Date/Time: Tue, 15 Sep 2026 10:06:58 +0000
Some charts just will not open
View Count: 1425
| [2017-04-10 12:41:18] |
| User299392 - Posts: 216 |
When opening a chatbook, some charts just will not open. This has never happening before. What do you think is going on here now? |
| [2017-04-10 17:04:36] |
We see you are using version 1541. So this is not a problem in that particular version. What we want you to do is follow the instructions here to use a backup Chartbook: http://www.sierrachart.com/index.php?page=doc/Chartbooks.html#BackupChartbook Start off with the newest back up and go back to earlier ones until you get one that opens all of the charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-04-10 17:10:31] |
I did that. I can tell you though that I have a lot of charts open not too many symbols. It says ST:13 in the status connection. WHat else can I do? |
| [2017-04-10 17:34:28] |
What we want you to do is follow the instructions here to attach one of the backup Chartbooks that you have: Support Board Posting Information: Attaching a File (Optional) And tell us how many charts should be in it and we will see how many charts actually open and see if we can identify any problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-04-10 18:25:16] |
See attached. There should be more than 40 charts in this file. |
Private File |
| [2017-04-11 01:34:27] |
That Chartbook has 75 charts in it. When opening it we encountered and exception which we have now fixed and that may have led to the problem where not all of the charts opened. The new release will be out this evening. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-04-12 13:13:59] |
This problem still persists even after version 1542 updated. This time with a different chartbook attached. It has more than 20 charts in it and only 2 opened. See chartbook attached. |
| [2017-04-12 20:11:51] |
ANy luck with this?
| [2017-04-12 21:51:02] |
The Chartbook in post #7 contains 10 charts. There was no error opening it or any errors logged. If you are seeing less charts, the issue must be a system issue on your side maybe with creating windows. We want you to restart Sierra Chart and open just that one Chartbook and then provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-04-12 23:01:05] |
I did the following - - Shut down the application - Downloaded and installed 1543 - Opened in Safe Mode - Opened the just the chart book having this problem - And it still did not open all the charts - as requested - see the message log below - also attached that same chartbook again for reference Let me know Reading Internal Order ID file. | 2017-04-12 18:58:06 Reading Trade Orders file. | 2017-04-12 18:58:06 Reading Trade Positions file. | 2017-04-12 18:58:06 Listening on UDP port 22903. | 2017-04-12 18:58:06 Software version: 1543 | 2017-04-12 18:58:06 Uses New Spreadsheets | 2017-04-12 18:58:06 Enabled for: Advanced Features. | 2017-04-12 18:58:06 Enabled for: Advanced Features 2. | 2017-04-12 18:58:06 Enabled for: Sierra Chart Historical Data Service. | 2017-04-12 18:58:06 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-04-12 18:58:06 Current selected Data/Trading service: CQG FIX Trading | 2017-04-12 18:58:06 Chart Update Interval: 777 | 2017-04-12 18:58:06 Data/Trade Service Settings automatically set. | 2017-04-12 18:58:06 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-04-12 18:58:06 2017-04-12 18:58:11 Local computer time | 2017-04-12 18:58:06 2017-04-12 22:58:11 Local computer time in UTC | 