Date/Time: Thu, 16 Jan 2025 16:02:00 +0000
User Question
View Count: 953
[2017-11-08 20:24:57]
Sierra Chart - Max - Posts: 5778
I am a new customer and I have been given my login and password from my broker stage five however I can get it to work.
Can you help please
Rithmic Trading | Port for executable: 50336 | 2017-11-08 18:40:13
Listening socket (1788), port 50336 | Closed. | 2017-11-08 18:40:13
Rithmic Trading | Starting server: D:\sierra\Rim\DTCBridge.exe | 2017-11-08 18:40:13
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50336 | 2017-11-08 18:40:15
DTC Client (109) | Creating socket. | 2017-11-08 18:40:15
DTC Client (109) | Connecting to IP: 127.0.0.1. | 2017-11-08 18:40:15
DTC Client (109) | Connect event error. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2017-11-08 18:40:24 *
DTC Client (109) | Initiating close of socket by core. | 2017-11-08 18:40:24
DTC Client (109) | Closed. | 2017-11-08 18:40:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-08 18:40:24
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-08 18:40:24
Rithmic Trading | Disconnected. | 2017-11-08 18:40:24
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-08 18:40:24
Rithmic Trading | Port for executable: 50338 | 2017-11-08 18:40:26
Listening socket (1660), port 50338 | Closed. | 2017-11-08 18:40:26
Rithmic Trading | Starting server: D:\sierra\Rim\DTCBridge.exe | 2017-11-08 18:40:26
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50338 | 2017-11-08 18:40:28
DTC Client (110) | Creating socket. | 2017-11-08 18:40:28
DTC Client (110) | Connecting to IP: 127.0.0.1. | 2017-11-08 18:40:28
DTC Client (110) | Connect event error. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2017-11-08 18:40:37 *
DTC Client (110) | Initiating close of socket by core. | 2017-11-08 18:40:37
DTC Client (110) | Closed. | 2017-11-08 18:40:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-08 18:40:37
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-08 18:40:37
Rithmic Trading | Disconnected. | 2017-11-08 18:40:37
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-08 18:40:37
Sierra Chart Support
[2017-11-08 21:12:32]
We must see the entire message log.
Provide a copy of the Message Log by following these instructions:
[2017-11-08 21:41:35]
User913831 - Posts: 37
Reading Internal Order ID file. | 2017-11-08 17:47:07
Reading Trade Orders file. | 2017-11-08 17:47:07
Reading Trade Positions file. | 2017-11-08 17:47:07
Listening on UDP port 22903. | 2017-11-08 17:47:07
Software version: 1594 | 2017-11-08 17:47:07
Usage end date: 2018-09-26 | 2017-11-08 17:47:07
Enabled for: Advanced Features. | 2017-11-08 17:47:07
Enabled for: Advanced Features 2. | 2017-11-08 17:47:07
Enabled for: Sierra Chart Historical Data Service. | 2017-11-08 17:47:07
Allow Support for Sierra Chart Data Feeds is enabled. | 2017-11-08 17:47:07
Current selected Data/Trading service: Rithmic Trading | 2017-11-08 17:47:07
Chart Update Interval: 500 | 2017-11-08 17:47:07
Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2017-11-08 17:47:07
2017-11-08 17:47:11 Local computer time | 2017-11-08 17:47:07
2017-11-08 16:47:11 Local computer time in UTC | 2017-11-08 17:47:07
2017-11-08 17:47:11 Local computer time in SC Time Zone | 2017-11-08 17:47:07
2017-11-08 16:47:08 Server time in UTC | 2017-11-08 17:47:07
Local computer UTC time and Server UTC time difference: 2 seconds. | 2017-11-08 17:47:07
Program path: D:\sierra\ | 2017-11-08 17:47:07
Data Files path: D:\sierra\Data\ | 2017-11-08 17:47:07
OS Version Number: 10.0 | 2017-11-08 17:47:07
Locale Setting: C | 2017-11-08 17:47:07
Opened cached Intraday file: D:\sierra\Data\AUDUSD.scid | 2017-11-08 22:00:12
Opened cached Intraday file: D:\sierra\Data\EURUSD.scid | 2017-11-08 22:00:32
DTC Client (251) | Initiating close of socket by core. | 2017-11-08 22:40:43
DTC Client (251) | Shutdown started. Waiting for graceful close. | 2017-11-08 22:40:43
DTC Client (251) | Socket gracefully closed by remote side. | 2017-11-08 22:40:43
DTC Client (251) | Closed. | 2017-11-08 22:40:43
SC DTC Data | Disconnected from the server. | 2017-11-08 22:40:43
SC Data - All Services | Disconnected. | 2017-11-08 22:40:43
Checking for new symbol settings for service code rim | 2017-11-08 22:40:43
Current selected Data/Trading service: Rithmic Trading | 2017-11-08 22:40:43
