Date/Time: Wed, 15 Jan 2025 16:19:18 +0000
low volume node
View Count: 1936
[2017-08-05 23:24:48] |
Yamin2000 - Posts: 31 |
HI i am a supply and demand trader ,and i would like to insert volume profile to my trading strategy to make sure the zone is the correct one. Is it possible to mark low volume node in sierrachart? Does Point of control percentage can show low volume node for me ? |
[2017-08-06 03:24:07] |
i think i found what i am looking for ,its Volume Value Area Lines i am not good in indicators does choosing Volume Value Area Lines in minutes make big difference if i am using tick chart?if its yes can you add time length as tick ? |
[2017-08-07 04:27:12] |
So it sounds as though you require the Volume Value Area Low value? If so, using the Volume Value Area Lines study is fine. You can also use the Volume by Price study for this as well: Volume By Price Study: Calculating and Displaying Developing Point of Control, Value Area High/Low, Volume Weighted Average Price Lines It is not a problem to use it with charts based on Number of Trades Per Bar. if its yes can you add time length as tick ? No, this is not supported.
