Date/Time: Sat, 18 Jan 2025 01:59:01 +0000
Trade caused big loss, trade was not showing on the chart....
View Count: 942
[2018-01-17 23:12:45] |
User859795 - Posts: 51 |
Hello, Broker: AMP Futures Data: CTS T4 using server side orders / OCO According to AMP's statement, there was an open CL Futures trade, running from 1-12 to 1-14, it caused $960 loss - we only use $200 risk, never more. AMP Futures walked away, their statement shows CL Futures open at price of 63.57 on 1-12-2018 and this trade closed on 1-16-2018 on price of 64.53. CTS T4 states there are no issues on their side. There was no open trade showing on the chart, nothing shows on the chart regarding to an open trade running into nowhere. We had several other CL trades in between this time period, those opened / closed with no issue. How is this possible? How can a trade running somewhere on some servers and not showing it on the chart? Zolie Attached trade activity log |
TradeActivityLog.txt - Attached On 2018-01-17 23:12:37 UTC - Size: 46.37 KB - 351 views |
[2018-01-17 23:44:06] |
It is best that you examine this from your side since you have a very good understanding of what you were doing and expecting at each moment in time. Here is the documentation to determine the historical Position Quantity and why it went to zero when it did (assuming that is what happened): Trade Activity Log: Determining Historical Trade Position Quantity from Trade Activity Log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-17 23:45:07
[2018-01-18 00:20:49] |
I don't understand, because the trade log/position log shows the correctly filled stop loss, however the position itself stayed open invisibly and ran away for a couple of days, but this all wasn't showing on the platform - this open position was only showing on AMP statement.How is this possible?
[2018-01-18 00:22:53] |
What does the Trade Activity Log tell you about this? Did at any point in time, during the relevant time frame, did it go to zero when it should have been nonzero for the particular Symbol and Trade Account?
[2018-01-18 00:26:30] |
Sorry, i don't understand what you mean. There was no visible sign of any open trades or any open positions.
[2018-01-18 02:44:00] |
This would indicate that at some point the CTS server reported a Position of 0 for the particular Symbol and Trade Account. Anytime there is a Position update from the server, there is a line in the Trade Activity log for this. However, this is what we are seeing: Order 2018-01-12 11:28:30.246 CL.20180200.CME_NY Updated Internal Position Quantity to -1. Previous: 0 Unspecified Order 2018-01-12 11:28:30.248 CL.20180200.CME_NY Updated Service Position Quantity to -1 Unspecified Order 2018-01-12 14:05:17.444 Disconnected from server None Unspecified So at 2018-01-12 14:05:17.444 when apparently you closed Sierra Chart, there was a Position reported of -1 for CL.20180200.CME_NY. This is what you should have seen. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-18 03:22:17] |
Thank you, does that mean that the CTS server failed to show the open position?
[2018-01-18 03:27:44] |
How can i use accuse them (either CTS or AMP Futures) about this fault?
[2018-01-18 04:36:22] |
So is it correct that there was a -1 Position Quantity for CL.20180200.CME_NY aat 2018-01-12 14:05:17.444 ? We do not know. That is why we a huge disadvantage here. And when you say that you did not see this on the chart. We also do not know how you are coming to that conclusion precisely. You may not have seen the Position line because it could have been at a price level which was not even visible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
