Date/Time: Sun, 12 Jan 2025 13:46:40 +0000
User Question
View Count: 798
[2017-03-01 21:16:24] |
Sierra Chart - Max - Posts: 5778 |
I have sent you a copy of the message log showing the same error message over and over. Tom
Reading Internal Order ID file. | 2017-03-01 09:36:40 Reading Trade Orders file. | 2017-03-01 09:36:40 Reading Trade Positions file. | 2017-03-01 09:36:40 Software version: 1522 | 2017-03-01 09:36:40 Uses New Spreadsheets | 2017-03-01 09:36:40 Usage end date: 2017-03-28 | 2017-03-01 09:36:40 Enabled for: Advanced Features. | 2017-03-01 09:36:40 Enabled for: Advanced Features 2. | 2017-03-01 09:36:40 Enabled for: Sierra Chart Historical Data Service. | 2017-03-01 09:36:40 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2017-03-01 09:36:40 Enabled for: INDEXES_DATA_BARCHART | 2017-03-01 09:36:40 Enabled for: CME (Trading Account Required) | 2017-03-01 09:36:40 Enabled for: CBOT (Trading Account Required) | 2017-03-01 09:36:40 Enabled for: COMEX (Trading Account Required) | 2017-03-01 09:36:40 Enabled for: NYMEX (Trading Account Required) | 2017-03-01 09:36:40 Enabled for: CFE Futures | 2017-03-01 09:36:40 Received 1 data feed usernames. | 2017-03-01 09:36:40 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-03-01 09:36:40 Current selected Data/Trading service: TD Ameritrade | 2017-03-01 09:36:40 Chart Update Interval: 500 | 2017-03-01 09:36:40 Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-03-01 09:36:40 2017-03-01 09:37:00 Local computer time | 2017-03-01 09:36:40 2017-03-01 17:37:00 Local computer time in UTC | 2017-03-01 09:36:40 2017-03-01 09:37:00 Local computer time in SC Time Zone | 2017-03-01 09:36:40 2017-03-01 17:36:56 Server time in UTC | 2017-03-01 09:36:40 Local computer UTC time and Server UTC time difference: 4 seconds. | 2017-03-01 09:36:40 Program path: C:\SierraChart\ | 2017-03-01 09:36:40 Data Files path: C:\SierraChart\Data\ | 2017-03-01 09:36:40 OS Version Number: 6.1 | 2017-03-01 09:36:40 Locale Setting: C | 2017-03-01 09:36:40 Checking for new symbol settings for service code tda | 2017-03-01 09:36:40 HTTPS connection to www.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2017-03-01 09:36:40 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-03-01 09:37:02 HTTPS connection to www.sierrachart.com:443 (3) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-03-01 09:37:22 * HTTPS connection to www.sierrachart.com:443 (3) | Initiating close of socket by core. | 2017-03-01 09:37:22 HTTP request 1 for symbol settings MD5 for tda failed. | 2017-03-01 09:37:22 HTTPS connection to www.sierrachart.com:443 (3) | Closed. | 2017-03-01 09:37:22 HTTPS connection to www.sierrachart.com:443 (4) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-03-01 09:37:24 * HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-03-01 09:37:24 Error downloading user file: C:\SierraChart\Data\Reversion.dll. Error Message: Failed to establish a connection for the request. Restart Sierra Chart to try again. | 2017-03-01 09:37:24 * HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-03-01 09:37:24 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2017-03-01 09:37:24 TD Ameritrade | Connecting. | 2017-03-01 09:37:35 TD Ameritrade | Logging in. (Step 1 of 3) | 2017-03-01 09:37:35 HTTPS connection to apis.tdameritrade.com:443 (6) | Creating socket. Using TLS 1.0. | 2017-03-01 09:37:35 TD Ameritrade | Authorized for streamer data. Account: 86*** | 2017-03-01 09:37:35 TD Ameritrade | Authorized for streamer data. Account: 86*** | 2017-03-01 09:37:35 TD Ameritrade | Authorized for streamer data. Account: 86*** | 2017-03-01 09:37:35 TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2017-03-01 09:37:35 TD Ameritrade | Requesting message key for account activity streamer (Step 3 of 3) | 2017-03-01 09:37:35 TD Ameritrade | Requesting account balance data. Connection will be complete once received. | 2017-03-01 09:37:35 TD Ameritrade | Connected to data and trading server. | 2017-03-01 09:37:36 TD Ameritrade | Streamer request #1 initiated. | 2017-03-01 09:37:37 HTTPS connection to ameritrade02.streamer.com:443 (7) | Creating socket. Using TLS 1.0. | 2017-03-01 09:37:37 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 09:37:37 HTTPS connection to www.sierrachart.com:443 (5) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-03-01 09:37:44 * HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2017-03-01 09:37:44 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2017-03-01 09:37:44 Error downloading user file: C:\SierraChart\Data\OFE_TT2.dll. Error Message: Failed to establish a connection for the request. Restart Sierra Chart to try again. | 2017-03-01 09:37:44 * HTTPS connection to www.sierrachart.com:443 (8) | Creating socket. Using TLS 1.2. | 2017-03-01 09:37:44 UVXY 0.20 Range #1 | Reloading chart. | 2017-03-01 09:37:47 UVXY 5 Min #2 | Reloading chart. | 2017-03-01 09:37:47 VXX 5 Min #3 | Reloading chart. | 2017-03-01 09:37:47 IWM 5 Min #4 | Reloading chart. | 2017-03-01 09:37:47 DUST 5 Min #5 | Reloading chart. | 2017-03-01 09:37:47 DUST 0.20 Range #6 | Reloading chart. | 2017-03-01 09:37:47 IWM 0.20 Range #7 | Reloading chart. | 2017-03-01 09:37:47 TD Ameritrade | Starting real-time market data updates for: UVXY. ID: 1 | 2017-03-01 09:37:49 TD Ameritrade | Requesting security definition data for: UVXY. ID: 1 | 2017-03-01 09:37:49 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: UVXY | 2017-03-01 09:37:49 Intraday data recording state for symbol UVXY is set to download 'Pending'. | 2017-03-01 09:37:49 Delaying start of download for UVXY | 2017-03-01 09:37:49 TD Ameritrade | Starting real-time market data updates for: VXX. ID: 2 | 2017-03-01 09:37:49 TD Ameritrade | Requesting security definition data for: VXX. ID: 2 | 2017-03-01 09:37:49 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: VXX | 2017-03-01 09:37:49 Intraday data recording state for symbol VXX is set to download 'Pending'. | 2017-03-01 09:37:49 TD Ameritrade | Starting real-time market data updates for: IWM. ID: 3 | 2017-03-01 09:37:49 TD Ameritrade | Requesting security definition data for: IWM. ID: 3 | 2017-03-01 09:37:49 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: IWM | 2017-03-01 09:37:49 Intraday data recording state for symbol IWM is set to download 'Pending'. | 2017-03-01 09:37:49 TD Ameritrade | Starting real-time market data updates for: DUST. ID: 4 | 2017-03-01 09:37:49 TD Ameritrade | Requesting security definition data for: DUST. ID: 4 | 2017-03-01 09:37:49 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: DUST | 2017-03-01 09:37:49 Intraday data recording state for symbol DUST is set to download 'Pending'. | 2017-03-01 09:37:49 TD Ameritrade | Old streamer request finished. Request ID: 1. | 2017-03-01 09:37:50 HTTPS connection to ameritrade02.streamer.com:443 (7) | Initiating close of socket by core. | 2017-03-01 09:37:50 HTTPS connection to ameritrade02.streamer.com:443 (7) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:37:50 TD Ameritrade | Streamer request #2 initiated. | 2017-03-01 09:37:51 HTTPS connection to ameritrade02.streamer.com:443 (9) | Creating socket. Using TLS 1.0. | 2017-03-01 09:37:51 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 09:37:51 HTTPS connection to ameritrade02.streamer.com:443 (7) | Socket gracefully closed by remote side. | 2017-03-01 09:37:52 HTTPS connection to ameritrade02.streamer.com:443 (7) | Closed. | 2017-03-01 09:37:52 Delaying start of download for UVXY | 2017-03-01 09:37:52 HD Request # 2 | Downloading Intraday chart data for UVXY to the file UVXY.scid. Service: equities.us | 2017-03-01 09:37:55 HD Request # 2 | Download start date-time: 2017-02-27 14:08:47.000 | 2017-03-01 09:37:55 HD Request # 2 | Using server: ds7.sierracharts.com port 10149 | 2017-03-01 09:37:55 Socket (10) | Creating socket. | 2017-03-01 09:37:55 HD Request # 2 | Setting DTC encoding to Binary VLS | 2017-03-01 09:37:55 HD Request # 2 | Sending historical data logon request message. | 2017-03-01 09:37:55 HD Request # 2 | Requesting Intraday data. Start date-time: 2017-02-27 14:08:47. Record interval: 0. Symbol: UVXY | 2017-03-01 09:37:55 HD Request # 2 | Decompressing data. | 2017-03-01 09:37:55 HD Request # 2 | Receiving Intraday data for UVXY starting at 2017-02-27 14:09:35 | 2017-03-01 09:37:56 HD Request # 2 | Timestamp of first Intraday data file record written: 2017-02-27 14:09:35 | 2017-03-01 09:37:56 Socket (10) | Initiating close of socket by core. | 2017-03-01 09:37:57 The network socket for historical data has been closed. | 2017-03-01 09:37:57 Socket (10) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:37:57 HD Request # 2 | Received 119976 records from 2017-02-27 14:09:35 to 2017-03-01 09:22:51 (43.2 hours) and wrote 119976 records for UVXY | 2017-03-01 09:37:57 HD Request # 2 | Intraday download COMPLETE for UVXY. Completion time: 2s. Unique request ID: 1 | 2017-03-01 09:37:57 Removed historical data download ID 1 | 2017-03-01 09:37:57 Real-time Intraday chart data file updates started for UVXY | 2017-03-01 09:37:57 Intraday chart data file opened for UVXY | 2017-03-01 09:37:57 TD Ameritrade | Using primary service for historical data for UVXY | 2017-03-01 09:37:57 Intraday data recording state for symbol UVXY is set to download 'Pending'. | 2017-03-01 09:37:57 HD Request # 3 | Downloading Intraday chart data for UVXY to the file UVXY.scid. Service: equities.us | 2017-03-01 09:37:57 HD Request # 3 | Download start date-time: 2017-03-01 09:22:51.000 | 2017-03-01 09:37:57 HD Request # 3 | Requesting 0 days of historical Minute data. | 2017-03-01 09:37:57 HD Request # 4 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: equities.us | 2017-03-01 09:37:57 HD Request # 4 | Download start date-time: 2017-02-27 14:09:04.000 | 2017-03-01 09:37:57 HD Request # 4 | Using server: ds1.sierracharts.com port 10149 | 2017-03-01 09:37:57 Socket (11) | Creating socket. | 2017-03-01 09:37:58 Socket (10) | Socket gracefully closed by remote side. | 2017-03-01 09:37:58 Socket (10) | Closed. | 2017-03-01 09:37:58 HD Request # 3 | Receiving Intraday data for UVXY starting at 2017-03-01 05:00:00 | 2017-03-01 09:37:58 HD Request # 3 | Timestamp of first Intraday data file record written: 2017-03-01 09:23:00 | 2017-03-01 09:37:58 HD Request # 3 | Received 276 records from 2017-03-01 05:00:00 to 2017-03-01 09:36:00 (4.6 hours) and wrote 14 records for UVXY | 2017-03-01 09:37:58 HD Request # 3 | Intraday download COMPLETE for UVXY. Completion time: 0s. Unique request ID: 5 | 2017-03-01 09:37:58 Removed historical data download ID 5 | 2017-03-01 09:37:58 Real-time Intraday chart data file updates started for UVXY | 2017-03-01 09:37:58 Intraday chart data file opened for UVXY | 2017-03-01 09:37:58 HD Request # 4 | Setting DTC encoding to Binary VLS | 2017-03-01 09:37:58 HD Request # 4 | Sending historical data logon request message. | 2017-03-01 09:37:58 HD Request # 4 | Requesting Intraday data. Start date-time: 2017-02-27 14:09:04. Record interval: 0. Symbol: VXX | 2017-03-01 09:37:58 HD Request # 4 | Decompressing data. | 2017-03-01 09:37:58 HD Request # 4 | Receiving Intraday data for VXX starting at 2017-02-27 14:11:29 | 2017-03-01 09:37:58 HD Request # 4 | Timestamp of first Intraday data file record written: 2017-02-27 14:11:29 | 2017-03-01 09:37:58 Socket (11) | Initiating close of socket by core. | 2017-03-01 09:37:59 The network socket for historical data has been closed. | 2017-03-01 09:37:59 Socket (11) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:37:59 HD Request # 4 | Received 211008 records from 2017-02-27 14:11:29 to 2017-03-01 09:22:55 (43.2 hours) and wrote 211008 records for VXX | 2017-03-01 09:37:59 HD Request # 4 | Intraday download COMPLETE for VXX. Completion time: 2s. Unique request ID: 2 | 2017-03-01 09:37:59 Removed historical data download ID 2 | 2017-03-01 09:37:59 Real-time Intraday chart data file updates started for VXX | 2017-03-01 09:37:59 Intraday chart data file opened for VXX | 2017-03-01 09:37:59 TD Ameritrade | Using primary service for historical data for VXX | 2017-03-01 09:37:59 Intraday data recording state for symbol VXX is set to download 'Pending'. | 2017-03-01 09:37:59 HD Request # 5 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: equities.us | 2017-03-01 09:37:59 HD Request # 5 | Download start date-time: 2017-03-01 09:22:55.000 | 2017-03-01 09:37:59 HD Request # 5 | Requesting 0 days of historical Minute data. | 2017-03-01 09:37:59 HD Request # 6 | Downloading Intraday chart data for IWM to the file IWM.scid. Service: equities.us | 2017-03-01 09:37:59 HD Request # 6 | Download start date-time: 2017-02-27 14:07:11.000 | 2017-03-01 09:37:59 HD Request # 6 | Using server: ds7.sierracharts.com port 10149 | 2017-03-01 09:37:59 Socket (12) | Creating socket. | 2017-03-01 09:37:59 Socket (11) | Socket gracefully closed by remote side. | 2017-03-01 09:37:59 Socket (11) | Closed. | 2017-03-01 09:37:59 HD Request # 5 | Receiving Intraday data for VXX starting at 2017-03-01 05:00:00 | 2017-03-01 09:37:59 HD Request # 5 | Timestamp of first Intraday data file record written: 2017-03-01 09:23:00 | 2017-03-01 09:37:59 HD Request # 5 | Received 277 records from 2017-03-01 05:00:00 to 2017-03-01 09:36:00 (4.6 hours) and wrote 14 records for