Date/Time: Wed, 15 Jan 2025 12:52:13 +0000
SC fails to fetch BitMEX data
View Count: 1036
[2017-07-26 18:36:38] |
JacobMoore - Posts: 7 |
I followed the instructions written on this page: BitMEX Trading Service SC doesn't connect to BitMEX. This is the message log I got: Reading Internal Order ID file. | 2017-07-26 20:17:58 Reading Trade Orders file. | 2017-07-26 20:17:58 Reading Trade Positions file. | 2017-07-26 20:17:58 Listening on UDP port 22903. | 2017-07-26 20:17:58 Software version: 1589 | 2017-07-26 20:17:58 Usage end date: 2017-08-09 | 2017-07-26 20:17:58 Enabled for: Advanced Features. | 2017-07-26 20:17:58 Enabled for: Advanced Features 2. | 2017-07-26 20:17:58 Enabled for: Sierra Chart Historical Data Service. | 2017-07-26 20:17:58 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-07-26 20:17:58 Current selected Data/Trading service: BitMEX (Testnet) | 2017-07-26 20:17:58 Chart Update Interval: 500 | 2017-07-26 20:17:58 Time Zone: +04:00:00 (MSK+04) | 2017-07-26 20:17:58 2017-07-26 19:18:03 Local computer time | 2017-07-26 20:17:58 2017-07-26 16:18:03 Local computer time in UTC | 2017-07-26 20:17:58 2017-07-26 20:18:03 Local computer time in SC Time Zone | 2017-07-26 20:17:58 2017-07-26 16:17:59 Server time in UTC | 2017-07-26 20:17:58 Local computer UTC time and Server UTC time difference: 2 seconds. | 2017-07-26 20:17:58 Program path: C:\SierraChart\ | 2017-07-26 20:17:58 Data Files path: C:\SierraChart\Data\ | 2017-07-26 20:17:58 OS Version Number: 10.0 | 2017-07-26 20:17:58 Locale Setting: C | 2017-07-26 20:17:58 Checking for new symbol settings for service code BitMEX | 2017-07-26 20:17:58 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-07-26 20:17:58 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2017-07-26 20:17:58 Symbol settings are up-to-date for BitMEX | 2017-07-26 20:18:04 BitMEX (Testnet) | Connecting to the server ds3.sierracharts.com. Port 5567 | 2017-07-26 20:18:08 DTC Client (5) | Creating socket. Using TLS 1.2. | 2017-07-26 20:18:08 DTC Client (5) | Connecting to IP: 65.182.172.42. | 2017-07-26 20:18:08 BitMEX (Testnet) | Connected to server. | 2017-07-26 20:18:08 BitMEX (Testnet) | Starting socket receive thread. | 2017-07-26 20:18:08 BitMEX (Testnet) | Sending Encoding Request to server | 2017-07-26 20:18:08 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2017-07-26 20:18:09 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event | 2017-07-26 20:18:09 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-07-26 20:18:09 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-07-26 20:18:09 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-07-26 20:18:09 BitMEX (Testnet) | Setting DTC encoding to Binary VLS | 2017-07-26 20:18:09 BitMEX (Testnet) | Sending logon request message. | 2017-07-26 20:18:09 BitMEX (Testnet) | Received logon response. | 2017-07-26 20:18:09 BitMEX (Testnet) | Server Name: SC DTC Server. | 2017-07-26 20:18:09 BitMEX (Testnet) | Server protocol version: 7. Client protocol version: 7 | 2017-07-26 20:18:09 BitMEX (Testnet) | Connection error: Username or Password is incorrect. | 2017-07-26 20:18:09 DTC Client (5) | Initiating close of socket by core. | 2017-07-26 20:18:09 BitMEX (Testnet) | Disconnected. | 2017-07-26 20:18:09 DTC Client (5) | Shutdown started. Waiting for graceful close. | 2017-07-26 20:18:09 DTC Client (5) | Socket gracefully closed by remote side. | 2017-07-26 20:18:09 DTC Client (5) | Closed. | 2017-07-26 20:18:09 How do I fix this? |
[2017-07-26 22:33:04] |
So to confirm, you did follow step 1 here?: https://www.sierrachart.com/index.php?page=doc/BitMEX_Trading.php#SetupInstructions This is the relevant error message: BitMEX (Testnet) | Connection error: Username or Password is incorrect. | 2017-07-26 20:18:09 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-26 22:54:33] |
Yes. See attached file.
Capture.PNG / V - Attached On 2017-07-26 22:53:32 UTC - Size: 258.87 KB - 286 views |
[2017-07-27 10:41:54] |
Could you double check the username that you entered on the BitMEX site and make sure it matches your Sierra Chart username/Account Name. Let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-27 10:42:22
[2017-07-27 12:58:02] |
They do match. See attached files.
Date Time Of Last Edit: 2017-07-27 15:04:55
Capture.PNG / V - Attached On 2017-07-27 12:57:24 UTC - Size: 67.24 KB - 299 views Capture1.PNG / V - Attached On 2017-07-27 12:57:28 UTC - Size: 261.26 KB - 257 views |
[2017-07-27 14:06:05] |
Make sure there is not an N in front of your Sierra Chart Account Name on the BitMEX DTC integration page. This is what we are seeing from our side. There is also another issue we need to let BitMEX know about. We have done that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-27 14:06:32
[2017-07-27 15:09:10] |
The files attached in my previous reply were private, were you able to open them? I changed them to public anyways. The first time I integrated Sierra Chart on the BitMEX DTC integration page I typed an "N" in front of my account name, mistakenly thinking that was my account name. Then I disconnected that account name, and typed my correct account name: Gorodzhiy. Date Time Of Last Edit: 2017-07-27 15:09:21
[2017-07-27 15:17:50] |
Yes we were able to open those attachments. They can be made private. We will let BitMEX know this: The first time I integrated Sierra Chart on the BitMEX DTC integration page I typed an "N" in front of my account name, mistakenly thinking that was my account name. Then I disconnected that account name, and typed my correct account name: Gorodzhiy. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-27 15:19:08] |
Please let me know when it'll work. Thank you.
[2017-07-27 15:55:49] |
BitMEX is working on it. Not sure when they will have this all done. We would allow about a day.
[2017-07-28 05:57:54] |
Could you try connecting again now.
[2017-07-28 12:46:54] |
It works. Thank you.
