Date/Time: Thu, 16 Jan 2025 05:00:15 +0000
No historical data
View Count: 1201
[2017-10-10 16:55:51]
User023822 - Posts: 15
Hi, When I open up a chartbook I am missing the current day's intraday data. Also as charts finish loading I get the message 'Download failed'. It appears to only affect newer versions of Sierra Chart i.e if I rollback to version 1568, everything works fine. This has been a problem for some weeks.
Data through AMP.
I've attached a screen shot and log files (I think). http://www.sierrachart.com/image.php?Image=1507654446625.png
Thank you.
Private File
Private File
[2017-10-10 17:25:14]
Refer to this section here for this:
http://www.sierrachart.com/index.php?page=doc/HistoricalIntradayData.html#ErrorDownloadingDataSCHistoricalDataServer
Based on this, a firewall on your computer is causing the problem.
[2017-10-10 17:37:01]
I have a working connection and data is coming through, just no data prior to switching on. If it is the firewall, which specific part of Sierra Chart should I add to the list. The firewall is just standard Windows Defender on Windows 10.
[2017-10-10 17:44:02]
I have added Sierra Chart to Windows Defender list of allowed apps but still no data other than live data
[2017-10-10 17:59:26]
Go to the chart and select Edit >>Delete All Data and Download.
After that post a copy of the Message Log following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2017-10-10 18:28:21]
Reading Internal Order ID file. | 2017-10-10 18:44:19
Reading Trade Orders file. | 2017-10-10 18:44:19
Reading Trade Positions file. | 2017-10-10 18:44:19
Listening on UDP port 22903. | 2017-10-10 18:44:19
Software version: 1621 | 2017-10-10 18:44:19
Enabled for: Advanced Features. | 2017-10-10 18:44:19
Enabled for: Sierra Chart Historical Data Service. | 2017-10-10 18:44:19
Allow Support for Sierra Chart Data Feeds is enabled. | 2017-10-10 18:44:19
Current selected Data/Trading service: CQG FIX Trading | 2017-10-10 18:44:19
Chart Update Interval: 500 | 2017-10-10 18:44:19
Data/Trade Service Settings automatically set. | 2017-10-10 18:44:19
Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2017-10-10 18:44:19
2017-10-10 18:44:27 Local computer time | 2017-10-10 18:44:19
2017-10-10 17:44:27 Local computer time in UTC | 2017-10-10 18:44:19
2017-10-10 18:44:27 Local computer time in SC Time Zone | 2017-10-10 18:44:19
2017-10-10 17:44:22 Server time in UTC | 2017-10-10 18:44:19
Local computer UTC time and Server UTC time difference: 0 seconds. | 2017-10-10 18:44:19
Program path: C:\SierraChart\ | 2017-10-10 18:44:19
Data Files path: C:\SierraChart\Data\ | 2017-10-10 18:44:19
OS Version Number: 10.0 | 2017-10-10 18:44:19
Locale Setting: C | 2017-10-10 18:44:19
Checking for new symbol settings for service code cqg | 2017-10-10 18:44:19
HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-10-10 18:44:19
HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2017-10-10 18:44:19
Symbol settings are up-to-date for cqg | 2017-10-10 18:44:28
Received 5 login tokens. | 2017-10-10 18:44:28
HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2017-10-10 18:44:29
HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2017-10-10 18:44:29
HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2017-10-10 18:44:33
HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-10-10 18:44:33
HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2017-10-10 18:44:33
HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-10 18:44:33
HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-10-10 18:44:33
HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2017-10-10 18:44:33
HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2017-10-10 18:44:33
HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2017-10-10 18:44:33
HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-10 18:44:33
HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2017-10-10 18:44:33
HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2017-10-10 18:44:34
HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2017-10-10 18:44:34
HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2017-10-10 18:44:34
HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-10 18:44:34
HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2017-10-10 18:44:34
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-10-10 18:44:37
CQG FIX socket (6) | Creating socket. Using TLS 1.2. | 2017-10-10 18:44:38
CQG FIX socket (6) | Connecting to IP: 208.48.16.214. | 2017-10-10 18:44:38
CQG FIX: Sending the Logon message. | 2017-10-10 18:44:38
CQG FIX Trading | Connected to trading server. | 2017-10-10 18:44:39
CQG FIX Trading | Connecting to server api.cqg.com | 2017-10-10 18:44:39
CQG WebSocket | Connecting to WebSocket server. | 2017-10-10 18:44:39
CQG WebSocket socket (7) | Creating socket. Using TLS 1.2. | 2017-10-10 18:44:39
CQG WebSocket socket (7) | Connecting to IP: 195.166.124.165. | 2017-10-10 18:44:39
CQG FIX | FCM name: AMP | 2017-10-10 18:44:39
CQG WebSocket | Opening WebSocket. | 2017-10-10 18:44:39
CQG WebSocket | Sending WebSocket handshake. | 2017-10-10 18:44:39
CQG WebSocket | Received WebSocket handshake acknowledgment. | 2017-10-10 18:44:39
CQG WebSocket | Web socket state is now open. | 2017-10-10 18:44:39
CQG FIX Trading | WebSocket connected. | 2017-10-10 18:44:39
CQG FIX Trading | Sending market data logon message. | 2017-10-10 18:44:39
CQG FIX Trading | Logon successful. Session Token = Rkn8FgY+DKTgxLc+MLd0KSMBQJpxHQXPrOKUXtqR/Css9yu2ZSDWEE9yCXMR9Nf3U9EW0COvQL+ | 2017-10-10 18:44:39
CQG FIX Trading | Connected to data and trading server. | 2017-10-10 18:44:39
F.US.CLEX17 [CBV] 60 Min #9 | Reloading chart. | 2017-10-10 18:44:46
F.US.CLEX17 [CBV] 60 Min #9 | Performing historical Daily data download for symbol CLX17 starting at last date in file. | 2017-10-10 18:44:46
F.US.CLEX17 [CBV] 60 Min #9 | Waiting for historical downloads to complete with the IDs: 1, | 2017-10-10 18:44:46
F.US.CLEX17 [CB] 1 Day #4 | Reloading chart. | 2017-10-10 18:44:46
F.US.CLEX17 [CB] 1 Day #4 | Waiting for historical downloads to complete with the IDs: 1, | 2017-10-10 18:44:46
F.US.CLEX17 [CV] 20 Sec #1 | Reloading chart. | 2017-10-10 18:44:46
F.US.CLEX17 [CV] 20 Sec #1 | Waiting for historical downloads to complete with the IDs: 1, | 2017-10-10 18:44:46
F.US.CLEX17 [CBV] 5 Min #3 | Reloading chart. | 2017-10-10 18:44:46
F.US.CLEX17 [CBV] 5 Min #3 | Waiting for historical downloads to complete with the IDs: 1, | 2017-10-10 18:44:46
F.US.CLEX17 [CBV] 5 Min #6 | Reloading chart. | 2017-10-10 18:44:46
F.US.CLEX17 [CBV] 5 Min #6 | Waiting for historical downloads to complete with the IDs: 1, | 2017-10-10 18:44:46
F.US.CLEX17 [CV] 1 Min #7 | Reloading chart. | 2017-10-10 18:44:46
