Date/Time: Tue, 04 Nov 2025 14:58:12 +0000
OCO orders ?
View Count: 2839
|   [2013-04-03 13:21:00]     |
| Harvey W Hampton - Posts: 6 |
                I am using Sierra Charts and Zenfire feed with Mirus Futures. Since OCO orders can be complex and change frequently, it is logical that they exist only on my work station/computer. Suppose I use an OCO order and it executes. How may I enter a stop loss order manually for protection. For protection I mean a stop loss order that resides with the broker's server. This will provide protection in case of a loss of power, computer failure, or loss of connection. Thanks in advance. H. Hampton.  |
|   [2013-04-03 16:09:17]     |
                You just simply enter a Stop order and it will be sent to the trading server. In the case of a chart or Trade DOM, refer to these sections for instructions to enter a Stop order: http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#ChartTrading http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#TradeDOM Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
