Date/Time: Mon, 13 Jan 2025 07:52:28 +0000
SierraChartFileDownloader.exe has stopped working
View Count: 662
[2017-04-19 09:33:52] |
User787778 - Posts: 142 |
When attempting to update Sierra to the latest version, using > Help-Download Current Version < The following happens: The software is downloaded and then I close Sierra. The installer window opens and when I install the update, I get an error message: “SierraChartFileDownloader.exe has stopped working” I have tried to download the file from the Software Download section but get the same error. I can’t see the relevant log message. Your assistance would be appreciated. |
Private File |
[2017-04-19 09:38:39] |
The problem is caused by a program called Bandwidth Guard on your system. It is causing an access violation within the Sierra Chart File Downloader program. Remove or disable it from your system.
[2017-04-19 09:55:02] |
Thanks. I have searched my computer but can't find any such program.
[2017-04-19 16:22:00] |
In the screenshot you attached, you can see the name of that program as a filename and that is what is causing the problem. Maybe the actual name of the program is different. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-19 16:25:42
