Date/Time: Tue, 04 Nov 2025 14:57:42 +0000
Image Question
View Count: 2815
|   [2013-04-05 06:18:37]     |
| C. Notes - Posts: 130 |
                Is it possible to upload a spreadsheet image? Love the image upload feature. It's great. I've been using it to post numerous charts so hopefully it brings extra users and visitors to Sierra Chart! Awesome feature... Date Time Of Last Edit: 2013-04-05 06:19:15
|   [2013-04-05 06:56:16]     |
| ganz - Posts: 1048 |
                Hello SC Team. My suggestion is about User's Image Gallery: - Could you consider to add an ability to attach a Chartbook underneath an Image? - IMHO, an ability to select/search certain user in the Gallery may be helpful also. Thank you. PS: C. Notes Will You excuse me for interrupting Your thread in order not to start another one? Thank You.  |
|   [2013-04-05 20:55:22]     |
                The ability to upload a spreadsheet image will come later on. We will see about supporting a Chartbook in the User Image Gallery. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-05 20:55:32
