Date/Time: Fri, 02 Oct 2026 11:10:47 +0000
Sierra Charts will not log in to S5/Gain live platform
View Count: 1272
| [2017-05-23 13:57:57] |
| User23815 - Posts: 219 |
I attempted to connect SC to my live S5/Gain account and it would not connect. I went to the DTS settings and the server on my saved settings was blank. I selected the server, prod.gainfutures.com but it still did not connect. I also re-entered my password to make sure it was correct. The account number is correct. I get no error message, just the yellow bar of SC trying to connect. I tried both available servers and neither worked. The demo connects fine. Help please. Thanks |
| [2017-05-23 14:02:19] |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-05-23 14:31:54] |
Reading Internal Order ID file. | 2017-05-23 05:10:14 Reading Trade Orders file. | 2017-05-23 05:10:14 Reading Trade Positions file. | 2017-05-23 05:10:14 Listening on UDP port 22903. | 2017-05-23 05:10:14 Software version: 1542 | 2017-05-23 05:10:14 Uses New Spreadsheets | 2017-05-23 05:10:14 Usage end date: 2017-06-18 | 2017-05-23 05:10:14 Enabled for: Advanced Features. | 2017-05-23 05:10:14 Enabled for: Sierra Chart Historical Data Service. | 2017-05-23 05:10:14 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2017-05-23 05:10:14 Enabled for: INDEXES_DATA_BARCHART | 2017-05-23 05:10:14 Enabled for: CME (Trading Account Required) | 2017-05-23 05:10:14 Enabled for: CBOT (Trading Account Required) | 2017-05-23 05:10:14 Enabled for: COMEX (Trading Account Required) | 2017-05-23 05:10:14 Enabled for: NYMEX (Trading Account Required) | 2017-05-23 05:10:14 Received 1 data feed usernames. | 2017-05-23 05:10:14 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-05-23 05:10:14 Current selected Data/Trading service: GAIN Capital/OEC | 2017-05-23 05:10:14 Chart Update Interval: 900 | 2017-05-23 05:10:14 Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-05-23 05:10:14 2017-05-23 05:10:18 Local computer time | 2017-05-23 05:10:14 2017-05-23 12:10:18 Local computer time in UTC | 2017-05-23 05:10:14 2017-05-23 05:10:18 Local computer time in SC Time Zone | 2017-05-23 05:10:14 2017-05-23 12:10:16 Server time in UTC | 2017-05-23 05:10:14 Local computer UTC time and Server UTC time difference: 1 seconds. | 2017-05-23 05:10:14 Program path: C:\SierraChart NS\ | 2017-05-23 05:10:14 Data Files path: C:\SierraChart NS\Data\ | 2017-05-23 05:10:14 OS Version Number: 6.2 | 2017-05-23 05:10:14 Locale Setting: C | 2017-05-23 05:10:14 Checking for new symbol settings for service code oec | 2017-05-23 05:10:14 HTTPS connection to www.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2017-05-23 05:10:14 Symbol settings are up-to-date for oec | 2017-05-23 05:10:19 GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2017-05-23 05:10:23 GAIN Capital FIX Trading socket (4) | Creating socket. | 2017-05-23 05:10:23 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 05:10:23 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 05:10:23 GAIN Capital/OEC | Connecting to market data server sim.gainfutures.com:9301. | 2017-05-23 05:10:23 GAIN Capital FAST Data socket (5) | Creating socket. | 2017-05-23 05:10:23 GAIN Capital FAST Data: Sending the Hello message. | 2017-05-23 05:10:23 GAIN Capital FAST Data: Sending the Logon message. | 2017-05-23 05:10:23 GAIN Capital/OEC | Connected to data and trading server. | 2017-05-23 05:10:23 NOTICE: Not connected to Live trading account to receive CME real-time futures data at lower cost exchange fee. | 2017-05-23 05:10:23 HTTPS connection to www.sierrachart.com:443 (3) | Received socket Close event | 2017-05-23 05:10:24 HTTPS connection to www.sierrachart.com:443 (3) | Socket gracefully closed by remote side. | 2017-05-23 05:10:24 HTTPS connection to www.sierrachart.com:443 (3) | Initiating close of socket by core. | 2017-05-23 05:10:24 HTTPS connection to www.sierrachart.com:443 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 05:10:24 HTTPS connection to www.sierrachart.com:443 (3) | Closed. | 2017-05-23 05:10:24 File >> Disconnect selected. | 2017-05-23 05:10:27 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-05-23 05:10:27 GAIN Capital FIX Trading: Sending a Logout message. | 2017-05-23 05:10:27 GAIN Capital FAST Data: Sending a Logout message. | 2017-05-23 05:10:27 GAIN Capital/OEC | Disconnected. | 2017-05-23 05:10:27 GAIN Capital FAST Data socket (5) | Socket gracefully closed by remote side. | 2017-05-23 05:10:27 GAIN Capital FAST Data socket (5) | Received socket Close event | 2017-05-23 05:10:27 GAIN Capital FAST Data socket (5) | Initiating close of socket by core. | 2017-05-23 05:10:27 GAIN Capital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2017-05-23 05:10:27 GAIN Capital FAST Data socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 05:10:27 GAIN Capital FAST Data socket (5) | Closed. | 2017-05-23 05:10:27 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 05:10:27 GAIN Capital FIX Trading: Received a Logout message. | 2017-05-23 05:10:27 GAIN Capital FIX Trading socket (4) | Initiating close of socket by core. | 2017-05-23 05:10:27 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 05:10:27 GAIN Capital FIX Trading socket (4) | Shutdown started. Waiting for graceful close. | 2017-05-23 05:10:27 GAIN Capital FIX Trading socket (4) | Socket gracefully closed by remote side. | 2017-05-23 05:10:27 GAIN Capital FIX Trading socket (4) | Closed. | 2017-05-23 05:10:27 NQM7 [CB] Daily #1 | Reloading chart. | 2017-05-23 05:10:35 NQM7 [CB] Daily #1 | Performing historical Daily data download for symbol NQM7 starting at last date in file. | 2017-05-23 05:10:35 NQM7 [CB] Daily #1 | Waiting for historical downloads to complete with the IDs: 1, | 2017-05-23 05:10:35 ZNM7 [CB] Daily #6 | Reloading chart. | 2017-05-23 05:10:35 ZNM7 [CB] Daily #6 | Performing historical Daily data download for symbol ZNM7 starting at last date in file. | 2017-05-23 05:10:35 ZNM7 [CB] Daily #6 | Waiting for historical downloads to complete with the IDs: 2, | 2017-05-23 05:10:35 ESM7 [CB] Daily #8 | Reloading chart. | 2017-05-23 05:10:35 ESM7 [CB] Daily #8 | Performing historical Daily data download for symbol ESM7 starting at last date in file. | 2017-05-23 05:10:35 ESM7 [CB] Daily #8 | Waiting for historical downloads to complete with the IDs: 3, | 2017-05-23 05:10:35 ESM7 [CB] Weekly #2 | Reloading chart. | 2017-05-23 05:10:35 ESM7 [CB] Weekly #2 | Waiting for historical downloads to complete with the IDs: 3, | 2017-05-23 05:10:35 Mapping NQM7 to NQM17. Service code: cme | 2017-05-23 05:10:35 HD Request # 2 | Downloading Historical Daily chart data for NQM7. Starting date: 2017-05-19. Service: oec | 2017-05-23 05:10:35 HD Request # 2 | Using user Barchart Historical data account. | 2017-05-23 05:10:35 HD Request # 2 | Requesting historical Daily data for NQM17 starting at 2017-05-18 | 2017-05-23 05:10:35 HTTP connection to ds01.ddfplus.com:80 (6) | Creating socket. | 2017-05-23 05:10:35 HD Request # 2 | Receiving historical Daily data for NQM7 starting at 2017-05-19 | 2017-05-23 05:10:35 HD Request # 2 | Writing historical Daily data to the file NQM7.dly | 2017-05-23 05:10:35 HD Request # 2 | Received 4 records from 2017-05-19 00:00:00 to 2017-05-23 00:00:00 (5.0 days) and wrote 3 records for NQM7 | 2017-05-23 05:10:35 HD Request # 2 | Daily download COMPLETE for NQM7. Completion time: 0s. Unique request ID: 1 | 2017-05-23 05:10:35 Removed historical data download ID 1 | 2017-05-23 05:10:35 Mapping ZNM7 to ZNM17. Service code: cbot | 2017-05-23 05:10:35 HD Request # 3 | Downloading Historical Daily chart data for ZNM7. Starting date: 2017-05-19. Service: oec | 2017-05-23 05:10:35 HD Request # 3 | Using user Barchart Historical data account. | 2017-05-23 05:10:35 HD Request # 3 | Requesting historical Daily data for ZNM17 starting at 2017-05-18 | 2017-05-23 05:10:35 HD Request # 3 | Receiving historical Daily data for ZNM7 starting at 2017-05-19 | 2017-05-23 05:10:36 HD Request # 3 | Writing historical Daily data to the file ZNM7.dly | 2017-05-23 05:10:36 HD Request # 3 | Received 4 records from 2017-05-19 00:00:00 to 2017-05-23 00:00:00 (5.0 days) and wrote 3 records for ZNM7 | 2017-05-23 05:10:36 HD Request # 3 | Daily download COMPLETE for ZNM7. Completion time: 0s. Unique request ID: 2 | 2017-05-23 05:10:36 Removed historical data download ID 2 | 2017-05-23 05:10:36 Mapping ESM7 to ESM17. Service code: cme | 2017-05-23 05:10:36 HD Request # 4 | Downloading Historical Daily chart data for ESM7. Starting date: 2017-05-19. Service: oec | 2017-05-23 05:10:36 HD Request # 4 | Using user Barchart Historical data account. | 2017-05-23 05:10:36 HD Request # 4 | Requesting historical Daily data for ESM17 starting at 2017-05-18 | 2017-05-23 05:10:36 NQM7 [CB] Daily #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-05-23 05:10:36 NQM7 [CB] Daily #1 | Reloading chart. | 2017-05-23 05:10:36 HD Request # 4 | Receiving historical Daily data for ESM7 starting at 2017-05-19 | 2017-05-23 05:10:36 HD Request # 4 | Writing historical Daily data to the file ESM7.dly | 2017-05-23 05:10:36 HD Request # 4 | Received 4 records from 2017-05-19 00:00:00 to 2017-05-23 00:00:00 (5.0 days) and wrote 3 records for ESM7 | 2017-05-23 05:10:36 HD Request # 4 | Daily download COMPLETE for ESM7. Completion time: 0s. Unique request ID: 3 | 2017-05-23 05:10:36 Removed historical data download ID 3 | 2017-05-23 05:10:36 ZNM7 [CB] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-05-23 05:10:36 ZNM7 [CB] Daily #6 | Reloading chart. | 2017-05-23 05:10:36 ESM7 [CB] Daily #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-05-23 05:10:36 ESM7 [CB] Daily #8 | Reloading chart. | 2017-05-23 05:10:36 ESM7 [CB] Weekly #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-05-23 05:10:36 ESM7 [CB] Weekly #2 | Reloading chart. | 2017-05-23 05:10:36 NQM7 [CB] Daily #1 | Reloading chart. | 2017-05-23 05:10:37 ZNM7 [CB] Daily #6 | Reloading chart. | 2017-05-23 05:10:37 ESM7 [CB] Daily #8 | Reloading chart. | 2017-05-23 05:10:37 ESM7 [CB] Weekly #2 | Reloading chart. | 2017-05-23 05:10:37 ZNM7 60 Min #3 | Reloading chart. | 2017-05-23 05:10:50 ESM7 30 Min #4 | Reloading chart. | 2017-05-23 05:10:50 ESM7 30 Min #2 | Reloading chart. | 2017-05-23 05:10:50 ESM7 Point & Figure 3-4 #7 | Reloading chart. | 2017-05-23 05:10:50 EMDM7 30 Min #6 | Reloading chart. | 2017-05-23 05:10:50 ADR-SP 5 Min #9 | Reloading chart. | 2017-05-23 05:10:50 NQM7 30 Min #5 | Reloading chart. | 2017-05-23 05:10:50 ESM7 30 Min #8 | Reloading chart. | 2017-05-23 05:10:50 Intraday data recording state for symbol ZNM7 is set to download 'Pending'. | 2017-05-23 05:10:51 HD Request # 5 | Downloading Intraday chart data for ZNM7 to the file ZNM7.scid. Service: cbot | 2017-05-23 05:10:51 HD Request # 5 | Download start date-time: 2017-05-22 13:25:00.000 | 2017-05-23 05:10:51 HD Request # 5 | Using server: ds7.sierracharts.com port 10149 | 2017-05-23 05:10:51 Socket (7) | Creating socket. | 2017-05-23 05:10:51 Intraday data recording state for symbol ESM7 is set to download 'Pending'. | 2017-05-23 05:10:51 Mapping EMDM7 to EMDM17. Service code: cme | 2017-05-23 05:10:51 Intraday data recording state for symbol EMDM7 is set to download 'Pending'. | 2017-05-23 05:10:51 Intraday data recording state for symbol ADR-SP is set to download 'Pending'. | 2017-05-23 05:10:51 Intraday data recording state for symbol NQM7 is set to download 'Pending'. | 2017-05-23 05:10:51 HD Request # 5 | Setting DTC encoding to Binary VLS | 2017-05-23 05:10:51 HD Request # 5 | Sending historical data logon request message. | 2017-05-23 05:10:51 HD Request # 5 | Requesting Intraday data. Start date-time: 2017-05-22 13:25:00. Record interval: 0. Symbol: ZNM17 | 2017-05-23 05:10:52 HD Request # 5 | Decompressing data. | 2017-05-23 05:10:52 HD Request # 5 | Receiving Intraday data for ZNM7 starting at 2017-05-22 13:25:00 | 2017-05-23 05:10:52 HD Request # 5 | Timestamp of first Intraday data file record written: 2017-05-22 13:27:37 | 2017-05-23 05:10:52 HD Request # 5 | Historical data for ZNM7 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-05-23 05:10:52 Socket (7) | Initiating close of socket by core. | 2017-05-23 05:10:52 Historical data download thread signaled to stop. | 2017-05-23 05:10:52 Socket (7) | Shutdown started. Waiting for graceful close. | 2017-05-23 05:10:52 Socket (7) | Socket gracefully closed by remote side. | 2017-05-23 05:10:52 Socket (7) | Closed. | 2017-05-23 05:10:52 HD Request # 5 | Received 51570 records from 2017-05-22 13:25:00 to 2017-05-23 05:00:41 (15.6 hours) and wrote 51568 records for ZNM7 | 2017-05-23 05:10:52 HD Request # 5 | Intraday download COMPLETE for ZNM7. Completion time: 1s. Unique request ID: 4 | 2017-05-23 05:10:52 Removed historical data download ID 4 | 2017-05-23 05:10:52 HD Request # 6 | Downloading Intraday chart data for ESM7 to the file ESM7.scid. Service: cme | 2017-05-23 05:10:52 HD Request # 6 | Download start date-time: 2017-05-22 13:15:00.000 | 2017-05-23 05:10:52 HD Request # 6 | Using server: ds1.sierracharts.com port 10149 | 2017-05-23 05:10:52 Socket (8) | Creating socket. | 2017-05-23 05:10:52 HD Request # 6 | Setting DTC encoding to Binary VLS | 2017-05-23 05:10:52 HD Request # 6 | Sending historical data logon request message. | 2017-05-23 05:10:52 HD Request # 6 | Requesting Intraday data. Start date-time: 2017-05-22 13:15:00. Record interval: 0. Symbol: ESM17 | 2017-05-23 05:10:52 HD Request # 6 | Decompressing data. | 2017-05-23 05:10:52 HD Request # 6 | Receiving Intraday data for ESM7 starting at 2017-05-22 13:30:00 | 2017-05-23 05:10:52 HD Request # 6 | Timestamp of first Intraday data file record written: 2017-05-22 13:30:00 | 2017-05-23 05:10:52 HD Request # 6 | Historical data for ESM7 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-05-23 05:10:53 Socket (8) | Initiating close of socket by core. | 2017-05-23 05:10:53 Historical data download thread signaled to stop. | 2017-05-23 05:10:53 Socket (8) | Shutdown started. Waiting for graceful close. | 2017-05-23 05:10:53 Socket (8) | Socket gracefully closed by remote side. | 2017-05-23 05:10:53 Socket (8) | Closed. | 2017-05-23 05:10:53 HD Request # 6 | Received 64773 records from 2017-05-22 13:30:00 to 2017-05-23 05:00:51 (15.5 hours) and wrote 64773 records for ESM7 | 2017-05-23 05:10:53 HD Request # 6 | Intraday download COMPLETE for ESM7. Completion time: 0s. Unique request ID: 5 | 2017-05-23 05:10:53 Removed historical data download ID 5 | 2017-05-23 05:10:53 HD Request # 7 | Downloading Intraday chart data for EMDM7 to the file EMDM7.scid. Service: cme | 2017-05-23 05:10:53 HD Request # 7 | Download start date-time: 2017-05-22 13:14:57.000 | 2017-05-23 05:10:53 HD Request # 7 | Using server: ds7.sierracharts.com port 10149 | 2017-05-23 05:10:53 Socket (9) | Creating socket. | 2017-05-23 05:10:53 HD Request # 7 | Setting DTC encoding to Binary VLS | 2017-05-23 05:10:53 HD Request # 7 | Sending historical data logon request message. | 2017-05-23 05:10:53 HD Request # 7 | Requesting Intraday data. Start date-time: 2017-05-22 13:14:57. Record interval: 0. Symbol: EMDM17 | 2017-05-23 05:10:53 HD Request # 7 | Decompressing data. | 2017-05-23 05:10:53 HD Request # 7 | Receiving Intraday data for EMDM7 starting at 2017-05-22 13:14:57 | 2017-05-23 05:10:53 HD Request # 7 | Timestamp of first Intraday data file record written: 2017-05-22 13:36:02 | 2017-05-23 05:10:53 Socket (9) | Initiating close of socket by core. | 2017-05-23 05:10:53 HD Request # 7 | Historical data for EMDM7 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-05-23 05:10:53 Socket (9) | Shutdown started. Waiting for graceful close. | 2017-05-23 05:10:53 Socket (9) | Socket gracefully closed by remote side. | 2017-05-23 05:10:53 Historical data download thread signaled to stop. | 2017-05-23 05:10:53 Socket (9) | Closed. | 2017-05-23 05:10:53 HD Request # 7 | Received 402 records from 2017-05-22 13:14:57 to 2017-05-23 05:00:21 (15.8 hours) and wrote 401 records for EMDM7 | 2017-05-23 05:10:53 HD Request # 7 | Intraday download COMPLETE for EMDM7. Completion time: 0s. Unique request ID: 6 | 2017-05-23 05:10:53 Removed historical data download ID 6 | 2017-05-23 05:10:53 HD Request # 8 | Downloading Intraday chart data for ADR-SP to the file ADR-SP.scid. Service: statscalc | 2017-05-23 05:10:53 HD Request # 8 | Download start date-time: 2017-05-22 13:26:55.000 | 2017-05-23 05:10:53 HD Request # 8 | Using server: ds4.sierracharts.com port 10149 | 2017-05-23 05:10:53 Socket (10) | Creating socket. | 2017-05-23 05:10:53 HD Request # 8 | Setting DTC encoding to Binary VLS | 2017-05-23 05:10:53 HD Request # 8 | Sending historical data logon request message. | 2017-05-23 05:10:53 HD Request # 8 | Requesting Intraday data. Start date-time: 2017-05-22 13:26:55. Record interval: 0. Symbol: ADR-SP | 2017-05-23 05:10:54 HD Request # 8 | Decompressing data. | 2017-05-23 05:10:54 HD Request # 8 | Receiving Intraday data for ADR-SP starting at 2017-05-22 13:26:55 | 2017-05-23 05:10:54 HD Request # 8 | Timestamp of first Intraday data file record written: 2017-05-22 13:26:57 | 2017-05-23 05:10:54 HD Request # 8 | Historical data for ADR-SP is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-05-23 05:10:54 Socket (10) | Initiating close of socket by core. | 2017-05-23 05:10:54 Historical data download thread signaled to stop. | 2017-05-23 05:10:54 Socket (10) | Shutdown started. Waiting for graceful close. | 2017-05-23 05:10:54 Socket (10) | Socket gracefully closed by remote side. | 2017-05-23 05:10:54 Socket (10) | Closed. | 2017-05-23 05:10:54 HD Request # 8 | Received 6671 records from 2017-05-22 13:26:55 to 2017-05-23 05:10:50 (15.7 hours) and wrote 6670 records for ADR-SP | 2017-05-23 05:10:54 HD Request # 8 | Intraday download COMPLETE for ADR-SP. Completion time: 0s. Unique request ID: 7 | 2017-05-23 05:10:54 Removed historical data download ID 7 | 2017-05-23 05:10:54 HD Request # 9 | Downloading Intraday chart data for NQM7 to the file NQM7.scid. Service: cme | 2017-05-23 05:10:54 HD Request # 9 | Download start date-time: 2017-05-22 13:14:59.000 | 2017-05-23 05:10:54 HD Request # 9 | Using server: ds1.sierracharts.com port 10149 | 2017-05-23 05:10:54 Socket (11) | Creating socket. | 2017-05-23 05:10:54 HD Request # 9 | Setting DTC encoding to Binary VLS | 2017-05-23 05:10:54 HD Request # 9 | Sending historical data logon request message. | 2017-05-23 05:10:54 HD Request # 9 | Requesting Intraday data. Start date-time: 2017-05-22 13:14:59. Record interval: 0. Symbol: NQM17 | 2017-05-23 05:10:54 HD Request # 9 | Decompressing data. | 2017-05-23 05:10:54 HD Request # 9 | Receiving Intraday data for NQM7 starting at 2017-05-22 13:14:59 | 2017-05-23 05:10:54 HD Request # 9 | Timestamp of first Intraday data file record written: 2017-05-22 13:30:00 | 2017-05-23 05:10:54 HD Request # 9 | Historical data for NQM7 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-05-23 05:10:54 Socket (11) | Initiating close of socket by core. | 2017-05-23 05:10:54 Historical data download thread signaled to stop. | 2017-05-23 05:10:54 Socket (11) | Shutdown started. Waiting for graceful close. | 2017-05-23 05:10:54 Socket (11) | Socket gracefully closed by remote side. | 2017-05-23 05:10:54 Socket (11) | Closed. | 2017-05-23 05:10:54 HD Request # 9 | Received 25762 records from 2017-05-22 13:14:59 to 2017-05-23 05:00:50 (15.8 hours) and wrote 25756 records for NQM7 | 2017-05-23 05:10:54 HD Request # 9 | Intraday download COMPLETE for NQM7. Completion time: 1s. Unique request ID: 8 | 2017-05-23 05:10:54 Removed historical data download ID 8 | 2017-05-23 05:10:54 ESM7 Flex Renko 3-2-1 #3 | Reloading chart. | 2017-05-23 05:11:02 ESM7 10000 Volume #2 | Reloading chart. | 2017-05-23 05:11:02 ESM7 Flex Renko 4-2-1 #5 | Reloading chart. | 2017-05-23 05:11:02 TICK-NYSE 2 Min #1 | Reloading chart. | 2017-05-23 05:11:15 ADR-SP 2 Min #2 | Reloading chart. | 2017-05-23 05:11:15 ADR-NYSE 2 Min #3 | Reloading chart. | 2017-05-23 05:11:15 ADR-TF 2 Min #4 | Reloading chart. | 2017-05-23 05:11:15 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2017-05-23 05:11:16 HD Request # 10 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2017-05-23 05:11:16 HD Request # 10 | Download start date-time: 2017-05-22 13:26:55.000 | 2017-05-23 05:11:16 HD Request # 10 | Using server: ds3.sierracharts.com port 10149 | 2017-05-23 05:11:16 Socket (12) | Creating socket. | 2017-05-23 05:11:16 Intraday data recording state for symbol ADR-NYSE is set to download 'Pending'. | 2017-05-23 05:11:16 Intraday data recording state for symbol ADR-TF is set to download 'Pending'. | 2017-05-23 05:11:16 HD Request # 10 | Setting DTC encoding to Binary VLS | 2017-05-23 05:11:16 HD Request # 10 | Sending historical data logon request message. | 2017-05-23 05:11:16 HD Request # 10 | Requesting Intraday data. Start date-time: 2017-05-22 13:26:55. Record interval: 0. Symbol: TICK-NYSE | 2017-05-23 05:11:16 HD Request # 10 | Decompressing data. | 2017-05-23 05:11:16 HD Request # 10 | Receiving Intraday data for TICK-NYSE starting at 2017-05-22 13:26:55 | 2017-05-23 05:11:16 HD Request # 10 | Timestamp of first Intraday data file record written: 2017-05-22 13:26:57 | 2017-05-23 05:11:16 HD Request # 10 | Historical data for TICK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-05-23 05:11:16 Socket (12) | Initiating close of socket by core. | 2017-05-23 05:11:16 Historical data download thread signaled to stop. | 2017-05-23 05:11:16 Socket (12) | Shutdown started. Waiting for graceful close. | 2017-05-23 05:11:16 Socket (12) | Socket gracefully closed by remote side. | 2017-05-23 05:11:16 Socket (12) | Closed. | 2017-05-23 05:11:16 HD Request # 10 | Received 6699 records from 2017-05-22 13:26:55 to 2017-05-23 05:11:12 (15.7 hours) and wrote 6698 records for TICK-NYSE | 2017-05-23 05:11:16 HD Request # 10 | Intraday download COMPLETE for TICK-NYSE. Completion time: 1s. Unique request ID: 9 | 2017-05-23 05:11:16 Removed historical data download ID 9 | 2017-05-23 05:11:16 HD Request # 11 | Downloading Intraday chart data for ADR-NYSE to the file ADR-NYSE.scid. Service: statscalc | 2017-05-23 05:11:16 HD Request # 11 | Download start date-time: 2017-05-22 13:26:55.000 | 2017-05-23 05:11:16 HD Request # 11 | Using server: ds4.sierracharts.com port 10149 | 2017-05-23 05:11:16 Socket (13) | Creating socket. | 2017-05-23 05:11:16 HD Request # 11 | Setting DTC encoding to Binary VLS | 2017-05-23 05:11:16 HD Request # 11 | Sending historical data logon request message. | 2017-05-23 05:11:16 HD Request # 11 | Requesting Intraday data. Start date-time: 2017-05-22 13:26:55. Record interval: 0. Symbol: ADR-NYSE | 2017-05-23 05:11:17 HD Request # 11 | Decompressing data. | 2017-05-23 05:11:17 HD Request # 11 | Receiving Intraday data for ADR-NYSE starting at 2017-05-22 13:26:55 | 2017-05-23 05:11:17 HD Request # 11 | Timestamp of first Intraday data file record written: 2017-05-22 13:26:57 | 2017-05-23 05:11:17 HD Request # 11 | Historical data for ADR-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-05-23 05:11:17 Socket (13) | Initiating close of socket by core. | 2017-05-23 05:11:17 Historical data download thread signaled to stop. | 2017-05-23 05:11:17 Socket (13) | Shutdown started. Waiting for graceful close. | 2017-05-23 05:11:17 Socket (13) | Socket gracefully closed by remote side. | 2017-05-23 05:11:17 Socket (13) | Closed. | 2017-05-23 05:11:17 HD Request # 11 | Received 4589 records from 2017-05-22 13:26:55 to 2017-05-22 16:59:59 (3.6 hours) and wrote 4588 records for ADR-NYSE | 2017-05-23 05:11:17 HD Request # 11 | Intraday download COMPLETE for ADR-NYSE. Completion time: 0s. Unique request ID: 10 | 2017-05-23 05:11:17 Removed historical data download ID 10 | 2017-05-23 05:11:17 HD Request # 12 | Downloading Intraday chart data for ADR-TF to the file ADR-TF.scid. Service: statscalc | 2017-05-23 05:11:17 HD Request # 12 | Download start date-time: 2017-05-22 13:26:55.000 | 2017-05-23 05:11:17 HD Request # 12 | Using server: ds3.sierracharts.com port 10149 | 2017-05-23 05:11:17 Socket (14) | Creating socket. | 2017-05-23 05:11:17 HD Request # 12 | Setting DTC encoding to Binary VLS | 2017-05-23 05:11:17 HD Request # 12 | Sending historical data logon request message. | 2017-05-23 05:11:17 HD Request # 12 | Requesting Intraday data. Start date-time: 2017-05-22 13:26:55. Record interval: 0. Symbol: ADR-TF | 2017-05-23 05:11:17 HD Request # 12 | Decompressing data. | 2017-05-23 05:11:17 HD Request # 12 | Receiving Intraday data for ADR-TF starting at 2017-05-22 13:26:55 | 2017-05-23 05:11:17 HD Request # 12 | Timestamp of first Intraday data file record written: 2017-05-22 13:26:57 | 2017-05-23 05:11:17 HD Request # 12 | Historical data for ADR-TF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-05-23 05:11:17 Socket (14) | Initiating close of socket by core. | 2017-05-23 05:11:17 Historical data download thread signaled to stop. | 2017-05-23 05:11:17 Socket (14) | Shutdown started. Waiting for graceful close. | 2017-05-23 05:11:17 Socket (14) | Socket gracefully closed by remote side. | 2017-05-23 05:11:17 Socket (14) | Closed. | 2017-05-23 05:11:17 HD Request # 12 | Received 6687 records from 2017-05-22 13:26:55 to 2017-05-23 05:11:13 (15.7 hours) and wrote 6686 records for ADR-TF | 2017-05-23 05:11:17 HD Request # 12 | Intraday download COMPLETE for ADR-TF. Completion time: 0s. Unique request ID: 11 | 2017-05-23 05:11:17 Removed historical data download ID 11 | 2017-05-23 05:11:17 HTTP connection to ds01.ddfplus.com:80 (6) | Socket gracefully closed by remote side. | 2017-05-23 05:11:41 HTTP connection to ds01.ddfplus.com:80 (6) | Received socket Close event | 2017-05-23 05:11:41 HTTP connection to ds01.ddfplus.com:80 (6) | Initiating close of socket by core. | 2017-05-23 05:11:41 HTTP connection to ds01.ddfplus.com:80 (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 05:11:41 HTTP connection to ds01.ddfplus.com:80 (6) | Closed. | 2017-05-23 05:11:41 GAIN Capital/OEC | Connecting to trading server . Port: 9400. | 2017-05-23 06:18:33 File >> Disconnect selected. | 2017-05-23 06:18:58 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-05-23 06:18:58 GAIN Capital FIX Trading socket (49) | Initiating close of socket by core. | 2017-05-23 06:18:58 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:18:58 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:18:58 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-23 06:20:51 GAIN Capital FIX Trading socket (51) | Creating socket. Using TLS 1.2. | 2017-05-23 06:20:51 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:20:51 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:20:51 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-23 06:20:51 GAIN Capital FAST Data socket (52) | Creating socket. | 2017-05-23 06:20:51 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-23 06:20:51 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-23 06:20:51 GAIN Capital FIX Trading socket (51) | Initiating close of socket by core. | 2017-05-23 06:20:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:20:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:20:51 GAIN Capital FIX Trading socket (51) | Write in progress. Shutdown being delayed. | 2017-05-23 06:20:51 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:20:51 GAIN Capital FAST Data socket (52) | Initiating close of socket by core. | 2017-05-23 06:20:51 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:20:51 GAIN Capital FAST Data socket (52) | Closed. | 2017-05-23 06:20:51 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 06:20:51 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:20:51 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:20:51 GAIN Capital FIX Trading socket (51) | Socket gracefully closed by remote side. | 2017-05-23 06:20:51 GAIN Capital FIX Trading socket (51) | Write has completed. Shutdown being performed. | 2017-05-23 06:20:51 GAIN Capital FIX Trading socket (51) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:20:51 GAIN Capital FIX Trading socket (51) | Closed. | 2017-05-23 06:20:51 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-23 06:20:54 GAIN Capital FIX Trading socket (53) | Creating socket. Using TLS 1.2. | 2017-05-23 06:20:54 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:20:54 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:20:55 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-23 06:20:55 GAIN Capital FAST Data socket (54) | Creating socket. | 2017-05-23 06:20:55 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-23 06:20:55 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-23 06:20:55 GAIN Capital FIX Trading socket (53) | Initiating close of socket by core. | 2017-05-23 06:20:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:20:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:20:55 GAIN Capital FIX Trading socket (53) | Write in progress. Shutdown being delayed. | 2017-05-23 06:20:55 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:20:55 GAIN Capital FAST Data socket (54) | Initiating close of socket by core. | 2017-05-23 06:20:55 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:20:55 GAIN Capital FAST Data socket (54) | Closed. | 2017-05-23 06:20:55 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 06:20:55 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:20:55 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:20:55 GAIN Capital FIX Trading socket (53) | Socket gracefully closed by remote side. | 2017-05-23 06:20:55 GAIN Capital FIX Trading socket (53) | Write has completed. Shutdown being performed. | 2017-05-23 06:20:55 GAIN Capital FIX Trading socket (53) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:20:55 GAIN Capital FIX Trading socket (53) | Closed. | 2017-05-23 06:20:55 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-23 06:20:58 GAIN Capital FIX Trading socket (55) | Creating socket. Using TLS 1.2. | 2017-05-23 06:20:58 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:20:58 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:20:58 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-23 06:20:58 GAIN Capital FAST Data socket (56) | Creating socket. | 2017-05-23 06:20:58 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-23 06:20:58 