Date/Time: Sun, 05 May 2024 04:44:43 +0000
How many computer I am allowed to download for my account?
View Count: 1518
[2018-01-11 21:38:54] |
User93731 - Posts: 79 |
Hi : I have currently installed Sierra Chart in two coumpter (One at Home , the other at my office). I intend to buy anther PC and have SC installed. So Could I use the same account on my third computer? Thanks |
[2018-01-11 22:42:40] |
Yes. Did you want to use all three at the same time?
[2018-01-12 16:08:03] |
No. I might want to use two Computers, each computer with diffenrt datafeed at the same time. Will this work?
[2018-01-12 19:17:15] |
Yes this will work just fine. No problems.
[2019-12-12 16:27:36] |
Hi: I have three computers installed SC and This morning when I tried to using my account to open the SC on my second computer, the first login window told me that I exceed the system allowed. Based on your reply, it seems that I am ok with two Systems allowed. Could you fix this for me? Thanks |
[2019-12-12 18:04:04] |
Two systems are definitely allowed. Currently you have Sierra Chart running on two different systems. You can add a third system here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-12 18:04:31
[2019-12-12 20:18:29] |
Thanks. My SC in the office is not shout down as I thought. Thanks |
