Date/Time: Tue, 04 Nov 2025 15:50:42 +0000
Can I backup my customised instance of Sierra Charts to a file(eg: TNA file)?
View Count: 1090
[2017-05-04 14:10:51]
User822076 - Posts: 1
To the support team, I'm new to Sierra Charts and wanted to confirm the following. Once I've customised my chartbooks, added custom indicators etc, etc, can I then backup my customised instance of Sierra Charts and save to a back up/achieve file (eg: TNA file or similar) on an external drive? I'm currently doing this with another trading software that I'm currently using, so wondered if Sierra Charts has a similar/same function?? It comes in handy (massive time saver) when my PC's hard drive dies (which has happened in the past) or when loading up a secondary trading PC/laptop.
[2017-05-04 14:32:09]
Yes of course. You just simply need to backup the entire Sierra Chart installation folder. Sierra Chart is a portable application and all of its files are contained within its own folder.
Also refer to help topic 15:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
