Date/Time: Tue, 26 Nov 2024 06:32:33 +0000
date checkbox in drawing properties
View Count: 872
[2017-09-26 07:45:58]
TradingMarketProfile - Posts: 120
Is it possible for you to add an option in drawing properties : date checkbox
this mean add the date near the price on the line or rectangle
[2017-09-26 18:20:47]
This is supported with the Vertical Line tool:
Chart Drawing Tools: Horizontal Line | Horizontal Ray | Horizonal Line Non-Extended | Vertical Line
You can also use the Chart Values tool to see the Date-Time of the chart bar:
Chart Drawing Tools: Chart Values/Crosshair
You could also manually type the date for a drawing that supports text:
Chart Drawing Tools: Modify Text
[2017-09-27 07:35:12]
User555435 - Posts: 5
Good question, so would it be possible to add the same checkbox for date/time as the vertical line on the horizonal line and extending rectangles?
That would be great stuff!
Date Time Of Last Edit: 2017-09-27 07:36:14
[2017-09-27 17:12:09]
Yes it's that, the same as vertical line but in horizontal line and extending rectangle
i'm sure it's easy for you because already done :)
[2023-12-26 19:35:09]
User676363 - Posts: 72
A date marker is easy when there is only one date, but most tools have several anchor points.
Easy to see why this ticket got left unanswered. It doesn't give a good user story/solution.
Let me try.
What would be nice is if we can add to the Anchors tab on all tools a "show time" option next to each Date/Time anchor.
The show time would then be a drop down with these options:
1. None
2. Top-Left
3. Top-Center
4. Top-Right
5. Center-Left
6. Center-Center
7. Center-Right
8. Bottom-Left
9. Bottom-Center
10. Bottom-Right
Then a second menu (or checkboxes as we have seen in other SierraChart objects) for what to display:
- Date
- Time
- Date and time
This method would work for Forks, Lines, Extended Rectangles, OHLC, Ellipse, etc.
Every tool can have a menu added to the Anchors tab and eventually, we will be able to show the dates and/or times at every anchor point of any object.
Eventually, it would be nice if the text objects could be positioned a bit like the risk/reward tool where we can grab the text and move it left/right/up/down and position it as we wish after it's drawn.