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-08 22:40:43
HTTPS connection to www.sierrachart.com:443 (271) | Creating socket. Using TLS 1.2. | 2017-11-08 22:40:43
HTTPS connection to www.sierrachart.com:443 (271) | Connecting to IP: 204.15.192.108. | 2017-11-08 22:40:43
Requesting symbol settings for service code rim. Overwrite = on. | 2017-11-08 22:40:44
Symbol settings received. | 2017-11-08 22:40:44
Processed 1054 symbol settings. | 2017-11-08 22:40:44
Rithmic Trading | Port for executable: 53555 | 2017-11-08 22:40:45
Listening socket (1984), port 53555 | Closed. | 2017-11-08 22:40:45
Rithmic Trading | Starting server: D:\sierra\Rim\DTCBridge.exe | 2017-11-08 22:40:45
Rithmic Trading | Connecting to the server 127.0.0.1. Port 53555 | 2017-11-08 22:40:47
DTC Client (272) | Creating socket. | 2017-11-08 22:40:47
DTC Client (272) | Connecting to IP: 127.0.0.1. | 2017-11-08 22:40:47
HTTPS connection to www.sierrachart.com:443 (271) | Socket gracefully closed by remote side. | 2017-11-08 22:40:49
HTTPS connection to www.sierrachart.com:443 (271) | Received socket Close event | 2017-11-08 22:40:49
HTTPS connection to www.sierrachart.com:443 (271) | Initiating close of socket by core. | 2017-11-08 22:40:49
HTTPS connection to www.sierrachart.com:443 (271) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-08 22:40:49
HTTPS connection to www.sierrachart.com:443 (271) | Closed. | 2017-11-08 22:40:49
DTC Client (272) | Connect event error. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2017-11-08 22:40:56 *
DTC Client (272) | Initiating close of socket by core. | 2017-11-08 22:40:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-08 22:40:56
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-08 22:40:56
DTC Client (272) | Closed. | 2017-11-08 22:40:56
Rithmic Trading | Disconnected. | 2017-11-08 22:40:56
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-08 22:40:56
Rithmic Trading | Port for executable: 53559 | 2017-11-08 22:40:58
Listening socket (1988), port 53559 | Closed. | 2017-11-08 22:40:58
Rithmic Trading | Starting server: D:\sierra\Rim\DTCBridge.exe | 2017-11-08 22:40:58
Rithmic Trading | Connecting to the server 127.0.0.1. Port 53559 | 2017-11-08 22:41:00
DTC Client (273) | Creating socket. | 2017-11-08 22:41:00
DTC Client (273) | Connecting to IP: 127.0.0.1. | 2017-11-08 22:41:00
DTC Client (273) | Connect event error. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2017-11-08 22:41:09 *
DTC Client (273) | Initiating close of socket by core. | 2017-11-08 22:41:09
DTC Client (273) | Closed. | 2017-11-08 22:41:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-08 22:41:09
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-08 22:41:09
Rithmic Trading | Disconnected. | 2017-11-08 22:41:09
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-08 22:41:09
Rithmic Trading | Port for executable: 53562 | 2017-11-08 22:41:11
Listening socket (1992), port 53562 | Closed. | 2017-11-08 22:41:11
Rithmic Trading | Starting server: D:\sierra\Rim\DTCBridge.exe | 2017-11-08 22:41:11
Rithmic Trading | Connecting to the server 127.0.0.1. Port 53562 | 2017-11-08 22:41:13
DTC Client (275) | Creating socket. | 2017-11-08 22:41:13
DTC Client (275) | Connecting to IP: 127.0.0.1. | 2017-11-08 22:41:13
DTC Client (275) | Connect event error. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2017-11-08 22:41:22 *
DTC Client (275) | Initiating close of socket by core. | 2017-11-08 22:41:22
DTC Client (275) | Closed. | 2017-11-08 22:41:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-08 22:41:22
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-08 22:41:22
Rithmic Trading | Disconnected. | 2017-11-08 22:41:22
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-08 22:41:22
Rithmic Trading | Port for executable: 53565 | 2017-11-08 22:41:24
Listening socket (2008), port 53565 | Closed. | 2017-11-08 22:41:24
Rithmic Trading | Starting server: D:\sierra\Rim\DTCBridge.exe | 2017-11-08 22:41:24
Date Time Of Last Edit: 2017-11-08 23:08:12
[2017-11-08 23:08:55]
This looks like it may be caused by security software running on your computer. The first thing we want you to do is to update Sierra Chart to the current version. Follow the instructions here:
Try connecting to Rithmic again from Sierra Chart and provide a copy of the Message Log. This will give us a better idea of what the problem is.
