Date/Time: Mon, 13 Jan 2025 03:01:10 +0000
6EM7 screens
View Count: 625
[2017-03-27 10:17:08]
User504193 - Posts: 38
I have just logged on after a month or so since my last logon. I've updated the rollover for 6EM7. I have 21 screens of varying ranges. All charts are set to using sierra chart continuous contract data. A lot of the screens are showing only data from logon. Can you advise? see attached.
image1.PNG / V - Attached On 2017-03-27 10:16:27 UTC - Size: 190.74 KB - 247 views
image2.PNG / V - Attached On 2017-03-27 10:16:37 UTC - Size: 197.41 KB - 271 views
[2017-03-27 17:56:07]
Refer to the information here for the different possibilities of what the problem can be and solutions:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
Since you are using a sub instance, also refer to:
Using DTC Server for Data and Trading in Another Sierra Chart Instance: Historical Data and Missing Historical Data
It is best to open a new chart for the symbol with the chart bars set to 5 minutes per bar and use that to make sure the data is there and to re-download the data.
Date Time Of Last Edit: 2017-03-27 17:58:07
