Date/Time: Tue, 04 Nov 2025 14:58:19 +0000
[User Discussion] - TSSupertrend Stop
View Count: 3359
[2013-04-03 20:19:26]
User6191 - Posts: 6
Is there anyone who can modify the current built-in SuperTrend Stop to permit the selection of a Hull moving average for the stop. Enclosed is the Ninjatrader script that is a little more versatile. Thanks.
attachmentTSSupertrend Stop.txt - Attached On 2013-04-03 20:18:35 UTC - Size: 17.85 KB - 2288 views
[2013-04-04 01:04:59]
M5amhan - Posts: 468
i believe you can
Add these three studies: study subgraph reference, moving average hull, and supertrend stop
Put the study subgraph reference in region 1 and input study 1 & 2 as the mov avg and supertrend
This should do what you are trying to do I believe
You can change settings which you do not want drawn to "do not draw"
Date Time Of Last Edit: 2013-04-04 01:05:39
[2013-04-04 02:48:37]
vegasfoster - Posts: 444
You can get a mod here that let's you use any study for the centerline http://www.bigmiketrading.com/download/sierra_chart/1347-download.html?view
[2013-04-04 15:54:56]
i tried using a color bar based on alert condition, but it wont work because you would have to use both subgraph 1 and 2 and you can only use one for the input data
so i dont think you can change it but you can try asking support about it, they may give you the same answer though
