Date/Time: Tue, 04 Nov 2025 10:02:02 +0000
DETACHING WINDOWS AND ALWAYS ON TOP.
View Count: 2444
|   [2018-02-21 20:43:03]     |
| User725605 - Posts: 60 |
                I do not prefer the way the charts fit into the chart FRAME on my four monitors. I would “prefer” my charts to take up the entire monitor space avoiding the wasted WHITE space above and below. To attempt solving this issue I have referenced the Detaching and Attaching Chart Windows section of your support documents. I detached an individual chart successfully from my main window by following – Window>> Detach /Attach Window. I then dragged it to the monitor of my choice. I sized it to ‘maximum’ as I desire. When I clicked on my main window my re-sized to “maximum” chart disappeared. I then followed the instruction to Window>>Chart Window Always Visible in the hope that this would – lock my newly sized chart in place. To my dismay, it immediately ‘downsized’ this chart inside the white space again. This was not what I wanted. Then I went to the Setting Detached Chart to Be Always on Top. I attempted to follow your instruction Window>> Always on Top only to see that it is NOT executable - it is faded out. If this option WAS executable, would I achieve my desired chart layout? Is there another way to achieve my desired result as I have explained it?  |
|   [2018-02-21 20:56:22]     |
                 When I clicked on my main window my re-sized to “maximum” chart disappeared.  This does not make sense. Do you know why this would be the case? From our perspective this is hard to understand because we cannot see exactly what you are doing and the behavior.It might be related to this option: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html&CAID=def#BringDetachedWindowsToTopOnMainWindowFocus Make sure that is disabled.  I then followed the instruction to Window>>Chart Window Always Visible in the hope that this would – lock my newly sized chart in place. To my dismay, it immediately ‘downsized’ this chart inside the white space again. This was not what I wanted.  Once again, this makes no sense. No sense whatsoever. Changing that setting is going to have no  immediate effect. It only keeps the chart visible, when switching to a different chart book. I attempted to follow your instruction Window>> Always on Top only to see that it is NOT executable - it is faded out.  You need to use this command on the detached chart itself. Not from the main window.
                Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
