Date/Time: Thu, 16 Jan 2025 10:02:36 +0000
Charts linked, but scroll position doesnt work
View Count: 971
[2017-10-28 23:34:42] |
User578163 - Posts: 8 |
Hello, I installed SierraChart on mac OS and tried this via Wine and via Parallels... I have two charts linked (1) and "Scroll position" checked but it doesn't work. My scroll position doesn't change in both charts. ... Everything works fine on my Windows computer, but since I want to use mac OS from now on, I would like to solve this problem. Could you please help me? See screenshot here: https://prnt.sc/h3b3x6 Thank you |
Snímek obrazovky 2017-10-29 v 1.32.56.png / V - Attached On 2017-10-28 23:33:24 UTC - Size: 178.76 KB - 268 views |
[2017-10-30 18:47:30] |
We did a test now and we do not see a problem with this. Make sure Scroll Position is enabled on both charts. If you still have a problem we suspect it is an issue related to using WINE. But looking at the screenshot you provided, it sounds like you might be interested in using Tools >>Synchronize Charts instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
