Date/Time: Wed, 15 Jan 2025 05:50:17 +0000
DTC question
View Count: 1264
[2017-06-11 23:28:08]
User341584 - Posts: 44
Im setting up a DTC server because I want to keep the data flowing without my main pc being on all the time. I chart the market depth and unless I keep a computer on, data won't collect. So i'm setting up a dtc server on an older desktop.
On the client side-- is it typical to have open 2 instances to be able to connect to my DTC server?
I have my normal trade/data account login and connected on dtc server. Then on client side I have dtc- sub instance (trading) selected and populated. However, I can't connect to server unless I open a second instance?
Also, Even though I get the green light as connected. Data and charts are not updating?
Any help is appreciated. Thanks
Date Time Of Last Edit: 2017-06-12 00:05:29
[2017-06-12 00:30:40]
This is all very confusing to us.
You can do whatever you want. It does not matter.
This is not relevant to a connection problem.
You need to tell us one of the symbols you have a problem with and provide a copy of the Message Log by following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2017-06-12 00:39:49]
My apologies. Problem was a server side firewall.
I had to allow Sierra Charts for Firewall. Everything seems to be working now.
Thank you
[2017-06-12 03:12:09]
OK this is good.
[2017-06-12 03:22:03]
Is it possible to use the server's marketdepthdata folder on clients to update after not being connected? Is this possible with dtc?
Date Time Of Last Edit: 2017-06-12 03:32:51
[2017-06-12 03:59:41]
No not at this time. That is a considerable development effort on our side which we have not yet gotten to.
