Date/Time: Sat, 18 Jan 2025 07:56:31 +0000
Renko Charts
View Count: 1986
[2018-01-26 12:03:21] |
jimskin - Posts: 127 |
I’ve been trying to duplicate a Median Renko chart I have running on another platform in SC but can’t seem to do it. The charts on the other platform have a Retracement Factor of 0.5 (50%) and Symmetrical Reversals are switched on. I can set the Retracement Factor on the Flex Renko charts but don’t know how to set Symmetrical Reversals. I read the documentation but couldn’t find any reference to Symmetrical Reversals. Also, I noticed there are two Renko Custom Studies in SC (Renko Chart and Renko Chart Enhanced). I tried the Renko Chart Enhanced study but it appears to be broken. It takes about 5 minutes for the price to update. The Renko Chart custom study seems very good. It’s actually a lot smoother than the built in Renko charts in SC. Is it possible to get the built in Flex or Standard Renko charts working like the custom Renko Chart study? I’ve tried for many hours, but no luck. Thanks |
[2018-01-26 18:33:45] |
We do not know what is meant by Symmetrical Reversals. We provide no support for those older Renko studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-26 19:42:24
[2018-01-26 19:23:34] |
Ok. Who developed the Renko studies. Is the source code available.
[2018-01-26 19:31:19] |
Yes you can find the source code: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-26 19:40:07] |
Xfanman1 - Posts: 320 |
Also, I noticed there are two Renko Custom Studies in SC (Renko Chart and Renko Chart Enhanced). I tried the Renko Chart Enhanced study but it appears to be broken. It takes about 5 minutes for the price to update. The Renko Chart custom study seems very good. It’s actually a lot smoother than the built in Renko charts in SC. Is it possible to get the built in Flex or Standard Renko charts working like the custom Renko Chart study? I’ve tried for many hours, but no luck. Thanks If you post an image of a chart from your other platform with its settings there are many here that could probably help you. Renko has been talked to death here the past few months so it's had a lot of attention and development by the SC Engineering team. Just a suggestion....Scott Date Time Of Last Edit: 2018-01-26 19:40:41
[2018-01-26 19:43:02] |
There is also another developer in France, who has created some other custom Renko bars, that may help as well. Maybe they will see this post and let you know what they have available. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-26 19:59:06] |
Ok, great. Thank you.
[2018-01-31 17:31:11] |
Is it possible to refresh individual charts (I've tried setting the 'Intraday Data Storage Time Unit' to 1 Tick). I'm using the custom Renko Chart study on a Daily timeframe but the renko chart doesn't update in real-time. I have to keep clicking the 'Dly' tab to get the renko bars to update.
[2018-02-01 15:45:58] |
I managed to find a solution to the issue above. Thanks