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-23 06:20:58 GAIN Capital FIX Trading socket (55) | Initiating close of socket by core. | 2017-05-23 06:20:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:20:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:20:58 GAIN Capital FIX Trading socket (55) | Write in progress. Shutdown being delayed. | 2017-05-23 06:20:58 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:20:58 GAIN Capital FAST Data socket (56) | Initiating close of socket by core. | 2017-05-23 06:20:58 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:20:58 GAIN Capital FAST Data socket (56) | Closed. | 2017-05-23 06:20:58 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 06:20:58 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:20:58 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:20:58 GAIN Capital FIX Trading socket (55) | Socket gracefully closed by remote side. | 2017-05-23 06:20:58 GAIN Capital FIX Trading socket (55) | Write has completed. Shutdown being performed. | 2017-05-23 06:20:58 GAIN Capital FIX Trading socket (55) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:20:58 GAIN Capital FIX Trading socket (55) | Closed. | 2017-05-23 06:20:58 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-23 06:21:01 GAIN Capital FIX Trading socket (57) | Creating socket. Using TLS 1.2. | 2017-05-23 06:21:01 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:21:01 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:21:01 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-23 06:21:01 GAIN Capital FAST Data socket (58) | Creating socket. | 2017-05-23 06:21:01 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-23 06:21:01 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-23 06:21:01 GAIN Capital FIX Trading socket (57) | Initiating close of socket by core. | 2017-05-23 06:21:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:21:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:21:01 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:21:01 GAIN Capital FIX Trading socket (57) | Write in progress. Shutdown being delayed. | 2017-05-23 06:21:01 GAIN Capital FAST Data socket (58) | Initiating close of socket by core. | 2017-05-23 06:21:01 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:21:01 GAIN Capital FAST Data socket (58) | Closed. | 2017-05-23 06:21:01 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 06:21:01 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:21:01 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:21:01 GAIN Capital FIX Trading socket (57) | Socket gracefully closed by remote side. | 2017-05-23 06:21:02 GAIN Capital FIX Trading socket (57) | Write has completed. Shutdown being performed. | 2017-05-23 06:21:02 GAIN Capital FIX Trading socket (57) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:21:02 GAIN Capital FIX Trading socket (57) | Closed. | 2017-05-23 06:21:02 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-23 06:21:04 GAIN Capital FIX Trading socket (59) | Creating socket. Using TLS 1.2. | 2017-05-23 06:21:04 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:21:05 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:21:05 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-23 06:21:05 GAIN Capital FAST Data socket (60) | Creating socket. | 2017-05-23 06:21:05 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-23 06:21:05 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-23 06:21:05 GAIN Capital FIX Trading socket (59) | Initiating close of socket by core. | 2017-05-23 06:21:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:21:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:21:05 GAIN Capital FIX Trading socket (59) | Write in progress. Shutdown being delayed. | 2017-05-23 06:21:05 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:21:05 GAIN Capital FAST Data socket (60) | Initiating close of socket by core. | 2017-05-23 06:21:05 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:21:05 GAIN Capital FAST Data socket (60) | Closed. | 2017-05-23 06:21:05 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 06:21:05 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:21:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:21:05 GAIN Capital FIX Trading socket (59) | Socket gracefully closed by remote side. | 2017-05-23 06:21:05 GAIN Capital FIX Trading socket (59) | Write has completed. Shutdown being performed. | 2017-05-23 06:21:05 GAIN Capital FIX Trading socket (59) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:21:05 GAIN Capital FIX Trading socket (59) | Closed. | 2017-05-23 06:21:05 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-23 06:21:08 GAIN Capital FIX Trading socket (61) | Creating socket. Using TLS 1.2. | 2017-05-23 06:21:08 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:21:08 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:21:08 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-23 06:21:08 GAIN Capital FAST Data socket (62) | Creating socket. | 2017-05-23 06:21:08 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-23 06:21:08 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-23 06:21:08 GAIN Capital FIX Trading socket (61) | Initiating close of socket by core. | 2017-05-23 06:21:08 GAIN Capital FIX Trading socket (61) | Write in progress. Shutdown being delayed. | 2017-05-23 06:21:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:21:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:21:08 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:21:08 GAIN Capital FAST Data socket (62) | Initiating close of socket by core. | 2017-05-23 06:21:08 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:21:08 GAIN Capital FAST Data socket (62) | Closed. | 2017-05-23 06:21:08 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 06:21:08 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:21:08 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:21:08 GAIN Capital FIX Trading socket (61) | Socket gracefully closed by remote side. | 2017-05-23 06:21:08 GAIN Capital FIX Trading socket (61) | Write has completed. Shutdown being performed. | 2017-05-23 06:21:08 GAIN Capital FIX Trading socket (61) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:21:08 GAIN Capital FIX Trading socket (61) | Closed. | 2017-05-23 06:21:08 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-23 06:21:11 GAIN Capital FIX Trading socket (63) | Creating socket. Using TLS 1.2. | 2017-05-23 06:21:11 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:21:12 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:21:12 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-23 06:21:12 GAIN Capital FAST Data socket (64) | Creating socket. | 2017-05-23 06:21:12 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-23 06:21:12 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-23 06:21:12 GAIN Capital FIX Trading socket (63) | Initiating close of socket by core. | 2017-05-23 06:21:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:21:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:21:12 GAIN Capital FIX Trading socket (63) | Write in progress. Shutdown being delayed. | 2017-05-23 06:21:12 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:21:12 GAIN Capital FAST Data socket (64) | Initiating close of socket by core. | 2017-05-23 06:21:12 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:21:12 GAIN Capital FAST Data socket (64) | Closed. | 2017-05-23 06:21:12 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 06:21:12 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:21:12 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:21:12 GAIN Capital FIX Trading socket (63) | Socket gracefully closed by remote side. | 2017-05-23 06:21:12 GAIN Capital FIX Trading socket (63) | Write has completed. Shutdown being performed. | 2017-05-23 06:21:12 GAIN Capital FIX Trading socket (63) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:21:12 GAIN Capital FIX Trading socket (63) | Closed. | 2017-05-23 06:21:12 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-23 06:21:15 GAIN Capital FIX Trading socket (65) | Creating socket. Using TLS 1.2. | 2017-05-23 06:21:15 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:21:15 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:21:15 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-23 06:21:15 GAIN Capital FAST Data socket (66) | Creating socket. | 2017-05-23 06:21:15 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-23 06:21:15 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-23 06:21:15 GAIN Capital FIX Trading socket (65) | Initiating close of socket by core. | 2017-05-23 06:21:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:21:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:21:15 GAIN Capital FIX Trading socket (65) | Write in progress. Shutdown being delayed. | 2017-05-23 06:21:15 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:21:15 GAIN Capital FAST Data socket (66) | Initiating close of socket by core. | 2017-05-23 06:21:15 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:21:15 GAIN Capital FAST Data socket (66) | Closed. | 2017-05-23 06:21:15 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 06:21:15 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:21:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:21:15 GAIN Capital FIX Trading socket (65) | Socket gracefully closed by remote side. | 2017-05-23 06:21:15 GAIN Capital FIX Trading socket (65) | Write has completed. Shutdown being performed. | 2017-05-23 06:21:15 GAIN Capital FIX Trading socket (65) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:21:15 GAIN Capital FIX Trading socket (65) | Closed. | 2017-05-23 06:21:15 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-23 06:21:18 GAIN Capital FIX Trading socket (67) | Creating socket. Using TLS 1.2. | 2017-05-23 06:21:18 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:21:18 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:21:19 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-23 06:21:19 GAIN Capital FAST Data socket (68) | Creating socket. | 2017-05-23 06:21:19 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-23 06:21:19 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-23 06:21:19 GAIN Capital FIX Trading socket (67) | Initiating close of socket by core. | 2017-05-23 06:21:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:21:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:21:19 GAIN Capital FIX Trading socket (67) | Write in progress. Shutdown being delayed. | 2017-05-23 06:21:19 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:21:19 GAIN Capital FAST Data socket (68) | Initiating close of socket by core. | 2017-05-23 06:21:19 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:21:19 GAIN Capital FAST Data socket (68) | Closed. | 2017-05-23 06:21:19 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 06:21:19 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:21:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:21:19 GAIN Capital FIX Trading socket (67) | Socket gracefully closed by remote side. | 2017-05-23 06:21:19 GAIN Capital FIX Trading socket (67) | Write has completed. Shutdown being performed. | 2017-05-23 06:21:19 GAIN Capital FIX Trading socket (67) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:21:19 GAIN Capital FIX Trading socket (67) | Closed. | 2017-05-23 06:21:19 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-23 06:21:22 GAIN Capital FIX Trading socket (69) | Creating socket. Using TLS 1.2. | 2017-05-23 06:21:22 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:21:22 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:21:22 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-23 06:21:22 GAIN Capital FAST Data socket (70) | Creating socket. | 2017-05-23 06:21:22 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-23 06:21:22 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-23 06:21:22 GAIN Capital FIX Trading socket (69) | Initiating close of socket by core. | 2017-05-23 06:21:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:21:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:21:22 GAIN Capital FIX Trading socket (69) | Write in progress. Shutdown being delayed. | 2017-05-23 06:21:22 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:21:22 GAIN Capital FAST Data socket (70) | Initiating close of socket by core. | 2017-05-23 06:21:22 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:21:22 GAIN Capital FAST Data socket (70) | Closed. | 2017-05-23 06:21:22 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 06:21:22 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:21:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:21:22 GAIN Capital FIX Trading socket (69) | Socket gracefully closed by remote side. | 2017-05-23 06:21:22 GAIN Capital FIX Trading socket (69) | Write has completed. Shutdown being performed. | 2017-05-23 06:21:22 GAIN Capital FIX Trading socket (69) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:21:22 GAIN Capital FIX Trading socket (69) | Closed. | 2017-05-23 06:21:22 File >> Disconnect selected. | 2017-05-23 06:21:24 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:21:24 GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2017-05-23 06:21:59 GAIN Capital FIX Trading socket (71) | Creating socket. | 2017-05-23 06:21:59 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:21:59 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:21:59 GAIN Capital/OEC | Connecting to market data server sim.gainfutures.com:9301. | 2017-05-23 06:21:59 GAIN Capital FAST Data socket (72) | Creating socket. | 2017-05-23 06:21:59 GAIN Capital FAST Data: Sending the Hello message. | 2017-05-23 06:21:59 GAIN Capital FAST Data: Sending the Logon message. | 2017-05-23 06:21:59 GAIN Capital/OEC | Connected to data and trading server. | 2017-05-23 06:21:59 NOTICE: Not connected to Live trading account to receive CME real-time futures data at lower cost exchange fee. | 2017-05-23 06:21:59 GAIN Capital/OEC | Starting real-time market data updates for: NQM7. ID: 1 | 2017-05-23 06:21:59 GAIN Capital/OEC | Requesting security definition data for: NQM7. ID: 1 | 2017-05-23 06:21:59 GAIN Capital/OEC | Starting real-time market data updates for: ZNM7. ID: 2 | 2017-05-23 06:21:59 GAIN Capital/OEC | Requesting security definition data for: ZNM7. ID: 2 | 2017-05-23 06:21:59 GAIN Capital/OEC | Starting real-time market data updates for: ESM7. ID: 3 | 2017-05-23 06:21:59 GAIN Capital/OEC | Requesting security definition data for: ESM7. ID: 3 | 2017-05-23 06:21:59 Intraday data recording state for symbol ESM7 is set to download 'Pending'. | 2017-05-23 06:21:59 Delaying start of download for ESM7 | 2017-05-23 06:21:59 SC DTC Data | Starting real-time market data updates for: TICK-NYSE. ID: 4 | 2017-05-23 06:21:59 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-05-23 06:21:59 DTC Client (73) | Creating socket. | 2017-05-23 06:21:59 SC DTC Data | Requesting security definition data for: TICK-NYSE. ID: 4 | 2017-05-23 06:21:59 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2017-05-23 06:21:59 Delaying start of