2017-04-12 18:58:06 2017-04-12 18:58:11 Local computer time in SC Time Zone | 2017-04-12 18:58:06 2017-04-12 22:58:08 Server time in UTC | 2017-04-12 18:58:06 Local computer UTC time and Server UTC time difference: 2 seconds. | 2017-04-12 18:58:06 Program path: C:\SierraChart\ | 2017-04-12 18:58:06 Data Files path: C:\SierraChart\Data\ | 2017-04-12 18:58:06 OS Version Number: 6.2 | 2017-04-12 18:58:06 Locale Setting: C | 2017-04-12 18:58:06 Created the DTC Protocol server. | 2017-04-12 18:58:06 DTC Protocol Server listening on port 11099. | 2017-04-12 18:58:06 Created the DTC Protocol historical data server. | 2017-04-12 18:58:06 HD Server Manager | Listening on port 11098 | 2017-04-12 18:58:06 Checking for new symbol settings for service code cqg | 2017-04-12 18:58:06 HTTPS connection to www.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2017-04-12 18:58:06 Requesting symbol settings for service code cqg. Overwrite = off. | 2017-04-12 18:58:12 Symbol settings received. | 2017-04-12 18:58:12 Processed 1100 symbol settings. | 2017-04-12 18:58:12 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-04-12 18:58:16 CQG FIX socket (4) | Creating socket. Using TLS 1.2. | 2017-04-12 18:58:17 CQG FIX: Sending the Logon message. | 2017-04-12 18:58:17 CQG FIX Trading | Connected to trading server. | 2017-04-12 18:58:17 CQG FIX Trading | Connecting to server api.cqg.com | 2017-04-12 18:58:17 CQG websocket | Connecting to websocket server. | 2017-04-12 18:58:17 CQG FIX | FCM name: AMP | 2017-04-12 18:58:17 CQG FIX | FCM name: AMP | 2017-04-12 18:58:17 HTTPS connection to www.sierrachart.com:443 (3) | Socket gracefully closed by remote side. | 2017-04-12 18:58:17 HTTPS connection to www.sierrachart.com:443 (3) | Received socket Close event | 2017-04-12 18:58:17 HTTPS connection to www.sierrachart.com:443 (3) | Initiating close of socket by core. | 2017-04-12 18:58:17 HTTPS connection to www.sierrachart.com:443 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-04-12 18:58:17 HTTPS connection to www.sierrachart.com:443 (3) | Closed. | 2017-04-12 18:58:17 CQG websocket socket (5) | Creating socket. Using TLS 1.2. | 2017-04-12 18:58:17 CQG websocket | Opening websocket. | 2017-04-12 18:58:18 CQG websocket | Sending websocket handshake. | 2017-04-12 18:58:18 CQG websocket | Received websocket handshake acknowledgment. | 2017-04-12 18:58:18 CQG websocket | Web socket state is now open. | 2017-04-12 18:58:18 CQG FIX Trading | Websocket connected. | 2017-04-12 18:58:18 CQG FIX Trading | Sending market data logon message. | 2017-04-12 18:58:18 CQG FIX Trading | Logon successful. Session Token = vqhdGDyTOXN7jdzWpGCl7cBF5oiklX9agDW6EpYv+K0 | 2017-04-12 18:58:18 CQG FIX Trading | Connected to data and trading server. | 2017-04-12 18:58:18 CQG FIX Trading | Starting real-time market data updates for: F.US.CA6Z16. ID: 1 | 2017-04-12 18:58:18 CQG FIX Trading | Sending symbol resolution request for F.US.CA6Z16. ID: 411874 | 2017-04-12 18:58:18 CQG FIX Trading | Requesting security definition data for: F.US.CA6Z16. ID: 1 | 2017-04-12 18:58:18 CQG FIX Trading | Starting real-time market data updates for: F.US.BP6Z16. ID: 2 | 2017-04-12 18:58:18 CQG FIX Trading | Sending symbol resolution request for F.US.BP6Z16. ID: 411875 | 2017-04-12 18:58:18 CQG FIX Trading | Requesting security definition data for: F.US.BP6Z16. ID: 2 | 2017-04-12 18:58:18 Symbol Error - F.US.CA6Z16 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-04-12 18:58:18 CQG FIX Trading | Received symbol resolution