Date/Time: Wed, 15 Jan 2025 15:27:57 +0000
LMAX orders canceled overnight
View Count: 967
[2017-07-11 22:05:44]
AlexPereira - Posts: 197
I am using LMAX connection, and my attached orders of a position disappear overnight ( normal stop and limit OCO orders ).
I have searched for an option to disable this "canceling", but cannot find it. How do I make orders not disappear overnight with LMAX ( they don't disappear on my other broker )
Thanks.
[2017-07-11 23:32:42]
You need to set the Time in Force for the Attached Orders to Good Till Canceled. Refer to:
Attached Orders: Time In Force
[2017-07-12 11:41:24]
Yes, of course, I always use that setting of "Good Till Canceled" !
Could this be something relative to LMAX ? How can I give more info ? I can try to make a small position just before overnight and make a video of it.
[2017-07-12 14:45:43]
We will look into this. We just need the Internal Order ID number of one of these orders that has been canceled.
Use the Trade Activity Log to locate the order and give us the Internal Order ID number. Here are instructions:
Trade Activity Log: Viewing Historical Trade Activity
Date Time Of Last Edit: 2017-07-12 14:46:49
[2017-07-12 17:08:23]
Thanks, I can't for sure give an order ID, don't know for sure if its the right one.
I will put a small order with "attached orders" today before 17:00 NY time, and report the order ID numbers here.
[2017-07-12 19:04:06]
OK. Let us know.
[2017-07-12 19:28:55]
So, I have a minimal order that I am going to leave overnight, just for testing.
The Internal Order ID is 3740 for the limit order, and 3741 for the stop order.
The instrument is USDJPY.
[2017-07-12 21:19:29]
Happened again:
Part of the log activity log:
Order  2017-07-12 21:16:13.932    Connected to server                Unspecified      None
Order  2017-07-12 21:16:18.933    Requested Open orders from trading service                Unspecified      None
Order  2017-07-12 21:16:18.987    LMAX Live Trading - DTC | No Trade Positions reported by DTC Server. Clearing existing Trade Positions.                Unspecified      None
Order  2017-07-12 21:16:18.988  USDJPY  Canceling due to no order update from server  3741  109092  Triggered Step Trail Stop  1  Sell  111.6920000    Pending Cancel      212524746  Close  3739
Order  2017-07-12 21:16:18.989  USDJPY  Canceling due to no order update from server  3741  109092  Triggered Step Trail Stop  1  Sell  111.6920000    Canceled      212524746  Close  3739
Order  2017-07-12 21:16:18.990  USDJPY  Canceling due to no order update from server  3740  109091  Limit  1  Sell  114.5960000    Pending Cancel      212524746  Close  3739
Order  2017-07-12 21:16:18.991  USDJPY  Canceling due to no order update from server  3740  109091  Limit  1  Sell  114.5960000    Canceled      212524746  Close  3739
[2017-07-13 05:36:28]
Are you sure you set the Attached Orders as Good till Canceled on the Targets tab of the Trade Window?
You may have set this on the wrong Trade Window.
Refer to:
https://www.sierrachart.com/index.php?page=doc/TradeWindow.html#SettingsNotApplying
What we see below is that LMAX did cancel the order. The only reason we can think of is because it was a Day order.
ActivityType  DateTime  Symbol  OrderActionSource  InternalOrderID  ServiceOrderID  OrderType  Quantity  BuySell  Price  Price2  OrderStatus  FillPrice  FilledQuantity  TradeAccount  OpenClose  ParentInternalOrderID  PositionQuantity  FillExecutionServiceID  HighDuringPosition  LowDuringPosition
Order  2017-07-12 20:59:58.656  USDJPY  LMAX order update (Canceled)  109092  AAGJIwAAAAMwRlg4  Stop  1  Sell  111.692    Canceled      ** Close  109090
[2017-07-13 06:39:08]
I think that might be it, in one of the charts I sometimes trade ( I have 3 charts for the same instrument, a tick chart, a renko chart and a numbers bar chart ) had on "Main : Good till canceled" but had on "Targets : Day".
I will try again tonight, I also activated linking and synch trade window through the different charts. ( As I am running on Linux, I usually only have on chart with the trade window open, and don't open and close alot so that a crash doesn't happen )
Thanks very much for the help and sorry if its a false problem !