VXX | 2017-03-01 09:37:59 HD Request # 5 | Intraday download COMPLETE for VXX. Completion time: 0s. Unique request ID: 6 | 2017-03-01 09:37:59 Removed historical data download ID 6 | 2017-03-01 09:37:59 Real-time Intraday chart data file updates started for VXX | 2017-03-01 09:37:59 Intraday chart data file opened for VXX | 2017-03-01 09:37:59 HD Request # 6 | Setting DTC encoding to Binary VLS | 2017-03-01 09:38:00 HD Request # 6 | Sending historical data logon request message. | 2017-03-01 09:38:00 HD Request # 6 | Requesting Intraday data. Start date-time: 2017-02-27 14:07:11. Record interval: 0. Symbol: IWM | 2017-03-01 09:38:00 HD Request # 6 | Decompressing data. | 2017-03-01 09:38:00 HD Request # 6 | Receiving Intraday data for IWM starting at 2017-02-27 14:11:02 | 2017-03-01 09:38:00 HD Request # 6 | Timestamp of first Intraday data file record written: 2017-02-27 14:11:02 | 2017-03-01 09:38:00 Socket (12) | Initiating close of socket by core. | 2017-03-01 09:38:02 The network socket for historical data has been closed. | 2017-03-01 09:38:02 Socket (12) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:38:02 HD Request # 6 | Received 188682 records from 2017-02-27 14:11:02 to 2017-03-01 09:22:51 (43.2 hours) and wrote 188682 records for IWM | 2017-03-01 09:38:02 HD Request # 6 | Intraday download COMPLETE for IWM. Completion time: 3s. Unique request ID: 3 | 2017-03-01 09:38:02 Removed historical data download ID 3 | 2017-03-01 09:38:02 Real-time Intraday chart data file updates started for IWM | 2017-03-01 09:38:02 Intraday chart data file opened for IWM | 2017-03-01 09:38:02 TD Ameritrade | Using primary service for historical data for IWM | 2017-03-01 09:38:02 Intraday data recording state for symbol IWM is set to download 'Pending'. | 2017-03-01 09:38:02 HD Request # 7 | Downloading Intraday chart data for IWM to the file IWM.scid. Service: equities.us | 2017-03-01 09:38:02 HD Request # 7 | Download start date-time: 2017-03-01 09:22:51.000 | 2017-03-01 09:38:02 HD Request # 7 | Requesting 0 days of historical Minute data. | 2017-03-01 09:38:02 HD Request # 8 | Downloading Intraday chart data for DUST to the file DUST.scid. Service: equities.us | 2017-03-01 09:38:02 HD Request # 8 | Download start date-time: 2017-02-27 14:07:37.000 | 2017-03-01 09:38:02 HD Request # 8 | Using server: ds1.sierracharts.com port 10149 | 2017-03-01 09:38:02 Socket (13) | Creating socket. | 2017-03-01 09:38:02 Socket (12) | Socket gracefully closed by remote side. | 2017-03-01 09:38:02 Socket (12) | Closed. | 2017-03-01 09:38:02 HD Request # 7 | Receiving Intraday data for IWM starting at 2017-03-01 05:00:00 | 2017-03-01 09:38:02 HD Request # 7 | Timestamp of first Intraday data file record written: 2017-03-01 09:23:00 | 2017-03-01 09:38:02 HD Request # 7 | Received 273 records from 2017-03-01 05:00:00 to 2017-03-01 09:36:00 (4.6 hours) and wrote 14 records for IWM | 2017-03-01 09:38:02 HD Request # 7 | Intraday download COMPLETE for IWM. Completion time: 0s. Unique request ID: 7 | 2017-03-01 09:38:02 Removed historical data download ID 7 | 2017-03-01 09:38:02 Real-time Intraday chart data file updates started for IWM | 2017-03-01 09:38:02 Intraday chart data file opened for IWM | 2017-03-01 09:38:02 HD Request # 8 | Setting DTC encoding to Binary VLS | 2017-03-01 09:38:02 HD Request # 8 | Sending historical data logon request message. | 2017-03-01 09:38:02 HD Request # 8 | Requesting Intraday data. Start date-time: 2017-02-27 14:07:37. Record interval: 0. Symbol: DUST | 2017-03-01 09:38:02 HD Request # 8 | Decompressing data. | 2017-03-01 09:38:03 HD Request # 8 | Receiving Intraday data for DUST starting at 2017-02-27 14:11:29 | 2017-03-01 09:38:03 HD Request # 8 | Timestamp of first Intraday data file record written: 2017-02-27 14:11:29 | 2017-03-01 09:38:03 Socket (13) | Initiating close of socket by core. | 2017-03-01 09:38:03 The network socket for historical data has been closed. | 2017-03-01 09:38:03 HD Request # 8 | Received 57501 records from 2017-02-27 14:11:29 to 2017-03-01 09:23:01 (43.2 hours) and wrote 57501 records for DUST | 2017-03-01 09:38:03 HD Request # 8 | Intraday download COMPLETE for DUST. Completion time: 1s. Unique request ID: 4 | 2017-03-01 09:38:03 Removed historical data download ID 4 | 2017-03-01 09:38:03 Real-time Intraday chart data file updates started for DUST | 2017-03-01 09:38:03 Intraday chart data file opened for DUST | 2017-03-01 09:38:03 TD Ameritrade | Using primary service for historical data for DUST | 2017-03-01 09:38:03 Intraday data recording state for symbol DUST is set to download 'Pending'. | 2017-03-01 09:38:03 Socket (13) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:38:03 HD Request # 9 | Downloading Intraday chart data for DUST to the file DUST.scid. Service: equities.us | 2017-03-01 09:38:03 HD Request # 9 | Download start date-time: 2017-03-01 09:23:01.000 | 2017-03-01 09:38:03 HD Request # 9 | Requesting 0 days of historical Minute data. | 2017-03-01 09:38:03 Socket (13) | Socket gracefully closed by remote side. | 2017-03-01 09:38:03 Socket (13) | Closed. | 2017-03-01 09:38:03 HD Request # 9 | Receiving Intraday data for DUST starting at 2017-03-01 05:00:00 | 2017-03-01 09:38:03 HD Request # 9 | Timestamp of first Intraday data file record written: 2017-03-01 09:24:00 | 2017-03-01 09:38:03 HD Request # 9 | Received 274 records from 2017-03-01 05:00:00 to 2017-03-01 09:37:00 (4.6 hours) and wrote 14 records for DUST | 2017-03-01 09:38:03 HD Request # 9 | Intraday download COMPLETE for DUST. Completion time: 0s. Unique request ID: 8 | 2017-03-01 09:38:03 Removed historical data download ID 8 | 2017-03-01 09:38:03 Real-time Intraday chart data file updates started for DUST | 2017-03-01 09:38:03 Intraday chart data file opened for DUST | 2017-03-01 09:38:03 HTTPS connection to www.sierrachart.com:443 (8) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-03-01 09:38:06 * HTTPS connection to www.sierrachart.com:443 (8) | Initiating close of socket by core. | 2017-03-01 09:38:06 Error downloading user file: C:\SierraChart\Data\OFE_OA.dll. Error Message: Failed to establish a connection for the request. Restart Sierra Chart to try again. | 2017-03-01 09:38:06 * HTTPS connection to www.sierrachart.com:443 (8) | Closed. | 2017-03-01 09:38:06 HTTPS connection to www.sierrachart.com:443 (14) | Creating socket. Using TLS 1.2. | 2017-03-01 09:38:06 HTTPS connection to www.sierrachart.com:443 (14) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-03-01 09:38:27 * HTTPS connection to www.sierrachart.com:443 (14) | Initiating close of socket by core. | 2017-03-01 09:38:27 Error downloading user file: C:\SierraChart\Data\OFE_DF.dll. Error Message: Failed to establish a connection for the request. Restart Sierra Chart to try again. | 2017-03-01 09:38:27 * HTTPS connection to www.sierrachart.com:443 (14) | Closed. | 2017-03-01 09:38:27 HTTPS connection to www.sierrachart.com:443 (15) | Creating socket. Using TLS 1.2. | 2017-03-01 09:38:27 HTTPS connection to www.sierrachart.com:443 (15) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-03-01 09:38:47 * HTTPS connection to www.sierrachart.com:443 (15) | Initiating close of socket by core. | 2017-03-01 09:38:47 Error downloading user file: C:\SierraChart\Data\OFETilt.dll. Error Message: Failed to establish a connection for the request. Restart Sierra Chart to try again. | 2017-03-01 09:38:47 * HTTPS connection to www.sierrachart.com:443 (15) | Closed. | 2017-03-01 09:38:48 HTTPS connection to www.sierrachart.com:443 (16) | Creating socket. Using TLS 1.2. | 2017-03-01 09:38:48 HTTPS connection to www.sierrachart.com:443 (16) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-03-01 09:39:09 * HTTPS connection to www.sierrachart.com:443 (16) | Initiating close of socket by core. | 2017-03-01 09:39:09 Error downloading user file: C:\SierraChart\Data\OFEOrderflowAcceptance.dll. Error Message: Failed to establish a connection for the request. Restart Sierra Chart to try again. | 2017-03-01 09:39:09 * HTTPS connection to www.sierrachart.com:443 (16) | Closed. | 2017-03-01 09:39:09 HTTPS connection to www.sierrachart.com:443 (18) | Creating socket. Using TLS 1.2. | 2017-03-01 09:39:09 HTTPS connection to www.sierrachart.com:443 (18) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-03-01 09:39:30 * HTTPS connection to www.sierrachart.com:443 (18) | Initiating close of socket by core. | 2017-03-01 09:39:30 Error downloading user file: C:\SierraChart\Data\Robert.dll. Error Message: Failed to establish a connection for the request. Restart Sierra Chart to try again. | 2017-03-01 09:39:30 * HTTPS connection to www.sierrachart.com:443 (18) | Closed. | 2017-03-01 09:39:30 HTTPS connection to apis.tdameritrade.com:443 (6) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init; error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 09:40:00 HTTPS connection to apis.tdameritrade.com:443 (6) | Initiating close of socket by core. | 2017-03-01 09:40:00 HTTPS connection to apis.tdameritrade.com:443 (6) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:40:00 HTTPS connection to apis.tdameritrade.com:443 (19) | Creating socket. Using TLS 1.0. | 2017-03-01 09:40:00 HTTPS connection to apis.tdameritrade.com:443 (6) | Received socket Close event | 2017-03-01 09:40:00 HTTPS connection to apis.tdameritrade.com:443 (6) | Closed. | 2017-03-01 09:40:00 HTTPS connection to ameritrade02.streamer.com:443 (9) | Initiating close of socket by core. | 2017-03-01 09:40:51 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 2. | 2017-03-01 09:40:51 HTTPS connection to ameritrade02.streamer.com:443 (9) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:40:51 TD Ameritrade | Streamer request #3 initiated. | 2017-03-01 09:40:53 HTTPS connection to ameritrade02.streamer.com:443 (20) | Creating socket. Using TLS 1.0. | 2017-03-01 09:40:53 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 09:40:54 Opened cached Intraday file: C:\SierraChart\Data\UVXY.scid | 2017-03-01 09:40:54 Opened cached Intraday file: C:\SierraChart\Data\VXX.scid | 2017-03-01 09:40:54 Opened cached Intraday file: C:\SierraChart\Data\IWM.scid | 2017-03-01 09:40:54 Opened cached Intraday file: C:\SierraChart\Data\DUST.scid | 2017-03-01 09:40:54 HTTPS connection to ameritrade02.streamer.com:443 (20) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 09:41:22 HTTPS connection to ameritrade02.streamer.com:443 (20) | Initiating close of socket by core. | 2017-03-01 09:41:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 3. | 2017-03-01 09:41:22 HTTPS connection to ameritrade02.streamer.com:443 (20) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:41:22 TD Ameritrade | Streamer request #4 initiated. | 2017-03-01 09:41:24 HTTPS connection to ameritrade02.streamer.com:443 (22) | Creating socket. Using TLS 1.0. | 2017-03-01 09:41:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 09:41:24 HTTPS connection to ameritrade02.streamer.com:443 (20) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 09:41:24 * HTTPS connection to ameritrade02.streamer.com:443 (20) | Received socket Close event | 2017-03-01 09:41:24 HTTPS connection to ameritrade02.streamer.com:443 (20) | Closed. | 2017-03-01 09:41:24 HTTPS connection to ameritrade02.streamer.com:443 (22) | Received socket Close event | 2017-03-01 09:42:34 HTTPS connection to ameritrade02.streamer.com:443 (22) | Initiating close of socket by core. | 2017-03-01 09:42:34 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 4. | 2017-03-01 09:42:34 HTTPS connection to ameritrade02.streamer.com:443 (22) | Socket gracefully closed by remote side. | 2017-03-01 09:42:34 HTTPS connection to ameritrade02.streamer.com:443 (22) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-03-01 09:42:34 HTTPS connection to ameritrade02.streamer.com:443 (22) | Closed. | 2017-03-01 09:42:34 TD Ameritrade | Streamer request #5 initiated. | 2017-03-01 09:42:36 HTTPS connection to ameritrade02.streamer.com:443 (23) | Creating socket. Using TLS 1.0. | 2017-03-01 09:42:36 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 09:42:37 HTTPS connection to ameritrade02.streamer.com:443 (9) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 09:42:38 HTTPS connection to ameritrade02.streamer.com:443 (9) | Closed. | 2017-03-01 09:42:38 HTTPS connection to ameritrade02.streamer.com:443 (23) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 09:43:23 HTTPS connection to ameritrade02.streamer.com:443 (23) | Initiating close of socket by core. | 2017-03-01 09:43:23 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 5. | 2017-03-01 09:43:23 HTTPS connection to ameritrade02.streamer.com:443 (23) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:43:23 TD Ameritrade | Streamer request #6 initiated. | 2017-03-01 09:43:25 HTTPS connection to ameritrade02.streamer.com:443 (25) | Creating socket. Using TLS 1.0. | 2017-03-01 09:43:25 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 09:43:26 HTTPS connection to ameritrade02.streamer.com:443 (23) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 09:43:26 * HTTPS connection to ameritrade02.streamer.com:443 (23) | Received socket Close event | 2017-03-01 09:43:26 HTTPS connection to ameritrade02.streamer.com:443 (23) | Closed. | 2017-03-01 09:43:26 