Date/Time: Tue, 04 Nov 2025 09:19:30 +0000
mkt stats
View Count: 1193
|   [2017-10-05 14:28:14]     |
| User170575 - Posts: 221 |
                Hi, Regarding the ADR-SP---I cannot seem to get data past 1/4/2016. Is this on my end or does the data just go back that far? If it only goes back so far are there any other options via SC? Thanks, Cy  |
|   [2017-10-05 17:25:28]     |
                The data goes back to 2014-02. Follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2018-01-01 19:14:24]     |
                Hi--I have tried several of these options and cant seem to increase the data on the mkt stat--TICK-NYSE_NASDAQ_NYSEMKT---its seems it will only go back about six months of historical data---i tried increasing the number of days in the chart settings---and then the data/trade settings--intraday storage to 4 seconds--Max Hist increase to 5000 on both just to see--and then I did the delete all data and dn load. I am using IB---but was thinking the mktstats come from SC? I have been able to pull the stats back to 2014--but not now. What am I missing? Thoughts appreciated Cy  |
|   [2018-01-01 20:45:10]     |
                Data for TICK-NYSE_NASDAQ_NYSEMK only does go back to about the middle of 2017. but was thinking the mktstats come from SC? Yes.
                Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-01 20:49:42
