Date/Time: Tue, 04 Nov 2025 06:51:31 +0000
Quote Board or Chartbook?
View Count: 1542
|   [2017-07-16 12:27:37]     |
| User172040 - Posts: 70 |
                I read the chart book and quote board docs and did a search on the support board but could not find what I was looking for. Please advise what would be the better setup given my criteria. I trade, ES, NQ, CL, E6 and GC which have mostly different pit opening times and different volume per day. I use tick charts which means a lightly traded instrument like NQ will have a 'lower' tick value than something like the ES or CL. Now, if I create a quote board and link that to the charts, ALL charts will show the same opening time and tick value charts (as they are linked). How can I customize the charts for the different instruments (i.e. independent tick charts and independent opening times) and still have a quote board? Currently it seems as if I'll have to create 5 different chartbooks in order to have my instruments customized?  |
|   [2017-07-18 01:44:06]     |
                The only thing you can do is use your own Session Times. This can be set in the Global Symbol Settings for the symbol: Global Symbol Settings Also refer to: Global Symbol Settings: Setting of Intraday Chart Session Times Currently it seems as if I'll have to create 5 different chartbooks in order to have my instruments customized?  Yes it would seem like it.
                Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-18 01:46:57