HTTPS connection to apis.tdameritrade.com:443 (19) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 09:46:00 HTTPS connection to apis.tdameritrade.com:443 (19) | Initiating close of socket by core. | 2017-03-01 09:46:00 HTTPS connection to apis.tdameritrade.com:443 (19) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:46:00 HTTPS connection to apis.tdameritrade.com:443 (27) | Creating socket. Using TLS 1.0. | 2017-03-01 09:46:00 HTTPS connection to apis.tdameritrade.com:443 (19) | Received socket Close event | 2017-03-01 09:46:00 HTTPS connection to apis.tdameritrade.com:443 (19) | Closed. | 2017-03-01 09:46:00 HTTPS connection to ameritrade02.streamer.com:443 (25) | Initiating close of socket by core. | 2017-03-01 09:46:26 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 6. | 2017-03-01 09:46:26 HTTPS connection to ameritrade02.streamer.com:443 (25) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:46:26 TD Ameritrade | Streamer request #7 initiated. | 2017-03-01 09:46:28 HTTPS connection to ameritrade02.streamer.com:443 (28) | Creating socket. Using TLS 1.0. | 2017-03-01 09:46:28 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 09:46:28 IWM 5 Min #8 | Reloading chart. | 2017-03-01 09:47:05 HTTPS connection to ameritrade02.streamer.com:443 (28) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 09:47:22 HTTPS connection to ameritrade02.streamer.com:443 (28) | Initiating close of socket by core. | 2017-03-01 09:47:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 7. | 2017-03-01 09:47:22 HTTPS connection to ameritrade02.streamer.com:443 (28) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:47:22 TD Ameritrade | Streamer request #8 initiated. | 2017-03-01 09:47:24 HTTPS connection to ameritrade02.streamer.com:443 (30) | Creating socket. Using TLS 1.0. | 2017-03-01 09:47:24 HTTPS connection to ameritrade02.streamer.com:443 (28) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 09:47:24 * HTTPS connection to ameritrade02.streamer.com:443 (28) | Received socket Close event | 2017-03-01 09:47:24 HTTPS connection to ameritrade02.streamer.com:443 (28) | Closed. | 2017-03-01 09:47:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 09:47:24 HTTPS connection to ameritrade02.streamer.com:443 (25) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 09:47:40 HTTPS connection to ameritrade02.streamer.com:443 (25) | Closed. | 2017-03-01 09:47:40 HTTPS connection to ameritrade02.streamer.com:443 (30) | Initiating close of socket by core. | 2017-03-01 09:50:24 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 8. | 2017-03-01 09:50:24 HTTPS connection to ameritrade02.streamer.com:443 (30) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:50:24 TD Ameritrade | Streamer request #9 initiated. | 2017-03-01 09:50:26 HTTPS connection to ameritrade02.streamer.com:443 (32) | Creating socket. Using TLS 1.0. | 2017-03-01 09:50:26 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 09:50:27 HTTPS connection to ameritrade02.streamer.com:443 (30) | Socket gracefully closed by remote side. | 2017-03-01 09:50:27 HTTPS connection to ameritrade02.streamer.com:443 (30) | Closed. | 2017-03-01 09:50:27 HTTPS connection to ameritrade02.streamer.com:443 (32) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 09:51:22 HTTPS connection to ameritrade02.streamer.com:443 (32) | Initiating close of socket by core. | 2017-03-01 09:51:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 9. | 2017-03-01 09:51:22 HTTPS connection to ameritrade02.streamer.com:443 (32) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:51:22 TD Ameritrade | Streamer request #10 initiated. | 2017-03-01 09:51:24 HTTPS connection to ameritrade02.streamer.com:443 (34) | Creating socket. Using TLS 1.0. | 2017-03-01 09:51:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 09:51:24 HTTPS connection to ameritrade02.streamer.com:443 (32) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 09:51:24 * HTTPS connection to ameritrade02.streamer.com:443 (32) | Received socket Close event | 2017-03-01 09:51:24 HTTPS connection to ameritrade02.streamer.com:443 (32) | Closed. | 2017-03-01 09:51:24 HTTPS connection to ameritrade02.streamer.com:443 (34) | Initiating close of socket by core. | 2017-03-01 09:54:24 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 10. | 2017-03-01 09:54:24 HTTPS connection to ameritrade02.streamer.com:443 (34) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:54:24 TD Ameritrade | Streamer request #11 initiated. | 2017-03-01 09:54:26 HTTPS connection to ameritrade02.streamer.com:443 (36) | Creating socket. Using TLS 1.0. | 2017-03-01 09:54:26 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 09:54:27 HTTPS connection to ameritrade02.streamer.com:443 (36) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 09:55:22 HTTPS connection to ameritrade02.streamer.com:443 (36) | Initiating close of socket by core. | 2017-03-01 09:55:22 HTTPS connection to ameritrade02.streamer.com:443 (36) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:55:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 11. | 2017-03-01 09:55:22 TD Ameritrade | Streamer request #12 initiated. | 2017-03-01 09:55:24 HTTPS connection to ameritrade02.streamer.com:443 (38) | Creating socket. Using TLS 1.0. | 2017-03-01 09:55:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 09:55:25 HTTPS connection to ameritrade02.streamer.com:443 (36) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 09:55:25 * HTTPS connection to ameritrade02.streamer.com:443 (36) | Received socket Close event | 2017-03-01 09:55:25 HTTPS connection to ameritrade02.streamer.com:443 (36) | Closed. | 2017-03-01 09:55:25 HTTPS connection to ameritrade02.streamer.com:443 (34) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 09:55:40 HTTPS connection to ameritrade02.streamer.com:443 (34) | Closed. | 2017-03-01 09:55:40 HTTPS connection to ameritrade02.streamer.com:443 (38) | Initiating close of socket by core. | 2017-03-01 09:58:25 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 12. | 2017-03-01 09:58:25 HTTPS connection to ameritrade02.streamer.com:443 (38) | Shutdown started. Waiting for graceful close. | 2017-03-01 09:58:25 TD Ameritrade | Streamer request #13 initiated. | 2017-03-01 09:58:27 HTTPS connection to ameritrade02.streamer.com:443 (40) | Creating socket. Using TLS 1.0. | 2017-03-01 09:58:27 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 09:58:27 HTTPS connection to ameritrade02.streamer.com:443 (38) | Socket gracefully closed by remote side. | 2017-03-01 09:58:38 HTTPS connection to ameritrade02.streamer.com:443 (38) | Closed. | 2017-03-01 09:58:38 HTTPS connection to ameritrade02.streamer.com:443 (40) | Initiating close of socket by core. | 2017-03-01 10:01:27 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 13. | 2017-03-01 10:01:27 HTTPS connection to ameritrade02.streamer.com:443 (40) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:01:27 TD Ameritrade | Streamer request #14 initiated. | 2017-03-01 10:01:29 HTTPS connection to ameritrade02.streamer.com:443 (43) | Creating socket. Using TLS 1.0. | 2017-03-01 10:01:30 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:01:30 HTTPS connection to ameritrade02.streamer.com:443 (40) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 10:02:40 HTTPS connection to ameritrade02.streamer.com:443 (40) | Closed. | 2017-03-01 10:02:40 HTTPS connection to apis.tdameritrade.com:443 (27) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 10:04:01 HTTPS connection to apis.tdameritrade.com:443 (27) | Initiating close of socket by core. | 2017-03-01 10:04:01 HTTPS connection to apis.tdameritrade.com:443 (27) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:04:01 HTTPS connection to apis.tdameritrade.com:443 (45) | Creating socket. Using TLS 1.0. | 2017-03-01 10:04:01 HTTPS connection to apis.tdameritrade.com:443 (27) | Received socket Close event | 2017-03-01 10:04:01 HTTPS connection to apis.tdameritrade.com:443 (27) | Closed. | 2017-03-01 10:04:01 HTTPS connection to ameritrade02.streamer.com:443 (43) | Initiating close of socket by core. | 2017-03-01 10:04:30 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 14. | 2017-03-01 10:04:30 HTTPS connection to ameritrade02.streamer.com:443 (43) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:04:30 TD Ameritrade | Streamer request #15 initiated. | 2017-03-01 10:04:32 HTTPS connection to ameritrade02.streamer.com:443 (46) | Creating socket. Using TLS 1.0. | 2017-03-01 10:04:32 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:04:32 HTTPS connection to ameritrade02.streamer.com:443 (43) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 10:05:40 HTTPS connection to ameritrade02.streamer.com:443 (43) | Closed. | 2017-03-01 10:05:40 HTTPS connection to ameritrade02.streamer.com:443 (46) | Initiating close of socket by core. | 2017-03-01 10:07:32 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 15. | 2017-03-01 10:07:32 HTTPS connection to ameritrade02.streamer.com:443 (46) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:07:32 TD Ameritrade | Streamer request #16 initiated. | 2017-03-01 10:07:34 HTTPS connection to ameritrade02.streamer.com:443 (49) | Creating socket. Using TLS 1.0. | 2017-03-01 10:07:34 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:07:34 HTTPS connection to ameritrade02.streamer.com:443 (46) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 10:08:40 HTTPS connection to ameritrade02.streamer.com:443 (46) | Closed. | 2017-03-01 10:08:40 HTTPS connection to apis.tdameritrade.com:443 (45) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 10:10:00 HTTPS connection to apis.tdameritrade.com:443 (45) | Initiating close of socket by core. | 2017-03-01 10:10:00 HTTPS connection to apis.tdameritrade.com:443 (45) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:10:00 HTTPS connection to apis.tdameritrade.com:443 (45) | Received socket Close event | 2017-03-01 10:10:00 HTTPS connection to apis.tdameritrade.com:443 (45) | Closed. | 2017-03-01 10:10:00 HTTPS connection to apis.tdameritrade.com:443 (51) | Creating socket. Using TLS 1.0. | 2017-03-01 10:10:01 HTTPS connection to ameritrade02.streamer.com:443 (49) | Initiating close of socket by core. | 2017-03-01 10:10:34 HTTPS connection to ameritrade02.streamer.com:443 (49) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:10:34 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 16. | 2017-03-01 10:10:34 TD Ameritrade | Streamer request #17 initiated. | 2017-03-01 10:10:36 HTTPS connection to ameritrade02.streamer.com:443 (52) | Creating socket. Using TLS 1.0. | 2017-03-01 10:10:36 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:10:37 HTTPS connection to ameritrade02.streamer.com:443 (49) | Socket gracefully closed by remote side. | 2017-03-01 10:10:43 HTTPS connection to ameritrade02.streamer.com:443 (49) | Closed. | 2017-03-01 10:10:43 HTTPS connection to ameritrade02.streamer.com:443 (52) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 10:11:22 HTTPS connection to ameritrade02.streamer.com:443 (52) | Initiating close of socket by core. | 2017-03-01 10:11:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 17. | 2017-03-01 10:11:22 HTTPS connection to ameritrade02.streamer.com:443 (52) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:11:22 TD Ameritrade | Streamer request #18 initiated. | 2017-03-01 10:11:24 HTTPS connection to ameritrade02.streamer.com:443 (54) | Creating socket. Using TLS 1.0. | 2017-03-01 10:11:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:11:24 HTTPS connection to ameritrade02.streamer.com:443 (52) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 10:11:25 * HTTPS connection to ameritrade02.streamer.com:443 (52) | Received socket Close event | 2017-03-01 10:11:25 HTTPS connection to ameritrade02.streamer.com:443 (52) | Closed. | 2017-03-01 10:11:25 HTTPS connection to ameritrade02.streamer.com:443 (54) | Initiating close of socket by core. | 2017-03-01 10:14:24 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 18. | 2017-03-01 10:14:24 HTTPS connection to ameritrade02.streamer.com:443 (54) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:14:24 TD Ameritrade | Streamer request #19 initiated. | 2017-03-01 10:14:26 HTTPS connection to ameritrade02.streamer.com:443 (56) | Creating socket. Using TLS 1.0. | 2017-03-01 10:14:27 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 10:14:27 HTTPS connection to ameritrade02.streamer.com:443 (54) | Socket gracefully closed by remote side. | 2017-03-01 10:14:40 HTTPS connection to ameritrade02.streamer.com:443 (54) | Closed. | 2017-03-01 10:14:40 HTTPS connection to ameritrade02.streamer.com:443 (56) | Received socket Close event | 2017-03-01 10:14:54 HTTPS connection to ameritrade02.streamer.com:443 (56) | Initiating close of socket by core. | 2017-03-01 10:14:54 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 19. | 2017-03-01 10:14:54 HTTPS connection to ameritrade02.streamer.com:443 (56) | Socket gracefully closed by remote side. | 2017-03-01 10:14:54 HTTPS connection to ameritrade02.streamer.com:443 (56) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-03-01 10:14:54 HTTPS connection to ameritrade02.streamer.com:443 (56) | Closed. | 2017-03-01 10:14:54 TD Ameritrade | Streamer request #20 initiated. | 2017-03-01 10:14:56 HTTPS connection to ameritrade02.streamer.com:443 (57) | Creating socket. Using TLS 1.0. | 2017-03-01 10:14:56 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:14:56 HTTPS connection to ameritrade02.streamer.com:443 (57) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 10:15:22 HTTPS connection to ameritrade02.streamer.com:443 (57) | Initiating close of socket by core. | 2017-03-01 10:15:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 20. | 2017-03-01 10:15:22 HTTPS connection to ameritrade02.streamer.com:443 (57) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:15:22 TD Ameritrade | Streamer request #21 initiated. | 2017-03-01 10:15:24 HTTPS connection to ameritrade02.streamer.com:443 (59) | Creating socket. Using TLS 1.0. | 2017-03-01 10:15:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:15:24 HTTPS connection to ameritrade02.streamer.com:443 (57) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 10:15:24 * HTTPS connection to ameritrade02.streamer.com:443 (57) | Received socket Close event | 2017-03-01 10:15:24 HTTPS connection to ameritrade02.streamer.com:443 (57) | Closed. | 2017-03-01 10:15:24 HTTPS connection to ameritrade02.streamer.com:443 (59) | Initiating close of socket by core. | 2017-03-01 10:18:24 HTTPS connection to ameritrade02.streamer.com:443 (59) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:18:24 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 21. | 2017-03-01 10:18:24 TD Ameritrade | Streamer request #22 initiated. | 2017-03-01 10:18:26 HTTPS connection to ameritrade02.streamer.com:443 (61) | Creating socket. Using TLS 1.0. | 2017-03-01 10:18:26 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:18:26 HTTPS connection to ameritrade02.streamer.com:443 (59) | Socket gracefully closed by remote side. | 2017-03-01 10:18:40 HTTPS connection to ameritrade02.streamer.com:443 (59) | Closed. | 2017-03-01 10:18:40 HTTPS connection to ameritrade02.streamer.com:443 (61) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 10:19:21 HTTPS connection to ameritrade02.streamer.com:443 (61) | Initiating close of socket by core. | 2017-03-01 10:19:21 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 22. | 2017-03-01 10:19:21 HTTPS connection to ameritrade02.streamer.com:443 (61) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:19:21 TD Ameritrade | Streamer request #23 initiated. | 2017-03-01 10:19:23 HTTPS connection to ameritrade02.streamer.com:443 (63) | Creating socket. Using TLS 1.0. | 2017-03-01 10:19:23 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:19:24 HTTPS connection to ameritrade02.streamer.com:443 (61) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 10:19:24 * HTTPS connection to ameritrade02.streamer.com:443 (61) | Received socket Close event | 2017-03-01 10:19:24 HTTPS connection to ameritrade02.streamer.com:443 (61) | Closed. | 2017-03-01 10:19:24 HTTPS connection to apis.tdameritrade.com:443 (51) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 10:22:00 HTTPS connection to apis.tdameritrade.com:443 (51) | Initiating close of socket by core. | 2017-03-01 10:22:00 HTTPS connection to apis.tdameritrade.com:443 (51) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:22:00 HTTPS connection to apis.tdameritrade.com:443 (65) | Creating socket. Using TLS 1.0. | 2017-03-01 10:22:00 HTTPS connection to apis.tdameritrade.com:443 (51) | Received socket Close event | 2017-03-01 10:22:00 HTTPS connection to apis.tdameritrade.com:443 (51) | Closed. | 2017-03-01 10:22:00 HTTPS connection to ameritrade02.streamer.com:443 (63) | Initiating close of socket by core. | 2017-03-01 10:22:24 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 23. | 2017-03-01 10:22:24 HTTPS connection to ameritrade02.streamer.com:443 (63) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:22:24 TD Ameritrade | Streamer request #24 initiated. | 2017-03-01 10:22:26 HTTPS connection to ameritrade02.streamer.com:443 (66) | Creating socket. Using TLS 1.0. | 2017-03-01 10:22:26 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:22:26 HTTPS connection to ameritrade02.streamer.com:443 (63) | Socket gracefully closed by remote side. | 2017-03-01 10:22:40 HTTPS connection to ameritrade02.streamer.com:443 (63) | Closed. | 2017-03-01 10:22:40 HTTPS connection to ameritrade02.streamer.com:443 (66) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 10:23:22 HTTPS connection to ameritrade02.streamer.com:443 (66) | Initiating close of socket by core. | 2017-03-01 10:23:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 24. | 2017-03-01 10:23:22 HTTPS connection to ameritrade02.streamer.com:443 (66) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:23:22 TD Ameritrade | Streamer request #25 initiated. | 2017-03-01 10:23:24 HTTPS connection to ameritrade02.streamer.com:443 (68) | Creating socket. Using TLS 1.0. | 2017-03-01 10:23:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:23:24 HTTPS connection to ameritrade02.streamer.com:443 (66) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 10:23:24 * HTTPS connection to ameritrade02.streamer.com:443 (66) | Received socket Close event | 2017-03-01 10:23:24 HTTPS connection to ameritrade02.streamer.com:443 (66) | Closed. | 2017-03-01 10:23:24 HTTPS connection to ameritrade02.streamer.com:443 (68) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 10:25:25 HTTPS connection to ameritrade02.streamer.com:443 (68) | Initiating close of socket by core. | 2017-03-01 10:25:25 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 25. | 2017-03-01 10:25:25 HTTPS connection to ameritrade02.streamer.com:443 (68) | Received socket Close event | 2017-03-01 10:25:25 HTTPS connection to ameritrade02.streamer.com:443 (68) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:25:25 TD Ameritrade | Streamer request #26 initiated. | 2017-03-01 10:25:27 HTTPS connection to ameritrade02.streamer.com:443 (70) | Creating socket. Using TLS 1.0. | 2017-03-01 10:25:28 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:25:28 HTTPS connection to ameritrade02.streamer.com:443 (68) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 10:26:40 HTTPS connection to ameritrade02.streamer.com:443 (68) | Closed. | 2017-03-01 10:26:40 HTTPS connection to ameritrade02.streamer.com:443 (70) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 10:27:21 HTTPS connection to ameritrade02.streamer.com:443 (70) | Initiating close of socket by core. | 2017-03-01 10:27:21 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 26. | 2017-03-01 10:27:21 HTTPS connection to ameritrade02.streamer.com:443 (70) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:27:21 TD Ameritrade | Streamer request #27 initiated. | 2017-03-01 10:27:23 HTTPS connection to ameritrade02.streamer.com:443 (72) | Creating socket. Using TLS 1.0. | 2017-03-01 10:27:23 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:27:24 HTTPS connection to ameritrade02.streamer.com:443 (70) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 10:27:24 * HTTPS connection to ameritrade02.streamer.com:443 (70) | Received socket Close event | 2017-03-01 10:27:24 HTTPS connection to ameritrade02.streamer.com:443 (70) | Closed. | 2017-03-01 10:27:24 HTTPS connection to ameritrade02.streamer.com:443 (72) | Initiating close of socket by core. | 2017-03-01 10:30:24 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 27. | 2017-03-01 10:30:24 HTTPS connection to ameritrade02.streamer.com:443 (72) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:30:24 TD Ameritrade | Streamer request #28 initiated. | 2017-03-01 10:30:26 HTTPS connection to ameritrade02.streamer.com:443 (74) | Creating socket. Using TLS 1.0. | 2017-03-01 10:30:26 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 10:30:26 HTTPS connection to ameritrade02.streamer.com:443 (72) | Socket gracefully closed by remote side. | 2017-03-01 10:30:40 HTTPS connection to ameritrade02.streamer.com:443 (72) | Closed. | 2017-03-01 10:30:40 HTTPS connection to ameritrade02.streamer.com:443 (74) | Received socket Close event | 2017-03-01 10:30:45 HTTPS connection to ameritrade02.streamer.com:443 (74) | Socket gracefully closed by remote side. | 2017-03-01 10:30:45 HTTPS connection to ameritrade02.streamer.com:443 (74) | Initiating close of socket by core. | 2017-03-01 10:30:45 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 28. | 2017-03-01 10:30:45 HTTPS connection to ameritrade02.streamer.com:443 (74) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-03-01 10:30:45 HTTPS connection to ameritrade02.streamer.com:443 (74) | Closed. | 2017-03-01 10:30:45 TD Ameritrade | Streamer request #29 initiated. | 2017-03-01 10:30:47 HTTPS connection to ameritrade02.streamer.com:443 (75) | Creating socket. Using TLS 1.0. | 2017-03-01 10:30:47 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 10:30:47 HTTPS connection to ameritrade02.streamer.com:443 (75) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 10:31:22 HTTPS connection to ameritrade02.streamer.com:443 (75) | Initiating close of socket by core. | 2017-03-01 10:31:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 29. | 2017-03-01 10:31:22 HTTPS connection to ameritrade02.streamer.com:443 (75) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:31:22 TD Ameritrade | Streamer request #30 initiated. | 2017-03-01 10:31:24 HTTPS connection to ameritrade02.streamer.com:443 (77) | Creating socket. Using TLS 1.0. | 2017-03-01 10:31:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 10:31:24 HTTPS connection to ameritrade02.streamer.com:443 (75) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 10:31:24 * HTTPS connection to ameritrade02.streamer.com:443 (75) | Received socket Close event | 2017-03-01 10:31:24 HTTPS connection to ameritrade02.streamer.com:443 (75) | Closed. | 2017-03-01 10:31:24 HTTPS connection to apis.tdameritrade.com:443 (65) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 10:34:01 HTTPS connection to apis.tdameritrade.com:443 (65) | Initiating close of socket by core. | 2017-03-01 10:34:01 HTTPS connection to apis.tdameritrade.com:443 (65) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:34:01 HTTPS connection to apis.tdameritrade.com:443 (65) | Received socket Close event | 2017-03-01 10:34:01 HTTPS connection to apis.tdameritrade.com:443 (65) | Closed. | 2017-03-01 10:34:01 HTTPS connection to apis.tdameritrade.com:443 (79) | Creating socket. Using TLS 1.0. | 2017-03-01 10:34:01 HTTPS connection to ameritrade02.streamer.com:443 (77) | Initiating close of socket by core. | 2017-03-01 10:34:24 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 30. | 2017-03-01 10:34:24 HTTPS connection to ameritrade02.streamer.com:443 (77) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:34:24 TD Ameritrade | Streamer request #31 initiated. | 2017-03-01 10:34:26 HTTPS connection to ameritrade02.streamer.com:443 (80) | Creating socket. Using TLS 1.0. | 2017-03-01 10:34:26 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 10:34:26 HTTPS connection to ameritrade02.streamer.com:443 (77) | Socket gracefully closed by remote side. | 2017-03-01 10:34:41 HTTPS connection to ameritrade02.streamer.com:443 (77) | Closed. | 2017-03-01 10:34:41 HTTPS connection to ameritrade02.streamer.com:443 (80) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 10:35:22 HTTPS connection to ameritrade02.streamer.com:443 (80) | Initiating close of socket by core. | 2017-03-01 10:35:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 31. | 2017-03-01 10:35:22 HTTPS connection to ameritrade02.streamer.com:443 (80) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:35:22 TD Ameritrade | Streamer request #32 initiated. | 2017-03-01 10:35:24 HTTPS connection to ameritrade02.streamer.com:443 (82) | Creating socket. Using TLS 1.0. | 2017-03-01 10:35:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 10:35:24 HTTPS connection to ameritrade02.streamer.com:443 (80) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 10:35:24 * HTTPS connection to ameritrade02.streamer.com:443 (80) | Received socket Close event | 2017-03-01 10:35:24 HTTPS connection to ameritrade02.streamer.com:443 (80) | Closed. | 2017-03-01 10:35:24 HTTPS connection to ameritrade02.streamer.com:443 (82) | Initiating close of socket by core. | 2017-03-01 10:38:24 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 32. | 2017-03-01 10:38:24 HTTPS connection to ameritrade02.streamer.com:443 (82) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:38:24 TD Ameritrade | Streamer request #33 initiated. | 2017-03-01 10:38:26 HTTPS connection to ameritrade02.streamer.com:443 (84) | Creating socket. Using TLS 1.0. | 2017-03-01 10:38:26 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 10:38:27 TD Ameritrade | OnAsyncHTTP2RequestFinished did not process RequestID 178. | 2017-03-01 10:38:34 TD Ameritrade | OnAsyncHTTP2RequestFinished did not process RequestID 179. | 2017-03-01 10:38:40 TD Ameritrade | OnAsyncHTTP2RequestFinished did not process RequestID 180. | 2017-03-01 10:38:40 TD Ameritrade | OnAsyncHTTP2RequestFinished did not process RequestID 181. | 2017-03-01 10:38:40 TD Ameritrade | OnAsyncHTTP2RequestFinished did not process RequestID 182. | 2017-03-01 10:38:41 HTTPS connection to ameritrade02.streamer.com:443 (82) | Socket gracefully closed by remote side. | 2017-03-01 10:38:41 HTTPS connection to ameritrade02.streamer.com:443 (82) | Closed. | 2017-03-01 10:38:41 HTTPS connection to ameritrade02.streamer.com:443 (84) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 10:39:22 HTTPS connection to ameritrade02.streamer.com:443 (84) | Initiating close of socket by core. | 2017-03-01 10:39:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 33. | 2017-03-01 10:39:22 HTTPS connection to ameritrade02.streamer.com:443 (84) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:39:22 TD Ameritrade | Streamer request #34 initiated. | 2017-03-01 10:39:24 HTTPS connection to ameritrade02.streamer.com:443 (86) | Creating socket. Using TLS 1.0. | 2017-03-01 10:39:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 10:39:24 HTTPS connection to ameritrade02.streamer.com:443 (84) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 10:39:24 * HTTPS connection to ameritrade02.streamer.com:443 (84) | Received socket Close event | 2017-03-01 10:39:24 HTTPS connection to ameritrade02.streamer.com:443 (84) | Closed. | 2017-03-01 10:39:24 HTTPS connection to ameritrade02.streamer.com:443 (86) | Initiating close of socket by core. | 2017-03-01 10:42:26 HTTPS connection to ameritrade02.streamer.com:443 (86) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:42:26 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 34. | 2017-03-01 10:42:26 TD Ameritrade | Streamer request #35 initiated. | 2017-03-01 10:42:28 HTTPS connection to ameritrade02.streamer.com:443 (88) | Creating socket. Using TLS 1.0. | 2017-03-01 10:42:28 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:42:28 HTTPS connection to ameritrade02.streamer.com:443 (86) | Socket gracefully closed by remote side. | 2017-03-01 10:42:41 HTTPS connection to ameritrade02.streamer.com:443 (86) | Closed. | 2017-03-01 10:42:41 HTTPS connection to ameritrade02.streamer.com:443 (88) | Initiating close of socket by core. | 2017-03-01 10:45:28 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 35. | 2017-03-01 10:45:28 HTTPS connection to ameritrade02.streamer.com:443 (88) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:45:28 TD Ameritrade | Streamer request #36 initiated. | 2017-03-01 10:45:30 HTTPS connection to ameritrade02.streamer.com:443 (91) | Creating socket. Using TLS 1.0. | 2017-03-01 10:45:30 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:45:31 HTTPS connection to ameritrade02.streamer.com:443 (88) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 10:46:40 HTTPS connection to ameritrade02.streamer.com:443 (88) | Closed. | 2017-03-01 10:46:40 HTTPS connection to ameritrade02.streamer.com:443 (91) | Initiating close of socket by core. | 2017-03-01 10:48:31 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 36. | 2017-03-01 10:48:31 HTTPS connection to ameritrade02.streamer.com:443 (91) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:48:31 TD Ameritrade | Streamer request #37 initiated. | 2017-03-01 10:48:33 HTTPS connection to ameritrade02.streamer.com:443 (93) | Creating socket. Using TLS 1.0. | 2017-03-01 10:48:33 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:48:33 HTTPS connection to ameritrade02.streamer.com:443 (91) | Socket gracefully closed by remote side. | 2017-03-01 10:48:41 HTTPS connection to ameritrade02.streamer.com:443 (91) | Closed. | 2017-03-01 10:48:41 HTTPS connection to ameritrade02.streamer.com:443 (93) | Initiating close of socket by core. | 2017-03-01 10:51:33 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 37. | 2017-03-01 10:51:33 HTTPS connection to ameritrade02.streamer.com:443 (93) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:51:33 TD Ameritrade | Streamer request #38 initiated. | 2017-03-01 10:51:35 HTTPS connection to ameritrade02.streamer.com:443 (96) | Creating socket. Using TLS 1.0. | 2017-03-01 10:51:35 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:51:35 HTTPS connection to ameritrade02.streamer.com:443 (93) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 10:52:40 HTTPS connection to ameritrade02.streamer.com:443 (93) | Closed. | 2017-03-01 10:52:40 HTTPS connection to ameritrade02.streamer.com:443 (96) | Initiating close of socket by core. | 2017-03-01 10:54:35 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 38. | 2017-03-01 10:54:35 HTTPS connection to ameritrade02.streamer.com:443 (96) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:54:35 TD Ameritrade | Streamer request #39 initiated. | 2017-03-01 10:54:38 HTTPS connection to ameritrade02.streamer.com:443 (98) | Creating socket. Using TLS 1.0. | 2017-03-01 10:54:38 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 10:54:38 HTTPS connection to ameritrade02.streamer.com:443 (96) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 10:55:40 HTTPS connection to ameritrade02.streamer.com:443 (96) | Closed. | 2017-03-01 10:55:40 HTTPS connection to ameritrade02.streamer.com:443 (98) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 10:56:00 HTTPS connection to ameritrade02.streamer.com:443 (98) | Received socket Close event | 2017-03-01 10:56:00 HTTPS connection to ameritrade02.streamer.com:443 (98) | Initiating close of socket by core. | 2017-03-01 10:56:00 HTTPS connection to ameritrade02.streamer.com:443 (98) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:56:00 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 39. | 2017-03-01 10:56:00 TD Ameritrade | Streamer request #40 initiated. | 2017-03-01 10:56:02 HTTPS connection to ameritrade02.streamer.com:443 (100) | Creating socket. Using TLS 1.0. | 2017-03-01 10:56:02 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 10:56:02 HTTPS connection to ameritrade02.streamer.com:443 (98) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 10:57:40 HTTPS connection to ameritrade02.streamer.com:443 (98) | Closed. | 2017-03-01 10:57:40 HTTPS connection to ameritrade02.streamer.com:443 (100) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 10:59:25 HTTPS connection to ameritrade02.streamer.com:443 (100) | Initiating close of socket by core. | 2017-03-01 10:59:25 HTTPS connection to ameritrade02.streamer.com:443 (100) | Shutdown started. Waiting for graceful close. | 2017-03-01 10:59:25 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 40. | 2017-03-01 10:59:25 TD Ameritrade | Streamer request #41 initiated. | 2017-03-01 10:59:27 HTTPS connection to ameritrade02.streamer.com:443 (103) | Creating socket. Using TLS 1.0. | 2017-03-01 10:59:27 HTTPS connection to ameritrade02.streamer.com:443 (100) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 10:59:28 * HTTPS connection to ameritrade02.streamer.com:443 (100) | Received socket Close event | 2017-03-01 10:59:28 HTTPS connection to ameritrade02.streamer.com:443 (100) | Closed. | 2017-03-01 10:59:28 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 10:59:28 HTTPS connection to ameritrade02.streamer.com:443 (103) | Initiating close of socket by core. | 2017-03-01 11:02:28 HTTPS connection to ameritrade02.streamer.com:443 (103) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:02:28 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 41. | 2017-03-01 11:02:28 TD Ameritrade | Streamer request #42 initiated. | 2017-03-01 11:02:30 HTTPS connection to ameritrade02.streamer.com:443 (105) | Creating socket. Using TLS 1.0. | 2017-03-01 11:02:30 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 11:02:30 HTTPS connection to ameritrade02.streamer.com:443 (103) | Socket gracefully closed by remote side. | 2017-03-01 11:02:42 HTTPS connection to ameritrade02.streamer.com:443 (103) | Closed. | 2017-03-01 11:02:42 HTTPS connection to apis.tdameritrade.com:443 (79) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 11:04:01 HTTPS connection to apis.tdameritrade.com:443 (79) | Initiating close of socket by core. | 2017-03-01 11:04:01 HTTPS connection to apis.tdameritrade.com:443 (79) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:04:01 HTTPS connection to apis.tdameritrade.com:443 (79) | Received socket Close event | 2017-03-01 11:04:01 HTTPS connection to apis.tdameritrade.com:443 (79) | Closed. | 2017-03-01 11:04:01 HTTPS connection to apis.tdameritrade.com:443 (107) | Creating socket. Using TLS 1.0. | 2017-03-01 11:04:01 HTTPS connection to ameritrade02.streamer.com:443 (105) | Initiating close of socket by core. | 2017-03-01 11:05:30 HTTPS connection to ameritrade02.streamer.com:443 (105) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:05:30 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 42. | 2017-03-01 11:05:30 TD Ameritrade | Streamer request #43 initiated. | 2017-03-01 11:05:32 HTTPS connection to ameritrade02.streamer.com:443 (109) | Creating socket. Using TLS 1.0. | 2017-03-01 11:05:32 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 11:05:33 HTTPS connection to ameritrade02.streamer.com:443 (105) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 11:06:39 HTTPS connection to ameritrade02.streamer.com:443 (105) | Closed. | 2017-03-01 11:06:39 HTTPS connection to ameritrade02.streamer.com:443 (109) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 11:07:29 HTTPS connection to ameritrade02.streamer.com:443 (109) | Initiating close of socket by core. | 2017-03-01 11:07:29 HTTPS connection to ameritrade02.streamer.com:443 (109) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:07:29 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 43. | 2017-03-01 11:07:29 TD Ameritrade | Streamer request #44 initiated. | 2017-03-01 11:07:32 HTTPS connection to ameritrade02.streamer.com:443 (112) | Creating socket. Using TLS 1.0. | 2017-03-01 11:07:36 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 11:07:36 HTTPS connection to ameritrade02.streamer.com:443 (109) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 11:07:36 * HTTPS connection to ameritrade02.streamer.com:443 (109) | Received socket Close event | 2017-03-01 11:07:36 HTTPS connection to ameritrade02.streamer.com:443 (109) | Closed. | 2017-03-01 11:07:36 HTTPS connection to apis.tdameritrade.com:443 (107) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 11:10:01 HTTPS connection to apis.tdameritrade.com:443 (107) | Initiating close of socket by core. | 2017-03-01 11:10:01 HTTPS connection to apis.tdameritrade.com:443 (107) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:10:01 HTTPS connection to apis.tdameritrade.com:443 (114) | Creating socket. Using TLS 1.0. | 2017-03-01 11:10:01 HTTPS connection to apis.tdameritrade.com:443 (107) | Received socket Close event | 2017-03-01 11:10:01 HTTPS connection to apis.tdameritrade.com:443 (107) | Closed. | 2017-03-01 11:10:01 HTTPS connection to ameritrade02.streamer.com:443 (112) | Socket gracefully closed by remote side. | 2017-03-01 11:10:29 HTTPS connection to ameritrade02.streamer.com:443 (112) | Received socket Close event | 2017-03-01 11:10:29 HTTPS connection to ameritrade02.streamer.com:443 (112) | Initiating close of socket by core. | 2017-03-01 11:10:29 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 44. | 2017-03-01 11:10:29 HTTPS connection to ameritrade02.streamer.com:443 (112) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-03-01 11:10:29 HTTPS connection to ameritrade02.streamer.com:443 (112) | Closed. | 2017-03-01 11:10:29 TD Ameritrade | Streamer request #45 initiated. | 2017-03-01 11:10:31 HTTPS connection to ameritrade02.streamer.com:443 (115) | Creating socket. Using TLS 1.0. | 2017-03-01 11:10:31 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 11:10:31 HTTPS connection to ameritrade02.streamer.com:443 (115) | Socket gracefully closed by remote side. | 2017-03-01 11:10:57 HTTPS connection to ameritrade02.streamer.com:443 (115) | Received socket Close event | 2017-03-01 11:10:57 HTTPS connection to ameritrade02.streamer.com:443 (115) | Initiating close of socket by core. | 2017-03-01 11:10:57 HTTPS connection to ameritrade02.streamer.com:443 (115) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-03-01 11:10:57 HTTPS connection to ameritrade02.streamer.com:443 (115) | Closed. | 2017-03-01 11:10:57 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 45. | 2017-03-01 11:10:57 TD Ameritrade | Streamer request #46 initiated. | 2017-03-01 11:10:59 HTTPS connection to ameritrade02.streamer.com:443 (116) | Creating socket. Using TLS 1.0. | 2017-03-01 11:10:59 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 11:11:00 HTTPS connection to ameritrade02.streamer.com:443 (116) | Initiating close of socket by core. | 2017-03-01 11:14:00 HTTPS connection to ameritrade02.streamer.com:443 (116) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:14:00 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 46. | 2017-03-01 11:14:00 TD Ameritrade | Streamer request #47 initiated. | 2017-03-01 11:14:02 HTTPS connection to ameritrade02.streamer.com:443 (119) | Creating socket. Using TLS 1.0. | 2017-03-01 11:14:02 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 11:14:02 HTTPS connection to ameritrade02.streamer.com:443 (116) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 11:15:40 HTTPS connection to ameritrade02.streamer.com:443 (116) | Closed. | 2017-03-01 11:15:40 HTTPS connection to apis.tdameritrade.com:443 (114) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 