download for ESM7 | 2017-05-23 06:21:59 SC DTC Data | Starting real-time market data updates for: ADR-SP. ID: 5 | 2017-05-23 06:21:59 SC DTC Data | Requesting security definition data for: ADR-SP. ID: 5 | 2017-05-23 06:21:59 Intraday data recording state for symbol ADR-SP is set to download 'Pending'. | 2017-05-23 06:21:59 HD Request # 13 | Downloading Intraday chart data for ESM7 to the file ESM7.scid. Service: oec | 2017-05-23 06:21:59 HD Request # 13 | Download start date-time: 2017-05-23 05:00:51.000 | 2017-05-23 06:21:59 HD Request # 13 | Using server: ds4.sierracharts.com port 10149 | 2017-05-23 06:21:59 Socket (74) | Creating socket. | 2017-05-23 06:21:59 SC DTC Data | Starting real-time market data updates for: ADR-NYSE. ID: 6 | 2017-05-23 06:22:00 SC DTC Data | Requesting security definition data for: ADR-NYSE. ID: 6 | 2017-05-23 06:22:00 Intraday data recording state for symbol ADR-NYSE is set to download 'Pending'. | 2017-05-23 06:22:00 SC DTC Data | Starting real-time market data updates for: ADR-TF. ID: 7 | 2017-05-23 06:22:00 SC DTC Data | Requesting security definition data for: ADR-TF. ID: 7 | 2017-05-23 06:22:00 Intraday data recording state for symbol ADR-TF is set to download 'Pending'. | 2017-05-23 06:22:00 Intraday data recording state for symbol ZNM7 is set to download 'Pending'. | 2017-05-23 06:22:00 SC DTC Data | Connected to server. | 2017-05-23 06:22:00 SC DTC Data | Starting socket receive thread. | 2017-05-23 06:22:00 SC DTC Data | Sending Encoding Request to server | 2017-05-23 06:22:00 GAIN Capital/OEC | Starting real-time market data updates for: EMDM7. ID: 8 | 2017-05-23 06:22:00 GAIN Capital/OEC | Requesting security definition data for: EMDM7. ID: 8 | 2017-05-23 06:22:00 Intraday data recording state for symbol EMDM7 is set to download 'Pending'. | 2017-05-23 06:22:00 Intraday data recording state for symbol NQM7 is set to download 'Pending'. | 2017-05-23 06:22:00 HD Request # 13 | Setting DTC encoding to Binary VLS | 2017-05-23 06:22:00 HD Request # 13 | Sending historical data logon request message. | 2017-05-23 06:22:00 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-23 06:22:00 SC DTC Data | Sending logon request message. | 2017-05-23 06:22:00 HD Request # 13 | Requesting Intraday data. Start date-time: 2017-05-23 05:00:51. Record interval: 0. Symbol: ESM7 | 2017-05-23 06:22:00 HD Request # 13 | Decompressing data. | 2017-05-23 06:22:00 HD Request # 13 | Receiving Intraday data for ESM7 starting at 2017-05-23 05:00:51 | 2017-05-23 06:22:00 HD Request # 13 | Timestamp of first Intraday data file record written: 2017-05-23 05:00:52 | 2017-05-23 06:22:00 Socket (74) | Initiating close of socket by core. | 2017-05-23 06:22:00 Historical data download thread signaled to stop. | 2017-05-23 06:22:00 Socket (74) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:22:00 Socket (74) | Socket gracefully closed by remote side. | 2017-05-23 06:22:00 Socket (74) | Closed. | 2017-05-23 06:22:00 HD Request # 13 | Received 8695 records from 2017-05-23 05:00:51 to 2017-05-23 06:21:54 (81.0 minutes) and wrote 8694 records for ESM7 | 2017-05-23 06:22:00 HD Request # 13 | Intraday download COMPLETE for ESM7. Completion time: 0s. Unique request ID: 12 | 2017-05-23 06:22:00 Removed historical data download ID 12 | 2017-05-23 06:22:00 Real-time Intraday chart data file updates started for ESM7 | 2017-05-23 06:22:00 Intraday chart data file opened for ESM7 | 2017-05-23 06:22:00 Delaying start of download for TICK-NYSE | 2017-05-23 06:22:00 SC DTC Data | Received logon response. | 2017-05-23 06:22:00 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-23 06:22:00 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-23 06:22:00 SC DTC Data | Successfully connected. | 2017-05-23 06:22:00 SC DTC Data | Trading is not supported. | 2017-05-23 06:22:00 SC DTC Data | Restarting real-time data updates for symbol: ADR-NYSE | 2017-05-23 06:22:00 SC DTC Data | Restarting real-time data updates for symbol: ADR-SP | 2017-05-23 06:22:00 SC DTC Data | Restarting real-time data updates for symbol: ADR-TF | 2017-05-23 06:22:00 SC DTC Data | Restarting real-time data updates for symbol: TICK-NYSE | 2017-05-23 06:22:00 SC DTC Data | Received security definition for symbol ADR-NYSE | 2017-05-23 06:22:00 SC DTC Data | Received security definition for symbol ADR-SP | 2017-05-23 06:22:00 SC DTC Data | Received security definition for symbol ADR-TF | 2017-05-23 06:22:00 SC DTC Data | Received security definition for symbol TICK-NYSE | 2017-05-23 06:22:00 Delaying start of download for TICK-NYSE | 2017-05-23 06:22:01 Opened cached Intraday file: C:\SierraChart NS\Data\ESM7.scid | 2017-05-23 06:22:04 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2017-05-23 06:22:04 HD Request # 14 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2017-05-23 06:22:05 HD Request # 14 | Download start date-time: 2017-05-23 05:11:12.000 | 2017-05-23 06:22:05 HD Request # 14 | Using server: ds3.sierracharts.com port 10149 | 2017-05-23 06:22:05 Socket (75) | Creating socket. | 2017-05-23 06:22:05 HD Request # 14 | Setting DTC encoding to Binary VLS | 2017-05-23 06:22:05 HD Request # 14 | Sending historical data logon request message. | 2017-05-23 06:22:05 HD Request # 14 | Requesting Intraday data. Start date-time: 2017-05-23 05:11:12. Record interval: 0. Symbol: TICK-NYSE | 2017-05-23 06:22:06 HD Request # 14 | Decompressing data. | 2017-05-23 06:22:06 HD Request # 14 | Receiving Intraday data for TICK-NYSE starting at 2017-05-23 05:11:12 | 2017-05-23 06:22:06 HD Request # 14 | Timestamp of first Intraday data file record written: 2017-05-23 05:11:13 | 2017-05-23 06:22:06 Socket (75) | Initiating close of socket by core. | 2017-05-23 06:22:06 Historical data download thread signaled to stop. | 2017-05-23 06:22:06 Socket (75) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:22:06 Socket (75) | Socket gracefully closed by remote side. | 2017-05-23 06:22:06 Socket (75) | Closed. | 2017-05-23 06:22:06 HD Request # 14 | Received 3659 records from 2017-05-23 05:11:12 to 2017-05-23 06:22:04 (70.9 minutes) and wrote 3658 records for TICK-NYSE | 2017-05-23 06:22:06 Added 11 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2017-05-23 06:22:06 HD Request # 14 | Intraday download COMPLETE for TICK-NYSE. Completion time: 0s. Unique request ID: 13 | 2017-05-23 06:22:06 Removed historical data download ID 13 | 2017-05-23 06:22:06 Real-time Intraday chart data file updates started for TICK-NYSE | 2017-05-23 06:22:06 Intraday chart data file opened for TICK-NYSE | 2017-05-23 06:22:06 HD Request # 15 | Downloading Intraday chart data for ADR-SP to the file ADR-SP.scid. Service: statscalc | 2017-05-23 06:22:06 HD Request # 15 | Download start date-time: 2017-05-23 05:10:50.000 | 2017-05-23 06:22:06 HD Request # 15 | Using server: ds4.sierracharts.com port 10149 | 2017-05-23 06:22:06 Socket (76) | Creating socket. | 2017-05-23 06:22:06 HD Request # 15 | Setting DTC encoding to Binary VLS | 2017-05-23 06:22:06 HD Request # 15 | Sending historical data logon request message. | 2017-05-23 06:22:06 HD Request # 15 | Requesting Intraday data. Start date-time: 2017-05-23 05:10:50. Record interval: 0. Symbol: ADR-SP | 2017-05-23 06:22:06 HD Request # 15 | Decompressing data. | 2017-05-23 06:22:06 HD Request # 15 | Receiving Intraday data for ADR-SP starting at 2017-05-23 05:10:50 | 2017-05-23 06:22:06 HD Request # 15 | Timestamp of first Intraday data file record written: 2017-05-23 05:10:52 | 2017-05-23 06:22:06 Socket (76) | Initiating close of socket by core. | 2017-05-23 06:22:06 Socket (76) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:22:06 Socket (76) | Socket gracefully closed by remote side. | 2017-05-23 06:22:06 Historical data download thread signaled to stop. | 2017-05-23 06:22:06 Socket (76) | Closed. | 2017-05-23 06:22:06 HD Request # 15 | Received 3673 records from 2017-05-23 05:10:50 to 2017-05-23 06:22:03 (71.2 minutes) and wrote 3672 records for ADR-SP | 2017-05-23 06:22:06 Added 23 Time and Sales records to Intraday data file for ADR-SP after download. | 2017-05-23 06:22:06 HD Request # 15 | Intraday download COMPLETE for ADR-SP. Completion time: 0s. Unique request ID: 14 | 2017-05-23 06:22:06 Removed historical data download ID 14 | 2017-05-23 06:22:06 Real-time Intraday chart data file updates started for ADR-SP | 2017-05-23 06:22:06 Intraday chart data file opened for ADR-SP | 2017-05-23 06:22:06 HD Request # 16 | Downloading Intraday chart data for ADR-NYSE to the file ADR-NYSE.scid. Service: statscalc | 2017-05-23 06:22:06 HD Request # 16 | Download start date-time: 2017-05-22 16:59:59.000 | 2017-05-23 06:22:06 HD Request # 16 | Using server: ds3.sierracharts.com port 10149 | 2017-05-23 06:22:06 Socket (77) | Creating socket. | 2017-05-23 06:22:06 HD Request # 16 | Setting DTC encoding to Binary VLS | 2017-05-23 06:22:07 HD Request # 16 | Sending historical data logon request message. | 2017-05-23 06:22:07 HD Request # 16 | Requesting Intraday data. Start date-time: 2017-05-22 16:59:59. Record interval: 0. Symbol: ADR-NYSE | 2017-05-23 06:22:07 HD Request # 16 | Decompressing data. | 2017-05-23 06:22:07 HD Request # 16 | Receiving Intraday data for ADR-NYSE starting at 2017-05-22 16:59:59 | 2017-05-23 06:22:07 HD Request # 16 | Timestamp of first Intraday data file record written: 2017-05-23 05:24:15 | 2017-05-23 06:22:07 Socket (77) | Initiating close of socket by core. | 2017-05-23 06:22:07 Historical data download thread signaled to stop. | 2017-05-23 06:22:07 Socket (77) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:22:07 Socket (77) | Socket gracefully closed by remote side. | 2017-05-23 06:22:07 Socket (77) | Closed. | 2017-05-23 06:22:07 HD Request # 16 | Received 3120 records from 2017-05-22 16:59:59 to 2017-05-23 06:22:04 (13.4 hours) and wrote 3119 records for ADR-NYSE | 2017-05-23 06:22:07 Added 17 Time and Sales records to Intraday data file for ADR-NYSE after download. | 2017-05-23 06:22:07 HD Request # 16 | Intraday download COMPLETE for ADR-NYSE. Completion time: 1s. Unique request ID: 15 | 2017-05-23 06:22:07 Removed historical data download ID 15 | 2017-05-23 06:22:07 Real-time Intraday chart data file updates started for ADR-NYSE | 2017-05-23 06:22:07 Intraday chart data file opened for ADR-NYSE | 2017-05-23 06:22:07 HD Request # 17 | Downloading Intraday chart data for ADR-TF to the file ADR-TF.scid. Service: statscalc | 2017-05-23 06:22:07 HD Request # 17 | Download start date-time: 2017-05-23 05:11:13.000 | 2017-05-23 06:22:07 HD Request # 17 | Using server: ds4.sierracharts.com port 10149 | 2017-05-23 06:22:07 Socket (78) | Creating socket. | 2017-05-23 06:22:07 HD Request # 17 | Setting DTC encoding to Binary VLS | 2017-05-23 06:22:08 HD Request # 17 | Sending historical data logon request message. | 2017-05-23 06:22:08 HD Request # 17 | Requesting Intraday data. Start date-time: 2017-05-23 05:11:13. Record interval: 0. Symbol: ADR-TF | 2017-05-23 06:22:08 HD Request # 17 | Decompressing data. | 2017-05-23 06:22:08 HD Request # 17 | Receiving Intraday data for ADR-TF starting at 2017-05-23 05:11:13 | 2017-05-23 06:22:08 HD Request # 17 | Timestamp of first Intraday data file record written: 2017-05-23 05:11:17 | 2017-05-23 06:22:08 Socket (78) | Initiating close of socket by core. | 2017-05-23 06:22:08 Socket (78) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:22:08 Socket (78) | Socket gracefully closed by remote side. | 2017-05-23 06:22:08 Socket (78) | Closed. | 2017-05-23 06:22:08 Historical data download thread signaled to stop. | 2017-05-23 06:22:08 HD Request # 17 | Received 3659 records from 2017-05-23 05:11:13 to 2017-05-23 06:22:05 (70.9 minutes) and wrote 3658 records for ADR-TF | 2017-05-23 06:22:08 Added 8 Time and Sales records to Intraday data file for ADR-TF after download. | 2017-05-23 06:22:08 HD Request # 17 | Intraday download COMPLETE for ADR-TF. Completion time: 1s. Unique request ID: 16 | 2017-05-23 06:22:08 Removed historical data download ID 16 | 2017-05-23 06:22:08 Real-time Intraday chart data file updates started for ADR-TF | 2017-05-23 06:22:08 Intraday chart data file opened for ADR-TF | 2017-05-23 06:22:08 HD Request # 18 | Downloading Intraday chart data for ZNM7 to the file ZNM7.scid. Service: oec | 2017-05-23 06:22:08 HD Request # 18 | Download start date-time: 2017-05-23 05:00:41.000 | 2017-05-23 06:22:08 HD Request # 18 | Using server: ds3.sierracharts.com port 10149 | 2017-05-23 06:22:08 Socket (79) | Creating socket. | 2017-05-23 06:22:08 HD Request # 18 | Setting DTC encoding to Binary VLS | 2017-05-23 06:22:08 HD Request # 18 | Sending historical data logon request message. | 2017-05-23 06:22:08 HD Request # 18 | Requesting Intraday data. Start date-time: 2017-05-23 05:00:41. Record interval: 0. Symbol: ZNM7 | 2017-05-23 06:22:08 HD Request # 18 | Decompressing data. | 2017-05-23 06:22:08 HD Request # 18 | Receiving Intraday data for ZNM7 starting at 2017-05-23 05:00:41 | 2017-05-23 06:22:09 HD Request # 18 | Timestamp of first Intraday data file record written: 2017-05-23 05:01:19 | 2017-05-23 06:22:09 Socket (79) | Initiating close of socket by core. | 2017-05-23 06:22:09 Historical data download thread signaled to stop. | 2017-05-23 06:22:09 Socket (79) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:22:09 Socket (79) | Socket gracefully closed by remote side. | 2017-05-23 06:22:09 Socket (79) | Closed. | 2017-05-23 06:22:09 HD Request # 18 | Received 13048 records from 2017-05-23 05:00:41 to 2017-05-23 06:22:04 (81.4 minutes) and wrote 13047 records for ZNM7 | 2017-05-23 06:22:09 HD Request # 18 | Intraday download COMPLETE for ZNM7. Completion time: 0s. Unique request ID: 17 | 2017-05-23 06:22:09 Removed historical data download ID 17 | 2017-05-23 06:22:09 Real-time Intraday chart data file updates started for ZNM7 | 2017-05-23 06:22:09 Intraday chart data file opened for ZNM7 | 2017-05-23 06:22:09 HD Request # 19 | Downloading Intraday chart data for EMDM7 to the file EMDM7.scid. Service: oec | 2017-05-23 06:22:09 HD Request # 19 | Download start date-time: 2017-05-23 05:00:21.000 | 2017-05-23 06:22:09 HD Request # 19 | Using server: ds4.sierracharts.com port 10149 | 2017-05-23 06:22:09 Socket (80) | Creating socket. | 2017-05-23 06:22:09 HD Request # 19 | Setting DTC encoding to Binary VLS | 2017-05-23 06:22:09 HD Request # 19 | Sending historical data logon request message. | 2017-05-23 06:22:09 HD Request # 19 | Requesting Intraday data. Start date-time: 2017-05-23 05:00:21. Record interval: 0. Symbol: EMDM7 | 2017-05-23 06:22:09 HD Request # 19 | Decompressing data. | 2017-05-23 06:22:09 HD Request # 19 | Receiving Intraday data for EMDM7 starting at 2017-05-23 05:00:21 | 2017-05-23 06:22:09 HD Request # 19 | Timestamp of first Intraday data file record written: 2017-05-23 05:01:05 | 2017-05-23 06:22:09 Socket (80) | Initiating close of socket by core. | 2017-05-23 06:22:09 Socket (80) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:22:09 Socket (80) | Socket gracefully closed by remote side. | 2017-05-23 06:22:09 Socket (80) | Closed. | 2017-05-23 06:22:09 Historical data download thread signaled to stop. | 2017-05-23 