Date/Time: Fri, 17 Jan 2025 07:32:05 +0000
Numbers Bars text coloring on one value/ background coloring on another
View Count: 1334
[2017-12-09 17:53:53]
User781967 - Posts: 18
I would like to save space on my numbers bars by combining the information from two columns into one. I would like to coloring the text based on diagonal background based on diagonal dominant side AskVol BidVol Percentage based on a 400 percent threshold and color the background of column one based on the highest AskVol BidVol difference. These amounts are currently highlighted in column two. I know that I can color text separately, but that seems based on volume and not a percentage. Can you help please? Thanks. http://www.sierrachart.com/image.php?Image=1512841851584.png
[2017-12-11 05:09:22]
You just need to use both the Text Coloring Method and the Background Coloring Method and use different colors for each. This is explained here:
Numbers Bars: Using Text and Background Coloring Methods at Same Time
The Text Coloring Method supports both percentages and actual volume.
Date Time Of Last Edit: 2017-12-11 05:11:27
[2017-12-12 04:55:26]
Thank you for your response. I have tried to work with what you sent me, but the problem that I have is that I am trying to compare two separate on different thresholds. I am highlighting text at 400 percent (on diagonal dominant, but I want to color the background only for the highest ask vol/bid vol difference cyan and for the lowest ask/bid difference pink in a single column of bid vol x ask vol. What am I doing wrong? Thank you.
[2017-12-13 04:30:59]
OK we see, this really requires different threshold Inputs for both the Text and Background coloring methods. We would rather not do that to avoid complicating the study.
You just really need a separate Numbers Bars chart for this.
Date Time Of Last Edit: 2017-12-13 04:31:15