11:16:01 HTTPS connection to apis.tdameritrade.com:443 (114) | Initiating close of socket by core. | 2017-03-01 11:16:01 HTTPS connection to apis.tdameritrade.com:443 (114) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:16:01 HTTPS connection to apis.tdameritrade.com:443 (114) | Received socket Close event | 2017-03-01 11:16:01 HTTPS connection to apis.tdameritrade.com:443 (114) | Closed. | 2017-03-01 11:16:01 HTTPS connection to apis.tdameritrade.com:443 (121) | Creating socket. Using TLS 1.0. | 2017-03-01 11:16:01 HTTPS connection to ameritrade02.streamer.com:443 (119) | Initiating close of socket by core. | 2017-03-01 11:17:02 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 47. | 2017-03-01 11:17:02 HTTPS connection to ameritrade02.streamer.com:443 (119) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:17:02 TD Ameritrade | Streamer request #48 initiated. | 2017-03-01 11:17:04 HTTPS connection to ameritrade02.streamer.com:443 (123) | Creating socket. Using TLS 1.0. | 2017-03-01 11:17:04 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 11:17:05 HTTPS connection to ameritrade02.streamer.com:443 (119) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 11:18:40 HTTPS connection to ameritrade02.streamer.com:443 (119) | Closed. | 2017-03-01 11:18:40 HTTPS connection to ameritrade02.streamer.com:443 (123) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 11:19:22 HTTPS connection to ameritrade02.streamer.com:443 (123) | Initiating close of socket by core. | 2017-03-01 11:19:22 HTTPS connection to ameritrade02.streamer.com:443 (123) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:19:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 48. | 2017-03-01 11:19:22 TD Ameritrade | Streamer request #49 initiated. | 2017-03-01 11:19:24 HTTPS connection to ameritrade02.streamer.com:443 (125) | Creating socket. Using TLS 1.0. | 2017-03-01 11:19:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 11:19:24 HTTPS connection to ameritrade02.streamer.com:443 (123) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 11:19:24 * HTTPS connection to ameritrade02.streamer.com:443 (123) | Received socket Close event | 2017-03-01 11:19:24 HTTPS connection to ameritrade02.streamer.com:443 (123) | Closed. | 2017-03-01 11:19:24 HTTPS connection to apis.tdameritrade.com:443 (121) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 11:22:01 HTTPS connection to apis.tdameritrade.com:443 (121) | Initiating close of socket by core. | 2017-03-01 11:22:01 HTTPS connection to apis.tdameritrade.com:443 (121) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:22:01 HTTPS connection to apis.tdameritrade.com:443 (127) | Creating socket. Using TLS 1.0. | 2017-03-01 11:22:01 HTTPS connection to apis.tdameritrade.com:443 (121) | Received socket Close event | 2017-03-01 11:22:01 HTTPS connection to apis.tdameritrade.com:443 (121) | Closed. | 2017-03-01 11:22:01 HTTPS connection to ameritrade02.streamer.com:443 (125) | Initiating close of socket by core. | 2017-03-01 11:22:24 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 49. | 2017-03-01 11:22:24 HTTPS connection to ameritrade02.streamer.com:443 (125) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:22:24 TD Ameritrade | Streamer request #50 initiated. | 2017-03-01 11:22:26 HTTPS connection to ameritrade02.streamer.com:443 (128) | Creating socket. Using TLS 1.0. | 2017-03-01 11:22:26 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 11:22:27 HTTPS connection to ameritrade02.streamer.com:443 (125) | Socket gracefully closed by remote side. | 2017-03-01 11:22:43 HTTPS connection to ameritrade02.streamer.com:443 (125) | Closed. | 2017-03-01 11:22:43 HTTPS connection to ameritrade02.streamer.com:443 (128) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 11:23:22 HTTPS connection to ameritrade02.streamer.com:443 (128) | Initiating close of socket by core. | 2017-03-01 11:23:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 50. | 2017-03-01 11:23:22 HTTPS connection to ameritrade02.streamer.com:443 (128) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:23:22 TD Ameritrade | Streamer request #51 initiated. | 2017-03-01 11:23:24 HTTPS connection to ameritrade02.streamer.com:443 (130) | Creating socket. Using TLS 1.0. | 2017-03-01 11:23:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 11:23:24 HTTPS connection to ameritrade02.streamer.com:443 (128) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 11:23:24 * HTTPS connection to ameritrade02.streamer.com:443 (128) | Received socket Close event | 2017-03-01 11:23:24 HTTPS connection to ameritrade02.streamer.com:443 (128) | Closed. | 2017-03-01 11:23:24 HTTPS connection to ameritrade02.streamer.com:443 (130) | Received socket Close event | 2017-03-01 11:23:26 HTTPS connection to ameritrade02.streamer.com:443 (130) | Socket gracefully closed by remote side. | 2017-03-01 11:23:26 HTTPS connection to ameritrade02.streamer.com:443 (130) | Initiating close of socket by core. | 2017-03-01 11:23:26 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 51. | 2017-03-01 11:23:26 HTTPS connection to ameritrade02.streamer.com:443 (130) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-03-01 11:23:26 HTTPS connection to ameritrade02.streamer.com:443 (130) | Closed. | 2017-03-01 11:23:26 TD Ameritrade | Streamer request #52 initiated. | 2017-03-01 11:23:28 HTTPS connection to ameritrade02.streamer.com:443 (131) | Creating socket. Using TLS 1.0. | 2017-03-01 11:23:28 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 11:23:28 HTTPS connection to ameritrade02.streamer.com:443 (131) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 11:25:22 HTTPS connection to ameritrade02.streamer.com:443 (131) | Initiating close of socket by core. | 2017-03-01 11:25:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 52. | 2017-03-01 11:25:22 HTTPS connection to ameritrade02.streamer.com:443 (131) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:25:22 TD Ameritrade | Streamer request #53 initiated. | 2017-03-01 11:25:24 HTTPS connection to ameritrade02.streamer.com:443 (133) | Creating socket. Using TLS 1.0. | 2017-03-01 11:25:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 11:25:25 HTTPS connection to ameritrade02.streamer.com:443 (131) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 11:25:25 * HTTPS connection to ameritrade02.streamer.com:443 (131) | Received socket Close event | 2017-03-01 11:25:25 HTTPS connection to ameritrade02.streamer.com:443 (131) | Closed. | 2017-03-01 11:25:25 HTTPS connection to apis.tdameritrade.com:443 (127) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 11:28:01 HTTPS connection to apis.tdameritrade.com:443 (127) | Initiating close of socket by core. | 2017-03-01 11:28:01 HTTPS connection to apis.tdameritrade.com:443 (127) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:28:01 HTTPS connection to apis.tdameritrade.com:443 (135) | Creating socket. Using TLS 1.0. | 2017-03-01 11:28:01 HTTPS connection to apis.tdameritrade.com:443 (127) | Received socket Close event | 2017-03-01 11:28:01 HTTPS connection to apis.tdameritrade.com:443 (127) | Closed. | 2017-03-01 11:28:01 HTTPS connection to ameritrade02.streamer.com:443 (133) | Initiating close of socket by core. | 2017-03-01 11:28:25 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 53. | 2017-03-01 11:28:25 HTTPS connection to ameritrade02.streamer.com:443 (133) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:28:25 TD Ameritrade | Streamer request #54 initiated. | 2017-03-01 11:28:27 HTTPS connection to ameritrade02.streamer.com:443 (136) | Creating socket. Using TLS 1.0. | 2017-03-01 11:28:27 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 11:28:27 HTTPS connection to ameritrade02.streamer.com:443 (133) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 11:29:40 HTTPS connection to ameritrade02.streamer.com:443 (133) | Closed. | 2017-03-01 11:29:40 HTTPS connection to ameritrade02.streamer.com:443 (136) | Initiating close of socket by core. | 2017-03-01 11:31:27 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 54. | 2017-03-01 11:31:27 HTTPS connection to ameritrade02.streamer.com:443 (136) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:31:27 TD Ameritrade | Streamer request #55 initiated. | 2017-03-01 11:31:29 HTTPS connection to ameritrade02.streamer.com:443 (139) | Creating socket. Using TLS 1.0. | 2017-03-01 11:31:30 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 11:31:31 HTTPS connection to ameritrade02.streamer.com:443 (136) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 11:32:39 HTTPS connection to ameritrade02.streamer.com:443 (136) | Closed. | 2017-03-01 11:32:39 HTTPS connection to ameritrade02.streamer.com:443 (139) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 11:33:21 HTTPS connection to ameritrade02.streamer.com:443 (139) | Initiating close of socket by core. | 2017-03-01 11:33:21 HTTPS connection to ameritrade02.streamer.com:443 (139) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:33:21 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 55. | 2017-03-01 11:33:21 TD Ameritrade | Streamer request #56 initiated. | 2017-03-01 11:33:26 HTTPS connection to ameritrade02.streamer.com:443 (141) | Creating socket. Using TLS 1.0. | 2017-03-01 11:33:27 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 11:33:27 HTTPS connection to ameritrade02.streamer.com:443 (139) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 11:33:27 * HTTPS connection to ameritrade02.streamer.com:443 (139) | Received socket Close event | 2017-03-01 11:33:27 HTTPS connection to ameritrade02.streamer.com:443 (139) | Closed. | 2017-03-01 11:33:27 HTTPS connection to ameritrade02.streamer.com:443 (141) | Initiating close of socket by core. | 2017-03-01 11:36:27 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 56. | 2017-03-01 11:36:27 HTTPS connection to ameritrade02.streamer.com:443 (141) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:36:27 TD Ameritrade | Streamer request #57 initiated. | 2017-03-01 11:36:29 HTTPS connection to ameritrade02.streamer.com:443 (143) | Creating socket. Using TLS 1.0. | 2017-03-01 11:36:30 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 11:36:30 HTTPS connection to ameritrade02.streamer.com:443 (141) | Socket gracefully closed by remote side. | 2017-03-01 11:36:43 HTTPS connection to ameritrade02.streamer.com:443 (141) | Closed. | 2017-03-01 11:36:43 HTTPS connection to ameritrade02.streamer.com:443 (143) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 11:39:22 HTTPS connection to ameritrade02.streamer.com:443 (143) | Initiating close of socket by core. | 2017-03-01 11:39:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 57. | 2017-03-01 11:39:22 HTTPS connection to ameritrade02.streamer.com:443 (143) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:39:22 TD Ameritrade | Streamer request #58 initiated. | 2017-03-01 11:39:24 HTTPS connection to ameritrade02.streamer.com:443 (146) | Creating socket. Using TLS 1.0. | 2017-03-01 11:39:25 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 11:39:25 HTTPS connection to ameritrade02.streamer.com:443 (143) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 11:39:25 * HTTPS connection to ameritrade02.streamer.com:443 (143) | Received socket Close event | 2017-03-01 11:39:25 HTTPS connection to ameritrade02.streamer.com:443 (143) | Closed. | 2017-03-01 11:39:25 HTTPS connection to ameritrade02.streamer.com:443 (146) | Initiating close of socket by core. | 2017-03-01 11:42:25 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 58. | 2017-03-01 11:42:25 HTTPS connection to ameritrade02.streamer.com:443 (146) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:42:25 TD Ameritrade | Streamer request #59 initiated. | 2017-03-01 11:42:27 HTTPS connection to ameritrade02.streamer.com:443 (148) | Creating socket. Using TLS 1.0. | 2017-03-01 11:42:28 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 11:42:29 HTTPS connection to ameritrade02.streamer.com:443 (146) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 11:43:40 HTTPS connection to ameritrade02.streamer.com:443 (146) | Closed. | 2017-03-01 11:43:40 HTTPS connection to ameritrade02.streamer.com:443 (148) | Initiating close of socket by core. | 2017-03-01 11:45:29 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 59. | 2017-03-01 11:45:29 HTTPS connection to ameritrade02.streamer.com:443 (148) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:45:29 TD Ameritrade | Streamer request #60 initiated. | 2017-03-01 11:45:31 HTTPS connection to ameritrade02.streamer.com:443 (151) | Creating socket. Using TLS 1.0. | 2017-03-01 11:45:31 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 11:45:32 HTTPS connection to ameritrade02.streamer.com:443 (148) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 11:46:39 HTTPS connection to ameritrade02.streamer.com:443 (148) | Closed. | 2017-03-01 11:46:39 HTTPS connection to ameritrade02.streamer.com:443 (151) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 11:47:21 HTTPS connection to ameritrade02.streamer.com:443 (151) | Initiating close of socket by core. | 2017-03-01 11:47:21 HTTPS connection to ameritrade02.streamer.com:443 (151) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:47:21 