[2017-11-09 09:53:11]
Reading Internal Order ID file. | 2017-11-09 10:51:58
Reading Trade Orders file. | 2017-11-09 10:51:58
Reading Trade Positions file. | 2017-11-09 10:51:58
Listening on UDP port 22903. | 2017-11-09 10:51:58
Software version: 1640 | 2017-11-09 10:51:58
Usage end date: 2018-09-26 | 2017-11-09 10:51:58
Enabled for: Advanced Features. | 2017-11-09 10:51:58
Enabled for: Advanced Features 2. | 2017-11-09 10:51:58
Enabled for: Sierra Chart Historical Data Service. | 2017-11-09 10:51:58
Allow Support for Sierra Chart Data Feeds is enabled. | 2017-11-09 10:51:58
Current selected Data/Trading service: Rithmic Trading | 2017-11-09 10:51:58
Chart Update Interval: 500 | 2017-11-09 10:51:58
Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2017-11-09 10:51:58
2017-11-09 10:52:02 Local computer time | 2017-11-09 10:51:58
2017-11-09 09:52:02 Local computer time in UTC | 2017-11-09 10:51:58
2017-11-09 10:52:02 Local computer time in SC Time Zone | 2017-11-09 10:51:58
2017-11-09 09:52:00 Server time in UTC | 2017-11-09 10:51:58
Local computer UTC time and Server UTC time difference: 2 seconds. | 2017-11-09 10:51:58
Program path: D:\sierra\ | 2017-11-09 10:51:58
Data Files path: D:\sierra\Data\ | 2017-11-09 10:51:58
OS Version Number: 10.0 | 2017-11-09 10:51:58
Locale Setting: C | 2017-11-09 10:51:58
Created the DTC Protocol server. | 2017-11-09 10:51:58
DTC Protocol Server listening on port 11099. | 2017-11-09 10:51:58
Created the DTC Protocol historical data server. | 2017-11-09 10:51:58
HD Server Manager | Listening on port 11098 | 2017-11-09 10:51:58
Checking for new symbol settings for service code rim | 2017-11-09 10:51:58
HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-11-09 10:51:58
HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2017-11-09 10:51:58
Received 5 login tokens. | 2017-11-09 10:52:03
Symbol settings are up-to-date for rim | 2017-11-09 10:52:03
HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2017-11-09 10:52:04
HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2017-11-09 10:52:04
HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2017-11-09 10:52:08
HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2017-11-09 10:52:08
HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2017-11-09 10:52:08
HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-09 10:52:08
HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2017-11-09 10:52:08
HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2017-11-09 10:52:08
HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2017-11-09 10:52:08
HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-11-09 10:52:08
HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-09 10:52:08
HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-11-09 10:52:08
HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2017-11-09 10:52:09
HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2017-11-09 10:52:09
HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2017-11-09 10:52:09
HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-09 10:52:09
HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2017-11-09 10:52:09
Files to Open on Start up | Opening file: PierreTest.cht | 2017-11-09 10:52:10
DYZ17 3 Min #3 | Reloading chart. | 2017-11-09 10:52:10
DXZ17 1 Min #1 | Reloading chart. | 2017-11-09 10:52:10
EURUSD [CBV] 5 Min #5 | Reloading chart. | 2017-11-09 10:52:10
EURUSD [CBV] 5 Min #5 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2017-11-09 10:52:10
EURUSD [CBV] 5 Min #5 | There are no continuous futures contract symbols. Loading data normally. | 2017-11-09 10:52:10
EURUSD 1 Min #2 | Reloading chart. | 2017-11-09 10:52:10
ESU17 30 Min #4 | Reloading chart. | 2017-11-09 10:52:10
ESU17 Rev. 4t #6 | Reloading chart. | 2017-11-09 10:52:10
Files to Open on Start up | Opening file: Formation paris.cht | 2017-11-09 10:52:10
AUDUSD [CBV] 30 Min #2 | Reloading chart. | 2017-11-09 10:52:10
AUDUSD [CBV] 30 Min #2 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2017-11-09 10:52:10
AUDUSD [CBV] 30 Min #2 | There are no continuous futures contract symbols. Loading data normally. | 2017-11-09 10:52:10
AUDUSD [CBV] Daily #3 | Reloading chart. | 2017-11-09 10:52:10
AUDUSD [CBV] Daily #3 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2017-11-09 10:52:10
AUDUSD [CBV] Daily #3 | There are no continuous futures contract symbols. Loading data normally. | 2017-11-09 10:52:10
AUDUSD [CBV] #4 | Reloading chart. | 2017-11-09 10:52:10
AUDUSD [CBV] #4 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2017-11-09 10:52:10
AUDUSD [CBV] #4 | There are no continuous futures contract symbols. Loading data normally. | 2017-11-09 10:52:10
AUDUSD Rev. 4t #5 | Reloading chart. | 2017-11-09 10:52:10
AUDUSD 3 Min #6 | Reloading chart. | 2017-11-09 10:52:10
AUDUSD 3 Min #1 | Reloading chart. | 2017-11-09 10:52:10
AUDUSD 30 Min #7 | Reloading chart. | 2017-11-09 10:52:10
AUDUSD [CBV] 30 Min #8 | Reloading chart. | 2017-11-09 10:52:10
AUDUSD [CBV] 30 Min #8 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2017-11-09 10:52:10
AUDUSD [CBV] 30 Min #8 | There are no continuous futures contract symbols. Loading data normally. | 2017-11-09 10:52:10
Using Bid/Ask average for last trade price for EURUSD | 2017-11-09 10:52:14
Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2017-11-09 10:52:14