06:22:09 HD Request # 19 | Received 252 records from 2017-05-23 05:00:21 to 2017-05-23 06:22:00 (81.7 minutes) and wrote 250 records for EMDM7 | 2017-05-23 06:22:09 HD Request # 19 | Intraday download COMPLETE for EMDM7. Completion time: 0s. Unique request ID: 18 | 2017-05-23 06:22:09 Removed historical data download ID 18 | 2017-05-23 06:22:09 Real-time Intraday chart data file updates started for EMDM7 | 2017-05-23 06:22:09 Intraday chart data file opened for EMDM7 | 2017-05-23 06:22:09 HD Request # 20 | Downloading Intraday chart data for NQM7 to the file NQM7.scid. Service: oec | 2017-05-23 06:22:09 HD Request # 20 | Download start date-time: 2017-05-23 05:00:50.000 | 2017-05-23 06:22:09 HD Request # 20 | Using server: ds3.sierracharts.com port 10149 | 2017-05-23 06:22:09 Socket (81) | Creating socket. | 2017-05-23 06:22:09 HD Request # 20 | Setting DTC encoding to Binary VLS | 2017-05-23 06:22:09 HD Request # 20 | Sending historical data logon request message. | 2017-05-23 06:22:09 HD Request # 20 | Requesting Intraday data. Start date-time: 2017-05-23 05:00:50. Record interval: 0. Symbol: NQM7 | 2017-05-23 06:22:09 HD Request # 20 | Decompressing data. | 2017-05-23 06:22:09 HD Request # 20 | Receiving Intraday data for NQM7 starting at 2017-05-23 05:00:50 | 2017-05-23 06:22:09 HD Request # 20 | Timestamp of first Intraday data file record written: 2017-05-23 05:01:00 | 2017-05-23 06:22:09 Socket (81) | Initiating close of socket by core. | 2017-05-23 06:22:10 Socket (81) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:22:10 Socket (81) | Socket gracefully closed by remote side. | 2017-05-23 06:22:10 Socket (81) | Closed. | 2017-05-23 06:22:10 Historical data download thread signaled to stop. | 2017-05-23 06:22:10 HD Request # 20 | Received 4080 records from 2017-05-23 05:00:50 to 2017-05-23 06:22:00 (81.2 minutes) and wrote 4076 records for NQM7 | 2017-05-23 06:22:10 HD Request # 20 | Intraday download COMPLETE for NQM7. Completion time: 1s. Unique request ID: 19 | 2017-05-23 06:22:10 Removed historical data download ID 19 | 2017-05-23 06:22:10 Real-time Intraday chart data file updates started for NQM7 | 2017-05-23 06:22:10 Intraday chart data file opened for NQM7 | 2017-05-23 06:22:10 Opened cached Intraday file: C:\SierraChart NS\Data\TICK-NYSE.scid | 2017-05-23 06:22:14 Opened cached Intraday file: C:\SierraChart NS\Data\ADR-SP.scid | 2017-05-23 06:22:14 Opened cached Intraday file: C:\SierraChart NS\Data\ADR-NYSE.scid | 2017-05-23 06:22:14 Opened cached Intraday file: C:\SierraChart NS\Data\ADR-TF.scid | 2017-05-23 06:22:14 Opened cached Intraday file: C:\SierraChart NS\Data\NQM7.scid | 2017-05-23 06:22:24 Opened cached Intraday file: C:\SierraChart NS\Data\ZNM7.scid | 2017-05-23 06:22:34 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-05-23 06:22:40 GAIN Capital FIX Trading: Sending a Logout message. | 2017-05-23 06:22:40 GAIN Capital FAST Data: Sending a Logout message. | 2017-05-23 06:22:40 DTC Client (73) | 16 bytes remaining in receive buffer when socket closed. | 2017-05-23 06:22:40 DTC Client (73) | Initiating close of socket by core. | 2017-05-23 06:22:40 SC DTC Data | Disconnected from the server. | 2017-05-23 06:22:40 DTC Client (73) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:22:40 DTC Client (73) | Socket gracefully closed by remote side. | 2017-05-23 06:22:40 DTC Client (73) | Closed. | 2017-05-23 06:22:40 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:22:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:22:40 GAIN Capital FAST Data socket (72) | Socket gracefully closed by remote side. | 2017-05-23 06:22:40 GAIN Capital FAST Data socket (72) | Received socket Close event | 2017-05-23 06:22:40 GAIN Capital FIX Trading socket (71) | Socket gracefully closed by remote side. | 2017-05-23 06:22:40 GAIN Capital FIX Trading socket (71) | Received socket Close event | 2017-05-23 06:22:40 GAIN Capital FIX Trading: Received a Logout message. | 2017-05-23 06:22:40 GAIN Capital FIX Trading socket (71) | Initiating close of socket by core. | 2017-05-23 06:22:40 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:22:40 GAIN Capital FIX Trading socket (71) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:22:40 GAIN Capital FIX Trading socket (71) | Closed. | 2017-05-23 06:22:40 GAIN Capital FAST Data socket (72) | Initiating close of socket by core. | 2017-05-23 06:22:40 GAIN Capital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2017-05-23 06:22:40 GAIN Capital FAST Data socket (72) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:22:40 GAIN Capital FAST Data socket (72) | Closed. | 2017-05-23 06:22:40 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 06:22:40 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-23 06:22:43 GAIN Capital FIX Trading socket (83) | Creating socket. Using TLS 1.2. | 2017-05-23 06:22:43 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:22:43 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:22:43 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-23 06:22:43 GAIN Capital FAST Data socket (84) | Creating socket. | 2017-05-23 06:22:43 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-23 06:22:43 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-23 06:22:43 GAIN Capital FIX Trading socket (83) | Initiating close of socket by core. | 2017-05-23 06:22:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:22:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:22:43 GAIN Capital FIX Trading socket (83) | Write in progress. Shutdown being delayed. | 2017-05-23 06:22:43 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:22:43 GAIN Capital FAST Data socket (84) | Initiating close of socket by core. | 2017-05-23 06:22:43 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:22:43 GAIN Capital FAST Data socket (84) | Closed. | 2017-05-23 06:22:43 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 06:22:43 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:22:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:22:43 GAIN Capital FIX Trading socket (83) | Socket gracefully closed by remote side. | 2017-05-23 06:22:43 GAIN Capital FIX Trading socket (83) | Write has completed. Shutdown being performed. | 2017-05-23 06:22:43 GAIN Capital FIX Trading socket (83) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:22:43 GAIN Capital FIX Trading socket (83) | Closed. | 2017-05-23 06:22:43 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-23 06:22:46 GAIN Capital FIX Trading socket (85) | Creating socket. Using TLS 1.2. | 2017-05-23 06:22:46 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:22:46 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:22:46 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-23 06:22:46 GAIN Capital FAST Data socket (86) | Creating socket. | 2017-05-23 06:22:46 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-23 06:22:46 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-23 06:22:46 GAIN Capital FIX Trading socket (85) | Initiating close of socket by core. | 2017-05-23 06:22:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:22:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:22:46 GAIN Capital FIX Trading socket (85) | Write in progress. Shutdown being delayed. | 2017-05-23 06:22:46 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:22:46 GAIN Capital FAST Data socket (86) | Initiating close of socket by core. | 2017-05-23 06:22:46 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:22:46 GAIN Capital FAST Data socket (86) | Closed. | 2017-05-23 06:22:46 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 06:22:46 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:22:46 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:22:46 GAIN Capital FIX Trading socket (85) | Socket gracefully closed by remote side. | 2017-05-23 06:22:46 GAIN Capital FIX Trading socket (85) | Write has completed. Shutdown being performed. | 2017-05-23 06:22:46 GAIN Capital FIX Trading socket (85) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:22:46 GAIN Capital FIX Trading socket (85) | Closed. | 2017-05-23 06:22:46 File >> Disconnect selected. | 2017-05-23 06:22:48 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:22:48 GAIN Capital/OEC | Connecting to trading server api.gainfutures.com. Port: 9400. | 2017-05-23 06:23:27 GAIN Capital FIX Trading socket (87) | Creating socket. Using TLS 1.2. | 2017-05-23 06:23:27 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:23:27 GAIN Capital FIX Trading socket (87) | Socket gracefully closed by remote side. | 2017-05-23 06:23:27 GAIN Capital FIX Trading socket (87) | Received socket Close event | 2017-05-23 06:23:27 GAIN Capital FIX Trading socket (87) | Initiating close of socket by core. | 2017-05-23 06:23:27 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:23:27 GAIN Capital FIX Trading socket (87) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:23:27 GAIN Capital FIX Trading socket (87) | Closed. | 2017-05-23 06:23:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:23:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:23:27 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:23:27 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:23:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:23:27 GAIN Capital/OEC | Connecting to trading server api.gainfutures.com. Port: 9400. | 2017-05-23 06:23:30 GAIN Capital FIX Trading socket (88) | Creating socket. Using TLS 1.2. | 2017-05-23 06:23:30 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:23:30 GAIN Capital FIX Trading socket (88) | Socket gracefully closed by remote side. | 2017-05-23 06:23:30 GAIN Capital FIX Trading socket (88) | Received socket Close event | 2017-05-23 06:23:30 GAIN Capital FIX Trading socket (88) | Initiating close of socket by core. | 2017-05-23 06:23:30 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:23:30 GAIN Capital FIX Trading socket (88) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:23:30 GAIN Capital FIX Trading socket (88) | Closed. | 2017-05-23 06:23:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:23:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:23:30 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:23:30 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:23:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:23:30 GAIN Capital/OEC | Connecting to trading server api.gainfutures.com. Port: 9400. | 2017-05-23 06:23:33 GAIN Capital FIX Trading socket (89) | Creating socket. Using TLS 1.2. | 2017-05-23 06:23:33 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:23:34 GAIN Capital FIX Trading socket (89) | Socket gracefully closed by remote side. | 2017-05-23 06:23:34 GAIN Capital FIX Trading socket (89) | Received socket Close event | 2017-05-23 06:23:34 GAIN Capital FIX Trading socket (89) | Initiating close of socket by core. | 2017-05-23 06:23:34 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:23:34 GAIN Capital FIX Trading socket (89) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:23:34 GAIN Capital FIX Trading socket (89) | Closed. | 2017-05-23 06:23:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:23:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:23:34 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:23:34 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:23:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:23:34 GAIN Capital/OEC | Connecting to trading server api.gainfutures.com. Port: 9400. | 2017-05-23 06:23:37 GAIN Capital FIX Trading socket (90) | Creating socket. Using TLS 1.2. | 2017-05-23 06:23:37 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:23:37 GAIN Capital FIX Trading socket (90) | Socket gracefully closed by remote side. | 2017-05-23 06:23:37 GAIN Capital FIX Trading socket (90) | Received socket Close event | 2017-05-23 06:23:37 GAIN Capital FIX Trading socket (90) | Initiating close of socket by core. | 2017-05-23 06:23:37 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:23:37 GAIN Capital FIX Trading socket (90) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:23:37 GAIN Capital FIX Trading socket (90) | Closed. | 2017-05-23 06:23:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:23:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:23:37 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:23:37 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:23:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:23:37 File >> Disconnect selected. | 2017-05-23 06:23:40 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:23:40 GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2017-05-23 06:24:43 GAIN Capital FIX Trading socket (92) | Creating socket. | 2017-05-23 06:24:43 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:24:43 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:24:43 GAIN Capital/OEC | Connecting to market data server sim.gainfutures.com:9301. | 2017-05-23 06:24:43 GAIN Capital FAST Data socket (93) | Creating socket. | 2017-05-23 06:24:43 GAIN Capital FAST Data: Sending the Hello message. | 2017-05-23 06:24:43 GAIN Capital FAST Data: Sending the Logon message. | 2017-05-23 06:24:43 GAIN Capital/OEC | Connected to data and trading server. | 2017-05-23 06:24:43 NOTICE: Not connected to Live trading account to receive CME real-time futures data at lower cost exchange fee. | 2017-05-23 06:24:43 GAIN Capital/OEC | Starting real-time market data updates for: ZNM7. ID: 1 | 2017-05-23 06:24:43 GAIN Capital/OEC | Requesting security definition data for: ZNM7. ID: 1 | 2017-05-23 06:24:43 GAIN Capital/OEC | Starting real-time market data updates for: ESM7. ID: 2 | 2017-05-23 06:24:43 GAIN Capital/OEC | Requesting security definition data for: ESM7. ID: 2 | 2017-05-23 06:24:43 Intraday data recording state for symbol ESM7 is set to download 'Pending'. | 2017-05-23 06:24:43 Delaying start of download for ESM7 | 2017-05-23 06:24:43 SC DTC Data | Starting real-time market data updates for: TICK-NYSE. ID: 3 | 2017-05-23 06:24:44 SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2017-05-23 06:24:44 SC DTC Data | Requesting security definition data for: TICK-NYSE. ID: 3 | 2017-05-23 06:24:44 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2017-05-23 06:24:44 DTC Client (94) | Creating socket. | 2017-05-23 06:24:44 SC DTC Data | Starting real-time market data updates for: ADR-SP. ID: 4 | 2017-05-23 06:24:44 SC DTC Data | Requesting security definition data for: ADR-SP. ID: 4 | 2017-05-23 06:24:44 Intraday data recording state for symbol ADR-SP is set to download 'Pending'. | 2017-05-23 06:24:44 SC DTC Data | Starting real-time market data updates for: ADR-NYSE. ID: 5 | 2017-05-23 06:24:44 SC DTC Data | Requesting security definition data for: ADR-NYSE. ID: 5 | 2017-05-23 06:24:44 Intraday data recording state for symbol ADR-NYSE is set to download 'Pending'. | 2017-05-23 06:24:44 SC DTC Data | Starting real-time market data updates for: ADR-TF. ID: 6 | 2017-05-23 06:24:44 SC DTC Data | Requesting security definition data for: ADR-TF. ID: 6 | 2017-05-23 06:24:44 Intraday data recording state for symbol ADR-TF is set to download 'Pending'. | 2017-05-23 06:24:44 Intraday data