Date/Time: Thu, 16 Jan 2025 12:08:17 +0000
Futures options data from SC Data using CQG DTS
View Count: 1056
[2017-10-30 22:56:42]
Usermb - Posts: 126
Using 1631
DTS: CQG FIX
Is there any way i could get Options data from SC Data when connected to the CQG trading service?
I am looking for the [M] I know from futures, which I do not see for Options.
Just in case this doesn't work, is there any trading service that works well with your real time options data feed?
Is there any way I could use the DOM for an option on CL futures (say C.US.CLEZ175400) with your SC Data real time feed and trade from it (DOM) through CQG?
[2017-10-31 05:10:56]
You can get the futures options data but you cannot trade using those same symbols.
Just follow through the instructions here:
Futures Options Now Available with Sierra Chart Exchange Data Feed! | Post: 128596
[2017-10-31 12:35:31]
Usermb - Posts: 126
Can I have two different chart windows in the same Chartbook, for two different Option Symbols as follows:
- one SC Data Symbol for real time data through your service (say "LOZ17 C5400.FUT_OPT.NYMEX")
- the other with the equivalent CQG Symbol for trading that Option (say "C.US.CLEZ175400")
[2017-10-31 18:18:20]
Yes of course this is no problem at all.
[2017-11-03 16:52:10]
Usermb - Posts: 126
I have just tried opening an intraday Window for "LOZ17 C5400.FUT_OPT.NYMEX" while connected to CQG, it doesn't work: "Symbol is unknown", "Download failed".
It is correct, in post #3 I did not ask whether it works when connected to CQG, but a connection to CQG is required for trading the options, so here's my try at asking what I meant: is there any way to get your real time and/or historical data for Options (on futures) while connected to CQG (or any other DTS than SC Data)? This is possible for futures and I'm very happy with it ([M]).
I'm not necessarily looking for "[M]" (although that would be lovely), a two chart windows solutions would do it as well.
[2017-11-03 17:17:57]
Yes. And we just realized that we did not add the necessary Symbol Settings for this. This is done now.
After that, follow the instructions in this post here:
We are also in the process of moving options to a different server. Update Sierra Chart to the current version following the instructions here:
This is essential.
Date Time Of Last Edit: 2017-11-03 17:19:18
[2017-11-03 17:29:18]
Usermb - Posts: 126
Wonderful, it works like a charm, thank you so very much.
