Date/Time: Sat, 06 Jun 2026 21:36:13 +0000
CQG disconnects and reconnects frequently
View Count: 1032
| [2018-02-13 15:48:23] |
| User925794 - Posts: 28 |
Good morning, after troubleshooting with AMP, they directed me to SC support. This problem started Sunday night, but was infrequent. By Monday, the disconnect/reconnect was happening every couple of hours. This morning, the connection is lost every 10 seconds. I tried loading release 1684, same problem persisted. Now on 1700 with no change. My network and computer have been rebooted twice. All anti-virus and firewall has been disabled. There's no web based streaming content or speed problems. Nothing in Windows event logs alarming network adapter issues. Suggestions? |
| [2018-02-13 18:29:24] |
When you have the problem again, provide a copy of the Message Log following these instructions here: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2018-02-13 19:30:21] |
Here's the log. Please note: I shut down SC until I heard back from you. Then launched SC and waited for some logs to build. The disconnect/reconnect "bounce" occurred 4-5 more times and 'all of a sudden', it has remained connected for about 30 minutes without incident. That being said, I'd still like to know what happened due to the hazardous nature of this kind of communication error. Thanks guys, I still love your platform best of all! Reading Internal Order ID file. | 2018-02-13 12:43:34 Reading Trade Orders file. | 2018-02-13 12:43:34 Reading Trade Positions file. | 2018-02-13 12:43:34 Listening on UDP port 22903. | 2018-02-13 12:43:34 Software version: 1700 | 2018-02-13 12:43:34 Enabled for: Advanced Features. | 2018-02-13 12:43:34 Enabled for: Sierra Chart Historical Data Service. | 2018-02-13 12:43:34 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-02-13 12:43:34 Current selected Data/Trading service: CQG FIX Trading | 2018-02-13 12:43:34 Chart Update Interval: 500 | 2018-02-13 12:43:34 Data/Trade Service Settings automatically set. | 2018-02-13 12:43:34 Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-02-13 12:43:34 2018-02-13 12:43:34 Local computer time | 2018-02-13 12:43:34 2018-02-13 18:43:34 Local computer time in UTC | 2018-02-13 12:43:34 2018-02-13 12:43:34 Local computer time in SC Time Zone | 2018-02-13 12:43:34 2018-02-13 18:43:33 Server time in UTC | 2018-02-13 12:43:34 Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-02-13 12:43:34 Program path: C:\SierraChartAMPMe\ | 2018-02-13 12:43:34 Data Files path: C:\SierraChartAMPMe\Data\ | 2018-02-13 12:43:34 OS Version Number: 6.1 | 2018-02-13 12:43:34 Locale Setting: C | 2018-02-13 12:43:34 Checking for new symbol settings for service code cqg | 2018-02-13 12:43:34 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-02-13 12:43:34 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-02-13 12:43:34 Symbol settings are up-to-date for cqg | 2018-02-13 12:43:35 Received 5 login tokens. | 2018-02-13 12:43:35 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-02-13 12:43:36 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-02-13 12:43:36 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-02-13 12:43:40 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-02-13 12:43:40 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-02-13 12:43:40 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-13 12:43:40 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-02-13 12:43:40 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-02-13 12:43:40 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-02-13 12:43:40 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-02-13 12:43:40 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-13 12:43:40 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-02-13 12:43:40 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-02-13 12:43:42 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2018-02-13 12:43:42 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-02-13 12:43:42 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-13 12:43:42 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-02-13 12:43:42 Files to Open on Start up | Opening file: YM v8.cht | 2018-02-13 12:43:43 F.US.YMH18 [CBV] 1 Min #4 | Reloading chart. | 2018-02-13 12:43:43 F.US.YMH18 #5 | Reloading chart. | 2018-02-13 12:43:43 F.US.YMH18 [CB] 1380 Min #2 | Reloading chart. | 2018-02-13 12:43:43 F.US.YMH18 [CB] 450 Min #6 | Reloading chart. | 2018-02-13 12:43:43 F.US.YMH18 [CBV] 4 Range #7 | Reloading chart. | 2018-02-13 12:43:43 Files to Open on Start up | Opening file: Emini Russ RTY v8.cht | 2018-02-13 12:43:43 F.US.RTYH18 [CBV] 1 Min #4 | Reloading chart. | 2018-02-13 12:43:43 F.US.RTYH18 #5 | Reloading chart. | 2018-02-13 12:43:43 F.US.RTYH18 [CB] 1380 Min #2 | Reloading chart. | 2018-02-13 12:43:43 F.US.RTYH18 [CB] 450 Min #6 | Reloading chart. | 2018-02-13 12:43:43 F.US.RTYH18 [CBV] 0.4 Range #7 | Reloading chart. | 2018-02-13 12:43:44 Files to Open on Start up | Opening file: Crude v9.cht | 2018-02-13 12:43:44 F.US.CLEH18 [CBV] 1 Min #4 | Reloading chart. | 2018-02-13 12:43:44 F.US.CLEH18 #5 | Reloading chart. | 2018-02-13 12:43:44 F.US.CLEH18 [CBV] 1380 Min #2 | Reloading chart. | 2018-02-13 12:43:44 F.US.CLEH18 [CBV] 540 Min #6 | Reloading chart. | 2018-02-13 12:43:45 F.US.CLEH18 0.02 Range #7 | Reloading chart. | 2018-02-13 12:43:45 F.US.CLEH18 [CBV] 1 Min #1 | Reloading chart. | 2018-02-13 12:43:46 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:10 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:10 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:10 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:10 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:44:20 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:44:20 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:44:20 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:44:20 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:44:20 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:44:20 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:20 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:20 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:20 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:20 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:44:24 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:44:24 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:44:24 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:44:24 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:44:25 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:44:25 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:44:26 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:44:26 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:44:26 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:44:26 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:44:26 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:44:26 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:44:26 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:44:26 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 12:44:26 F.US.YMH18 #5 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:44:26 HD Request # 2 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 12:44:26 HD Request # 2 | Download start date-time: 2018-02-13 12:33:32.000 | 2018-02-13 12:44:26 HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 12:44:26 Socket (6) | Creating socket. | 2018-02-13 12:44:26 Socket (6) | Connecting to IP: 192.81.56.146. | 2018-02-13 12:44:26 F.US.YMH18 [CBV] 1 Min #4 | Reloading chart. | 2018-02-13 12:44:26 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 12:44:26 F.US.YMH18 [CBV] 4 Range #7 | Reloading chart. | 2018-02-13 12:44:26 F.US.RTYH18 [CBV] 1 Min #4 | Reloading chart. | 2018-02-13 12:44:26 F.US.RTYH18 [CBV] 0.4 Range #7 | Reloading chart. | 2018-02-13 12:44:26 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 12:44:26 HD Request # 2 | Setting DTC encoding to Binary VLS | 2018-02-13 12:44:26 HD Request # 2 | Sending historical data logon request message. | 2018-02-13 12:44:26 F.US.CLEH18 [CBV] 1 Min #4 | Reloading chart. | 2018-02-13 12:44:26 HD Request # 2 | Requesting Intraday data. Start date-time: 2018-02-13 12:33:32. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 12:44:26 Socket (6) | Initiating close of socket by core. | 2018-02-13 12:44:26 Socket (6) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:44:26 HD Request # 2 | Historical data for F.US.YMH18 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-02-13 12:44:26 Historical data download thread signaled to stop. | 2018-02-13 12:44:26 HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.YMH18 | 2018-02-13 12:44:26 HD Request # 2 | Completion time: 0s | 2018-02-13 12:44:26 HD Request # 2 | Intraday data download complete for F.US.YMH18. Unique request ID: 1 | 2018-02-13 12:44:26 Removed historical data download ID 1 | 2018-02-13 12:44:26 HD Request # 3 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 12:44:26 HD Request # 3 | Download start date-time: 2018-02-13 12:33:32.000 | 2018-02-13 12:44:26 HD Request # 3 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 12:44:26 Socket (7) | Creating socket. | 2018-02-13 12:44:26 Socket (7) | Connecting to IP: 65.182.172.42. | 2018-02-13 12:44:26 Socket (6) | Socket gracefully closed by remote side. | 2018-02-13 12:44:26 Socket (6) | Closed. | 2018-02-13 12:44:26 F.US.CLEH18 [CBV] 1380 Min #2 | Reloading chart. | 2018-02-13 12:44:26 HD Request # 3 | Setting DTC encoding to Binary VLS | 2018-02-13 12:44:26 HD Request # 3 | Sending historical data logon request message. | 2018-02-13 12:44:26 HD Request # 3 | Requesting Intraday data. Start date-time: 2018-02-13 12:33:32. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 12:44:26 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:44:26 Socket (7) | Initiating close of socket by core. | 2018-02-13 12:44:26 Socket (7) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:44:26 Socket (7) | Socket gracefully closed by remote side. | 2018-02-13 12:44:26 Socket (7) | Closed. | 2018-02-13 12:44:26 HD Request # 3 | Historical data for F.US.RTYH18 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-02-13 12:44:27 Historical data download thread signaled to stop. | 2018-02-13 12:44:27 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.RTYH18 | 2018-02-13 12:44:27 HD Request # 3 | Completion time: 1s | 2018-02-13 12:44:27 HD Request # 3 | Intraday data download complete for F.US.RTYH18. Unique request ID: 2 | 2018-02-13 12:44:27 Removed historical data download ID 2 | 2018-02-13 12:44:27 HD Request # 4 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 12:44:27 HD Request # 4 | Download start date-time: 2018-02-13 12:33:32.000 | 2018-02-13 12:44:27 HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 12:44:27 Socket (8) | Creating socket. | 2018-02-13 12:44:27 Socket (8) | Connecting to IP: 192.81.56.146. | 2018-02-13 12:44:27 F.US.CLEH18 [CBV] 1 Min #1 | Reloading chart. | 2018-02-13 12:44:27 HD Request # 4 | Setting DTC encoding to Binary VLS | 2018-02-13 12:44:27 HD Request # 4 | Sending historical data logon request message. | 2018-02-13 12:44:27 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 12:44:27 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:44:27 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:44:27 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:44:27 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:27 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:27 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:27 HD Request # 4 | Requesting Intraday data. Start date-time: 2018-02-13 12:33:32. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 12:44:27 CQG FIX socket (9) | Creating socket. Using TLS 1.2. | 2018-02-13 12:44:27 CQG FIX socket (9) | Connecting to IP: 208.48.16.214. | 2018-02-13 12:44:27 Socket (8) | Initiating close of socket by core. | 2018-02-13 12:44:27 HD Request # 4 | Historical data for F.US.CLEH18 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-02-13 12:44:27 Socket (8) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:44:27 Historical data download thread signaled to stop. | 2018-02-13 12:44:27 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.CLEH18 | 2018-02-13 12:44:27 HD Request # 4 | Completion time: 0s | 2018-02-13 12:44:27 HD Request # 4 | Intraday data download complete for F.US.CLEH18. Unique request ID: 3 | 2018-02-13 12:44:27 Removed historical data download ID 3 | 2018-02-13 12:44:27 Socket (8) | Socket gracefully closed by remote side. | 2018-02-13 12:44:27 Socket (8) | Closed. | 2018-02-13 12:44:27 CQG FIX: Sending the Logon message. | 2018-02-13 12:44:27 CQG FIX Trading | Connected to trading server. | 2018-02-13 12:44:27 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 12:44:27 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 12:44:27 CQG FIX | FCM name: AMP | 2018-02-13 12:44:27 CQG WebSocket socket (10) | Creating socket. Using TLS 1.2. | 2018-02-13 12:44:27 CQG WebSocket socket (10) | Connecting to IP: 208.48.16.35. | 2018-02-13 12:44:27 CQG WebSocket | Opening WebSocket. | 2018-02-13 12:44:27 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 12:44:27 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 12:44:28 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 12:44:28 CQG WebSocket | Header line. Sec-WebSocket-Accept: RBDzo3zt96RJfuJM1JQo3tVEMFs= | 2018-02-13 12:44:28 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 12:44:28 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 12:44:28 CQG WebSocket | Header line. | 2018-02-13 12:44:28 CQG WebSocket | Web socket state is now open. | 2018-02-13 12:44:28 CQG FIX Trading | WebSocket connected. | 2018-02-13 12:44:28 CQG FIX Trading | Sending market data logon message. | 2018-02-13 12:44:28 CQG FIX Trading | Logon successful. Session Token = ZJcf2E1k2BYWIr+agycMWa8YtMTeDGLoTUKsS6Ic8p8tKkc3TD8bc4S4jIiq+MHJC/QVAyNbyw9 | 2018-02-13 12:44:28 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 12:44:28 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 1 | 2018-02-13 12:44:28 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 701470 | 2018-02-13 12:44:28 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 1 | 2018-02-13 12:44:28 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 12:44:28 Delaying start of download for F.US.YMH18 | 2018-02-13 12:44:28 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 2 | 2018-02-13 12:44:28 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 701471 | 2018-02-13 12:44:28 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 2 | 2018-02-13 12:44:28 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 12:44:28 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 4 | 2018-02-13 12:44:28 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 701472 | 2018-02-13 12:44:28 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 4 | 2018-02-13 12:44:28 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 3 | 2018-02-13 12:44:28 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 701473 | 2018-02-13 12:44:28 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 3 | 2018-02-13 12:44:28 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 12:44:28 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:31 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:31 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:31 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 701470. Contract ID: 1. | 2018-02-13 12:44:31 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 12:44:31 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 701471. Contract ID: 2. | 2018-02-13 12:44:31 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 12:44:31 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 701472. Contract ID: 3. | 2018-02-13 12:44:31 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 12:44:31 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 701473. Contract ID: 4. | 2018-02-13 12:44:31 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 12:44:31 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:36 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:36 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:44:36 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:45:00 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:45:00 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:45:00 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:45:07 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:45:07 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:45:07 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:45:07 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:45:07 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:45:07 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:13 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:13 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:13 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:13 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:13 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:13 CQG FIX: Received a Logout message. Text = RcvTestRequestHeartbeatTimerExpired | 2018-02-13 12:45:13 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-02-13 12:45:13 CQG FIX socket (9) | Adding bytes from final send buffer from buffered socket: 112 | 2018-02-13 12:45:13 CQG FIX socket (9) | Initiating close of socket by core. | 2018-02-13 12:45:13 CQG FIX: Disconnected. | 2018-02-13 12:45:13 CQG FIX socket (9) | Write in progress. Shutdown being delayed. | 2018-02-13 12:45:13 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:13 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:13 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:13 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:13 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:13 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:13 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:13 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:13 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:13 CQG FIX socket (9) | Sending bytes from final send buffer: 112 | 2018-02-13 12:45:13 CQG FIX socket (9) | Write has completed. Shutdown being performed. | 2018-02-13 12:45:14 CQG FIX socket (9) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:45:14 CQG FIX socket (9) | Socket gracefully closed by remote side. | 2018-02-13 12:45:14 CQG FIX socket (9) | Closed. | 2018-02-13 12:45:14 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:45:14 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:45:15 Circular chart reference detected. Charts: 4, 7. Chartbook: Emini Russ RTY v8.cht. | 2018-02-13 12:45:17 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:45:17 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:22 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:22 F.US.YMH18 #5 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:45:22 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 5 | 2018-02-13 12:45:22 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 701474 | 2018-02-13 12:45:22 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 5 | 2018-02-13 12:45:22 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 7 | 2018-02-13 12:45:22 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 701475 | 2018-02-13 12:45:22 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 7 | 2018-02-13 12:45:22 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 6 | 2018-02-13 12:45:22 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 701476 | 2018-02-13 12:45:22 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 6 | 2018-02-13 12:45:22 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 8 | 2018-02-13 12:45:22 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 701477 | 2018-02-13 12:45:22 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 8 | 2018-02-13 12:45:22 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 9 | 2018-02-13 12:45:22 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 701478 | 2018-02-13 12:45:22 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 9 | 2018-02-13 12:45:22 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 10 | 2018-02-13 12:45:22 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 701479 | 2018-02-13 12:45:22 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 10 | 2018-02-13 12:45:22 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 11 | 2018-02-13 12:45:22 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 701480 | 2018-02-13 12:45:22 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 11 | 2018-02-13 12:45:22 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:45:22 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 701474. Contract ID: 5. | 2018-02-13 12:45:25 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 12:45:25 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 701475. Contract ID: 6. | 2018-02-13 12:45:25 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 12:45:25 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 701476. Contract ID: 7. | 2018-02-13 12:45:25 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 12:45:25 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 701477. Contract ID: 8. | 2018-02-13 12:45:25 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 12:45:25 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 701478. Contract ID: 9. | 2018-02-13 12:45:25 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 12:45:25 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 701479. Contract ID: 10. | 2018-02-13 12:45:25 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 12:45:25 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 701480. Contract ID: 11. | 2018-02-13 12:45:25 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 12:45:25 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:45:25 Circular chart reference detected. Charts: 4, 7. Chartbook: YM v8.cht. | 2018-02-13 12:45:50 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 12 | 2018-02-13 12:45:50 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 701481 | 2018-02-13 12:45:50 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 12 | 2018-02-13 12:45:50 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 13 | 2018-02-13 12:45:50 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 701482 | 2018-02-13 12:45:50 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 13 | 2018-02-13 12:45:50 HD Request # 5 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 12:45:50 HD Request # 5 | Download start date-time: 2018-02-13 12:33:32.000 | 2018-02-13 12:45:50 HD Request # 5 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 12:45:50 Socket (11) | Creating socket. | 2018-02-13 12:45:50 Socket (11) | Connecting to IP: 65.182.172.42. | 2018-02-13 12:45:50 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 12:45:50 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 12:45:50 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 12:45:50 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 12:45:50 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 12:45:50 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 12:45:50 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 12:45:50 CQG WebSocket socket (10) | Adding bytes from final send buffer from buffered socket: 110 | 2018-02-13 12:45:50 CQG WebSocket socket (10) | Initiating close of socket by core. | 2018-02-13 12:45:50 CQG WebSocket | WebSocket closed. | 2018-02-13 12:45:50 CQG FIX Trading | WebSocket closed. | 2018-02-13 12:45:50 Connection to the external service has been lost. | 2018-02-13 12:45:50 CQG WebSocket socket (10) | Write in progress. Shutdown being delayed. | 2018-02-13 12:45:50 CQG WebSocket socket (10) | Sending bytes from final send buffer: 110 | 2018-02-13 12:45:50 CQG WebSocket socket (10) | Write has completed. Shutdown being performed. | 2018-02-13 12:45:50 CQG WebSocket socket (10) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:45:50 CQG WebSocket socket (10) | Socket gracefully closed by remote side. | 2018-02-13 12:45:50 CQG WebSocket socket (10) | Closed. | 2018-02-13 12:45:50 HD Request # 5 | Setting DTC encoding to Binary VLS | 2018-02-13 12:45:50 HD Request # 5 | Sending historical data logon request message. | 2018-02-13 12:45:50 HD Request # 5 | Requesting Intraday data. Start date-time: 2018-02-13 12:33:32. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 12:45:50 HD Request # 5 | Decompressing data. | 2018-02-13 12:45:50 HD Request # 5 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 12:33:32 | 2018-02-13 12:45:50 HD Request # 5 | Timestamp of first Intraday data file record written: 2018-02-13 12:33:33 | 2018-02-13 12:45:50 Socket (11) | Initiating close of socket by core. | 2018-02-13 12:45:50 Socket (11) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:45:50 Socket (11) | Socket gracefully closed by remote side. | 2018-02-13 12:45:50 Socket (11) | Closed. | 2018-02-13 12:45:50 Historical data download thread signaled to stop. | 2018-02-13 12:45:52 HD Request # 5 | Received 3461 records from 2018-02-13 12:33:32 to 2018-02-13 12:45:47 (12.3 minutes) and wrote 3459 records for F.US.YMH18 | 2018-02-13 12:45:52 HD Request # 5 | Completion time: 3s | 2018-02-13 12:45:52 HD Request # 5 | Intraday data download complete for F.US.YMH18. Unique request ID: 4 | 2018-02-13 12:45:52 Removed historical data download ID 4 | 2018-02-13 12:45:52 HD Request # 6 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 12:45:52 HD Request # 6 | Download start date-time: 2018-02-13 12:33:32.000 | 2018-02-13 12:45:52 HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 12:45:52 Socket (13) | Creating socket. | 2018-02-13 12:45:52 Socket (13) | Connecting to IP: 192.81.56.146. | 2018-02-13 12:45:52 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:45:52 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:45:52 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:45:52 HD Request # 6 | Setting DTC encoding to Binary VLS | 2018-02-13 12:45:52 HD Request # 6 | Sending historical data logon request message. | 2018-02-13 12:45:52 HD Request # 6 | Requesting Intraday data. Start date-time: 2018-02-13 12:33:32. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 12:45:52 Socket (13) | Initiating close of socket by core. | 2018-02-13 12:45:52 Socket (13) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:45:52 Socket (13) | Socket gracefully closed by remote side. | 2018-02-13 12:45:52 Socket (13) | Closed. | 2018-02-13 12:45:52 HD Request # 6 | Historical data for F.US.RTYH18 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-02-13 12:45:53 Historical data download thread signaled to stop. | 2018-02-13 12:45:53 HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.RTYH18 | 2018-02-13 12:45:53 HD Request # 6 | Completion time: 0s | 2018-02-13 12:45:53 HD Request # 6 | Intraday data download complete for F.US.RTYH18. Unique request ID: 5 | 2018-02-13 12:45:53 Removed historical data download ID 5 | 2018-02-13 12:45:53 HD Request # 7 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 12:45:53 HD Request # 7 | Download start date-time: 2018-02-13 12:33:32.000 | 2018-02-13 12:45:53 HD Request # 7 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 12:45:53 Socket (14) | Creating socket. | 2018-02-13 12:45:53 Socket (14) | Connecting to IP: 65.182.172.42. | 2018-02-13 12:45:53 HD Request # 7 | Setting DTC encoding to Binary VLS | 2018-02-13 12:45:53 HD Request # 7 | Sending historical data logon request message. | 2018-02-13 12:45:53 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:45:53 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:45:53 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:45:53 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:45:53 HD Request # 7 | Requesting Intraday data. Start date-time: 2018-02-13 12:33:32. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 12:45:53 Socket (14) | Initiating close of socket by core. | 2018-02-13 12:45:53 Socket (14) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:45:53 Socket (14) | Socket gracefully closed by remote side. | 2018-02-13 12:45:53 Socket (14) | Closed. | 2018-02-13 12:45:53 HD Request # 7 | Historical data for F.US.CLEH18 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-02-13 12:45:53 Historical data download thread signaled to stop. | 2018-02-13 12:45:53 HD Request # 7 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.CLEH18 | 2018-02-13 12:45:53 HD Request # 7 | Completion time: 0s | 2018-02-13 12:45:53 HD Request # 7 | Intraday data download complete for F.US.CLEH18. Unique request ID: 6 | 2018-02-13 12:45:53 Removed historical data download ID 6 | 2018-02-13 12:45:53 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:45:54 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:45:56 Circular chart reference detected. Charts: 4, 7. Chartbook: Emini Russ RTY v8.cht. | 2018-02-13 12:45:56 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:57 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:57 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:57 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:57 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:45:57 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:45:57 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:45:59 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:46:06 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:46:06 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:46:06 Circular chart reference detected. Charts: 7, 4. Chartbook: YM v8.cht. | 2018-02-13 12:46:06 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:46:06 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:46:29 Circular chart reference detected. Charts: 4, 7. Chartbook: YM v8.cht. | 2018-02-13 12:46:29 CQG FIX Trading | Disconnected. | 2018-02-13 12:46:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 12:46:30 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:46:30 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:46:34 Circular chart reference detected. Charts: 7, 4. Chartbook: Emini Russ RTY v8.cht. | 2018-02-13 12:46:34 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:46:34 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:46:35 Circular chart reference detected. Charts: 4, 7. Chartbook: Emini Russ RTY v8.cht. | 2018-02-13 12:46:37 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:46:37 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:46:42 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:46:42 F.US.YMH18 #5 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:46:42 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:46:42 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:46:43 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:46:50 Circular chart reference detected. Charts: 7, 4. Chartbook: YM v8.cht. | 2018-02-13 12:46:50 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 12:46:52 CQG FIX socket (15) | Creating socket. Using TLS 1.2. | 2018-02-13 12:46:52 CQG FIX socket (15) | Connecting to IP: 208.48.16.214. | 2018-02-13 12:46:52 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:46:52 F.US.YMH18 #5 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:46:53 CQG FIX: Sending the Logon message. | 2018-02-13 12:46:55 CQG FIX Trading | Connected to trading server. | 2018-02-13 12:46:56 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 12:46:56 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 12:46:56 CQG WebSocket socket (17) | Creating socket. Using TLS 1.2. | 2018-02-13 12:46:56 CQG WebSocket socket (17) | Connecting to IP: 208.48.16.35. | 2018-02-13 12:46:56 CQG WebSocket | Opening WebSocket. | 2018-02-13 12:46:56 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 12:46:56 CQG FIX | FCM name: AMP | 2018-02-13 12:46:56 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 12:46:56 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 12:46:56 CQG WebSocket | Header line. Sec-WebSocket-Accept: 3kcAS74WK2wAq1zvEWZGbahKnws= | 2018-02-13 12:46:56 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 12:46:56 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 12:46:56 CQG WebSocket | Header line. | 2018-02-13 12:46:56 CQG WebSocket | Web socket state is now open. | 2018-02-13 12:46:56 CQG FIX Trading | WebSocket connected. | 2018-02-13 12:46:56 CQG FIX Trading | Sending market data logon message. | 2018-02-13 12:46:56 CQG FIX Trading | Logon successful. Session Token = LlIwNuskN/FgUPizB+GmMQkIH/9lS+A0ZyBG7e59h9oDGwfv2FWvcEZX9WGaNlePrKIdQxIlYCk | 2018-02-13 12:46:57 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 12:47:00 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 1 | 2018-02-13 12:47:00 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 701483 | 2018-02-13 12:47:00 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 1 | 2018-02-13 12:47:00 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 12:47:00 Delaying start of download for F.US.YMH18 | 2018-02-13 12:47:00 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 2 | 2018-02-13 12:47:00 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 701484 | 2018-02-13 12:47:00 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 2 | 2018-02-13 12:47:00 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 12:47:00 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 701483. Contract ID: 1. | 2018-02-13 12:47:00 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 12:47:00 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 701484. Contract ID: 2. | 2018-02-13 12:47:00 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 12:47:00 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 3 | 2018-02-13 12:47:00 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 701485 | 2018-02-13 12:47:00 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 3 | 2018-02-13 12:47:00 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 4 | 2018-02-13 12:47:00 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 701486 | 2018-02-13 12:47:00 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 4 | 2018-02-13 12:47:00 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 5 | 2018-02-13 12:47:00 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 701487 | 2018-02-13 12:47:00 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 5 | 2018-02-13 12:47:00 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 6 | 2018-02-13 12:47:00 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 701488 | 2018-02-13 12:47:00 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 6 | 2018-02-13 12:47:00 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 7 | 2018-02-13 12:47:00 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 701489 | 2018-02-13 12:47:00 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 7 | 2018-02-13 12:47:00 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 8 | 2018-02-13 12:47:00 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 701490 | 2018-02-13 12:47:00 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 8 | 2018-02-13 12:47:00 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 10 | 2018-02-13 12:47:00 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 701491 | 2018-02-13 12:47:00 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 10 | 2018-02-13 12:47:00 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 9 | 2018-02-13 12:47:00 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 701492 | 2018-02-13 12:47:00 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 9 | 2018-02-13 12:47:00 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 12:47:00 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 701485. Contract ID: 3. | 2018-02-13 12:47:01 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 12:47:01 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 701486. Contract ID: 4. | 2018-02-13 12:47:01 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 12:47:01 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 701487. Contract ID: 5. | 2018-02-13 12:47:01 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 12:47:01 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 701488. Contract ID: 6. | 2018-02-13 12:47:01 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 12:47:01 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 701489. Contract ID: 7. | 2018-02-13 12:47:01 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 12:47:01 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 701490. Contract ID: 8. | 2018-02-13 12:47:01 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 12:47:01 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 701491. Contract ID: 9. | 2018-02-13 12:47:01 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 12:47:01 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 701492. Contract ID: 10. | 2018-02-13 12:47:01 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 12:47:01 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 11 | 2018-02-13 12:47:03 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 701493 | 2018-02-13 12:47:03 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 11 | 2018-02-13 12:47:03 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 13 | 2018-02-13 12:47:03 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 701494 | 2018-02-13 12:47:03 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 13 | 2018-02-13 12:47:03 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 12 | 2018-02-13 12:47:03 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 701495 | 2018-02-13 12:47:03 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 12 | 2018-02-13 12:47:03 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 701493. Contract ID: 11. | 2018-02-13 12:47:03 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 12:47:03 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 701494. Contract ID: 12. | 2018-02-13 12:47:03 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 12:47:03 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 701495. Contract ID: 13. | 2018-02-13 12:47:03 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 12:47:03 Delaying start of download for F.US.YMH18 | 2018-02-13 12:47:04 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 12:47:09 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 12:47:09 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 12:47:09 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 12:47:09 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 12:47:09 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 12:47:09 HD Request # 8 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 12:47:09 HD Request # 8 | Download start date-time: 2018-02-13 12:45:47.000 | 2018-02-13 12:47:09 HD Request # 8 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 12:47:09 Socket (18) | Creating socket. | 2018-02-13 12:47:09 Socket (18) | Connecting to IP: 192.81.56.146. | 2018-02-13 12:47:09 HD Request # 8 | Setting DTC encoding to Binary VLS | 2018-02-13 12:47:09 HD Request # 8 | Sending historical data logon request message. | 2018-02-13 12:47:09 HD Request # 8 | Requesting Intraday data. Start date-time: 2018-02-13 12:45:47. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 12:47:09 HD Request # 8 | Decompressing data. | 2018-02-13 12:47:10 HD Request # 8 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 12:45:47 | 2018-02-13 12:47:10 HD Request # 8 | Timestamp of first Intraday data file record written: 2018-02-13 12:45:48 | 2018-02-13 12:47:10 Socket (18) | Initiating close of socket by core. | 2018-02-13 12:47:10 Socket (18) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:47:10 Socket (18) | Socket gracefully closed by remote side. | 2018-02-13 12:47:10 Socket (18) | Closed. | 2018-02-13 12:47:10 Historical data download thread signaled to stop. | 2018-02-13 12:47:10 HD Request # 8 | Received 275 records from 2018-02-13 12:45:47 to 2018-02-13 12:47:07 (80.0 seconds) and wrote 271 records for F.US.YMH18 | 2018-02-13 12:47:10 Added 6 Time and Sales records to Intraday data file for F.US.YMH18 after download. | 2018-02-13 12:47:10 HD Request # 8 | Completion time: 1s | 2018-02-13 12:47:10 HD Request # 8 | Intraday data download complete for F.US.YMH18. Unique request ID: 7 | 2018-02-13 12:47:10 Removed historical data download ID 7 | 2018-02-13 12:47:10 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 12:47:10 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 12:47:10 HD Request # 9 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 12:47:10 HD Request # 9 | Download start date-time: 2018-02-13 12:33:32.000 | 2018-02-13 12:47:10 HD Request # 9 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 12:47:10 Socket (19) | Creating socket. | 2018-02-13 12:47:10 Socket (19) | Connecting to IP: 65.182.172.42. | 2018-02-13 12:47:10 HD Request # 9 | Setting DTC encoding to Binary VLS | 2018-02-13 12:47:10 HD Request # 9 | Sending historical data logon request message. | 2018-02-13 12:47:10 HD Request # 9 | Requesting Intraday data. Start date-time: 2018-02-13 12:33:32. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 12:47:10 HD Request # 9 | Decompressing data. | 2018-02-13 12:47:11 HD Request # 9 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 12:33:32 | 2018-02-13 12:47:11 HD Request # 9 | Timestamp of first Intraday data file record written: 2018-02-13 12:33:32 | 2018-02-13 12:47:11 Socket (19) | Initiating close of socket by core. | 2018-02-13 12:47:11 Socket (19) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:47:11 Socket (19) | Socket gracefully closed by remote side. | 2018-02-13 12:47:11 Socket (19) | Closed. | 2018-02-13 12:47:11 Historical data download thread signaled to stop. | 2018-02-13 12:47:11 HD Request # 9 | Received 1647 records from 2018-02-13 12:33:32 to 2018-02-13 12:47:08 (13.6 minutes) and wrote 1646 records for F.US.RTYH18 | 2018-02-13 12:47:11 HD Request # 9 | Completion time: 0s | 2018-02-13 12:47:11 HD Request # 9 | Intraday data download complete for F.US.RTYH18. Unique request ID: 8 | 2018-02-13 12:47:11 Removed historical data download ID 8 | 2018-02-13 12:47:11 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 12:47:11 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 12:47:11 HD Request # 10 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 12:47:11 HD Request # 10 | Download start date-time: 2018-02-13 12:33:32.000 | 2018-02-13 12:47:11 HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 12:47:11 Socket (20) | Creating socket. | 2018-02-13 12:47:11 Socket (20) | Connecting to IP: 192.81.56.146. | 2018-02-13 12:47:11 HD Request # 10 | Setting DTC encoding to Binary VLS | 2018-02-13 12:47:11 HD Request # 10 | Sending historical data logon request message. | 2018-02-13 12:47:11 HD Request # 10 | Requesting Intraday data. Start date-time: 2018-02-13 12:33:32. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 12:47:11 HD Request # 10 | Decompressing data. | 2018-02-13 12:47:11 HD Request # 10 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 12:33:32 | 2018-02-13 12:47:11 HD Request # 10 | Timestamp of first Intraday data file record written: 2018-02-13 12:33:34 | 2018-02-13 12:47:11 Socket (20) | Initiating close of socket by core. | 2018-02-13 12:47:11 Socket (20) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:47:11 Socket (20) | Socket gracefully closed by remote side. | 2018-02-13 12:47:12 Socket (20) | Closed. | 2018-02-13 12:47:12 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:47:12 Historical data download thread signaled to stop. | 2018-02-13 12:47:12 HD Request # 10 | Received 5020 records from 2018-02-13 12:33:32 to 2018-02-13 12:47:10 (13.6 minutes) and wrote 5019 records for F.US.CLEH18 | 2018-02-13 12:47:12 Added 40 Time and Sales records to Intraday data file for F.US.CLEH18 after download. | 2018-02-13 12:47:12 HD Request # 10 | Completion time: 0s | 2018-02-13 12:47:12 HD Request # 10 | Intraday data download complete for F.US.CLEH18. Unique request ID: 9 | 2018-02-13 12:47:12 Removed historical data download ID 9 | 2018-02-13 12:47:12 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 12:47:12 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 12:47:12 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:47:12 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:47:12 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:47:12 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:47:12 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:47:12 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:47:12 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:47:13 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:47:13 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:47:13 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:47:13 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:47:13 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 12:47:13 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 12:47:13 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 12:47:13 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:47:14 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:47:16 Circular chart reference detected. Charts: 4, 7. Chartbook: Emini Russ RTY v8.cht. | 2018-02-13 12:47:16 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:47:16 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:47:18 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:47:25 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:47:25 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:47:25 Circular chart reference detected. Charts: 7, 4. Chartbook: YM v8.cht. | 2018-02-13 12:47:25 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:47:25 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:47:30 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:47:30 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:47:30 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:47:30 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:47:30 Circular chart reference detected. Charts: 4, 7. Chartbook: YM v8.cht. | 2018-02-13 12:47:54 CQG FIX: Received a Logout message. Text = RcvTestRequestHeartbeatTimerExpired | 2018-02-13 12:47:54 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-02-13 12:47:54 CQG FIX socket (15) | Adding bytes from final send buffer from buffered socket: 112 | 2018-02-13 12:47:54 CQG FIX socket (15) | Initiating close of socket by core. | 2018-02-13 12:47:54 CQG FIX: Disconnected. | 2018-02-13 12:47:54 CQG FIX socket (15) | Write in progress. Shutdown being delayed. | 2018-02-13 12:47:54 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:47:54 CQG FIX socket (15) | Sending bytes from final send buffer: 112 | 2018-02-13 12:47:54 CQG FIX socket (15) | Write has completed. Shutdown being performed. | 2018-02-13 12:47:54 CQG FIX socket (15) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:47:54 CQG FIX socket (15) | Socket gracefully closed by remote side. | 2018-02-13 12:47:54 CQG FIX socket (15) | Closed. | 2018-02-13 12:47:54 Circular chart reference detected. Charts: 7, 4. Chartbook: Emini Russ RTY v8.cht. | 2018-02-13 12:47:59 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:47:59 F.US.YMH18 #5 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:48:00 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:48:00 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 12:48:02 CQG WebSocket socket (17) | Adding bytes from final send buffer from buffered socket: 8 | 2018-02-13 12:48:02 CQG WebSocket socket (17) | Initiating close of socket by core. | 2018-02-13 12:48:02 CQG WebSocket | WebSocket closed. | 2018-02-13 12:48:02 CQG FIX Trading | WebSocket closed. | 2018-02-13 12:48:02 Connection to the external service has been lost. | 2018-02-13 12:48:02 CQG WebSocket socket (17) | Write in progress. Shutdown being delayed. | 2018-02-13 12:48:02 CQG WebSocket socket (17) | Sending bytes from final send buffer: 8 | 2018-02-13 12:48:02 CQG WebSocket socket (17) | Write has completed. Shutdown being performed. | 2018-02-13 12:48:02 CQG WebSocket socket (17) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:48:02 CQG WebSocket socket (17) | Socket gracefully closed by remote side. | 2018-02-13 12:48:02 CQG WebSocket socket (17) | Closed. | 2018-02-13 12:48:02 CQG FIX Trading | Disconnected. | 2018-02-13 12:48:10 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 12:48:10 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 12:48:16 CQG FIX socket (22) | Creating socket. Using TLS 1.2. | 2018-02-13 12:48:16 CQG FIX socket (22) | Connecting to IP: 208.48.16.214. | 2018-02-13 12:48:16 CQG FIX: Sending the Logon message. | 2018-02-13 12:48:19 CQG FIX Trading | Connected to trading server. | 2018-02-13 12:48:20 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 12:48:20 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 12:48:20 CQG WebSocket socket (23) | Creating socket. Using TLS 1.2. | 2018-02-13 12:48:20 CQG WebSocket socket (23) | Connecting to IP: 208.48.16.35. | 2018-02-13 12:48:20 CQG WebSocket | Opening WebSocket. | 2018-02-13 12:48:21 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 12:48:21 CQG FIX | FCM name: AMP | 2018-02-13 12:48:21 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 12:48:22 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 12:48:22 CQG WebSocket | Header line. Sec-WebSocket-Accept: 3JxNaE8jhjiF9x1qUhME5M+2Aqk= | 2018-02-13 12:48:22 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 12:48:22 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 12:48:22 CQG WebSocket | Header line. | 2018-02-13 12:48:22 CQG WebSocket | Web socket state is now open. | 2018-02-13 12:48:22 CQG FIX Trading | WebSocket connected. | 2018-02-13 12:48:22 CQG FIX Trading | Sending market data logon message. | 2018-02-13 12:48:22 CQG FIX Trading | Logon successful. Session Token = 2ezOMYE9lHh91GSaak9vUpMAYau6wRXQvFex3liNpEEUxENAMMCrfL2Z9YopI5Xc8ebeMNwmxWq | 2018-02-13 12:48:22 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 12:48:26 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 2 | 2018-02-13 12:48:26 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 701496 | 2018-02-13 12:48:26 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 2 | 2018-02-13 12:48:26 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 1 | 2018-02-13 12:48:26 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 701497 | 2018-02-13 12:48:26 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 1 | 2018-02-13 12:48:26 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 12:48:26 Delaying start of download for F.US.CLEH18 | 2018-02-13 12:48:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 701496. Contract ID: 1. | 2018-02-13 12:48:26 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 12:48:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 701497. Contract ID: 2. | 2018-02-13 12:48:26 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 12:48:26 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 3 | 2018-02-13 12:48:26 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 701498 | 2018-02-13 12:48:26 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 3 | 2018-02-13 12:48:26 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 12:48:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 701498. Contract ID: 3. | 2018-02-13 12:48:27 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 12:48:27 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 4 | 2018-02-13 12:48:27 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 701499 | 2018-02-13 12:48:27 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 4 | 2018-02-13 12:48:27 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 12:48:27 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 701499. Contract ID: 4. | 2018-02-13 12:48:28 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 12:48:28 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 5 | 2018-02-13 12:48:28 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 701500 | 2018-02-13 12:48:28 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 5 | 2018-02-13 12:48:28 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 7 | 2018-02-13 12:48:28 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 701501 | 2018-02-13 12:48:28 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 7 | 2018-02-13 12:48:28 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 6 | 2018-02-13 12:48:28 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 701502 | 2018-02-13 12:48:28 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 6 | 2018-02-13 12:48:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 701500. Contract ID: 5. | 2018-02-13 12:48:28 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 12:48:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 701501. Contract ID: 6. | 2018-02-13 12:48:28 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 12:48:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 701502. Contract ID: 7. | 2018-02-13 12:48:28 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 12:48:28 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 8 | 2018-02-13 12:48:29 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 701503 | 2018-02-13 12:48:29 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 8 | 2018-02-13 12:48:29 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 9 | 2018-02-13 12:48:29 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 701504 | 2018-02-13 12:48:29 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 9 | 2018-02-13 12:48:29 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 10 | 2018-02-13 12:48:29 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 701505 | 2018-02-13 12:48:29 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 10 | 2018-02-13 12:48:29 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 11 | 2018-02-13 12:48:29 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 701506 | 2018-02-13 12:48:29 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 11 | 2018-02-13 12:48:29 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 12 | 2018-02-13 12:48:29 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 701507 | 2018-02-13 12:48:29 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 12 | 2018-02-13 12:48:29 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 701503. Contract ID: 8. | 2018-02-13 12:48:30 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 12:48:30 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 701504. Contract ID: 9. | 2018-02-13 12:48:30 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 12:48:30 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 701505. Contract ID: 10. | 2018-02-13 12:48:30 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 12:48:30 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 701506. Contract ID: 11. | 2018-02-13 12:48:30 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 12:48:30 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 701507. Contract ID: 12. | 2018-02-13 12:48:30 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 12:48:30 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 13 | 2018-02-13 12:48:30 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 701508 | 2018-02-13 12:48:30 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 13 | 2018-02-13 12:48:30 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 701508. Contract ID: 13. | 2018-02-13 12:48:30 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 12:48:30 HD Request # 11 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 12:48:31 HD Request # 11 | Download start date-time: 2018-02-13 12:48:00.000 | 2018-02-13 12:48:31 HD Request # 11 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 12:48:31 Socket (24) | Creating socket. | 2018-02-13 12:48:31 Socket (24) | Connecting to IP: 65.182.172.42. | 2018-02-13 12:48:31 HD Request # 11 | Setting DTC encoding to Binary VLS | 2018-02-13 12:48:31 HD Request # 11 | Sending historical data logon request message. | 2018-02-13 12:48:31 HD Request # 11 | Requesting Intraday data. Start date-time: 2018-02-13 12:48:00. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 12:48:32 HD Request # 11 | Decompressing data. | 2018-02-13 12:48:32 HD Request # 11 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 12:48:00 | 2018-02-13 12:48:32 HD Request # 11 | Timestamp of first Intraday data file record written: 2018-02-13 12:48:02 | 2018-02-13 12:48:32 Socket (24) | Initiating close of socket by core. | 2018-02-13 12:48:32 Socket (24) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:48:32 Historical data download thread signaled to stop. | 2018-02-13 12:48:32 HD Request # 11 | Received 98 records from 2018-02-13 12:48:00 to 2018-02-13 12:48:30 (30.0 seconds) and wrote 89 records for F.US.CLEH18 | 2018-02-13 12:48:32 Added 1 Time and Sales records to Intraday data file for F.US.CLEH18 after download. | 2018-02-13 12:48:32 HD Request # 11 | Completion time: 0s | 2018-02-13 12:48:32 HD Request # 11 | Intraday data download complete for F.US.CLEH18. Unique request ID: 10 | 2018-02-13 12:48:32 Removed historical data download ID 10 | 2018-02-13 12:48:32 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 12:48:32 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 12:48:32 Delaying start of download for F.US.YMH18 | 2018-02-13 12:48:32 Socket (24) | Socket gracefully closed by remote side. | 2018-02-13 12:48:32 Socket (24) | Closed. | 2018-02-13 12:48:32 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:48:34 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:48:34 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:48:34 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:48:35 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:48:35 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:48:35 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:48:35 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 12:48:35 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 12:48:38 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 12:48:38 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 12:48:38 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 12:48:38 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 12:48:38 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 12:48:38 HD Request # 12 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 12:48:40 HD Request # 12 | Download start date-time: 2018-02-13 12:48:00.000 | 2018-02-13 12:48:40 HD Request # 12 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 12:48:40 Socket (25) | Creating socket. | 2018-02-13 12:48:40 Socket (25) | Connecting to IP: 192.81.56.146. | 2018-02-13 12:48:40 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:48:40 HD Request # 12 | Setting DTC encoding to Binary VLS | 2018-02-13 12:48:40 HD Request # 12 | Sending historical data logon request message. | 2018-02-13 12:48:40 HD Request # 12 | Requesting Intraday data. Start date-time: 2018-02-13 12:48:00. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 12:48:40 HD Request # 12 | Decompressing data. | 2018-02-13 12:48:40 HD Request # 12 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 12:48:00 | 2018-02-13 12:48:40 HD Request # 12 | Timestamp of first Intraday data file record written: 2018-02-13 12:48:00 | 2018-02-13 12:48:40 Socket (25) | Initiating close of socket by core. | 2018-02-13 12:48:40 Socket (25) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:48:40 Socket (25) | Socket gracefully closed by remote side. | 2018-02-13 12:48:40 Socket (25) | Closed. | 2018-02-13 12:48:40 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:48:45 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:48:45 Historical data download thread signaled to stop. | 2018-02-13 12:48:45 HD Request # 12 | Received 114 records from 2018-02-13 12:48:00 to 2018-02-13 12:48:36 (36.0 seconds) and wrote 108 records for F.US.YMH18 | 2018-02-13 12:48:45 Added 11 Time and Sales records to Intraday data file for F.US.YMH18 after download. | 2018-02-13 12:48:45 HD Request # 12 | Completion time: 5s | 2018-02-13 12:48:45 HD Request # 12 | Intraday data download complete for F.US.YMH18. Unique request ID: 11 | 2018-02-13 12:48:45 Removed historical data download ID 11 | 2018-02-13 12:48:45 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 12:48:45 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 12:48:45 HD Request # 13 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 12:48:45 HD Request # 13 | Download start date-time: 2018-02-13 12:47:57.000 | 2018-02-13 12:48:45 HD Request # 13 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 12:48:45 Socket (26) | Creating socket. | 2018-02-13 12:48:45 Socket (26) | Connecting to IP: 65.182.172.42. | 2018-02-13 12:48:45 HD Request # 13 | Setting DTC encoding to Binary VLS | 2018-02-13 12:48:45 HD Request # 13 | Sending historical data logon request message. | 2018-02-13 12:48:45 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:48:45 HD Request # 13 | Requesting Intraday data. Start date-time: 2018-02-13 12:47:57. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 12:48:45 HD Request # 13 | Decompressing data. | 2018-02-13 12:48:45 HD Request # 13 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 12:47:57 | 2018-02-13 12:48:45 HD Request # 13 | Timestamp of first Intraday data file record written: 2018-02-13 12:47:57 | 2018-02-13 12:48:45 Socket (26) | Initiating close of socket by core. | 2018-02-13 12:48:45 Socket (26) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:48:45 Socket (26) | Socket gracefully closed by remote side. | 2018-02-13 12:48:46 Socket (26) | Closed. | 2018-02-13 12:48:46 Historical data download thread signaled to stop. | 2018-02-13 12:48:46 HD Request # 13 | Received 56 records from 2018-02-13 12:47:57 to 2018-02-13 12:48:44 (47.0 seconds) and wrote 53 records for F.US.RTYH18 | 2018-02-13 12:48:46 Added 7 Time and Sales records to Intraday data file for F.US.RTYH18 after download. | 2018-02-13 12:48:46 HD Request # 13 | Completion time: 0s | 2018-02-13 12:48:46 HD Request # 13 | Intraday data download complete for F.US.RTYH18. Unique request ID: 12 | 2018-02-13 12:48:46 Removed historical data download ID 12 | 2018-02-13 12:48:46 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 12:48:46 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 12:48:46 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:48:46 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 12:48:48 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:48:49 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:48:49 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:48:49 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 12:48:51 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:49:13 Circular chart reference detected. Charts: 4, 7. Chartbook: YM v8.cht. | 2018-02-13 12:49:13 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:49:13 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:49:13 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:49:13 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:49:15 F.US.YMH18 #5 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:49:16 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 12:49:16 CQG WebSocket socket (23) | Adding bytes from final send buffer from buffered socket: 8 | 2018-02-13 12:49:16 CQG WebSocket socket (23) | Initiating close of socket by core. | 2018-02-13 12:49:16 CQG WebSocket | WebSocket closed. | 2018-02-13 12:49:16 CQG FIX Trading | WebSocket closed. | 2018-02-13 12:49:16 Connection to the external service has been lost. | 2018-02-13 12:49:16 CQG WebSocket socket (23) | Write in progress. Shutdown being delayed. | 2018-02-13 12:49:16 CQG WebSocket socket (23) | Sending bytes from final send buffer: 8 | 2018-02-13 12:49:16 CQG WebSocket socket (23) | Write has completed. Shutdown being performed. | 2018-02-13 12:49:16 CQG WebSocket socket (23) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:49:16 CQG WebSocket socket (23) | Socket gracefully closed by remote side. | 2018-02-13 12:49:16 CQG WebSocket socket (23) | Closed. | 2018-02-13 12:49:16 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:49:19 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:49:19 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:49:19 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:49:19 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:49:21 Circular chart reference detected. Charts: 4, 7. Chartbook: Emini Russ RTY v8.cht. | 2018-02-13 12:49:23 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:49:24 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:49:31 Circular chart reference detected. Charts: 7, 4. Chartbook: YM v8.cht. | 2018-02-13 12:49:31 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:49:31 Circular chart reference detected. Charts: 4, 7. Chartbook: YM v8.cht. | 2018-02-13 12:49:55 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:49:55 Circular chart reference detected. Charts: 7, 4. Chartbook: Emini Russ RTY v8.cht. | 2018-02-13 12:50:00 F.US.YMH18 #5 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:50:02 CQG FIX: DisconnectFIX called. | 2018-02-13 12:50:02 CQG FIX: Sending a Logout message. | 2018-02-13 12:50:02 CQG FIX Trading | Disconnected. | 2018-02-13 12:50:02 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 12:50:02 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 12:50:02 CQG FIX socket (22) | Initiating close of socket by core. | 2018-02-13 12:50:02 CQG FIX: Disconnected. | 2018-02-13 12:50:02 CQG FIX socket (22) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:50:02 CQG FIX socket (22) | Socket gracefully closed by remote side. | 2018-02-13 12:50:02 CQG FIX socket (22) | Closed. | 2018-02-13 12:50:02 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 12:50:08 CQG FIX socket (29) | Creating socket. Using TLS 1.2. | 2018-02-13 12:50:08 CQG FIX socket (29) | Connecting to IP: 208.48.16.214. | 2018-02-13 12:50:08 CQG FIX: Sending the Logon message. | 2018-02-13 12:50:13 CQG FIX Trading | Connected to trading server. | 2018-02-13 12:50:14 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 12:50:14 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 12:50:14 CQG WebSocket socket (30) | Creating socket. Using TLS 1.2. | 2018-02-13 12:50:14 CQG WebSocket socket (30) | Connecting to IP: 208.48.16.35. | 2018-02-13 12:50:14 CQG FIX | FCM name: AMP | 2018-02-13 12:50:14 CQG WebSocket | Opening WebSocket. | 2018-02-13 12:50:15 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 12:50:15 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 12:50:16 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 12:50:16 CQG WebSocket | Header line. Sec-WebSocket-Accept: WYTswWj11p7wzFPmBglAw4wP7IE= | 2018-02-13 12:50:16 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 12:50:16 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 12:50:16 CQG WebSocket | Header line. | 2018-02-13 12:50:16 CQG WebSocket | Web socket state is now open. | 2018-02-13 12:50:16 CQG FIX Trading | WebSocket connected. | 2018-02-13 12:50:16 CQG FIX Trading | Sending market data logon message. | 2018-02-13 12:50:16 CQG FIX Trading | Logon successful. Session Token = Dx/ZGa0b/kF8Noz+CxZMjupvgOcv4KV75alVFvUcUJgjha/DrY6zXZuN+iQ6R4jdKDk834bqHEJ | 2018-02-13 12:50:17 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 12:50:22 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 1 | 2018-02-13 12:50:22 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 701509 | 2018-02-13 12:50:22 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 1 | 2018-02-13 12:50:22 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 2 | 2018-02-13 12:50:22 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 701510 | 2018-02-13 12:50:22 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 2 | 2018-02-13 12:50:22 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 3 | 2018-02-13 12:50:22 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 701511 | 2018-02-13 12:50:22 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 3 | 2018-02-13 12:50:22 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 4 | 2018-02-13 12:50:22 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 701512 | 2018-02-13 12:50:22 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 4 | 2018-02-13 12:50:22 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 5 | 2018-02-13 12:50:22 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 701513 | 2018-02-13 12:50:22 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 5 | 2018-02-13 12:50:22 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 12:50:22 Delaying start of download for F.US.RTYH18 | 2018-02-13 12:50:22 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 701509. Contract ID: 1. | 2018-02-13 12:50:22 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 12:50:22 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 701510. Contract ID: 2. | 2018-02-13 12:50:22 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 12:50:22 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 701511. Contract ID: 3. | 2018-02-13 12:50:22 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 12:50:22 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 701512. Contract ID: 4. | 2018-02-13 12:50:22 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 12:50:22 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 701513. Contract ID: 5. | 2018-02-13 12:50:22 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 12:50:22 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 6 | 2018-02-13 12:50:22 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 701514 | 2018-02-13 12:50:22 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 6 | 2018-02-13 12:50:22 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 12:50:22 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 8 | 2018-02-13 12:50:22 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 701515 | 2018-02-13 12:50:22 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 8 | 2018-02-13 12:50:22 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 7 | 2018-02-13 12:50:22 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 701516 | 2018-02-13 12:50:22 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 7 | 2018-02-13 12:50:22 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 12:50:22 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 701514. Contract ID: 6. | 2018-02-13 12:50:22 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 12:50:22 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 701515. Contract ID: 7. | 2018-02-13 12:50:22 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 12:50:22 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 701516. Contract ID: 8. | 2018-02-13 12:50:22 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 12:50:22 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 9 | 2018-02-13 12:50:25 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 701517 | 2018-02-13 12:50:25 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 9 | 2018-02-13 12:50:25 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 10 | 2018-02-13 12:50:25 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 701518 | 2018-02-13 12:50:25 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 10 | 2018-02-13 12:50:25 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 701517. Contract ID: 9. | 2018-02-13 12:50:26 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 12:50:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 701518. Contract ID: 10. | 2018-02-13 12:50:26 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 12:50:26 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 11 | 2018-02-13 12:50:26 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 701519 | 2018-02-13 12:50:26 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 11 | 2018-02-13 12:50:26 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 13 | 2018-02-13 12:50:26 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 701520 | 2018-02-13 12:50:26 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 13 | 2018-02-13 12:50:26 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 12 | 2018-02-13 12:50:26 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 701521 | 2018-02-13 12:50:26 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 12 | 2018-02-13 12:50:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 701519. Contract ID: 11. | 2018-02-13 12:50:28 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 12:50:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 701520. Contract ID: 12. | 2018-02-13 12:50:28 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 12:50:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 701521. Contract ID: 13. | 2018-02-13 12:50:28 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 12:50:28 HD Request # 14 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 12:50:29 HD Request # 14 | Download start date-time: 2018-02-13 12:48:59.000 | 2018-02-13 12:50:29 HD Request # 14 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 12:50:29 Socket (31) | Creating socket. | 2018-02-13 12:50:29 Socket (31) | Connecting to IP: 192.81.56.146. | 2018-02-13 12:50:29 HD Request # 14 | Setting DTC encoding to Binary VLS | 2018-02-13 12:50:30 HD Request # 14 | Sending historical data logon request message. | 2018-02-13 12:50:30 HD Request # 14 | Requesting Intraday data. Start date-time: 2018-02-13 12:48:59. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 12:50:30 HD Request # 14 | Decompressing data. | 2018-02-13 12:50:30 HD Request # 14 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 12:48:59 | 2018-02-13 12:50:30 HD Request # 14 | Timestamp of first Intraday data file record written: 2018-02-13 12:49:15 | 2018-02-13 12:50:30 Socket (31) | Initiating close of socket by core. | 2018-02-13 12:50:30 Socket (31) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:50:30 Socket (31) | Socket gracefully closed by remote side. | 2018-02-13 12:50:30 Socket (31) | Closed. | 2018-02-13 12:50:30 Historical data download thread signaled to stop. | 2018-02-13 12:50:30 HD Request # 14 | Received 100 records from 2018-02-13 12:48:59 to 2018-02-13 12:50:28 (89.0 seconds) and wrote 86 records for F.US.RTYH18 | 2018-02-13 12:50:30 HD Request # 14 | Completion time: 0s | 2018-02-13 12:50:30 HD Request # 14 | Intraday data download complete for F.US.RTYH18. Unique request ID: 13 | 2018-02-13 12:50:30 Removed historical data download ID 13 | 2018-02-13 12:50:30 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 12:50:30 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 12:50:30 HD Request # 15 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 12:50:30 HD Request # 15 | Download start date-time: 2018-02-13 12:49:13.000 | 2018-02-13 12:50:30 HD Request # 15 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 12:50:30 Socket (32) | Creating socket. | 2018-02-13 12:50:30 Socket (32) | Connecting to IP: 65.182.172.42. | 2018-02-13 12:50:30 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:50:30 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:50:30 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:50:30 HD Request # 15 | Setting DTC encoding to Binary VLS | 2018-02-13 12:50:31 HD Request # 15 | Sending historical data logon request message. | 2018-02-13 12:50:31 HD Request # 15 | Requesting Intraday data. Start date-time: 2018-02-13 12:49:13. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 12:50:31 HD Request # 15 | Decompressing data. | 2018-02-13 12:50:31 HD Request # 15 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 12:49:13 | 2018-02-13 12:50:31 HD Request # 15 | Timestamp of first Intraday data file record written: 2018-02-13 12:49:15 | 2018-02-13 12:50:31 Socket (32) | Initiating close of socket by core. | 2018-02-13 12:50:31 Socket (32) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:50:31 Socket (32) | Socket gracefully closed by remote side. | 2018-02-13 12:50:31 Socket (32) | Closed. | 2018-02-13 12:50:31 Historical data download thread signaled to stop. | 2018-02-13 12:50:32 HD Request # 15 | Received 257 records from 2018-02-13 12:49:13 to 2018-02-13 12:50:29 (76.0 seconds) and wrote 251 records for F.US.YMH18 | 2018-02-13 12:50:32 Added 1 Time and Sales records to Intraday data file for F.US.YMH18 after download. | 2018-02-13 12:50:32 HD Request # 15 | Completion time: 1s | 2018-02-13 12:50:32 HD Request # 15 | Intraday data download complete for F.US.YMH18. Unique request ID: 14 | 2018-02-13 12:50:32 Removed historical data download ID 14 | 2018-02-13 12:50:32 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 12:50:32 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 12:50:32 HD Request # 16 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 12:50:32 HD Request # 16 | Download start date-time: 2018-02-13 12:49:14.000 | 2018-02-13 12:50:32 HD Request # 16 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 12:50:32 Socket (33) | Creating socket. | 2018-02-13 12:50:32 Socket (33) | Connecting to IP: 192.81.56.146. | 2018-02-13 12:50:32 HD Request # 16 | Setting DTC encoding to Binary VLS | 2018-02-13 12:50:32 HD Request # 16 | Sending historical data logon request message. | 2018-02-13 12:50:32 HD Request # 16 | Requesting Intraday data. Start date-time: 2018-02-13 12:49:14. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 12:50:32 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:50:32 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:50:32 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:50:32 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:50:32 HD Request # 16 | Decompressing data. | 2018-02-13 12:50:32 HD Request # 16 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 12:49:14 | 2018-02-13 12:50:32 HD Request # 16 | Timestamp of first Intraday data file record written: 2018-02-13 12:49:19 | 2018-02-13 12:50:32 Socket (33) | Initiating close of socket by core. | 2018-02-13 12:50:32 Socket (33) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:50:32 Socket (33) | Socket gracefully closed by remote side. | 2018-02-13 12:50:32 Socket (33) | Closed. | 2018-02-13 12:50:32 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:50:37 Circular chart reference detected. Charts: 7, 4. Chartbook: Emini Russ RTY v8.cht. | 2018-02-13 12:50:37 Historical data download thread signaled to stop. | 2018-02-13 12:50:37 HD Request # 16 | Received 331 records from 2018-02-13 12:49:14 to 2018-02-13 12:50:30 (76.0 seconds) and wrote 318 records for F.US.CLEH18 | 2018-02-13 12:50:37 Added 56 Time and Sales records to Intraday data file for F.US.CLEH18 after download. | 2018-02-13 12:50:37 HD Request # 16 | Completion time: 6s | 2018-02-13 12:50:37 HD Request # 16 | Intraday data download complete for F.US.CLEH18. Unique request ID: 15 | 2018-02-13 12:50:37 Removed historical data download ID 15 | 2018-02-13 12:50:37 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 12:50:37 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 12:50:37 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 12:50:38 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 12:50:38 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 12:50:38 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 12:50:38 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 12:50:38 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 12:50:38 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:50:38 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:50:40 Circular chart reference detected. Charts: 4, 7. Chartbook: Emini Russ RTY v8.cht. | 2018-02-13 12:50:40 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 12:50:40 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 12:50:40 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 12:50:40 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:50:40 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:50:48 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:50:48 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:50:48 Circular chart reference detected. Charts: 7, 4. Chartbook: YM v8.cht. | 2018-02-13 12:50:48 F.US.YMH18 #5 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:50:48 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:50:48 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:50:48 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:50:48 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:50:48 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:51:12 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:51:12 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:51:13 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:51:17 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:51:17 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:51:17 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:51:17 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:51:18 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 12:51:23 CQG WebSocket socket (30) | Adding bytes from final send buffer from buffered socket: 8 | 2018-02-13 12:51:23 CQG WebSocket socket (30) | Initiating close of socket by core. | 2018-02-13 12:51:23 CQG WebSocket | WebSocket closed. | 2018-02-13 12:51:23 CQG FIX Trading | WebSocket closed. | 2018-02-13 12:51:23 Connection to the external service has been lost. | 2018-02-13 12:51:23 CQG WebSocket socket (30) | Write in progress. Shutdown being delayed. | 2018-02-13 12:51:23 CQG WebSocket socket (30) | Sending bytes from final send buffer: 8 | 2018-02-13 12:51:23 CQG WebSocket socket (30) | Write has completed. Shutdown being performed. | 2018-02-13 12:51:23 CQG WebSocket socket (30) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:51:23 CQG WebSocket socket (30) | Socket gracefully closed by remote side. | 2018-02-13 12:51:23 CQG WebSocket socket (30) | Closed. | 2018-02-13 12:51:23 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:51:28 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:51:30 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:51:37 F.US.YMH18 #5 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:51:37 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:51:38 CQG FIX: DisconnectFIX called. | 2018-02-13 12:51:40 CQG FIX: Sending a Logout message. | 2018-02-13 12:51:40 CQG FIX Trading | Disconnected. | 2018-02-13 12:51:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 12:51:40 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 12:51:41 CQG FIX socket (29) | Initiating close of socket by core. | 2018-02-13 12:51:41 CQG FIX: Disconnected. | 2018-02-13 12:51:41 CQG FIX socket (29) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:51:41 CQG FIX socket (29) | Socket gracefully closed by remote side. | 2018-02-13 12:51:41 CQG FIX socket (29) | Closed. | 2018-02-13 12:51:41 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 12:51:46 CQG FIX socket (36) | Creating socket. Using TLS 1.2. | 2018-02-13 12:51:46 CQG FIX socket (36) | Connecting to IP: 208.48.16.214. | 2018-02-13 12:51:46 CQG FIX: Sending the Logon message. | 2018-02-13 12:51:50 CQG FIX Trading | Connected to trading server. | 2018-02-13 12:51:51 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 12:51:51 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 12:51:51 CQG WebSocket socket (37) | Creating socket. Using TLS 1.2. | 2018-02-13 12:51:51 CQG WebSocket socket (37) | Connecting to IP: 208.48.16.35. | 2018-02-13 12:51:51 CQG WebSocket | Opening WebSocket. | 2018-02-13 12:51:52 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 12:51:52 CQG FIX | FCM name: AMP | 2018-02-13 12:51:52 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 12:51:52 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 12:51:52 CQG WebSocket | Header line. Sec-WebSocket-Accept: ws/xAQpuK9ds4mWMm1sxTjw5V+I= | 2018-02-13 12:51:52 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 12:51:52 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 12:51:52 CQG WebSocket | Header line. | 2018-02-13 12:51:52 CQG WebSocket | Web socket state is now open. | 2018-02-13 12:51:52 CQG FIX Trading | WebSocket connected. | 2018-02-13 12:51:52 CQG FIX Trading | Sending market data logon message. | 2018-02-13 12:51:52 CQG FIX Trading | Logon successful. Session Token = oGDqGhcxqQlGJjGy2V3yeDSnYrFGx2rIfGg76vXx/OcaXUpWJGdabhDzJNr9Zj/gWnRr+AB0gSZ | 2018-02-13 12:51:53 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 12:51:56 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 1 | 2018-02-13 12:51:56 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 701522 | 2018-02-13 12:51:56 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 1 | 2018-02-13 12:51:56 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 12:51:56 Delaying start of download for F.US.YMH18 | 2018-02-13 12:51:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 701522. Contract ID: 1. | 2018-02-13 12:51:57 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 12:51:57 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 2 | 2018-02-13 12:51:57 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 701523 | 2018-02-13 12:51:57 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 2 | 2018-02-13 12:51:57 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 3 | 2018-02-13 12:51:57 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 701524 | 2018-02-13 12:51:57 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 3 | 2018-02-13 12:51:57 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 4 | 2018-02-13 12:51:57 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 701525 | 2018-02-13 12:51:57 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 4 | 2018-02-13 12:51:57 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 5 | 2018-02-13 12:51:57 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 701526 | 2018-02-13 12:51:57 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 5 | 2018-02-13 12:51:57 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 6 | 2018-02-13 12:51:57 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 701527 | 2018-02-13 12:51:57 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 6 | 2018-02-13 12:51:57 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 8 | 2018-02-13 12:51:57 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 701528 | 2018-02-13 12:51:57 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 8 | 2018-02-13 12:51:57 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 7 | 2018-02-13 12:51:57 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 701529 | 2018-02-13 12:51:57 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 7 | 2018-02-13 12:51:57 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 12:51:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 701523. Contract ID: 2. | 2018-02-13 12:51:57 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 12:51:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 701524. Contract ID: 3. | 2018-02-13 12:51:57 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 12:51:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 701525. Contract ID: 4. | 2018-02-13 12:51:57 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 12:51:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 701526. Contract ID: 5. | 2018-02-13 12:51:57 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 12:51:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 701527. Contract ID: 6. | 2018-02-13 12:51:57 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 12:51:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 701528. Contract ID: 7. | 2018-02-13 12:51:57 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 12:51:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 701529. Contract ID: 8. | 2018-02-13 12:51:57 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 12:51:57 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 9 | 2018-02-13 12:51:57 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 701530 | 2018-02-13 12:51:57 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 9 | 2018-02-13 12:51:57 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 12:51:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 701530. Contract ID: 9. | 2018-02-13 12:51:57 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 12:51:57 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 10 | 2018-02-13 12:51:58 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 701531 | 2018-02-13 12:51:58 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 10 | 2018-02-13 12:51:58 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 12 | 2018-02-13 12:51:58 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 701532 | 2018-02-13 12:51:58 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 12 | 2018-02-13 12:51:58 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 11 | 2018-02-13 12:51:58 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 701533 | 2018-02-13 12:51:58 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 11 | 2018-02-13 12:51:58 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 13 | 2018-02-13 12:51:58 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 701534 | 2018-02-13 12:51:58 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 13 | 2018-02-13 12:51:58 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 701531. Contract ID: 10. | 2018-02-13 12:51:59 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 12:51:59 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 701532. Contract ID: 11. | 2018-02-13 12:51:59 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 12:51:59 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 701533. Contract ID: 12. | 2018-02-13 12:51:59 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 12:51:59 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 701534. Contract ID: 13. | 2018-02-13 12:51:59 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 12:51:59 HD Request # 17 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 12:52:02 HD Request # 17 | Download start date-time: 2018-02-13 12:51:19.000 | 2018-02-13 12:52:02 HD Request # 17 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 12:52:02 Socket (38) | Creating socket. | 2018-02-13 12:52:02 Socket (38) | Connecting to IP: 65.182.172.42. | 2018-02-13 12:52:02 HD Request # 17 | Setting DTC encoding to Binary VLS | 2018-02-13 12:52:03 HD Request # 17 | Sending historical data logon request message. | 2018-02-13 12:52:03 HD Request # 17 | Requesting Intraday data. Start date-time: 2018-02-13 12:51:19. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 12:52:03 HD Request # 17 | Decompressing data. | 2018-02-13 12:52:03 HD Request # 17 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 12:51:19 | 2018-02-13 12:52:03 HD Request # 17 | Timestamp of first Intraday data file record written: 2018-02-13 12:51:21 | 2018-02-13 12:52:03 Socket (38) | Initiating close of socket by core. | 2018-02-13 12:52:03 Socket (38) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:52:03 Socket (38) | Socket gracefully closed by remote side. | 2018-02-13 12:52:03 Socket (38) | Closed. | 2018-02-13 12:52:03 Historical data download thread signaled to stop. | 2018-02-13 12:52:03 HD Request # 17 | Received 119 records from 2018-02-13 12:51:19 to 2018-02-13 12:51:53 (34.0 seconds) and wrote 103 records for F.US.YMH18 | 2018-02-13 12:52:03 Added 4 Time and Sales records to Intraday data file for F.US.YMH18 after download. | 2018-02-13 12:52:03 HD Request # 17 | Completion time: 0s | 2018-02-13 12:52:03 HD Request # 17 | Intraday data download complete for F.US.YMH18. Unique request ID: 16 | 2018-02-13 12:52:03 Removed historical data download ID 16 | 2018-02-13 12:52:03 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 12:52:03 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 12:52:03 HD Request # 18 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 12:52:03 HD Request # 18 | Download start date-time: 2018-02-13 12:51:22.000 | 2018-02-13 12:52:03 HD Request # 18 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 12:52:03 Socket (39) | Creating socket. | 2018-02-13 12:52:03 Socket (39) | Connecting to IP: 192.81.56.146. | 2018-02-13 12:52:03 HD Request # 18 | Setting DTC encoding to Binary VLS | 2018-02-13 12:52:03 HD Request # 18 | Sending historical data logon request message. | 2018-02-13 12:52:03 HD Request # 18 | Requesting Intraday data. Start date-time: 2018-02-13 12:51:22. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 12:52:03 HD Request # 18 | Decompressing data. | 2018-02-13 12:52:03 HD Request # 18 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 12:51:22 | 2018-02-13 12:52:03 HD Request # 18 | Timestamp of first Intraday data file record written: 2018-02-13 12:51:23 | 2018-02-13 12:52:03 Socket (39) | Initiating close of socket by core. | 2018-02-13 12:52:03 Socket (39) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:52:03 Historical data download thread signaled to stop. | 2018-02-13 12:52:03 HD Request # 18 | Received 109 records from 2018-02-13 12:51:22 to 2018-02-13 12:51:57 (35.0 seconds) and wrote 108 records for F.US.CLEH18 | 2018-02-13 12:52:03 HD Request # 18 | Completion time: 1s | 2018-02-13 12:52:03 HD Request # 18 | Intraday data download complete for F.US.CLEH18. Unique request ID: 17 | 2018-02-13 12:52:03 Removed historical data download ID 17 | 2018-02-13 12:52:03 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 12:52:03 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 12:52:03 HD Request # 19 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 12:52:03 HD Request # 19 | Download start date-time: 2018-02-13 12:51:22.000 | 2018-02-13 12:52:03 HD Request # 19 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 12:52:03 Socket (40) | Creating socket. | 2018-02-13 12:52:03 Socket (40) | Connecting to IP: 65.182.172.42. | 2018-02-13 12:52:03 Socket (39) | Socket gracefully closed by remote side. | 2018-02-13 12:52:03 Socket (39) | Closed. | 2018-02-13 12:52:03 HD Request # 19 | Setting DTC encoding to Binary VLS | 2018-02-13 12:52:03 HD Request # 19 | Sending historical data logon request message. | 2018-02-13 12:52:03 HD Request # 19 | Requesting Intraday data. Start date-time: 2018-02-13 12:51:22. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 12:52:03 HD Request # 19 | Decompressing data. | 2018-02-13 12:52:04 HD Request # 19 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 12:51:22 | 2018-02-13 12:52:04 HD Request # 19 | Timestamp of first Intraday data file record written: 2018-02-13 12:51:23 | 2018-02-13 12:52:04 Socket (40) | Initiating close of socket by core. | 2018-02-13 12:52:04 Socket (40) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:52:04 Socket (40) | Socket gracefully closed by remote side. | 2018-02-13 12:52:04 Socket (40) | Closed. | 2018-02-13 12:52:04 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:52:04 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:52:04 Historical data download thread signaled to stop. | 2018-02-13 12:52:04 HD Request # 19 | Received 53 records from 2018-02-13 12:51:22 to 2018-02-13 12:52:02 (40.0 seconds) and wrote 51 records for F.US.RTYH18 | 2018-02-13 12:52:04 Added 7 Time and Sales records to Intraday data file for F.US.RTYH18 after download. | 2018-02-13 12:52:04 HD Request # 19 | Completion time: 0s | 2018-02-13 12:52:04 HD Request # 19 | Intraday data download complete for F.US.RTYH18. Unique request ID: 18 | 2018-02-13 12:52:04 Removed historical data download ID 18 | 2018-02-13 12:52:04 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 12:52:04 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 12:52:04 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:52:05 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:52:05 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:52:05 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 12:52:05 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 12:52:05 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 12:52:05 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:52:29 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 12:52:29 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 12:52:29 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 12:52:29 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 12:52:29 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 12:52:29 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 12:52:29 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:52:29 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:52:29 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:52:29 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:52:29 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:52:29 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:52:29 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:52:29 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:52:30 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:52:30 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:52:30 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:52:30 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:52:35 F.US.YMH18 #5 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:52:35 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:52:35 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:52:37 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:52:37 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:52:39 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:52:46 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:52:46 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:52:50 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:52:50 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:52:50 CQG FIX: Received a Logout message. Text = RcvTestRequestHeartbeatTimerExpired | 2018-02-13 12:53:14 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-02-13 12:53:14 CQG FIX socket (36) | Adding bytes from final send buffer from buffered socket: 113 | 2018-02-13 12:53:14 CQG FIX socket (36) | Initiating close of socket by core. | 2018-02-13 12:53:14 CQG FIX: Disconnected. | 2018-02-13 12:53:14 CQG FIX socket (36) | Write in progress. Shutdown being delayed. | 2018-02-13 12:53:14 CQG FIX socket (36) | Sending bytes from final send buffer: 113 | 2018-02-13 12:53:15 CQG FIX socket (36) | Write has completed. Shutdown being performed. | 2018-02-13 12:53:15 CQG FIX socket (36) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:53:15 CQG FIX socket (36) | Socket gracefully closed by remote side. | 2018-02-13 12:53:15 CQG FIX socket (36) | Closed. | 2018-02-13 12:53:15 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 12:53:15 CQG WebSocket socket (37) | Adding bytes from final send buffer from buffered socket: 8 | 2018-02-13 12:53:15 CQG WebSocket socket (37) | Initiating close of socket by core. | 2018-02-13 12:53:15 CQG WebSocket | WebSocket closed. | 2018-02-13 12:53:15 CQG FIX Trading | WebSocket closed. | 2018-02-13 12:53:15 Connection to the external service has been lost. | 2018-02-13 12:53:15 CQG WebSocket socket (37) | Write in progress. Shutdown being delayed. | 2018-02-13 12:53:15 CQG WebSocket socket (37) | Sending bytes from final send buffer: 8 | 2018-02-13 12:53:15 CQG WebSocket socket (37) | Write has completed. Shutdown being performed. | 2018-02-13 12:53:15 CQG WebSocket socket (37) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:53:15 CQG WebSocket socket (37) | Socket gracefully closed by remote side. | 2018-02-13 12:53:15 CQG WebSocket socket (37) | Closed. | 2018-02-13 12:53:15 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:53:18 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:53:18 F.US.YMH18 #5 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:53:24 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:53:24 CQG FIX Trading | Disconnected. | 2018-02-13 12:53:28 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 12:53:28 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 12:53:34 CQG FIX socket (42) | Creating socket. Using TLS 1.2. | 2018-02-13 12:53:34 CQG FIX socket (42) | Connecting to IP: 208.48.16.214. | 2018-02-13 12:53:34 CQG FIX: Sending the Logon message. | 2018-02-13 12:53:37 CQG FIX Trading | Connected to trading server. | 2018-02-13 12:53:38 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 12:53:38 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 12:53:38 CQG WebSocket socket (44) | Creating socket. Using TLS 1.2. | 2018-02-13 12:53:38 CQG WebSocket socket (44) | Connecting to IP: 208.48.16.35. | 2018-02-13 12:53:38 CQG WebSocket | Opening WebSocket. | 2018-02-13 12:53:38 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 12:53:38 CQG FIX | FCM name: AMP | 2018-02-13 12:53:38 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 12:53:39 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 12:53:39 CQG WebSocket | Header line. Sec-WebSocket-Accept: C5RdxiWA+bb84r3Bl9mJKLDmk+c= | 2018-02-13 12:53:39 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 12:53:39 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 12:53:39 CQG WebSocket | Header line. | 2018-02-13 12:53:39 CQG WebSocket | Web socket state is now open. | 2018-02-13 12:53:39 CQG FIX Trading | WebSocket connected. | 2018-02-13 12:53:39 CQG FIX Trading | Sending market data logon message. | 2018-02-13 12:53:39 CQG FIX Trading | Logon successful. Session Token = c2UCjLrPFBlVAMOuHd1dyk8mwjqxX95E5a9TnwrdpUoAxSCQTHB5kUxGfM2vr5+zFWMVwPBsnXo | 2018-02-13 12:53:39 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 12:53:42 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 2 | 2018-02-13 12:53:42 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 701535 | 2018-02-13 12:53:42 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 2 | 2018-02-13 12:53:42 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 1 | 2018-02-13 12:53:42 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 701536 | 2018-02-13 12:53:42 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 1 | 2018-02-13 12:53:42 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 12:53:42 Delaying start of download for F.US.CLEH18 | 2018-02-13 12:53:42 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 701535. Contract ID: 1. | 2018-02-13 12:53:42 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 12:53:42 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 701536. Contract ID: 2. | 2018-02-13 12:53:42 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 12:53:42 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 3 | 2018-02-13 12:53:42 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 701537 | 2018-02-13 12:53:42 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 3 | 2018-02-13 12:53:42 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 4 | 2018-02-13 12:53:42 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 701538 | 2018-02-13 12:53:42 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 4 | 2018-02-13 12:53:42 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 5 | 2018-02-13 12:53:42 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 701539 | 2018-02-13 12:53:42 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 5 | 2018-02-13 12:53:42 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 6 | 2018-02-13 12:53:42 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 701540 | 2018-02-13 12:53:42 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 6 | 2018-02-13 12:53:42 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 7 | 2018-02-13 12:53:42 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 701541 | 2018-02-13 12:53:42 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 7 | 2018-02-13 12:53:42 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 8 | 2018-02-13 12:53:42 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 701542 | 2018-02-13 12:53:42 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 8 | 2018-02-13 12:53:42 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 9 | 2018-02-13 12:53:42 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 701543 | 2018-02-13 12:53:42 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 9 | 2018-02-13 12:53:42 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 12:53:42 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 701537. Contract ID: 3. | 2018-02-13 12:53:42 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 12:53:42 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 12:53:42 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 701538. Contract ID: 4. | 2018-02-13 12:53:43 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 12:53:43 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 701539. Contract ID: 5. | 2018-02-13 12:53:43 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 12:53:43 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 701540. Contract ID: 6. | 2018-02-13 12:53:43 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 12:53:43 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 701541. Contract ID: 7. | 2018-02-13 12:53:43 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 12:53:43 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 701542. Contract ID: 8. | 2018-02-13 12:53:43 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 12:53:43 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 701543. Contract ID: 9. | 2018-02-13 12:53:43 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 12:53:43 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 10 | 2018-02-13 12:53:44 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 701544 | 2018-02-13 12:53:44 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 10 | 2018-02-13 12:53:44 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 12 | 2018-02-13 12:53:44 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 701545 | 2018-02-13 12:53:44 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 12 | 2018-02-13 12:53:44 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 11 | 2018-02-13 12:53:44 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 701546 | 2018-02-13 12:53:44 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 11 | 2018-02-13 12:53:44 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 13 | 2018-02-13 12:53:44 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 701547 | 2018-02-13 12:53:44 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 13 | 2018-02-13 12:53:44 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 701544. Contract ID: 10. | 2018-02-13 12:53:44 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 12:53:44 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 701545. Contract ID: 11. | 2018-02-13 12:53:44 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 12:53:44 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 701546. Contract ID: 12. | 2018-02-13 12:53:44 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 12:53:44 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 701547. Contract ID: 13. | 2018-02-13 12:53:44 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 12:53:44 HD Request # 20 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 12:53:47 HD Request # 20 | Download start date-time: 2018-02-13 12:53:13.000 | 2018-02-13 12:53:47 HD Request # 20 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 12:53:47 Socket (45) | Creating socket. | 2018-02-13 12:53:47 Socket (45) | Connecting to IP: 192.81.56.146. | 2018-02-13 12:53:47 HD Request # 20 | Setting DTC encoding to Binary VLS | 2018-02-13 12:53:47 HD Request # 20 | Sending historical data logon request message. | 2018-02-13 12:53:47 HD Request # 20 | Requesting Intraday data. Start date-time: 2018-02-13 12:53:13. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 12:53:47 HD Request # 20 | Decompressing data. | 2018-02-13 12:53:47 HD Request # 20 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 12:53:13 | 2018-02-13 12:53:47 HD Request # 20 | Timestamp of first Intraday data file record written: 2018-02-13 12:53:15 | 2018-02-13 12:53:47 Socket (45) | Initiating close of socket by core. | 2018-02-13 12:53:47 Socket (45) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:53:47 Socket (45) | Socket gracefully closed by remote side. | 2018-02-13 12:53:47 Socket (45) | Closed. | 2018-02-13 12:53:47 Historical data download thread signaled to stop. | 2018-02-13 12:53:48 HD Request # 20 | Received 140 records from 2018-02-13 12:53:13 to 2018-02-13 12:53:45 (32.0 seconds) and wrote 139 records for F.US.CLEH18 | 2018-02-13 12:53:48 HD Request # 20 | Completion time: 0s | 2018-02-13 12:53:48 HD Request # 20 | Intraday data download complete for F.US.CLEH18. Unique request ID: 19 | 2018-02-13 12:53:48 Removed historical data download ID 19 | 2018-02-13 12:53:48 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 12:53:48 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 12:53:48 Delaying start of download for F.US.RTYH18 | 2018-02-13 12:53:48 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:53:48 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:53:48 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:53:48 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:53:49 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:53:54 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:53:54 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:53:54 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 12:53:54 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:53:54 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 12:53:55 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 12:53:56 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 12:53:56 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 12:53:56 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 12:53:56 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 12:53:56 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 12:53:56 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 12:53:56 HD Request # 21 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 12:53:59 HD Request # 21 | Download start date-time: 2018-02-13 12:53:09.000 | 2018-02-13 12:53:59 HD Request # 21 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 12:53:59 Socket (46) | Creating socket. | 2018-02-13 12:53:59 Socket (46) | Connecting to IP: 65.182.172.42. | 2018-02-13 12:53:59 HD Request # 21 | Setting DTC encoding to Binary VLS | 2018-02-13 12:53:59 HD Request # 21 | Sending historical data logon request message. | 2018-02-13 12:53:59 HD Request # 21 | Requesting Intraday data. Start date-time: 2018-02-13 12:53:09. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 12:54:00 HD Request # 21 | Decompressing data. | 2018-02-13 12:54:00 HD Request # 21 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 12:53:09 | 2018-02-13 12:54:00 HD Request # 21 | Timestamp of first Intraday data file record written: 2018-02-13 12:53:11 | 2018-02-13 12:54:00 Socket (46) | Initiating close of socket by core. | 2018-02-13 12:54:00 Socket (46) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:54:00 Socket (46) | Socket gracefully closed by remote side. | 2018-02-13 12:54:00 Socket (46) | Closed. | 2018-02-13 12:54:00 Historical data download thread signaled to stop. | 2018-02-13 12:54:00 HD Request # 21 | Received 74 records from 2018-02-13 12:53:09 to 2018-02-13 12:53:59 (50.0 seconds) and wrote 68 records for F.US.RTYH18 | 2018-02-13 12:54:00 Added 6 Time and Sales records to Intraday data file for F.US.RTYH18 after download. | 2018-02-13 12:54:00 HD Request # 21 | Completion time: 0s | 2018-02-13 12:54:00 HD Request # 21 | Intraday data download complete for F.US.RTYH18. Unique request ID: 20 | 2018-02-13 12:54:00 Removed historical data download ID 20 | 2018-02-13 12:54:00 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 12:54:00 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 12:54:00 HD Request # 22 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 12:54:00 HD Request # 22 | Download start date-time: 2018-02-13 12:53:11.000 | 2018-02-13 12:54:00 HD Request # 22 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 12:54:00 Socket (47) | Creating socket. | 2018-02-13 12:54:00 Socket (47) | Connecting to IP: 192.81.56.146. | 2018-02-13 12:54:00 HD Request # 22 | Setting DTC encoding to Binary VLS | 2018-02-13 12:54:00 HD Request # 22 | Sending historical data logon request message. | 2018-02-13 12:54:00 HD Request # 22 | Requesting Intraday data. Start date-time: 2018-02-13 12:53:11. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 12:54:00 HD Request # 22 | Decompressing data. | 2018-02-13 12:54:00 HD Request # 22 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 12:53:11 | 2018-02-13 12:54:00 HD Request # 22 | Timestamp of first Intraday data file record written: 2018-02-13 12:53:17 | 2018-02-13 12:54:00 Socket (47) | Initiating close of socket by core. | 2018-02-13 12:54:00 Socket (47) | Shutdown started. Waiting for graceful close. | 2018-02-13 12:54:00 Socket (47) | Socket gracefully closed by remote side. | 2018-02-13 12:54:00 Socket (47) | Closed. | 2018-02-13 12:54:00 Historical data download thread signaled to stop. | 2018-02-13 12:54:01 HD Request # 22 | Received 291 records from 2018-02-13 12:53:11 to 2018-02-13 12:53:59 (48.0 seconds) and wrote 287 records for F.US.YMH18 | 2018-02-13 12:54:01 Added 2 Time and Sales records to Intraday data file for F.US.YMH18 after download. | 2018-02-13 12:54:01 HD Request # 22 | Completion time: 2s | 2018-02-13 12:54:01 HD Request # 22 | Intraday data download complete for F.US.YMH18. Unique request ID: 21 | 2018-02-13 12:54:01 Removed historical data download ID 21 | 2018-02-13 12:54:01 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 12:54:01 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 12:54:01 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:54:02 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:54:02 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:54:02 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:54:02 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:54:02 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:54:02 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:54:02 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 12:54:04 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 12:54:04 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:54:07 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:54:07 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:54:10 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:54:10 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:54:17 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:54:17 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:54:17 F.US.YMH18 #5 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:54:17 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:54:17 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:54:41 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 12:54:42 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:54:48 Chart #4 has tagged chart #5 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 12:54:55 F.US.YMH18 #5 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 12:54:55 |
| [2018-02-13 22:03:39] |
| User925794 - Posts: 28 |
The event has repeated 50 times between 12:46 and 15:28 Thanks. Reading Internal Order ID file. | 2018-02-13 12:43:34 Reading Trade Orders file. | 2018-02-13 12:43:34 Reading Trade Positions file. | 2018-02-13 12:43:34 Listening on UDP port 22903. | 2018-02-13 12:43:34 Software version: 1700 | 2018-02-13 12:43:34 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 14:53:02 CQG FIX socket (289) | Creating socket. Using TLS 1.2. | 2018-02-13 14:53:02 CQG FIX socket (289) | Connecting to IP: 208.48.16.214. | 2018-02-13 14:53:02 CQG FIX: Sending the Logon message. | 2018-02-13 14:53:06 CQG FIX Trading | Connected to trading server. | 2018-02-13 14:53:06 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 14:53:06 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 14:53:06 CQG WebSocket socket (290) | Creating socket. Using TLS 1.2. | 2018-02-13 14:53:06 CQG WebSocket socket (290) | Connecting to IP: 208.48.16.35. | 2018-02-13 14:53:06 CQG FIX | FCM name: AMP | 2018-02-13 14:53:07 CQG WebSocket | Opening WebSocket. | 2018-02-13 14:53:07 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 14:53:07 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 14:53:08 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 14:53:08 CQG WebSocket | Header line. Sec-WebSocket-Accept: wtLfsPXB8vS5UzJXrjS1n0Kpt+g= | 2018-02-13 14:53:08 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 14:53:08 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 14:53:08 CQG WebSocket | Header line. | 2018-02-13 14:53:08 CQG WebSocket | Web socket state is now open. | 2018-02-13 14:53:08 CQG FIX Trading | WebSocket connected. | 2018-02-13 14:53:08 CQG FIX Trading | Sending market data logon message. | 2018-02-13 14:53:08 CQG FIX Trading | Logon successful. Session Token = piu7hPPkZVdpEV0Q8GhpdRdTogkgZKG8n9wZJ5V3vaIeNodgtWPmgUBdwEV2gREGnM0t/BQpuFR | 2018-02-13 14:53:09 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 14:53:13 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 2 | 2018-02-13 14:53:13 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 701873 | 2018-02-13 14:53:13 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 2 | 2018-02-13 14:53:13 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 1 | 2018-02-13 14:53:13 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 701874 | 2018-02-13 14:53:13 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 1 | 2018-02-13 14:53:13 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 14:53:13 Delaying start of download for F.US.CLEH18 | 2018-02-13 14:53:13 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 3 | 2018-02-13 14:53:13 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 701875 | 2018-02-13 14:53:13 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 3 | 2018-02-13 14:53:13 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 14:53:13 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 701873. Contract ID: 1. | 2018-02-13 14:53:13 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 14:53:13 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 701874. Contract ID: 2. | 2018-02-13 14:53:13 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 14:53:13 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 701875. Contract ID: 3. | 2018-02-13 14:53:13 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 14:53:13 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 4 | 2018-02-13 14:53:13 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 701876 | 2018-02-13 14:53:13 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 4 | 2018-02-13 14:53:13 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 14:53:13 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 701876. Contract ID: 4. | 2018-02-13 14:53:13 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 14:53:13 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 5 | 2018-02-13 14:53:14 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 701877 | 2018-02-13 14:53:14 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 5 | 2018-02-13 14:53:14 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 7 | 2018-02-13 14:53:14 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 701878 | 2018-02-13 14:53:14 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 7 | 2018-02-13 14:53:14 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 6 | 2018-02-13 14:53:14 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 701879 | 2018-02-13 14:53:14 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 6 | 2018-02-13 14:53:14 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 8 | 2018-02-13 14:53:14 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 701880 | 2018-02-13 14:53:14 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 8 | 2018-02-13 14:53:14 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 9 | 2018-02-13 14:53:14 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 701881 | 2018-02-13 14:53:14 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 9 | 2018-02-13 14:53:14 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 10 | 2018-02-13 14:53:14 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 701882 | 2018-02-13 14:53:14 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 10 | 2018-02-13 14:53:14 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 11 | 2018-02-13 14:53:14 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 701883 | 2018-02-13 14:53:14 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 11 | 2018-02-13 14:53:14 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 701877. Contract ID: 5. | 2018-02-13 14:53:15 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 14:53:15 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 701878. Contract ID: 6. | 2018-02-13 14:53:15 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 14:53:15 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 701879. Contract ID: 7. | 2018-02-13 14:53:15 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 14:53:15 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 701880. Contract ID: 8. | 2018-02-13 14:53:15 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 14:53:15 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 701881. Contract ID: 9. | 2018-02-13 14:53:15 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 14:53:15 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 701882. Contract ID: 10. | 2018-02-13 14:53:15 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 14:53:15 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 701883. Contract ID: 11. | 2018-02-13 14:53:15 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 14:53:15 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 12 | 2018-02-13 14:53:15 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 701884 | 2018-02-13 14:53:15 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 12 | 2018-02-13 14:53:15 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 13 | 2018-02-13 14:53:15 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 701885 | 2018-02-13 14:53:15 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 13 | 2018-02-13 14:53:15 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 701884. Contract ID: 12. | 2018-02-13 14:53:16 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 14:53:16 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 701885. Contract ID: 13. | 2018-02-13 14:53:16 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 14:53:16 Delaying start of download for F.US.CLEH18 | 2018-02-13 14:53:17 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 14:53:21 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 14:53:21 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 14:53:21 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 14:53:21 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 14:53:21 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 14:53:21 HD Request # 98 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 14:53:23 HD Request # 98 | Download start date-time: 2018-02-13 14:52:40.000 | 2018-02-13 14:53:23 HD Request # 98 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 14:53:23 Socket (291) | Creating socket. | 2018-02-13 14:53:23 Socket (291) | Connecting to IP: 192.81.56.146. | 2018-02-13 14:53:23 HD Request # 98 | Setting DTC encoding to Binary VLS | 2018-02-13 14:53:23 HD Request # 98 | Sending historical data logon request message. | 2018-02-13 14:53:23 HD Request # 98 | Requesting Intraday data. Start date-time: 2018-02-13 14:52:40. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 14:53:23 HD Request # 98 | Decompressing data. | 2018-02-13 14:53:23 HD Request # 98 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 14:52:40 | 2018-02-13 14:53:23 HD Request # 98 | Timestamp of first Intraday data file record written: 2018-02-13 14:52:40 | 2018-02-13 14:53:23 Socket (291) | Initiating close of socket by core. | 2018-02-13 14:53:23 Socket (291) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:53:23 Socket (291) | Socket gracefully closed by remote side. | 2018-02-13 14:53:23 Socket (291) | Closed. | 2018-02-13 14:53:23 Historical data download thread signaled to stop. | 2018-02-13 14:53:24 HD Request # 98 | Received 16 records from 2018-02-13 14:52:40 to 2018-02-13 14:53:01 (21.0 seconds) and wrote 15 records for F.US.CLEH18 | 2018-02-13 14:53:24 Added 2 Time and Sales records to Intraday data file for F.US.CLEH18 after download. | 2018-02-13 14:53:24 HD Request # 98 | Completion time: 1s | 2018-02-13 14:53:24 HD Request # 98 | Intraday data download complete for F.US.CLEH18. Unique request ID: 97 | 2018-02-13 14:53:24 Removed historical data download ID 97 | 2018-02-13 14:53:24 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 14:53:24 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 14:53:24 HD Request # 99 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 14:53:24 HD Request # 99 | Download start date-time: 2018-02-13 14:52:44.000 | 2018-02-13 14:53:24 HD Request # 99 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 14:53:24 Socket (292) | Creating socket. | 2018-02-13 14:53:24 Socket (292) | Connecting to IP: 65.182.172.42. | 2018-02-13 14:53:24 HD Request # 99 | Setting DTC encoding to Binary VLS | 2018-02-13 14:53:24 HD Request # 99 | Sending historical data logon request message. | 2018-02-13 14:53:24 HD Request # 99 | Requesting Intraday data. Start date-time: 2018-02-13 14:52:44. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 14:53:24 HD Request # 99 | Decompressing data. | 2018-02-13 14:53:24 HD Request # 99 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 14:52:44 | 2018-02-13 14:53:24 HD Request # 99 | Timestamp of first Intraday data file record written: 2018-02-13 14:52:44 | 2018-02-13 14:53:24 Socket (292) | Initiating close of socket by core. | 2018-02-13 14:53:24 Socket (292) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:53:24 Socket (292) | Socket gracefully closed by remote side. | 2018-02-13 14:53:24 Socket (292) | Closed. | 2018-02-13 14:53:24 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:53:24 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:53:24 Historical data download thread signaled to stop. | 2018-02-13 14:53:24 HD Request # 99 | Received 346 records from 2018-02-13 14:52:44 to 2018-02-13 14:53:22 (38.0 seconds) and wrote 314 records for F.US.YMH18 | 2018-02-13 14:53:24 Added 5 Time and Sales records to Intraday data file for F.US.YMH18 after download. | 2018-02-13 14:53:24 HD Request # 99 | Completion time: 0s | 2018-02-13 14:53:24 HD Request # 99 | Intraday data download complete for F.US.YMH18. Unique request ID: 98 | 2018-02-13 14:53:24 Removed historical data download ID 98 | 2018-02-13 14:53:24 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 14:53:24 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 14:53:24 HD Request # 100 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 14:53:24 HD Request # 100 | Download start date-time: 2018-02-13 14:52:44.000 | 2018-02-13 14:53:24 HD Request # 100 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 14:53:24 Socket (293) | Creating socket. | 2018-02-13 14:53:24 Socket (293) | Connecting to IP: 192.81.56.146. | 2018-02-13 14:53:24 HD Request # 100 | Setting DTC encoding to Binary VLS | 2018-02-13 14:53:25 HD Request # 100 | Sending historical data logon request message. | 2018-02-13 14:53:25 HD Request # 100 | Requesting Intraday data. Start date-time: 2018-02-13 14:52:44. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 14:53:25 HD Request # 100 | Decompressing data. | 2018-02-13 14:53:25 HD Request # 100 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 14:52:44 | 2018-02-13 14:53:25 HD Request # 100 | Timestamp of first Intraday data file record written: 2018-02-13 14:52:44 | 2018-02-13 14:53:25 Socket (293) | Initiating close of socket by core. | 2018-02-13 14:53:25 Socket (293) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:53:25 Socket (293) | Socket gracefully closed by remote side. | 2018-02-13 14:53:25 Socket (293) | Closed. | 2018-02-13 14:53:25 Historical data download thread signaled to stop. | 2018-02-13 14:53:25 HD Request # 100 | Received 117 records from 2018-02-13 14:52:44 to 2018-02-13 14:53:22 (38.0 seconds) and wrote 106 records for F.US.RTYH18 | 2018-02-13 14:53:25 Added 12 Time and Sales records to Intraday data file for F.US.RTYH18 after download. | 2018-02-13 14:53:25 HD Request # 100 | Completion time: 1s | 2018-02-13 14:53:25 HD Request # 100 | Intraday data download complete for F.US.RTYH18. Unique request ID: 99 | 2018-02-13 14:53:25 Removed historical data download ID 99 | 2018-02-13 14:53:25 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 14:53:25 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 14:53:25 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:53:25 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 14:53:26 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 14:53:26 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:53:27 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:53:27 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 14:53:27 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 14:53:29 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:53:51 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:53:51 Chart #2 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:53:51 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:53:51 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:53:51 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:53:51 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:53:51 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 14:53:52 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:53:59 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:54:00 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:54:00 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:54:00 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:54:00 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:54:04 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:54:04 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:54:04 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:54:04 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:54:06 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:54:06 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 14:54:08 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 14:54:32 CQG WebSocket socket (290) | Adding bytes from final send buffer from buffered socket: 22 | 2018-02-13 14:54:32 CQG WebSocket socket (290) | Initiating close of socket by core. | 2018-02-13 14:54:32 CQG WebSocket | WebSocket closed. | 2018-02-13 14:54:32 CQG WebSocket socket (290) | Write in progress. Shutdown being delayed. | 2018-02-13 14:54:32 CQG FIX Trading | WebSocket closed. | 2018-02-13 14:54:32 Connection to the external service has been lost. | 2018-02-13 14:54:32 CQG WebSocket socket (290) | Sending bytes from final send buffer: 22 | 2018-02-13 14:54:32 CQG WebSocket socket (290) | Write has completed. Shutdown being performed. | 2018-02-13 14:54:32 CQG WebSocket socket (290) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:54:32 CQG WebSocket socket (290) | Socket gracefully closed by remote side. | 2018-02-13 14:54:33 CQG WebSocket socket (290) | Closed. | 2018-02-13 14:54:33 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:54:36 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:54:37 CQG FIX: DisconnectFIX called. | 2018-02-13 14:54:44 CQG FIX: Sending a Logout message. | 2018-02-13 14:54:44 CQG FIX Trading | Disconnected. | 2018-02-13 14:54:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 14:54:44 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 14:54:44 CQG FIX socket (289) | Initiating close of socket by core. | 2018-02-13 14:54:44 CQG FIX: Disconnected. | 2018-02-13 14:54:44 CQG FIX socket (289) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:54:44 CQG FIX socket (289) | Socket gracefully closed by remote side. | 2018-02-13 14:54:44 CQG FIX socket (289) | Closed. | 2018-02-13 14:54:44 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 14:54:50 CQG FIX socket (295) | Creating socket. Using TLS 1.2. | 2018-02-13 14:54:50 CQG FIX socket (295) | Connecting to IP: 208.48.16.214. | 2018-02-13 14:54:50 CQG FIX: Sending the Logon message. | 2018-02-13 14:54:54 CQG FIX Trading | Connected to trading server. | 2018-02-13 14:54:55 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 14:54:55 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 14:54:55 CQG WebSocket socket (296) | Creating socket. Using TLS 1.2. | 2018-02-13 14:54:55 CQG WebSocket socket (296) | Connecting to IP: 208.48.16.35. | 2018-02-13 14:54:55 CQG FIX | FCM name: AMP | 2018-02-13 14:54:55 CQG WebSocket | Opening WebSocket. | 2018-02-13 14:54:55 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 14:54:55 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 14:54:56 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 14:54:56 CQG WebSocket | Header line. Sec-WebSocket-Accept: 7pmtXftFOkJ6dVyX/nB14M/gbMQ= | 2018-02-13 14:54:56 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 14:54:56 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 14:54:56 CQG WebSocket | Header line. | 2018-02-13 14:54:56 CQG WebSocket | Web socket state is now open. | 2018-02-13 14:54:56 CQG FIX Trading | WebSocket connected. | 2018-02-13 14:54:56 CQG FIX Trading | Sending market data logon message. | 2018-02-13 14:54:56 CQG FIX Trading | Logon successful. Session Token = a4wFo9EzF3AMlzxvIRQ5erYEZrvooGXDNQlm87Y+rpkkn8B3kqmZHFCEViwGG2UG5M4CCATqNQ4 | 2018-02-13 14:54:57 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 14:55:00 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 1 | 2018-02-13 14:55:00 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 701886 | 2018-02-13 14:55:00 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 1 | 2018-02-13 14:55:00 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 14:55:00 Delaying start of download for F.US.YMH18 | 2018-02-13 14:55:00 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 3 | 2018-02-13 14:55:00 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 701887 | 2018-02-13 14:55:00 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 3 | 2018-02-13 14:55:00 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 2 | 2018-02-13 14:55:00 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 701888 | 2018-02-13 14:55:00 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 2 | 2018-02-13 14:55:00 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 14:55:00 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 4 | 2018-02-13 14:55:00 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 701889 | 2018-02-13 14:55:00 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 4 | 2018-02-13 14:55:00 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 14:55:00 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 701886. Contract ID: 1. | 2018-02-13 14:55:00 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 14:55:00 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 701887. Contract ID: 2. | 2018-02-13 14:55:00 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 14:55:00 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 701888. Contract ID: 3. | 2018-02-13 14:55:00 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 14:55:00 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 701889. Contract ID: 4. | 2018-02-13 14:55:00 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 14:55:00 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 5 | 2018-02-13 14:55:03 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 701890 | 2018-02-13 14:55:03 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 5 | 2018-02-13 14:55:03 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 7 | 2018-02-13 14:55:03 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 701891 | 2018-02-13 14:55:03 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 7 | 2018-02-13 14:55:03 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 6 | 2018-02-13 14:55:03 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 701892 | 2018-02-13 14:55:03 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 6 | 2018-02-13 14:55:03 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 8 | 2018-02-13 14:55:03 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 701893 | 2018-02-13 14:55:03 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 8 | 2018-02-13 14:55:03 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 9 | 2018-02-13 14:55:03 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 701894 | 2018-02-13 14:55:03 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 9 | 2018-02-13 14:55:03 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 10 | 2018-02-13 14:55:03 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 701895 | 2018-02-13 14:55:03 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 10 | 2018-02-13 14:55:03 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 11 | 2018-02-13 14:55:03 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 701896 | 2018-02-13 14:55:03 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 11 | 2018-02-13 14:55:03 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 12 | 2018-02-13 14:55:03 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 701897 | 2018-02-13 14:55:03 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 12 | 2018-02-13 14:55:03 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 13 | 2018-02-13 14:55:03 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 701898 | 2018-02-13 14:55:03 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 13 | 2018-02-13 14:55:03 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 701890. Contract ID: 5. | 2018-02-13 14:55:04 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 14:55:04 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 701891. Contract ID: 6. | 2018-02-13 14:55:04 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 14:55:04 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 701892. Contract ID: 7. | 2018-02-13 14:55:04 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 14:55:04 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 701893. Contract ID: 8. | 2018-02-13 14:55:04 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 14:55:04 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 701894. Contract ID: 9. | 2018-02-13 14:55:04 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 14:55:04 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 701895. Contract ID: 10. | 2018-02-13 14:55:04 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 14:55:04 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 701896. Contract ID: 11. | 2018-02-13 14:55:04 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 14:55:04 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 701897. Contract ID: 12. | 2018-02-13 14:55:04 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 14:55:04 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 701898. Contract ID: 13. | 2018-02-13 14:55:04 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 14:55:04 HD Request # 101 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 14:55:05 HD Request # 101 | Download start date-time: 2018-02-13 14:54:31.000 | 2018-02-13 14:55:05 HD Request # 101 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 14:55:05 Socket (297) | Creating socket. | 2018-02-13 14:55:05 Socket (297) | Connecting to IP: 65.182.172.42. | 2018-02-13 14:55:05 HD Request # 101 | Setting DTC encoding to Binary VLS | 2018-02-13 14:55:05 HD Request # 101 | Sending historical data logon request message. | 2018-02-13 14:55:05 HD Request # 101 | Requesting Intraday data. Start date-time: 2018-02-13 14:54:31. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 14:55:05 HD Request # 101 | Decompressing data. | 2018-02-13 14:55:05 HD Request # 101 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 14:54:31 | 2018-02-13 14:55:05 HD Request # 101 | Timestamp of first Intraday data file record written: 2018-02-13 14:54:32 | 2018-02-13 14:55:05 Socket (297) | Initiating close of socket by core. | 2018-02-13 14:55:05 Socket (297) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:55:05 Socket (297) | Socket gracefully closed by remote side. | 2018-02-13 14:55:05 Socket (297) | Closed. | 2018-02-13 14:55:05 Historical data download thread signaled to stop. | 2018-02-13 14:55:06 HD Request # 101 | Received 288 records from 2018-02-13 14:54:31 to 2018-02-13 14:55:02 (31.0 seconds) and wrote 286 records for F.US.YMH18 | 2018-02-13 14:55:06 Added 22 Time and Sales records to Intraday data file for F.US.YMH18 after download. | 2018-02-13 14:55:06 HD Request # 101 | Completion time: 1s | 2018-02-13 14:55:06 HD Request # 101 | Intraday data download complete for F.US.YMH18. Unique request ID: 100 | 2018-02-13 14:55:06 Removed historical data download ID 100 | 2018-02-13 14:55:06 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 14:55:06 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 14:55:06 HD Request # 102 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 14:55:06 HD Request # 102 | Download start date-time: 2018-02-13 14:54:28.000 | 2018-02-13 14:55:06 HD Request # 102 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 14:55:06 Socket (298) | Creating socket. | 2018-02-13 14:55:06 Socket (298) | Connecting to IP: 192.81.56.146. | 2018-02-13 14:55:06 HD Request # 102 | Setting DTC encoding to Binary VLS | 2018-02-13 14:55:06 HD Request # 102 | Sending historical data logon request message. | 2018-02-13 14:55:06 HD Request # 102 | Requesting Intraday data. Start date-time: 2018-02-13 14:54:28. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 14:55:06 HD Request # 102 | Decompressing data. | 2018-02-13 14:55:06 HD Request # 102 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 14:54:28 | 2018-02-13 14:55:06 HD Request # 102 | Timestamp of first Intraday data file record written: 2018-02-13 14:54:36 | 2018-02-13 14:55:06 Socket (298) | Initiating close of socket by core. | 2018-02-13 14:55:06 Socket (298) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:55:06 Socket (298) | Socket gracefully closed by remote side. | 2018-02-13 14:55:06 Socket (298) | Closed. | 2018-02-13 14:55:06 Historical data download thread signaled to stop. | 2018-02-13 14:55:06 HD Request # 102 | Received 32 records from 2018-02-13 14:54:28 to 2018-02-13 14:55:02 (34.0 seconds) and wrote 31 records for F.US.CLEH18 | 2018-02-13 14:55:06 Added 3 Time and Sales records to Intraday data file for F.US.CLEH18 after download. | 2018-02-13 14:55:06 HD Request # 102 | Completion time: 0s | 2018-02-13 14:55:06 HD Request # 102 | Intraday data download complete for F.US.CLEH18. Unique request ID: 101 | 2018-02-13 14:55:06 Removed historical data download ID 101 | 2018-02-13 14:55:06 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 14:55:06 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 14:55:06 HD Request # 103 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 14:55:06 HD Request # 103 | Download start date-time: 2018-02-13 14:54:31.000 | 2018-02-13 14:55:06 HD Request # 103 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 14:55:06 Socket (299) | Creating socket. | 2018-02-13 14:55:06 Socket (299) | Connecting to IP: 65.182.172.42. | 2018-02-13 14:55:06 HD Request # 103 | Setting DTC encoding to Binary VLS | 2018-02-13 14:55:06 HD Request # 103 | Sending historical data logon request message. | 2018-02-13 14:55:06 HD Request # 103 | Requesting Intraday data. Start date-time: 2018-02-13 14:54:31. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 14:55:06 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:55:06 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:55:06 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 14:55:06 HD Request # 103 | Decompressing data. | 2018-02-13 14:55:07 HD Request # 103 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 14:54:31 | 2018-02-13 14:55:07 HD Request # 103 | Timestamp of first Intraday data file record written: 2018-02-13 14:54:32 | 2018-02-13 14:55:07 Socket (299) | Initiating close of socket by core. | 2018-02-13 14:55:07 Socket (299) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:55:07 Socket (299) | Socket gracefully closed by remote side. | 2018-02-13 14:55:07 Socket (299) | Closed. | 2018-02-13 14:55:07 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 14:55:07 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:55:31 Historical data download thread signaled to stop. | 2018-02-13 14:55:31 HD Request # 103 | Received 155 records from 2018-02-13 14:54:31 to 2018-02-13 14:55:04 (33.0 seconds) and wrote 144 records for F.US.RTYH18 | 2018-02-13 14:55:31 Added 147 Time and Sales records to Intraday data file for F.US.RTYH18 after download. | 2018-02-13 14:55:31 HD Request # 103 | Completion time: 24s | 2018-02-13 14:55:31 HD Request # 103 | Intraday data download complete for F.US.RTYH18. Unique request ID: 102 | 2018-02-13 14:55:31 Removed historical data download ID 102 | 2018-02-13 14:55:31 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 14:55:31 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 14:55:31 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 14:55:31 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 14:55:31 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:55:38 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:55:38 Chart #2 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:55:38 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:55:38 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:55:38 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:55:38 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:55:38 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:55:39 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 14:55:39 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 14:55:39 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 14:55:39 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 14:55:39 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 14:55:39 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 14:55:39 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:55:39 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:55:39 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:55:39 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 14:55:40 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:55:44 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:55:44 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:55:44 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:55:44 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:55:44 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:55:44 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:55:46 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:55:46 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 14:55:48 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 14:56:12 CQG WebSocket socket (296) | Adding bytes from final send buffer from buffered socket: 22 | 2018-02-13 14:56:12 CQG WebSocket socket (296) | Initiating close of socket by core. | 2018-02-13 14:56:12 CQG WebSocket | WebSocket closed. | 2018-02-13 14:56:12 CQG FIX Trading | WebSocket closed. | 2018-02-13 14:56:12 Connection to the external service has been lost. | 2018-02-13 14:56:12 CQG WebSocket socket (296) | Sending bytes from final send buffer: 22 | 2018-02-13 14:56:12 CQG WebSocket socket (296) | Write in progress. Shutdown being delayed. | 2018-02-13 14:56:12 CQG WebSocket socket (296) | Write has completed. Shutdown being performed. | 2018-02-13 14:56:12 CQG WebSocket socket (296) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:56:12 CQG WebSocket socket (296) | Socket gracefully closed by remote side. | 2018-02-13 14:56:12 CQG WebSocket socket (296) | Closed. | 2018-02-13 14:56:12 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 14:56:16 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:56:23 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:56:23 CQG FIX: DisconnectFIX called. | 2018-02-13 14:56:30 CQG FIX: Sending a Logout message. | 2018-02-13 14:56:30 CQG FIX Trading | Disconnected. | 2018-02-13 14:56:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 14:56:30 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 14:56:30 CQG FIX socket (295) | Initiating close of socket by core. | 2018-02-13 14:56:30 CQG FIX: Disconnected. | 2018-02-13 14:56:30 CQG FIX socket (295) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:56:30 CQG FIX socket (295) | Socket gracefully closed by remote side. | 2018-02-13 14:56:30 CQG FIX socket (295) | Closed. | 2018-02-13 14:56:30 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 14:56:36 CQG FIX socket (301) | Creating socket. Using TLS 1.2. | 2018-02-13 14:56:36 CQG FIX socket (301) | Connecting to IP: 208.48.16.214. | 2018-02-13 14:56:36 CQG FIX: Sending the Logon message. | 2018-02-13 14:56:39 CQG FIX Trading | Connected to trading server. | 2018-02-13 14:56:40 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 14:56:40 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 14:56:40 CQG WebSocket socket (303) | Creating socket. Using TLS 1.2. | 2018-02-13 14:56:40 CQG WebSocket socket (303) | Connecting to IP: 208.48.16.35. | 2018-02-13 14:56:40 CQG FIX | FCM name: AMP | 2018-02-13 14:56:41 CQG WebSocket | Opening WebSocket. | 2018-02-13 14:56:41 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 14:56:41 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 14:56:41 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 14:56:41 CQG WebSocket | Header line. Sec-WebSocket-Accept: Ecv6hJyda3MEY4hVAjbUuKfdw0A= | 2018-02-13 14:56:41 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 14:56:41 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 14:56:41 CQG WebSocket | Header line. | 2018-02-13 14:56:41 CQG WebSocket | Web socket state is now open. | 2018-02-13 14:56:41 CQG FIX Trading | WebSocket connected. | 2018-02-13 14:56:41 CQG FIX Trading | Sending market data logon message. | 2018-02-13 14:56:41 CQG FIX Trading | Logon successful. Session Token = R2PSwqOtt9O8dPA7mU9uRyWRSkJa5LSv3x4/A20AisUbPfLnSKEjQjMsG8AAQGqK0m6rSXKii/G | 2018-02-13 14:56:42 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 14:56:45 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 1 | 2018-02-13 14:56:45 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 701899 | 2018-02-13 14:56:45 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 1 | 2018-02-13 14:56:45 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 14:56:45 Delaying start of download for F.US.RTYH18 | 2018-02-13 14:56:45 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 701899. Contract ID: 1. | 2018-02-13 14:56:45 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 14:56:45 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 3 | 2018-02-13 14:56:45 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 701900 | 2018-02-13 14:56:45 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 3 | 2018-02-13 14:56:45 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 2 | 2018-02-13 14:56:45 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 701901 | 2018-02-13 14:56:45 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 2 | 2018-02-13 14:56:45 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 14:56:45 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 4 | 2018-02-13 14:56:45 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 701902 | 2018-02-13 14:56:45 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 4 | 2018-02-13 14:56:45 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 14:56:45 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 701900. Contract ID: 2. | 2018-02-13 14:56:46 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 14:56:46 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 701901. Contract ID: 3. | 2018-02-13 14:56:46 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 14:56:46 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 701902. Contract ID: 4. | 2018-02-13 14:56:46 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 14:56:46 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 5 | 2018-02-13 14:56:46 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 701903 | 2018-02-13 14:56:46 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 5 | 2018-02-13 14:56:46 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 7 | 2018-02-13 14:56:46 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 701904 | 2018-02-13 14:56:46 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 7 | 2018-02-13 14:56:46 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 6 | 2018-02-13 14:56:46 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 701905 | 2018-02-13 14:56:46 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 6 | 2018-02-13 14:56:46 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 8 | 2018-02-13 14:56:46 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 701906 | 2018-02-13 14:56:46 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 8 | 2018-02-13 14:56:46 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 9 | 2018-02-13 14:56:46 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 701907 | 2018-02-13 14:56:46 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 9 | 2018-02-13 14:56:46 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 10 | 2018-02-13 14:56:46 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 701908 | 2018-02-13 14:56:46 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 10 | 2018-02-13 14:56:46 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 11 | 2018-02-13 14:56:46 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 701909 | 2018-02-13 14:56:46 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 11 | 2018-02-13 14:56:46 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 701903. Contract ID: 5. | 2018-02-13 14:56:47 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 14:56:47 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 701904. Contract ID: 6. | 2018-02-13 14:56:47 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 14:56:47 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 701905. Contract ID: 7. | 2018-02-13 14:56:47 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 14:56:47 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 701906. Contract ID: 8. | 2018-02-13 14:56:47 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 14:56:47 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 701907. Contract ID: 9. | 2018-02-13 14:56:47 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 14:56:47 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 701908. Contract ID: 10. | 2018-02-13 14:56:47 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 14:56:47 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 701909. Contract ID: 11. | 2018-02-13 14:56:47 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 14:56:47 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 12 | 2018-02-13 14:56:48 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 701910 | 2018-02-13 14:56:48 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 12 | 2018-02-13 14:56:48 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 13 | 2018-02-13 14:56:48 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 701911 | 2018-02-13 14:56:48 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 13 | 2018-02-13 14:56:48 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 701910. Contract ID: 12. | 2018-02-13 14:56:49 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 14:56:49 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 701911. Contract ID: 13. | 2018-02-13 14:56:49 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 14:56:49 HD Request # 104 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 14:56:50 HD Request # 104 | Download start date-time: 2018-02-13 14:56:10.000 | 2018-02-13 14:56:50 HD Request # 104 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 14:56:50 Socket (304) | Creating socket. | 2018-02-13 14:56:50 Socket (304) | Connecting to IP: 192.81.56.146. | 2018-02-13 14:56:50 HD Request # 104 | Setting DTC encoding to Binary VLS | 2018-02-13 14:56:50 HD Request # 104 | Sending historical data logon request message. | 2018-02-13 14:56:50 HD Request # 104 | Requesting Intraday data. Start date-time: 2018-02-13 14:56:10. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 14:56:50 HD Request # 104 | Decompressing data. | 2018-02-13 14:56:50 HD Request # 104 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 14:56:10 | 2018-02-13 14:56:50 HD Request # 104 | Timestamp of first Intraday data file record written: 2018-02-13 14:56:11 | 2018-02-13 14:56:50 Socket (304) | Initiating close of socket by core. | 2018-02-13 14:56:50 Socket (304) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:56:50 Socket (304) | Socket gracefully closed by remote side. | 2018-02-13 14:56:50 Socket (304) | Closed. | 2018-02-13 14:56:50 Historical data download thread signaled to stop. | 2018-02-13 14:56:51 HD Request # 104 | Received 299 records from 2018-02-13 14:56:10 to 2018-02-13 14:56:46 (36.0 seconds) and wrote 298 records for F.US.RTYH18 | 2018-02-13 14:56:51 Added 25 Time and Sales records to Intraday data file for F.US.RTYH18 after download. | 2018-02-13 14:56:51 HD Request # 104 | Completion time: 1s | 2018-02-13 14:56:51 HD Request # 104 | Intraday data download complete for F.US.RTYH18. Unique request ID: 103 | 2018-02-13 14:56:51 Removed historical data download ID 103 | 2018-02-13 14:56:51 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 14:56:51 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 14:56:51 Delaying start of download for F.US.CLEH18 | 2018-02-13 14:56:51 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:56:51 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:56:51 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:56:53 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 14:56:53 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:56:58 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 14:56:58 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 14:56:58 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 14:56:58 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 14:56:58 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 14:56:58 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 14:56:58 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:56:58 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:56:58 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:56:59 HD Request # 105 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 14:57:02 HD Request # 105 | Download start date-time: 2018-02-13 14:55:47.000 | 2018-02-13 14:57:02 HD Request # 105 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 14:57:02 Socket (305) | Creating socket. | 2018-02-13 14:57:02 Socket (305) | Connecting to IP: 65.182.172.42. | 2018-02-13 14:57:02 HD Request # 105 | Setting DTC encoding to Binary VLS | 2018-02-13 14:57:02 HD Request # 105 | Sending historical data logon request message. | 2018-02-13 14:57:02 HD Request # 105 | Requesting Intraday data. Start date-time: 2018-02-13 14:55:47. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 14:57:02 HD Request # 105 | Decompressing data. | 2018-02-13 14:57:02 HD Request # 105 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 14:55:47 | 2018-02-13 14:57:02 HD Request # 105 | Timestamp of first Intraday data file record written: 2018-02-13 14:56:17 | 2018-02-13 14:57:02 Socket (305) | Initiating close of socket by core. | 2018-02-13 14:57:02 Socket (305) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:57:02 Socket (305) | Socket gracefully closed by remote side. | 2018-02-13 14:57:02 Socket (305) | Closed. | 2018-02-13 14:57:02 Historical data download thread signaled to stop. | 2018-02-13 14:57:03 HD Request # 105 | Received 19 records from 2018-02-13 14:55:47 to 2018-02-13 14:57:01 (74.0 seconds) and wrote 18 records for F.US.CLEH18 | 2018-02-13 14:57:03 HD Request # 105 | Completion time: 2s | 2018-02-13 14:57:03 HD Request # 105 | Intraday data download complete for F.US.CLEH18. Unique request ID: 104 | 2018-02-13 14:57:03 Removed historical data download ID 104 | 2018-02-13 14:57:03 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 14:57:03 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 14:57:03 HD Request # 106 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 14:57:03 HD Request # 106 | Download start date-time: 2018-02-13 14:56:11.000 | 2018-02-13 14:57:03 HD Request # 106 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 14:57:03 Socket (306) | Creating socket. | 2018-02-13 14:57:03 Socket (306) | Connecting to IP: 192.81.56.146. | 2018-02-13 14:57:03 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:57:03 HD Request # 106 | Setting DTC encoding to Binary VLS | 2018-02-13 14:57:03 HD Request # 106 | Sending historical data logon request message. | 2018-02-13 14:57:03 HD Request # 106 | Requesting Intraday data. Start date-time: 2018-02-13 14:56:11. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 14:57:03 HD Request # 106 | Decompressing data. | 2018-02-13 14:57:03 HD Request # 106 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 14:56:11 | 2018-02-13 14:57:03 HD Request # 106 | Timestamp of first Intraday data file record written: 2018-02-13 14:56:11 | 2018-02-13 14:57:03 Socket (306) | Initiating close of socket by core. | 2018-02-13 14:57:03 Socket (306) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:57:03 Socket (306) | Socket gracefully closed by remote side. | 2018-02-13 14:57:03 Socket (306) | Closed. | 2018-02-13 14:57:03 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 14:57:05 Historical data download thread signaled to stop. | 2018-02-13 14:57:08 HD Request # 106 | Received 620 records from 2018-02-13 14:56:11 to 2018-02-13 14:57:00 (49.0 seconds) and wrote 618 records for F.US.YMH18 | 2018-02-13 14:57:08 Added 75 Time and Sales records to Intraday data file for F.US.YMH18 after download. | 2018-02-13 14:57:08 HD Request # 106 | Completion time: 4s | 2018-02-13 14:57:08 HD Request # 106 | Intraday data download complete for F.US.YMH18. Unique request ID: 105 | 2018-02-13 14:57:08 Removed historical data download ID 105 | 2018-02-13 14:57:08 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 14:57:08 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 14:57:08 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 14:57:08 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:57:09 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:57:09 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:57:10 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:57:11 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:57:11 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 14:57:11 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:57:36 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:57:36 Chart #2 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:57:36 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:57:36 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:57:36 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:57:36 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:57:36 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 14:57:36 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:57:43 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:57:44 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:57:48 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:57:48 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:57:49 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 14:57:51 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 14:58:15 CQG WebSocket socket (303) | Adding bytes from final send buffer from buffered socket: 22 | 2018-02-13 14:58:15 CQG WebSocket socket (303) | Initiating close of socket by core. | 2018-02-13 14:58:15 CQG WebSocket | WebSocket closed. | 2018-02-13 14:58:15 CQG FIX Trading | WebSocket closed. | 2018-02-13 14:58:15 Connection to the external service has been lost. | 2018-02-13 14:58:15 CQG WebSocket socket (303) | Write in progress. Shutdown being delayed. | 2018-02-13 14:58:15 CQG WebSocket socket (303) | Sending bytes from final send buffer: 22 | 2018-02-13 14:58:15 CQG WebSocket socket (303) | Write has completed. Shutdown being performed. | 2018-02-13 14:58:15 CQG WebSocket socket (303) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:58:15 CQG WebSocket socket (303) | Socket gracefully closed by remote side. | 2018-02-13 14:58:15 CQG WebSocket socket (303) | Closed. | 2018-02-13 14:58:15 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:58:18 CQG FIX: DisconnectFIX called. | 2018-02-13 14:58:22 CQG FIX: Sending a Logout message. | 2018-02-13 14:58:22 CQG FIX Trading | Disconnected. | 2018-02-13 14:58:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 14:58:22 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 14:58:22 CQG FIX socket (301) | Initiating close of socket by core. | 2018-02-13 14:58:22 CQG FIX: Disconnected. | 2018-02-13 14:58:22 CQG FIX socket (301) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:58:22 CQG FIX socket (301) | Socket gracefully closed by remote side. | 2018-02-13 14:58:22 CQG FIX socket (301) | Closed. | 2018-02-13 14:58:22 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 14:58:28 CQG FIX socket (308) | Creating socket. Using TLS 1.2. | 2018-02-13 14:58:28 CQG FIX socket (308) | Connecting to IP: 208.48.16.214. | 2018-02-13 14:58:28 CQG FIX: Sending the Logon message. | 2018-02-13 14:58:32 CQG FIX Trading | Connected to trading server. | 2018-02-13 14:58:33 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 14:58:33 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 14:58:33 CQG WebSocket socket (309) | Creating socket. Using TLS 1.2. | 2018-02-13 14:58:33 CQG WebSocket socket (309) | Connecting to IP: 208.48.16.35. | 2018-02-13 14:58:33 CQG FIX | FCM name: AMP | 2018-02-13 14:58:33 CQG WebSocket | Opening WebSocket. | 2018-02-13 14:58:33 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 14:58:33 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 14:58:34 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 14:58:34 CQG WebSocket | Header line. Sec-WebSocket-Accept: Zat34MjfzP02j6dGorgXuR5M0PE= | 2018-02-13 14:58:34 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 14:58:34 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 14:58:34 CQG WebSocket | Header line. | 2018-02-13 14:58:34 CQG WebSocket | Web socket state is now open. | 2018-02-13 14:58:34 CQG FIX Trading | WebSocket connected. | 2018-02-13 14:58:34 CQG FIX Trading | Sending market data logon message. | 2018-02-13 14:58:34 CQG FIX Trading | Logon successful. Session Token = lR+SYPfuB5qUAwgRsBB7C9GJXmfDuKAzQH1Hg6uy/acJD9GhWl2vrmHsaVicBGgr5NJQ+vbomm1 | 2018-02-13 14:58:35 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 14:58:37 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 1 | 2018-02-13 14:58:37 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 701912 | 2018-02-13 14:58:37 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 1 | 2018-02-13 14:58:37 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 14:58:37 Delaying start of download for F.US.RTYH18 | 2018-02-13 14:58:38 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 701912. Contract ID: 1. | 2018-02-13 14:58:38 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 14:58:38 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 2 | 2018-02-13 14:58:38 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 701913 | 2018-02-13 14:58:38 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 2 | 2018-02-13 14:58:38 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 14:58:38 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 4 | 2018-02-13 14:58:38 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 701914 | 2018-02-13 14:58:38 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 4 | 2018-02-13 14:58:38 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 3 | 2018-02-13 14:58:38 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 701915 | 2018-02-13 14:58:38 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 3 | 2018-02-13 14:58:38 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 14:58:38 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 5 | 2018-02-13 14:58:38 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 701916 | 2018-02-13 14:58:38 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 5 | 2018-02-13 14:58:38 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 7 | 2018-02-13 14:58:38 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 701917 | 2018-02-13 14:58:38 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 7 | 2018-02-13 14:58:38 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 6 | 2018-02-13 14:58:38 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 701918 | 2018-02-13 14:58:38 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 6 | 2018-02-13 14:58:38 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 8 | 2018-02-13 14:58:38 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 701919 | 2018-02-13 14:58:38 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 8 | 2018-02-13 14:58:38 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 9 | 2018-02-13 14:58:38 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 701920 | 2018-02-13 14:58:38 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 9 | 2018-02-13 14:58:38 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 10 | 2018-02-13 14:58:38 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 701921 | 2018-02-13 14:58:38 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 10 | 2018-02-13 14:58:38 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 11 | 2018-02-13 14:58:38 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 701922 | 2018-02-13 14:58:38 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 11 | 2018-02-13 14:58:38 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 701913. Contract ID: 2. | 2018-02-13 14:58:39 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 14:58:39 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 701914. Contract ID: 3. | 2018-02-13 14:58:39 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 14:58:39 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 701915. Contract ID: 4. | 2018-02-13 14:58:39 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 14:58:39 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 701916. Contract ID: 5. | 2018-02-13 14:58:39 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 14:58:39 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 701917. Contract ID: 6. | 2018-02-13 14:58:39 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 14:58:39 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 701918. Contract ID: 7. | 2018-02-13 14:58:39 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 14:58:39 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 701919. Contract ID: 8. | 2018-02-13 14:58:39 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 14:58:39 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 701920. Contract ID: 9. | 2018-02-13 14:58:39 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 14:58:39 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 701921. Contract ID: 10. | 2018-02-13 14:58:39 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 14:58:39 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 701922. Contract ID: 11. | 2018-02-13 14:58:39 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 14:58:39 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 12 | 2018-02-13 14:58:41 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 701923 | 2018-02-13 14:58:41 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 12 | 2018-02-13 14:58:41 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 13 | 2018-02-13 14:58:41 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 701924 | 2018-02-13 14:58:41 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 13 | 2018-02-13 14:58:41 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 701923. Contract ID: 12. | 2018-02-13 14:58:42 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 14:58:42 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 701924. Contract ID: 13. | 2018-02-13 14:58:42 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 14:58:42 Delaying start of download for F.US.RTYH18 | 2018-02-13 14:58:43 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 14:58:46 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 14:58:46 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 14:58:46 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 14:58:46 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 14:58:46 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 14:58:46 HD Request # 107 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 14:58:48 HD Request # 107 | Download start date-time: 2018-02-13 14:58:13.000 | 2018-02-13 14:58:48 HD Request # 107 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 14:58:48 Socket (311) | Creating socket. | 2018-02-13 14:58:48 Socket (311) | Connecting to IP: 65.182.172.42. | 2018-02-13 14:58:48 HD Request # 107 | Setting DTC encoding to Binary VLS | 2018-02-13 14:58:48 HD Request # 107 | Sending historical data logon request message. | 2018-02-13 14:58:48 HD Request # 107 | Requesting Intraday data. Start date-time: 2018-02-13 14:58:13. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 14:58:48 HD Request # 107 | Decompressing data. | 2018-02-13 14:58:49 HD Request # 107 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 14:58:13 | 2018-02-13 14:58:49 HD Request # 107 | Timestamp of first Intraday data file record written: 2018-02-13 14:58:13 | 2018-02-13 14:58:49 Socket (311) | Initiating close of socket by core. | 2018-02-13 14:58:49 Socket (311) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:58:49 Socket (311) | Socket gracefully closed by remote side. | 2018-02-13 14:58:49 Socket (311) | Closed. | 2018-02-13 14:58:49 Historical data download thread signaled to stop. | 2018-02-13 14:58:49 HD Request # 107 | Received 355 records from 2018-02-13 14:58:13 to 2018-02-13 14:58:46 (33.0 seconds) and wrote 353 records for F.US.RTYH18 | 2018-02-13 14:58:49 Added 28 Time and Sales records to Intraday data file for F.US.RTYH18 after download. | 2018-02-13 14:58:49 HD Request # 107 | Completion time: 0s | 2018-02-13 14:58:49 HD Request # 107 | Intraday data download complete for F.US.RTYH18. Unique request ID: 106 | 2018-02-13 14:58:49 Removed historical data download ID 106 | 2018-02-13 14:58:49 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 14:58:49 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 14:58:49 HD Request # 108 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 14:58:49 HD Request # 108 | Download start date-time: 2018-02-13 14:58:13.000 | 2018-02-13 14:58:49 HD Request # 108 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 14:58:49 Socket (312) | Creating socket. | 2018-02-13 14:58:49 Socket (312) | Connecting to IP: 192.81.56.146. | 2018-02-13 14:58:49 HD Request # 108 | Setting DTC encoding to Binary VLS | 2018-02-13 14:58:49 HD Request # 108 | Sending historical data logon request message. | 2018-02-13 14:58:49 HD Request # 108 | Requesting Intraday data. Start date-time: 2018-02-13 14:58:13. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 14:58:49 HD Request # 108 | Decompressing data. | 2018-02-13 14:58:49 HD Request # 108 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 14:58:13 | 2018-02-13 14:58:49 HD Request # 108 | Timestamp of first Intraday data file record written: 2018-02-13 14:58:14 | 2018-02-13 14:58:49 Socket (312) | Initiating close of socket by core. | 2018-02-13 14:58:49 Socket (312) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:58:49 Socket (312) | Socket gracefully closed by remote side. | 2018-02-13 14:58:50 Socket (312) | Closed. | 2018-02-13 14:58:50 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:58:50 Historical data download thread signaled to stop. | 2018-02-13 14:58:50 HD Request # 108 | Received 379 records from 2018-02-13 14:58:13 to 2018-02-13 14:58:47 (34.0 seconds) and wrote 359 records for F.US.YMH18 | 2018-02-13 14:58:50 Added 2 Time and Sales records to Intraday data file for F.US.YMH18 after download. | 2018-02-13 14:58:50 HD Request # 108 | Completion time: 1s | 2018-02-13 14:58:50 HD Request # 108 | Intraday data download complete for F.US.YMH18. Unique request ID: 107 | 2018-02-13 14:58:50 Removed historical data download ID 107 | 2018-02-13 14:58:50 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 14:58:50 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 14:58:50 HD Request # 109 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 14:58:50 HD Request # 109 | Download start date-time: 2018-02-13 14:58:12.000 | 2018-02-13 14:58:50 HD Request # 109 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 14:58:50 Socket (313) | Creating socket. | 2018-02-13 14:58:50 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:58:50 Chart #2 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:58:50 Socket (313) | Connecting to IP: 65.182.172.42. | 2018-02-13 14:58:50 HD Request # 109 | Setting DTC encoding to Binary VLS | 2018-02-13 14:58:50 HD Request # 109 | Sending historical data logon request message. | 2018-02-13 14:58:50 HD Request # 109 | Requesting Intraday data. Start date-time: 2018-02-13 14:58:12. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 14:58:50 HD Request # 109 | Decompressing data. | 2018-02-13 14:58:51 HD Request # 109 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 14:58:12 | 2018-02-13 14:58:51 HD Request # 109 | Timestamp of first Intraday data file record written: 2018-02-13 14:58:19 | 2018-02-13 14:58:51 Socket (313) | Initiating close of socket by core. | 2018-02-13 14:58:51 Socket (313) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:58:51 Historical data download thread signaled to stop. | 2018-02-13 14:58:51 HD Request # 109 | Received 32 records from 2018-02-13 14:58:12 to 2018-02-13 14:58:42 (30.0 seconds) and wrote 19 records for F.US.CLEH18 | 2018-02-13 14:58:51 HD Request # 109 | Completion time: 0s | 2018-02-13 14:58:51 HD Request # 109 | Intraday data download complete for F.US.CLEH18. Unique request ID: 108 | 2018-02-13 14:58:51 Removed historical data download ID 108 | 2018-02-13 14:58:51 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 14:58:51 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 14:58:51 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:58:51 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:58:51 Socket (313) | Socket gracefully closed by remote side. | 2018-02-13 14:58:51 Socket (313) | Closed. | 2018-02-13 14:58:51 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:58:51 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:58:51 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:58:51 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:58:51 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 14:58:52 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 14:58:52 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 14:58:52 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:58:54 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:58:54 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:58:56 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:58:56 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 14:58:56 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:59:20 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 14:59:20 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 14:59:27 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 14:59:27 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:59:32 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:59:32 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:59:32 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:59:32 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:59:32 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:59:37 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 14:59:37 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 14:59:37 CQG WebSocket socket (309) | Adding bytes from final send buffer from buffered socket: 8 | 2018-02-13 14:59:37 CQG WebSocket socket (309) | Initiating close of socket by core. | 2018-02-13 14:59:37 CQG WebSocket | WebSocket closed. | 2018-02-13 14:59:37 CQG FIX Trading | WebSocket closed. | 2018-02-13 14:59:37 Connection to the external service has been lost. | 2018-02-13 14:59:37 CQG WebSocket socket (309) | Write in progress. Shutdown being delayed. | 2018-02-13 14:59:37 CQG WebSocket socket (309) | Sending bytes from final send buffer: 8 | 2018-02-13 14:59:37 CQG WebSocket socket (309) | Write has completed. Shutdown being performed. | 2018-02-13 14:59:38 CQG WebSocket socket (309) | Shutdown started. Waiting for graceful close. | 2018-02-13 14:59:38 CQG WebSocket socket (309) | Socket gracefully closed by remote side. | 2018-02-13 14:59:38 CQG WebSocket socket (309) | Closed. | 2018-02-13 14:59:38 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 14:59:41 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 14:59:43 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:00:09 CQG FIX: DisconnectFIX called. | 2018-02-13 15:00:11 CQG FIX: Sending a Logout message. | 2018-02-13 15:00:11 CQG FIX Trading | Disconnected. | 2018-02-13 15:00:11 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 15:00:11 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 15:00:12 CQG FIX socket (308) | Initiating close of socket by core. | 2018-02-13 15:00:12 CQG FIX: Disconnected. | 2018-02-13 15:00:12 CQG FIX socket (308) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:00:12 CQG FIX socket (308) | Socket gracefully closed by remote side. | 2018-02-13 15:00:12 CQG FIX socket (308) | Closed. | 2018-02-13 15:00:12 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 15:00:17 CQG FIX socket (315) | Creating socket. Using TLS 1.2. | 2018-02-13 15:00:17 CQG FIX socket (315) | Connecting to IP: 208.48.16.214. | 2018-02-13 15:00:17 CQG FIX: Sending the Logon message. | 2018-02-13 15:00:20 CQG FIX Trading | Connected to trading server. | 2018-02-13 15:00:21 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 15:00:21 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 15:00:21 CQG WebSocket socket (316) | Creating socket. Using TLS 1.2. | 2018-02-13 15:00:21 CQG WebSocket socket (316) | Connecting to IP: 208.48.16.35. | 2018-02-13 15:00:21 CQG WebSocket | Opening WebSocket. | 2018-02-13 15:00:22 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 15:00:22 CQG FIX | FCM name: AMP | 2018-02-13 15:00:22 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 15:00:23 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 15:00:23 CQG WebSocket | Header line. Sec-WebSocket-Accept: d0ePiYF3a98O+zYXASMawqVCO/g= | 2018-02-13 15:00:23 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 15:00:23 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 15:00:23 CQG WebSocket | Header line. | 2018-02-13 15:00:23 CQG WebSocket | Web socket state is now open. | 2018-02-13 15:00:23 CQG FIX Trading | WebSocket connected. | 2018-02-13 15:00:23 CQG FIX Trading | Sending market data logon message. | 2018-02-13 15:00:23 CQG FIX Trading | Logon successful. Session Token = fAxyqJH4DEW7ShRxyZd25vB/rO0CZp8YCd4eMDRTMKw23uZb5za9j9Vhy/9R9SN3cml2o8MOEWJ | 2018-02-13 15:00:23 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 15:00:27 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 2 | 2018-02-13 15:00:27 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 701925 | 2018-02-13 15:00:27 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 2 | 2018-02-13 15:00:27 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 1 | 2018-02-13 15:00:27 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 701926 | 2018-02-13 15:00:27 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 1 | 2018-02-13 15:00:27 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 3 | 2018-02-13 15:00:27 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 701927 | 2018-02-13 15:00:27 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 3 | 2018-02-13 15:00:27 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 5 | 2018-02-13 15:00:27 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 701928 | 2018-02-13 15:00:27 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 5 | 2018-02-13 15:00:27 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 4 | 2018-02-13 15:00:27 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 701929 | 2018-02-13 15:00:27 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 4 | 2018-02-13 15:00:27 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 6 | 2018-02-13 15:00:27 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 701930 | 2018-02-13 15:00:27 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 6 | 2018-02-13 15:00:27 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 7 | 2018-02-13 15:00:27 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 701931 | 2018-02-13 15:00:27 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 7 | 2018-02-13 15:00:27 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 8 | 2018-02-13 15:00:27 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 701932 | 2018-02-13 15:00:27 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 8 | 2018-02-13 15:00:27 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 9 | 2018-02-13 15:00:27 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 701933 | 2018-02-13 15:00:27 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 9 | 2018-02-13 15:00:27 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 10 | 2018-02-13 15:00:27 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 701934 | 2018-02-13 15:00:27 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 10 | 2018-02-13 15:00:27 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 11 | 2018-02-13 15:00:27 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 701935 | 2018-02-13 15:00:27 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 11 | 2018-02-13 15:00:27 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 12 | 2018-02-13 15:00:27 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 701936 | 2018-02-13 15:00:27 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 12 | 2018-02-13 15:00:27 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 13 | 2018-02-13 15:00:27 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 701937 | 2018-02-13 15:00:27 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 13 | 2018-02-13 15:00:27 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 15:00:27 Delaying start of download for F.US.YMH18 | 2018-02-13 15:00:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 701925. Contract ID: 1. | 2018-02-13 15:00:28 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 15:00:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 701926. Contract ID: 2. | 2018-02-13 15:00:28 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 15:00:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 701927. Contract ID: 3. | 2018-02-13 15:00:28 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 15:00:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 701928. Contract ID: 4. | 2018-02-13 15:00:28 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 15:00:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 701929. Contract ID: 5. | 2018-02-13 15:00:28 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 15:00:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 701930. Contract ID: 6. | 2018-02-13 15:00:28 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 15:00:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 701931. Contract ID: 7. | 2018-02-13 15:00:28 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 15:00:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 701932. Contract ID: 8. | 2018-02-13 15:00:28 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 15:00:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 701933. Contract ID: 9. | 2018-02-13 15:00:28 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 15:00:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 701934. Contract ID: 10. | 2018-02-13 15:00:28 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 15:00:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 701935. Contract ID: 11. | 2018-02-13 15:00:28 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 15:00:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 701936. Contract ID: 12. | 2018-02-13 15:00:28 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 15:00:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 701937. Contract ID: 13. | 2018-02-13 15:00:28 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 15:00:28 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 15:00:28 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 15:00:28 HD Request # 110 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 15:00:33 HD Request # 110 | Download start date-time: 2018-02-13 14:59:37.000 | 2018-02-13 15:00:33 HD Request # 110 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:00:33 Socket (317) | Creating socket. | 2018-02-13 15:00:33 Socket (317) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:00:33 HD Request # 110 | Setting DTC encoding to Binary VLS | 2018-02-13 15:00:33 HD Request # 110 | Sending historical data logon request message. | 2018-02-13 15:00:33 HD Request # 110 | Requesting Intraday data. Start date-time: 2018-02-13 14:59:37. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 15:00:33 HD Request # 110 | Decompressing data. | 2018-02-13 15:00:33 HD Request # 110 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 14:59:37 | 2018-02-13 15:00:33 HD Request # 110 | Timestamp of first Intraday data file record written: 2018-02-13 14:59:37 | 2018-02-13 15:00:33 Socket (317) | Initiating close of socket by core. | 2018-02-13 15:00:33 Socket (317) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:00:33 Socket (317) | Socket gracefully closed by remote side. | 2018-02-13 15:00:33 Socket (317) | Closed. | 2018-02-13 15:00:33 Historical data download thread signaled to stop. | 2018-02-13 15:00:33 HD Request # 110 | Received 1536 records from 2018-02-13 14:59:37 to 2018-02-13 15:00:30 (53.0 seconds) and wrote 1534 records for F.US.YMH18 | 2018-02-13 15:00:33 Added 13 Time and Sales records to Intraday data file for F.US.YMH18 after download. | 2018-02-13 15:00:33 HD Request # 110 | Completion time: 1s | 2018-02-13 15:00:33 HD Request # 110 | Intraday data download complete for F.US.YMH18. Unique request ID: 109 | 2018-02-13 15:00:33 Removed historical data download ID 109 | 2018-02-13 15:00:33 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 15:00:33 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 15:00:33 HD Request # 111 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 15:00:33 HD Request # 111 | Download start date-time: 2018-02-13 14:59:36.000 | 2018-02-13 15:00:33 HD Request # 111 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:00:33 Socket (318) | Creating socket. | 2018-02-13 15:00:33 Socket (318) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:00:33 HD Request # 111 | Setting DTC encoding to Binary VLS | 2018-02-13 15:00:34 HD Request # 111 | Sending historical data logon request message. | 2018-02-13 15:00:34 HD Request # 111 | Requesting Intraday data. Start date-time: 2018-02-13 14:59:36. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 15:00:34 HD Request # 111 | Decompressing data. | 2018-02-13 15:00:34 HD Request # 111 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 14:59:36 | 2018-02-13 15:00:34 HD Request # 111 | Timestamp of first Intraday data file record written: 2018-02-13 14:59:37 | 2018-02-13 15:00:34 Socket (318) | Initiating close of socket by core. | 2018-02-13 15:00:34 Socket (318) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:00:34 Socket (318) | Socket gracefully closed by remote side. | 2018-02-13 15:00:34 Socket (318) | Closed. | 2018-02-13 15:00:34 Historical data download thread signaled to stop. | 2018-02-13 15:00:34 HD Request # 111 | Received 1908 records from 2018-02-13 14:59:36 to 2018-02-13 15:00:32 (56.0 seconds) and wrote 1902 records for F.US.RTYH18 | 2018-02-13 15:00:34 Added 2 Time and Sales records to Intraday data file for F.US.RTYH18 after download. | 2018-02-13 15:00:34 HD Request # 111 | Completion time: 0s | 2018-02-13 15:00:34 HD Request # 111 | Intraday data download complete for F.US.RTYH18. Unique request ID: 110 | 2018-02-13 15:00:34 Removed historical data download ID 110 | 2018-02-13 15:00:34 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 15:00:34 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 15:00:34 HD Request # 112 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 15:00:34 HD Request # 112 | Download start date-time: 2018-02-13 14:59:30.000 | 2018-02-13 15:00:34 HD Request # 112 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:00:34 Socket (319) | Creating socket. | 2018-02-13 15:00:34 Socket (319) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:00:34 HD Request # 112 | Setting DTC encoding to Binary VLS | 2018-02-13 15:00:34 HD Request # 112 | Sending historical data logon request message. | 2018-02-13 15:00:34 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:00:34 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:00:34 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:00:34 HD Request # 112 | Requesting Intraday data. Start date-time: 2018-02-13 14:59:30. