Date/Time: Tue, 04 Nov 2025 14:57:32 +0000
[User Discussion] - RSI-Color Above/below Zero
View Count: 2844
|   [2013-04-04 15:03:34]     |
| User59821 - Posts: 6 |
                i would  like to have rsi bars change color-when above/below zero-they currently stay same color-even though selection is set above/below zero. that setting works with the CCi-but not on the RSi thanks,  |
|   [2013-04-04 20:26:19]     |
| Sawtooth - Posts: 4285 |
                The RSI plots values 0-100.  You can use the Study Subgraph Subtract study, Based On the RSI, with the Amount To Subtract set to 50, then use the Auto-coloring Based On +/-.
