Date/Time: Sun, 12 Jan 2025 13:42:14 +0000
Button Captions
View Count: 811
[2017-03-05 23:16:07] |
User104854 - Posts: 457 |
I went in to use this for my control bar buttons. Specifically the Trade Management Study. I have 3 of them on my control bar. By default they all are labeled TMS. I went in and set the button captions to TMS1, TMS2, and TMS3 and it changed them on the control bar. But as soon as I went into the actual TMS study from a chart and changed the ACS control bar button number it changes the button back to the default which is TMS. Am I missing a setting somewhere or can this be fixed? Regardless of the simplicity of this particular example I would like to use the graphics settings and labels for other buttons and want to make sure that they'll work. Thank you. |
[2017-03-06 05:59:54] |
The Custom Study button text is set by the Trade Management by Study study. We are adding a new Input to it, to disable that so that the custom button Properties you set will remain. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
