Date/Time: Tue, 04 Nov 2025 12:18:43 +0000
Dollar Calculator Tool?
View Count: 1281
[2017-08-08 06:11:03]
User585845 - Posts: 17
Does Sierra Chart have a dollar calculator tool or something similar? The dollar calculator tool is used to find the dollar value between two points on the chart. How it works in another software I have used in the past is that you click on the chart where you want the calculator to start and drag to where you want the calculation to be completed. The dollar amount of the chart movement will be calculated from the beginning and end point values and will be displayed in the center of the line.
[2017-08-08 07:20:40]
Use the Chart Calculator Tool:
Chart Drawing Tools: Chart Calculator
You will need to enable the "Currency Value" option in the Chart Calculator drawing tool configuration window.
