Date/Time: Tue, 04 Nov 2025 14:57:32 +0000
Candles formation issue
View Count: 2571
|   [2013-04-04 18:26:21]     |
| Zonescalper - Posts: 6 |
                Dear support, The candles in my 2 minute chart are not correctly created. The first chart has candles created at 14:12 and 14:14 and then again time says 14:12 and 14:14 for the two candles after that. http://www.sierrachart.com/image.php?l=1365099347691.png The second chart I have redownloaded the chart again and I get the correct chart. http://www.sierrachart.com/image.php?l=136509937346.png What can I do to solve this candle formation issue? Kind regards, Zones  |
|   [2013-04-04 21:07:02]     |
                How do you have: Global Settings >> Data/Trade Service Settings >> Timestamp Using Local Computer Clock set? In general what you have is a time stamping problem. Refer to help topic 38 here: http://www.sierrachart.com/index.php?l=doc/helpdetails38.html Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
