Date/Time: Sat, 18 Jan 2025 05:10:35 +0000
system clock not matching
View Count: 1381
[2018-01-29 14:34:47] |
User98657 - Posts: 329 |
I'm getting errors on start up (and its obvious when checking time) that my computer clock does not match the server. i followed the instructions to set system clock to mach server, but it's not working. Clicked on the Analyze button after update failed.
[2018-01-29 17:11:38] |
Your clock is off by almost 3 minutes. You need to make sure that the clock is set accurately. Refer to the documentation here: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating: Setting Computer System Date-Time and Time Zone We see that you are running Windows 10. Have you disabled the "Set Time Automatically" within Windows? In most cases, you would want to keep this setting enabled. If despite having "Set Time Automatically" enabled the computer clock is still not being set correctly, then you need to manually adjust it. For more details refer to the following page: http://www.thewindowsclub.com/time-language-settings-windows-10 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-29 17:36:36] |
User681267 - Posts: 16 |
Here's a really neat program to keep your pc clock synced automatically: http://timesynctool.com/ |
