Date/Time: Tue, 14 Jan 2025 11:54:56 +0000
First Instance non connecting (but 2nd instance is)
View Count: 894
[2017-05-20 11:25:32]
RonW - Posts: 105
From the Log:
CQG WebAPI | Market data logon unsuccessful. Server message: Trade routing is not available now. Contact customer support for assistance. | 2017-05-20 07:20:11 *
I sent the whole log.
I do not use CQG through Sierra for Trade Routing. I only use it for charting. I do not understand why it will not connect. I have a 2nd instance open, which appears to have connected ok.
[2017-05-20 11:40:19]
RonW - Posts: 105
just a picture on my desktop showing first instance on left disconnected and second instance on right connected
imageImage 1.png / V - Attached On 2017-05-20 11:39:07 UTC - Size: 356.67 KB - 239 views
[2017-05-20 11:44:08]
RonW - Posts: 105
What I did before this happened:
I opened Sierra early on Saturday morning. I learned how to create weekly charts of day session only data.
I did it first on an oil chart, converting a historical chart to intraday bar only 7-0-0 and it worked fine
Next a historical S&P chart. Here I noticed the data file only went back to November 2016. I changed that back to November 2012, and made the other changes to convert it to a weekly chart of day session only. That data never downloaded and I disconnected.
[2017-05-20 16:34:01]
That error message is from CQG. The other instance you are referring to is a sub instance which will always be able to connect to the main instance.
Contact your broker about this if you continue to encounter this Sunday evening:
Date Time Of Last Edit: 2017-05-20 16:34:23
[2017-05-20 17:00:11]
Rexz - Posts: 22
If it is any help I can't connect to CQG through Sierra charts today. My broker is AMP Futures. They must be doing maitenance or it might be down.
