting for graceful close. | 2018-02-26 11:50:25
Rithmic Trading | Port for executable: 51750 | 2018-02-26 11:50:27
Listening socket (1792). Port 51750 | Closed. | 2018-02-26 11:50:27
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 11:50:27
Rithmic Trading | Bridge process is not running! | 2018-02-26 11:50:29
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51750 | 2018-02-26 11:50:29
DTC Client socket (61) | Creating socket. | 2018-02-26 11:50:29
DTC Client socket (61) | Connecting to IP: 127.0.0.1. | 2018-02-26 11:50:29
DTC Client socket (61) | Connect event error. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2018-02-26 11:50:30 *
DTC Client socket (61) | Initiating close of socket by core. | 2018-02-26 11:50:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 11:50:30
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:30
DTC Client socket (61) | Closed. | 2018-02-26 11:50:30
Rithmic Trading | Disconnected. | 2018-02-26 11:50:30
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:30
Rithmic Trading | Port for executable: 51752 | 2018-02-26 11:50:32
Listening socket (1792). Port 51752 | Closed. | 2018-02-26 11:50:32
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 11:50:32
Rithmic Trading | Bridge process is not running! | 2018-02-26 11:50:34
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51752 | 2018-02-26 11:50:34
DTC Client socket (62) | Creating socket. | 2018-02-26 11:50:34
DTC Client socket (62) | Connecting to IP: 127.0.0.1. | 2018-02-26 11:50:34
DTC Client socket (62) | Connect event error. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2018-02-26 11:50:36 *
DTC Client socket (62) | Initiating close of socket by core. | 2018-02-26 11:50:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 11:50:36
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:36
DTC Client socket (62) | Closed. | 2018-02-26 11:50:36
Rithmic Trading | Disconnected. | 2018-02-26 11:50:36
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:36
Rithmic Trading | Port for executable: 51754 | 2018-02-26 11:50:38
Listening socket (1828). Port 51754 | Closed. | 2018-02-26 11:50:38
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 11:50:38
Rithmic Trading | Bridge process is not running! | 2018-02-26 11:50:40
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51754 | 2018-02-26 11:50:40
DTC Client socket (63) | Creating socket. | 2018-02-26 11:50:40
DTC Client socket (63) | Connecting to IP: 127.0.0.1. | 2018-02-26 11:50:40
DTC Client socket (63) | Connect event error. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2018-02-26 11:50:41 *
DTC Client socket (63) | Initiating close of socket by core. | 2018-02-26 11:50:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 11:50:41
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:41
DTC Client socket (63) | Closed. | 2018-02-26 11:50:41
Rithmic Trading | Disconnected. | 2018-02-26 11:50:41
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:41
Rithmic Trading | Port for executable: 51756 | 2018-02-26 11:50:43
Listening socket (1804). Port 51756 | Closed. | 2018-02-26 11:50:43
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 11:50:43
Rithmic Trading | Bridge process is not running! | 2018-02-26 11:50:45
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51756 | 2018-02-26 11:50:45
DTC Client socket (64) | Creating socket. | 2018-02-26 11:50:45
DTC Client socket (64) | Connecting to IP: 127.0.0.1. | 2018-02-26 11:50:45
DTC Client socket (60) | Close event error. Windows error code 10053: De software op uw hostcomputer heeft een verbinding verbroken. | 2018-02-26 11:50:45 *
DTC Client socket (60) | Socket gracefully closed by remote side. | 2018-02-26 11:50:45
DTC Client socket (60) | Closed. | 2018-02-26 11:50:45
DTC Client socket (64) | Connect event error. Windows error code 10061: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd. | 2018-02-26 11:50:46 *
DTC Client socket (64) | Initiating close of socket by core. | 2018-02-26 11:50:46
DTC Client socket (64) | Closed. | 2018-02-26 11:50:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 11:50:46
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:46
Rithmic Trading | Disconnected. | 2018-02-26 11:50:46
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:50:46
Rithmic Trading | Port for executable: 51763 | 2018-02-26 11:52:46
Listening socket (1804). Port 51763 | Closed. | 2018-02-26 11:52:46
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 11:52:46
Rithmic Trading | Bridge process is running. | 2018-02-26 11:52:48
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51763 | 2018-02-26 11:52:48