HD Request # 2 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2017-11-09 10:52:14
HD Request # 2 | Download start date-time: 2017-11-09 10:51:11.000 | 2017-11-09 10:52:14
HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2017-11-09 10:52:14
Socket (6) | Creating socket. | 2017-11-09 10:52:14
Socket (6) | Connecting to IP: 192.81.56.146. | 2017-11-09 10:52:14
Using Bid/Ask average for last trade price for AUDUSD | 2017-11-09 10:52:14
Intraday data recording state for symbol AUDUSD is set to download 'Pending'. | 2017-11-09 10:52:14
HD Request # 2 | Setting DTC encoding to Binary VLS | 2017-11-09 10:52:14
HD Request # 2 | Sending historical data logon request message. | 2017-11-09 10:52:14
Rithmic Trading | Port for executable: 55248 | 2017-11-09 10:52:14
Listening socket (1232). Port 55248 | Closed. | 2017-11-09 10:52:14
Rithmic Trading | Starting server: D:\sierra\Rim\DTCBridge.exe | 2017-11-09 10:52:14
HD Request # 2 | Requesting Intraday data. Start date-time: 2017-11-09 10:51:11. Record interval: 0. Symbol: EURUSD | 2017-11-09 10:52:14
HD Request # 2 | Decompressing data. | 2017-11-09 10:52:14
HD Request # 2 | Receiving Intraday data for EURUSD starting at 2017-11-09 10:51:11 | 2017-11-09 10:52:14
HD Request # 2 | Timestamp of first Intraday data file record written: 2017-11-09 10:51:19 | 2017-11-09 10:52:14
Socket (6) | Initiating close of socket by core. | 2017-11-09 10:52:14
HD Request # 2 | Historical data for EURUSD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-11-09 10:52:14
Socket (6) | Shutdown started. Waiting for graceful close. | 2017-11-09 10:52:14
Historical data download thread signaled to stop. | 2017-11-09 10:52:14
HD Request # 2 | Received 59 records from 2017-11-09 10:51:11 to 2017-11-09 10:52:06 (55.0 seconds) and wrote 58 records for EURUSD | 2017-11-09 10:52:14
HD Request # 2 | Intraday download COMPLETE for EURUSD. Completion time: 1s. Unique request ID: 1 | 2017-11-09 10:52:14
Removed historical data download ID 1 | 2017-11-09 10:52:14
HD Request # 3 | Downloading Intraday chart data for AUDUSD to the file AUDUSD.scid. Service: fxcm | 2017-11-09 10:52:14
HD Request # 3 | Download start date-time: 2017-11-09 10:51:06.000 | 2017-11-09 10:52:14
HD Request # 3 | Using server: ds3.sierracharts.com port 10150 | 2017-11-09 10:52:14
Socket (7) | Creating socket. | 2017-11-09 10:52:14
Socket (7) | Connecting to IP: 65.182.172.42. | 2017-11-09 10:52:14
Socket (6) | Socket gracefully closed by remote side. | 2017-11-09 10:52:14
Socket (6) | Closed. | 2017-11-09 10:52:14
HD Request # 3 | Setting DTC encoding to Binary VLS | 2017-11-09 10:52:14
HD Request # 3 | Sending historical data logon request message. | 2017-11-09 10:52:14
HD Request # 3 | Requesting Intraday data. Start date-time: 2017-11-09 10:51:06. Record interval: 0. Symbol: AUDUSD | 2017-11-09 10:52:14
HD Request # 3 | Decompressing data. | 2017-11-09 10:52:14
HD Request # 3 | Receiving Intraday data for AUDUSD starting at 2017-11-09 10:51:06 | 2017-11-09 10:52:14
HD Request # 3 | Timestamp of first Intraday data file record written: 2017-11-09 10:51:28 | 2017-11-09 10:52:14
Socket (7) | Initiating close of socket by core. | 2017-11-09 10:52:14
HD Request # 3 | Historical data for AUDUSD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-11-09 10:52:14
Socket (7) | Shutdown started. Waiting for graceful close. | 2017-11-09 10:52:14
HD Request # 3 | Received 43 records from 2017-11-09 10:51:06 to 2017-11-09 10:52:11 (65.0 seconds) and wrote 42 records for AUDUSD | 2017-11-09 10:52:14
HD Request # 3 | Intraday download COMPLETE for AUDUSD. Completion time: 0s. Unique request ID: 2 | 2017-11-09 10:52:14
Removed historical data download ID 2 | 2017-11-09 10:52:14
HD Request # 4 | Downloading Historical Daily chart data for AUDUSD. Starting date: 2017-11-08. Service: fxcm | 2017-11-09 10:52:14
HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2017-11-09 10:52:14
Socket (8) | Creating socket. | 2017-11-09 10:52:14
Socket (8) | Connecting to IP: 192.81.56.146. | 2017-11-09 10:52:14
Socket (7) | Socket gracefully closed by remote side. | 2017-11-09 10:52:14
Socket (7) | Closed. | 2017-11-09 10:52:14
HD Request # 4 | Setting DTC encoding to Binary VLS | 2017-11-09 10:52:15
HD Request # 4 | Sending historical data logon request message. | 2017-11-09 10:52:15
HD Request # 4 | Requesting historical Daily data starting at 2017-11-08. | 2017-11-09 10:52:15
HD Request # 4 | Decompressing data. | 2017-11-09 10:52:15
HD Request # 4 | Receiving historical Daily data for AUDUSD starting at 2017-11-08 | 2017-11-09 10:52:15
HD Request # 4 | Writing historical Daily data to the file AUDUSD.dly | 2017-11-09 10:52:15
Socket (8) | Initiating close of socket by core. | 2017-11-09 10:52:15
Socket (8) | Shutdown started. Waiting for graceful close. | 2017-11-09 10:52:15
Historical data download thread signaled to stop. | 2017-11-09 10:52:15
HD Request # 4 | Received 2 records from 2017-11-08 00:00:00 to 2017-11-09 00:00:00 (2.0 days) and wrote 2 records for AUDUSD | 2017-11-09 10:52:15
HD Request # 4 | Daily download COMPLETE for AUDUSD. Completion time: 0s. Unique request ID: 3 | 2017-11-09 10:52:15
Removed historical data download ID 3 | 2017-11-09 10:52:15
Socket (8) | Socket gracefully closed by remote side. | 2017-11-09 10:52:15