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 15:00:34 HD Request # 112 | Decompressing data. | 2018-02-13 15:00:34 HD Request # 112 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 14:59:30 | 2018-02-13 15:00:34 HD Request # 112 | Timestamp of first Intraday data file record written: 2018-02-13 14:59:37 | 2018-02-13 15:00:34 Socket (319) | Initiating close of socket by core. | 2018-02-13 15:00:34 Socket (319) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:00:34 Socket (319) | Socket gracefully closed by remote side. | 2018-02-13 15:00:35 Socket (319) | Closed. | 2018-02-13 15:00:35 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 15:00:35 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:00:58 Historical data download thread signaled to stop. | 2018-02-13 15:00:58 HD Request # 112 | Received 141 records from 2018-02-13 14:59:30 to 2018-02-13 15:00:29 (59.0 seconds) and wrote 139 records for F.US.CLEH18 | 2018-02-13 15:00:58 Added 29 Time and Sales records to Intraday data file for F.US.CLEH18 after download. | 2018-02-13 15:00:58 HD Request # 112 | Completion time: 24s | 2018-02-13 15:00:58 HD Request # 112 | Intraday data download complete for F.US.CLEH18. Unique request ID: 111 | 2018-02-13 15:00:58 Removed historical data download ID 111 | 2018-02-13 15:00:58 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 15:00:58 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 15:00:58 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:00:58 Chart #2 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:00:58 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:00:58 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:00:58 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:00:58 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:00:58 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:00:59 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 15:00:59 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 15:00:59 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:01:06 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 15:01:06 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 15:01:06 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 15:01:06 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 15:01:06 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 15:01:06 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 15:01:06 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:01:07 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:01:07 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:01:07 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:01:07 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:01:11 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:01:11 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:01:11 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:01:11 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:01:11 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:01:11 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:01:14 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:01:14 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:01:16 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 15:01:40 CQG WebSocket socket (316) | Adding bytes from final send buffer from buffered socket: 22 | 2018-02-13 15:01:40 CQG WebSocket socket (316) | Initiating close of socket by core. | 2018-02-13 15:01:40 CQG WebSocket | WebSocket closed. | 2018-02-13 15:01:40 CQG FIX Trading | WebSocket closed. | 2018-02-13 15:01:40 Connection to the external service has been lost. | 2018-02-13 15:01:40 CQG WebSocket socket (316) | Sending bytes from final send buffer: 22 | 2018-02-13 15:01:40 CQG WebSocket socket (316) | Write in progress. Shutdown being delayed. | 2018-02-13 15:01:40 CQG WebSocket socket (316) | Write has completed. Shutdown being performed. | 2018-02-13 15:01:40 CQG WebSocket socket (316) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:01:40 CQG WebSocket socket (316) | Socket gracefully closed by remote side. | 2018-02-13 15:01:40 CQG WebSocket socket (316) | Closed. | 2018-02-13 15:01:40 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:01:43 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:01:44 CQG FIX: DisconnectFIX called. | 2018-02-13 15:01:51 CQG FIX: Sending a Logout message. | 2018-02-13 15:01:51 CQG FIX Trading | Disconnected. | 2018-02-13 15:01:51 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 15:01:51 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 15:01:51 CQG FIX socket (315) | Initiating close of socket by core. | 2018-02-13 15:01:51 CQG FIX: Disconnected. | 2018-02-13 15:01:51 CQG FIX socket (315) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:01:51 CQG FIX socket (315) | Socket gracefully closed by remote side. | 2018-02-13 15:01:51 CQG FIX socket (315) | Closed. | 2018-02-13 15:01:51 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 15:01:57 CQG FIX socket (321) | Creating socket. Using TLS 1.2. | 2018-02-13 15:01:57 CQG FIX socket (321) | Connecting to IP: 208.48.16.214. | 2018-02-13 15:01:57 CQG FIX: Sending the Logon message. | 2018-02-13 15:02:01 CQG FIX Trading | Connected to trading server. | 2018-02-13 15:02:02 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 15:02:02 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 15:02:02 CQG WebSocket socket (322) | Creating socket. Using TLS 1.2. | 2018-02-13 15:02:02 CQG WebSocket socket (322) | Connecting to IP: 208.48.16.35. | 2018-02-13 15:02:02 CQG FIX | FCM name: AMP | 2018-02-13 15:02:03 CQG WebSocket | Opening WebSocket. | 2018-02-13 15:02:03 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 15:02:03 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 15:02:03 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 15:02:03 CQG WebSocket | Header line. Sec-WebSocket-Accept: UqQKtLSnSJQoDrdbx2rfQq8R8jc= | 2018-02-13 15:02:03 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 15:02:03 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 15:02:03 CQG WebSocket | Header line. | 2018-02-13 15:02:03 CQG WebSocket | Web socket state is now open. | 2018-02-13 15:02:03 CQG FIX Trading | WebSocket connected. | 2018-02-13 15:02:03 CQG FIX Trading | Sending market data logon message. | 2018-02-13 15:02:03 CQG FIX Trading | Logon successful. Session Token = b9c8gang4jNftKgVnWjS5jRYN/g1RQyfHnASVht2I/IJN/7LSS54UetKbE9c1jucUrS0aBU0Mek | 2018-02-13 15:02:04 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 15:02:08 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 1 | 2018-02-13 15:02:08 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 701938 | 2018-02-13 15:02:08 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 1 | 2018-02-13 15:02:08 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 15:02:08 Delaying start of download for F.US.YMH18 | 2018-02-13 15:02:08 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:02:08 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 701939 | 2018-02-13 15:02:08 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:02:08 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 2 | 2018-02-13 15:02:08 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 701940 | 2018-02-13 15:02:08 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 2 | 2018-02-13 15:02:08 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 15:02:08 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 4 | 2018-02-13 15:02:08 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 701941 | 2018-02-13 15:02:08 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 4 | 2018-02-13 15:02:08 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 6 | 2018-02-13 15:02:08 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 701942 | 2018-02-13 15:02:08 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 6 | 2018-02-13 15:02:08 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 5 | 2018-02-13 15:02:08 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 701943 | 2018-02-13 15:02:08 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 5 | 2018-02-13 15:02:08 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 7 | 2018-02-13 15:02:08 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 701944 | 2018-02-13 15:02:08 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 7 | 2018-02-13 15:02:08 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 8 | 2018-02-13 15:02:08 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 701945 | 2018-02-13 15:02:08 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 8 | 2018-02-13 15:02:08 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 9 | 2018-02-13 15:02:08 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 701946 | 2018-02-13 15:02:08 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 9 | 2018-02-13 15:02:08 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:02:08 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 701947 | 2018-02-13 15:02:08 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:02:08 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 11 | 2018-02-13 15:02:08 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 701948 | 2018-02-13 15:02:08 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 11 | 2018-02-13 15:02:08 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 12 | 2018-02-13 15:02:08 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 701949 | 2018-02-13 15:02:08 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 12 | 2018-02-13 15:02:08 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 13 | 2018-02-13 15:02:08 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 701950 | 2018-02-13 15:02:08 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 13 | 2018-02-13 15:02:08 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 15:02:08 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 701938. Contract ID: 1. | 2018-02-13 15:02:08 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 15:02:08 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 701939. Contract ID: 2. | 2018-02-13 15:02:08 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 15:02:08 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 701940. Contract ID: 3. | 2018-02-13 15:02:08 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 15:02:08 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 701941. Contract ID: 4. | 2018-02-13 15:02:08 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 15:02:08 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 701942. Contract ID: 5. | 2018-02-13 15:02:08 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 15:02:08 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 701943. Contract ID: 6. | 2018-02-13 15:02:08 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 15:02:08 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 701944. Contract ID: 7. | 2018-02-13 15:02:08 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 15:02:08 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 701945. Contract ID: 8. | 2018-02-13 15:02:08 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 15:02:08 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 701946. Contract ID: 9. | 2018-02-13 15:02:08 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 15:02:08 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 701947. Contract ID: 10. | 2018-02-13 15:02:08 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 15:02:08 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 701948. Contract ID: 11. | 2018-02-13 15:02:08 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 15:02:08 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 701949. Contract ID: 12. | 2018-02-13 15:02:08 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 15:02:08 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 701950. Contract ID: 13. | 2018-02-13 15:02:08 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 15:02:08 HD Request # 113 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 15:02:13 HD Request # 113 | Download start date-time: 2018-02-13 15:01:35.000 | 2018-02-13 15:02:13 HD Request # 113 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:02:13 Socket (323) | Creating socket. | 2018-02-13 15:02:13 Socket (323) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:02:13 HD Request # 113 | Setting DTC encoding to Binary VLS | 2018-02-13 15:02:13 HD Request # 113 | Sending historical data logon request message. | 2018-02-13 15:02:13 HD Request # 113 | Requesting Intraday data. Start date-time: 2018-02-13 15:01:35. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 15:02:13 HD Request # 113 | Decompressing data. | 2018-02-13 15:02:13 HD Request # 113 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 15:01:35 | 2018-02-13 15:02:13 HD Request # 113 | Timestamp of first Intraday data file record written: 2018-02-13 15:01:35 | 2018-02-13 15:02:13 Socket (323) | Initiating close of socket by core. | 2018-02-13 15:02:13 Socket (323) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:02:13 Socket (323) | Socket gracefully closed by remote side. | 2018-02-13 15:02:13 Socket (323) | Closed. | 2018-02-13 15:02:13 Historical data download thread signaled to stop. | 2018-02-13 15:02:14 HD Request # 113 | Received 154 records from 2018-02-13 15:01:35 to 2018-02-13 15:02:11 (36.0 seconds) and wrote 139 records for F.US.YMH18 | 2018-02-13 15:02:14 Added 9 Time and Sales records to Intraday data file for F.US.YMH18 after download. | 2018-02-13 15:02:14 HD Request # 113 | Completion time: 1s | 2018-02-13 15:02:14 HD Request # 113 | Intraday data download complete for F.US.YMH18. Unique request ID: 112 | 2018-02-13 15:02:14 Removed historical data download ID 112 | 2018-02-13 15:02:14 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 15:02:14 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 15:02:14 HD Request # 114 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 15:02:14 HD Request # 114 | Download start date-time: 2018-02-13 15:01:20.000 | 2018-02-13 15:02:14 HD Request # 114 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:02:14 Socket (324) | Creating socket. | 2018-02-13 15:02:14 Socket (324) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:02:14 HD Request # 114 | Setting DTC encoding to Binary VLS | 2018-02-13 15:02:14 HD Request # 114 | Sending historical data logon request message. | 2018-02-13 15:02:14 HD Request # 114 | Requesting Intraday data. Start date-time: 2018-02-13 15:01:20. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 15:02:14 HD Request # 114 | Decompressing data. | 2018-02-13 15:02:14 HD Request # 114 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 15:01:20 | 2018-02-13 15:02:14 HD Request # 114 | Timestamp of first Intraday data file record written: 2018-02-13 15:01:44 | 2018-02-13 15:02:14 Socket (324) | Initiating close of socket by core. | 2018-02-13 15:02:14 Socket (324) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:02:14 Socket (324) | Socket gracefully closed by remote side. | 2018-02-13 15:02:14 Socket (324) | Closed. | 2018-02-13 15:02:14 Historical data download thread signaled to stop. | 2018-02-13 15:02:15 HD Request # 114 | Received 9 records from 2018-02-13 15:01:20 to 2018-02-13 15:01:55 (35.0 seconds) and wrote 8 records for F.US.CLEH18 | 2018-02-13 15:02:15 HD Request # 114 | Completion time: 0s | 2018-02-13 15:02:15 HD Request # 114 | Intraday data download complete for F.US.CLEH18. Unique request ID: 113 | 2018-02-13 15:02:15 Removed historical data download ID 113 | 2018-02-13 15:02:15 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 15:02:15 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 15:02:15 HD Request # 115 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 15:02:15 HD Request # 115 | Download start date-time: 2018-02-13 15:01:38.000 | 2018-02-13 15:02:15 HD Request # 115 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:02:15 Socket (325) | Creating socket. | 2018-02-13 15:02:15 Socket (325) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:02:15 HD Request # 115 | Setting DTC encoding to Binary VLS | 2018-02-13 15:02:15 HD Request # 115 | Sending historical data logon request message. | 2018-02-13 15:02:15 HD Request # 115 | Requesting Intraday data. Start date-time: 2018-02-13 15:01:38. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 15:02:15 HD Request # 115 | Decompressing data. | 2018-02-13 15:02:15 HD Request # 115 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 15:01:38 | 2018-02-13 15:02:15 HD Request # 115 | Timestamp of first Intraday data file record written: 2018-02-13 15:01:42 | 2018-02-13 15:02:15 Socket (325) | Initiating close of socket by core. | 2018-02-13 15:02:15 Socket (325) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:02:15 Socket (325) | Socket gracefully closed by remote side. | 2018-02-13 15:02:15 Socket (325) | Closed. | 2018-02-13 15:02:15 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 15:02:15 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:02:16 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:02:16 Historical data download thread signaled to stop. | 2018-02-13 15:02:16 HD Request # 115 | Received 67 records from 2018-02-13 15:01:38 to 2018-02-13 15:02:11 (33.0 seconds) and wrote 65 records for F.US.RTYH18 | 2018-02-13 15:02:16 HD Request # 115 | Completion time: 1s | 2018-02-13 15:02:16 HD Request # 115 | Intraday data download complete for F.US.RTYH18. Unique request ID: 114 | 2018-02-13 15:02:16 Removed historical data download ID 114 | 2018-02-13 15:02:16 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 15:02:16 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 15:02:16 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:02:16 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:02:16 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:02:16 Chart #2 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:02:16 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:02:17 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:02:17 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:02:17 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:02:17 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:02:17 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:02:19 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:02:19 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:02:19 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 15:02:22 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:02:43 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 15:02:43 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 15:02:43 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 15:02:43 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 15:02:43 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 15:02:43 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 15:02:43 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:02:43 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 15:02:43 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:02:50 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:02:50 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:02:55 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:02:55 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:02:55 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:02:55 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:02:59 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:02:59 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:02:59 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:03:01 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:03:02 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:03:04 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 15:03:28 CQG WebSocket socket (322) | Adding bytes from final send buffer from buffered socket: 22 | 2018-02-13 15:03:28 CQG WebSocket socket (322) | Initiating close of socket by core. | 2018-02-13 15:03:28 CQG WebSocket | WebSocket closed. | 2018-02-13 15:03:28 CQG FIX Trading | WebSocket closed. | 2018-02-13 15:03:28 Connection to the external service has been lost. | 2018-02-13 15:03:28 CQG WebSocket socket (322) | Write in progress. Shutdown being delayed. | 2018-02-13 15:03:28 CQG WebSocket socket (322) | Sending bytes from final send buffer: 22 | 2018-02-13 15:03:28 CQG WebSocket socket (322) | Write has completed. Shutdown being performed. | 2018-02-13 15:03:28 CQG WebSocket socket (322) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:03:28 CQG WebSocket socket (322) | Socket gracefully closed by remote side. | 2018-02-13 15:03:28 CQG WebSocket socket (322) | Closed. | 2018-02-13 15:03:28 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:03:32 CQG FIX: DisconnectFIX called. | 2018-02-13 15:03:40 CQG FIX: Sending a Logout message. | 2018-02-13 15:03:40 CQG FIX Trading | Disconnected. | 2018-02-13 15:03:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 15:03:40 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 15:03:40 CQG FIX socket (321) | Initiating close of socket by core. | 2018-02-13 15:03:40 CQG FIX: Disconnected. | 2018-02-13 15:03:40 CQG FIX socket (321) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:03:40 CQG FIX socket (321) | Socket gracefully closed by remote side. | 2018-02-13 15:03:40 CQG FIX socket (321) | Closed. | 2018-02-13 15:03:40 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 15:03:46 CQG FIX socket (328) | Creating socket. Using TLS 1.2. | 2018-02-13 15:03:46 CQG FIX socket (328) | Connecting to IP: 208.48.16.214. | 2018-02-13 15:03:46 CQG FIX: Sending the Logon message. | 2018-02-13 15:03:49 CQG FIX Trading | Connected to trading server. | 2018-02-13 15:03:50 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 15:03:50 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 15:03:50 CQG WebSocket socket (329) | Creating socket. Using TLS 1.2. | 2018-02-13 15:03:50 CQG WebSocket socket (329) | Connecting to IP: 208.48.16.35. | 2018-02-13 15:03:50 CQG WebSocket | Opening WebSocket. | 2018-02-13 15:03:51 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 15:03:51 CQG FIX | FCM name: AMP | 2018-02-13 15:03:51 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 15:03:52 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 15:03:52 CQG WebSocket | Header line. Sec-WebSocket-Accept: zt3g9WpOS5Sl+ruJu+qV3snYCBk= | 2018-02-13 15:03:52 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 15:03:52 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 15:03:52 CQG WebSocket | Header line. | 2018-02-13 15:03:52 CQG WebSocket | Web socket state is now open. | 2018-02-13 15:03:52 CQG FIX Trading | WebSocket connected. | 2018-02-13 15:03:52 CQG FIX Trading | Sending market data logon message. | 2018-02-13 15:03:52 CQG FIX Trading | Logon successful. Session Token = FnX/mA/L7P5AuurOqgj8odhAuvot2/YV6ZxKmM9p9uIYazSoIESWQlOH38+GNEQV54QRpOgvv15 | 2018-02-13 15:03:52 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 15:03:56 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 1 | 2018-02-13 15:03:56 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 701951 | 2018-02-13 15:03:56 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 1 | 2018-02-13 15:03:56 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 15:03:56 Delaying start of download for F.US.YMH18 | 2018-02-13 15:03:56 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:03:56 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 701952 | 2018-02-13 15:03:56 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:03:56 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 2 | 2018-02-13 15:03:56 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 701953 | 2018-02-13 15:03:56 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 2 | 2018-02-13 15:03:56 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 15:03:56 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 701951. Contract ID: 1. | 2018-02-13 15:03:56 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 15:03:56 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 701952. Contract ID: 2. | 2018-02-13 15:03:56 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 15:03:56 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 701953. Contract ID: 3. | 2018-02-13 15:03:56 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 15:03:56 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 4 | 2018-02-13 15:03:56 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 701954 | 2018-02-13 15:03:56 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 4 | 2018-02-13 15:03:56 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 6 | 2018-02-13 15:03:56 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 701955 | 2018-02-13 15:03:56 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 6 | 2018-02-13 15:03:56 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 5 | 2018-02-13 15:03:56 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 701956 | 2018-02-13 15:03:56 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 5 | 2018-02-13 15:03:56 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 7 | 2018-02-13 15:03:56 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 701957 | 2018-02-13 15:03:56 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 7 | 2018-02-13 15:03:56 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 8 | 2018-02-13 15:03:56 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 701958 | 2018-02-13 15:03:56 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 8 | 2018-02-13 15:03:56 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 9 | 2018-02-13 15:03:56 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 701959 | 2018-02-13 15:03:56 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 9 | 2018-02-13 15:03:56 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:03:56 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 701960 | 2018-02-13 15:03:56 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:03:56 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 11 | 2018-02-13 15:03:56 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 701961 | 2018-02-13 15:03:56 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 11 | 2018-02-13 15:03:56 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 15:03:56 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 701954. Contract ID: 4. | 2018-02-13 15:03:57 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 15:03:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 701955. Contract ID: 5. | 2018-02-13 15:03:57 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 15:03:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 701956. Contract ID: 6. | 2018-02-13 15:03:57 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 15:03:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 701957. Contract ID: 7. | 2018-02-13 15:03:57 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 15:03:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 701958. Contract ID: 8. | 2018-02-13 15:03:57 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 15:03:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 701959. Contract ID: 9. | 2018-02-13 15:03:57 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 15:03:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 701960. Contract ID: 10. | 2018-02-13 15:03:57 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 15:03:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 701961. Contract ID: 11. | 2018-02-13 15:03:57 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 15:03:57 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 12 | 2018-02-13 15:03:57 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 701962 | 2018-02-13 15:03:57 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 12 | 2018-02-13 15:03:57 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 13 | 2018-02-13 15:03:57 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 701963 | 2018-02-13 15:03:57 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 13 | 2018-02-13 15:03:57 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 701962. Contract ID: 12. | 2018-02-13 15:03:58 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 15:03:58 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 701963. Contract ID: 13. | 2018-02-13 15:03:58 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 15:03:58 Delaying start of download for F.US.YMH18 | 2018-02-13 15:04:01 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 15:04:05 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 15:04:05 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 15:04:05 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 15:04:05 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 15:04:05 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 15:04:05 HD Request # 116 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 15:04:06 HD Request # 116 | Download start date-time: 2018-02-13 15:03:23.000 | 2018-02-13 15:04:06 HD Request # 116 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:04:06 Socket (330) | Creating socket. | 2018-02-13 15:04:06 Socket (330) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:04:06 HD Request # 116 | Setting DTC encoding to Binary VLS | 2018-02-13 15:04:06 HD Request # 116 | Sending historical data logon request message. | 2018-02-13 15:04:06 HD Request # 116 | Requesting Intraday data. Start date-time: 2018-02-13 15:03:23. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 15:04:07 HD Request # 116 | Decompressing data. | 2018-02-13 15:04:07 HD Request # 116 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 15:03:23 | 2018-02-13 15:04:07 HD Request # 116 | Timestamp of first Intraday data file record written: 2018-02-13 15:03:23 | 2018-02-13 15:04:07 Socket (330) | Initiating close of socket by core. | 2018-02-13 15:04:07 Socket (330) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:04:07 Socket (330) | Socket gracefully closed by remote side. | 2018-02-13 15:04:07 Socket (330) | Closed. | 2018-02-13 15:04:07 Historical data download thread signaled to stop. | 2018-02-13 15:04:07 HD Request # 116 | Received 157 records from 2018-02-13 15:03:23 to 2018-02-13 15:04:04 (41.0 seconds) and wrote 151 records for F.US.YMH18 | 2018-02-13 15:04:07 HD Request # 116 | Completion time: 0s | 2018-02-13 15:04:07 HD Request # 116 | Intraday data download complete for F.US.YMH18. Unique request ID: 115 | 2018-02-13 15:04:07 Removed historical data download ID 115 | 2018-02-13 15:04:07 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 15:04:07 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 15:04:07 HD Request # 117 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 15:04:07 HD Request # 117 | Download start date-time: 2018-02-13 15:03:21.000 | 2018-02-13 15:04:07 HD Request # 117 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:04:07 Socket (331) | Creating socket. | 2018-02-13 15:04:07 Socket (331) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:04:07 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:04:07 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:04:07 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:04:07 HD Request # 117 | Setting DTC encoding to Binary VLS | 2018-02-13 15:04:07 HD Request # 117 | Sending historical data logon request message. | 2018-02-13 15:04:07 HD Request # 117 | Requesting Intraday data. Start date-time: 2018-02-13 15:03:21. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 15:04:07 HD Request # 117 | Decompressing data. | 2018-02-13 15:04:07 HD Request # 117 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 15:03:21 | 2018-02-13 15:04:07 HD Request # 117 | Timestamp of first Intraday data file record written: 2018-02-13 15:03:28 | 2018-02-13 15:04:07 Socket (331) | Initiating close of socket by core. | 2018-02-13 15:04:07 Socket (331) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:04:07 Socket (331) | Socket gracefully closed by remote side. | 2018-02-13 15:04:07 Socket (331) | Closed. | 2018-02-13 15:04:07 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:04:31 Historical data download thread signaled to stop. | 2018-02-13 15:04:31 HD Request # 117 | Received 39 records from 2018-02-13 15:03:21 to 2018-02-13 15:03:52 (31.0 seconds) and wrote 21 records for F.US.CLEH18 | 2018-02-13 15:04:31 Added 11 Time and Sales records to Intraday data file for F.US.CLEH18 after download. | 2018-02-13 15:04:31 HD Request # 117 | Completion time: 24s | 2018-02-13 15:04:31 HD Request # 117 | Intraday data download complete for F.US.CLEH18. Unique request ID: 116 | 2018-02-13 15:04:31 Removed historical data download ID 116 | 2018-02-13 15:04:31 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 15:04:31 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 15:04:31 HD Request # 118 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 15:04:31 HD Request # 118 | Download start date-time: 2018-02-13 15:03:22.000 | 2018-02-13 15:04:31 HD Request # 118 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:04:31 Socket (332) | Creating socket. | 2018-02-13 15:04:31 Socket (332) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:04:31 HD Request # 118 | Setting DTC encoding to Binary VLS | 2018-02-13 15:04:31 HD Request # 118 | Sending historical data logon request message. | 2018-02-13 15:04:31 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:04:31 Chart #2 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:04:31 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:04:31 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:04:31 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:04:31 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:04:31 HD Request # 118 | Requesting Intraday data. Start date-time: 2018-02-13 15:03:22. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 15:04:31 HD Request # 118 | Decompressing data. | 2018-02-13 15:04:31 HD Request # 118 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 15:03:22 | 2018-02-13 15:04:31 HD Request # 118 | Timestamp of first Intraday data file record written: 2018-02-13 15:03:28 | 2018-02-13 15:04:31 Socket (332) | Initiating close of socket by core. | 2018-02-13 15:04:31 Socket (332) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:04:31 Socket (332) | Socket gracefully closed by remote side. | 2018-02-13 15:04:31 Socket (332) | Closed. | 2018-02-13 15:04:31 Historical data download thread signaled to stop. | 2018-02-13 15:04:32 HD Request # 118 | Received 119 records from 2018-02-13 15:03:22 to 2018-02-13 15:04:29 (67.0 seconds) and wrote 108 records for F.US.RTYH18 | 2018-02-13 15:04:32 Added 5 Time and Sales records to Intraday data file for F.US.RTYH18 after download. | 2018-02-13 15:04:32 HD Request # 118 | Completion time: 0s | 2018-02-13 15:04:32 HD Request # 118 | Intraday data download complete for F.US.RTYH18. Unique request ID: 117 | 2018-02-13 15:04:32 Removed historical data download ID 117 | 2018-02-13 15:04:32 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 15:04:32 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 15:04:32 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:04:32 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 15:04:32 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:04:39 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:04:40 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:04:40 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:04:40 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:04:40 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 15:04:41 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 15:04:41 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:04:44 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:04:44 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:04:44 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:04:44 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:04:44 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:04:44 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:04:46 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:04:46 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:04:48 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 15:05:12 CQG WebSocket socket (329) | Adding bytes from final send buffer from buffered socket: 22 | 2018-02-13 15:05:12 CQG WebSocket socket (329) | Initiating close of socket by core. | 2018-02-13 15:05:12 CQG WebSocket | WebSocket closed. | 2018-02-13 15:05:12 CQG FIX Trading | WebSocket closed. | 2018-02-13 15:05:12 Connection to the external service has been lost. | 2018-02-13 15:05:12 CQG WebSocket socket (329) | Write in progress. Shutdown being delayed. | 2018-02-13 15:05:12 CQG WebSocket socket (329) | Sending bytes from final send buffer: 22 | 2018-02-13 15:05:12 CQG WebSocket socket (329) | Write has completed. Shutdown being performed. | 2018-02-13 15:05:12 CQG WebSocket socket (329) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:05:12 CQG WebSocket socket (329) | Socket gracefully closed by remote side. | 2018-02-13 15:05:12 CQG WebSocket socket (329) | Closed. | 2018-02-13 15:05:12 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:05:16 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:05:17 CQG FIX: DisconnectFIX called. | 2018-02-13 15:05:24 CQG FIX: Sending a Logout message. | 2018-02-13 15:05:24 CQG FIX Trading | Disconnected. | 2018-02-13 15:05:24 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 15:05:24 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 15:05:24 CQG FIX socket (328) | Initiating close of socket by core. | 2018-02-13 15:05:24 CQG FIX: Disconnected. | 2018-02-13 15:05:24 CQG FIX socket (328) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:05:24 CQG FIX socket (328) | Socket gracefully closed by remote side. | 2018-02-13 15:05:24 CQG FIX socket (328) | Closed. | 2018-02-13 15:05:24 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 15:05:30 CQG FIX socket (334) | Creating socket. Using TLS 1.2. | 2018-02-13 15:05:30 CQG FIX socket (334) | Connecting to IP: 208.48.16.214. | 2018-02-13 15:05:30 CQG FIX: Sending the Logon message. | 2018-02-13 15:05:33 CQG FIX Trading | Connected to trading server. | 2018-02-13 15:05:34 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 15:05:34 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 15:05:34 CQG WebSocket socket (335) | Creating socket. Using TLS 1.2. | 2018-02-13 15:05:34 CQG WebSocket socket (335) | Connecting to IP: 208.48.16.35. | 2018-02-13 15:05:34 CQG WebSocket | Opening WebSocket. | 2018-02-13 15:05:35 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 15:05:35 CQG FIX | FCM name: AMP | 2018-02-13 15:05:35 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 15:05:35 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 15:05:35 CQG WebSocket | Header line. Sec-WebSocket-Accept: V8hOTk1sMLBvO7L2ituam06gkaY= | 2018-02-13 15:05:35 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 15:05:35 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 15:05:35 CQG WebSocket | Header line. | 2018-02-13 15:05:35 CQG WebSocket | Web socket state is now open. | 2018-02-13 15:05:35 CQG FIX Trading | WebSocket connected. | 2018-02-13 15:05:35 CQG FIX Trading | Sending market data logon message. | 2018-02-13 15:05:35 CQG FIX Trading | Logon successful. Session Token = gam2PkzLhBfbfSlr4AjbPEMBhpybaPdnba5XHD0KYTsBi3q2Ldb2Ro9XMjm7QwPaDeO+4VafMtE | 2018-02-13 15:05:36 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 15:05:39 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 1 | 2018-02-13 15:05:39 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 701964 | 2018-02-13 15:05:39 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 1 | 2018-02-13 15:05:39 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 15:05:39 Delaying start of download for F.US.YMH18 | 2018-02-13 15:05:39 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:05:39 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 701965 | 2018-02-13 15:05:39 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:05:39 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 2 | 2018-02-13 15:05:39 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 701966 | 2018-02-13 15:05:39 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 2 | 2018-02-13 15:05:39 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 15:05:39 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 4 | 2018-02-13 15:05:39 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 701967 | 2018-02-13 15:05:39 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 4 | 2018-02-13 15:05:39 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 15:05:39 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 701964. Contract ID: 1. | 2018-02-13 15:05:40 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 15:05:40 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 701965. Contract ID: 2. | 2018-02-13 15:05:40 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 15:05:40 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 701966. Contract ID: 3. | 2018-02-13 15:05:40 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 15:05:40 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 701967. Contract ID: 4. | 2018-02-13 15:05:40 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 15:05:40 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 5 | 2018-02-13 15:05:40 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 701968 | 2018-02-13 15:05:40 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 5 | 2018-02-13 15:05:40 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 7 | 2018-02-13 15:05:40 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 701969 | 2018-02-13 15:05:40 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 7 | 2018-02-13 15:05:40 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 6 | 2018-02-13 15:05:40 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 701970 | 2018-02-13 15:05:40 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 6 | 2018-02-13 15:05:40 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 8 | 2018-02-13 15:05:40 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 701971 | 2018-02-13 15:05:40 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 8 | 2018-02-13 15:05:40 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 9 | 2018-02-13 15:05:40 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 701972 | 2018-02-13 15:05:40 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 9 | 2018-02-13 15:05:40 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:05:40 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 701973 | 2018-02-13 15:05:40 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:05:40 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 11 | 2018-02-13 15:05:40 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 701974 | 2018-02-13 15:05:40 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 11 | 2018-02-13 15:05:40 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 12 | 2018-02-13 15:05:40 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 701975 | 2018-02-13 15:05:40 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 12 | 2018-02-13 15:05:40 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 13 | 2018-02-13 15:05:40 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 701976 | 2018-02-13 15:05:40 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 13 | 2018-02-13 15:05:40 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 701968. Contract ID: 5. | 2018-02-13 15:05:41 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 15:05:41 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 701969. Contract ID: 6. | 2018-02-13 15:05:41 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 15:05:41 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 701970. Contract ID: 7. | 2018-02-13 15:05:41 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 15:05:41 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 701971. Contract ID: 8. | 2018-02-13 15:05:41 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 15:05:41 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 701972. Contract ID: 9. | 2018-02-13 15:05:41 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 15:05:41 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 701973. Contract ID: 10. | 2018-02-13 15:05:41 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 15:05:41 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 701974. Contract ID: 11. | 2018-02-13 15:05:41 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 15:05:41 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 701975. Contract ID: 12. | 2018-02-13 15:05:41 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 15:05:41 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 701976. Contract ID: 13. | 2018-02-13 15:05:41 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 15:05:41 Delaying start of download for F.US.YMH18 | 2018-02-13 15:05:44 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 15:05:48 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 15:05:48 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 15:05:48 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 15:05:48 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 15:05:48 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 15:05:48 HD Request # 119 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 15:05:49 HD Request # 119 | Download start date-time: 2018-02-13 15:05:05.000 | 2018-02-13 15:05:49 HD Request # 119 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:05:49 Socket (337) | Creating socket. | 2018-02-13 15:05:49 Socket (337) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:05:49 HD Request # 119 | Setting DTC encoding to Binary VLS | 2018-02-13 15:05:49 HD Request # 119 | Sending historical data logon request message. | 2018-02-13 15:05:49 HD Request # 119 | Requesting Intraday data. Start date-time: 2018-02-13 15:05:05. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 15:05:49 HD Request # 119 | Decompressing data. | 2018-02-13 15:05:49 HD Request # 119 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 15:05:05 | 2018-02-13 15:05:49 HD Request # 119 | Timestamp of first Intraday data file record written: 2018-02-13 15:05:13 | 2018-02-13 15:05:49 Socket (337) | Initiating close of socket by core. | 2018-02-13 15:05:49 Socket (337) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:05:49 Socket (337) | Socket gracefully closed by remote side. | 2018-02-13 15:05:49 Socket (337) | Closed. | 2018-02-13 15:05:49 Historical data download thread signaled to stop. | 2018-02-13 15:05:49 HD Request # 119 | Received 82 records from 2018-02-13 15:05:05 to 2018-02-13 15:05:41 (36.0 seconds) and wrote 73 records for F.US.YMH18 | 2018-02-13 15:05:49 HD Request # 119 | Completion time: 0s | 2018-02-13 15:05:49 HD Request # 119 | Intraday data download complete for F.US.YMH18. Unique request ID: 118 | 2018-02-13 15:05:49 Removed historical data download ID 118 | 2018-02-13 15:05:49 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 15:05:49 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 15:05:49 HD Request # 120 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 15:05:49 HD Request # 120 | Download start date-time: 2018-02-13 15:04:53.000 | 2018-02-13 15:05:49 HD Request # 120 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:05:49 Socket (338) | Creating socket. | 2018-02-13 15:05:49 Socket (338) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:05:49 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:05:49 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:05:49 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:05:49 HD Request # 120 | Setting DTC encoding to Binary VLS | 2018-02-13 15:05:50 HD Request # 120 | Sending historical data logon request message. | 2018-02-13 15:05:50 HD Request # 120 | Requesting Intraday data. Start date-time: 2018-02-13 15:04:53. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 15:05:50 HD Request # 120 | Decompressing data. | 2018-02-13 15:05:50 HD Request # 120 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 15:04:53 | 2018-02-13 15:05:50 HD Request # 120 | Timestamp of first Intraday data file record written: 2018-02-13 15:05:25 | 2018-02-13 15:05:50 Socket (338) | Initiating close of socket by core. | 2018-02-13 15:05:50 Socket (338) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:05:50 Socket (338) | Socket gracefully closed by remote side. | 2018-02-13 15:05:50 Socket (338) | Closed. | 2018-02-13 15:05:50 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 15:05:51 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:06:13 Historical data download thread signaled to stop. | 2018-02-13 15:06:13 HD Request # 120 | Received 10 records from 2018-02-13 15:04:53 to 2018-02-13 15:05:46 (53.0 seconds) and wrote 8 records for F.US.CLEH18 | 2018-02-13 15:06:13 Added 15 Time and Sales records to Intraday data file for F.US.CLEH18 after download. | 2018-02-13 15:06:13 HD Request # 120 | Completion time: 24s | 2018-02-13 15:06:13 HD Request # 120 | Intraday data download complete for F.US.CLEH18. Unique request ID: 119 | 2018-02-13 15:06:13 Removed historical data download ID 119 | 2018-02-13 15:06:13 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 15:06:13 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 15:06:13 HD Request # 121 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 15:06:13 HD Request # 121 | Download start date-time: 2018-02-13 15:05:05.000 | 2018-02-13 15:06:13 HD Request # 121 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:06:13 Socket (339) | Creating socket. | 2018-02-13 15:06:13 Socket (339) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:06:13 HD Request # 121 | Setting DTC encoding to Binary VLS | 2018-02-13 15:06:14 HD Request # 121 | Sending historical data logon request message. | 2018-02-13 15:06:14 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:06:14 HD Request # 121 | Requesting Intraday data. Start date-time: 2018-02-13 15:05:05. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 15:06:14 HD Request # 121 | Decompressing data. | 2018-02-13 15:06:14 HD Request # 121 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 15:05:05 | 2018-02-13 15:06:14 HD Request # 121 | Timestamp of first Intraday data file record written: 2018-02-13 15:05:05 | 2018-02-13 15:06:14 Socket (339) | Initiating close of socket by core. | 2018-02-13 15:06:14 Socket (339) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:06:14 Socket (339) | Socket gracefully closed by remote side. | 2018-02-13 15:06:14 Socket (339) | Closed. | 2018-02-13 15:06:14 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:06:21 Historical data download thread signaled to stop. | 2018-02-13 15:06:21 HD Request # 121 | Received 136 records from 2018-02-13 15:05:05 to 2018-02-13 15:06:11 (66.0 seconds) and wrote 122 records for F.US.RTYH18 | 2018-02-13 15:06:21 Added 7 Time and Sales records to Intraday data file for F.US.RTYH18 after download. | 2018-02-13 15:06:21 HD Request # 121 | Completion time: 7s | 2018-02-13 15:06:21 HD Request # 121 | Intraday data download complete for F.US.RTYH18. Unique request ID: 120 | 2018-02-13 15:06:21 Removed historical data download ID 120 | 2018-02-13 15:06:21 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 15:06:21 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 15:06:21 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:06:22 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:06:22 Chart #2 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:06:22 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:06:22 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:06:22 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:06:22 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:06:22 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 15:06:22 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:06:22 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:06:22 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:06:22 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:06:27 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:06:27 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:06:27 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:06:27 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:06:27 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:06:27 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 15:06:28 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:06:29 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:06:29 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:06:31 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 15:06:55 CQG WebSocket socket (335) | Adding bytes from final send buffer from buffered socket: 8 | 2018-02-13 15:06:55 CQG WebSocket socket (335) | Initiating close of socket by core. | 2018-02-13 15:06:55 CQG WebSocket | WebSocket closed. | 2018-02-13 15:06:55 CQG FIX Trading | WebSocket closed. | 2018-02-13 15:06:55 Connection to the external service has been lost. | 2018-02-13 15:06:55 CQG WebSocket socket (335) | Write in progress. Shutdown being delayed. | 2018-02-13 15:06:55 CQG WebSocket socket (335) | Sending bytes from final send buffer: 8 | 2018-02-13 15:06:55 CQG WebSocket socket (335) | Write has completed. Shutdown being performed. | 2018-02-13 15:06:55 CQG WebSocket socket (335) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:06:55 CQG WebSocket socket (335) | Socket gracefully closed by remote side. | 2018-02-13 15:06:55 CQG WebSocket socket (335) | Closed. | 2018-02-13 15:06:55 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:06:58 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:07:05 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:07:10 CQG FIX: DisconnectFIX called. | 2018-02-13 15:07:12 CQG FIX: Sending a Logout message. | 2018-02-13 15:07:12 CQG FIX Trading | Disconnected. | 2018-02-13 15:07:12 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 15:07:12 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 15:07:13 CQG FIX socket (334) | Initiating close of socket by core. | 2018-02-13 15:07:13 CQG FIX: Disconnected. | 2018-02-13 15:07:13 CQG FIX socket (334) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:07:13 CQG FIX socket (334) | Socket gracefully closed by remote side. | 2018-02-13 15:07:13 CQG FIX socket (334) | Closed. | 2018-02-13 15:07:13 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 15:07:18 CQG FIX socket (341) | Creating socket. Using TLS 1.2. | 2018-02-13 15:07:19 CQG FIX socket (341) | Connecting to IP: 208.48.16.214. | 2018-02-13 15:07:19 CQG FIX: Sending the Logon message. | 2018-02-13 15:07:23 CQG FIX Trading | Connected to trading server. | 2018-02-13 15:07:24 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 15:07:24 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 15:07:24 CQG WebSocket socket (342) | Creating socket. Using TLS 1.2. | 2018-02-13 15:07:24 CQG WebSocket socket (342) | Connecting to IP: 208.48.16.35. | 2018-02-13 15:07:24 CQG FIX | FCM name: AMP | 2018-02-13 15:07:24 CQG WebSocket | Opening WebSocket. | 2018-02-13 15:07:24 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 15:07:24 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 15:07:25 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 15:07:25 CQG WebSocket | Header line. Sec-WebSocket-Accept: cVlJIEAWbyRhL1qzPNY1TUTaQvU= | 2018-02-13 15:07:25 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 15:07:25 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 15:07:25 CQG WebSocket | Header line. | 2018-02-13 15:07:25 CQG WebSocket | Web socket state is now open. | 2018-02-13 15:07:25 CQG FIX Trading | WebSocket connected. | 2018-02-13 15:07:25 CQG FIX Trading | Sending market data logon message. | 2018-02-13 15:07:25 CQG FIX Trading | Logon successful. Session Token = W+nBJWXA/tmQsUZHLBrEV8dOdBo5mVh/iQULgj1GroQGSfToC4YCvZzDG2WbiyyriiSEl9oBq13 | 2018-02-13 15:07:26 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 15:07:29 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 1 | 2018-02-13 15:07:29 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 701977 | 2018-02-13 15:07:29 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 1 | 2018-02-13 15:07:29 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 15:07:29 Delaying start of download for F.US.RTYH18 | 2018-02-13 15:07:29 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 701977. Contract ID: 1. | 2018-02-13 15:07:29 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 15:07:29 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:07:29 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 701978 | 2018-02-13 15:07:29 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:07:29 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 2 | 2018-02-13 15:07:29 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 701979 | 2018-02-13 15:07:29 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 2 | 2018-02-13 15:07:29 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 15:07:29 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 701978. Contract ID: 2. | 2018-02-13 15:07:30 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 15:07:30 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 701979. Contract ID: 3. | 2018-02-13 15:07:30 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 15:07:30 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 4 | 2018-02-13 15:07:30 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 701980 | 2018-02-13 15:07:30 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 4 | 2018-02-13 15:07:30 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 5 | 2018-02-13 15:07:30 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 701981 | 2018-02-13 15:07:30 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 5 | 2018-02-13 15:07:30 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 6 | 2018-02-13 15:07:30 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 701982 | 2018-02-13 15:07:30 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 6 | 2018-02-13 15:07:30 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 7 | 2018-02-13 15:07:30 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 701983 | 2018-02-13 15:07:30 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 7 | 2018-02-13 15:07:30 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 8 | 2018-02-13 15:07:30 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 701984 | 2018-02-13 15:07:30 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 8 | 2018-02-13 15:07:30 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 9 | 2018-02-13 15:07:30 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 701985 | 2018-02-13 15:07:30 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 9 | 2018-02-13 15:07:30 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 15:07:30 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 701980. Contract ID: 4. | 2018-02-13 15:07:31 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 15:07:31 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 701981. Contract ID: 5. | 2018-02-13 15:07:31 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 15:07:31 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 701982. Contract ID: 6. | 2018-02-13 15:07:31 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 15:07:31 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 701983. Contract ID: 7. | 2018-02-13 15:07:31 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 15:07:31 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 701984. Contract ID: 8. | 2018-02-13 15:07:31 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 15:07:31 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 701985. Contract ID: 9. | 2018-02-13 15:07:31 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 15:07:31 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 10 | 2018-02-13 15:07:33 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 701986 | 2018-02-13 15:07:33 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 10 | 2018-02-13 15:07:33 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 12 | 2018-02-13 15:07:33 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 701987 | 2018-02-13 15:07:33 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 12 | 2018-02-13 15:07:33 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 11 | 2018-02-13 15:07:33 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 701988 | 2018-02-13 15:07:33 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 11 | 2018-02-13 15:07:33 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 13 | 2018-02-13 15:07:33 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 701989 | 2018-02-13 15:07:33 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 13 | 2018-02-13 15:07:33 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 701986. Contract ID: 10. | 2018-02-13 15:07:33 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 15:07:33 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 701987. Contract ID: 11. | 2018-02-13 15:07:33 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 15:07:33 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 701988. Contract ID: 12. | 2018-02-13 15:07:33 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 15:07:33 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 701989. Contract ID: 13. | 2018-02-13 15:07:33 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 15:07:33 HD Request # 122 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 15:07:35 HD Request # 122 | Download start date-time: 2018-02-13 15:06:48.000 | 2018-02-13 15:07:35 HD Request # 122 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:07:35 Socket (343) | Creating socket. | 2018-02-13 15:07:35 Socket (343) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:07:35 HD Request # 122 | Setting DTC encoding to Binary VLS | 2018-02-13 15:07:35 HD Request # 122 | Sending historical data logon request message. | 2018-02-13 15:07:35 HD Request # 122 | Requesting Intraday data. Start date-time: 2018-02-13 15:06:48. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 15:07:35 HD Request # 122 | Decompressing data. | 2018-02-13 15:07:35 HD Request # 122 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 15:06:48 | 2018-02-13 15:07:35 HD Request # 122 | Timestamp of first Intraday data file record written: 2018-02-13 15:06:54 | 2018-02-13 15:07:35 Socket (343) | Initiating close of socket by core. | 2018-02-13 15:07:35 Socket (343) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:07:35 Socket (343) | Socket gracefully closed by remote side. | 2018-02-13 15:07:35 Socket (343) | Closed. | 2018-02-13 15:07:35 Historical data download thread signaled to stop. | 2018-02-13 15:07:35 HD Request # 122 | Received 148 records from 2018-02-13 15:06:48 to 2018-02-13 15:07:31 (43.0 seconds) and wrote 145 records for F.US.RTYH18 | 2018-02-13 15:07:35 HD Request # 122 | Completion time: 1s | 2018-02-13 15:07:35 HD Request # 122 | Intraday data download complete for F.US.RTYH18. Unique request ID: 121 | 2018-02-13 15:07:35 Removed historical data download ID 121 | 2018-02-13 15:07:35 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 15:07:35 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 15:07:35 HD Request # 123 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 15:07:35 HD Request # 123 | Download start date-time: 2018-02-13 15:06:24.000 | 2018-02-13 15:07:35 HD Request # 123 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:07:35 Socket (344) | Creating socket. | 2018-02-13 15:07:35 Socket (344) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:07:35 HD Request # 123 | Setting DTC encoding to Binary VLS | 2018-02-13 15:07:35 HD Request # 123 | Sending historical data logon request message. | 2018-02-13 15:07:35 HD Request # 123 | Requesting Intraday data. Start date-time: 2018-02-13 15:06:24. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 15:07:35 HD Request # 123 | Decompressing data. | 2018-02-13 15:07:35 HD Request # 123 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 15:06:24 | 2018-02-13 15:07:35 HD Request # 123 | Timestamp of first Intraday data file record written: 2018-02-13 15:06:54 | 2018-02-13 15:07:35 Socket (344) | Initiating close of socket by core. | 2018-02-13 15:07:35 Socket (344) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:07:35 Socket (344) | Socket gracefully closed by remote side. | 2018-02-13 15:07:36 Socket (344) | Closed. | 2018-02-13 15:07:36 Historical data download thread signaled to stop. | 2018-02-13 15:07:36 HD Request # 123 | Received 7 records from 2018-02-13 15:06:24 to 2018-02-13 15:07:16 (52.0 seconds) and wrote 6 records for F.US.CLEH18 | 2018-02-13 15:07:36 HD Request # 123 | Completion time: 0s | 2018-02-13 15:07:36 HD Request # 123 | Intraday data download complete for F.US.CLEH18. Unique request ID: 122 | 2018-02-13 15:07:36 Removed historical data download ID 122 | 2018-02-13 15:07:36 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 15:07:36 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 15:07:36 HD Request # 124 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 15:07:36 HD Request # 124 | Download start date-time: 2018-02-13 15:06:49.000 | 2018-02-13 15:07:36 HD Request # 124 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:07:36 Socket (345) | Creating socket. | 2018-02-13 15:07:36 Socket (345) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:07:36 HD Request # 124 | Setting DTC encoding to Binary VLS | 2018-02-13 15:07:36 HD Request # 124 | Sending historical data logon request message. | 2018-02-13 15:07:36 HD Request # 124 | Requesting Intraday data. Start date-time: 2018-02-13 15:06:49. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 15:07:36 HD Request # 124 | Decompressing data. | 2018-02-13 15:07:36 HD Request # 124 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 15:06:49 | 2018-02-13 15:07:36 HD Request # 124 | Timestamp of first Intraday data file record written: 2018-02-13 15:06:49 | 2018-02-13 15:07:36 Socket (345) | Initiating close of socket by core. | 2018-02-13 15:07:36 Socket (345) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:07:36 Socket (345) | Socket gracefully closed by remote side. | 2018-02-13 15:07:36 Socket (345) | Closed. | 2018-02-13 15:07:36 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:07:37 Historical data download thread signaled to stop. | 2018-02-13 15:07:37 HD Request # 124 | Received 108 records from 2018-02-13 15:06:49 to 2018-02-13 15:07:31 (42.0 seconds) and wrote 93 records for F.US.YMH18 | 2018-02-13 15:07:37 Added 2 Time and Sales records to Intraday data file for F.US.YMH18 after download. | 2018-02-13 15:07:37 HD Request # 124 | Completion time: 1s | 2018-02-13 15:07:37 HD Request # 124 | Intraday data download complete for F.US.YMH18. Unique request ID: 123 | 2018-02-13 15:07:37 Removed historical data download ID 123 | 2018-02-13 15:07:37 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 15:07:37 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 15:07:37 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:07:37 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:07:37 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 15:07:38 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:07:38 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:07:38 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:07:38 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:07:38 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:07:40 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:07:40 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 15:07:41 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:07:42 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:07:42 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:07:42 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:08:06 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 15:08:06 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 15:08:06 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 15:08:06 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 15:08:06 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 15:08:06 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 15:08:06 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:08:06 Chart #2 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:08:06 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:08:06 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:08:06 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:08:06 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:08:06 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:08:07 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 15:08:08 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:08:14 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:08:14 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:08:19 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:08:23 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:08:23 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:08:24 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:08:26 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 15:08:50 CQG WebSocket socket (342) | Adding bytes from final send buffer from buffered socket: 22 | 2018-02-13 15:08:50 CQG WebSocket socket (342) | Initiating close of socket by core. | 2018-02-13 15:08:50 CQG WebSocket | WebSocket closed. | 2018-02-13 15:08:50 CQG FIX Trading | WebSocket closed. | 2018-02-13 15:08:50 Connection to the external service has been lost. | 2018-02-13 15:08:50 CQG WebSocket socket (342) | Write in progress. Shutdown being delayed. | 2018-02-13 15:08:50 CQG WebSocket socket (342) | Sending bytes from final send buffer: 22 | 2018-02-13 15:08:50 CQG WebSocket socket (342) | Write has completed. Shutdown being performed. | 2018-02-13 15:08:50 CQG WebSocket socket (342) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:08:50 CQG WebSocket socket (342) | Socket gracefully closed by remote side. | 2018-02-13 15:08:50 CQG WebSocket socket (342) | Closed. | 2018-02-13 15:08:50 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:08:53 CQG FIX: DisconnectFIX called. | 2018-02-13 15:08:57 CQG FIX: Sending a Logout message. | 2018-02-13 15:08:57 CQG FIX Trading | Disconnected. | 2018-02-13 15:08:57 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 15:08:57 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 15:08:57 CQG FIX socket (341) | Initiating close of socket by core. | 2018-02-13 15:08:57 CQG FIX: Disconnected. | 2018-02-13 15:08:57 CQG FIX socket (341) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:08:57 CQG FIX socket (341) | Socket gracefully closed by remote side. | 2018-02-13 15:08:57 CQG FIX socket (341) | Closed. | 2018-02-13 15:08:57 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 15:09:03 CQG FIX socket (348) | Creating socket. Using TLS 1.2. | 2018-02-13 15:09:03 CQG FIX socket (348) | Connecting to IP: 208.48.16.214. | 2018-02-13 15:09:03 CQG FIX: Sending the Logon message. | 2018-02-13 15:09:08 CQG FIX Trading | Connected to trading server. | 2018-02-13 15:09:08 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 15:09:08 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 15:09:08 CQG WebSocket socket (349) | Creating socket. Using TLS 1.2. | 2018-02-13 15:09:08 CQG WebSocket socket (349) | Connecting to IP: 208.48.16.35. | 2018-02-13 15:09:08 CQG FIX | FCM name: AMP | 2018-02-13 15:09:09 CQG WebSocket | Opening WebSocket. | 2018-02-13 15:09:09 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 15:09:09 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 15:09:09 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 15:09:09 CQG WebSocket | Header line. Sec-WebSocket-Accept: cF4ouNug6nhGI6wtSMEyyRdnXOM= | 2018-02-13 15:09:09 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 15:09:09 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 15:09:09 CQG WebSocket | Header line. | 2018-02-13 15:09:09 CQG WebSocket | Web socket state is now open. | 2018-02-13 15:09:09 CQG FIX Trading | WebSocket connected. | 2018-02-13 15:09:09 CQG FIX Trading | Sending market data logon message. | 2018-02-13 15:09:09 CQG FIX Trading | Logon successful. Session Token = 2CGDSViv7+L9Pf0HlhsSK6H/SM5qO4RtUXvrheT/TOAh5FVmcG49hFjLkXyL614HfX3BRKhfmvu | 2018-02-13 15:09:10 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 15:09:14 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 1 | 2018-02-13 15:09:14 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 701990 | 2018-02-13 15:09:14 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 1 | 2018-02-13 15:09:14 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 15:09:14 Delaying start of download for F.US.YMH18 | 2018-02-13 15:09:14 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:09:14 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 701991 | 2018-02-13 15:09:14 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:09:14 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 2 | 2018-02-13 15:09:14 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 701992 | 2018-02-13 15:09:14 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 2 | 2018-02-13 15:09:14 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 15:09:14 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 4 | 2018-02-13 15:09:14 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 701993 | 2018-02-13 15:09:14 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 4 | 2018-02-13 15:09:14 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 15:09:14 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 701990. Contract ID: 1. | 2018-02-13 15:09:14 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 15:09:14 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 701991. Contract ID: 2. | 2018-02-13 15:09:14 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 15:09:14 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 701992. Contract ID: 3. | 2018-02-13 15:09:14 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 15:09:14 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 701993. Contract ID: 4. | 2018-02-13 15:09:14 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 15:09:14 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 5 | 2018-02-13 15:09:16 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 701994 | 2018-02-13 15:09:16 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 5 | 2018-02-13 15:09:16 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 6 | 2018-02-13 15:09:16 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 701995 | 2018-02-13 15:09:16 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 6 | 2018-02-13 15:09:16 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 7 | 2018-02-13 15:09:16 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 701996 | 2018-02-13 15:09:16 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 7 | 2018-02-13 15:09:16 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 8 | 2018-02-13 15:09:16 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 701997 | 2018-02-13 15:09:16 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 8 | 2018-02-13 15:09:16 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 9 | 2018-02-13 15:09:16 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 701998 | 2018-02-13 15:09:16 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 9 | 2018-02-13 15:09:16 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 10 | 2018-02-13 15:09:16 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 701999 | 2018-02-13 15:09:16 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 10 | 2018-02-13 15:09:16 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 12 | 2018-02-13 15:09:16 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 702000 | 2018-02-13 15:09:16 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 12 | 2018-02-13 15:09:16 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 11 | 2018-02-13 15:09:16 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 702001 | 2018-02-13 15:09:16 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 11 | 2018-02-13 15:09:16 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 13 | 2018-02-13 15:09:16 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 702002 | 2018-02-13 15:09:16 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 13 | 2018-02-13 15:09:16 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 701994. Contract ID: 5. | 2018-02-13 15:09:17 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 15:09:17 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 701995. Contract ID: 6. | 2018-02-13 15:09:17 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 15:09:17 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 701996. Contract ID: 7. | 2018-02-13 15:09:17 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 15:09:17 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 701997. Contract ID: 8. | 2018-02-13 15:09:17 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 15:09:17 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 701998. Contract ID: 9. | 2018-02-13 15:09:17 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 15:09:17 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 701999. Contract ID: 10. | 2018-02-13 15:09:17 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 15:09:17 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 702000. Contract ID: 11. | 2018-02-13 15:09:17 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 15:09:17 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 702001. Contract ID: 12. | 2018-02-13 15:09:17 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 15:09:17 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 702002. Contract ID: 13. | 2018-02-13 15:09:17 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 15:09:17 HD Request # 125 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 15:09:19 HD Request # 125 | Download start date-time: 2018-02-13 15:08:43.000 | 2018-02-13 15:09:19 HD Request # 125 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:09:19 Socket (350) | Creating socket. | 2018-02-13 15:09:19 Socket (350) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:09:19 HD Request # 125 | Setting DTC encoding to Binary VLS | 2018-02-13 15:09:19 HD Request # 125 | Sending historical data logon request message. | 2018-02-13 15:09:19 HD Request # 125 | Requesting Intraday data. Start date-time: 2018-02-13 15:08:43. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 15:09:19 HD Request # 125 | Decompressing data. | 2018-02-13 15:09:19 HD Request # 125 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 15:08:43 | 2018-02-13 15:09:19 HD Request # 125 | Timestamp of first Intraday data file record written: 2018-02-13 15:08:49 | 2018-02-13 15:09:19 Socket (350) | Initiating close of socket by core. | 2018-02-13 15:09:19 Socket (350) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:09:19 Socket (350) | Socket gracefully closed by remote side. | 2018-02-13 15:09:20 Socket (350) | Closed. | 2018-02-13 15:09:20 Historical data download thread signaled to stop. | 2018-02-13 15:09:20 HD Request # 125 | Received 46 records from 2018-02-13 15:08:43 to 2018-02-13 15:09:16 (33.0 seconds) and wrote 36 records for F.US.YMH18 | 2018-02-13 15:09:20 Added 4 Time and Sales records to Intraday data file for F.US.YMH18 after download. | 2018-02-13 15:09:20 HD Request # 125 | Completion time: 1s | 2018-02-13 15:09:20 HD Request # 125 | Intraday data download complete for F.US.YMH18. Unique request ID: 124 | 2018-02-13 15:09:20 Removed historical data download ID 124 | 2018-02-13 15:09:20 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 15:09:20 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 15:09:20 HD Request # 126 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 15:09:20 HD Request # 126 | Download start date-time: 2018-02-13 15:08:40.000 | 2018-02-13 15:09:20 HD Request # 126 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:09:20 Socket (351) | Creating socket. | 2018-02-13 15:09:20 Socket (351) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:09:20 HD Request # 126 | Setting DTC encoding to Binary VLS | 2018-02-13 15:09:20 HD Request # 126 | Sending historical data logon request message. | 2018-02-13 15:09:20 HD Request # 126 | Requesting Intraday data. Start date-time: 2018-02-13 15:08:40. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 15:09:20 HD Request # 126 | Decompressing data. | 2018-02-13 15:09:20 HD Request # 126 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 15:08:40 | 2018-02-13 15:09:20 HD Request # 126 | Timestamp of first Intraday data file record written: 2018-02-13 15:08:49 | 2018-02-13 15:09:20 Socket (351) | Initiating close of socket by core. | 2018-02-13 15:09:20 Socket (351) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:09:20 Socket (351) | Socket gracefully closed by remote side. | 2018-02-13 15:09:20 Socket (351) | Closed. | 2018-02-13 15:09:20 Historical data download thread signaled to stop. | 2018-02-13 15:09:21 HD Request # 126 | Received 2 records from 2018-02-13 15:08:40 to 2018-02-13 15:08:49 (9.0 seconds) and wrote 1 record for F.US.CLEH18 | 2018-02-13 15:09:21 Added 8 Time and Sales records to Intraday data file for F.US.CLEH18 after download. | 2018-02-13 15:09:21 HD Request # 126 | Completion time: 0s | 2018-02-13 15:09:21 HD Request # 126 | Intraday data download complete for F.US.CLEH18. Unique request ID: 125 | 2018-02-13 15:09:21 Removed historical data download ID 125 | 2018-02-13 15:09:21 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 15:09:21 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 15:09:21 HD Request # 127 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 15:09:21 HD Request # 127 | Download start date-time: 2018-02-13 15:08:48.000 | 2018-02-13 15:09:21 HD Request # 127 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:09:21 Socket (352) | Creating socket. | 2018-02-13 15:09:21 Socket (352) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:09:21 HD Request # 127 | Setting DTC encoding to Binary VLS | 2018-02-13 15:09:21 HD Request # 127 | Sending historical data logon request message. | 2018-02-13 15:09:21 HD Request # 127 | Requesting Intraday data. Start date-time: 2018-02-13 15:08:48. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 15:09:21 HD Request # 127 | Decompressing data. | 2018-02-13 15:09:21 HD Request # 127 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 15:08:48 | 2018-02-13 15:09:21 HD Request # 127 | Timestamp of first Intraday data file record written: 2018-02-13 15:08:50 | 2018-02-13 15:09:21 Socket (352) | Initiating close of socket by core. | 2018-02-13 15:09:21 Socket (352) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:09:21 Socket (352) | Socket gracefully closed by remote side. | 2018-02-13 15:09:21 Socket (352) | Closed. | 2018-02-13 15:09:21 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:09:22 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:09:22 Historical data download thread signaled to stop. | 2018-02-13 15:09:22 HD Request # 127 | Received 33 records from 2018-02-13 15:08:48 to 2018-02-13 15:09:17 (29.0 seconds) and wrote 31 records for F.US.RTYH18 | 2018-02-13 15:09:22 HD Request # 127 | Completion time: 0s | 2018-02-13 15:09:22 HD Request # 127 | Intraday data download complete for F.US.RTYH18. Unique request ID: 126 | 2018-02-13 15:09:22 Removed historical data download ID 126 | 2018-02-13 15:09:22 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 15:09:22 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 15:09:22 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:09:22 Chart #2 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:09:22 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:09:22 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:09:22 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:09:22 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:09:22 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:09:23 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:09:23 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 15:09:23 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 15:09:23 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 15:09:23 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 15:09:23 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 15:09:23 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 15:09:23 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:09:23 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 15:09:24 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 15:09:24 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 15:09:24 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:09:25 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:09:25 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:09:25 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:09:49 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:09:49 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:09:56 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:09:56 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:10:01 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:10:01 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:10:01 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:10:01 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:10:05 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:10:05 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:10:05 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:10:06 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:10:08 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:10:10 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 15:10:34 CQG WebSocket socket (349) | Adding bytes from final send buffer from buffered socket: 22 | 2018-02-13 15:10:34 CQG WebSocket socket (349) | Initiating close of socket by core. | 2018-02-13 15:10:34 CQG WebSocket | WebSocket closed. | 2018-02-13 15:10:34 CQG FIX Trading | WebSocket closed. | 2018-02-13 15:10:34 Connection to the external service has been lost. | 2018-02-13 15:10:34 CQG WebSocket socket (349) | Write in progress. Shutdown being delayed. | 2018-02-13 15:10:34 CQG WebSocket socket (349) | Sending bytes from final send buffer: 22 | 2018-02-13 15:10:34 CQG WebSocket socket (349) | Write has completed. Shutdown being performed. | 2018-02-13 15:10:34 CQG WebSocket socket (349) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:10:34 CQG WebSocket socket (349) | Socket gracefully closed by remote side. | 2018-02-13 15:10:34 CQG WebSocket socket (349) | Closed. | 2018-02-13 15:10:34 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:10:38 CQG FIX: DisconnectFIX called. | 2018-02-13 15:10:45 CQG FIX: Sending a Logout message. | 2018-02-13 15:10:45 CQG FIX Trading | Disconnected. | 2018-02-13 15:10:45 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 15:10:45 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 15:10:46 CQG FIX socket (348) | Initiating close of socket by core. | 2018-02-13 15:10:46 CQG FIX: Disconnected. | 2018-02-13 15:10:46 CQG FIX socket (348) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:10:46 CQG FIX socket (348) | Socket gracefully closed by remote side. | 2018-02-13 15:10:46 CQG FIX socket (348) | Closed. | 2018-02-13 15:10:46 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 15:10:52 CQG FIX socket (354) | Creating socket. Using TLS 1.2. | 2018-02-13 15:10:52 CQG FIX socket (354) | Connecting to IP: 208.48.16.214. | 2018-02-13 15:10:52 CQG FIX: Sending the Logon message. | 2018-02-13 15:10:55 CQG FIX Trading | Connected to trading server. | 2018-02-13 15:10:56 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 15:10:56 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 15:10:56 CQG WebSocket socket (355) | Creating socket. Using TLS 1.2. | 2018-02-13 15:10:56 CQG WebSocket socket (355) | Connecting to IP: 208.48.16.35. | 2018-02-13 15:10:56 CQG WebSocket | Opening WebSocket. | 2018-02-13 15:10:57 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 15:10:57 CQG FIX | FCM name: AMP | 2018-02-13 15:10:57 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 15:10:57 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 15:10:57 CQG WebSocket | Header line. Sec-WebSocket-Accept: VoDGtG21uAeE6OqTzvQzfU9Fm80= | 2018-02-13 15:10:57 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 15:10:57 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 15:10:57 CQG WebSocket | Header line. | 2018-02-13 15:10:57 CQG WebSocket | Web socket state is now open. | 2018-02-13 15:10:57 CQG FIX Trading | WebSocket connected. | 2018-02-13 15:10:57 CQG FIX Trading | Sending market data logon message. | 2018-02-13 15:10:57 CQG FIX Trading | Logon successful. Session Token = 6elHgkhqq5UvCVtNTa3upSdmZ1iz9VBxjRxT/SytmcEgZ7+dat/Z8uE4vtvXT+HZ9bStLt9amkW | 2018-02-13 15:10:58 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 15:11:01 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 1 | 2018-02-13 15:11:01 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 702003 | 2018-02-13 15:11:01 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 1 | 2018-02-13 15:11:01 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 15:11:01 Delaying start of download for F.US.YMH18 | 2018-02-13 15:11:01 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:11:01 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 702004 | 2018-02-13 15:11:01 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:11:01 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 2 | 2018-02-13 15:11:01 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 702005 | 2018-02-13 15:11:01 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 2 | 2018-02-13 15:11:01 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 15:11:01 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 702003. Contract ID: 1. | 2018-02-13 15:11:02 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 15:11:02 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 702004. Contract ID: 2. | 2018-02-13 15:11:02 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 15:11:02 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 702005. Contract ID: 3. | 2018-02-13 15:11:02 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 15:11:02 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 4 | 2018-02-13 15:11:02 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 702006 | 2018-02-13 15:11:02 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 4 | 2018-02-13 15:11:02 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 15:11:02 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 702006. Contract ID: 4. | 2018-02-13 15:11:03 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 15:11:03 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 5 | 2018-02-13 15:11:04 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 702007 | 2018-02-13 15:11:04 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 5 | 2018-02-13 15:11:04 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 7 | 2018-02-13 15:11:04 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 702008 | 2018-02-13 15:11:04 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 7 | 2018-02-13 15:11:04 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 6 | 2018-02-13 15:11:04 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 702009 | 2018-02-13 15:11:04 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 6 | 2018-02-13 15:11:04 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 8 | 2018-02-13 15:11:04 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 702010 | 2018-02-13 15:11:04 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 8 | 2018-02-13 15:11:04 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 9 | 2018-02-13 15:11:04 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 702011 | 2018-02-13 15:11:04 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 9 | 2018-02-13 15:11:04 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:11:04 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 702012 | 2018-02-13 15:11:04 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:11:04 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 11 | 2018-02-13 15:11:04 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 702013 | 2018-02-13 15:11:04 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 11 | 2018-02-13 15:11:04 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 12 | 2018-02-13 15:11:04 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 702014 | 2018-02-13 15:11:04 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 12 | 2018-02-13 15:11:04 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 13 | 2018-02-13 15:11:04 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 702015 | 2018-02-13 15:11:04 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 13 | 2018-02-13 15:11:04 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 702007. Contract ID: 5. | 2018-02-13 15:11:05 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 15:11:05 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 702008. Contract ID: 6. | 2018-02-13 15:11:05 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 15:11:05 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 702009. Contract ID: 7. | 2018-02-13 15:11:05 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 15:11:05 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 702010. Contract ID: 8. | 2018-02-13 15:11:05 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 15:11:05 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 702011. Contract ID: 9. | 2018-02-13 15:11:05 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 15:11:05 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 702012. Contract ID: 10. | 2018-02-13 15:11:05 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 15:11:05 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 702013. Contract ID: 11. | 2018-02-13 15:11:05 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 15:11:05 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 702014. Contract ID: 12. | 2018-02-13 15:11:05 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 15:11:05 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 702015. Contract ID: 13. | 2018-02-13 15:11:05 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 15:11:05 Delaying start of download for F.US.YMH18 | 2018-02-13 15:11:06 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 15:11:10 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 15:11:10 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 15:11:10 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 15:11:10 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 15:11:10 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 15:11:10 HD Request # 128 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 15:11:13 HD Request # 128 | Download start date-time: 2018-02-13 15:10:33.000 | 2018-02-13 15:11:13 HD Request # 128 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:11:13 Socket (356) | Creating socket. | 2018-02-13 15:11:13 Socket (356) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:11:13 HD Request # 128 | Setting DTC encoding to Binary VLS | 2018-02-13 15:11:13 HD Request # 128 | Sending historical data logon request message. | 2018-02-13 15:11:13 HD Request # 128 | Requesting Intraday data. Start date-time: 2018-02-13 15:10:33. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 15:11:13 HD Request # 128 | Decompressing data. | 2018-02-13 15:11:13 HD Request # 128 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 15:10:33 | 2018-02-13 15:11:13 HD Request # 128 | Timestamp of first Intraday data file record written: 2018-02-13 15:10:37 | 2018-02-13 15:11:13 Socket (356) | Initiating close of socket by core. | 2018-02-13 15:11:13 Socket (356) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:11:13 Socket (356) | Socket gracefully closed by remote side. | 2018-02-13 15:11:13 Socket (356) | Closed. | 2018-02-13 15:11:13 Historical data download thread signaled to stop. | 2018-02-13 15:11:13 HD Request # 128 | Received 80 records from 2018-02-13 15:10:33 to 2018-02-13 15:11:09 (36.0 seconds) and wrote 71 records for F.US.YMH18 | 2018-02-13 15:11:13 HD Request # 128 | Completion time: 1s | 2018-02-13 15:11:13 HD Request # 128 | Intraday data download complete for F.US.YMH18. Unique request ID: 127 | 2018-02-13 15:11:13 Removed historical data download ID 127 | 2018-02-13 15:11:13 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 15:11:13 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 15:11:13 HD Request # 129 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 15:11:13 HD Request # 129 | Download start date-time: 2018-02-13 15:09:41.000 | 2018-02-13 15:11:13 HD Request # 129 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:11:13 Socket (357) | Creating socket. | 2018-02-13 15:11:13 Socket (357) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:11:13 HD Request # 129 | Setting DTC encoding to Binary VLS | 2018-02-13 15:11:13 HD Request # 129 | Sending historical data logon request message. | 2018-02-13 15:11:13 HD Request # 129 | Requesting Intraday data. Start date-time: 2018-02-13 15:09:41. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 15:11:14 HD Request # 129 | Decompressing data. | 2018-02-13 15:11:14 HD Request # 129 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 15:09:41 | 2018-02-13 15:11:14 HD Request # 129 | Timestamp of first Intraday data file record written: 2018-02-13 15:10:50 | 2018-02-13 15:11:14 Socket (357) | Initiating close of socket by core. | 2018-02-13 15:11:14 Socket (357) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:11:14 Socket (357) | Socket gracefully closed by remote side. | 2018-02-13 15:11:14 Socket (357) | Closed. | 2018-02-13 15:11:14 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:11:14 Historical data download thread signaled to stop. | 2018-02-13 15:11:14 HD Request # 129 | Received 24 records from 2018-02-13 15:09:41 to 2018-02-13 15:11:06 (85.0 seconds) and wrote 21 records for F.US.CLEH18 | 2018-02-13 15:11:14 HD Request # 129 | Completion time: 0s | 2018-02-13 15:11:14 HD Request # 129 | Intraday data download complete for F.US.CLEH18. Unique request ID: 128 | 2018-02-13 15:11:14 Removed historical data download ID 128 | 2018-02-13 15:11:14 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 15:11:14 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 15:11:14 HD Request # 130 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 15:11:14 HD Request # 130 | Download start date-time: 2018-02-13 15:10:33.000 | 2018-02-13 15:11:14 HD Request # 130 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:11:14 Socket (358) | Creating socket. | 2018-02-13 15:11:14 Socket (358) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:11:14 HD Request # 130 | Setting DTC encoding to Binary VLS | 2018-02-13 15:11:14 HD Request # 130 | Sending historical data logon request message. | 2018-02-13 15:11:14 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:11:14 Chart #2 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:11:14 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:11:14 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:11:14 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:11:14 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:11:14 HD Request # 130 | Requesting Intraday data. Start date-time: 2018-02-13 15:10:33. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 15:11:14 HD Request # 130 | Decompressing data. | 2018-02-13 15:11:14 HD Request # 130 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 15:10:33 | 2018-02-13 15:11:14 HD Request # 130 | Timestamp of first Intraday data file record written: 2018-02-13 15:10:38 | 2018-02-13 15:11:14 Socket (358) | Initiating close of socket by core. | 2018-02-13 15:11:14 Socket (358) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:11:14 Socket (358) | Socket gracefully closed by remote side. | 2018-02-13 15:11:14 Socket (358) | Closed. | 2018-02-13 15:11:14 Historical data download thread signaled to stop. | 2018-02-13 15:11:15 HD Request # 130 | Received 19 records from 2018-02-13 15:10:33 to 2018-02-13 15:11:06 (33.0 seconds) and wrote 18 records for F.US.RTYH18 | 2018-02-13 15:11:15 HD Request # 130 | Completion time: 0s | 2018-02-13 15:11:15 HD Request # 130 | Intraday data download complete for F.US.RTYH18. Unique request ID: 129 | 2018-02-13 15:11:15 Removed historical data download ID 129 | 2018-02-13 15:11:15 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 15:11:15 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 15:11:15 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:11:16 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:11:16 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:11:16 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:11:16 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 15:11:17 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 15:11:17 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:11:20 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:11:20 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:11:20 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:11:20 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:11:20 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:11:20 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:11:23 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:11:23 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:11:25 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:11:25 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:11:25 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:11:48 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:11:48 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 15:11:50 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:11:55 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:11:56 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 15:12:02 CQG WebSocket socket (355) | Adding bytes from final send buffer from buffered socket: 8 | 2018-02-13 15:12:02 CQG WebSocket socket (355) | Initiating close of socket by core. | 2018-02-13 15:12:02 CQG WebSocket | WebSocket closed. | 2018-02-13 15:12:02 CQG WebSocket socket (355) | Write in progress. Shutdown being delayed. | 2018-02-13 15:12:02 CQG FIX Trading | WebSocket closed. | 2018-02-13 15:12:02 Connection to the external service has been lost. | 2018-02-13 15:12:02 CQG WebSocket socket (355) | Sending bytes from final send buffer: 8 | 2018-02-13 15:12:02 CQG WebSocket socket (355) | Write has completed. Shutdown being performed. | 2018-02-13 15:12:02 CQG WebSocket socket (355) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:12:02 CQG WebSocket socket (355) | Socket gracefully closed by remote side. | 2018-02-13 15:12:02 CQG WebSocket socket (355) | Closed. | 2018-02-13 15:12:02 CQG FIX: DisconnectFIX called. | 2018-02-13 15:12:10 CQG FIX: Sending a Logout message. | 2018-02-13 15:12:10 CQG FIX Trading | Disconnected. | 2018-02-13 15:12:10 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 15:12:10 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 15:12:10 CQG FIX socket (354) | Initiating close of socket by core. | 2018-02-13 15:12:10 CQG FIX: Disconnected. | 2018-02-13 15:12:10 CQG FIX socket (354) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:12:10 CQG FIX socket (354) | Socket gracefully closed by remote side. | 2018-02-13 15:12:10 CQG FIX socket (354) | Closed. | 2018-02-13 15:12:10 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 15:12:16 CQG FIX socket (360) | Creating socket. Using TLS 1.2. | 2018-02-13 15:12:16 CQG FIX socket (360) | Connecting to IP: 208.48.16.214. | 2018-02-13 15:12:16 CQG FIX: Sending the Logon message. | 2018-02-13 15:12:19 CQG FIX Trading | Connected to trading server. | 2018-02-13 15:12:20 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 15:12:20 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 15:12:20 CQG WebSocket socket (361) | Creating socket. Using TLS 1.2. | 2018-02-13 15:12:20 CQG WebSocket socket (361) | Connecting to IP: 208.48.16.35. | 2018-02-13 15:12:20 CQG WebSocket | Opening WebSocket. | 2018-02-13 15:12:20 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 15:12:20 CQG FIX | FCM name: AMP | 2018-02-13 15:12:20 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 15:12:21 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 15:12:21 CQG WebSocket | Header line. Sec-WebSocket-Accept: /weYKul6oGef0ep6tpWkLik3NzY= | 2018-02-13 15:12:21 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 15:12:21 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 15:12:21 CQG WebSocket | Header line. | 2018-02-13 15:12:21 CQG WebSocket | Web socket state is now open. | 2018-02-13 15:12:21 CQG FIX Trading | WebSocket connected. | 2018-02-13 15:12:21 CQG FIX Trading | Sending market data logon message. | 2018-02-13 15:12:21 CQG FIX Trading | Logon successful. Session Token = Wa431qxFwBtQKCzABUU0trSQGGuOHhz6eeua/eK/+FcCPSJXolYB+TD7QZyu6bhCzyIWLu2C/PZ | 2018-02-13 15:12:22 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 15:12:26 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 1 | 2018-02-13 15:12:26 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 702016 | 2018-02-13 15:12:26 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 1 | 2018-02-13 15:12:26 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 15:12:26 Delaying start of download for F.US.YMH18 | 2018-02-13 15:12:26 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:12:26 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 702017 | 2018-02-13 15:12:26 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:12:26 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 2 | 2018-02-13 15:12:26 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 702018 | 2018-02-13 15:12:26 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 2 | 2018-02-13 15:12:26 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 15:12:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 702016. Contract ID: 1. | 2018-02-13 15:12:26 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 15:12:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 702017. Contract ID: 2. | 2018-02-13 15:12:26 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 15:12:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 702018. Contract ID: 3. | 2018-02-13 15:12:26 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 15:12:26 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 4 | 2018-02-13 15:12:26 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 702019 | 2018-02-13 15:12:26 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 4 | 2018-02-13 15:12:26 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 15:12:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 702019. Contract ID: 4. | 2018-02-13 15:12:27 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 15:12:27 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 5 | 2018-02-13 15:12:27 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 702020 | 2018-02-13 15:12:27 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 5 | 2018-02-13 15:12:27 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 7 | 2018-02-13 15:12:27 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 702021 | 2018-02-13 15:12:27 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 7 | 2018-02-13 15:12:27 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 6 | 2018-02-13 15:12:27 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 702022 | 2018-02-13 15:12:27 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 6 | 2018-02-13 15:12:27 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 8 | 2018-02-13 15:12:27 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 702023 | 2018-02-13 15:12:27 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 8 | 2018-02-13 15:12:27 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 9 | 2018-02-13 15:12:27 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 702024 | 2018-02-13 15:12:27 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 9 | 2018-02-13 15:12:27 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:12:27 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 702025 | 2018-02-13 15:12:27 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:12:27 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 11 | 2018-02-13 15:12:27 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 702026 | 2018-02-13 15:12:27 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 11 | 2018-02-13 15:12:27 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 12 | 2018-02-13 15:12:27 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 702027 | 2018-02-13 15:12:27 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 12 | 2018-02-13 15:12:27 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 13 | 2018-02-13 15:12:27 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 702028 | 2018-02-13 15:12:27 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 13 | 2018-02-13 15:12:27 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 702020. Contract ID: 5. | 2018-02-13 15:12:28 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 15:12:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 702021. Contract ID: 6. | 2018-02-13 15:12:28 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 15:12:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 702022. Contract ID: 7. | 2018-02-13 15:12:28 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 15:12:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 702023. Contract ID: 8. | 2018-02-13 15:12:28 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 15:12:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 702024. Contract ID: 9. | 2018-02-13 15:12:28 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 15:12:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 702025. Contract ID: 10. | 2018-02-13 15:12:28 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 15:12:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 702026. Contract ID: 11. | 2018-02-13 15:12:28 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 15:12:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 702027. Contract ID: 12. | 2018-02-13 15:12:28 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 15:12:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 702028. Contract ID: 13. | 2018-02-13 15:12:28 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 15:12:28 HD Request # 131 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 15:12:32 HD Request # 131 | Download start date-time: 2018-02-13 15:11:59.000 | 2018-02-13 15:12:32 HD Request # 131 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:12:32 Socket (362) | Creating socket. | 2018-02-13 15:12:32 Socket (362) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:12:32 HD Request # 131 | Setting DTC encoding to Binary VLS | 2018-02-13 15:12:32 HD Request # 131 | Sending historical data logon request message. | 2018-02-13 15:12:32 HD Request # 131 | Requesting Intraday data. Start date-time: 2018-02-13 15:11:59. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 15:12:32 HD Request # 131 | Decompressing data. | 2018-02-13 15:12:32 HD Request # 131 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 15:11:59 | 2018-02-13 15:12:32 HD Request # 131 | Timestamp of first Intraday data file record written: 2018-02-13 15:12:01 | 2018-02-13 15:12:32 Socket (362) | Initiating close of socket by core. | 2018-02-13 15:12:32 Socket (362) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:12:32 Socket (362) | Socket gracefully closed by remote side. | 2018-02-13 15:12:32 Socket (362) | Closed. | 2018-02-13 15:12:32 Historical data download thread signaled to stop. | 2018-02-13 15:12:33 HD Request # 131 | Received 64 records from 2018-02-13 15:11:59 to 2018-02-13 15:12:29 (30.0 seconds) and wrote 58 records for F.US.YMH18 | 2018-02-13 15:12:33 Added 2 Time and Sales records to Intraday data file for F.US.YMH18 after download. | 2018-02-13 15:12:33 HD Request # 131 | Completion time: 0s | 2018-02-13 15:12:33 HD Request # 131 | Intraday data download complete for F.US.YMH18. Unique request ID: 130 | 2018-02-13 15:12:33 Removed historical data download ID 130 | 2018-02-13 15:12:33 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 15:12:33 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 15:12:33 HD Request # 132 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 15:12:33 HD Request # 132 | Download start date-time: 2018-02-13 15:11:32.000 | 2018-02-13 15:12:33 HD Request # 132 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:12:33 Socket (363) | Creating socket. | 2018-02-13 15:12:33 Socket (363) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:12:33 HD Request # 132 | Setting DTC encoding to Binary VLS | 2018-02-13 15:12:33 HD Request # 132 | Sending historical data logon request message. | 2018-02-13 15:12:33 HD Request # 132 | Requesting Intraday data. Start date-time: 2018-02-13 15:11:32. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 15:12:33 HD Request # 132 | Decompressing data. | 2018-02-13 15:12:33 HD Request # 132 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 15:11:32 | 2018-02-13 15:12:33 Socket (363) | Initiating close of socket by core. | 2018-02-13 15:12:33 Socket (363) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:12:33 Socket (363) | Socket gracefully closed by remote side. | 2018-02-13 15:12:33 Socket (363) | Closed. | 2018-02-13 15:12:33 Historical data download thread signaled to stop. | 2018-02-13 15:12:33 HD Request # 132 | Received 1 record from 2018-02-13 15:11:32 to 2018-02-13 15:11:32 (0.0 seconds) and wrote 0 records for F.US.CLEH18 | 2018-02-13 15:12:33 HD Request # 132 | Completion time: 1s | 2018-02-13 15:12:33 HD Request # 132 | Intraday data download complete for F.US.CLEH18. Unique request ID: 131 | 2018-02-13 15:12:33 Removed historical data download ID 131 | 2018-02-13 15:12:33 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 15:12:33 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 15:12:33 HD Request # 133 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 15:12:33 HD Request # 133 | Download start date-time: 2018-02-13 15:12:00.000 | 2018-02-13 15:12:33 HD Request # 133 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:12:33 Socket (364) | Creating socket. | 2018-02-13 15:12:33 Socket (364) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:12:33 HD Request # 133 | Setting DTC encoding to Binary VLS | 2018-02-13 15:12:34 HD Request # 133 | Sending historical data logon request message. | 2018-02-13 15:12:34 HD Request # 133 | Requesting Intraday data. Start date-time: 2018-02-13 15:12:00. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 15:12:34 HD Request # 133 | Decompressing data. | 2018-02-13 15:12:34 HD Request # 133 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 15:12:00 | 2018-02-13 15:12:34 HD Request # 133 | Timestamp of first Intraday data file record written: 2018-02-13 15:12:01 | 2018-02-13 15:12:34 Socket (364) | Initiating close of socket by core. | 2018-02-13 15:12:34 Socket (364) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:12:34 Socket (364) | Socket gracefully closed by remote side. | 2018-02-13 15:12:34 Socket (364) | Closed. | 2018-02-13 15:12:34 Historical data download thread signaled to stop. | 2018-02-13 15:12:34 HD Request # 133 | Received 106 records from 2018-02-13 15:12:00 to 2018-02-13 15:12:30 (30.0 seconds) and wrote 97 records for F.US.RTYH18 | 2018-02-13 15:12:34 Added 9 Time and Sales records to Intraday data file for F.US.RTYH18 after download. | 2018-02-13 15:12:34 HD Request # 133 | Completion time: 1s | 2018-02-13 15:12:34 HD Request # 133 | Intraday data download complete for F.US.RTYH18. Unique request ID: 132 | 2018-02-13 15:12:34 Removed historical data download ID 132 | 2018-02-13 15:12:34 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 15:12:34 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 15:12:34 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:12:34 Chart #2 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:12:34 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:12:34 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:12:34 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:12:34 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:12:34 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:12:35 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 15:12:36 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:12:37 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:12:37 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:12:37 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:13:01 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:13:01 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 15:13:03 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 15:13:03 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:13:08 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 15:13:08 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 15:13:08 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 15:13:08 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 15:13:08 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 15:13:08 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 15:13:08 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:13:08 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:13:08 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:13:08 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:13:08 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:13:13 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:13:13 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:13:13 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:13:13 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:13:13 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:13:13 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:13:15 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:13:15 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:13:16 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:13:18 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 15:13:42 CQG WebSocket socket (361) | Adding bytes from final send buffer from buffered socket: 22 | 2018-02-13 15:13:42 CQG WebSocket socket (361) | Initiating close of socket by core. | 2018-02-13 15:13:42 CQG WebSocket | WebSocket closed. | 2018-02-13 15:13:42 CQG FIX Trading | WebSocket closed. | 2018-02-13 15:13:42 Connection to the external service has been lost. | 2018-02-13 15:13:42 CQG WebSocket socket (361) | Sending bytes from final send buffer: 22 | 2018-02-13 15:13:42 CQG WebSocket socket (361) | Write in progress. Shutdown being delayed. | 2018-02-13 15:13:42 CQG WebSocket socket (361) | Write has completed. Shutdown being performed. | 2018-02-13 15:13:42 CQG WebSocket socket (361) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:13:42 CQG WebSocket socket (361) | Socket gracefully closed by remote side. | 2018-02-13 15:13:42 CQG WebSocket socket (361) | Closed. | 2018-02-13 15:13:42 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:13:46 CQG FIX: DisconnectFIX called. | 2018-02-13 15:13:53 CQG FIX: Sending a Logout message. | 2018-02-13 15:13:53 CQG FIX Trading | Disconnected. | 2018-02-13 15:13:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 15:13:53 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 15:13:54 CQG FIX socket (360) | Initiating close of socket by core. | 2018-02-13 15:13:54 CQG FIX: Disconnected. | 2018-02-13 15:13:54 CQG FIX socket (360) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:13:54 CQG FIX socket (360) | Socket gracefully closed by remote side. | 2018-02-13 15:13:54 CQG FIX socket (360) | Closed. | 2018-02-13 15:13:54 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 15:14:00 CQG FIX socket (367) | Creating socket. Using TLS 1.2. | 2018-02-13 15:14:00 CQG FIX socket (367) | Connecting to IP: 208.48.16.214. | 2018-02-13 15:14:00 CQG FIX: Sending the Logon message. | 2018-02-13 15:14:03 CQG FIX Trading | Connected to trading server. | 2018-02-13 15:14:04 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 15:14:04 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 15:14:04 CQG WebSocket socket (368) | Creating socket. Using TLS 1.2. | 2018-02-13 15:14:04 CQG WebSocket socket (368) | Connecting to IP: 208.48.16.35. | 2018-02-13 15:14:04 CQG FIX | FCM name: AMP | 2018-02-13 15:14:05 CQG WebSocket | Opening WebSocket. | 2018-02-13 15:14:05 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 15:14:05 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 15:14:05 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 15:14:05 CQG WebSocket | Header line. Sec-WebSocket-Accept: ybGsEokgZYw85GW345CUx/x5GQk= | 2018-02-13 15:14:05 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 15:14:05 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 15:14:05 CQG WebSocket | Header line. | 2018-02-13 15:14:05 CQG WebSocket | Web socket state is now open. | 2018-02-13 15:14:05 CQG FIX Trading | WebSocket connected. | 2018-02-13 15:14:05 CQG FIX Trading | Sending market data logon message. | 2018-02-13 15:14:05 CQG FIX Trading | Logon successful. Session Token = 3e0JTa6q1IOEBYQkalY83xvmnIFX4VYC6jMT4Z17avMu7VzCGrLOR8V+NAAYFP4MX4nP2IXTGkZ | 2018-02-13 15:14:06 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 15:14:09 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 1 | 2018-02-13 15:14:09 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 702029 | 2018-02-13 15:14:09 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 1 | 2018-02-13 15:14:09 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 15:14:09 Delaying start of download for F.US.YMH18 | 2018-02-13 15:14:09 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:14:09 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 702030 | 2018-02-13 15:14:09 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:14:09 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 2 | 2018-02-13 15:14:09 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 702031 | 2018-02-13 15:14:09 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 2 | 2018-02-13 15:14:09 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 15:14:09 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 702029. Contract ID: 1. | 2018-02-13 15:14:10 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 15:14:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 702030. Contract ID: 2. | 2018-02-13 15:14:10 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 15:14:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 702031. Contract ID: 3. | 2018-02-13 15:14:10 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 15:14:10 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 4 | 2018-02-13 15:14:10 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 702032 | 2018-02-13 15:14:10 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 4 | 2018-02-13 15:14:10 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 6 | 2018-02-13 15:14:10 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 702033 | 2018-02-13 15:14:10 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 6 | 2018-02-13 15:14:10 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 5 | 2018-02-13 15:14:10 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 702034 | 2018-02-13 15:14:10 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 5 | 2018-02-13 15:14:10 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 7 | 2018-02-13 15:14:10 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 702035 | 2018-02-13 15:14:10 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 7 | 2018-02-13 15:14:10 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 8 | 2018-02-13 15:14:10 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 702036 | 2018-02-13 15:14:10 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 8 | 2018-02-13 15:14:10 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 9 | 2018-02-13 15:14:10 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 702037 | 2018-02-13 15:14:10 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 9 | 2018-02-13 15:14:10 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:14:10 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 702038 | 2018-02-13 15:14:10 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:14:10 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 11 | 2018-02-13 15:14:10 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 702039 | 2018-02-13 15:14:10 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 11 | 2018-02-13 15:14:10 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 12 | 2018-02-13 15:14:10 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 702040 | 2018-02-13 15:14:10 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 12 | 2018-02-13 15:14:10 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 13 | 2018-02-13 15:14:10 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 702041 | 2018-02-13 15:14:10 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 13 | 2018-02-13 15:14:10 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 15:14:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 702032. Contract ID: 4. | 2018-02-13 15:14:10 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 15:14:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 702033. Contract ID: 5. | 2018-02-13 15:14:10 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 15:14:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 702034. Contract ID: 6. | 2018-02-13 15:14:10 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 15:14:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 702035. Contract ID: 7. | 2018-02-13 15:14:10 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 15:14:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 702036. Contract ID: 8. | 2018-02-13 15:14:10 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 15:14:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 702037. Contract ID: 9. | 2018-02-13 15:14:10 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 15:14:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 702038. Contract ID: 10. | 2018-02-13 15:14:10 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 15:14:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 702039. Contract ID: 11. | 2018-02-13 15:14:10 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 15:14:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 702040. Contract ID: 12. | 2018-02-13 15:14:10 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 15:14:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 702041. Contract ID: 13. | 2018-02-13 15:14:10 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 15:14:10 Delaying start of download for F.US.YMH18 | 2018-02-13 15:14:14 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 15:14:18 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 15:14:18 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 15:14:18 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 15:14:18 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 15:14:18 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 15:14:18 HD Request # 134 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 15:14:19 HD Request # 134 | Download start date-time: 2018-02-13 15:13:38.000 | 2018-02-13 15:14:19 HD Request # 134 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:14:19 Socket (369) | Creating socket. | 2018-02-13 15:14:19 Socket (369) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:14:19 HD Request # 134 | Setting DTC encoding to Binary VLS | 2018-02-13 15:14:19 HD Request # 134 | Sending historical data logon request message. | 2018-02-13 15:14:19 HD Request # 134 | Requesting Intraday data. Start date-time: 2018-02-13 15:13:38. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 15:14:19 HD Request # 134 | Decompressing data. | 2018-02-13 15:14:19 HD Request # 134 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 15:13:38 | 2018-02-13 15:14:19 HD Request # 134 | Timestamp of first Intraday data file record written: 2018-02-13 15:13:41 | 2018-02-13 15:14:19 Socket (369) | Initiating close of socket by core. | 2018-02-13 15:14:19 Socket (369) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:14:19 Socket (369) | Socket gracefully closed by remote side. | 2018-02-13 15:14:20 Socket (369) | Closed. | 2018-02-13 15:14:20 Historical data download thread signaled to stop. | 2018-02-13 15:14:20 HD Request # 134 | Received 117 records from 2018-02-13 15:13:38 to 2018-02-13 15:14:14 (36.0 seconds) and wrote 116 records for F.US.YMH18 | 2018-02-13 15:14:20 Added 7 Time and Sales records to Intraday data file for F.US.YMH18 after download. | 2018-02-13 15:14:20 HD Request # 134 | Completion time: 0s | 2018-02-13 15:14:20 HD Request # 134 | Intraday data download complete for F.US.YMH18. Unique request ID: 133 | 2018-02-13 15:14:20 Removed historical data download ID 133 | 2018-02-13 15:14:20 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 15:14:20 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 15:14:20 HD Request # 135 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 15:14:20 HD Request # 135 | Download start date-time: 2018-02-13 15:13:40.000 | 2018-02-13 15:14:20 HD Request # 135 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:14:20 Socket (370) | Creating socket. | 2018-02-13 15:14:20 Socket (370) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:14:20 HD Request # 135 | Setting DTC encoding to Binary VLS | 2018-02-13 15:14:20 HD Request # 135 | Sending historical data logon request message. | 2018-02-13 15:14:20 HD Request # 135 | Requesting Intraday data. Start date-time: 2018-02-13 15:13:40. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 15:14:20 HD Request # 135 | Decompressing data. | 2018-02-13 15:14:21 HD Request # 135 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 15:13:40 | 2018-02-13 15:14:21 HD Request # 135 | Timestamp of first Intraday data file record written: 2018-02-13 15:13:41 | 2018-02-13 15:14:21 Socket (370) | Initiating close of socket by core. | 2018-02-13 15:14:21 Socket (370) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:14:21 Socket (370) | Socket gracefully closed by remote side. | 2018-02-13 15:14:21 Socket (370) | Closed. | 2018-02-13 15:14:21 Historical data download thread signaled to stop. | 2018-02-13 15:14:21 HD Request # 135 | Received 43 records from 2018-02-13 15:13:40 to 2018-02-13 15:14:14 (34.0 seconds) and wrote 42 records for F.US.CLEH18 | 2018-02-13 15:14:21 HD Request # 135 | Completion time: 0s | 2018-02-13 15:14:21 HD Request # 135 | Intraday data download complete for F.US.CLEH18. Unique request ID: 134 | 2018-02-13 15:14:21 Removed historical data download ID 134 | 2018-02-13 15:14:21 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 15:14:21 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 15:14:21 HD Request # 136 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 15:14:21 HD Request # 136 | Download start date-time: 2018-02-13 15:13:32.000 | 2018-02-13 15:14:21 HD Request # 136 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:14:21 Socket (371) | Creating socket. | 2018-02-13 15:14:21 Socket (371) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:14:21 HD Request # 136 | Setting DTC encoding to Binary VLS | 2018-02-13 15:14:21 HD Request # 136 | Sending historical data logon request message. | 2018-02-13 15:14:21 HD Request # 136 | Requesting Intraday data. Start date-time: 2018-02-13 15:13:32. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 15:14:21 HD Request # 136 | Decompressing data. | 2018-02-13 15:14:21 HD Request # 136 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 15:13:32 | 2018-02-13 15:14:21 HD Request # 136 | Timestamp of first Intraday data file record written: 2018-02-13 15:13:44 | 2018-02-13 15:14:21 Socket (371) | Initiating close of socket by core. | 2018-02-13 15:14:21 Socket (371) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:14:21 Historical data download thread signaled to stop. | 2018-02-13 15:14:21 HD Request # 136 | Received 192 records from 2018-02-13 15:13:32 to 2018-02-13 15:14:19 (47.0 seconds) and wrote 188 records for F.US.RTYH18 | 2018-02-13 15:14:21 Added 50 Time and Sales records to Intraday data file for F.US.RTYH18 after download. | 2018-02-13 15:14:21 HD Request # 136 | Completion time: 0s | 2018-02-13 15:14:21 HD Request # 136 | Intraday data download complete for F.US.RTYH18. Unique request ID: 135 | 2018-02-13 15:14:21 Removed historical data download ID 135 | 2018-02-13 15:14:21 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 15:14:21 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 15:14:21 Socket (371) | Socket gracefully closed by remote side. | 2018-02-13 15:14:21 Socket (371) | Closed. | 2018-02-13 15:14:21 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:14:21 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:14:21 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:14:21 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.YMH18.scid | 2018-02-13 15:14:22 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.RTYH18.scid | 2018-02-13 15:14:22 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:14:45 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:14:45 Chart #2 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:14:45 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:14:45 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:14:45 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:14:45 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:14:45 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:14:46 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 15:14:46 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:14:53 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:14:54 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:14:54 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:14:54 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:14:54 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:14:58 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:14:58 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:14:58 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:14:58 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:14:58 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:14:58 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:15:00 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:15:01 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:15:02 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 15:15:26 CQG WebSocket socket (368) | Adding bytes from final send buffer from buffered socket: 8 | 2018-02-13 15:15:26 CQG WebSocket socket (368) | Initiating close of socket by core. | 2018-02-13 15:15:26 CQG WebSocket | WebSocket closed. | 2018-02-13 15:15:26 CQG FIX Trading | WebSocket closed. | 2018-02-13 15:15:26 Connection to the external service has been lost. | 2018-02-13 15:15:26 CQG WebSocket socket (368) | Write in progress. Shutdown being delayed. | 2018-02-13 15:15:26 CQG WebSocket socket (368) | Sending bytes from final send buffer: 8 | 2018-02-13 15:15:26 CQG WebSocket socket (368) | Write has completed. Shutdown being performed. | 2018-02-13 15:15:26 CQG WebSocket socket (368) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:15:26 CQG WebSocket socket (368) | Socket gracefully closed by remote side. | 2018-02-13 15:15:27 CQG WebSocket socket (368) | Closed. | 2018-02-13 15:15:27 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:15:30 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:15:31 CQG FIX: DisconnectFIX called. | 2018-02-13 15:15:38 CQG FIX: Sending a Logout message. | 2018-02-13 15:15:38 CQG FIX Trading | Disconnected. | 2018-02-13 15:15:38 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 15:15:38 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 15:15:38 CQG FIX socket (367) | Initiating close of socket by core. | 2018-02-13 15:15:38 CQG FIX: Disconnected. | 2018-02-13 15:15:38 CQG FIX socket (367) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:15:38 CQG FIX socket (367) | Socket gracefully closed by remote side. | 2018-02-13 15:15:38 CQG FIX socket (367) | Closed. | 2018-02-13 15:15:38 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 15:15:44 CQG FIX socket (374) | Creating socket. Using TLS 1.2. | 2018-02-13 15:15:44 CQG FIX socket (374) | Connecting to IP: 208.48.16.214. | 2018-02-13 15:15:44 CQG FIX: Sending the Logon message. | 2018-02-13 15:15:47 CQG FIX Trading | Connected to trading server. | 2018-02-13 15:15:48 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 15:15:48 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 15:15:48 CQG WebSocket socket (375) | Creating socket. Using TLS 1.2. | 2018-02-13 15:15:48 CQG WebSocket socket (375) | Connecting to IP: 208.48.16.35. | 2018-02-13 15:15:48 CQG WebSocket | Opening WebSocket. | 2018-02-13 15:15:49 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 15:15:49 CQG FIX | FCM name: AMP | 2018-02-13 15:15:49 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 15:15:49 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 15:15:49 CQG WebSocket | Header line. Sec-WebSocket-Accept: 0I4CQXjPCCrvzaRBIExkEC16pOw= | 2018-02-13 15:15:49 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 15:15:49 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 15:15:49 CQG WebSocket | Header line. | 2018-02-13 15:15:49 CQG WebSocket | Web socket state is now open. | 2018-02-13 15:15:49 CQG FIX Trading | WebSocket connected. | 2018-02-13 15:15:49 CQG FIX Trading | Sending market data logon message. | 2018-02-13 15:15:49 CQG FIX Trading | Logon successful. Session Token = 9jvXS7iZGUCkpIA8zgpTyRY7Uam+RDm7rjwl1eGzEsY7tNDGKq4JT194f4q18gPvEGbICoT5RIf | 2018-02-13 15:15:50 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 15:15:53 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 1 | 2018-02-13 15:15:53 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 702042 | 2018-02-13 15:15:53 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 1 | 2018-02-13 15:15:53 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 15:15:53 Delaying start of download for F.US.RTYH18 | 2018-02-13 15:15:54 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 702042. Contract ID: 1. | 2018-02-13 15:15:54 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 15:15:54 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 2 | 2018-02-13 15:15:54 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 702043 | 2018-02-13 15:15:54 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 2 | 2018-02-13 15:15:54 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 15:15:54 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 4 | 2018-02-13 15:15:54 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 702044 | 2018-02-13 15:15:54 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 4 | 2018-02-13 15:15:54 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 3 | 2018-02-13 15:15:54 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 702045 | 2018-02-13 15:15:54 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 3 | 2018-02-13 15:15:54 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 15:15:54 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 5 | 2018-02-13 15:15:54 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 702046 | 2018-02-13 15:15:54 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 5 | 2018-02-13 15:15:54 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 7 | 2018-02-13 15:15:54 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 702047 | 2018-02-13 15:15:54 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 7 | 2018-02-13 15:15:54 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 6 | 2018-02-13 15:15:54 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 702048 | 2018-02-13 15:15:54 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 6 | 2018-02-13 15:15:54 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 8 | 2018-02-13 15:15:54 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 702049 | 2018-02-13 15:15:54 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 8 | 2018-02-13 15:15:54 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 9 | 2018-02-13 15:15:54 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 702050 | 2018-02-13 15:15:54 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 9 | 2018-02-13 15:15:54 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:15:54 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 702051 | 2018-02-13 15:15:54 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:15:54 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 11 | 2018-02-13 15:15:54 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 702052 | 2018-02-13 15:15:54 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 11 | 2018-02-13 15:15:54 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 12 | 2018-02-13 15:15:54 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 702053 | 2018-02-13 15:15:54 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 12 | 2018-02-13 15:15:54 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 13 | 2018-02-13 15:15:54 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 702054 | 2018-02-13 15:15:54 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 13 | 2018-02-13 15:15:54 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 702043. Contract ID: 2. | 2018-02-13 15:15:55 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 15:15:55 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 702044. Contract ID: 3. | 2018-02-13 15:15:55 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 15:15:55 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 702045. Contract ID: 4. | 2018-02-13 15:15:55 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 15:15:55 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 702046. Contract ID: 5. | 2018-02-13 15:15:55 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 15:15:55 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 702047. Contract ID: 6. | 2018-02-13 15:15:55 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 15:15:55 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 702048. Contract ID: 7. | 2018-02-13 15:15:55 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 15:15:55 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 702049. Contract ID: 8. | 2018-02-13 15:15:55 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 15:15:55 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 702050. Contract ID: 9. | 2018-02-13 15:15:55 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 15:15:55 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 702051. Contract ID: 10. | 2018-02-13 15:15:55 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 15:15:55 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 702052. Contract ID: 11. | 2018-02-13 15:15:55 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 15:15:55 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 702053. Contract ID: 12. | 2018-02-13 15:15:55 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 15:15:55 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 702054. Contract ID: 13. | 2018-02-13 15:15:55 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 15:15:55 HD Request # 137 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 15:15:59 HD Request # 137 | Download start date-time: 2018-02-13 15:14:59.000 | 2018-02-13 15:15:59 HD Request # 137 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:15:59 Socket (376) | Creating socket. | 2018-02-13 15:15:59 Socket (376) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:15:59 HD Request # 137 | Setting DTC encoding to Binary VLS | 2018-02-13 15:15:59 HD Request # 137 | Sending historical data logon request message. | 2018-02-13 15:15:59 HD Request # 137 | Requesting Intraday data. Start date-time: 2018-02-13 15:14:59. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 15:15:59 HD Request # 137 | Decompressing data. | 2018-02-13 15:15:59 HD Request # 137 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 15:14:59 | 2018-02-13 15:15:59 Socket (376) | Initiating close of socket by core. | 2018-02-13 15:15:59 Socket (376) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:15:59 Socket (376) | Socket gracefully closed by remote side. | 2018-02-13 15:15:59 Socket (376) | Closed. | 2018-02-13 15:15:59 Historical data download thread signaled to stop. | 2018-02-13 15:15:59 HD Request # 137 | Received 7 records from 2018-02-13 15:14:59 to 2018-02-13 15:14:59 (0.0 seconds) and wrote 0 records for F.US.RTYH18 | 2018-02-13 15:15:59 HD Request # 137 | Completion time: 0s | 2018-02-13 15:15:59 HD Request # 137 | Intraday data download complete for F.US.RTYH18. Unique request ID: 136 | 2018-02-13 15:15:59 Removed historical data download ID 136 | 2018-02-13 15:15:59 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 15:15:59 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 15:15:59 Delaying start of download for F.US.YMH18 | 2018-02-13 15:15:59 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:16:02 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 15:16:02 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 15:16:02 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 15:16:02 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 15:16:02 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 15:16:02 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 15:16:02 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:16:02 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:16:02 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:16:03 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:16:03 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:16:05 HD Request # 138 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 15:16:07 HD Request # 138 | Download start date-time: 2018-02-13 15:14:58.000 | 2018-02-13 15:16:07 HD Request # 138 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:16:07 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:16:07 Socket (377) | Creating socket. | 2018-02-13 15:16:07 Socket (377) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:16:07 HD Request # 138 | Setting DTC encoding to Binary VLS | 2018-02-13 15:16:07 HD Request # 138 | Sending historical data logon request message. | 2018-02-13 15:16:07 HD Request # 138 | Requesting Intraday data. Start date-time: 2018-02-13 15:14:58. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 15:16:07 HD Request # 138 | Decompressing data. | 2018-02-13 15:16:07 HD Request # 138 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 15:14:58 | 2018-02-13 15:16:07 Socket (377) | Initiating close of socket by core. | 2018-02-13 15:16:07 Socket (377) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:16:07 Socket (377) | Socket gracefully closed by remote side. | 2018-02-13 15:16:07 Socket (377) | Closed. | 2018-02-13 15:16:07 Historical data download thread signaled to stop. | 2018-02-13 15:16:12 HD Request # 138 | Received 4 records from 2018-02-13 15:14:58 to 2018-02-13 15:14:58 (0.0 seconds) and wrote 0 records for F.US.YMH18 | 2018-02-13 15:16:12 HD Request # 138 | Completion time: 5s | 2018-02-13 15:16:12 HD Request # 138 | Intraday data download complete for F.US.YMH18. Unique request ID: 137 | 2018-02-13 15:16:12 Removed historical data download ID 137 | 2018-02-13 15:16:12 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 15:16:12 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 15:16:12 HD Request # 139 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 15:16:12 HD Request # 139 | Download start date-time: 2018-02-13 15:15:18.000 | 2018-02-13 15:16:12 HD Request # 139 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:16:12 Socket (378) | Creating socket. | 2018-02-13 15:16:12 Socket (378) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:16:12 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:16:12 Chart #2 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:16:12 HD Request # 139 | Setting DTC encoding to Binary VLS | 2018-02-13 15:16:12 HD Request # 139 | Sending historical data logon request message. | 2018-02-13 15:16:12 HD Request # 139 | Requesting Intraday data. Start date-time: 2018-02-13 15:15:18. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 15:16:12 HD Request # 139 | Decompressing data. | 2018-02-13 15:16:12 HD Request # 139 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 15:15:18 | 2018-02-13 15:16:12 HD Request # 139 | Timestamp of first Intraday data file record written: 2018-02-13 15:15:27 | 2018-02-13 15:16:12 Socket (378) | Initiating close of socket by core. | 2018-02-13 15:16:12 Socket (378) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:16:12 Socket (378) | Socket gracefully closed by remote side. | 2018-02-13 15:16:12 Socket (378) | Closed. | 2018-02-13 15:16:12 Historical data download thread signaled to stop. | 2018-02-13 15:16:13 HD Request # 139 | Received 11 records from 2018-02-13 15:15:18 to 2018-02-13 15:16:10 (52.0 seconds) and wrote 10 records for F.US.CLEH18 | 2018-02-13 15:16:13 HD Request # 139 | Completion time: 2s | 2018-02-13 15:16:13 HD Request # 139 | Intraday data download complete for F.US.CLEH18. Unique request ID: 138 | 2018-02-13 15:16:13 Removed historical data download ID 138 | 2018-02-13 15:16:13 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 15:16:13 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 15:16:13 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:16:14 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:16:14 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:16:14 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:16:38 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:16:38 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 15:16:39 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:16:45 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 15:16:46 CQG WebSocket socket (375) | Adding bytes from final send buffer from buffered socket: 8 | 2018-02-13 15:16:46 CQG WebSocket socket (375) | Initiating close of socket by core. | 2018-02-13 15:16:46 CQG WebSocket | WebSocket closed. | 2018-02-13 15:16:46 CQG FIX Trading | WebSocket closed. | 2018-02-13 15:16:46 Connection to the external service has been lost. | 2018-02-13 15:16:46 CQG WebSocket socket (375) | Write in progress. Shutdown being delayed. | 2018-02-13 15:16:46 CQG WebSocket socket (375) | Sending bytes from final send buffer: 8 | 2018-02-13 15:16:46 CQG WebSocket socket (375) | Write has completed. Shutdown being performed. | 2018-02-13 15:16:46 CQG WebSocket socket (375) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:16:46 CQG WebSocket socket (375) | Socket gracefully closed by remote side. | 2018-02-13 15:16:46 CQG WebSocket socket (375) | Closed. | 2018-02-13 15:16:46 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:16:49 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:16:49 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:16:49 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:16:49 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:16:49 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:16:49 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:16:49 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:16:53 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:16:53 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:16:53 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:16:55 CQG FIX: DisconnectFIX called. | 2018-02-13 15:17:21 CQG FIX: Sending a Logout message. | 2018-02-13 15:17:21 CQG FIX Trading | Disconnected. | 2018-02-13 15:17:21 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 15:17:21 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:17:21 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 15:17:21 CQG FIX socket (374) | Initiating close of socket by core. | 2018-02-13 15:17:21 CQG FIX: Disconnected. | 2018-02-13 15:17:21 CQG FIX socket (374) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:17:21 CQG FIX socket (374) | Socket gracefully closed by remote side. | 2018-02-13 15:17:21 CQG FIX socket (374) | Closed. | 2018-02-13 15:17:21 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 15:17:27 CQG FIX socket (380) | Creating socket. Using TLS 1.2. | 2018-02-13 15:17:27 CQG FIX socket (380) | Connecting to IP: 208.48.16.214. | 2018-02-13 15:17:27 CQG FIX: Sending the Logon message. | 2018-02-13 15:17:30 CQG FIX Trading | Connected to trading server. | 2018-02-13 15:17:31 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 15:17:31 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 15:17:31 CQG WebSocket socket (381) | Creating socket. Using TLS 1.2. | 2018-02-13 15:17:31 CQG WebSocket socket (381) | Connecting to IP: 208.48.16.35. | 2018-02-13 15:17:31 CQG WebSocket | Opening WebSocket. | 2018-02-13 15:17:32 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 15:17:32 CQG FIX | FCM name: AMP | 2018-02-13 15:17:32 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 15:17:33 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 15:17:33 CQG WebSocket | Header line. Sec-WebSocket-Accept: K4sLLRjrQJ8z3vlycoW1o9pRq9A= | 2018-02-13 15:17:33 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 15:17:33 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 15:17:33 CQG WebSocket | Header line. | 2018-02-13 15:17:33 CQG WebSocket | Web socket state is now open. | 2018-02-13 15:17:33 CQG FIX Trading | WebSocket connected. | 2018-02-13 15:17:33 CQG FIX Trading | Sending market data logon message. | 2018-02-13 15:17:33 CQG FIX Trading | Logon successful. Session Token = q267jEszpcphqODHWaV2K+/9R5mpe9KSIGshcrPpuicElscYV4XVqQVAU1xzf+fLtyjuLCxDZ7Q | 2018-02-13 15:17:33 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 15:17:37 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 1 | 2018-02-13 15:17:37 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 702055 | 2018-02-13 15:17:37 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 1 | 2018-02-13 15:17:37 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 15:17:37 Delaying start of download for F.US.RTYH18 | 2018-02-13 15:17:37 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 702055. Contract ID: 1. | 2018-02-13 15:17:37 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 15:17:37 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:17:37 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 702056 | 2018-02-13 15:17:37 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:17:37 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 2 | 2018-02-13 15:17:37 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 702057 | 2018-02-13 15:17:37 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 2 | 2018-02-13 15:17:37 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 15:17:37 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 4 | 2018-02-13 15:17:37 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 702058 | 2018-02-13 15:17:37 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 4 | 2018-02-13 15:17:37 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 15:17:37 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 5 | 2018-02-13 15:17:37 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 702059 | 2018-02-13 15:17:37 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 5 | 2018-02-13 15:17:37 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 7 | 2018-02-13 15:17:37 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 702060 | 2018-02-13 15:17:37 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 7 | 2018-02-13 15:17:37 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 6 | 2018-02-13 15:17:37 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 702061 | 2018-02-13 15:17:37 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 6 | 2018-02-13 15:17:37 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 8 | 2018-02-13 15:17:37 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 702062 | 2018-02-13 15:17:37 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 8 | 2018-02-13 15:17:37 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 9 | 2018-02-13 15:17:37 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 702063 | 2018-02-13 15:17:37 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 9 | 2018-02-13 15:17:37 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:17:37 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 702064 | 2018-02-13 15:17:37 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:17:37 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 11 | 2018-02-13 15:17:37 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 702065 | 2018-02-13 15:17:37 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 11 | 2018-02-13 15:17:37 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 702056. Contract ID: 2. | 2018-02-13 15:17:38 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 15:17:38 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 702057. Contract ID: 3. | 2018-02-13 15:17:38 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 15:17:38 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 702058. Contract ID: 4. | 2018-02-13 15:17:38 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 15:17:38 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 702059. Contract ID: 5. | 2018-02-13 15:17:38 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 15:17:38 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 702060. Contract ID: 6. | 2018-02-13 15:17:38 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 15:17:38 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 702061. Contract ID: 7. | 2018-02-13 15:17:38 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 15:17:38 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 702062. Contract ID: 8. | 2018-02-13 15:17:38 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 15:17:38 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 702063. Contract ID: 9. | 2018-02-13 15:17:38 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 15:17:38 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 702064. Contract ID: 10. | 2018-02-13 15:17:38 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 15:17:38 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 702065. Contract ID: 11. | 2018-02-13 15:17:38 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 15:17:38 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 12 | 2018-02-13 15:17:39 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 702066 | 2018-02-13 15:17:39 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 12 | 2018-02-13 15:17:39 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 13 | 2018-02-13 15:17:39 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 702067 | 2018-02-13 15:17:39 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 13 | 2018-02-13 15:17:39 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 702066. Contract ID: 12. | 2018-02-13 15:17:40 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 15:17:40 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 702067. Contract ID: 13. | 2018-02-13 15:17:40 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 15:17:40 Delaying start of download for F.US.RTYH18 | 2018-02-13 15:17:42 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 15:17:46 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 15:17:46 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 15:17:46 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 15:17:46 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 15:17:46 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 15:17:46 HD Request # 140 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 15:17:47 HD Request # 140 | Download start date-time: 2018-02-13 15:14:59.000 | 2018-02-13 15:17:47 HD Request # 140 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:17:47 Socket (383) | Creating socket. | 2018-02-13 15:17:47 Socket (383) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:17:47 HD Request # 140 | Setting DTC encoding to Binary VLS | 2018-02-13 15:17:47 HD Request # 140 | Sending historical data logon request message. | 2018-02-13 15:17:47 HD Request # 140 | Requesting Intraday data. Start date-time: 2018-02-13 15:14:59. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 15:17:47 HD Request # 140 | Decompressing data. | 2018-02-13 15:17:47 HD Request # 140 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 15:14:59 | 2018-02-13 15:17:47 Socket (383) | Initiating close of socket by core. | 2018-02-13 15:17:47 Socket (383) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:17:47 Socket (383) | Socket gracefully closed by remote side. | 2018-02-13 15:17:48 Socket (383) | Closed. | 2018-02-13 15:17:48 Historical data download thread signaled to stop. | 2018-02-13 15:17:48 HD Request # 140 | Received 7 records from 2018-02-13 15:14:59 to 2018-02-13 15:14:59 (0.0 seconds) and wrote 0 records for F.US.RTYH18 | 2018-02-13 15:17:48 HD Request # 140 | Completion time: 1s | 2018-02-13 15:17:48 HD Request # 140 | Intraday data download complete for F.US.RTYH18. Unique request ID: 139 | 2018-02-13 15:17:48 Removed historical data download ID 139 | 2018-02-13 15:17:48 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 15:17:48 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 15:17:48 HD Request # 141 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 15:17:48 HD Request # 141 | Download start date-time: 2018-02-13 15:16:39.000 | 2018-02-13 15:17:48 HD Request # 141 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:17:48 Socket (384) | Creating socket. | 2018-02-13 15:17:48 Socket (384) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:17:48 HD Request # 141 | Setting DTC encoding to Binary VLS | 2018-02-13 15:17:48 HD Request # 141 | Sending historical data logon request message. | 2018-02-13 15:17:48 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:17:48 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:17:48 HD Request # 141 | Requesting Intraday data. Start date-time: 2018-02-13 15:16:39. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 15:17:48 HD Request # 141 | Decompressing data. | 2018-02-13 15:17:49 HD Request # 141 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 15:16:39 | 2018-02-13 15:17:49 HD Request # 141 | Timestamp of first Intraday data file record written: 2018-02-13 15:16:39 | 2018-02-13 15:17:49 Socket (384) | Initiating close of socket by core. | 2018-02-13 15:17:49 Socket (384) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:17:49 Socket (384) | Socket gracefully closed by remote side. | 2018-02-13 15:17:49 Socket (384) | Closed. | 2018-02-13 15:17:49 Historical data download thread signaled to stop. | 2018-02-13 15:17:49 HD Request # 141 | Received 17 records from 2018-02-13 15:16:39 to 2018-02-13 15:17:01 (22.0 seconds) and wrote 14 records for F.US.CLEH18 | 2018-02-13 15:17:49 HD Request # 141 | Completion time: 0s | 2018-02-13 15:17:49 HD Request # 141 | Intraday data download complete for F.US.CLEH18. Unique request ID: 140 | 2018-02-13 15:17:49 Removed historical data download ID 140 | 2018-02-13 15:17:49 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 15:17:49 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 15:17:49 HD Request # 142 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 15:17:49 HD Request # 142 | Download start date-time: 2018-02-13 15:14:58.000 | 2018-02-13 15:17:49 HD Request # 142 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:17:49 Socket (385) | Creating socket. | 2018-02-13 15:17:49 Socket (385) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:17:49 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:17:49 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:17:49 HD Request # 142 | Setting DTC encoding to Binary VLS | 2018-02-13 15:17:49 HD Request # 142 | Sending historical data logon request message. | 2018-02-13 15:17:49 HD Request # 142 | Requesting Intraday data. Start date-time: 2018-02-13 15:14:58. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 15:17:49 HD Request # 142 | Decompressing data. | 2018-02-13 15:17:50 HD Request # 142 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 15:14:58 | 2018-02-13 15:17:50 Socket (385) | Initiating close of socket by core. | 2018-02-13 15:17:50 Socket (385) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:17:50 Socket (385) | Socket gracefully closed by remote side. | 2018-02-13 15:17:50 Socket (385) | Closed. | 2018-02-13 15:17:50 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:17:52 Historical data download thread signaled to stop. | 2018-02-13 15:17:52 HD Request # 142 | Received 4 records from 2018-02-13 15:14:58 to 2018-02-13 15:14:58 (0.0 seconds) and wrote 0 records for F.US.YMH18 | 2018-02-13 15:17:52 HD Request # 142 | Completion time: 2s | 2018-02-13 15:17:52 HD Request # 142 | Intraday data download complete for F.US.YMH18. Unique request ID: 141 | 2018-02-13 15:17:52 Removed historical data download ID 141 | 2018-02-13 15:17:52 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 15:17:52 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 15:17:52 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:17:52 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:17:52 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:17:52 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 15:17:52 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:18:16 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:18:16 Chart #2 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:18:16 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:18:16 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:18:16 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:18:16 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:18:16 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:18:16 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:18:23 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:18:23 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:18:28 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:18:28 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:18:33 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:18:33 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:18:33 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:18:33 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:18:33 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:18:35 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:18:37 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 15:19:01 CQG WebSocket socket (381) | Adding bytes from final send buffer from buffered socket: 22 | 2018-02-13 15:19:01 CQG WebSocket socket (381) | Initiating close of socket by core. | 2018-02-13 15:19:01 CQG WebSocket | WebSocket closed. | 2018-02-13 15:19:01 CQG FIX Trading | WebSocket closed. | 2018-02-13 15:19:01 Connection to the external service has been lost. | 2018-02-13 15:19:01 CQG WebSocket socket (381) | Write in progress. Shutdown being delayed. | 2018-02-13 15:19:01 CQG WebSocket socket (381) | Sending bytes from final send buffer: 22 | 2018-02-13 15:19:01 CQG WebSocket socket (381) | Write has completed. Shutdown being performed. | 2018-02-13 15:19:01 CQG WebSocket socket (381) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:19:01 CQG WebSocket socket (381) | Socket gracefully closed by remote side. | 2018-02-13 15:19:01 CQG WebSocket socket (381) | Closed. | 2018-02-13 15:19:01 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:19:04 CQG FIX: DisconnectFIX called. | 2018-02-13 15:19:08 CQG FIX: Sending a Logout message. | 2018-02-13 15:19:08 CQG FIX Trading | Disconnected. | 2018-02-13 15:19:08 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 15:19:08 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 15:19:08 CQG FIX socket (380) | Initiating close of socket by core. | 2018-02-13 15:19:08 CQG FIX: Disconnected. | 2018-02-13 15:19:08 CQG FIX socket (380) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:19:08 CQG FIX socket (380) | Socket gracefully closed by remote side. | 2018-02-13 15:19:08 CQG FIX socket (380) | Closed. | 2018-02-13 15:19:08 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 15:19:14 CQG FIX socket (387) | Creating socket. Using TLS 1.2. | 2018-02-13 15:19:14 CQG FIX socket (387) | Connecting to IP: 208.48.16.214. | 2018-02-13 15:19:14 CQG FIX: Sending the Logon message. | 2018-02-13 15:19:19 CQG FIX Trading | Connected to trading server. | 2018-02-13 15:19:19 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 15:19:19 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 15:19:19 CQG WebSocket socket (388) | Creating socket. Using TLS 1.2. | 2018-02-13 15:19:19 CQG WebSocket socket (388) | Connecting to IP: 208.48.16.35. | 2018-02-13 15:19:19 CQG FIX | FCM name: AMP | 2018-02-13 15:19:20 CQG WebSocket | Opening WebSocket. | 2018-02-13 15:19:20 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 15:19:20 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 15:19:21 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 15:19:21 CQG WebSocket | Header line. Sec-WebSocket-Accept: ANA9HjcHSHursXmWxMmmz/qckeU= | 2018-02-13 15:19:21 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 15:19:21 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 15:19:21 CQG WebSocket | Header line. | 2018-02-13 15:19:21 CQG WebSocket | Web socket state is now open. | 2018-02-13 15:19:21 CQG FIX Trading | WebSocket connected. | 2018-02-13 15:19:21 CQG FIX Trading | Sending market data logon message. | 2018-02-13 15:19:21 CQG FIX Trading | Logon successful. Session Token = 607SB8739tXmG1sjRjp4A1xhCGyfpcnEXO0sx3mAjlEXB+h2Ysdd8dDz0he6ZpOLU4TQguhpR3u | 2018-02-13 15:19:21 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 15:19:25 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 1 | 2018-02-13 15:19:25 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 702068 | 2018-02-13 15:19:25 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 1 | 2018-02-13 15:19:25 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 15:19:25 Delaying start of download for F.US.RTYH18 | 2018-02-13 15:19:25 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 702068. Contract ID: 1. | 2018-02-13 15:19:25 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 15:19:25 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:19:25 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 702069 | 2018-02-13 15:19:25 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:19:25 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 2 | 2018-02-13 15:19:25 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 702070 | 2018-02-13 15:19:25 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 2 | 2018-02-13 15:19:25 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 15:19:25 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 4 | 2018-02-13 15:19:25 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 702071 | 2018-02-13 15:19:25 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 4 | 2018-02-13 15:19:25 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 15:19:25 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 702069. Contract ID: 2. | 2018-02-13 15:19:25 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 15:19:25 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 702070. Contract ID: 3. | 2018-02-13 15:19:26 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 15:19:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 702071. Contract ID: 4. | 2018-02-13 15:19:26 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 15:19:26 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 5 | 2018-02-13 15:19:26 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 702072 | 2018-02-13 15:19:26 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 5 | 2018-02-13 15:19:26 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 7 | 2018-02-13 15:19:26 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 702073 | 2018-02-13 15:19:26 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 7 | 2018-02-13 15:19:26 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 6 | 2018-02-13 15:19:26 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 702074 | 2018-02-13 15:19:26 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 6 | 2018-02-13 15:19:26 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 8 | 2018-02-13 15:19:26 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 702075 | 2018-02-13 15:19:26 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 8 | 2018-02-13 15:19:26 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 9 | 2018-02-13 15:19:26 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 702076 | 2018-02-13 15:19:26 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 9 | 2018-02-13 15:19:26 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:19:26 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 702077 | 2018-02-13 15:19:26 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 10 | 2018-02-13 15:19:26 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 11 | 2018-02-13 15:19:26 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 702078 | 2018-02-13 15:19:26 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 11 | 2018-02-13 15:19:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 702072. Contract ID: 5. | 2018-02-13 15:19:26 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 15:19:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 702073. Contract ID: 6. | 2018-02-13 15:19:26 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 15:19:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 702074. Contract ID: 7. | 2018-02-13 15:19:26 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 15:19:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 702075. Contract ID: 8. | 2018-02-13 15:19:26 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 15:19:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 702076. Contract ID: 9. | 2018-02-13 15:19:26 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 15:19:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 702077. Contract ID: 10. | 2018-02-13 15:19:26 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 15:19:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 702078. Contract ID: 11. | 2018-02-13 15:19:26 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 15:19:26 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 12 | 2018-02-13 15:19:28 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 702079 | 2018-02-13 15:19:28 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 12 | 2018-02-13 15:19:28 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 13 | 2018-02-13 15:19:28 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 702080 | 2018-02-13 15:19:28 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 13 | 2018-02-13 15:19:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 702079. Contract ID: 12. | 2018-02-13 15:19:29 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 15:19:29 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 702080. Contract ID: 13. | 2018-02-13 15:19:29 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 15:19:29 HD Request # 143 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 15:19:30 HD Request # 143 | Download start date-time: 2018-02-13 15:14:59.000 | 2018-02-13 15:19:30 HD Request # 143 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:19:30 Socket (389) | Creating socket. | 2018-02-13 15:19:30 Socket (389) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:19:30 HD Request # 143 | Setting DTC encoding to Binary VLS | 2018-02-13 15:19:30 HD Request # 143 | Sending historical data logon request message. | 2018-02-13 15:19:30 HD Request # 143 | Requesting Intraday data. Start date-time: 2018-02-13 15:14:59. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 15:19:30 HD Request # 143 | Decompressing data. | 2018-02-13 15:19:31 HD Request # 143 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 15:14:59 | 2018-02-13 15:19:31 Socket (389) | Initiating close of socket by core. | 2018-02-13 15:19:31 Socket (389) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:19:31 Socket (389) | Socket gracefully closed by remote side. | 2018-02-13 15:19:31 Socket (389) | Closed. | 2018-02-13 15:19:31 Historical data download thread signaled to stop. | 2018-02-13 15:19:31 HD Request # 143 | Received 7 records from 2018-02-13 15:14:59 to 2018-02-13 15:14:59 (0.0 seconds) and wrote 0 records for F.US.RTYH18 | 2018-02-13 15:19:31 HD Request # 143 | Completion time: 1s | 2018-02-13 15:19:31 HD Request # 143 | Intraday data download complete for F.US.RTYH18. Unique request ID: 142 | 2018-02-13 15:19:31 Removed historical data download ID 142 | 2018-02-13 15:19:31 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 15:19:31 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 15:19:31 HD Request # 144 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 15:19:31 HD Request # 144 | Download start date-time: 2018-02-13 15:18:29.000 | 2018-02-13 15:19:31 HD Request # 144 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:19:31 Socket (390) | Creating socket. | 2018-02-13 15:19:31 Socket (390) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:19:31 HD Request # 144 | Setting DTC encoding to Binary VLS | 2018-02-13 15:19:31 HD Request # 144 | Sending historical data logon request message. | 2018-02-13 15:19:31 HD Request # 144 | Requesting Intraday data. Start date-time: 2018-02-13 15:18:29. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 15:19:31 HD Request # 144 | Decompressing data. | 2018-02-13 15:19:31 HD Request # 144 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 15:18:29 | 2018-02-13 15:19:31 HD Request # 144 | Timestamp of first Intraday data file record written: 2018-02-13 15:19:03 | 2018-02-13 15:19:31 Socket (390) | Initiating close of socket by core. | 2018-02-13 15:19:31 Socket (390) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:19:31 Socket (390) | Socket gracefully closed by remote side. | 2018-02-13 15:19:31 Socket (390) | Closed. | 2018-02-13 15:19:31 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:19:32 Historical data download thread signaled to stop. | 2018-02-13 15:19:32 HD Request # 144 | Received 28 records from 2018-02-13 15:18:29 to 2018-02-13 15:19:14 (45.0 seconds) and wrote 23 records for F.US.CLEH18 | 2018-02-13 15:19:32 Added 2 Time and Sales records to Intraday data file for F.US.CLEH18 after download. | 2018-02-13 15:19:32 HD Request # 144 | Completion time: 0s | 2018-02-13 15:19:32 HD Request # 144 | Intraday data download complete for F.US.CLEH18. Unique request ID: 143 | 2018-02-13 15:19:32 Removed historical data download ID 143 | 2018-02-13 15:19:32 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 15:19:32 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 15:19:32 HD Request # 145 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 15:19:32 HD Request # 145 | Download start date-time: 2018-02-13 15:14:58.000 | 2018-02-13 15:19:32 HD Request # 145 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:19:32 Socket (391) | Creating socket. | 2018-02-13 15:19:32 Socket (391) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:19:32 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:19:32 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:19:32 HD Request # 145 | Setting DTC encoding to Binary VLS | 2018-02-13 15:19:32 HD Request # 145 | Sending historical data logon request message. | 2018-02-13 15:19:32 HD Request # 145 | Requesting Intraday data. Start date-time: 2018-02-13 15:14:58. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 15:19:32 HD Request # 145 | Decompressing data. | 2018-02-13 15:19:32 HD Request # 145 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 15:14:58 | 2018-02-13 15:19:32 Socket (391) | Initiating close of socket by core. | 2018-02-13 15:19:32 Socket (391) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:19:32 Socket (391) | Socket gracefully closed by remote side. | 2018-02-13 15:19:33 Socket (391) | Closed. | 2018-02-13 15:19:33 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:19:33 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:19:33 Historical data download thread signaled to stop. | 2018-02-13 15:19:33 HD Request # 145 | Received 4 records from 2018-02-13 15:14:58 to 2018-02-13 15:14:58 (0.0 seconds) and wrote 0 records for F.US.YMH18 | 2018-02-13 15:19:33 HD Request # 145 | Completion time: 1s | 2018-02-13 15:19:33 HD Request # 145 | Intraday data download complete for F.US.YMH18. Unique request ID: 144 | 2018-02-13 15:19:33 Removed historical data download ID 144 | 2018-02-13 15:19:33 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 15:19:33 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 15:19:33 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:19:33 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:19:33 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:19:35 Chart #2 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:19:35 Chart #2 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:19:35 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:19:35 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:19:35 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:19:35 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:19:35 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:19:36 Chart #6 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:19:38 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:19:38 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:19:38 Chart #7 has tagged chart #4 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:20:02 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 15:20:02 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 15:20:02 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 15:20:02 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 15:20:02 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 15:20:02 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 15:20:02 F.US.YMH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:20:02 Opened cached Intraday file: C:\SierraChartAMPMe\Data\F.US.CLEH18.scid | 2018-02-13 15:20:03 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:20:09 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:20:09 F.US.CLEH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:20:14 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:20:18 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:20:18 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:20:19 F.US.CLEH18 [CBV] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:20:19 F.US.YMH18 [CBV] 4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: YM v8.cht | 2018-02-13 15:20:21 CQG WebSocket | Timeout waiting for pong message from server. | 2018-02-13 15:20:45 CQG WebSocket socket (388) | Adding bytes from final send buffer from buffered socket: 22 | 2018-02-13 15:20:45 CQG WebSocket socket (388) | Initiating close of socket by core. | 2018-02-13 15:20:45 CQG WebSocket | WebSocket closed. | 2018-02-13 15:20:45 CQG FIX Trading | WebSocket closed. | 2018-02-13 15:20:45 Connection to the external service has been lost. | 2018-02-13 15:20:45 CQG WebSocket socket (388) | Write in progress. Shutdown being delayed. | 2018-02-13 15:20:45 CQG WebSocket socket (388) | Sending bytes from final send buffer: 22 | 2018-02-13 15:20:45 CQG WebSocket socket (388) | Write has completed. Shutdown being performed. | 2018-02-13 15:20:45 CQG WebSocket socket (388) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:20:45 CQG WebSocket socket (388) | Socket gracefully closed by remote side. | 2018-02-13 15:20:45 CQG WebSocket socket (388) | Closed. | 2018-02-13 15:20:45 CQG FIX: DisconnectFIX called. | 2018-02-13 15:20:53 CQG FIX: Sending a Logout message. | 2018-02-13 15:20:53 CQG FIX Trading | Disconnected. | 2018-02-13 15:20:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-13 15:20:53 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2018-02-13 15:20:53 CQG FIX socket (387) | Initiating close of socket by core. | 2018-02-13 15:20:53 CQG FIX: Disconnected. | 2018-02-13 15:20:53 CQG FIX socket (387) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:20:53 CQG FIX socket (387) | Socket gracefully closed by remote side. | 2018-02-13 15:20:53 CQG FIX socket (387) | Closed. | 2018-02-13 15:20:53 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-02-13 15:20:59 CQG FIX socket (394) | Creating socket. Using TLS 1.2. | 2018-02-13 15:20:59 CQG FIX socket (394) | Connecting to IP: 208.48.16.214. | 2018-02-13 15:20:59 CQG FIX: Sending the Logon message. | 2018-02-13 15:21:03 CQG FIX Trading | Connected to trading server. | 2018-02-13 15:21:04 CQG FIX Trading | Connecting to server api.cqg.com | 2018-02-13 15:21:04 CQG WebSocket | Connecting to WebSocket server. | 2018-02-13 15:21:04 CQG WebSocket socket (395) | Creating socket. Using TLS 1.2. | 2018-02-13 15:21:04 CQG WebSocket socket (395) | Connecting to IP: 208.48.16.35. | 2018-02-13 15:21:04 CQG WebSocket | Opening WebSocket. | 2018-02-13 15:21:05 CQG WebSocket | Sending WebSocket handshake. | 2018-02-13 15:21:05 CQG FIX | FCM name: AMP | 2018-02-13 15:21:05 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-02-13 15:21:05 CQG WebSocket | Header line. Connection: upgrade | 2018-02-13 15:21:05 CQG WebSocket | Header line. Sec-WebSocket-Accept: ajHhg8SameXJEeQC/p/KDp2bkxI= | 2018-02-13 15:21:05 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-02-13 15:21:05 CQG WebSocket | Header line. Upgrade: websocket | 2018-02-13 15:21:05 CQG WebSocket | Header line. | 2018-02-13 15:21:05 CQG WebSocket | Web socket state is now open. | 2018-02-13 15:21:05 CQG FIX Trading | WebSocket connected. | 2018-02-13 15:21:05 CQG FIX Trading | Sending market data logon message. | 2018-02-13 15:21:05 CQG FIX Trading | Logon successful. Session Token = J+JFy9zos2XtdlI83NFdS4jJWkpBnsXtHhlUs4rE7uAjFadaIFi874xYlzzZpZrzPXSHxsMLj6O | 2018-02-13 15:21:06 CQG FIX Trading | Connected to data and trading server. | 2018-02-13 15:21:09 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYH18. ID: 1 | 2018-02-13 15:21:09 CQG FIX Trading | Sending symbol resolution request for F.US.RTYH18. ID: 702081 | 2018-02-13 15:21:09 CQG FIX Trading | Requesting security definition data for: F.US.RTYH18. ID: 1 | 2018-02-13 15:21:09 Intraday data recording state for symbol F.US.RTYH18 is set to download 'Pending'. | 2018-02-13 15:21:09 Delaying start of download for F.US.RTYH18 | 2018-02-13 15:21:09 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH8. Search Symbol: F.US.RTYH18. Request ID: 702081. Contract ID: 1. | 2018-02-13 15:21:09 CQG FIX Trading | Requesting market data for F.US.RTYH18 | 2018-02-13 15:21:09 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:21:09 CQG FIX Trading | Sending symbol resolution request for F.US.CLEJ18. ID: 702082 | 2018-02-13 15:21:09 CQG FIX Trading | Requesting security definition data for: F.US.CLEJ18. ID: 3 | 2018-02-13 15:21:09 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEH18. ID: 2 | 2018-02-13 15:21:09 CQG FIX Trading | Sending symbol resolution request for F.US.CLEH18. ID: 702083 | 2018-02-13 15:21:09 CQG FIX Trading | Requesting security definition data for: F.US.CLEH18. ID: 2 | 2018-02-13 15:21:09 Intraday data recording state for symbol F.US.CLEH18 is set to download 'Pending'. | 2018-02-13 15:21:09 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH18. ID: 4 | 2018-02-13 15:21:09 CQG FIX Trading | Sending symbol resolution request for F.US.YMH18. ID: 702084 | 2018-02-13 15:21:09 CQG FIX Trading | Requesting security definition data for: F.US.YMH18. ID: 4 | 2018-02-13 15:21:09 Intraday data recording state for symbol F.US.YMH18 is set to download 'Pending'. | 2018-02-13 15:21:09 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEJ8. Search Symbol: F.US.CLEJ18. Request ID: 702082. Contract ID: 2. | 2018-02-13 15:21:10 CQG FIX Trading | Requesting market data for F.US.CLEJ18 | 2018-02-13 15:21:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEH8. Search Symbol: F.US.CLEH18. Request ID: 702083. Contract ID: 3. | 2018-02-13 15:21:10 CQG FIX Trading | Requesting market data for F.US.CLEH18 | 2018-02-13 15:21:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH8. Search Symbol: F.US.YMH18. Request ID: 702084. Contract ID: 4. | 2018-02-13 15:21:10 CQG FIX Trading | Requesting market data for F.US.YMH18 | 2018-02-13 15:21:10 CQG FIX Trading | Starting real-time market data updates for: F.US.YMM18. ID: 5 | 2018-02-13 15:21:10 CQG FIX Trading | Sending symbol resolution request for F.US.YMM18. ID: 702085 | 2018-02-13 15:21:10 CQG FIX Trading | Requesting security definition data for: F.US.YMM18. ID: 5 | 2018-02-13 15:21:10 CQG FIX Trading | Starting real-time market data updates for: F.US.YMU18. ID: 6 | 2018-02-13 15:21:10 CQG FIX Trading | Sending symbol resolution request for F.US.YMU18. ID: 702086 | 2018-02-13 15:21:10 CQG FIX Trading | Requesting security definition data for: F.US.YMU18. ID: 6 | 2018-02-13 15:21:10 CQG FIX Trading | Starting real-time market data updates for: F.US.EPH18. ID: 7 | 2018-02-13 15:21:10 CQG FIX Trading | Sending symbol resolution request for F.US.EPH18. ID: 702087 | 2018-02-13 15:21:10 CQG FIX Trading | Requesting security definition data for: F.US.EPH18. ID: 7 | 2018-02-13 15:21:10 CQG FIX Trading | Starting real-time market data updates for: F.US.GCEJ18. ID: 8 | 2018-02-13 15:21:10 CQG FIX Trading | Sending symbol resolution request for F.US.GCEJ18. ID: 702088 | 2018-02-13 15:21:10 CQG FIX Trading | Requesting security definition data for: F.US.GCEJ18. ID: 8 | 2018-02-13 15:21:10 CQG FIX Trading | Starting real-time market data updates for: F.US.SIEH18. ID: 9 | 2018-02-13 15:21:10 CQG FIX Trading | Sending symbol resolution request for F.US.SIEH18. ID: 702089 | 2018-02-13 15:21:10 CQG FIX Trading | Requesting security definition data for: F.US.SIEH18. ID: 9 | 2018-02-13 15:21:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMM8. Search Symbol: F.US.YMM18. Request ID: 702085. Contract ID: 5. | 2018-02-13 15:21:10 CQG FIX Trading | Requesting market data for F.US.YMM18 | 2018-02-13 15:21:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMU8. Search Symbol: F.US.YMU18. Request ID: 702086. Contract ID: 6. | 2018-02-13 15:21:10 CQG FIX Trading | Requesting market data for F.US.YMU18 | 2018-02-13 15:21:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPH8. Search Symbol: F.US.EPH18. Request ID: 702087. Contract ID: 7. | 2018-02-13 15:21:10 CQG FIX Trading | Requesting market data for F.US.EPH18 | 2018-02-13 15:21:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEJ8. Search Symbol: F.US.GCEJ18. Request ID: 702088. Contract ID: 8. | 2018-02-13 15:21:10 CQG FIX Trading | Requesting market data for F.US.GCEJ18 | 2018-02-13 15:21:10 CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEH8. Search Symbol: F.US.SIEH18. Request ID: 702089. Contract ID: 9. | 2018-02-13 15:21:10 CQG FIX Trading | Requesting market data for F.US.SIEH18 | 2018-02-13 15:21:10 CQG FIX Trading | Starting real-time market data updates for: F.US.CLEK18. ID: 10 | 2018-02-13 15:21:11 CQG FIX Trading | Sending symbol resolution request for F.US.CLEK18. ID: 702090 | 2018-02-13 15:21:11 CQG FIX Trading | Requesting security definition data for: F.US.CLEK18. ID: 10 | 2018-02-13 15:21:11 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEJ18. ID: 12 | 2018-02-13 15:21:11 CQG FIX Trading | Sending symbol resolution request for F.US.RBEJ18. ID: 702091 | 2018-02-13 15:21:11 CQG FIX Trading | Requesting security definition data for: F.US.RBEJ18. ID: 12 | 2018-02-13 15:21:11 CQG FIX Trading | Starting real-time market data updates for: F.US.RBEH18. ID: 11 | 2018-02-13 15:21:11 CQG FIX Trading | Sending symbol resolution request for F.US.RBEH18. ID: 702092 | 2018-02-13 15:21:11 CQG FIX Trading | Requesting security definition data for: F.US.RBEH18. ID: 11 | 2018-02-13 15:21:11 CQG FIX Trading | Starting real-time market data updates for: F.US.RTYM18. ID: 13 | 2018-02-13 15:21:11 CQG FIX Trading | Sending symbol resolution request for F.US.RTYM18. ID: 702093 | 2018-02-13 15:21:11 CQG FIX Trading | Requesting security definition data for: F.US.RTYM18. ID: 13 | 2018-02-13 15:21:11 CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEK8. Search Symbol: F.US.CLEK18. Request ID: 702090. Contract ID: 10. | 2018-02-13 15:21:11 CQG FIX Trading | Requesting market data for F.US.CLEK18 | 2018-02-13 15:21:11 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEJ8. Search Symbol: F.US.RBEJ18. Request ID: 702091. Contract ID: 11. | 2018-02-13 15:21:11 CQG FIX Trading | Requesting market data for F.US.RBEJ18 | 2018-02-13 15:21:11 CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEH8. Search Symbol: F.US.RBEH18. Request ID: 702092. Contract ID: 12. | 2018-02-13 15:21:11 CQG FIX Trading | Requesting market data for F.US.RBEH18 | 2018-02-13 15:21:11 CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM8. Search Symbol: F.US.RTYM18. Request ID: 702093. Contract ID: 13. | 2018-02-13 15:21:11 CQG FIX Trading | Requesting market data for F.US.RTYM18 | 2018-02-13 15:21:11 HD Request # 146 | Downloading Intraday chart data for F.US.RTYH18 to the file F.US.RTYH18.scid. Service: cqg | 2018-02-13 15:21:14 HD Request # 146 | Download start date-time: 2018-02-13 15:14:59.000 | 2018-02-13 15:21:14 HD Request # 146 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:21:14 Socket (396) | Creating socket. | 2018-02-13 15:21:14 Socket (396) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:21:14 HD Request # 146 | Setting DTC encoding to Binary VLS | 2018-02-13 15:21:14 HD Request # 146 | Sending historical data logon request message. | 2018-02-13 15:21:14 HD Request # 146 | Requesting Intraday data. Start date-time: 2018-02-13 15:14:59. Record interval: 0. Symbol: F.US.RTYH18 | 2018-02-13 15:21:14 HD Request # 146 | Decompressing data. | 2018-02-13 15:21:14 HD Request # 146 | Receiving Intraday data for F.US.RTYH18 starting at 2018-02-13 15:14:59 | 2018-02-13 15:21:14 Socket (396) | Initiating close of socket by core. | 2018-02-13 15:21:14 Socket (396) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:21:14 Socket (396) | Socket gracefully closed by remote side. | 2018-02-13 15:21:14 Socket (396) | Closed. | 2018-02-13 15:21:14 Historical data download thread signaled to stop. | 2018-02-13 15:21:15 HD Request # 146 | Received 7 records from 2018-02-13 15:14:59 to 2018-02-13 15:14:59 (0.0 seconds) and wrote 0 records for F.US.RTYH18 | 2018-02-13 15:21:15 HD Request # 146 | Completion time: 0s | 2018-02-13 15:21:15 HD Request # 146 | Intraday data download complete for F.US.RTYH18. Unique request ID: 145 | 2018-02-13 15:21:15 Removed historical data download ID 145 | 2018-02-13 15:21:15 Real-time Intraday chart data file updates started for F.US.RTYH18 | 2018-02-13 15:21:15 Intraday chart data file opened for F.US.RTYH18 | 2018-02-13 15:21:15 Delaying start of download for F.US.CLEH18 | 2018-02-13 15:21:15 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:21:15 Chart #7 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:21:15 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:21:17 Chart #4 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:21:22 Requesting market depth updates for: F.US.CLEH18 if supported. | 2018-02-13 15:21:22 CQG FIX Trading | Requesting market data including full depth for F.US.CLEH18 | 2018-02-13 15:21:22 Requesting market depth updates for: F.US.RTYH18 if supported. | 2018-02-13 15:21:22 CQG FIX Trading | Requesting market data including full depth for F.US.RTYH18 | 2018-02-13 15:21:22 Requesting market depth updates for: F.US.YMH18 if supported. | 2018-02-13 15:21:22 CQG FIX Trading | Requesting market data including full depth for F.US.YMH18 | 2018-02-13 15:21:22 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:21:22 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:21:22 F.US.RTYH18 [CBV] 0.4 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:21:23 HD Request # 147 | Downloading Intraday chart data for F.US.CLEH18 to the file F.US.CLEH18.scid. Service: cqg | 2018-02-13 15:21:25 HD Request # 147 | Download start date-time: 2018-02-13 15:20:44.000 | 2018-02-13 15:21:25 HD Request # 147 | Using server: ds3.sierracharts.com port 10150 | 2018-02-13 15:21:25 Socket (397) | Creating socket. | 2018-02-13 15:21:25 Socket (397) | Connecting to IP: 65.182.172.42. | 2018-02-13 15:21:25 HD Request # 147 | Setting DTC encoding to Binary VLS | 2018-02-13 15:21:25 HD Request # 147 | Sending historical data logon request message. | 2018-02-13 15:21:25 HD Request # 147 | Requesting Intraday data. Start date-time: 2018-02-13 15:20:44. Record interval: 0. Symbol: F.US.CLEH18 | 2018-02-13 15:21:25 HD Request # 147 | Decompressing data. | 2018-02-13 15:21:26 HD Request # 147 | Receiving Intraday data for F.US.CLEH18 starting at 2018-02-13 15:20:44 | 2018-02-13 15:21:26 HD Request # 147 | Timestamp of first Intraday data file record written: 2018-02-13 15:20:52 | 2018-02-13 15:21:26 Socket (397) | Initiating close of socket by core. | 2018-02-13 15:21:26 Socket (397) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:21:26 Historical data download thread signaled to stop. | 2018-02-13 15:21:26 HD Request # 147 | Received 9 records from 2018-02-13 15:20:44 to 2018-02-13 15:21:15 (31.0 seconds) and wrote 8 records for F.US.CLEH18 | 2018-02-13 15:21:26 HD Request # 147 | Completion time: 0s | 2018-02-13 15:21:26 HD Request # 147 | Intraday data download complete for F.US.CLEH18. Unique request ID: 146 | 2018-02-13 15:21:26 Removed historical data download ID 146 | 2018-02-13 15:21:26 Real-time Intraday chart data file updates started for F.US.CLEH18 | 2018-02-13 15:21:26 Intraday chart data file opened for F.US.CLEH18 | 2018-02-13 15:21:26 HD Request # 148 | Downloading Intraday chart data for F.US.YMH18 to the file F.US.YMH18.scid. Service: cqg | 2018-02-13 15:21:26 HD Request # 148 | Download start date-time: 2018-02-13 15:14:58.000 | 2018-02-13 15:21:26 HD Request # 148 | Using server: ds4.sierracharts.com port 10149 | 2018-02-13 15:21:26 Socket (398) | Creating socket. | 2018-02-13 15:21:26 Socket (398) | Connecting to IP: 192.81.56.146. | 2018-02-13 15:21:26 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:21:26 Chart #2 has tagged chart #4 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:21:26 Chart #2 has tagged chart #7 for full recalculation. Chartbook: Crude v9.cht | 2018-02-13 15:21:26 F.US.CLEH18 0.02 Range #7 | Performing a full recalculation because it has been tagged. Chartbook: Crude v9.cht | 2018-02-13 15:21:26 Socket (397) | Socket gracefully closed by remote side. | 2018-02-13 15:21:26 Socket (397) | Closed. | 2018-02-13 15:21:26 HD Request # 148 | Setting DTC encoding to Binary VLS | 2018-02-13 15:21:26 HD Request # 148 | Sending historical data logon request message. | 2018-02-13 15:21:26 HD Request # 148 | Requesting Intraday data. Start date-time: 2018-02-13 15:14:58. Record interval: 0. Symbol: F.US.YMH18 | 2018-02-13 15:21:26 HD Request # 148 | Decompressing data. | 2018-02-13 15:21:26 HD Request # 148 | Receiving Intraday data for F.US.YMH18 starting at 2018-02-13 15:14:58 | 2018-02-13 15:21:26 Socket (398) | Initiating close of socket by core. | 2018-02-13 15:21:26 Socket (398) | Shutdown started. Waiting for graceful close. | 2018-02-13 15:21:26 Socket (398) | Socket gracefully closed by remote side. | 2018-02-13 15:21:26 Socket (398) | Closed. | 2018-02-13 15:21:26 Historical data download thread signaled to stop. | 2018-02-13 15:21:26 HD Request # 148 | Received 4 records from 2018-02-13 15:14:58 to 2018-02-13 15:14:58 (0.0 seconds) and wrote 0 records for F.US.YMH18 | 2018-02-13 15:21:26 HD Request # 148 | Completion time: 1s | 2018-02-13 15:21:26 HD Request # 148 | Intraday data download complete for F.US.YMH18. Unique request ID: 147 | 2018-02-13 15:21:26 Removed historical data download ID 147 | 2018-02-13 15:21:26 Real-time Intraday chart data file updates started for F.US.YMH18 | 2018-02-13 15:21:26 Intraday chart data file opened for F.US.YMH18 | 2018-02-13 15:21:26 Chart #4 has tagged chart #7 for full recalculation. Chartbook: YM v8.cht | 2018-02-13 15:21:27 F.US.RTYH18 [CBV] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Emini Russ RTY v8.cht | 2018-02-13 15:21:27 F.US.CLEH Date Time Of Last Edit: 2018-02-13 22:21:09
| [2018-02-13 22:20:10] |
OK we are looking this over. We just want to check to rule out a possibility, is Sierra Chart in a frozen state for more than 5 or 10 seconds before it happens? In other words is the program like frozen and inoperable for a period of time? And also at the time you notice this do you notice that the charts stop updating, in other words the data feed stops, and then there is a disconnection shortly after? Also, do not post any further Message Logs. They are not needed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-13 22:20:37
| [2018-02-13 23:12:05] |
We want you to update to prerelease 1701 which we are putting out in a few minutes. We increased the amount of time required before establishing a reconnection when a pong message is not received from the server. We have doubled it. It is now going to be 80 seconds rather than 40 seconds. Why that message is not getting received we do not know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-13 23:12:27
| [2018-02-13 23:22:27] |
| User925794 - Posts: 28 |
I saw that "warning" in the log. Didn't know about the delay. I'll update to prerelease. I have done some simple network actions like speed test and streaming media - zero indicators. Not sure if this would help, but perhaps there's a network ping exercise you could recommend? Maybe one of the IP addresses pointed to in the logs? Or some simple maneuver with Wireshark? What's strange is the decreasing window between event times since Sunday night at market open... I'll report back with observations. Thanks again. |
| [2018-02-13 23:24:45] |
We have released version 1701. Update following these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2018-02-14 14:52:44] |
Since updating to 1701, there have been no more connection drops to the server as of this posting. Thanks! ps - I'm still open to any network investigations that may help this endeavor if you would like. |
| [2018-02-14 18:43:55] |
OK good. So it did help for us to increase the time to wait for a response Pong message before considering there is a problem with the data feed.
| [2018-02-14 21:19:11] |
_ /(| ( : __\ \ _____ (____) `| (____)| | (____).__| (___)__.|_____ |