DTC Client socket (67) | Creating socket. | 2018-02-26 11:52:48
DTC Client socket (67) | Connecting to IP: 127.0.0.1. | 2018-02-26 11:52:48
Rithmic Trading | Connected to server. | 2018-02-26 11:52:48
Rithmic Trading | Starting socket receive thread. | 2018-02-26 11:52:48
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-02-26 11:52:48
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-02-26 11:52:48
Rithmic Trading | Sending logon request message. | 2018-02-26 11:52:48
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-02-26 11:52:48
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-02-26 11:52:48
Rithmic Trading | Message from server: Connecting to Rithmic 01 Europe server. | 2018-02-26 11:52:48
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2018-02-26 11:53:09
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2018-02-26 11:53:31
Rithmic Trading | Received logon response. | 2018-02-26 11:53:31
Rithmic Trading | Server Name: DTC Bridge. | 2018-02-26 11:53:31
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-02-26 11:53:31
Rithmic Trading | Logon error received from server | 2018-02-26 11:53:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 11:53:31
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:53:31
DTC Client socket (67) | Initiating close of socket by core. | 2018-02-26 11:53:31
Rithmic Trading | Disconnected. | 2018-02-26 11:53:31
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:53:31
DTC Client socket (67) | Shutdown started. Waiting for graceful close. | 2018-02-26 11:53:31
DTC Client socket (67) | Close event error. Windows error code 10053: De software op uw hostcomputer heeft een verbinding verbroken. | 2018-02-26 11:53:51 *
DTC Client socket (67) | Socket gracefully closed by remote side. | 2018-02-26 11:53:51
DTC Client socket (67) | Closed. | 2018-02-26 11:53:51
Rithmic Trading | Port for executable: 51792 | 2018-02-26 11:54:11
Listening socket (1552). Port 51792 | Closed. | 2018-02-26 11:54:11
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 11:54:11
Rithmic Trading | Bridge process is running. | 2018-02-26 11:54:13
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51792 | 2018-02-26 11:54:13
DTC Client socket (70) | Creating socket. | 2018-02-26 11:54:13
DTC Client socket (70) | Connecting to IP: 127.0.0.1. | 2018-02-26 11:54:13
Rithmic Trading | Connected to server. | 2018-02-26 11:54:13
Rithmic Trading | Starting socket receive thread. | 2018-02-26 11:54:13
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-02-26 11:54:13
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-02-26 11:54:13
Rithmic Trading | Sending logon request message. | 2018-02-26 11:54:13
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-02-26 11:54:13
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-02-26 11:54:13
Rithmic Trading | Message from server: Connecting to Rithmic 01 Europe server. | 2018-02-26 11:54:13
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2018-02-26 11:54:35
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2018-02-26 11:54:36
Rithmic Trading | Received logon response. | 2018-02-26 11:54:36
Rithmic Trading | Server Name: DTC Bridge. | 2018-02-26 11:54:36
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-02-26 11:54:36
Rithmic Trading | Logon error received from server | 2018-02-26 11:54:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 11:54:36
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:54:36
DTC Client socket (70) | Initiating close of socket by core. | 2018-02-26 11:54:36
Rithmic Trading | Disconnected. | 2018-02-26 11:54:36
DTC Client socket (70) | Shutdown started. Waiting for graceful close. | 2018-02-26 11:54:36
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:54:36
DTC Client socket (70) | Close event error. Windows error code 10053: De software op uw hostcomputer heeft een verbinding verbroken. | 2018-02-26 11:54:56 *
DTC Client socket (70) | Socket gracefully closed by remote side. | 2018-02-26 11:54:56
DTC Client socket (70) | Closed. | 2018-02-26 11:54:56
Rithmic Trading | Port for executable: 51825 | 2018-02-26 11:56:36
Listening socket (1832). Port 51825 | Closed. | 2018-02-26 11:56:36
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 11:56:36
Rithmic Trading | Bridge process is running. | 2018-02-26 11:56:39
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51825 | 2018-02-26 11:56:39
DTC Client socket (73) | Creating socket. | 2018-02-26 11:56:39
DTC Client socket (73) | Connecting to IP: 127.0.0.1. | 2018-02-26 11:56:39
Rithmic Trading | Connected to server. | 2018-02-26 11:56:39
Rithmic Trading | Starting socket receive thread. | 2018-02-26 11:56:39