F.US.CLEX17 [CV] 1 Min #7 | Waiting for historical downloads to complete with the IDs: 1, | 2017-10-10 18:44:46
F.US.CLEX17 [CV] 1 Min #5 | Reloading chart. | 2017-10-10 18:44:46
F.US.CLEX17 [CV] 1 Min #5 | Waiting for historical downloads to complete with the IDs: 1, | 2017-10-10 18:44:46
F.US.CLEX17 [CBV] 5 Min #8 | Reloading chart. | 2017-10-10 18:44:46
F.US.CLEX17 [CBV] 5 Min #8 | Waiting for historical downloads to complete with the IDs: 1, | 2017-10-10 18:44:46
HD Request # 2 | Downloading Historical Daily chart data for CLX17. Starting date: 2017-10-06. Service: cqgfix | 2017-10-10 18:44:46
HD Request # 2 | Requesting historical Daily data for CLX17 starting at 2017-10-05 | 2017-10-10 18:44:46
HTTP connection to ds01.ddfplus.com:80 (8) | Creating socket. | 2017-10-10 18:44:46
HTTP connection to ds01.ddfplus.com:80 (8) | Connecting to IP: 8.18.161.123. | 2017-10-10 18:44:46
HD Request # 2 | Receiving historical Daily data for CLX17 starting at 2017-10-06 | 2017-10-10 18:44:47
HD Request # 2 | Writing historical Daily data to the file CLX17.dly | 2017-10-10 18:44:47
HD Request # 2 | Received 4 records from 2017-10-06 00:00:00 to 2017-10-10 00:00:00 (5.0 days) and wrote 3 records for CLX17 | 2017-10-10 18:44:47
HD Request # 2 | Daily download COMPLETE for CLX17. Completion time: 1s. Unique request ID: 1 | 2017-10-10 18:44:47
Removed historical data download ID 1 | 2017-10-10 18:44:47
F.US.CLEX17 [CBV] 60 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-10-10 18:44:47
F.US.CLEX17 [CBV] 60 Min #9 | Reloading chart. | 2017-10-10 18:44:47
F.US.CLEX17 [CBV] 5 Min #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-10-10 18:44:47
F.US.CLEX17 [CBV] 5 Min #6 | Reloading chart. | 2017-10-10 18:44:47
F.US.CLEX17 [CB] 1 Day #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-10-10 18:44:47
F.US.CLEX17 [CB] 1 Day #4 | Reloading chart. | 2017-10-10 18:44:47
F.US.CLEX17 [CV] 1 Min #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-10-10 18:44:47
F.US.CLEX17 [CV] 1 Min #7 | Reloading chart. | 2017-10-10 18:44:47
F.US.CLEX17 [CV] 1 Min #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-10-10 18:44:47
F.US.CLEX17 [CV] 1 Min #5 | Reloading chart. | 2017-10-10 18:44:47
F.US.CLEX17 [CBV] 5 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-10-10 18:44:47
F.US.CLEX17 [CBV] 5 Min #8 | Reloading chart. | 2017-10-10 18:44:47
F.US.CLEX17 [CV] 20 Sec #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-10-10 18:44:47
F.US.CLEX17 [CV] 20 Sec #1 | Reloading chart. | 2017-10-10 18:44:47
F.US.CLEX17 [CBV] 5 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-10-10 18:44:47
F.US.CLEX17 [CBV] 5 Min #3 | Reloading chart. | 2017-10-10 18:44:47
F.US.CLEX17 [CBV] 5 Min #6 | Reloading chart. | 2017-10-10 18:44:48
F.US.CLEX17 [CB] 1 Day #4 | Reloading chart. | 2017-10-10 18:44:48
F.US.CLEX17 [CV] 1 Min #7 | Reloading chart. | 2017-10-10 18:44:48
F.US.CLEX17 [CV] 1 Min #5 | Reloading chart. | 2017-10-10 18:44:48
F.US.CLEX17 [CBV] 5 Min #8 | Reloading chart. | 2017-10-10 18:44:48
F.US.CLEX17 [CV] 20 Sec #1 | Reloading chart. | 2017-10-10 18:44:49
F.US.CLEX17 [CBV] 5 Min #3 | Reloading chart. | 2017-10-10 18:44:49
CQG FIX Trading | Starting real-time market data updates for: F.US.CLEX17. ID: 2 | 2017-10-10 18:44:49
CQG FIX Trading | Sending symbol resolution request for F.US.CLEX17. ID: 482360 | 2017-10-10 18:44:49
