Date/Time: Fri, 17 Jan 2025 23:40:32 +0000
Current TPO developing Volume Profile
View Count: 1246
[2018-01-09 16:24:19] |
BenjaminR - Posts: 170 |
I'd like to see an independent volume profile for the current developing TPO (total volume OR bidXask), as well as an independent volume profile for the developing session. By the way, I found a support ticket from 2014 with the same or similar request, and SC said eventually it will be available. Please advise. Thank you. |
[2018-01-09 19:48:05] |
We really do not fully understand the question because it is vague. But what we can infer is that you simply are asking about a particular volume profile starting at some point in time and ending at some point in time which could be the end of the chart. The Volume by Price study is fully capable of this. Just follow through the instructions here: Volume By Price Study: Step By Step Instructions Make sure you are using the Volume Graph Period Type that you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-09 19:49:10
[2018-01-09 21:02:03] |
Let me re-phrase the question: I'd like to see an independent volume profile for the current developing 30 min TPO, in addition to the independent volume profile that is available for displaying the volume profile for the entire developing session (all TPOs of a session). I hope that helps. |
[2018-01-09 22:46:01] |
So do you want at the end of the chart, a 30 minute Volume Profile starting from the most recent 30 minute time segment relative to the session Start Time?
[2018-01-09 23:07:13] |
Indeed, and I can currently do that; however, I also want to keep seeing the volume profile for the whole session as it develops. *** I should perhaps add... this configuration of 2 volume profiles would only be for the most current, recent profile on the right side of the chart. I wouldn't want to see the last 30 min volume profile next to the entire session's profile for every profile in the chart - only the current one. I could see a conflict w/ users overlaying the TPOs and the volume profiles. The 30 min volume profile should remain independent, if a user prefers to have the standard volume profile for a session underlay the TPO profile. Hope this helps clarify. I can create an example if needed. |
[2018-01-10 21:06:39] |
We have prepared the Input Settings you need to use for this here: Volume By Price Study: 30 Minute Volume Profile at End of TPO Profile Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