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 60. | 2017-03-01 11:47:21 TD Ameritrade | Streamer request #61 initiated. | 2017-03-01 11:47:24 HTTPS connection to ameritrade02.streamer.com:443 (153) | Creating socket. Using TLS 1.0. | 2017-03-01 11:47:24 HTTPS connection to ameritrade02.streamer.com:443 (151) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 11:47:24 * HTTPS connection to ameritrade02.streamer.com:443 (151) | Received socket Close event | 2017-03-01 11:47:24 HTTPS connection to ameritrade02.streamer.com:443 (151) | Closed. | 2017-03-01 11:47:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 11:47:24 HTTPS connection to ameritrade02.streamer.com:443 (153) | Initiating close of socket by core. | 2017-03-01 11:50:25 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 61. | 2017-03-01 11:50:25 HTTPS connection to ameritrade02.streamer.com:443 (153) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:50:25 TD Ameritrade | Streamer request #62 initiated. | 2017-03-01 11:50:27 HTTPS connection to ameritrade02.streamer.com:443 (155) | Creating socket. Using TLS 1.0. | 2017-03-01 11:50:27 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 11:50:27 HTTPS connection to ameritrade02.streamer.com:443 (153) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 11:50:44 * HTTPS connection to ameritrade02.streamer.com:443 (153) | Socket gracefully closed by remote side. | 2017-03-01 11:50:44 HTTPS connection to ameritrade02.streamer.com:443 (153) | Closed. | 2017-03-01 11:50:44 HTTPS connection to ameritrade02.streamer.com:443 (155) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 11:51:22 HTTPS connection to ameritrade02.streamer.com:443 (155) | Initiating close of socket by core. | 2017-03-01 11:51:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 62. | 2017-03-01 11:51:22 HTTPS connection to ameritrade02.streamer.com:443 (155) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:51:22 TD Ameritrade | Streamer request #63 initiated. | 2017-03-01 11:51:24 HTTPS connection to ameritrade02.streamer.com:443 (157) | Creating socket. Using TLS 1.0. | 2017-03-01 11:51:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 11:51:25 HTTPS connection to ameritrade02.streamer.com:443 (155) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 11:51:25 * HTTPS connection to ameritrade02.streamer.com:443 (155) | Received socket Close event | 2017-03-01 11:51:25 HTTPS connection to ameritrade02.streamer.com:443 (155) | Closed. | 2017-03-01 11:51:25 HTTPS connection to ameritrade02.streamer.com:443 (157) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 11:53:59 HTTPS connection to ameritrade02.streamer.com:443 (157) | Initiating close of socket by core. | 2017-03-01 11:53:59 HTTPS connection to ameritrade02.streamer.com:443 (157) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:53:59 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 63. | 2017-03-01 11:53:59 HTTPS connection to ameritrade02.streamer.com:443 (157) | Received socket Close event | 2017-03-01 11:53:59 HTTPS connection to ameritrade02.streamer.com:443 (157) | Closed. | 2017-03-01 11:53:59 TD Ameritrade | Streamer request #64 initiated. | 2017-03-01 11:54:01 HTTPS connection to ameritrade02.streamer.com:443 (159) | Creating socket. Using TLS 1.0. | 2017-03-01 11:54:01 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 11:54:01 HTTPS connection to ameritrade02.streamer.com:443 (159) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 11:55:22 HTTPS connection to ameritrade02.streamer.com:443 (159) | Initiating close of socket by core. | 2017-03-01 11:55:22 HTTPS connection to ameritrade02.streamer.com:443 (159) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:55:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 64. | 2017-03-01 11:55:22 TD Ameritrade | Streamer request #65 initiated. | 2017-03-01 11:55:24 HTTPS connection to ameritrade02.streamer.com:443 (161) | Creating socket. Using TLS 1.0. | 2017-03-01 11:55:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 11:55:25 HTTPS connection to ameritrade02.streamer.com:443 (159) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 11:55:25 * HTTPS connection to ameritrade02.streamer.com:443 (159) | Received socket Close event | 2017-03-01 11:55:25 HTTPS connection to ameritrade02.streamer.com:443 (159) | Closed. | 2017-03-01 11:55:25 HTTPS connection to ameritrade02.streamer.com:443 (161) | Initiating close of socket by core. | 2017-03-01 11:58:25 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 65. | 2017-03-01 11:58:25 HTTPS connection to ameritrade02.streamer.com:443 (161) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:58:25 TD Ameritrade | Streamer request #66 initiated. | 2017-03-01 11:58:27 HTTPS connection to ameritrade02.streamer.com:443 (163) | Creating socket. Using TLS 1.0. | 2017-03-01 11:58:27 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 11:58:27 HTTPS connection to ameritrade02.streamer.com:443 (161) | Socket gracefully closed by remote side. | 2017-03-01 11:58:44 HTTPS connection to ameritrade02.streamer.com:443 (161) | Closed. | 2017-03-01 11:58:44 HTTPS connection to ameritrade02.streamer.com:443 (163) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 11:59:22 HTTPS connection to ameritrade02.streamer.com:443 (163) | Initiating close of socket by core. | 2017-03-01 11:59:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 66. | 2017-03-01 11:59:22 HTTPS connection to ameritrade02.streamer.com:443 (163) | Shutdown started. Waiting for graceful close. | 2017-03-01 11:59:22 TD Ameritrade | Streamer request #67 initiated. | 2017-03-01 11:59:24 HTTPS connection to ameritrade02.streamer.com:443 (165) | Creating socket. Using TLS 1.0. | 2017-03-01 11:59:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 11:59:24 HTTPS connection to ameritrade02.streamer.com:443 (163) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 11:59:24 * HTTPS connection to ameritrade02.streamer.com:443 (163) | Received socket Close event | 2017-03-01 11:59:24 HTTPS connection to ameritrade02.streamer.com:443 (163) | Closed. | 2017-03-01 11:59:24 HTTPS connection to ameritrade02.streamer.com:443 (165) | Received socket Close event | 2017-03-01 12:01:13 HTTPS connection to ameritrade02.streamer.com:443 (165) | Socket gracefully closed by remote side. | 2017-03-01 12:01:13 HTTPS connection to ameritrade02.streamer.com:443 (165) | Initiating close of socket by core. | 2017-03-01 12:01:13 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 67. | 2017-03-01 12:01:13 HTTPS connection to ameritrade02.streamer.com:443 (165) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-03-01 12:01:13 HTTPS connection to ameritrade02.streamer.com:443 (165) | Closed. | 2017-03-01 12:01:13 TD Ameritrade | Streamer request #68 initiated. | 2017-03-01 12:01:15 HTTPS connection to ameritrade02.streamer.com:443 (167) | Creating socket. Using TLS 1.0. | 2017-03-01 12:01:15 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 12:01:15 HTTPS connection to ameritrade02.streamer.com:443 (167) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 12:03:34 HTTPS connection to ameritrade02.streamer.com:443 (167) | Initiating close of socket by core. | 2017-03-01 12:03:34 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 68. | 2017-03-01 12:03:34 HTTPS connection to ameritrade02.streamer.com:443 (167) | Received socket Close event | 2017-03-01 12:03:34 HTTPS connection to ameritrade02.streamer.com:443 (167) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:03:34 TD Ameritrade | Streamer request #69 initiated. | 2017-03-01 12:03:36 HTTPS connection to ameritrade02.streamer.com:443 (169) | Creating socket. Using TLS 1.0. | 2017-03-01 12:03:36 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 12:03:36 HTTPS connection to ameritrade02.streamer.com:443 (167) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 12:04:40 HTTPS connection to ameritrade02.streamer.com:443 (167) | Closed. | 2017-03-01 12:04:40 HTTPS connection to ameritrade02.streamer.com:443 (169) | Initiating close of socket by core. | 2017-03-01 12:06:36 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 69. | 2017-03-01 12:06:36 HTTPS connection to ameritrade02.streamer.com:443 (169) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:06:37 TD Ameritrade | Streamer request #70 initiated. | 2017-03-01 12:06:38 HTTPS connection to ameritrade02.streamer.com:443 (171) | Creating socket. Using TLS 1.0. | 2017-03-01 12:06:39 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 12:06:40 HTTPS connection to ameritrade02.streamer.com:443 (169) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 12:07:40 HTTPS connection to ameritrade02.streamer.com:443 (169) | Closed. | 2017-03-01 12:07:40 HTTPS connection to ameritrade02.streamer.com:443 (171) | Initiating close of socket by core. | 2017-03-01 12:09:40 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 70. | 2017-03-01 12:09:40 HTTPS connection to ameritrade02.streamer.com:443 (171) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:09:40 TD Ameritrade | Streamer request #71 initiated. | 2017-03-01 12:09:42 HTTPS connection to ameritrade02.streamer.com:443 (174) | Creating socket. Using TLS 1.0. | 2017-03-01 12:09:42 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 12:09:43 HTTPS connection to ameritrade02.streamer.com:443 (171) | Socket gracefully closed by remote side. | 2017-03-01 12:09:56 HTTPS connection to ameritrade02.streamer.com:443 (171) | Closed. | 2017-03-01 12:09:56 HTTPS connection to ameritrade02.streamer.com:443 (174) | Initiating close of socket by core. | 2017-03-01 12:12:43 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 71. | 2017-03-01 12:12:43 HTTPS connection to ameritrade02.streamer.com:443 (174) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:12:43 TD Ameritrade | Streamer request #72 initiated. | 2017-03-01 12:12:45 HTTPS connection to ameritrade02.streamer.com:443 (176) | Creating socket. Using TLS 1.0. | 2017-03-01 12:12:46 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2017-03-01 12:12:46 HTTPS connection to ameritrade02.streamer.com:443 (174) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 12:14:40 HTTPS connection to ameritrade02.streamer.com:443 (174) | Closed. | 2017-03-01 12:14:40 HTTPS connection to ameritrade02.streamer.com:443 (176) | Initiating close of socket by core. | 2017-03-01 12:15:46 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 72. | 2017-03-01 12:15:46 HTTPS connection to ameritrade02.streamer.com:443 (176) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:15:48 TD Ameritrade | Streamer request #73 initiated. | 2017-03-01 12:15:49 HTTPS connection to ameritrade02.streamer.com:443 (179) | Creating socket. Using TLS 1.0. | 2017-03-01 12:15:49 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 12:15:49 HTTPS connection to ameritrade02.streamer.com:443 (176) | Socket gracefully closed by remote side. | 2017-03-01 12:16:07 HTTPS connection to ameritrade02.streamer.com:443 (176) | Closed. | 2017-03-01 12:16:07 HTTPS connection to ameritrade02.streamer.com:443 (179) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 12:19:23 HTTPS connection to ameritrade02.streamer.com:443 (179) | Initiating close of socket by core. | 2017-03-01 12:19:23 HTTPS connection to ameritrade02.streamer.com:443 (179) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:19:23 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 73. | 2017-03-01 12:19:23 TD Ameritrade | Streamer request #74 initiated. | 2017-03-01 12:19:24 HTTPS connection to ameritrade02.streamer.com:443 (182) | Creating socket. Using TLS 1.0. | 2017-03-01 12:19:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 12:19:25 HTTPS connection to ameritrade02.streamer.com:443 (179) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 12:19:25 * HTTPS connection to ameritrade02.streamer.com:443 (179) | Received socket Close event | 2017-03-01 12:19:25 HTTPS connection to ameritrade02.streamer.com:443 (179) | Closed. | 2017-03-01 12:19:25 HTTPS connection to ameritrade02.streamer.com:443 (182) | Received socket Close event | 2017-03-01 12:20:50 HTTPS connection to ameritrade02.streamer.com:443 (182) | Initiating close of socket by core. | 2017-03-01 12:20:50 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 74. | 2017-03-01 12:20:50 HTTPS connection to ameritrade02.streamer.com:443 (182) | Socket gracefully closed by remote side. | 2017-03-01 12:20:50 HTTPS connection to ameritrade02.streamer.com:443 (182) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-03-01 12:20:50 HTTPS connection to ameritrade02.streamer.com:443 (182) | Closed. | 2017-03-01 12:20:50 TD Ameritrade | Streamer request #75 initiated. | 2017-03-01 12:20:52 HTTPS connection to ameritrade02.streamer.com:443 (183) | Creating socket. Using TLS 1.0. | 2017-03-01 12:20:52 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 12:20:52 HTTPS connection to ameritrade02.streamer.com:443 (183) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 12:21:22 HTTPS connection to ameritrade02.streamer.com:443 (183) | Initiating close of socket by core. | 2017-03-01 12:21:22 HTTPS connection to ameritrade02.streamer.com:443 (183) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:21:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 