recording state for symbol ZNM7 is set to download 'Pending'. | 2017-05-23 06:24:44 SC DTC Data | Connected to server. | 2017-05-23 06:24:44 SC DTC Data | Starting socket receive thread. | 2017-05-23 06:24:44 SC DTC Data | Sending Encoding Request to server | 2017-05-23 06:24:44 GAIN Capital/OEC | Starting real-time market data updates for: EMDM7. ID: 7 | 2017-05-23 06:24:44 GAIN Capital/OEC | Requesting security definition data for: EMDM7. ID: 7 | 2017-05-23 06:24:44 Intraday data recording state for symbol EMDM7 is set to download 'Pending'. | 2017-05-23 06:24:44 Delaying start of download for ESM7 | 2017-05-23 06:24:44 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-23 06:24:44 SC DTC Data | Sending logon request message. | 2017-05-23 06:24:44 GAIN Capital/OEC | Starting real-time market data updates for: NQM7. ID: 8 | 2017-05-23 06:24:44 GAIN Capital/OEC | Requesting security definition data for: NQM7. ID: 8 | 2017-05-23 06:24:44 Intraday data recording state for symbol NQM7 is set to download 'Pending'. | 2017-05-23 06:24:44 HD Request # 21 | Downloading Intraday chart data for ESM7 to the file ESM7.scid. Service: oec | 2017-05-23 06:24:44 HD Request # 21 | Download start date-time: 2017-05-23 06:22:34.000 | 2017-05-23 06:24:44 HD Request # 21 | Using server: ds4.sierracharts.com port 10149 | 2017-05-23 06:24:44 Socket (95) | Creating socket. | 2017-05-23 06:24:44 HD Request # 21 | Setting DTC encoding to Binary VLS | 2017-05-23 06:24:44 HD Request # 21 | Sending historical data logon request message. | 2017-05-23 06:24:44 SC DTC Data | Received logon response. | 2017-05-23 06:24:44 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-23 06:24:44 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-23 06:24:44 SC DTC Data | Successfully connected. | 2017-05-23 06:24:44 SC DTC Data | Trading is not supported. | 2017-05-23 06:24:44 SC DTC Data | Restarting real-time data updates for symbol: ADR-NYSE | 2017-05-23 06:24:44 SC DTC Data | Restarting real-time data updates for symbol: ADR-SP | 2017-05-23 06:24:44 SC DTC Data | Restarting real-time data updates for symbol: ADR-TF | 2017-05-23 06:24:44 SC DTC Data | Restarting real-time data updates for symbol: TICK-NYSE | 2017-05-23 06:24:44 HD Request # 21 | Requesting Intraday data. Start date-time: 2017-05-23 06:22:34. Record interval: 0. Symbol: ESM7 | 2017-05-23 06:24:44 SC DTC Data | Received security definition for symbol ADR-NYSE | 2017-05-23 06:24:44 HD Request # 21 | Decompressing data. | 2017-05-23 06:24:44 HD Request # 21 | Receiving Intraday data for ESM7 starting at 2017-05-23 06:22:34 | 2017-05-23 06:24:44 HD Request # 21 | Timestamp of first Intraday data file record written: 2017-05-23 06:22:41 | 2017-05-23 06:24:44 Socket (95) | Initiating close of socket by core. | 2017-05-23 06:24:44 Socket (95) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:24:44 Socket (95) | Socket gracefully closed by remote side. | 2017-05-23 06:24:44 Historical data download thread signaled to stop. | 2017-05-23 06:24:44 Socket (95) | Closed. | 2017-05-23 06:24:44 HD Request # 21 | Received 356 records from 2017-05-23 06:22:34 to 2017-05-23 06:24:40 (2.1 minutes) and wrote 355 records for ESM7 | 2017-05-23 06:24:44 HD Request # 21 | Intraday download COMPLETE for ESM7. Completion time: 0s. Unique request ID: 20 | 2017-05-23 06:24:44 Removed historical data download ID 20 | 2017-05-23 06:24:44 Real-time Intraday chart data file updates started for ESM7 | 2017-05-23 06:24:44 Intraday chart data file opened for ESM7 | 2017-05-23 06:24:44 Delaying start of download for TICK-NYSE | 2017-05-23 06:24:44 SC DTC Data | Received security definition for symbol ADR-SP | 2017-05-23 06:24:44 SC DTC Data | Received security definition for symbol ADR-TF | 2017-05-23 06:24:44 SC DTC Data | Received security definition for symbol TICK-NYSE | 2017-05-23 06:24:44 Delaying start of download for TICK-NYSE | 2017-05-23 06:24:45 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2017-05-23 06:24:48 HD Request # 22 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2017-05-23 06:24:49 HD Request # 22 | Download start date-time: 2017-05-23 06:22:38.000 | 2017-05-23 06:24:49 HD Request # 22 | Using server: ds3.sierracharts.com port 10149 | 2017-05-23 06:24:49 Socket (96) | Creating socket. | 2017-05-23 06:24:49 HD Request # 22 | Setting DTC encoding to Binary VLS | 2017-05-23 06:24:49 HD Request # 22 | Sending historical data logon request message. | 2017-05-23 06:24:49 HD Request # 22 | Requesting Intraday data. Start date-time: 2017-05-23 06:22:38. Record interval: 0. Symbol: TICK-NYSE | 2017-05-23 06:24:49 HD Request # 22 | Decompressing data. | 2017-05-23 06:24:49 HD Request # 22 | Receiving Intraday data for TICK-NYSE starting at 2017-05-23 06:22:38 | 2017-05-23 06:24:49 HD Request # 22 | Timestamp of first Intraday data file record written: 2017-05-23 06:22:39 | 2017-05-23 06:24:49 Socket (96) | Initiating close of socket by core. | 2017-05-23 06:24:49 Socket (96) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:24:49 Socket (96) | Socket gracefully closed by remote side. | 2017-05-23 06:24:49 Historical data download thread signaled to stop. | 2017-05-23 06:24:49 Socket (96) | Closed. | 2017-05-23 06:24:49 HD Request # 22 | Received 130 records from 2017-05-23 06:22:38 to 2017-05-23 06:24:47 (2.1 minutes) and wrote 129 records for TICK-NYSE | 2017-05-23 06:24:49 Added 9 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2017-05-23 06:24:49 HD Request # 22 | Intraday download COMPLETE for TICK-NYSE. Completion time: 1s. Unique request ID: 21 | 2017-05-23 06:24:49 Removed historical data download ID 21 | 2017-05-23 06:24:49 Real-time Intraday chart data file updates started for TICK-NYSE | 2017-05-23 06:24:49 Intraday chart data file opened for TICK-NYSE | 2017-05-23 06:24:49 Delaying start of download for ADR-SP | 2017-05-23 06:24:49 HD Request # 23 | Downloading Intraday chart data for ADR-SP to the file ADR-SP.scid. Service: statscalc | 2017-05-23 06:24:49 HD Request # 23 | Download start date-time: 2017-05-23 06:22:38.000 | 2017-05-23 06:24:49 HD Request # 23 | Using server: ds4.sierracharts.com port 10149 | 2017-05-23 06:24:49 Socket (97) | Creating socket. | 2017-05-23 06:24:49 HD Request # 23 | Setting DTC encoding to Binary VLS | 2017-05-23 06:24:49 HD Request # 23 | Sending historical data logon request message. | 2017-05-23 06:24:49 HD Request # 23 | Requesting Intraday data. Start date-time: 2017-05-23 06:22:38. Record interval: 0. Symbol: ADR-SP | 2017-05-23 06:24:49 HD Request # 23 | Decompressing data. | 2017-05-23 06:24:49 HD Request # 23 | Receiving Intraday data for ADR-SP starting at 2017-05-23 06:22:38 | 2017-05-23 06:24:49 HD Request # 23 | Timestamp of first Intraday data file record written: 2017-05-23 06:22:39 | 2017-05-23 06:24:49 Socket (97) | Initiating close of socket by core. | 2017-05-23 06:24:49 Socket (97) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:24:49 Socket (97) | Socket gracefully closed by remote side. | 2017-05-23 06:24:49 Socket (97) | Closed. | 2017-05-23 06:24:49 Historical data download thread signaled to stop. | 2017-05-23 06:24:49 HD Request # 23 | Received 129 records from 2017-05-23 06:22:38 to 2017-05-23 06:24:46 (2.1 minutes) and wrote 128 records for ADR-SP | 2017-05-23 06:24:49 Added 17 Time and Sales records to Intraday data file for ADR-SP after download. | 2017-05-23 06:24:49 HD Request # 23 | Intraday download COMPLETE for ADR-SP. Completion time: 0s. Unique request ID: 22 | 2017-05-23 06:24:49 Removed historical data download ID 22 | 2017-05-23 06:24:49 Real-time Intraday chart data file updates started for ADR-SP | 2017-05-23 06:24:49 Intraday chart data file opened for ADR-SP | 2017-05-23 06:24:49 HD Request # 24 | Downloading Intraday chart data for ADR-NYSE to the file ADR-NYSE.scid. Service: statscalc | 2017-05-23 06:24:49 HD Request # 24 | Download start date-time: 2017-05-23 06:22:38.000 | 2017-05-23 06:24:49 HD Request # 24 | Using server: ds3.sierracharts.com port 10149 | 2017-05-23 06:24:49 Socket (98) | Creating socket. | 2017-05-23 06:24:49 HD Request # 24 | Setting DTC encoding to Binary VLS | 2017-05-23 06:24:50 HD Request # 24 | Sending historical data logon request message. | 2017-05-23 06:24:50 HD Request # 24 | Requesting Intraday data. Start date-time: 2017-05-23 06:22:38. Record interval: 0. Symbol: ADR-NYSE | 2017-05-23 06:24:50 HD Request # 24 | Decompressing data. | 2017-05-23 06:24:50 HD Request # 24 | Receiving Intraday data for ADR-NYSE starting at 2017-05-23 06:22:38 | 2017-05-23 06:24:50 HD Request # 24 | Timestamp of first Intraday data file record written: 2017-05-23 06:22:39 | 2017-05-23 06:24:50 Socket (98) | Initiating close of socket by core. | 2017-05-23 06:24:50 Historical data download thread signaled to stop. | 2017-05-23 06:24:50 Socket (98) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:24:50 Socket (98) | Socket gracefully closed by remote side. | 2017-05-23 06:24:50 Socket (98) | Closed. | 2017-05-23 06:24:50 HD Request # 24 | Received 130 records from 2017-05-23 06:22:38 to 2017-05-23 06:24:47 (2.1 minutes) and wrote 129 records for ADR-NYSE | 2017-05-23 06:24:50 Added 22 Time and Sales records to Intraday data file for ADR-NYSE after download. | 2017-05-23 06:24:50 HD Request # 24 | Intraday download COMPLETE for ADR-NYSE. Completion time: 0s. Unique request ID: 23 | 2017-05-23 06:24:50 Removed historical data download ID 23 | 2017-05-23 06:24:50 Real-time Intraday chart data file updates started for ADR-NYSE | 2017-05-23 06:24:50 Intraday chart data file opened for ADR-NYSE | 2017-05-23 06:24:50 HD Request # 25 | Downloading Intraday chart data for ADR-TF to the file ADR-TF.scid. Service: statscalc | 2017-05-23 06:24:50 HD Request # 25 | Download start date-time: 2017-05-23 06:22:38.000 | 2017-05-23 06:24:50 HD Request # 25 | Using server: ds4.sierracharts.com port 10149 | 2017-05-23 06:24:50 Socket (99) | Creating socket. | 2017-05-23 06:24:50 HD Request # 25 | Setting DTC encoding to Binary VLS | 2017-05-23 06:24:50 HD Request # 25 | Sending historical data logon request message. | 2017-05-23 06:24:50 HD Request # 25 | Requesting Intraday data. Start date-time: 2017-05-23 06:22:38. Record interval: 0. Symbol: ADR-TF | 2017-05-23 06:24:50 HD Request # 25 | Decompressing data. | 2017-05-23 06:24:50 HD Request # 25 | Receiving Intraday data for ADR-TF starting at 2017-05-23 06:22:38 | 2017-05-23 06:24:50 HD Request # 25 | Timestamp of first Intraday data file record written: 2017-05-23 06:22:39 | 2017-05-23 06:24:50 Socket (99) | Initiating close of socket by core. | 2017-05-23 06:24:50 Socket (99) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:24:50 Socket (99) | Socket gracefully closed by remote side. | 2017-05-23 06:24:50 Historical data download thread signaled to stop. | 2017-05-23 06:24:50 Socket (99) | Closed. | 2017-05-23 06:24:50 HD Request # 25 | Received 131 records from 2017-05-23 06:22:38 to 2017-05-23 06:24:48 (2.2 minutes) and wrote 130 records for ADR-TF | 2017-05-23 06:24:50 Added 12 Time and Sales records to Intraday data file for ADR-TF after download. | 2017-05-23 06:24:50 HD Request # 25 | Intraday download COMPLETE for ADR-TF. Completion time: 0s. Unique request ID: 24 | 2017-05-23 06:24:50 Removed historical data download ID 24 | 2017-05-23 06:24:50 Real-time Intraday chart data file updates started for ADR-TF | 2017-05-23 06:24:50 Intraday chart data file opened for ADR-TF | 2017-05-23 06:24:50 HD Request # 26 | Downloading Intraday chart data for ZNM7 to the file ZNM7.scid. Service: oec | 2017-05-23 06:24:50 HD Request # 26 | Download start date-time: 2017-05-23 06:22:37.000 | 2017-05-23 06:24:50 HD Request # 26 | Using server: ds3.sierracharts.com port 10149 | 2017-05-23 06:24:50 Socket (100) | Creating socket. | 2017-05-23 06:24:50 HD Request # 26 | Setting DTC encoding to Binary VLS | 2017-05-23 06:24:50 HD Request # 26 | Sending historical data logon request message. | 2017-05-23 06:24:50 HD Request # 26 | Requesting Intraday data. Start date-time: 2017-05-23 06:22:37. Record interval: 0. Symbol: ZNM7 | 2017-05-23 06:24:50 HD Request # 26 | Decompressing data. | 2017-05-23 06:24:50 HD Request # 26 | Receiving Intraday data for ZNM7 starting at 2017-05-23 06:22:37 | 2017-05-23 06:24:50 HD Request # 26 | Timestamp of first Intraday data file record written: 2017-05-23 06:23:05 | 2017-05-23 06:24:50 Socket (100) | Initiating close of socket by core. | 2017-05-23 06:24:50 Socket (100) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:24:50 Socket (100) | Socket gracefully closed by remote side. | 2017-05-23 06:24:50 Historical data download thread signaled to stop. | 2017-05-23 06:24:50 Socket (100) | Closed. | 2017-05-23 06:24:50 HD Request # 26 | Received 56 records from 2017-05-23 06:22:37 to 2017-05-23 06:24:42 (2.1 minutes) and wrote 54 records for ZNM7 | 2017-05-23 06:24:50 HD Request # 26 | Intraday download COMPLETE for ZNM7. Completion time: 0s. Unique request ID: 25 | 2017-05-23 06:24:50 Removed historical data download ID 25 | 2017-05-23 06:24:50 Real-time Intraday chart data file updates started for ZNM7 | 2017-05-23 06:24:50 Intraday chart data file opened for ZNM7 | 2017-05-23 06:24:50 HD Request # 27 | Downloading Intraday chart data for EMDM7 to the file EMDM7.scid. Service: oec | 2017-05-23 06:24:50 HD Request # 27 | Download start date-time: 2017-05-23 06:22:00.000 | 2017-05-23 06:24:50 HD Request # 27 | Using server: ds4.sierracharts.com port 10149 | 2017-05-23 06:24:50 Socket (101) | Creating socket. | 2017-05-23 06:24:50 HD Request # 27 | Setting DTC encoding to Binary VLS | 2017-05-23 06:24:51 HD Request # 27 | Sending historical data logon request message. | 2017-05-23 06:24:51 HD Request # 27 | Requesting Intraday data. Start date-time: 2017-05-23 06:22:00. Record interval: 0. Symbol: EMDM7 | 2017-05-23 06:24:51 HD Request # 27 | Decompressing data. | 2017-05-23 06:24:51 HD Request # 27 | Receiving Intraday data for EMDM7 starting at 2017-05-23 06:22:00 | 2017-05-23 06:24:51 HD Request # 27 | Timestamp of first Intraday data file record written: 2017-05-23 06:23:15 | 2017-05-23 06:24:51 Socket (101) | Initiating close of socket by core. | 2017-05-23 06:24:51 Socket (101) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:24:51 Socket (101) | Socket gracefully closed by remote side. | 2017-05-23 06:24:51 Socket (101) | Closed. | 2017-05-23 06:24:51 Historical data download thread signaled to stop. | 2017-05-23 06:24:51 HD Request # 27 | Received 15 records from 2017-05-23 06:22:00 to 2017-05-23 06:24:21 (2.4 minutes) and wrote 11 records for EMDM7 | 2017-05-23 06:24:51 HD Request # 27 | Intraday download COMPLETE for EMDM7. Completion time: 1s. Unique request ID: 26 | 2017-05-23 06:24:51 Removed historical data download ID 26 | 2017-05-23 06:24:51 Real-time Intraday chart data file updates started for EMDM7 | 2017-05-23 06:24:51 Intraday chart data file opened for EMDM7 | 2017-05-23 06:24:51 HD Request # 28 | Downloading Intraday chart data for NQM7 to the file NQM7.scid. Service: oec | 2017-05-23 06:24:51 HD Request # 28 | Download start date-time: 2017-05-23 06:22:37.000 | 2017-05-23 06:24:51 