CQG FIX Trading | Requesting security definition data for: F.US.CLEX17. ID: 2 | 2017-10-10 18:44:49
Intraday data recording state for symbol F.US.CLEX17 is set to download 'Pending'. | 2017-10-10 18:44:49
Delaying start of download for F.US.CLEX17 | 2017-10-10 18:44:49
CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEX7. Search Symbol: F.US.CLEX17. Request ID: 482360. Contract ID: 1. | 2017-10-10 18:44:49
CQG FIX Trading | Requesting market data for F.US.CLEX17 | 2017-10-10 18:44:49
Requesting market depth updates for: F.US.CLEX17 if supported. | 2017-10-10 18:44:49
CQG FIX Trading | Requesting market data including full depth for F.US.CLEX17 | 2017-10-10 18:44:49
F.US.CLEX17 [CBV] 5 Min #6 | Reloading chart. | 2017-10-10 18:44:50
Delaying start of download for F.US.CLEX17 | 2017-10-10 18:44:50
F.US.CLEX17 [CV] 1 Min #7 | Reloading chart. | 2017-10-10 18:44:50
F.US.CLEX17 [CBV] 5 Min #3 | Reloading chart. | 2017-10-10 18:44:51
HD Request # 3 | Downloading Intraday chart data for F.US.CLEX17 to the file F.US.CLEX17.scid. Service: cqgfix | 2017-10-10 18:44:54
HD Request # 3 | Download start date-time: 2017-10-09 17:56:34.000 | 2017-10-10 18:44:54
HD Request # 3 | Using server: ds4.sierracharts.com port 10149 | 2017-10-10 18:44:54
Socket (9) | Creating socket. | 2017-10-10 18:44:54
Socket (9) | Connecting to IP: 192.81.56.146. | 2017-10-10 18:44:54
HD Request # 3 | Setting DTC encoding to Binary VLS | 2017-10-10 18:44:54
HD Request # 3 | Sending historical data logon request message. | 2017-10-10 18:44:54
Socket (9) | Initiating close of socket by core. | 2017-10-10 18:44:54
HD Request # 3 | Error downloading historical Intraday data for F.US.CLEX17. Historical data logon error: Data files folder not set for service code: cqgfix | 2017-10-10 18:44:54
Socket (9) | Shutdown started. Waiting for graceful close. | 2017-10-10 18:44:54
Historical data download thread signaled to stop. | 2017-10-10 18:44:54
HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.CLEX17 | 2017-10-10 18:44:54
HD Request # 3 | Receiving Intraday data for F.US.CLEX17 starting at 2017-10-10 18:44:48 | 2017-10-10 18:44:54
HD Request # 3 | Timestamp of first Intraday data file record written: 2017-10-10 18:44:48 | 2017-10-10 18:44:54
Added 15 Time and Sales records to Intraday data file for F.US.CLEX17 after download. | 2017-10-10 18:44:54
HD Request # 3 | Intraday download COMPLETE for F.US.CLEX17. Completion time: 0s. Unique request ID: 2 | 2017-10-10 18:44:54
Removed historical data download ID 2 | 2017-10-10 18:44:54
Real-time Intraday chart data file updates started for F.US.CLEX17 | 2017-10-10 18:44:54
Intraday chart data file opened for F.US.CLEX17 | 2017-10-10 18:44:54
Socket (9) | Socket gracefully closed by remote side. | 2017-10-10 18:44:55
Socket (9) | Closed. | 2017-10-10 18:44:55
Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEX17.scid | 2017-10-10 18:45:07
HTTP connection to ds01.ddfplus.com:80 (8) | Socket gracefully closed by remote side. | 2017-10-10 18:45:52
HTTP connection to ds01.ddfplus.com:80 (8) | Received socket Close event. | 2017-10-10 18:45:52
HTTP connection to ds01.ddfplus.com:80 (8) | Initiating close of socket by core. | 2017-10-10 18:45:52
HTTP connection to ds01.ddfplus.com:80 (8) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-10 18:45:52