75. | 2017-03-01 12:21:22 TD Ameritrade | Streamer request #76 initiated. | 2017-03-01 12:21:24 HTTPS connection to ameritrade02.streamer.com:443 (185) | Creating socket. Using TLS 1.0. | 2017-03-01 12:21:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 12:21:24 HTTPS connection to ameritrade02.streamer.com:443 (183) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 12:21:24 * HTTPS connection to ameritrade02.streamer.com:443 (183) | Received socket Close event | 2017-03-01 12:21:24 HTTPS connection to ameritrade02.streamer.com:443 (183) | Closed. | 2017-03-01 12:21:24 HTTPS connection to ameritrade02.streamer.com:443 (185) | Initiating close of socket by core. | 2017-03-01 12:24:24 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 76. | 2017-03-01 12:24:24 HTTPS connection to ameritrade02.streamer.com:443 (185) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:24:24 TD Ameritrade | Streamer request #77 initiated. | 2017-03-01 12:24:26 HTTPS connection to ameritrade02.streamer.com:443 (187) | Creating socket. Using TLS 1.0. | 2017-03-01 12:24:26 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 12:24:27 HTTPS connection to ameritrade02.streamer.com:443 (187) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 12:25:22 HTTPS connection to ameritrade02.streamer.com:443 (187) | Initiating close of socket by core. | 2017-03-01 12:25:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 77. | 2017-03-01 12:25:22 HTTPS connection to ameritrade02.streamer.com:443 (187) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:25:22 TD Ameritrade | Streamer request #78 initiated. | 2017-03-01 12:25:24 HTTPS connection to ameritrade02.streamer.com:443 (189) | Creating socket. Using TLS 1.0. | 2017-03-01 12:25:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 12:25:25 HTTPS connection to ameritrade02.streamer.com:443 (187) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 12:25:25 * HTTPS connection to ameritrade02.streamer.com:443 (187) | Received socket Close event | 2017-03-01 12:25:25 HTTPS connection to ameritrade02.streamer.com:443 (187) | Closed. | 2017-03-01 12:25:25 HTTPS connection to ameritrade02.streamer.com:443 (185) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 12:25:40 HTTPS connection to ameritrade02.streamer.com:443 (185) | Closed. | 2017-03-01 12:25:40 HTTPS connection to ameritrade02.streamer.com:443 (189) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 12:27:30 HTTPS connection to ameritrade02.streamer.com:443 (189) | Initiating close of socket by core. | 2017-03-01 12:27:30 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 78. | 2017-03-01 12:27:30 HTTPS connection to ameritrade02.streamer.com:443 (189) | Received socket Close event | 2017-03-01 12:27:30 HTTPS connection to ameritrade02.streamer.com:443 (189) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:27:30 TD Ameritrade | Streamer request #79 initiated. | 2017-03-01 12:27:32 HTTPS connection to ameritrade02.streamer.com:443 (191) | Creating socket. Using TLS 1.0. | 2017-03-01 12:27:32 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 12:27:32 HTTPS connection to ameritrade02.streamer.com:443 (189) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-03-01 12:28:40 HTTPS connection to ameritrade02.streamer.com:443 (189) | Closed. | 2017-03-01 12:28:40 HTTPS connection to ameritrade02.streamer.com:443 (191) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 12:29:22 HTTPS connection to ameritrade02.streamer.com:443 (191) | Initiating close of socket by core. | 2017-03-01 12:29:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 79. | 2017-03-01 12:29:22 HTTPS connection to ameritrade02.streamer.com:443 (191) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:29:22 TD Ameritrade | Streamer request #80 initiated. | 2017-03-01 12:29:24 HTTPS connection to ameritrade02.streamer.com:443 (193) | Creating socket. Using TLS 1.0. | 2017-03-01 12:29:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 12:29:25 HTTPS connection to ameritrade02.streamer.com:443 (191) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 12:29:25 * HTTPS connection to ameritrade02.streamer.com:443 (191) | Received socket Close event | 2017-03-01 12:29:25 HTTPS connection to ameritrade02.streamer.com:443 (191) | Closed. | 2017-03-01 12:29:25 HTTPS connection to ameritrade02.streamer.com:443 (193) | Initiating close of socket by core. | 2017-03-01 12:32:25 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 80. | 2017-03-01 12:32:25 HTTPS connection to ameritrade02.streamer.com:443 (193) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:32:25 TD Ameritrade | Streamer request #81 initiated. | 2017-03-01 12:32:27 HTTPS connection to ameritrade02.streamer.com:443 (195) | Creating socket. Using TLS 1.0. | 2017-03-01 12:32:27 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 12:32:28 HTTPS connection to ameritrade02.streamer.com:443 (193) | Socket gracefully closed by remote side. | 2017-03-01 12:32:46 HTTPS connection to ameritrade02.streamer.com:443 (193) | Closed. | 2017-03-01 12:32:46 HTTPS connection to ameritrade02.streamer.com:443 (195) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 12:33:22 HTTPS connection to ameritrade02.streamer.com:443 (195) | Initiating close of socket by core. | 2017-03-01 12:33:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 81. | 2017-03-01 12:33:22 HTTPS connection to ameritrade02.streamer.com:443 (195) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:33:22 TD Ameritrade | Streamer request #82 initiated. | 2017-03-01 12:33:24 HTTPS connection to ameritrade02.streamer.com:443 (197) | Creating socket. Using TLS 1.0. | 2017-03-01 12:33:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 12:33:25 HTTPS connection to ameritrade02.streamer.com:443 (195) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 12:33:25 * HTTPS connection to ameritrade02.streamer.com:443 (195) | Received socket Close event | 2017-03-01 12:33:25 HTTPS connection to ameritrade02.streamer.com:443 (195) | Closed. | 2017-03-01 12:33:25 HTTPS connection to ameritrade02.streamer.com:443 (197) | Received socket Close event | 2017-03-01 12:33:41 HTTPS connection to ameritrade02.streamer.com:443 (197) | Socket gracefully closed by remote side. | 2017-03-01 12:33:41 HTTPS connection to ameritrade02.streamer.com:443 (197) | Initiating close of socket by core. | 2017-03-01 12:33:41 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 82. | 2017-03-01 12:33:41 HTTPS connection to ameritrade02.streamer.com:443 (197) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-03-01 12:33:41 HTTPS connection to ameritrade02.streamer.com:443 (197) | Closed. | 2017-03-01 12:33:41 TD Ameritrade | Streamer request #83 initiated. | 2017-03-01 12:33:43 HTTPS connection to ameritrade02.streamer.com:443 (198) | Creating socket. Using TLS 1.0. | 2017-03-01 12:33:43 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 12:33:44 HTTPS connection to ameritrade02.streamer.com:443 (198) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 12:35:22 HTTPS connection to ameritrade02.streamer.com:443 (198) | Initiating close of socket by core. | 2017-03-01 12:35:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 83. | 2017-03-01 12:35:22 HTTPS connection to ameritrade02.streamer.com:443 (198) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:35:22 TD Ameritrade | Streamer request #84 initiated. | 2017-03-01 12:35:25 HTTPS connection to ameritrade02.streamer.com:443 (200) | Creating socket. Using TLS 1.0. | 2017-03-01 12:35:25 HTTPS connection to ameritrade02.streamer.com:443 (198) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 12:35:25 * HTTPS connection to ameritrade02.streamer.com:443 (198) | Received socket Close event | 2017-03-01 12:35:25 HTTPS connection to ameritrade02.streamer.com:443 (198) | Closed. | 2017-03-01 12:35:25 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 12:35:25 HTTPS connection to ameritrade02.streamer.com:443 (200) | Initiating close of socket by core. | 2017-03-01 12:38:25 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 84. | 2017-03-01 12:38:25 HTTPS connection to ameritrade02.streamer.com:443 (200) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:38:26 TD Ameritrade | Streamer request #85 initiated. | 2017-03-01 12:38:27 HTTPS connection to ameritrade02.streamer.com:443 (203) | Creating socket. Using TLS 1.0. | 2017-03-01 12:38:27 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 12:38:28 HTTPS connection to ameritrade02.streamer.com:443 (200) | Socket gracefully closed by remote side. | 2017-03-01 12:38:46 HTTPS connection to ameritrade02.streamer.com:443 (200) | Closed. | 2017-03-01 12:38:46 HTTPS connection to ameritrade02.streamer.com:443 (203) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 12:39:22 HTTPS connection to ameritrade02.streamer.com:443 (203) | Initiating close of socket by core. | 2017-03-01 12:39:22 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 85. | 2017-03-01 12:39:22 HTTPS connection to ameritrade02.streamer.com:443 (203) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:39:22 TD Ameritrade | Streamer request #86 initiated. | 2017-03-01 12:39:24 HTTPS connection to ameritrade02.streamer.com:443 (205) | Creating socket. Using TLS 1.0. | 2017-03-01 12:39:24 HTTPS connection to ameritrade02.streamer.com:443 (203) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 12:39:25 * HTTPS connection to ameritrade02.streamer.com:443 (203) | Received socket Close event | 2017-03-01 12:39:25 HTTPS connection to ameritrade02.streamer.com:443 (203) | Closed. | 2017-03-01 12:39:25 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 12:39:25 HTTPS connection to ameritrade02.streamer.com:443 (205) | Socket gracefully closed by remote side. | 2017-03-01 12:39:30 HTTPS connection to ameritrade02.streamer.com:443 (205) | Initiating close of socket by core. | 2017-03-01 12:39:30 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 86. | 2017-03-01 12:39:30 HTTPS connection to ameritrade02.streamer.com:443 (205) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-03-01 12:39:30 HTTPS connection to ameritrade02.streamer.com:443 (205) | Closed. | 2017-03-01 12:39:30 TD Ameritrade | Streamer request #87 initiated. | 2017-03-01 12:39:32 HTTPS connection to ameritrade02.streamer.com:443 (206) | Creating socket. Using TLS 1.0. | 2017-03-01 12:39:32 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 12:39:32 HTTPS connection to ameritrade02.streamer.com:443 (206) | Encryption stream error encountered. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-03-01 12:41:23 HTTPS connection to ameritrade02.streamer.com:443 (206) | Initiating close of socket by core. | 2017-03-01 12:41:23 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 87. | 2017-03-01 12:41:23 HTTPS connection to ameritrade02.streamer.com:443 (206) | Shutdown started. Waiting for graceful close. | 2017-03-01 12:41:23 TD Ameritrade | Streamer request #88 initiated. | 2017-03-01 12:41:25 HTTPS connection to ameritrade02.streamer.com:443 (208) | Creating socket. Using TLS 1.0. | 2017-03-01 12:41:25 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2017-03-01 12:41:25 HTTPS connection to ameritrade02.streamer.com:443 (206) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-03-01 12:41:25 * HTTPS connection to ameritrade02.streamer.com:443 (206) | Received socket Close event | 2017-03-01 12:41:25 HTTPS connection to ameritrade02.streamer.com:443 (206) | Closed. | 2017-03-01 12:41:25 Sierra Chart Support |
[2017-03-01 22:29:42] |
These are the relevant messages: HTTPS connection to ameritrade02.streamer.com:443 (205) | Socket gracefully closed by remote side. | 2017-03-01 12:39:30
HTTPS connection to ameritrade02.streamer.com:443 (205) | Initiating close of socket by core. | 2017-03-01 12:39:30 TD Ameritrade | Streamer request completed unexpectedly. Request ID: 86. | 2017-03-01 12:39:30 HTTPS connection to ameritrade02.streamer.com:443 (205) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-03-01 12:39:30 HTTPS connection to ameritrade02.streamer.com:443 (205) | Closed. | 2017-03-01 12:39:30 TD Ameritrade | Streamer request #87 initiated. | 2017-03-01 12:39:32 You have a connectivity problem to the TD Ameritrade server or there is a problem with the TD Ameritrade server which we cannot help with. Refer to help topic 1.2: https://www.sierrachart.com/index.php?page=doc/helpdetails1.php#h1.2 We recommend that you switch to a different broker because we have no ability to help you in this particular case beyond what we are saying in the next sentence. For the time being, just connect once a month to TD Ameritrade in order to take advantage of the lower-priced CME exchange fee. Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#ConnectingOnlyOnceAMonthToTradingAccount You have had ongoing issues maintaining a connection to TD Ameritrade for a long time now. We cannot help with these. You are going to continue to suffer this problem until you switch to a different broker or you just connect once a month to TD Ameritrade. Once again we cannot solve this problem. Refer to the list of supported trading services/brokers here: https://www.sierrachart.com/index.php?page=doc/Data.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-01 22:31:44