HD Request # 28 | Using server: ds3.sierracharts.com port 10149 | 2017-05-23 06:24:51 Socket (102) | Creating socket. | 2017-05-23 06:24:51 HD Request # 28 | Setting DTC encoding to Binary VLS | 2017-05-23 06:24:51 HD Request # 28 | Sending historical data logon request message. | 2017-05-23 06:24:51 HD Request # 28 | Requesting Intraday data. Start date-time: 2017-05-23 06:22:37. Record interval: 0. Symbol: NQM7 | 2017-05-23 06:24:51 HD Request # 28 | Decompressing data. | 2017-05-23 06:24:51 HD Request # 28 | Receiving Intraday data for NQM7 starting at 2017-05-23 06:22:37 | 2017-05-23 06:24:51 HD Request # 28 | Timestamp of first Intraday data file record written: 2017-05-23 06:22:39 | 2017-05-23 06:24:51 Socket (102) | Initiating close of socket by core. | 2017-05-23 06:24:51 Historical data download thread signaled to stop. | 2017-05-23 06:24:51 Socket (102) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:24:51 Socket (102) | Socket gracefully closed by remote side. | 2017-05-23 06:24:51 Socket (102) | Closed. | 2017-05-23 06:24:51 HD Request # 28 | Received 170 records from 2017-05-23 06:22:37 to 2017-05-23 06:24:48 (2.2 minutes) and wrote 169 records for NQM7 | 2017-05-23 06:24:51 HD Request # 28 | Intraday download COMPLETE for NQM7. Completion time: 0s. Unique request ID: 27 | 2017-05-23 06:24:51 Removed historical data download ID 27 | 2017-05-23 06:24:51 Real-time Intraday chart data file updates started for NQM7 | 2017-05-23 06:24:51 Intraday chart data file opened for NQM7 | 2017-05-23 06:24:51 Opened cached Intraday file: C:\SierraChart NS\Data\ESM7.scid | 2017-05-23 06:24:54 Opened cached Intraday file: C:\SierraChart NS\Data\TICK-NYSE.scid | 2017-05-23 06:24:54 Opened cached Intraday file: C:\SierraChart NS\Data\ADR-SP.scid | 2017-05-23 06:24:54 Opened cached Intraday file: C:\SierraChart NS\Data\ADR-NYSE.scid | 2017-05-23 06:24:54 Opened cached Intraday file: C:\SierraChart NS\Data\ADR-TF.scid | 2017-05-23 06:24:54 Opened cached Intraday file: C:\SierraChart NS\Data\NQM7.scid | 2017-05-23 06:24:54 Opened cached Intraday file: C:\SierraChart NS\Data\ZNM7.scid | 2017-05-23 06:25:04 Opened cached Intraday file: C:\SierraChart NS\Data\EMDM7.scid | 2017-05-23 06:25:24 GAIN Capital FIX Trading: DisconnectFIX called. | 2017-05-23 06:34:35 GAIN Capital FIX Trading: Sending a Logout message. | 2017-05-23 06:34:35 GAIN Capital FAST Data: Sending a Logout message. | 2017-05-23 06:34:35 DTC Client (94) | Initiating close of socket by core. | 2017-05-23 06:34:35 DTC Client (94) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:34:35 SC DTC Data | Disconnected from the server. | 2017-05-23 06:34:35 DTC Client (94) | Socket gracefully closed by remote side. | 2017-05-23 06:34:35 DTC Client (94) | Closed. | 2017-05-23 06:34:35 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:34:35 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:34:35 GAIN Capital FIX Trading socket (92) | Socket gracefully closed by remote side. | 2017-05-23 06:34:35 GAIN Capital FIX Trading socket (92) | Received socket Close event | 2017-05-23 06:34:35 GAIN Capital FAST Data socket (93) | Socket gracefully closed by remote side. | 2017-05-23 06:34:35 GAIN Capital FAST Data socket (93) | Received socket Close event | 2017-05-23 06:34:35 GAIN Capital FIX Trading: Received a Logout message. | 2017-05-23 06:34:35 GAIN Capital FIX Trading socket (92) | Initiating close of socket by core. | 2017-05-23 06:34:35 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:34:35 GAIN Capital FIX Trading socket (92) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:34:35 GAIN Capital FIX Trading socket (92) | Closed. | 2017-05-23 06:34:35 GAIN Capital FAST Data socket (93) | Initiating close of socket by core. | 2017-05-23 06:34:35 GAIN Capital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2017-05-23 06:34:35 GAIN Capital FAST Data socket (93) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:34:35 GAIN Capital FAST Data socket (93) | Closed. | 2017-05-23 06:34:35 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 06:34:35 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-23 06:34:38 GAIN Capital FIX Trading socket (109) | Creating socket. Using TLS 1.2. | 2017-05-23 06:34:38 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:34:38 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:34:38 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-23 06:34:38 GAIN Capital FAST Data socket (110) | Creating socket. | 2017-05-23 06:34:38 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-23 06:34:38 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-23 06:34:38 GAIN Capital FIX Trading socket (109) | Initiating close of socket by core. | 2017-05-23 06:34:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:34:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:34:38 GAIN Capital FIX Trading socket (109) | Write in progress. Shutdown being delayed. | 2017-05-23 06:34:38 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:34:38 GAIN Capital FAST Data socket (110) | Initiating close of socket by core. | 2017-05-23 06:34:38 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:34:38 GAIN Capital FAST Data socket (110) | Closed. | 2017-05-23 06:34:38 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 06:34:38 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:34:38 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:34:38 GAIN Capital FIX Trading socket (109) | Socket gracefully closed by remote side. | 2017-05-23 06:34:38 GAIN Capital FIX Trading socket (109) | Write has completed. Shutdown being performed. | 2017-05-23 06:34:38 GAIN Capital FIX Trading socket (109) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:34:38 GAIN Capital FIX Trading socket (109) | Closed. | 2017-05-23 06:34:38 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-23 06:34:41 GAIN Capital FIX Trading socket (111) | Creating socket. Using TLS 1.2. | 2017-05-23 06:34:41 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:34:42 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:34:42 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-23 06:34:42 GAIN Capital FAST Data socket (112) | Creating socket. | 2017-05-23 06:34:42 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-23 06:34:42 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-23 06:34:42 GAIN Capital FIX Trading socket (111) | Initiating close of socket by core. | 2017-05-23 06:34:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:34:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:34:42 GAIN Capital FIX Trading socket (111) | Write in progress. Shutdown being delayed. | 2017-05-23 06:34:42 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:34:42 GAIN Capital FAST Data socket (112) | Initiating close of socket by core. | 2017-05-23 06:34:42 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:34:42 GAIN Capital FAST Data socket (112) | Closed. | 2017-05-23 06:34:42 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-23 06:34:42 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:34:42 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:34:42 GAIN Capital FIX Trading socket (111) | Socket gracefully closed by remote side. | 2017-05-23 06:34:42 GAIN Capital FIX Trading socket (111) | Write has completed. Shutdown being performed. | 2017-05-23 06:34:42 GAIN Capital FIX Trading socket (111) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:34:42 GAIN Capital FIX Trading socket (111) | Closed. | 2017-05-23 06:34:42 File >> Disconnect selected. | 2017-05-23 06:34:44 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:34:44 GAIN Capital/OEC | Connecting to trading server api.gainfutures.com. Port: 9400. | 2017-05-23 06:35:06 GAIN Capital FIX Trading socket (113) | Creating socket. Using TLS 1.2. | 2017-05-23 06:35:06 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:35:06 GAIN Capital FIX Trading socket (113) | Socket gracefully closed by remote side. | 2017-05-23 06:35:07 GAIN Capital FIX Trading socket (113) | Initiating close of socket by core. | 2017-05-23 06:35:07 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:35:07 GAIN Capital FIX Trading socket (113) | Received socket Close event | 2017-05-23 06:35:07 GAIN Capital FIX Trading socket (113) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:35:07 GAIN Capital FIX Trading socket (113) | Closed. | 2017-05-23 06:35:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:35:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:35:07 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:35:07 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:35:07 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:35:07 GAIN Capital/OEC | Connecting to trading server api.gainfutures.com. Port: 9400. | 2017-05-23 06:35:10 GAIN Capital FIX Trading socket (114) | Creating socket. Using TLS 1.2. | 2017-05-23 06:35:10 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:35:10 GAIN Capital FIX Trading socket (114) | Socket gracefully closed by remote side. | 2017-05-23 06:35:10 GAIN Capital FIX Trading socket (114) | Received socket Close event | 2017-05-23 06:35:10 GAIN Capital FIX Trading socket (114) | Initiating close of socket by core. | 2017-05-23 06:35:10 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2017-05-23 06:35:10 GAIN Capital FIX Trading socket (114) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-23 06:35:10 GAIN Capital FIX Trading socket (114) | Closed. | 2017-05-23 06:35:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-23 06:35:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-23 06:35:10 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-23 06:35:10 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:35:10 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-23 06:35:10 File >> Disconnect selected. | 2017-05-23 06:35:11 GAIN Capital/OEC | Disconnected. | 2017-05-23 06:35:11 GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2017-05-23 06:37:37 GAIN Capital FIX Trading socket (116) | Creating socket. | 2017-05-23 06:37:37 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-23 06:37:38 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-23 06:37:38 GAIN Capital/OEC | Connecting to market data server sim.gainfutures.com:9301. | 2017-05-23 06:37:38 GAIN Capital FAST Data socket (117) | Creating socket. | 2017-05-23 06:37:38 GAIN Capital FAST Data: Sending the Hello message. | 2017-05-23 06:37:38 GAIN Capital FAST Data: Sending the Logon message. | 2017-05-23 06:37:38 GAIN Capital/OEC | Connected to data and trading server. | 2017-05-23 06:37:38 NOTICE: Not connected to Live trading account to receive CME real-time futures data at lower cost exchange fee. | 2017-05-23 06:37:38 GAIN Capital/OEC | Starting real-time market data updates for: ESM7. ID: 1 | 2017-05-23 06:37:38 GAIN Capital/OEC | Requesting security definition data for: ESM7. ID: 1 | 2017-05-23 06:37:38 Intraday data recording state for symbol ESM7 is set to download 'Pending'. | 2017-05-23 06:37:38 Delaying start of download for ESM7 | 2017-05-23 06:37:38 GAIN Capital/OEC | Starting real-time market data updates for: NQM7. ID: 2 | 2017-05-23 06:37:38 GAIN Capital/OEC | Requesting security definition data for: NQM7. ID: 2 | 2017-05-23 06:37:38 GAIN Capital/OEC | Starting real-time market data updates for: ZNM7. ID: 3 | 2017-05-23 06:37:38 GAIN Capital/OEC | Requesting security definition data for: ZNM7. ID: 3 | 2017-05-23 06:37:38 SC DTC Data | Starting real-time market data updates for: TICK-NYSE. ID: 4 | 2017-05-23 06:37:38 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-05-23 06:37:38 SC DTC Data | Requesting security definition data for: TICK-NYSE. ID: 4 | 2017-05-23 06:37:38 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2017-05-23 06:37:38 DTC Client (118) | Creating socket. | 2017-05-23 06:37:38 Delaying start of download for ESM7 | 2017-05-23 06:37:38 SC DTC Data | Starting real-time market data updates for: ADR-SP. ID: 5 | 2017-05-23 06:37:38 SC DTC Data | Requesting security definition data for: ADR-SP. ID: 5 | 2017-05-23 06:37:38 Intraday data recording state for symbol ADR-SP is set to download 'Pending'. | 2017-05-23 06:37:38 HD Request # 29 | Downloading Intraday chart data for ESM7 to the file ESM7.scid. Service: oec | 2017-05-23 06:37:38 HD Request # 29 | Download start date-time: 2017-05-23 06:34:33.000 | 2017-05-23 06:37:38 HD Request # 29 | Using server: ds4.sierracharts.com port 10149 | 2017-05-23 06:37:38 Socket (119) | Creating socket. | 2017-05-23 06:37:38 SC DTC Data | Starting real-time market data updates for: ADR-NYSE. ID: 6 | 2017-05-23 06:37:38 SC DTC Data | Requesting security definition data for: ADR-NYSE. ID: 6 | 2017-05-23 06:37:38 Intraday data recording state for symbol ADR-NYSE is set to download 'Pending'. | 2017-05-23 06:37:38 SC DTC Data | Starting real-time market data updates for: ADR-TF. ID: 7 | 2017-05-23 06:37:38 SC DTC Data | Requesting security definition data for: ADR-TF. ID: 7 | 2017-05-23 06:37:38 Intraday data recording state for symbol ADR-TF is set to download 'Pending'. | 2017-05-23 06:37:38 SC DTC Data | Connected to server. | 2017-05-23 06:37:38 SC DTC Data | Starting socket receive thread. | 2017-05-23 06:37:38 SC DTC Data | Sending Encoding Request to server | 2017-05-23 06:37:38 Intraday data recording state for symbol ZNM7 is set to download 'Pending'. | 2017-05-23 06:37:38 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-05-23 06:37:39 SC DTC Data | Sending logon request message. | 2017-05-23 06:37:39 HD Request # 29 | Setting DTC encoding to Binary VLS | 2017-05-23 06:37:39 HD Request # 29 | Sending historical data logon request message. | 2017-05-23 06:37:39 GAIN Capital/OEC | Starting real-time market data updates for: EMDM7. ID: 8 | 2017-05-23 06:37:39 GAIN Capital/OEC | Requesting security definition data for: EMDM7. ID: 8 | 2017-05-23 06:37:39 Intraday data recording state for symbol EMDM7 is set to download 'Pending'. | 2017-05-23 06:37:39 Intraday data recording state for symbol NQM7 is set to download 'Pending'. | 2017-05-23 06:37:39 SC DTC Data | Received logon response. | 2017-05-23 06:37:39 SC DTC Data | Server Name: SC Realtime Server. | 2017-05-23 06:37:39 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-05-23 06:37:39 SC DTC Data | Successfully connected. | 2017-05-23 06:37:39 SC DTC Data | Trading is not supported. | 2017-05-23 06:37:39 SC DTC Data | Restarting real-time data updates for symbol: ADR-NYSE | 2017-05-23 06:37:39 SC DTC Data | Restarting real-time data updates for symbol: ADR-SP | 2017-05-23 06:37:39 SC DTC Data | Restarting real-time data updates for symbol: ADR-TF | 2017-05-23 06:37:39 SC DTC Data | Restarting real-time data updates for symbol: TICK-NYSE | 2017-05-23 06:37:39 SC DTC Data | Received security definition for symbol ADR-NYSE | 2017-05-23 06:37:39 SC DTC Data | Received security definition for symbol ADR-SP | 2017-05-23 06:37:39 SC DTC Data | Received security definition for symbol ADR-TF | 2017-05-23 06:37:39 SC DTC Data | Received security definition for symbol TICK-NYSE | 2017-05-23 06:37:39 HD Request # 29 | Requesting Intraday data. Start date-time: 2017-05-23 