Date/Time: Thu, 16 Jan 2025 19:03:31 +0000
SC data --- real data feed and symbols
View Count: 921
[2017-11-17 11:44:18] |
Branislav Palacka - Posts: 1 |
Hello, I have a problem with correct symbols and live data feed. I have sierra 1644 SP5, Sierra Chart Real-Time and Historical Exchange Data Feed (trial) and CME, Globex only (For users without a trading account) (trial) In Data/Trade services setting I have SC Data – All Services and I check Allow Support for SCDF I use 2 minutes intraday chart When I use NQZ17-$IUXX then data lines in chart are incorrect, like all of them are within few points. The value of point is also incorrect as it starts on 0 and not from 6300… When I use just $IUXX then data lines are correct but volume for every line are exactly the same 120. In both instances I don’t have real data but late data with 1 hour delay. I really tried to read your Support board, but I still feel lost. Please help me to solve this. Thank you Branislav http://www.sierrachart.com/image.php?Image=1510918882231.png |
[2017-11-17 17:49:53] |
You need to use these particular symbols for real-time futures data: NQZ17 ESZ17 Did you want to receive real-time data for the symbol $IUXX ? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
