Date/Time: Tue, 04 Nov 2025 10:47:42 +0000
Remove Chart Info at Top
View Count: 2575
[2017-04-07 15:51:50]
User172040 - Posts: 70
How do I remove the chart info at the top? I can't see the full chart. Pls see attached screenshot
imageRemove Info.JPG / V - Attached On 2017-04-07 15:51:42 UTC - Size: 25.75 KB - 576 views
[2017-04-07 17:53:23]
Refer to:
http://www.sierrachart.com/index.php?page=doc/GlobalSettingsMenu.html#CustomizeChartHeader
[2017-04-07 19:10:45]
Thanks, but I see that all my indicator data still shows at the top. I can't remove that under 'Customize Chart Header'. Secondly, please note that the bottom of the chart also cuts off my data. How do i fix that? Please see attached
imageTop Bottom Cut Off.JPG / V - Attached On 2017-04-07 19:10:33 UTC - Size: 139.53 KB - 517 views
[2017-04-07 22:58:15]
Refer to this page:
Hiding Study and Main Price Graph Names and Values from the Values Windows and Region Data Line
Refer to Interactive Scale Range:
Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale
[2021-07-14 14:32:31]
User676363 - Posts: 84
Hello Support,
The first link was super helpful and did what I wanted for some blindfolded backtesting by allowing me to hide the symbol, dates, and pricing information. Excellent option to have. So thank you.
I notice that on this page, 3/4 images are giving me an error loading in my browser.
https://www.sierrachart.com/index.php?page=doc/helpdetails67.html#Image1
Do you have the same problems?
Thank you.
[2021-07-14 14:57:10]
John - SC Support - Posts: 42737
We do see that the images are missing. We will check on it and update the page. Thank you.
[2021-07-14 15:02:17]
The images have been corrected and if you refresh the page you will see them.
