Date/Time: Tue, 25 Feb 2025 18:52:39 +0000
Price Level Drawing Tool with Text
View Count: 2006
[2017-09-22 18:12:34] |
Clef - Posts: 11 |
Hi, Which drawing tool I should to mark key levels on chart that can be identified with the associated text? For example, I want to draw a line on the chart that indicates price of previous value area high (pVAH) along with such a text. |
[2017-09-23 01:03:26] |
You will want to use the Horizontal Line tool: Chart Drawing Tools: Horizontal Line | Horizontal Ray | Horizonal Line Non-Extended | Vertical Line Although you should look at using the Volume Value Area Lines study for this: Volume Value Area Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-22 20:59:45] |
User900676 - Posts: 57 |
what about price zones? I see people using a price zone tool but this does not seem to be a default tool
[2021-04-23 14:11:56] |
John - SC Support - Posts: 38165 |
If you are asking about price zones where you have a band above and a band below the bars based on calculation, then no, it is not inherently a study in Sierra Chart. But, it can be easily created, as it appears to just be a 5 period Exponential Moving Average of a 5 period Exponential Moving Average and then the bands are offset above and below that value. Refer to the following for the Exponential Moving Average: Moving Average - Exponential And refer to the following for creating bands based on a Standard Deviation: Standard Deviation Bands For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-23 16:11:31] |
I see people using a price zone tool but this does not seem to be a default tool Can you provide us a screenshot of this.
[2021-04-23 16:20:01] |
https://twitter.com/doublewidecap/status/1385580262264688647?s=21 The grey box on this chart for example |
[2021-04-23 18:04:04] |
There are any number of ways that box could be calculated, or drawn. We would need more information on how it is derived.
[2021-04-23 21:22:32] |
How about if it was Based on volume at price?
[2021-04-26 13:55:19] |
It could be the Value Area High and Low from a VbP. Refer to the following: Volume By Price Study: Volume Value Area Also, if you follow the instructions in that section and use the Value Area Lines study, then you could also fill in the area between the lines, as is shown in the image, but following these instructions: Chart Studies: Filling the Area Between Two Study Subgraphs within Same Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