Socket (8) | Closed. | 2017-11-09 10:52:15
AUDUSD [CBV] [M] Daily #3 | Reloading chart. | 2017-11-09 10:52:15
AUDUSD [CBV] [M] Daily #3 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2017-11-09 10:52:15
AUDUSD [CBV] [M] Daily #3 | There are no continuous futures contract symbols. Loading data normally. | 2017-11-09 10:52:15
Rithmic Trading | Bridge process is running. | 2017-11-09 10:52:17
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55248 | 2017-11-09 10:52:17
DTC Client socket (9) | Creating socket. | 2017-11-09 10:52:17
DTC Client socket (9) | Connecting to IP: 127.0.0.1. | 2017-11-09 10:52:17
DTC Client socket (9) | Connect event error. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2017-11-09 10:52:26 *
DTC Client socket (9) | Initiating close of socket by core. | 2017-11-09 10:52:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-09 10:52:26
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 10:52:26
DTC Client socket (9) | Closed. | 2017-11-09 10:52:26
Rithmic Trading | Disconnected. | 2017-11-09 10:52:26
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 10:52:26
Rithmic Trading | Port for executable: 55252 | 2017-11-09 10:52:28
Listening socket (1244). Port 55252 | Closed. | 2017-11-09 10:52:28
Rithmic Trading | Starting server: D:\sierra\Rim\DTCBridge.exe | 2017-11-09 10:52:28
Rithmic Trading | Bridge process is running. | 2017-11-09 10:52:30
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55252 | 2017-11-09 10:52:30
DTC Client socket (10) | Creating socket. | 2017-11-09 10:52:30
DTC Client socket (10) | Connecting to IP: 127.0.0.1. | 2017-11-09 10:52:30
DTC Client socket (10) | Connect event error. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2017-11-09 10:52:39 *
DTC Client socket (10) | Initiating close of socket by core. | 2017-11-09 10:52:39
DTC Client socket (10) | Closed. | 2017-11-09 10:52:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-09 10:52:39
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 10:52:39
Rithmic Trading | Disconnected. | 2017-11-09 10:52:39
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 10:52:39
Rithmic Trading | Port for executable: 55256 | 2017-11-09 10:52:41
Listening socket (1484). Port 55256 | Closed. | 2017-11-09 10:52:41
Rithmic Trading | Starting server: D:\sierra\Rim\DTCBridge.exe | 2017-11-09 10:52:41
Rithmic Trading | Bridge process is running. | 2017-11-09 10:52:43
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55256 | 2017-11-09 10:52:43
DTC Client socket (11) | Creating socket. | 2017-11-09 10:52:43
DTC Client socket (11) | Connecting to IP: 127.0.0.1. | 2017-11-09 10:52:43
DTC Client socket (11) | Connect event error. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2017-11-09 10:52:52 *
DTC Client socket (11) | Initiating close of socket by core. | 2017-11-09 10:52:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-09 10:52:52
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 10:52:52
DTC Client socket (11) | Closed. | 2017-11-09 10:52:52
Rithmic Trading | Disconnected. | 2017-11-09 10:52:52
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 10:52:52
Rithmic Trading | Port for executable: 55258 | 2017-11-09 10:52:54
Listening socket (1484). Port 55258 | Closed. | 2017-11-09 10:52:54
Rithmic Trading | Starting server: D:\sierra\Rim\DTCBridge.exe | 2017-11-09 10:52:54
Rithmic Trading | Bridge process is running. | 2017-11-09 10:52:56
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55258 | 2017-11-09 10:52:56
DTC Client socket (12) | Creating socket. | 2017-11-09 10:52:56
DTC Client socket (12) | Connecting to IP: 127.0.0.1. | 2017-11-09 10:52:56
DTC Client socket (12) | Connect event error. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2017-11-09 10:53:05 *
DTC Client socket (12) | Initiating close of socket by core. | 2017-11-09 10:53:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-09 10:53:05
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 10:53:05
DTC Client socket (12) | Closed. | 2017-11-09 10:53:05
Rithmic Trading | Disconnected. | 2017-11-09 10:53:05
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 10:53:05
[2017-11-09 10:04:18]
This is the relevant message:
Are you running any firewall or other security software on your computer, other than the Windows firewall?
Date Time Of Last Edit: 2017-11-09 10:04:36
[2017-11-09 10:14:33]
hi thanks for helping, i just run it as administrator to avoid firewall
Here is what I got
Reading Internal Order ID file. | 2017-11-09 11:12:35
Reading Trade Orders file. | 2017-11-09 11:12:35
Reading Trade Positions file. | 2017-11-09 11:12:35
Listening on UDP port 22903. | 2017-11-09 11:12:35
Software version: 1640 | 2017-11-09 11:12:35
Usage end date: 2018-09-26 | 2017-11-09 11:12:35
Enabled for: Advanced Features. | 2017-11-09 11:12:35
Enabled for: Advanced Features 2. | 2017-11-09 11:12:35
Enabled for: Sierra Chart Historical Data Service. | 2017-11-09 11:12:35
Allow Support for Sierra Chart Data Feeds is enabled. | 2017-11-09 11:12:35
Current selected Data/Trading service: Rithmic Trading | 2017-11-09 11:12:35
Chart Update Interval: 500 | 2017-11-09 11:12:35
Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2017-11-09 11:12:35
2017-11-09 11:12:39 Local computer time | 2017-11-09 11:12:35
2017-11-09 10:12:39 Local computer time in UTC | 2017-11-09 11:12:35