report for symbol F.US.BP6Z6. Search Symbol: F.US.BP6Z16. Request ID: 411875. Contract ID: 1. | 2017-04-12 18:58:18 CQG FIX Trading | Requesting market data for F.US.BP6Z16 | 2017-04-12 18:58:18 F.US.TFEM17 [CB] 60 Min #2 | Reloading chart. | 2017-04-12 18:58:43 F.US.TFEM17 [CB] 240 Min #3 | Reloading chart. | 2017-04-12 18:58:43 F.US.TFEM17 [CB] Daily #4 | Reloading chart. | 2017-04-12 18:58:43 F.US.TFEM17 [CB] Flex Renko 10-1-1 #6 | Reloading chart. | 2017-04-12 18:58:43 F.US.TFEM17 [CB] 30 Sec #1 | Reloading chart. | 2017-04-12 18:58:43 F.US.TFEM17 [CB] 15 Min #26 | Reloading chart. | 2017-04-12 18:58:43 F.US.TFEM17 [CB] 5 Min #9 | Reloading chart. | 2017-04-12 18:58:43 TICK-NYSE Renko 89t #27 | Reloading chart. | 2017-04-12 18:58:43 TICK-NYSE Flex Renko 55-1-1 #10 | Reloading chart. | 2017-04-12 18:58:43 TICK-NYSE [C] 30 Sec #17 | Reloading chart. | 2017-04-12 18:58:43 TICK-NYSE [C] 30 Sec #17 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2017-04-12 18:58:43 TICK-NYSE [C] 30 Sec #17 | There are no continuous futures contract symbols. Loading data normally. | 2017-04-12 18:58:43 CQG FIX Trading | Starting real-time market data updates for: F.US.TFEM17. ID: 3 | 2017-04-12 18:58:45 CQG FIX Trading | Sending symbol resolution request for F.US.TFEM17. ID: 411876 | 2017-04-12 18:58:45 CQG FIX Trading | Requesting security definition data for: F.US.TFEM17. ID: 3 | 2017-04-12 18:58:45 Intraday data recording state for symbol F.US.TFEM17 is set to download 'Pending'. | 2017-04-12 18:58:45 Delaying start of download for F.US.TFEM17 | 2017-04-12 18:58:45 HD Request # 2 | Downloading Historical Daily chart data for F.US.TFEM17. Starting date: 2017-04-11. Service: cqg | 2017-04-12 18:58:45 HD Request # 2 | Requesting historical Daily data for RJM17 starting at 2017-04-10 | 2017-04-12 18:58:45 CQG FIX Trading | Received symbol resolution report for symbol F.US.TFEM7. Search Symbol: F.US.TFEM17. Request ID: 411876. Contract ID: 2. | 2017-04-12 18:58:45 CQG FIX Trading | Requesting market data for F.US.TFEM17 | 2017-04-12 18:58:45 HTTP connection to ds01.ddfplus.com:80 (6) | Creating socket. | 2017-04-12 18:58:45 HD Request # 2 | Receiving historical Daily data for F.US.TFEM17 starting at 2017-04-11 | 2017-04-12 18:58:45 HD Request # 2 | Writing historical Daily data to the file F.US.TFEM17.dly | 2017-04-12 18:58:45 HD Request # 2 | Received 3 records from 2017-04-11 00:00:00 to 2017-04-12 00:00:00 (2.0 days) and wrote 2 records for F.US.TFEM17 | 2017-04-12 18:58:45 HD Request # 2 | Daily download COMPLETE for F.US.TFEM17. Completion time: 1s. Unique request ID: 2 | 2017-04-12 18:58:45 Removed historical data download ID 2 | 2017-04-12 18:58:45 Chart #10 has tagged chart #17 for full recalculation. Chartbook: FC-TF.cht | 2017-04-12 18:58:45 Chart #10 has tagged chart #17 for full recalculation. Chartbook: FC-TF.cht | 2017-04-12 18:58:45 SC DTC Data | Starting real-time market data updates for: TICK-NYSE. ID: 4 | 2017-04-12 18:58:45 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 10048 | 2017-04-12 18:58:45 SC DTC Data | Requesting security definition data for: TICK-NYSE. ID: 4 | 2017-04-12 18:58:45 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2017-04-12 18:58:45 Delaying start of download for F.US.TFEM17 | 2017-04-12 18:58:45 TICK-NYSE [C] [M] 30 Sec #17 | Performing a full recalculation because it has been tagged. Chartbook: FC-TF.cht | 2017-04-12 18:58:46 F.US.TFEM17 [CB] Daily #4 | Reloading chart. | 2017-04-12 18:58:46 DTC Client (7) | Creating