Date/Time: Tue, 14 Jan 2025 11:27:47 +0000
ZigZag Study Settings
View Count: 1766
[2017-05-15 16:21:46] |
Tojo - Posts: 4 |
The zigzag settings option to "Color the zigzag line using " either none / slope / trend confirmed volume / confirmed volume is excellent and very useful. Personally, I prefer to display text and leave the zigzag line hidden. A hidden line has the benefit of less clutter and no interference with price bars. To use the feature of coloring by either " none / slope / trend confirmed volume / confirmed volume" is it possible to add this coloring option to zigzag text? In other words, adding the following new option to zigzag settings .......... "Color the zigzag TEXT using " either none / slope / trend confirmed volume Thank you in advance for considering this enhancement to the zigzag study. |
[2017-05-15 22:42:29] |
Would be best to that you contact a programmer to do this for you. You can contact Jim _AT_ SierraChart.com. They can do this for an additional cost. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