2017-11-09 11:12:39 Local computer time in SC Time Zone | 2017-11-09 11:12:35
2017-11-09 10:12:37 Server time in UTC | 2017-11-09 11:12:35
Local computer UTC time and Server UTC time difference: 1 seconds. | 2017-11-09 11:12:35
Program path: D:\sierra\ | 2017-11-09 11:12:35
Data Files path: D:\sierra\Data\ | 2017-11-09 11:12:35
OS Version Number: 10.0 | 2017-11-09 11:12:35
Locale Setting: C | 2017-11-09 11:12:35
Created the DTC Protocol server. | 2017-11-09 11:12:35
DTC Protocol Server listening on port 11099. | 2017-11-09 11:12:35
Created the DTC Protocol historical data server. | 2017-11-09 11:12:35
HD Server Manager | Listening on port 11098 | 2017-11-09 11:12:35
Checking for new symbol settings for service code rim | 2017-11-09 11:12:35
HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-11-09 11:12:35
HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2017-11-09 11:12:35
Symbol settings are up-to-date for rim | 2017-11-09 11:12:40
Received 5 login tokens. | 2017-11-09 11:12:40
HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2017-11-09 11:12:41
HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2017-11-09 11:12:41
HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2017-11-09 11:12:45
HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-11-09 11:12:45
HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2017-11-09 11:12:45
HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-09 11:12:45
HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-11-09 11:12:45
HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2017-11-09 11:12:45
HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2017-11-09 11:12:45
HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2017-11-09 11:12:45
HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-09 11:12:45
HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2017-11-09 11:12:45
HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2017-11-09 11:12:46
HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2017-11-09 11:12:46
HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2017-11-09 11:12:46
HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-09 11:12:46
HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2017-11-09 11:12:46
Files to Open on Start up | Opening file: PierreTest.cht | 2017-11-09 11:12:47
DYZ17 3 Min #3 | Reloading chart. | 2017-11-09 11:12:47
DXZ17 1 Min #1 | Reloading chart. | 2017-11-09 11:12:47
EURUSD [CBV] 5 Min #5 | Reloading chart. | 2017-11-09 11:12:47
EURUSD [CBV] 5 Min #5 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2017-11-09 11:12:47
EURUSD [CBV] 5 Min #5 | There are no continuous futures contract symbols. Loading data normally. | 2017-11-09 11:12:47
EURUSD 1 Min #2 | Reloading chart. | 2017-11-09 11:12:47
ESU17 30 Min #4 | Reloading chart. | 2017-11-09 11:12:47
ESU17 Rev. 4t #6 | Reloading chart. | 2017-11-09 11:12:47
Files to Open on Start up | Opening file: Formation paris.cht | 2017-11-09 11:12:47
AUDUSD [CBV] 30 Min #2 | Reloading chart. | 2017-11-09 11:12:47
AUDUSD [CBV] 30 Min #2 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2017-11-09 11:12:47
AUDUSD [CBV] 30 Min #2 | There are no continuous futures contract symbols. Loading data normally. | 2017-11-09 11:12:47
AUDUSD [CBV] Daily #3 | Reloading chart. | 2017-11-09 11:12:47
AUDUSD [CBV] Daily #3 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2017-11-09 11:12:47
AUDUSD [CBV] Daily #3 | There are no continuous futures contract symbols. Loading data normally. | 2017-11-09 11:12:47
AUDUSD [CBV] #4 | Reloading chart. | 2017-11-09 11:12:47
AUDUSD [CBV] #4 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2017-11-09 11:12:47
AUDUSD [CBV] #4 | There are no continuous futures contract symbols. Loading data normally. | 2017-11-09 11:12:47
AUDUSD Rev. 4t #5 | Reloading chart. | 2017-11-09 11:12:47
AUDUSD 3 Min #6 | Reloading chart. | 2017-11-09 11:12:47
AUDUSD 3 Min #1 | Reloading chart. | 2017-11-09 11:12:47
AUDUSD 30 Min #7 | Reloading chart. | 2017-11-09 11:12:47
AUDUSD [CBV] 30 Min #8 | Reloading chart. | 2017-11-09 11:12:47
AUDUSD [CBV] 30 Min #8 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2017-11-09 11:12:47
AUDUSD [CBV] 30 Min #8 | There are no continuous futures contract symbols. Loading data normally. | 2017-11-09 11:12:47
Using Bid/Ask average for last trade price for EURUSD | 2017-11-09 11:12:50
Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2017-11-09 11:12:50
HD Request # 2 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2017-11-09 11:12:50
HD Request # 2 | Download start date-time: 2017-11-09 10:52:06.000 | 2017-11-09 11:12:50
HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2017-11-09 11:12:50
Socket (6) | Creating socket. | 2017-11-09 11:12:50
Socket (6) | Connecting to IP: 192.81.56.146. | 2017-11-09 11:12:50
Using Bid/Ask average for last trade price for AUDUSD | 2017-11-09 11:12:50
Intraday data recording state for symbol AUDUSD is set to download 'Pending'. | 2017-11-09 11:12:50
HD Request # 2 | Setting DTC encoding to Binary VLS | 2017-11-09 11:12:50
HD Request # 2 | Sending historical data logon request message. | 2017-11-09 11:12:50
Rithmic Trading | Port for executable: 55797 | 2017-11-09 11:12:50
Listening socket (1376). Port 55797 | Closed. | 2017-11-09 11:12:50
Rithmic Trading | Starting server: D:\sierra\Rim\DTCBridge.exe | 2017-11-09 11:12:50