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-02-26 11:56:39
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-02-26 11:56:39
Rithmic Trading | Sending logon request message. | 2018-02-26 11:56:39
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-02-26 11:56:39
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-02-26 11:56:39
Rithmic Trading | Message from server: Connecting to Rithmic 01 Europe server. | 2018-02-26 11:56:39
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2018-02-26 11:57:00
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2018-02-26 11:57:22
Rithmic Trading | Received logon response. | 2018-02-26 11:57:22
Rithmic Trading | Server Name: DTC Bridge. | 2018-02-26 11:57:22
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-02-26 11:57:22
Rithmic Trading | Logon error received from server | 2018-02-26 11:57:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 11:57:22
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:57:22
DTC Client socket (73) | Initiating close of socket by core. | 2018-02-26 11:57:22
Rithmic Trading | Disconnected. | 2018-02-26 11:57:22
DTC Client socket (73) | Shutdown started. Waiting for graceful close. | 2018-02-26 11:57:22
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:57:22
DTC Client socket (73) | Close event error. Windows error code 10053: De software op uw hostcomputer heeft een verbinding verbroken. | 2018-02-26 11:57:42 *
DTC Client socket (73) | Socket gracefully closed by remote side. | 2018-02-26 11:57:42
DTC Client socket (73) | Closed. | 2018-02-26 11:57:42
Rithmic Trading | Port for executable: 51847 | 2018-02-26 11:59:22
Listening socket (1540). Port 51847 | Closed. | 2018-02-26 11:59:22
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 11:59:22
Rithmic Trading | Bridge process is running. | 2018-02-26 11:59:24
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51847 | 2018-02-26 11:59:24
DTC Client socket (77) | Creating socket. | 2018-02-26 11:59:24
DTC Client socket (77) | Connecting to IP: 127.0.0.1. | 2018-02-26 11:59:24
Rithmic Trading | Connected to server. | 2018-02-26 11:59:24
Rithmic Trading | Starting socket receive thread. | 2018-02-26 11:59:24
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-02-26 11:59:24
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-02-26 11:59:24
Rithmic Trading | Sending logon request message. | 2018-02-26 11:59:24
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-02-26 11:59:24
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-02-26 11:59:24
Rithmic Trading | Message from server: Connecting to Rithmic 01 Europe server. | 2018-02-26 11:59:24
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2018-02-26 11:59:25
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2018-02-26 11:59:47
Rithmic Trading | Received logon response. | 2018-02-26 11:59:47
Rithmic Trading | Server Name: DTC Bridge. | 2018-02-26 11:59:47
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-02-26 11:59:47
Rithmic Trading | Logon error received from server | 2018-02-26 11:59:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 11:59:47
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:59:47
DTC Client socket (77) | Initiating close of socket by core. | 2018-02-26 11:59:47
Rithmic Trading | Disconnected. | 2018-02-26 11:59:47
DTC Client socket (77) | Shutdown started. Waiting for graceful close. | 2018-02-26 11:59:47
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 11:59:47
DTC Client socket (77) | Close event error. Windows error code 10053: De software op uw hostcomputer heeft een verbinding verbroken. | 2018-02-26 12:00:07 *
DTC Client socket (77) | Socket gracefully closed by remote side. | 2018-02-26 12:00:07
DTC Client socket (77) | Closed. | 2018-02-26 12:00:07
The message log has been sent to support. | 2018-02-26 12:00:11 *
HTTPS connection to www.sierrachart.com:443 (79) | Creating socket. Using TLS 1.2. | 2018-02-26 12:00:11
HTTPS connection to www.sierrachart.com:443 (79) | Connecting to IP: 204.15.192.108. | 2018-02-26 12:00:11
Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2018-02-26 12:00:12
HTTPS connection to www.sierrachart.com:443 (79) | Socket gracefully closed by remote side. | 2018-02-26 12:00:17
HTTPS connection to www.sierrachart.com:443 (79) | Received socket Close event. | 2018-02-26 12:00:17
HTTPS connection to www.sierrachart.com:443 (79) | Initiating close of socket by core. | 2018-02-26 12:00:17
HTTPS connection to www.sierrachart.com:443 (79) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-26 12:00:17
