Date/Time: Sat, 18 Jan 2025 04:59:54 +0000
Upgrade 1689 freezes
View Count: 605
[2018-01-25 16:37:37]
User881916 - Posts: 7
Hi. I performed the latest upgrade when the pop-up said it was available but now it goes into Not Responding when I try to do anything in the pull-down menus. It takes several minutes to come back. I currently have version 1689 and Windows 7. How do I begin to debug it? Can I go back to the previous version? Thank you.
[2018-01-25 17:59:46]
For this type of issue, refer to help topic 30:
http://www.sierrachart.com/index.php?page=doc/helpdetails30.html
You may want to run Sierra Chart in Safe Mode and see if that is at least a temporary solution:
Sierra Chart - Software Login Instructions: Using Safe Mode
To go back to an earlier version, refer to:
Software Download: Software Rollback Procedure
Date Time Of Last Edit: 2018-01-25 17:59:54