HD Request # 2 | Requesting Intraday data. Start date-time: 2017-11-09 10:52:06. Record interval: 0. Symbol: EURUSD | 2017-11-09 11:12:51
HD Request # 2 | Decompressing data. | 2017-11-09 11:12:51
HD Request # 2 | Receiving Intraday data for EURUSD starting at 2017-11-09 10:52:06 | 2017-11-09 11:12:51
HD Request # 2 | Timestamp of first Intraday data file record written: 2017-11-09 10:52:13 | 2017-11-09 11:12:51
Socket (6) | Initiating close of socket by core. | 2017-11-09 11:12:51
HD Request # 2 | Historical data for EURUSD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-11-09 11:12:51
Socket (6) | Shutdown started. Waiting for graceful close. | 2017-11-09 11:12:51
Historical data download thread signaled to stop. | 2017-11-09 11:12:51
HD Request # 2 | Received 2701 records from 2017-11-09 10:52:06 to 2017-11-09 11:12:47 (20.7 minutes) and wrote 2699 records for EURUSD | 2017-11-09 11:12:51
HD Request # 2 | Intraday download COMPLETE for EURUSD. Completion time: 1s. Unique request ID: 1 | 2017-11-09 11:12:51
Removed historical data download ID 1 | 2017-11-09 11:12:51
HD Request # 3 | Downloading Intraday chart data for AUDUSD to the file AUDUSD.scid. Service: fxcm | 2017-11-09 11:12:51
HD Request # 3 | Download start date-time: 2017-11-09 10:52:11.000 | 2017-11-09 11:12:51
HD Request # 3 | Using server: ds3.sierracharts.com port 10150 | 2017-11-09 11:12:51
Socket (7) | Creating socket. | 2017-11-09 11:12:51
Socket (7) | Connecting to IP: 65.182.172.42. | 2017-11-09 11:12:51
Socket (6) | Socket gracefully closed by remote side. | 2017-11-09 11:12:51
Socket (6) | Closed. | 2017-11-09 11:12:51
HD Request # 3 | Setting DTC encoding to Binary VLS | 2017-11-09 11:12:51
HD Request # 3 | Sending historical data logon request message. | 2017-11-09 11:12:51
HD Request # 3 | Requesting Intraday data. Start date-time: 2017-11-09 10:52:11. Record interval: 0. Symbol: AUDUSD | 2017-11-09 11:12:51
HD Request # 3 | Decompressing data. | 2017-11-09 11:12:52
HD Request # 3 | Receiving Intraday data for AUDUSD starting at 2017-11-09 10:52:11 | 2017-11-09 11:12:52
HD Request # 3 | Timestamp of first Intraday data file record written: 2017-11-09 10:52:14 | 2017-11-09 11:12:52
Socket (7) | Initiating close of socket by core. | 2017-11-09 11:12:52
HD Request # 3 | Historical data for AUDUSD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-11-09 11:12:52
Socket (7) | Shutdown started. Waiting for graceful close. | 2017-11-09 11:12:52
Historical data download thread signaled to stop. | 2017-11-09 11:12:52
HD Request # 3 | Received 1774 records from 2017-11-09 10:52:11 to 2017-11-09 11:12:49 (20.6 minutes) and wrote 1773 records for AUDUSD | 2017-11-09 11:12:52
HD Request # 3 | Intraday download COMPLETE for AUDUSD. Completion time: 0s. Unique request ID: 2 | 2017-11-09 11:12:52
Removed historical data download ID 2 | 2017-11-09 11:12:52
HD Request # 4 | Downloading Historical Daily chart data for AUDUSD. Starting date: 2017-11-08. Service: fxcm | 2017-11-09 11:12:52
HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2017-11-09 11:12:52
Socket (8) | Creating socket. | 2017-11-09 11:12:52
Socket (8) | Connecting to IP: 192.81.56.146. | 2017-11-09 11:12:52
Socket (7) | Socket gracefully closed by remote side. | 2017-11-09 11:12:52
Socket (7) | Closed. | 2017-11-09 11:12:52
HD Request # 4 | Setting DTC encoding to Binary VLS | 2017-11-09 11:12:52
HD Request # 4 | Sending historical data logon request message. | 2017-11-09 11:12:52
HD Request # 4 | Requesting historical Daily data starting at 2017-11-08. | 2017-11-09 11:12:52
HD Request # 4 | Decompressing data. | 2017-11-09 11:12:52
HD Request # 4 | Receiving historical Daily data for AUDUSD starting at 2017-11-08 | 2017-11-09 11:12:52
HD Request # 4 | Writing historical Daily data to the file AUDUSD.dly | 2017-11-09 11:12:52
Socket (8) | Initiating close of socket by core. | 2017-11-09 11:12:52
Socket (8) | Shutdown started. Waiting for graceful close. | 2017-11-09 11:12:52
HD Request # 4 | Received 2 records from 2017-11-08 00:00:00 to 2017-11-09 00:00:00 (2.0 days) and wrote 2 records for AUDUSD | 2017-11-09 11:12:52
HD Request # 4 | Daily download COMPLETE for AUDUSD. Completion time: 0s. Unique request ID: 3 | 2017-11-09 11:12:52
Removed historical data download ID 3 | 2017-11-09 11:12:52
Socket (8) | Socket gracefully closed by remote side. | 2017-11-09 11:12:52
Socket (8) | Closed. | 2017-11-09 11:12:52
AUDUSD [CBV] [M] Daily #3 | Reloading chart. | 2017-11-09 11:12:53
AUDUSD [CBV] [M] Daily #3 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2017-11-09 11:12:53
AUDUSD [CBV] [M] Daily #3 | There are no continuous futures contract symbols. Loading data normally. | 2017-11-09 11:12:53
Rithmic Trading | Bridge process is running. | 2017-11-09 11:12:53
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55797 | 2017-11-09 11:12:53
DTC Client socket (9) | Creating socket. | 2017-11-09 11:12:53
DTC Client socket (9) | Connecting to IP: 127.0.0.1. | 2017-11-09 11:12:53
DTC Client socket (9) | Connect event error. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2017-11-09 11:13:03 *
DTC Client socket (9) | Initiating close of socket by core. | 2017-11-09 11:13:03
DTC Client socket (9) | Closed. | 2017-11-09 11:13:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-09 11:13:03
