Date/Time: Mon, 20 Jan 2025 08:34:24 +0000
how to add mid lines for drawings
View Count: 1062
[2018-02-12 17:30:17] |
whats1thingnow - Posts: 407 |
Hi support, Coming from another charting platform, I was able to add mid lines for the drawing tools. So I was wondering if SC could do the same? For example, is it possible to add a mid line for the parallel lines tool, or the rectangle tool? Thanks! |
[2018-02-12 18:23:21] |
Depending on the particular tool, there are such options available. For example, for the Parallel Lines tool, you would simply add a level with a value of 50. For the rectangle, however, there is no direct way to do this, you would have to draw a manual line for that particular drawing. Any tool that allows the entry of a Level will work like the Parallel Lines tool. The documentation for the options on the Parallel Lines can be found here: Chart Drawing Tools: Parallel Lines Configuration The documentation for Drawing Properties can be found here: Chart Drawing Tools: Chart Drawing Properties The documentation for Drawing Configurations can be found here: Chart Drawing Tools: Drawing Tool Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-04 06:39:36] |
possible to add an option for the rectangle tool? right now, i have to use the rectangle tool... then use the parallel lines tool with value of 50 to add the midline for the rectangle thanks! |