HTTP connection to ds01.ddfplus.com:80 (8) | Closed. | 2017-10-10 18:45:52
Intraday data recording state for symbol F.US.CLEX17 is set to download 'Pending'. | 2017-10-10 19:26:30
Reloading all charts with filename: F.US.CLEX17.scid | 2017-10-10 19:26:30
HD Request # 4 | Downloading Intraday chart data for F.US.CLEX17 to the file F.US.CLEX17.scid. Service: cqgfix | 2017-10-10 19:26:30
HD Request # 4 | Download start date-time: 2017-09-10 01:00:00.000 | 2017-10-10 19:26:30
HD Request # 4 | Using server: ds3.sierracharts.com port 10150 | 2017-10-10 19:26:30
Socket (24) | Creating socket. | 2017-10-10 19:26:30
Socket (24) | Connecting to IP: 65.182.172.42. | 2017-10-10 19:26:30
HD Request # 4 | Setting DTC encoding to Binary VLS | 2017-10-10 19:26:30
HD Request # 4 | Sending historical data logon request message. | 2017-10-10 19:26:30
F.US.CLEX17 [CBV] 60 Min #9 | Reloading chart. | 2017-10-10 19:26:30
F.US.CLEX17 [CBV] 60 Min #9 | Waiting for historical downloads to complete with the IDs: 3, | 2017-10-10 19:26:30
F.US.CLEX17 [CV] 1 Min #5 | Reloading chart. | 2017-10-10 19:26:30
F.US.CLEX17 [CV] 1 Min #5 | Waiting for historical downloads to complete with the IDs: 3, | 2017-10-10 19:26:30
F.US.CLEX17 [CV] 1 Min #7 | Reloading chart. | 2017-10-10 19:26:30
F.US.CLEX17 [CV] 1 Min #7 | Waiting for historical downloads to complete with the IDs: 3, | 2017-10-10 19:26:30
Socket (24) | Initiating close of socket by core. | 2017-10-10 19:26:30
Socket (24) | Shutdown started. Waiting for graceful close. | 2017-10-10 19:26:30
F.US.CLEX17 [CBV] 5 Min #6 | Reloading chart. | 2017-10-10 19:26:30
F.US.CLEX17 [CBV] 5 Min #6 | Waiting for historical downloads to complete with the IDs: 3, | 2017-10-10 19:26:30
HD Request # 4 | Error downloading historical Intraday data for F.US.CLEX17. Historical data logon error: Data files folder not set for service code: cqgfix | 2017-10-10 19:26:30
Historical data download thread signaled to stop. | 2017-10-10 19:26:30
HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.CLEX17 | 2017-10-10 19:26:30
HD Request # 4 | Receiving Intraday data for F.US.CLEX17 starting at 2017-10-10 19:24:29 | 2017-10-10 19:26:30
HD Request # 4 | Timestamp of first Intraday data file record written: 2017-10-10 19:24:29 | 2017-10-10 19:26:30
Added 739 Time and Sales records to Intraday data file for F.US.CLEX17 after download. | 2017-10-10 19:26:30
HD Request # 4 | Intraday download COMPLETE for F.US.CLEX17. Completion time: 0s. Unique request ID: 3 | 2017-10-10 19:26:30
Removed historical data download ID 3 | 2017-10-10 19:26:30
Real-time Intraday chart data file updates started for F.US.CLEX17 | 2017-10-10 19:26:30
Intraday chart data file opened for F.US.CLEX17 | 2017-10-10 19:26:30
F.US.CLEX17 [CBV] 5 Min #8 | Reloading chart. | 2017-10-10 19:26:30
F.US.CLEX17 [CBV] 5 Min #8 | Waiting for historical downloads to complete with the IDs: 4, | 2017-10-10 19:26:30
HD Request # 5 | Downloading Intraday chart data for F.US.CLEX17 to the file F.US.CLEX17.scid. Service: cqgfix | 2017-10-10 19:26:30
HD Request # 5 | Download start date-time: 2017-09-04 00:59:59.000 | 2017-10-10 19:26:30
HD Request # 5 | Disabling Intraday chart updating for symbol during historical data download. | 2017-10-10 19:26:30
HD Request # 5 | Using server: ds4.sierracharts.com port 10149 | 2017-10-10 19:26:30
Socket (25) | Creating socket. | 2017-10-10 19:26:30