socket. | 2017-04-12 18:58:46 SC DTC Data | Connected to server. | 2017-04-12 18:58:46 SC DTC Data | Starting socket receive thread. | 2017-04-12 18:58:46 SC DTC Data | Sending Encoding Request to server | 2017-04-12 18:58:46 SC DTC Data | Setting DTC encoding to Binary VLS | 2017-04-12 18:58:46 SC DTC Data | Sending logon request message. | 2017-04-12 18:58:46 SC DTC Data | Received logon response. | 2017-04-12 18:58:46 SC DTC Data | Server Name: SC Realtime Server. | 2017-04-12 18:58:46 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2017-04-12 18:58:46 SC DTC Data | Successfully connected. | 2017-04-12 18:58:46 SC DTC Data | Trading is not supported. | 2017-04-12 18:58:46 SC DTC Data | Restarting real-time data updates for symbol: TICK-NYSE | 2017-04-12 18:58:46 SC DTC Data | Received security definition for symbol TICK-NYSE | 2017-04-12 18:58:46 Requesting market depth updates for: F.US.TFEM17 if supported. | 2017-04-12 18:58:48 CQG FIX Trading | Requesting market data including full depth for F.US.TFEM17 | 2017-04-12 18:58:48 HD Request # 3 | Downloading Intraday chart data for F.US.TFEM17 to the file F.US.TFEM17.scid. Service: cqg | 2017-04-12 18:58:50 HD Request # 3 | Download start date-time: 2017-04-12 16:12:03.000 | 2017-04-12 18:58:50 HD Request # 3 | Using server: ds4.sierracharts.com port 10149 | 2017-04-12 18:58:50 Socket (8) | Creating socket. | 2017-04-12 18:58:50 HD Request # 3 | Setting DTC encoding to Binary VLS | 2017-04-12 18:58:50 HD Request # 3 | Sending historical data logon request message. | 2017-04-12 18:58:50 HD Request # 3 | Requesting Intraday data. Start date-time: 2017-04-12 16:12:03. Record interval: 0. Symbol: F.US.TFEM17 | 2017-04-12 18:58:51 HD Request # 3 | Decompressing data. | 2017-04-12 18:58:51 HD Request # 3 | Receiving Intraday data for F.US.TFEM17 starting at 2017-04-12 16:12:03 | 2017-04-12 18:58:51 HD Request # 3 | Timestamp of first Intraday data file record written: 2017-04-12 16:12:08 | 2017-04-12 18:58:51 Socket (8) | Initiating close of socket by core. | 2017-04-12 18:58:51 Socket (8) | Shutdown started. Waiting for graceful close. | 2017-04-12 18:58:51 Socket (8) | Socket gracefully closed by remote side. | 2017-04-12 18:58:51 Historical data download thread signaled to stop. | 2017-04-12 18:58:51 Socket (8) | Closed. | 2017-04-12 18:58:51 HD Request # 3 | Received 1853 records from 2017-04-12 16:12:03 to 2017-04-12 17:59:56 (107.9 minutes) and wrote 1852 records for F.US.TFEM17 | 2017-04-12 18:58:51 HD Request # 3 | Intraday download COMPLETE for F.US.TFEM17. Completion time: 0s. Unique request ID: 1 | 2017-04-12 18:58:51 Removed historical data download ID 1 | 2017-04-12 18:58:51 Real-time Intraday chart data file updates started for F.US.TFEM17 | 2017-04-12 18:58:51 Intraday chart data file opened for F.US.TFEM17 | 2017-04-12 18:58:51 Delaying start of download for TICK-NYSE | 2017-04-12 18:58:51 Chart #1 has tagged chart #6 for full recalculation. Chartbook: FC-TF.cht | 2017-04-12 18:58:51 Chart #26 has tagged chart #6 for full recalculation. Chartbook: FC-TF.cht | 2017-04-12 18:58:51 Chart #9 has tagged chart #6 for full recalculation. Chartbook: FC-TF.cht | 2017-04-12 18:58:51 Chart #2 has tagged chart #6 for full recalculation. Chartbook: FC-TF.cht | 2017-04-12 18:58:51 HD Request # 4 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2017-04-12 18:58:51 HD Request # 4 | Download start date-time: 2017-04-12 16:12:06.000 | 2017-04-12 18:58:51 HD Request # 4 | Using server: ds3.sierracharts.com port 