Date/Time: Sat, 18 Jan 2025 19:35:19 +0000
order rejected
View Count: 714
[2018-02-12 18:59:43] |
User357295 - Posts: 76 |
Can you please tell me if it's coming from SC or from my broker, cause they can't see any orders rejected. Thanks Trade Activity Log: File read result: 11687 records inserted. 1582 fill records inserted. 0 records filtered. | 2018-02-12 19:54:08 Trade Activity Log: File date-time limits: Sim records date-time limit is 2018-01-28 00:00:00. Non-sim records date-time limit is 2017-11-11 00:00:00. Non-sim fill record date-time limit is 2017-02-12 00:00:00. | 2018-02-12 19:54:08 CQG order update (Rejected). Text: Symbol is incorrect or not defined. Internal Order ID: 3833. Service Order ID: (none). Symbol: p.US.CLEk186200 | 2018-02-12 19:56:38 * |
[2018-02-12 23:13:55] |
This error message is from CQG: Text: Symbol is incorrect or not defined.
Follow the method here to look up CQG option symbols to make sure you are using the right one: https://www.sierrachart.com/index.php?page=doc/CQGTrading.php#OptionsSymbolFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-15 17:59:40] |
A broker contacted us about this as well and we think maybe in relation to you and this particular order. Make sure the options symbol is all uppercase: Chart Data and Chart Data Files: Correcting Letter Case Of Symbols And make sure it is one of the listed options. Refer to: https://www.sierrachart.com/index.php?page=doc/CQGTrading.php#OptionsSymbolFormat With CQG never manually type an options symbol! Do not try to figure them out. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-16 19:53:22] |
We have followed up with CQG about this.
[2018-02-27 23:52:54] |
Did you still need help with this? CQG required some additional details. Specifically the FIX log. Let us know and we will then tell you what you need to do.
[2018-02-28 09:17:08] |
Everything's ok now thanks