06:34:33. Record interval: 0. Symbol: ESM7 | 2017-05-23 06:37:39 HD Request # 29 | Decompressing data. | 2017-05-23 06:37:39 HD Request # 29 | Receiving Intraday data for ESM7 starting at 2017-05-23 06:34:33 | 2017-05-23 06:37:39 HD Request # 29 | Timestamp of first Intraday data file record written: 2017-05-23 06:34:35 | 2017-05-23 06:37:39 Socket (119) | Initiating close of socket by core. | 2017-05-23 06:37:39 Socket (119) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:37:39 Socket (119) | Socket gracefully closed by remote side. | 2017-05-23 06:37:39 Socket (119) | Closed. | 2017-05-23 06:37:39 Historical data download thread signaled to stop. | 2017-05-23 06:37:39 HD Request # 29 | Received 5246 records from 2017-05-23 06:34:33 to 2017-05-23 06:37:38 (3.1 minutes) and wrote 5245 records for ESM7 | 2017-05-23 06:37:39 Added 37 Time and Sales records to Intraday data file for ESM7 after download. | 2017-05-23 06:37:39 HD Request # 29 | Intraday download COMPLETE for ESM7. Completion time: 0s. Unique request ID: 28 | 2017-05-23 06:37:39 Removed historical data download ID 28 | 2017-05-23 06:37:39 Real-time Intraday chart data file updates started for ESM7 | 2017-05-23 06:37:39 Intraday chart data file opened for ESM7 | 2017-05-23 06:37:39 Delaying start of download for TICK-NYSE | 2017-05-23 06:37:39 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2017-05-23 06:37:43 HD Request # 30 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2017-05-23 06:37:44 HD Request # 30 | Download start date-time: 2017-05-23 06:34:33.000 | 2017-05-23 06:37:44 HD Request # 30 | Using server: ds3.sierracharts.com port 10149 | 2017-05-23 06:37:44 Socket (120) | Creating socket. | 2017-05-23 06:37:44 HD Request # 30 | Setting DTC encoding to Binary VLS | 2017-05-23 06:37:44 HD Request # 30 | Sending historical data logon request message. | 2017-05-23 06:37:44 HD Request # 30 | Requesting Intraday data. Start date-time: 2017-05-23 06:34:33. Record interval: 0. Symbol: TICK-NYSE | 2017-05-23 06:37:45 HD Request # 30 | Decompressing data. | 2017-05-23 06:37:45 HD Request # 30 | Receiving Intraday data for TICK-NYSE starting at 2017-05-23 06:34:33 | 2017-05-23 06:37:45 HD Request # 30 | Timestamp of first Intraday data file record written: 2017-05-23 06:34:34 | 2017-05-23 06:37:45 Socket (120) | Initiating close of socket by core. | 2017-05-23 06:37:45 Socket (120) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:37:45 Socket (120) | Socket gracefully closed by remote side. | 2017-05-23 06:37:45 Socket (120) | Closed. | 2017-05-23 06:37:45 Historical data download thread signaled to stop. | 2017-05-23 06:37:45 HD Request # 30 | Received 190 records from 2017-05-23 06:34:33 to 2017-05-23 06:37:42 (3.2 minutes) and wrote 189 records for TICK-NYSE | 2017-05-23 06:37:45 Added 5 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2017-05-23 06:37:45 HD Request # 30 | Intraday download COMPLETE for TICK-NYSE. Completion time: 1s. Unique request ID: 29 | 2017-05-23 06:37:45 Removed historical data download ID 29 | 2017-05-23 06:37:45 Real-time Intraday chart data file updates started for TICK-NYSE | 2017-05-23 06:37:45 Intraday chart data file opened for TICK-NYSE | 2017-05-23 06:37:45 HD Request # 31 | Downloading Intraday chart data for ADR-SP to the file ADR-SP.scid. Service: statscalc | 2017-05-23 06:37:45 HD Request # 31 | Download start date-time: 2017-05-23 06:34:33.000 | 2017-05-23 06:37:45 HD Request # 31 | Using server: ds4.sierracharts.com port 10149 | 2017-05-23 06:37:45 Socket (121) | Creating socket. | 2017-05-23 06:37:45 HD Request # 31 | Setting DTC encoding to Binary VLS | 2017-05-23 06:37:45 HD Request # 31 | Sending historical data logon request message. | 2017-05-23 06:37:45 HD Request # 31 | Requesting Intraday data. Start date-time: 2017-05-23 06:34:33. Record interval: 0. Symbol: ADR-SP | 2017-05-23 06:37:45 HD Request # 31 | Decompressing data. | 2017-05-23 06:37:45 HD Request # 31 | Receiving Intraday data for ADR-SP starting at 2017-05-23 06:34:33 | 2017-05-23 06:37:45 HD Request # 31 | Timestamp of first Intraday data file record written: 2017-05-23 06:34:34 | 2017-05-23 06:37:45 Socket (121) | Initiating close of socket by core. | 2017-05-23 06:37:45 Historical data download thread signaled to stop. | 2017-05-23 06:37:45 Socket (121) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:37:45 Socket (121) | Socket gracefully closed by remote side. | 2017-05-23 06:37:45 Socket (121) | Closed. | 2017-05-23 06:37:45 HD Request # 31 | Received 190 records from 2017-05-23 06:34:33 to 2017-05-23 06:37:42 (3.2 minutes) and wrote 189 records for ADR-SP | 2017-05-23 06:37:45 Added 3 Time and Sales records to Intraday data file for ADR-SP after download. | 2017-05-23 06:37:45 HD Request # 31 | Intraday download COMPLETE for ADR-SP. Completion time: 0s. Unique request ID: 30 | 2017-05-23 06:37:45 Removed historical data download ID 30 | 2017-05-23 06:37:45 Real-time Intraday chart data file updates started for ADR-SP | 2017-05-23 06:37:45 Intraday chart data file opened for ADR-SP | 2017-05-23 06:37:45 HD Request # 32 | Downloading Intraday chart data for ADR-NYSE to the file ADR-NYSE.scid. Service: statscalc | 2017-05-23 06:37:45 HD Request # 32 | Download start date-time: 2017-05-23 06:34:33.000 | 2017-05-23 06:37:45 HD Request # 32 | Using server: ds3.sierracharts.com port 10149 | 2017-05-23 06:37:45 Socket (122) | Creating socket. | 2017-05-23 06:37:45 HD Request # 32 | Setting DTC encoding to Binary VLS | 2017-05-23 06:37:45 HD Request # 32 | Sending historical data logon request message. | 2017-05-23 06:37:45 HD Request # 32 | Requesting Intraday data. Start date-time: 2017-05-23 06:34:33. Record interval: 0. Symbol: ADR-NYSE | 2017-05-23 06:37:45 HD Request # 32 | Decompressing data. | 2017-05-23 06:37:45 HD Request # 32 | Receiving Intraday data for ADR-NYSE starting at 2017-05-23 06:34:33 | 2017-05-23 06:37:45 HD Request # 32 | Timestamp of first Intraday data file record written: 2017-05-23 06:34:34 | 2017-05-23 06:37:45 Socket (122) | Initiating close of socket by core. | 2017-05-23 06:37:45 Historical data download thread signaled to stop. | 2017-05-23 06:37:45 Socket (122) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:37:45 Socket (122) | Socket gracefully closed by remote side. | 2017-05-23 06:37:45 Socket (122) | Closed. | 2017-05-23 06:37:45 HD Request # 32 | Received 190 records from 2017-05-23 06:34:33 to 2017-05-23 06:37:42 (3.2 minutes) and wrote 189 records for ADR-NYSE | 2017-05-23 06:37:45 Added 3 Time and Sales records to Intraday data file for ADR-NYSE after download. | 2017-05-23 06:37:45 HD Request # 32 | Intraday download COMPLETE for ADR-NYSE. Completion time: 0s. Unique request ID: 31 | 2017-05-23 06:37:45 Removed historical data download ID 31 | 2017-05-23 06:37:45 Real-time Intraday chart data file updates started for ADR-NYSE | 2017-05-23 06:37:45 Intraday chart data file opened for ADR-NYSE | 2017-05-23 06:37:45 HD Request # 33 | Downloading Intraday chart data for ADR-TF to the file ADR-TF.scid. Service: statscalc | 2017-05-23 06:37:45 HD Request # 33 | Download start date-time: 2017-05-23 06:34:33.000 | 2017-05-23 06:37:45 HD Request # 33 | Using server: ds4.sierracharts.com port 10149 | 2017-05-23 06:37:45 Socket (123) | Creating socket. | 2017-05-23 06:37:45 HD Request # 33 | Setting DTC encoding to Binary VLS | 2017-05-23 06:37:46 HD Request # 33 | Sending historical data logon request message. | 2017-05-23 06:37:46 HD Request # 33 | Requesting Intraday data. Start date-time: 2017-05-23 06:34:33. Record interval: 0. Symbol: ADR-TF | 2017-05-23 06:37:46 HD Request # 33 | Decompressing data. | 2017-05-23 06:37:46 HD Request # 33 | Receiving Intraday data for ADR-TF starting at 2017-05-23 06:34:33 | 2017-05-23 06:37:46 HD Request # 33 | Timestamp of first Intraday data file record written: 2017-05-23 06:34:34 | 2017-05-23 06:37:46 Socket (123) | Initiating close of socket by core. | 2017-05-23 06:37:46 Socket (123) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:37:46 Socket (123) | Socket gracefully closed by remote side. | 2017-05-23 06:37:46 Socket (123) | Closed. | 2017-05-23 06:37:46 Historical data download thread signaled to stop. | 2017-05-23 06:37:46 HD Request # 33 | Received 190 records from 2017-05-23 06:34:33 to 2017-05-23 06:37:42 (3.2 minutes) and wrote 189 records for ADR-TF | 2017-05-23 06:37:46 Added 5 Time and Sales records to Intraday data file for ADR-TF after download. | 2017-05-23 06:37:46 HD Request # 33 | Intraday download COMPLETE for ADR-TF. Completion time: 1s. Unique request ID: 32 | 2017-05-23 06:37:46 Removed historical data download ID 32 | 2017-05-23 06:37:46 Real-time Intraday chart data file updates started for ADR-TF | 2017-05-23 06:37:46 Intraday chart data file opened for ADR-TF | 2017-05-23 06:37:46 HD Request # 34 | Downloading Intraday chart data for ZNM7 to the file ZNM7.scid. Service: oec | 2017-05-23 06:37:46 HD Request # 34 | Download start date-time: 2017-05-23 06:34:29.000 | 2017-05-23 06:37:46 HD Request # 34 | Using server: ds3.sierracharts.com port 10149 | 2017-05-23 06:37:46 Socket (124) | Creating socket. | 2017-05-23 06:37:46 Opened cached Intraday file: C:\SierraChart NS\Data\ESM7.scid | 2017-05-23 06:37:46 Opened cached Intraday file: C:\SierraChart NS\Data\TICK-NYSE.scid | 2017-05-23 06:37:46 Opened cached Intraday file: C:\SierraChart NS\Data\ADR-SP.scid | 2017-05-23 06:37:46 Opened cached Intraday file: C:\SierraChart NS\Data\ADR-NYSE.scid | 2017-05-23 06:37:46 HD Request # 34 | Setting DTC encoding to Binary VLS | 2017-05-23 06:37:46 HD Request # 34 | Sending historical data logon request message. | 2017-05-23 06:37:46 HD Request # 34 | Requesting Intraday data. Start date-time: 2017-05-23 06:34:29. Record interval: 0. Symbol: ZNM7 | 2017-05-23 06:37:46 HD Request # 34 | Decompressing data. | 2017-05-23 06:37:46 HD Request # 34 | Receiving Intraday data for ZNM7 starting at 2017-05-23 06:34:29 | 2017-05-23 06:37:46 HD Request # 34 | Timestamp of first Intraday data file record written: 2017-05-23 06:34:36 | 2017-05-23 06:37:46 Socket (124) | Initiating close of socket by core. | 2017-05-23 06:37:46 Socket (124) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:37:46 Socket (124) | Socket gracefully closed by remote side. | 2017-05-23 06:37:46 Historical data download thread signaled to stop. | 2017-05-23 06:37:46 Socket (124) | Closed. | 2017-05-23 06:37:46 HD Request # 34 | Received 650 records from 2017-05-23 06:34:29 to 2017-05-23 06:37:35 (3.1 minutes) and wrote 649 records for ZNM7 | 2017-05-23 06:37:46 HD Request # 34 | Intraday download COMPLETE for ZNM7. Completion time: 0s. Unique request ID: 33 | 2017-05-23 06:37:46 Removed historical data download ID 33 | 2017-05-23 06:37:46 Real-time Intraday chart data file updates started for ZNM7 | 2017-05-23 06:37:46 Intraday chart data file opened for ZNM7 | 2017-05-23 06:37:46 HD Request # 35 | Downloading Intraday chart data for EMDM7 to the file EMDM7.scid. Service: oec | 2017-05-23 06:37:46 HD Request # 35 | Download start date-time: 2017-05-23 06:34:33.000 | 2017-05-23 06:37:46 HD Request # 35 | Using server: ds4.sierracharts.com port 10149 | 2017-05-23 06:37:46 Socket (125) | Creating socket. | 2017-05-23 06:37:46 HD Request # 35 | Setting DTC encoding to Binary VLS | 2017-05-23 06:37:46 HD Request # 35 | Sending historical data logon request message. | 2017-05-23 06:37:46 HD Request # 35 | Requesting Intraday data. Start date-time: 2017-05-23 06:34:33. Record interval: 0. Symbol: EMDM7 | 2017-05-23 06:37:46 HD Request # 35 | Decompressing data. | 2017-05-23 06:37:46 HD Request # 35 | Receiving Intraday data for EMDM7 starting at 2017-05-23 06:34:33 | 2017-05-23 06:37:46 HD Request # 35 | Timestamp of first Intraday data file record written: 2017-05-23 06:34:35 | 2017-05-23 06:37:46 Socket (125) | Initiating close of socket by core. | 2017-05-23 06:37:46 Historical data download thread signaled to stop. | 2017-05-23 06:37:46 Socket (125) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:37:46 Socket (125) | Socket gracefully closed by remote side. | 2017-05-23 06:37:46 Socket (125) | Closed. | 2017-05-23 06:37:46 HD Request # 35 | Received 314 records from 2017-05-23 06:34:33 to 2017-05-23 06:37:41 (3.1 minutes) and wrote 313 records for EMDM7 | 2017-05-23 06:37:46 Added 1 Time and Sales records to Intraday data file for EMDM7 after download. | 2017-05-23 06:37:46 HD Request # 35 | Intraday download COMPLETE for EMDM7. Completion time: 0s. Unique request ID: 34 | 2017-05-23 06:37:46 Removed historical data download ID 34 | 2017-05-23 06:37:46 Real-time Intraday chart data file updates started for EMDM7 | 2017-05-23 06:37:46 Intraday chart data file opened for EMDM7 | 2017-05-23 06:37:46 HD Request # 36 | Downloading Intraday chart data for NQM7 to the file NQM7.scid. Service: oec | 2017-05-23 06:37:46 HD Request # 36 | Download start date-time: 2017-05-23 06:34:34.000 | 2017-05-23 06:37:46 HD Request # 36 | Using server: ds3.sierracharts.com port 10149 | 2017-05-23 06:37:46 Socket (126) | Creating socket. | 2017-05-23 06:37:46 HD Request # 36 | Setting DTC encoding to Binary VLS | 2017-05-23 06:37:47 HD Request # 36 | Sending historical data logon request message. | 2017-05-23 06:37:47 HD Request # 36 | Requesting Intraday data. Start date-time: 2017-05-23 06:34:34. Record interval: 0. Symbol: NQM7 | 2017-05-23 06:37:47 HD Request # 36 | Decompressing data. | 2017-05-23 06:37:47 HD Request # 36 | Receiving Intraday data for NQM7 starting at 2017-05-23 06:34:34 | 2017-05-23 06:37:47 HD Request # 36 | Timestamp of first Intraday data file record written: 2017-05-23 06:34:34 | 2017-05-23 06:37:47 Socket (126) | Initiating close of socket by core. | 2017-05-23 06:37:47 Historical data download thread signaled to stop. | 2017-05-23 06:37:47 Socket (126) | Shutdown started. Waiting for graceful close. | 2017-05-23 06:37:47 Socket (126) | Socket gracefully closed by remote side. | 2017-05-23 06:37:47 Socket (126) | Closed. | 2017-05-23 06:37:47 HD Request # 36 | Received 3867 records from 2017-05-23 06:34:34 to 2017-05-23 06:37:44 (3.2 minutes) and wrote 3862 records for NQM7 | 2017-05-23 06:37:47 Added 14 Time and Sales records to Intraday data file for NQM7 after download. | 2017-05-23 06:37:47 HD Request # 36 | Intraday download COMPLETE for NQM7. Completion time: 0s. Unique request ID: 35 | 2017-05-23 06:37:47 Removed historical data download ID 35 | 2017-05-23 06:37:47 Real-time Intraday chart data file updates started for NQM7 | 2017-05-23 06:37:47 Intraday chart data file opened for NQM7 | 2017-05-23 06:37:47 Opened cached Intraday file: C:\SierraChart NS\Data\NQM7.scid | 2017-05-23 06:37:56 Opened cached Intraday file: C:\SierraChart NS\Data\ZNM7.scid | 2017-05-23 06:37:56 Opened cached Intraday file: C:\SierraChart NS\Data\ADR-TF.scid | 2017-05-23 06:37:56 Opened cached Intraday file: C:\SierraChart NS\Data\EMDM7.scid | 2017-05-23 06:38:06 |
| [2017-05-23 14:50:59] |
This is the relevant message: GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-23 06:34:42 Refer to step 12 here: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