HTTPS connection to www.sierrachart.com:443 (79) | Closed. | 2018-02-26 12:00:17
Rithmic Trading | Port for executable: 51883 | 2018-02-26 12:01:47
Listening socket (1596). Port 51883 | Closed. | 2018-02-26 12:01:47
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 12:01:47
Rithmic Trading | Bridge process is running. | 2018-02-26 12:01:49
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51883 | 2018-02-26 12:01:49
DTC Client socket (81) | Creating socket. | 2018-02-26 12:01:49
DTC Client socket (81) | Connecting to IP: 127.0.0.1. | 2018-02-26 12:01:49
Rithmic Trading | Connected to server. | 2018-02-26 12:01:49
Rithmic Trading | Starting socket receive thread. | 2018-02-26 12:01:49
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-02-26 12:01:49
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-02-26 12:01:49
Rithmic Trading | Sending logon request message. | 2018-02-26 12:01:49
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-02-26 12:01:49
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-02-26 12:01:49
Rithmic Trading | Message from server: Connecting to Rithmic 01 Europe server. | 2018-02-26 12:01:49
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2018-02-26 12:01:51
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2018-02-26 12:01:52
Rithmic Trading | Received logon response. | 2018-02-26 12:01:52
Rithmic Trading | Server Name: DTC Bridge. | 2018-02-26 12:01:52
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-02-26 12:01:52
Rithmic Trading | Logon error received from server | 2018-02-26 12:01:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 12:01:52
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 12:01:52
DTC Client socket (81) | Initiating close of socket by core. | 2018-02-26 12:01:52
DTC Client socket (81) | Shutdown started. Waiting for graceful close. | 2018-02-26 12:01:52
Rithmic Trading | Disconnected. | 2018-02-26 12:01:52
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 12:01:52
DTC Client socket (81) | Close event error. Windows error code 10053: De software op uw hostcomputer heeft een verbinding verbroken. | 2018-02-26 12:02:12 *
DTC Client socket (81) | Socket gracefully closed by remote side. | 2018-02-26 12:02:12
DTC Client socket (81) | Closed. | 2018-02-26 12:02:12
Rithmic Trading | Port for executable: 51912 | 2018-02-26 12:03:52
Listening socket (2008). Port 51912 | Closed. | 2018-02-26 12:03:52
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 12:03:52
Rithmic Trading | Bridge process is running. | 2018-02-26 12:03:54
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51912 | 2018-02-26 12:03:54
DTC Client socket (84) | Creating socket. | 2018-02-26 12:03:54
DTC Client socket (84) | Connecting to IP: 127.0.0.1. | 2018-02-26 12:03:54
Rithmic Trading | Connected to server. | 2018-02-26 12:03:54
Rithmic Trading | Starting socket receive thread. | 2018-02-26 12:03:54
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-02-26 12:03:54
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-02-26 12:03:54
Rithmic Trading | Sending logon request message. | 2018-02-26 12:03:54
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-02-26 12:03:54
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-02-26 12:03:54
Rithmic Trading | Message from server: Connecting to Rithmic 01 Europe server. | 2018-02-26 12:03:54
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2018-02-26 12:04:16
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2018-02-26 12:04:17
Rithmic Trading | Received logon response. | 2018-02-26 12:04:17
Rithmic Trading | Server Name: DTC Bridge. | 2018-02-26 12:04:17
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-02-26 12:04:17
Rithmic Trading | Logon error received from server | 2018-02-26 12:04:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 12:04:17
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 12:04:17
DTC Client socket (84) | Initiating close of socket by core. | 2018-02-26 12:04:17
Rithmic Trading | Disconnected. | 2018-02-26 12:04:17
DTC Client socket (84) | Shutdown started. Waiting for graceful close. | 2018-02-26 12:04:17
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 12:04:17
DTC Client socket (84) | Close event error. Windows error code 10053: De software op uw hostcomputer heeft een verbinding verbroken. | 2018-02-26 12:04:37 *
DTC Client socket (84) | Socket gracefully closed by remote side. | 2018-02-26 12:04:37
DTC Client socket (84) | Closed. | 2018-02-26 12:04:37
Rithmic Trading | Port for executable: 51945 | 2018-02-26 12:06:17
Listening socket (2008). Port 51945 | Closed. | 2018-02-26 12:06:17
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 12:06:17
