Date/Time: Thu, 16 Jan 2025 16:23:01 +0000
Renko Flex reversal candles changed?
View Count: 1231
[2017-11-13 16:13:12] |
User23815 - Posts: 210 |
I have been using Renko Flex candles with wicks on the ES for a long time. I use spreadsheet alerts with arrows indicating the alert location on the chart. Today I downloaded the current version just to make sure I had the latest. Now on the candles where price reverses, the candles are printing in the opposite direction color. I noticed it because of the alert arrows showing a signal in one direction but the candle still printing in the opposite. For example, price reaches a high, then the next candle has a lower close than the previous. The candle with the lower close still prints in the higher close color. Other candles seem to then continue as normal, printing correctly. Was there a change made to Renko Flex or something else that would cause this? Thanks
[2017-11-13 17:53:59] |
Check the Renko New Bar Mode setting. Set it to what you require: Renko Bar Charts: Renko New Bar Mode Also refer to: Renko Bar Charts: Renko Open, High, Low, Close Values You really need to rely upon the Renko Open and Close Values. There is a study for this. This is the basic problem. You are using the true Open and Close values which may not match. RENKO CHART from studies drop down no longer works. These are found in Analysis >> Studies >> Add Custom Study>> Sierra Chart Custom Studies.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-13 19:47:02