Socket (25) | Connecting to IP: 192.81.56.146. | 2017-10-10 19:26:30
Socket (24) | Socket gracefully closed by remote side. | 2017-10-10 19:26:30
Socket (24) | Closed. | 2017-10-10 19:26:30
F.US.CLEX17 [CV] 20 Sec #1 | Reloading chart. | 2017-10-10 19:26:30
F.US.CLEX17 [CV] 20 Sec #1 | Waiting for historical downloads to complete with the IDs: 4, | 2017-10-10 19:26:30
F.US.CLEX17 [CB] 1 Day #4 | Reloading chart. | 2017-10-10 19:26:31
F.US.CLEX17 [CB] 1 Day #4 | Waiting for historical downloads to complete with the IDs: 4, | 2017-10-10 19:26:31
F.US.CLEX17 [CBV] 5 Min #3 | Reloading chart. | 2017-10-10 19:26:31
F.US.CLEX17 [CBV] 5 Min #3 | Waiting for historical downloads to complete with the IDs: 4, | 2017-10-10 19:26:31
HD Request # 5 | Setting DTC encoding to Binary VLS | 2017-10-10 19:26:31
HD Request # 5 | Sending historical data logon request message. | 2017-10-10 19:26:31
Socket (25) | Initiating close of socket by core. | 2017-10-10 19:26:31
HD Request # 5 | Error downloading historical Intraday data for F.US.CLEX17. Historical data logon error: Data files folder not set for service code: cqgfix | 2017-10-10 19:26:31
Socket (25) | Shutdown started. Waiting for graceful close. | 2017-10-10 19:26:31
Historical data download thread signaled to stop. | 2017-10-10 19:26:31
HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.CLEX17 | 2017-10-10 19:26:31
HD Request # 5 | Receiving Intraday data for F.US.CLEX17 starting at 2017-10-10 19:26:28 | 2017-10-10 19:26:31
HD Request # 5 | Truncating file to starting date-time of 2017-10-10 19:26:28 | 2017-10-10 19:26:31
HD Request # 5 | Timestamp of first Intraday data file record written: 2017-10-10 19:26:28 | 2017-10-10 19:26:31
Added 7 Time and Sales records to Intraday data file for F.US.CLEX17 after download. | 2017-10-10 19:26:31
HD Request # 5 | Intraday download COMPLETE for F.US.CLEX17. Completion time: 0s. Unique request ID: 4 | 2017-10-10 19:26:31
Removed historical data download ID 4 | 2017-10-10 19:26:31
Real-time Intraday chart data file updates started for F.US.CLEX17 | 2017-10-10 19:26:31
Intraday chart data file opened for F.US.CLEX17 | 2017-10-10 19:26:31
HD Request # 5 | Enabling Intraday chart updating for symbol. | 2017-10-10 19:26:31
HD Request # 5 | Reloading Intraday charts for F.US.CLEX17 | 2017-10-10 19:26:31
Reloading all charts with filename: F.US.CLEX17.scid | 2017-10-10 19:26:31
F.US.CLEX17 [CBV] 60 Min #9 | Reloading chart. | 2017-10-10 19:26:31
Socket (25) | Socket gracefully closed by remote side. | 2017-10-10 19:26:31
Socket (25) | Closed. | 2017-10-10 19:26:31
F.US.CLEX17 [CV] 1 Min #5 | Reloading chart. | 2017-10-10 19:26:31
F.US.CLEX17 [CBV] 5 Min #6 | Reloading chart. | 2017-10-10 19:26:31
F.US.CLEX17 [CV] 1 Min #7 | Reloading chart. | 2017-10-10 19:26:31
F.US.CLEX17 [CBV] 5 Min #8 | Reloading chart. | 2017-10-10 19:26:31
F.US.CLEX17 [CV] 20 Sec #1 | Reloading chart. | 2017-10-10 19:26:31
Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEX17.scid | 2017-10-10 19:26:38
[2017-10-10 18:30:34]
http://www.sierrachart.com/image.php?Image=1507660209303.png
[2017-10-10 21:14:59]
This is the relevant message:
We see what the problem is. This is not due to a firewall.
After that is done re-download the data in the chart again with Edit >>Delete All Data and Download.
Date Time Of Last Edit: 2017-10-10 21:15:37