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 11:13:03
Rithmic Trading | Disconnected. | 2017-11-09 11:13:03
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 11:13:03
Rithmic Trading | Port for executable: 55801 | 2017-11-09 11:13:05
Listening socket (1492). Port 55801 | Closed. | 2017-11-09 11:13:05
Rithmic Trading | Starting server: D:\sierra\Rim\DTCBridge.exe | 2017-11-09 11:13:05
Rithmic Trading | Bridge process is running. | 2017-11-09 11:13:07
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55801 | 2017-11-09 11:13:07
DTC Client socket (10) | Creating socket. | 2017-11-09 11:13:07
DTC Client socket (10) | Connecting to IP: 127.0.0.1. | 2017-11-09 11:13:07
DTC Client socket (10) | Connect event error. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2017-11-09 11:13:16 *
DTC Client socket (10) | Initiating close of socket by core. | 2017-11-09 11:13:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-09 11:13:16
DTC Client socket (10) | Closed. | 2017-11-09 11:13:16
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 11:13:16
Rithmic Trading | Disconnected. | 2017-11-09 11:13:16
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 11:13:16
Rithmic Trading | Port for executable: 55805 | 2017-11-09 11:13:18
Listening socket (1348). Port 55805 | Closed. | 2017-11-09 11:13:18
Rithmic Trading | Starting server: D:\sierra\Rim\DTCBridge.exe | 2017-11-09 11:13:18
Rithmic Trading | Bridge process is running. | 2017-11-09 11:13:20
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55805 | 2017-11-09 11:13:20
DTC Client socket (11) | Creating socket. | 2017-11-09 11:13:20
DTC Client socket (11) | Connecting to IP: 127.0.0.1. | 2017-11-09 11:13:20
DTC Client socket (11) | Connect event error. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2017-11-09 11:13:29 *
DTC Client socket (11) | Initiating close of socket by core. | 2017-11-09 11:13:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-09 11:13:29
DTC Client socket (11) | Closed. | 2017-11-09 11:13:29
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 11:13:29
Rithmic Trading | Disconnected. | 2017-11-09 11:13:29
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 11:13:29
Rithmic Trading | Port for executable: 55810 | 2017-11-09 11:13:31
Listening socket (1348). Port 55810 | Closed. | 2017-11-09 11:13:31
Rithmic Trading | Starting server: D:\sierra\Rim\DTCBridge.exe | 2017-11-09 11:13:31
Rithmic Trading | Bridge process is running. | 2017-11-09 11:13:33
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55810 | 2017-11-09 11:13:33
DTC Client socket (12) | Creating socket. | 2017-11-09 11:13:33
DTC Client socket (12) | Connecting to IP: 127.0.0.1. | 2017-11-09 11:13:33
DTC Client socket (12) | Connect event error. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2017-11-09 11:13:42 *
DTC Client socket (12) | Initiating close of socket by core. | 2017-11-09 11:13:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-09 11:13:42
DTC Client socket (12) | Closed. | 2017-11-09 11:13:42
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 11:13:42
Rithmic Trading | Disconnected. | 2017-11-09 11:13:42
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 11:13:42
Rithmic Trading | Port for executable: 55813 | 2017-11-09 11:13:44
Listening socket (1496). Port 55813 | Closed. | 2017-11-09 11:13:44
Rithmic Trading | Starting server: D:\sierra\Rim\DTCBridge.exe | 2017-11-09 11:13:44
Rithmic Trading | Bridge process is running. | 2017-11-09 11:13:46
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55813 | 2017-11-09 11:13:46
DTC Client socket (13) | Creating socket. | 2017-11-09 11:13:46
DTC Client socket (13) | Connecting to IP: 127.0.0.1. | 2017-11-09 11:13:46
DTC Client socket (13) | Connect event error. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2017-11-09 11:13:55 *
DTC Client socket (13) | Initiating close of socket by core. | 2017-11-09 11:13:55
DTC Client socket (13) | Closed. | 2017-11-09 11:13:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-09 11:13:55
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 11:13:55
Rithmic Trading | Disconnected. | 2017-11-09 11:13:55
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-09 11:13:55
Rithmic Trading | Port for executable: 55815 | 2017-11-09 11:13:57
Listening socket (1432). Port 55815 | Closed. | 2017-11-09 11:13:57
Rithmic Trading | Starting server: D:\sierra\Rim\DTCBridge.exe | 2017-11-09 11:13:57
[2017-11-09 20:44:15]
We apologize for the delay. Do you really have to use Rithmic? Who is your broker?
There is nothing we can do from our side in regards to this connection problem. Clearly there is some Security software on your system blocking the connection.
Connecting to Rithmic is more complicated than other services. Have a look at CQG and CTS:
Supported Data and Trading Services
[2017-11-10 18:02:39]
Thank you. We were able to connect to RTrader with the same login credentials on the same computer Sierra is on. For some reason, we cannot connect to Rithmic on Sierra Chart. Any ideas?
[2017-11-10 18:53:36]
Yes we can see the reason and we have already provided you all the information we can.
This is one reason why we do not favor Rithmic. Connections can be troublesome.
Who is your Futures broker?
Date Time Of Last Edit: 2017-11-10 18:53:45
