Date/Time: Tue, 04 Nov 2025 12:18:43 +0000
Persist Variables
View Count: 3642
[2017-06-27 05:39:37]
User972044 - Posts: 154
Also I am using persistent variables via the following manner:
int& variable_name = sc.PersistVars->Integers[0]; and then variable_name = 2;
It worked all fine last year. According to your documentation, https://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Variables_And_Arrays.html#scPersistVars:
Available Persistent Variables
sc.PersistVars->i1 through sc.PersistVars->i16. Integer data type.
sc.PersistVars->f1 through sc.PersistVars->f16. Single precision floating-point data type.
sc.PersistVars->d1 through sc.PersistVars->d24. Double precision floating-point data type.
sc.PersistVars->scdt1 through sc.PersistVars->scdt8. SCDateTime variable type.
sc.PersistVars->Integers[64]. Integer data type.
sc.PersistVars->Doubles[64]. Double precision floating-point data type.
Example
// You can use references to give the persistent variables
// more descriptive names that you can use.
// MyCounter is a reference to sc.PersistVars->Integers[0]
int& MyCounter = sc.PersistVars->Integers[0];
// MyAverage is a reference to sc.PersistVars->Doubles[2]
double& MyAverage = sc.PersistVars->Doubles[2];
// We are using the reference we made above.
// This is the same as: sc.PersistVars->Integers[0] += 1;
MyCounter += 1;
// This is the same as: sc.PersistVars->Doubles[2] = (10.0f+24.0f)/2.0f;
MyAverage = (10.0f+24.0f)/2.0f;
MyAverage = (sc.Subgraph[2][sc.Index]+24.0f)/2.0f;
Resetting Persistent Variables Example
if (sc.Index == 0)
// When there is a full recalculation of the study,
// reset the persistent variables we are using
sc.PersistVars->Integers[0] = 0;
sc.PersistVars->Integers[1] = 0;
sc.PersistVars->Integers[2] = 0;
sc.PersistVars->Integers[3] = 0;
this format is available for backward compatibility so everything compiled but when I try to change values to the persistent variables, the new values did not get set and the default value for persistent variables are supposed to be 0.00 but it's a ridiculously huge number such as these:
Chart: Replay 1.0X: XXXX 60 Min #2 | Study: Custom DLL Study | Buy PositionData Quantity: 0 TradeS_OrderQuantity: 0 Trade_PosL: 1086121984 | 2017-06-27 05:18:06
Chart: Replay 1.0X: XXXX 60 Min #2 | Study: Custom DLL Study | Sell PositionData Quantity: 0 TradeS_OrderQuantity: 0 Trade_PosS: 1086121984 | 2017-06-27 05:18:06
Chart: Replay 1.0X: XXXX 60 Min #2 | Study: Custom DLL Study | | 2017-06-27 05:18:06
My two persistent variables are Trade_PosL and Trade_PosS and they are NEVER set to 0 to begin with. They always stay as 1086121984 throughout the running of the whole program and because of this problem, my program is not sending any trades.
Please investigate and advise.
[2017-06-28 17:25:00]
Can I have an update on this? Are you still investigating? It's been two days since I reported this issue. Just to let you know this issue is still there after I upgraded Sierra Charts to the newest version. I was able to run my codes and the persist variables still did NOT get initialized to 0 as per your documentation and always stated as 1086121984.
[2017-06-29 17:59:12]
You must be doing something wrong from your side.
If you reset your persistent variables you are using back to 0 using code like this, then they will be set to zero for sure.
if (sc.Index == 0)
As long as you are displaying the values properly using the proper formatting function and formatting specification, persistent variables even without expressly resetting them in a study function, are at 0 when a study is applied to a chart or the Chartbook containing the chart which contains the study, is opened.
Date Time Of Last Edit: 2017-06-29 18:01:38
[2017-06-29 20:21:06]
I thought the proper formatting might be the cause too so I checked countless times already on what I did. These are the codes that I am using to display values of my persist variables Trade_PosL and Trade_PosS:
SCString Message7;
Message7.Format("Buy PositionData Quantity: %d TradeS_OrderQuantity: %d Trade_PosL: %d", PositionData.PositionQuantity, fabs(TradeS.OrderQuantity), Trade_PosL);
sc.AddMessageToLog(Message7, 0);
SCString Message8;
Message8.Format("Sell PositionData Quantity: %d TradeS_OrderQuantity: %d Trade_PosS: %d", PositionData.PositionQuantity, fabs(TradeS.OrderQuantity), Trade_PosS);
sc.AddMessageToLog(Message8, 0);
I know you don't provide Programming help and I am not expecting you to. I am just posting these codes here to show you what I did. I have used the same formatting to display other data and they are all displayed fine except these two persist variables. That's why it's so baffling and I am spending the time to create a support ticket for it. If you see something that's amiss, I would appreciate it if you can point it out. If not, you can just leave them to be.
if (sc.Index == 0)
This is what I use in my codes to reset the persist variable:
if (sc.Index == 0)
Trade_PosL = 0;
Trade_PosS = 0;
Very simple codes and they worked fine all last year but for some reason not anymore for this year. I will try your suggestions to see if they work. Hopefully they do and I won't have to post here again.
Date Time Of Last Edit: 2017-06-29 20:23:06
[2017-07-05 16:40:11]
We see what one of the problems is. You are using fabs instead of labs. You need to use the function that returns an integral type, when using %d.
Date Time Of Last Edit: 2017-07-05 16:40:35
[2017-07-06 02:59:05]
That certainly fixed the display problem for the TradeS.OrderQuantity but TradeS.OrderQuantity is NOT the persistent variables that I was having issues with and created this ticket for; the TradeS.OrderQuantity was just a member of the s_SCNewOrder class. Anyway, persistent variables are now working miraculously even though I did NOT change anything in my codes. I'll consider this issue resolved.
Date Time Of Last Edit: 2017-07-06 02:59:19