10149 | 2017-04-12 18:58:51 Chart #3 has tagged chart #6 for full recalculation. Chartbook: FC-TF.cht | 2017-04-12 18:58:51 Socket (9) | Creating socket. | 2017-04-12 18:58:51 F.US.TFEM17 [CB] Flex Renko 10-1-1 #6 | Performing a full recalculation because it has been tagged. Chartbook: FC-TF.cht | 2017-04-12 18:58:52 HD Request # 4 | Setting DTC encoding to Binary VLS | 2017-04-12 18:58:52 HD Request # 4 | Sending historical data logon request message. | 2017-04-12 18:58:52 HD Request # 4 | Requesting Intraday data. Start date-time: 2017-04-12 16:12:06. Record interval: 0. Symbol: TICK-NYSE | 2017-04-12 18:58:52 HD Request # 4 | Decompressing data. | 2017-04-12 18:58:52 HD Request # 4 | Receiving Intraday data for TICK-NYSE starting at 2017-04-12 16:12:06 | 2017-04-12 18:58:52 HD Request # 4 | Timestamp of first Intraday data file record written: 2017-04-12 16:12:07 | 2017-04-12 18:58:52 Socket (9) | Initiating close of socket by core. | 2017-04-12 18:58:52 Historical data download thread signaled to stop. | 2017-04-12 18:58:52 Socket (9) | Shutdown started. Waiting for graceful close. | 2017-04-12 18:58:52 Socket (9) | Socket gracefully closed by remote side. | 2017-04-12 18:58:52 Socket (9) | Closed. | 2017-04-12 18:58:52 HD Request # 4 | Received 5063 records from 2017-04-12 16:12:06 to 2017-04-12 18:58:49 (2.8 hours) and wrote 5062 records for TICK-NYSE | 2017-04-12 18:58:52 HD Request # 4 | Intraday download COMPLETE for TICK-NYSE. Completion time: 1s. Unique request ID: 3 | 2017-04-12 18:58:52 Removed historical data download ID 3 | 2017-04-12 18:58:52 Real-time Intraday chart data file updates started for TICK-NYSE | 2017-04-12 18:58:52 Intraday chart data file opened for TICK-NYSE | 2017-04-12 18:58:52 Chart #10 has tagged chart #17 for full recalculation. Chartbook: FC-TF.cht | 2017-04-12 18:58:53 TICK-NYSE [C] [M] 30 Sec #17 | Performing a full recalculation because it has been tagged. Chartbook: FC-TF.cht | 2017-04-12 18:58:53 Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid | 2017-04-12 18:59:01 |
| [2017-04-12 23:20:34] |
How many charts opened for you with this Chartbook?
| [2017-04-12 23:31:42] |
Just 2 - #27 #7 Both are TICK-NYSE |
| [2017-04-12 23:31:59] |
Sorry - #27 #17 (NOT #7) ERROR |
| [2017-04-13 16:42:07] |
After opening the Chartbook, go to the CW menu. How many charts do you see listed there?
| [2017-04-13 17:06:27] |
CW HAS 10 CHARTS IN IT. But a few observations here - 1. 2 shows up; 8 others remain minimized; 2. There were, however, many others in this chartbook that were made to show up (and not minimize), which seems to be have gotten deleted. Looks like some sort of corruption that has happened to this file. And this is where the problem is as to how come they just got erased? I have a backed up version of this file and that has all the charts as I expect and they open too. ANd I do not know as to why after certain release updates - this stuff happens. |
| [2017-04-13 17:44:36] |
1. Select Window >> Arrange Minimized Windows to see the minimized icons if you cannot currently. 2. We do not know what happened to them. They no longer exist. There was one recent release where there was a problem involving the saving of Chart Drawings to a Chartbook which may have led to the problem if you were using that version. But this is not a problem anymore in the current version. So just use a backup Chartbook file and the current version, and you will be fine going forward. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-13 17:45:47