Rithmic Trading | Bridge process is running. | 2018-02-26 12:06:19
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51945 | 2018-02-26 12:06:19
DTC Client socket (88) | Creating socket. | 2018-02-26 12:06:19
DTC Client socket (88) | Connecting to IP: 127.0.0.1. | 2018-02-26 12:06:19
Rithmic Trading | Connected to server. | 2018-02-26 12:06:19
Rithmic Trading | Starting socket receive thread. | 2018-02-26 12:06:19
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-02-26 12:06:19
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-02-26 12:06:19
Rithmic Trading | Sending logon request message. | 2018-02-26 12:06:19
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-02-26 12:06:19
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-02-26 12:06:19
Rithmic Trading | Message from server: Connecting to Rithmic 01 Europe server. | 2018-02-26 12:06:19
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2018-02-26 12:06:21
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2018-02-26 12:06:22
Rithmic Trading | Received logon response. | 2018-02-26 12:06:22
Rithmic Trading | Server Name: DTC Bridge. | 2018-02-26 12:06:22
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-02-26 12:06:22
Rithmic Trading | Logon error received from server | 2018-02-26 12:06:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 12:06:22
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 12:06:22
DTC Client socket (88) | Initiating close of socket by core. | 2018-02-26 12:06:23
Rithmic Trading | Disconnected. | 2018-02-26 12:06:23
DTC Client socket (88) | Shutdown started. Waiting for graceful close. | 2018-02-26 12:06:23
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 12:06:23
DTC Client socket (88) | Close event error. Windows error code 10053: De software op uw hostcomputer heeft een verbinding verbroken. | 2018-02-26 12:06:42 *
DTC Client socket (88) | Socket gracefully closed by remote side. | 2018-02-26 12:06:42
DTC Client socket (88) | Closed. | 2018-02-26 12:06:42
Rithmic Trading | Port for executable: 51963 | 2018-02-26 12:08:23
Listening socket (1228). Port 51963 | Closed. | 2018-02-26 12:08:23
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-02-26 12:08:23
Rithmic Trading | Bridge process is running. | 2018-02-26 12:08:25
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51963 | 2018-02-26 12:08:25
DTC Client socket (91) | Creating socket. | 2018-02-26 12:08:25
DTC Client socket (91) | Connecting to IP: 127.0.0.1. | 2018-02-26 12:08:25
Rithmic Trading | Connected to server. | 2018-02-26 12:08:25
Rithmic Trading | Starting socket receive thread. | 2018-02-26 12:08:25
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-02-26 12:08:25
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-02-26 12:08:25
Rithmic Trading | Sending logon request message. | 2018-02-26 12:08:25
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-02-26 12:08:25
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-02-26 12:08:25
Rithmic Trading | Message from server: Connecting to Rithmic 01 Europe server. | 2018-02-26 12:08:25
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2018-02-26 12:08:26
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2018-02-26 12:08:48
Rithmic Trading | Received logon response. | 2018-02-26 12:08:48
Rithmic Trading | Server Name: DTC Bridge. | 2018-02-26 12:08:48
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-02-26 12:08:48
Rithmic Trading | Logon error received from server | 2018-02-26 12:08:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-26 12:08:48
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 12:08:48
DTC Client socket (91) | Initiating close of socket by core. | 2018-02-26 12:08:48
Rithmic Trading | Disconnected. | 2018-02-26 12:08:48
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-26 12:08:48
DTC Client socket (91) | Shutdown started. Waiting for graceful close. | 2018-02-26 12:08:48
DTC Client socket (91) | Close event error. Windows error code 10053: De software op uw hostcomputer heeft een verbinding verbroken. | 2018-02-26 12:09:08 *
DTC Client socket (91) | Socket gracefully closed by remote side. | 2018-02-26 12:09:08
DTC Client socket (91) | Closed. | 2018-02-26 12:09:08
IP: 217.102.135.27 (Netherlands)
Date Time Of Last Edit: 2018-02-26 18:21:49
[2018-02-26 18:25:09]
This is the problem:
We cannot know if it is a server problem or a connectivity problem from your side.
We recommend using a different Server other than the Europe server.
There are many choices. Select Global Settings >> Data/Trade Service Settings. Change the server through Service Setting >> Server.
